MeshKit
1.0
00001 00014 #include "meshkit/MKCore.hpp" 00015 #include "meshkit/FBiGeom.hpp" 00016 #include "meshkit/SizingFunction.hpp" 00017 #include "meshkit/ModelEnt.hpp" 00018 00019 using namespace MeshKit; 00020 00021 #include "stdlib.h" 00022 #include <iostream> 00023 #include <sstream> 00024 #include <fstream> 00025 #include <math.h> 00026 #include <assert.h> 00027 #include <string.h> 00028 #include <stdio.h> 00029 #include <time.h> 00030 #include "moab/CartVect.hpp" 00031 #include "moab/Interface.hpp" 00032 #include "moab/Skinner.hpp" 00033 //#include "MBiMesh.hpp" 00034 #include <vector> 00035 00036 MKCore * mk; 00037 bool save_mesh = true; 00038 //std::string file_name; 00039 std::string bottom_mesh; //="quadsOnBed.vtk"; 00040 std::string top_filename; // "cropSE.h5m", to be smaller 00041 std::string out_mesh; // deleted by default 00042 int nbLayers; 00043 std::vector<double> grades; 00044 00045 bool create_a_set_with_tag_value(iMesh_Instance meshIface, 00046 iBase_EntityHandle * ents, int num_ents, char * tag_name, 00047 int size_name_tag, int value, iBase_EntitySetHandle & mesh_set); 00048 00049 int main(int argc, char *argv[]) 00050 { 00051 // Check command line arg 00052 00053 nbLayers = 5; // a good number of layers 00054 if (argc < 4) { 00055 std::cout << "Usage: " << argv[0] 00056 << " <bottom_mesh> <top_filename> <out_mesh> [-n layers] <ratios> " 00057 00058 << std::endl; 00059 bottom_mesh = (std::string) MESH_DIR + "/" + "quadsOnBed.vtk"; 00060 top_filename = std::string (MESH_DIR) + "/" + "cropSE.h5m"; //, to be smaller 00061 out_mesh = "hexas.h5m"; // deleted by default 00062 std::cout << " Using : " << bottom_mesh << " " << top_filename << " " 00063 << out_mesh << " -n 5" << "\n"; 00064 00065 std::cout << " the default output file is deleted \n"; 00066 } else { 00067 bottom_mesh = argv[1]; 00068 top_filename = argv[2]; 00069 out_mesh = argv[3]; 00070 save_mesh = true; 00071 int argno = 4; 00072 while (argno < argc) { 00073 if (!strcmp(argv[argno], "-n")) { 00074 argno++; 00075 nbLayers = atoi(argv[argno]); 00076 argno++; 00077 } else { 00078 //everything that is not interpreted must be a ratio 00079 grades.push_back(atof(argv[argno])); 00080 argno++; 00081 } 00082 } 00083 } 00084 int nbGrades = (int) grades.size(); 00085 if (nbGrades > 0) { 00086 // add all grades, then divide by total to get the new accumulated ratios 00087 double total = 0.; 00088 int i; 00089 for (i = 0; i < nbGrades; i++) { 00090 total += grades[i]; 00091 //grades[i] = total; // accumulated so far 00092 } 00093 for (i = 0; i < nbGrades; i++) { 00094 grades[i] /= total; 00095 } 00096 nbLayers = nbGrades; 00097 } else { 00098 nbGrades = nbLayers; 00099 for (int i = 0; i < nbLayers; i++) 00100 grades.push_back(1. / nbLayers); 00101 } 00102 00103 clock_t start_time = clock(); 00104 mk = new MKCore; 00105 iBase_ErrorType err; 00106 FBiGeom * fbiGeom = new FBiGeom(); // true for smooth, false for linear 00107 mk->add_igeom_instance(fbiGeom); 00108 // read initial mesh (quad mesh surface bottom) 00109 char opts[]="SMOOTH;"; 00110 err = fbiGeom->load(top_filename.c_str(), opts);// loading the top surface , as geometry 00111 IBERRCHK(err, "Failure to load smooth geometry."); 00112 clock_t load_time1 = clock();// load fb file (expensive), 00113 // load here the quads from bottom 00114 