MeshKit
1.0
00001 #include <iostream> 00002 #include <iomanip> // for setprecision 00003 #include <limits> // for double min/max 00004 #include <assert.h> 00005 #include <vector> 00006 #include "moab/Range.hpp" 00007 #include "moab/AdaptiveKDTree.hpp" 00008 #include "meshkit/arc.hpp" 00009 #include "meshkit/zip.hpp" 00010 #include "meshkit/gen.hpp" 00011 00012 #include "moab/GeomTopoTool.hpp" 00013 #include "moab/FileOptions.hpp" 00014 00015 using namespace moab; 00016 namespace arc { 00017 00018 ErrorCode orient_edge_with_tri( const EntityHandle edge, const EntityHandle tri ) { 00019 ErrorCode result; 00020 // get the connected vertices, properly ordered 00021 const EntityHandle *tri_conn; 00022 int n_verts; 00023 result = MBI()->get_connectivity( tri, tri_conn, n_verts ); 00024 assert(MB_SUCCESS == result); 00025 assert( 3 == n_verts ); 00026 00027 // get the endpoints of the edge 00028 const EntityHandle *edge_conn; 00029 result = MBI()->get_connectivity( edge, edge_conn, n_verts ); 00030 assert(MB_SUCCESS == result); 00031 assert( 2 == n_verts ); 00032 00033 // if the edge is backwards, reverse it 00034 if (( edge_conn[0]==tri_conn[0] && edge_conn[1]==tri_conn[2] ) || 00035 ( edge_conn[0]==tri_conn[1] && edge_conn[1]==tri_conn[0] ) || 00036 ( edge_conn[0]==tri_conn[2] && edge_conn[1]==tri_conn[1] ) ) { 00037 EntityHandle new_conn[2]; 00038 new_conn[0] = edge_conn[1]; 00039 new_conn[1] = edge_conn[0]; 00040 result = MBI()->set_connectivity( edge, new_conn, 2 ); 00041 assert(MB_SUCCESS == result); 00042 } 00043 return result; 00044 } 00045 00046 // Degenerate edges (same topological endpts) are caused by a prior step in which 00047 // coincident verts are merged. 00048 ErrorCode remove_degenerate_edges( Range &edges, const bool debug ) { 00049 Range::iterator i = edges.begin(); 00050 while (i!=edges.end()) { 00051 // get the endpoints of the edge 00052 ErrorCode rval; 00053 const EntityHandle *endpts; 00054 int n_verts; 00055 rval = MBI()->get_connectivity( *i, endpts, n_verts ); 00056 if(gen::error(MB_SUCCESS!=rval,"could not get connectivity")) 00057 return rval; 00058 00059 // remove the edge if degenerate 00060 if(2==n_verts && endpts[0]!=endpts[1]) { 00061 ++i; 00062 } else if( (2==n_verts && endpts[0]==endpts[1]) || 00063 (1==n_verts ) ) { 00064 if(debug) { 00065 std::cout << "remove_degenerate_edges: deleting degenerate edge and tris " 00066 << std::endl; 00067 } 00068 rval = zip::delete_adj_degenerate_tris( endpts[0] ); 00069 if(gen::error(MB_SUCCESS!=rval,"could not delete degenerate tris")) return rval; 00070 rval = MBI()->delete_entities( &(*i), 1 ); 00071 if(gen::error(MB_SUCCESS!=rval,"could not delete degenerate edge")) return rval; 00072 i = edges.erase(i); 00073 } else { 00074 std::cout << "remove_degenerate_edge: wrong edge connectivity size" << std::endl; 00075 return MB_FAILURE; 00076 } 00077 00078 } 00079 return MB_SUCCESS; 00080 } 00081 00082 00083 // Given a range of edges, remove pairs that have vertices (a,b) (b,a) 00084 ErrorCode remove_opposite_pairs_of_edges( Range &edges, const bool debug ) { 00085 00086 // do this in O(n) by using adjacencies instead of O(n^2) 00087 ErrorCode result; 00088 //for(Range::iterator i=edges.begin(); i!