MeshKit
1.0
00001 #ifndef __SURFPROHARMONICMAP_HPP 00002 #define __SURFPROHARMONICMAP_HPP 00003 00004 #include <stdlib.h> 00005 #include <stdio.h> 00006 #include <assert.h> 00007 #include <string> 00008 #include <iostream> 00009 #include <fstream> 00010 #include <string.h> 00011 #include <limits.h> 00012 00013 #include "meshkit/MKCore.hpp" 00014 #include "meshkit/iMesh.hpp" 00015 #include "meshkit/iGeom.hpp" 00016 #include "meshkit/iRel.hpp" 00017 #include "meshkit/MeshOp.hpp" 00018 #include "meshkit/ModelEnt.hpp" 00019 #include "meshkit/SimpleArray.hpp" 00020 #include "Global.hpp" 00021 #include "HarmonicMapper.hpp" 00022 #include <set> 00023 #include <vector> 00024 #include <map> 00025 00026 00027 using namespace std; 00028 00029 namespace MeshKit { 00030 00031 class SurfProHarmonicMap 00032 { 00033 public: 00034 //public function 00035 SurfProHarmonicMap(MKCore* core, iBase_EntityHandle s, iBase_EntityHandle t, iBase_EntityHandle v); 00036 ~SurfProHarmonicMap(); 00037 void match(); 00038 void projection(); 00039 void setMeshData(vector<Vertex> &s, vector<Vertex> &t, vector<Face> &f); 00040 void getMeshData(vector<Vertex> &v); 00041 private: 00042 void preprocessing(); 00043 void addFaceToList(iBase_EntityHandle entity, Face& f, int index, bool is_set_int); 00044 void GetGeomLoops(Face surf, vector<vector<int> > &loops_vertex, vector<vector<int> > &loops_edge); 00045 void postProcessGeomLoops(Face& surf); 00046 void getFacets(); 00047 void MapFacetGeom(Face f_surf, vector<Vertex> facet_node, std::map<int, int> &map_data, vector<list<int> > &geom_facet, int size_facet_v); 00048 //boundary distribution of the outmost boundary on the unit disk 00049 void boundaryDistribution(); 00050 //distribute facet vertices of outmost boundary on an unit disk 00051 void boundaryUnitDisk(Face f, vector<double> dist, vector<Vertex> &facet_v, std::vector<std::list<int> > geom_facet); 00052 //establish the correspondence of boundary vertices on the outmost boundary 00053 void LocateBoundaryNodesTarget(); 00054 //Distribute the interior nodes on the unit disk 00055 void test(); 00056 //compute the weight for each edge 00057 void ComputeWeight(); 00058 //add the facet edge to the list 00059 void addEdgeToList(int a, int b, int &count, vector<set<int> > &edge_connect, vector<Edge> &f_edges, vector<Vertex> &facet_v); 00060 //compute the edge weight 00061 void computeEdgeWeight(vector<Edge> &f_edges, vector<Face> &f, vector<Vertex> f_v); 00062 //add extra stuff to the facet mesh 00063 void addExtra(Face f, vector<Vertex> &facet_v, vector<Edge> &facet_e, vector<Face> &facet_tri, vector<list<int> > geom_facet, int size_facet_v); 00064 //find a specific triangle where a point is located 00065 int findFacetTri(vector<Face> &facet_tri, vector<Vector3D> nrml, Vector3D xyz, Vector3D &uvw); 00066 int findFacetTri(vector<Face> &facet_tri, Vector2D uv, Vector3D &uvw); 00067 void prjPtsToTri(Face tri, Vector3D pts, Vector3D nrml, Vector3D &xyz); 00068 bool ComputeBarycentric(Vector3D a, Vector3D b, Vector3D c, Vector3D xyz, Vector3D &uvw); 00069 bool ComputeBarycentric(Vector2D a, Vector2D b, Vector2D c, Vector2D xy, Vector3D &uvw); 00070 void computeNormalTri(Face &tri, Vector3D& nrml, Face surf); 00071 void cleanup(); 00072 void adjustVtxEdges(Face &f); 00073 private: 00074 //member variables 00075 MKCore* mk_core; 00076 00077 Face source; 00078 Face target; 00079 iBase_EntityHandle volume; 00080 vector<Face> link; 00081 vector<Edge> edges; 00082 vector<Vertex> vertices; 00083 iGeom *igeom_instance; 00084 iMesh *imesh_instance; 00085 iRel *irel_instance; 00086 iRel::PairHandle *irel_pair; 00087 iBase_TagHandle global_geom_tag; 00088 iBase_TagHandle global_mesh_tag; 00089 iBase_TagHandle harmonic_surf_pro, facet_mesh_tag; 00090 iGeom::Error g_err; 00091 iMesh::Error m_err; 00092 iRel::Error r_err; 00093 vector<Vertex> src_facet_v; 00094 vector<Vertex> tgt_facet_v; 00095 vector<Face> src_facet_tri; 00096 vector<Face> tgt_facet_tri; 00097 vector<Edge> src_facet_e; 00098 vector<Edge> tgt_facet_e; 00099 vector<set<int> > adj_src, adj_tgt; 00100 int size_src_v, size_src_e, size_src_f; 00101 int size_tgt_v, size_tgt_e, size_tgt_f; 00102 //map between geometry and facet 00103 std::map<int, int> src_facet_geom, tgt_facet_geom; 00104 std::vector<std::list<int> > src_geom_facet, tgt_geom_facet; 00105 00106 vector<Vertex> quad_mesh_src, quad_mesh_tgt; 00107 00108 vector<Face> facelist; 00109 00110 }; 00111 00112 } 00113 #endif 00114