=edges.end(); i++ ) { 00089 for(unsigned int i=0; i<edges.size(); i++) { 00090 EntityHandle the_edge = edges[i]; 00091 00092 // get endpoint verts 00093 Range two_verts; 00094 result = MBI()->get_adjacencies( &the_edge, 1, 0, false, two_verts); 00095 if(MB_SUCCESS != result) { 00096 std::cout << "result=" << result << " could not get adjacencies of edge" << std::endl; 00097 return result; 00098 } 00099 00100 // get adjacent edges, but only keep the edges adjacent to both verts 00101 Range adj_edges; 00102 result = MBI()->get_adjacencies( two_verts, 1, false, adj_edges, Interface::INTERSECT); 00103 assert(MB_SUCCESS == result); 00104 // remove the original edge 00105 //adj_edges.erase( *i ); 00106 00107 // if any other edges exist, they are opposite the original edge and should be 00108 // removed from the skin 00109 if ( 1<adj_edges.size() ) { 00110 if(debug) { 00111 std::cout << adj_edges.size() 00112 << " opposite edges will be removed from the surface skin " 00113 << adj_edges[0] << " " << adj_edges[1] << std::endl; 00114 } 00115 //gen::print_range_of_edges( adj_edges ); 00116 //gen::print_range_of_edges( edges ); 00117 //edges = edges.subtract( adj_edges ); 00118 //edges.erase( *i ); 00119 edges = subtract( edges, adj_edges ); 00120 result = MBI()->delete_entities( adj_edges ); 00121 assert(MB_SUCCESS == result); 00122 i--; 00123 } 00124 } 00125 return MB_SUCCESS; 00126 } 00127 00128 ErrorCode remove_opposite_pairs_of_edges_fast( Range &edges, const bool debug) { 00129 // special case 00130 ErrorCode rval; 00131 if(1==edges.size()) { 00132 std::cout << "cannot remove pairs: only one input edge" << std::endl; 00133 return MB_FAILURE; 00134 } 00135 00136 // populate edge array, used only for searching 00137 unsigned n_orig_edges = edges.size(); 00138 gen::edge *my_edges = new gen::edge[n_orig_edges]; 00139 unsigned j = 0; 00140 for(Range::const_iterator i=edges.begin(); i!=edges.end(); ++i) { 00141 // get the endpoints of the edge 00142 const EntityHandle *endpts; 00143 int n_verts; 00144 rval = MBI()->get_connectivity( *i, endpts, n_verts ); 00145 if(gen::error(MB_SUCCESS!=rval || 2!=n_verts,"could not get connectivity")) 00146 return rval; 00147 00148 // store the edges 00149 my_edges[j].e = *i; 00150 my_edges[j].v0 = endpts[0]; 00151 my_edges[j].v1 = endpts[1]; 00152 00153 // sort edge by handle 00154 if(my_edges[j].v1 < my_edges[j].v0) { 00155 EntityHandle temp = my_edges[j].v0; 00156 my_edges[j].v0 = my_edges[j].v1; 00157 my_edges[j].v1 = temp; 00158 } 00159 ++j; 00160 } 00161 00162 // sort edge array 00163 qsort(my_edges, n_orig_edges, sizeof(struct gen::edge), gen::compare_edge); 00164 00165 // find duplicate edges 00166 j=0; 00167 Range duplicate_edges; 00168 for(unsigned i=1; i<n_orig_edges; ++i) { 00169 // delete edge if a match exists 00170 if(my_edges[j].v0==my_edges[i].v0 && my_edges[j].v1==my_edges[i].v1) { 00171 duplicate_edges.insert( my_edges[j].e ); 00172 // find any remaining matches 00173 while( my_edges[j].v0==my_edges[i].v0 && 00174 my_edges[j].v1==my_edges[i].v1 && 00175 i<n_orig_edges) { 00176 duplicate_edges.insert( my_edges[i].e ); 00177 ++i; 00178 } 00179 // delete the matches 00180 edges = subtract( edges, duplicate_edges ); 00181 rval = MBI()->delete_entities( duplicate_edges ); 00182 if(gen::error(MB_SUCCESS!=rval,"cannot delete edge")) { 00183 delete[] my_edges; 00184 return rval; 00185 } 00186 if(debug) { 00187 std::cout << "remove_opposite_edges: deleting " << duplicate_edges.size() 00188 << " edges" << std::endl; 00189 } 00190 duplicate_edges.clear(); 00191 } 00192 j = i; 00193 } 00194 00195 delete[] my_edges; 00196 return MB_SUCCESS; 00197 } 00198 00199 ErrorCode get_next_oriented_edge( const Range edges, const EntityHandle edge, 00200 EntityHandle &next_edge ) { 00201 00202 // get the back vertex 00203 ErrorCode result; 00204 const EntityHandle *end_verts; 00205 int n_verts; 00206 result = MBI()->get_connectivity( edge, end_verts, n_verts ); 00207 assert(MB_SUCCESS==result); 00208 assert( 2 == n_verts ); 00209 00210 // get the edges adjacent to the back vertex 00211 Range adj_edges; 00212 result = MBI()->get_adjacencies( &(end_verts[1]), 1, 1, false, adj_edges ); 00213 assert(MB_SUCCESS==result); 00214 00215 // keep the edges that are part of the input range 00216 adj_edges = intersect( adj_edges, edges ); 00217 // don't want the input edge 00218 adj_edges.erase( edge ); 00219 00220 // make sure the edge is oriented correctly 00221 for(Range::iterator i=adj_edges.begin(); i!=adj_edges.end(); i++) { 00222 const EntityHandle *adj_end_verts; 00223 result = MBI()->get_connectivity( *i, adj_end_verts, n_verts ); 00224 if(MB_SUCCESS != result) { 00225 MBI()->list_entity(*i); 00226 std::cout << "result=" << result 00227 << " could not get connectivity of edge" << std::endl; 00228 return result; 00229 //gen::print_edge( *i ); 00230 } 00231 assert(MB_SUCCESS==result); 00232 assert( 2 == n_verts ); 00233 if ( end_verts[1]!=adj_end_verts[0] ) i = adj_edges.erase(i) - 1; 00234 } 00235 00236 /* The next edge could be ambiguous if more than one exists.This happens in 00237 surfaces that are ~1D, and in surfaces that have pinch points 00238 (mod13surf881). Although I didn't handle this case yet, if it occurs: 00239 -Remember that a pinch point could have not just 2, but multiple ears. 00240 -Select the next edge as the edge that shares the same triangle. 00241 -This approach will only work if the pinch point also exists in the 00242 geometric curves. 00243 -If the pinch point does not exist in the geometric curves (~1D surfs), 00244 there is no robust way to handle it. There should be an input assumption 00245 that this never happens. "The faceting skin cannot have pinch points 00246 unless they also occur in the surface's geometric curves." 00247 */ 00248 if ( 0==adj_edges.size() ) { 00249 next_edge = 0; 00250 } else if ( 1==adj_edges.size() ) { 00251 next_edge = adj_edges.front(); 00252 } else { 00253 std::cout << "get_next_oriented_edge: " << adj_edges.size() << 00254 " possible edges indicates a pinch point." << std::endl; 00255 result = MBI()->list_entity( end_verts[1] ); 00256 //assert(MB_SUCCESS == result); 00257 //return MB_MULTIPLE_ENTITIES_FOUND; 00258 next_edge = adj_edges.front(); 00259 } 00260 return MB_SUCCESS; 00261 } 00262 00263 ErrorCode create_loops_from_oriented_edges_fast( Range edges, 00264 std::vector< std::vector<EntityHandle> > &loops_of_edges, 00265 const bool debug ) { 00266 // place all edges in map 00267 std::multimap<EntityHandle,gen::edge> my_edges; 00268 ErrorCode rval; 00269 for(Range::const_iterator i=edges.begin(); i!=edges.end(); ++i) { 00270 // get the endpoints of the edge 00271 const EntityHandle *endpts; 00272 int n_verts; 00273 rval = MBI()->get_connectivity( *i, endpts, n_verts ); 00274 if(gen::error(MB_SUCCESS!=rval || 2!=n_verts,"could not get connectivity")) 00275 return rval; 00276 00277 // store the edges 00278 gen::edge temp; 00279 temp.e = *i; 00280 temp.v0 = endpts[0]; 00281 temp.v1 = endpts[1]; 00282 my_edges.insert( std::pair<EntityHandle,gen::edge>(temp.v0,temp) ); 00283 } 00284 std::cout << "error: function not complete" << std::endl; 00285 return MB_FAILURE; 00286 00287 return MB_SUCCESS; 00288 } 00289 00290 // This function should be rewritten using multimaps or something to avoid 00291 // upward adjacency searching. Vertices are searched for their adjacent edges. 00292 ErrorCode create_loops_from_oriented_edges( Range edges, 00293 std::vector< std::vector<EntityHandle> > &loops_of_edges, 00294 const bool debug ) { 00295 00296 // conserve edges 00297 ErrorCode result; 00298 unsigned int n_edges_in = edges.size(); 00299 unsigned int n_edges_out = 0; 00300 //gen::print_range_of_edges( edges ); 00301 // there could be several arcs for each surface 00302 while ( 0!= edges.size() ) { 00303 std::vector<EntityHandle> loop_of_edges; 00304 // pick initial edge and point 00305 EntityHandle edge = edges.front(); 00306 00307 // 20091201 Update: Pinch points may not be important. If not, there is no 00308 // purpose detecting them. Instead assume that pinch points coincide with 00309 // the endpoints of geometric curves. Also assume that the loop creation at 00310 // pinch points does not matter. Pinch points can result in one or more 00311 // loops, depending upon the path of traversal through the point. 00312 00313 // Check to make sure the beginning endpt of the first edge is not a pinch 00314 // point. If it is a pinch point the loop is ambiguous. Maybe--see watertightness notes for 20091201 00315 { 00316 const EntityHandle *end_verts; 00317 int n_verts; 00318 result = MBI()->get_connectivity( edge, end_verts, n_verts ); 00319 assert(MB_SUCCESS==result); 00320 assert( 2 == n_verts ); 00321 // get the edges adjacent to the back vertex 00322 Range adj_edges; 00323 result = MBI()->get_adjacencies( &(end_verts[0]), 1, 1, false, adj_edges ); 00324 assert(MB_SUCCESS==result); 00325 // keep the edges that are part of the input range 00326 adj_edges = intersect( adj_edges, edges ); 00327 if(2!=adj_edges.size() && debug) { 00328 std::cout << " create_loops: adj_edges.size()=" << adj_edges.size() << std::endl; 00329 std::cout << " create_loops: pinch point exists" << std::endl; 00330 result = MBI()->list_entity( end_verts[0] ); 00331 assert(MB_SUCCESS == result); 00332 //return MB_MULTIPLE_ENTITIES_FOUND; 00333 } 00334 } 00335 00336 // add it to the loop 00337 loop_of_edges.push_back( edge ); 00338 if(debug) std::cout << "push_back: " << edge << std::endl; 00339 n_edges_out++; 00340 edges.erase( edge ); 00341 00342 // find connected edges and add to the loop 00343 EntityHandle next_edge = 0; 00344 while (true) { 00345 00346 // get the next vertex and next edge 00347 result = get_next_oriented_edge( edges, edge, next_edge ); 00348 if(MB_ENTITY_NOT_FOUND == result) { 00349 return result; 00350 } else if(MB_SUCCESS != result) { 00351 gen::print_arc_of_edges( loop_of_edges ); 00352 return result; 00353 } 00354 //assert( MB_SUCCESS == result ); 00355 00356 // if the next edge was found 00357 if ( 0!=next_edge ) { 00358 // add it to the loop 00359 loop_of_edges.push_back( next_edge ); 00360 if(debug) std::cout << "push_back: " << next_edge << std::endl; 00361 n_edges_out++; 00362 00363 // remove the edge from the possible edges 00364 edges.erase( next_edge ); 00365 00366 // set the new reference vertex 00367 //vert = next_vert; 00368 edge = next_edge; 00369 00370 // if another edge was not found 00371 } else { 00372 break; 00373 00374 } 00375 } 00376 00377 // check to ensure the arc is closed 00378 Range first_edge; 00379 first_edge.insert( loop_of_edges.front() ); 00380 result = get_next_oriented_edge( first_edge, loop_of_edges.back(), next_edge ); 00381 assert(MB_SUCCESS == result); 00382 if(next_edge != first_edge.front()) { 00383 std::cout << "create_loops: loop is not closed" << std::endl; 00384 gen::print_arc_of_edges(loop_of_edges); 00385 return MB_FAILURE; 00386 } 00387 00388 // add the current arc to the vector of arcs 00389 loops_of_edges.push_back(loop_of_edges); 00390 } 00391 00392 // check to make sure that we have the same number of verts as we started with 00393 if(gen::error(n_edges_in!=n_edges_out,"edges not conserved")) return MB_FAILURE; 00394 assert( n_edges_in == n_edges_out ); 00395 00396 return MB_SUCCESS; 00397 } 00398 00399 // return a set of ordered_verts and remaining unordered_edges 00400 ErrorCode order_verts_by_edge( Range unordered_edges, 00401 std::vector<EntityHandle> &ordered_verts ) { 00402 if(unordered_edges.empty()) return MB_SUCCESS; 00403 00404 // get the endpoints of the curve. It should have 2 endpoints, unless is it a circle. 00405 Range end_verts; 00406 Skinner tool(MBI()); 00407 ErrorCode result; 00408 result = tool.find_skin( 0 , unordered_edges, 0, end_verts, false ); 00409 if(MB_SUCCESS != result) gen::print_range_of_edges( unordered_edges ); 00410 assert(MB_SUCCESS == result); 00411 00412 // start with one endpoint 00413 EntityHandle vert, edge; 00414 if(2 == end_verts.size()) { 00415 vert = end_verts.front(); 00416 } else if (0 == end_verts.size()) { 00417 result = MBI()->get_adjacencies( &unordered_edges.front(), 1, 0, false, end_verts ); 00418 assert(MB_SUCCESS == result); 00419 assert(2 == end_verts.size()); 00420 vert = end_verts.front(); 00421 } else return MB_FAILURE; 00422 00423 // build the ordered set of verts. It will be as large as the number 00424 // of edges, plus one extra endpoint. 00425 ordered_verts.clear(); 00426 ordered_verts.push_back( vert ); 00427 00428 // this cannot be used if multiple loops exist 00429 while(!unordered_edges.empty()) { 00430 // get an edge of the vert 00431 Range adj_edges; 00432 result = MBI()->get_adjacencies( &vert, 1, 1, false, adj_edges ); 00433 assert(MB_SUCCESS == result); 00434 adj_edges = intersect( adj_edges, unordered_edges ); 00435 //assert(!adj_edges.empty()); 00436 if(adj_edges.empty()) { 00437 std::cout << " order_verts_by_edgs: adj_edges is empty" << std::endl; 00438 return MB_FAILURE; 00439 } 00440 edge = adj_edges.front(); 00441 unordered_edges.erase( edge ); 00442 00443 // get the next vert 00444 end_verts.clear(); 00445 result = MBI()->get_adjacencies( &edge, 1, 0, false, end_verts ); 00446 assert(MB_SUCCESS == result); 00447 if(2 != end_verts.size()) { 00448 std::cout << "end_verts.size()=" << end_verts.size() << std::endl; 00449 gen::print_edge( edge ); 00450 } 00451 assert(2 == end_verts.size()); 00452 vert = end_verts.front()==vert ? end_verts.back() : end_verts.front(); 00453 ordered_verts.push_back( vert ); 00454 } 00455 return MB_SUCCESS; 00456 } 00457 00458 ErrorCode get_meshset( const EntityHandle set, std::vector<EntityHandle> &vec) { 00459 ErrorCode result; 00460 vec.clear(); 00461 result = MBI()->get_entities_by_handle( set, vec ); 00462 assert(MB_SUCCESS == result); 00463 return result; 00464 } 00465 00466 ErrorCode set_meshset( const EntityHandle set, const std::vector<EntityHandle> vec) { 00467 ErrorCode result; 00468 result = MBI()->clear_meshset( &set, 1 ); 00469 assert(MB_SUCCESS == result); 00470 result = MBI()->add_entities( set, &vec[0], vec.size() ); 00471 assert(MB_SUCCESS == result); 00472 return result; 00473 } 00474 00475 ErrorCode merge_curves( Range curve_sets, const double facet_tol, 00476 Tag id_tag, Tag merge_tag, const bool debug ) { 00477 // find curve endpoints to add to kd tree 00478 ErrorCode result; 00479 const double SQR_TOL = facet_tol*facet_tol; 00480 Range endpoints; 00481 for(Range::iterator i=curve_sets.begin(); i!=curve_sets.end(); i++) { 00482 std::vector<EntityHandle> curve; 00483 result = get_meshset( *i, curve ); 00484 assert(MB_SUCCESS == result); 00485 //if(2 > curve.size()) continue; 00486 assert(1 < curve.size()); 00487 EntityHandle front_endpt = curve[0]; 00488 EntityHandle back_endpt = curve[curve.size()-1]; 00489 // ADD CODE TO HANDLE SPECIAL CASES!! 00490 if(front_endpt == back_endpt) { // special case 00491 if(0 == gen::length(curve)) { // point curve 00492 } else { // circle 00493 } 00494 } else { // normal curve 00495 endpoints.insert( front_endpt ); 00496 endpoints.insert( back_endpt ); 00497 } 00498 } 00499 00500 // add endpoints to kd-tree. Tree must track ownership to know when verts are 00501 // merged away (deleted). 00502 00503 AdaptiveKDTree kdtree(MBI()); //, 0, MESHSET_TRACK_OWNER); 00504 EntityHandle root; 00505 00506 //set tree options 00507 const char settings[]="MAX_PER_LEAF=1;SPLITS_PER_DIR=1;PLANE_SET=0;MESHSET_FLAGS=0x1;TAG_NAME=0"; 00508 FileOptions fileopts(settings); 00509 00510 /* Old settings for the KD Tree 00511 // initialize settings of the KD Tree 00512 AdaptiveKDTree::Settings settings; 00513 // sets the tree to split any leaves with more than 1 entity 00514 settings.maxEntPerLeaf = 1; 00515 // tells the tree how many candidate planes to consider for each dim of the tree 00516 settings.candidateSplitsPerDir = 1; 00517 // planes are set to be at evenly spaced intervals 00518 settings.candidatePlaneSet = AdaptiveKDTree::SUBDIVISION; 00519 */ 00520 00521 00522 00523 00524 // initialize the tree and pass the root entity handle back into root 00525 result = kdtree.build_tree( endpoints, &root, &fileopts); 00526 assert(MB_SUCCESS == result); 00527 // create tree iterator 00528 AdaptiveKDTreeIter tree_iter; 00529 kdtree.get_tree_iterator( root, tree_iter ); 00530 00531 // search for other endpoints that match each curve's endpoints 00532 for(Range::iterator i=curve_sets.begin(); i!=curve_sets.end(); i++) { 00533 std::vector<EntityHandle> curve_i_verts; 00534 result = get_meshset( *i, curve_i_verts ); 00535 assert(MB_SUCCESS == result); 00536 double curve_length = gen::length( curve_i_verts ); 00537 //if(2 > curve.size()) continue; // HANDLE SPECIAL CASES (add logic) 00538 if(curve_i_verts.empty()) continue; 00539 EntityHandle endpts[2] = { curve_i_verts.front(), curve_i_verts.back() }; 00540 CartVect endpt_coords; 00541 //if( endpts[0] == endpts[1]) continue; // special case of point curve or circle 00542 std::vector<EntityHandle> leaves; 00543 00544 // initialize an array which will contain matched of front points in [0] and 00545 // matches for back points in [1] 00546 Range adj_curves[2]; 00547 // match the front then back endpts 00548 for(unsigned int j=0; j<2; j++) { 00549 result = MBI()->get_coords( &endpts[j], 1, endpt_coords.array()); 00550 assert(MB_SUCCESS == result); 00551 // takes all leaves of the tree within a distance (facet_tol) of the coordinates 00552 // passed in by endpt_coords.array() and returns them in leaves 00553 result = kdtree.distance_search( endpt_coords.array(), 00554 facet_tol, leaves, root ); 00555 assert(MB_SUCCESS == result); 00556 for(unsigned int k=0; k<leaves.size(); k++) { 00557 // retrieve all information about vertices in leaves 00558 std::vector<EntityHandle> leaf_verts; 00559 result = MBI()->get_entities_by_type( leaves[k], MBVERTEX, leaf_verts); 00560 assert(MB_SUCCESS == result); 00561 for(unsigned int l=0; l<leaf_verts.size(); l++) { 00562 double sqr_dist; 00563 result = gen::squared_dist_between_verts( endpts[j], leaf_verts[l], sqr_dist); 00564 assert(MB_SUCCESS == result); 00565 /* Find parent curves. There will be no parent curves if the curve has 00566 already been merged and no longer exists. */ 00567 if(SQR_TOL >= sqr_dist) { 00568 Range temp_curves; 00569 // get the curves for all vertices that are within the squared distance of each other 00570 result = MBI()->get_adjacencies( &leaf_verts[l], 1, 4, false, temp_curves); 00571 assert(MB_SUCCESS == result); 00572 // make sure the sets are curve sets before adding them to the list 00573 // of candidates. 00574 temp_curves = intersect(temp_curves, curve_sets); 00575 adj_curves[j].merge( temp_curves ); 00576 } 00577 } 00578 } 00579 } 00580 00581 // now find the curves that have matching endpts 00582 Range candidate_curves; 00583 // select curves that do not have coincident front AND back points 00584 // place them into candidate curves 00585 candidate_curves =intersect( adj_curves[0], adj_curves[1] ); 00586 if(candidate_curves.empty()) continue; 00587 00588 // subtract the current curve 00589 //int n_before = candidate_curves.size(); 00590 candidate_curves.erase( *i ); 00591 //int n_after = candidate_curves.size(); 00592 00593 00594 // now find curves who's interior vertices are also coincident and merge them 00595 for(Range::iterator j=candidate_curves.begin(); j!=candidate_curves.end(); j++) { 00596 std::vector<EntityHandle> curve_j_verts; 00597 result = get_meshset( *j, curve_j_verts ); 00598 assert(MB_SUCCESS == result); 00599 double j_curve_length = gen::length( curve_j_verts ); 00600 00601 int i_id, j_id; 00602 result = MBI()->tag_get_data( id_tag, &(*i), 1, &i_id ); 00603 assert(MB_SUCCESS == result); 00604 result = MBI()->tag_get_data( id_tag, &(*j), 1, &j_id ); 00605 assert(MB_SUCCESS == result); 00606 if(debug) { 00607 std::cout << "curve i_id=" << i_id << " j_id=" << j_id 00608 << " leng0=" << curve_length << " leng1=" << j_curve_length << std::endl; 00609 } 00610 00611 // reject curves with significantly different length (for efficiency) 00612 if( facet_tol < abs(curve_length - j_curve_length)) continue; 00613 00614 // align j_curve to be the same as i_curve 00615 bool reversed; 00616 if(gen::dist_between_verts(curve_i_verts.front(), curve_j_verts.front()) > 00617 gen::dist_between_verts(curve_i_verts.front(), curve_j_verts.back())) { 00618 reverse( curve_j_verts.begin(), curve_j_verts.end() ); 00619 reversed = true; 00620 } else { 00621 reversed = false; 00622 } 00623 00624 // Reject curves if the average distance between them is greater than 00625 // facet_tol. 00626 double dist; 00627 result = gen::dist_between_arcs( debug, curve_i_verts, curve_j_verts, dist ); 00628 assert(MB_SUCCESS == result); 00629 if( facet_tol < dist ) continue; 00630 00631 // THE CURVE WILL BE MERGED 00632 if (debug) 00633 { 00634 std::cout << " merging curve " << j_id << " to curve " << i_id 00635 << ", dist_between_curves=" << dist << " cm" << std::endl; 00636 } 00637 00638 // Merge the endpts of the curve to preserve topology. Merging (and deleting) 00639 // the endpoints will also remove them from the KDtree so that the merged 00640 // curve cannot be selected again. Update the curves when merging to avoid 00641 // stale info. 00642 if(curve_i_verts.front() != curve_j_verts.front()) { 00643 result = zip::merge_verts( curve_i_verts.front(), curve_j_verts.front(), 00644 curve_i_verts, curve_j_verts ); 00645 if(MB_SUCCESS != result) std::cout << result << std::endl; 00646 assert(MB_SUCCESS == result); 00647 } 00648 if(curve_i_verts.back() != curve_j_verts.back()) { 00649 result = zip::merge_verts( curve_i_verts.back(), curve_j_verts.back(), 00650 curve_i_verts, curve_j_verts ); 00651 if(MB_SUCCESS != result) std::cout << result << std::endl; 00652 assert(MB_SUCCESS == result); 00653 } 00654 00655 // Tag the curve that is merged away. We do not delete it so that its 00656 // parent-child links are preserved. Later, a surface's facets will be 00657 // deleted if all of its curves are deleted or merged with themselves. 00658 // Only after this can the merged away curves be deleted. 00659 result = MBI()->tag_set_data( merge_tag, &(*j), 1, &(*i) ); 00660 assert(MB_SUCCESS == result); 00661 00662 // clear the sets contents 00663 curve_j_verts.clear(); 00664 result = set_meshset( *j, curve_j_verts ); 00665 assert(MB_SUCCESS == result); 00666 00667 // reverse the curve-surf senses if the merged curve was found to be opposite the 00668 // curve we keep 00669 if(reversed) { 00670 std::vector<EntityHandle> surfs; 00671 std::vector<int> senses; 00672 GeomTopoTool gt(MBI(), false); 00673 result = gt.get_senses( *j, surfs, senses ); 00674 if(gen::error(MB_SUCCESS!=result,"failed to get senses")) return result; 00675 for(unsigned k=0; k<surfs.size(); ++k) { 00676 //forward to reverse 00677 if(SENSE_FORWARD==senses[k]) 00678 senses[k] = SENSE_REVERSE; 00679 //reverse to forward 00680 else if(SENSE_REVERSE==senses[k]) 00681 senses[k] = SENSE_FORWARD; 00682 //unknown to unknown 00683 else if(SENSE_UNKNOWN==senses[k]) 00684 senses[k] = SENSE_UNKNOWN; 00685 else 00686 if(gen::error(true,"unrecognized sense")) return MB_FAILURE; 00687 } 00688 result = gt.set_senses( *j, surfs, senses ); 00689 if(gen::error(MB_SUCCESS!=result,"failed to set senses")) return result; 00690 } 00691 00692 } 00693 } 00694 return MB_SUCCESS; 00695 } 00696 00697 00698 00699 }