iBase_EntitySetHandle setForQuads; 00115 00116 err = mk->imesh_instance()->createEntSet(false, setForQuads); 00117 IBERRCHK(err, "Failure to create set for loading the quads"); 00118 // load the quads in this set 00119 err = mk->imesh_instance()->load(setForQuads, bottom_mesh.c_str()); 00120 IBERRCHK(err, "Failure to load quad file."); 00121 00122 clock_t load_time2 = clock(); 00123 // and quads file (cheap) 00124 // 00125 double direction[3] = { 0., 0., 1. }; // normalized 00126 00127 // can we get to iMesh from iMesh.hpp? 00128 iMesh_Instance mesh1 = mk->imesh_instance()->instance(); 00129 00130 // first get all nodes from bottom mesh 00131 // get the quads and the vertices in one shot 00132 iBase_EntityHandle *quads = NULL; 00133 int quads_alloc = 0; 00134 iBase_EntityHandle *vert_adj = NULL; 00135 int vert_adj_alloc = 0, vert_adj_size, numQuads; 00136 int * offsets = NULL, offsets_alloc = 0, indices_size; 00137 int * indices = NULL, indices_alloc = 0, offsets_size; 00138 int ierr=0; 00139 iMesh_getAdjEntIndices(mesh1, setForQuads, iBase_FACE, iMesh_QUADRILATERAL, 00140 iBase_VERTEX, &quads, &quads_alloc, &numQuads, &vert_adj, 00141 &vert_adj_alloc, &vert_adj_size, &indices, &indices_alloc, &indices_size, 00142 &offsets, &offsets_alloc, &offsets_size, &ierr); 00143 // create one set with desired tag (1) 00144 iBase_EntitySetHandle mesh_set1; 00145 char nsname[]= "NEUMANN_SET"; 00146 create_a_set_with_tag_value(mesh1, quads, numQuads, nsname , 11, 1, mesh_set1); 00147 /* get the coordinates in one array */ 00148 00149 // delete now the original set? 00150 int vert_coords_alloc = 0; 00151 double * xyz = 0; // not allocated 00152 int vertex_coord_size = 0; 00153 00154 iMesh_getVtxArrCoords(mesh1, vert_adj, vert_adj_size, iBase_INTERLEAVED, 00155 &xyz, &vert_coords_alloc, &vertex_coord_size, &ierr); 00156 //IBERRCHK(err, "failed to get vertex coordinates of entities."); 00157 00158 // then, go to shoot rays to decide the sweeping thickness 00159 int & numNodes = vert_adj_size; // to not change too much 00160 double * dArr = new double[numNodes]; 00161 // then, go to shoot rays 00162 int j = 0; 00163 int numRaysIntersected = 0; 00164 // double factorFloating = (1.-937./1026.); 00165 for (j = 0; j < numNodes; j++) { 00166 //dArr[j] = xyz[j * 3 + 2]; 00167 dArr[j] = 0; // no intersection situation, marked by 0 00168 // for a point, see if it is inside the polygon, with winding number 00169 00170 iBase_StorageOrder order=iBase_INTERLEAVED; 00171 std::vector<iGeom::EntityHandle> entities_out; 00172 std::vector<double> points_out; 00173 std::vector<double> params_out; 00174 00175 double pos[3] = { xyz[3 * j], xyz[3 * j + 1], xyz[3 * j + 2] }; 00176 err= fbiGeom->getPntRayIntsct(pos[0], pos[1], pos[2], direction[0], 00177 direction[1], direction[2], order, entities_out, points_out, 00178 params_out); 00179 // get the first coordinate 00180 if (err != 0 || entities_out.size() < 1) 00181 continue;// we should bail out 00182 //double zTop = points_out[2]; // the z of the top, intersection computation 00183 00184 // consider only the first intersection point 00185 dArr[j] = params_out[0]; // the first intersection only 00186 numRaysIntersected++; 00187 } 00188 // to xyz coordinates, add some thickness, and (thick/layers), to create 00189 // a next layer, and the hexas 00190 iBase_EntityHandle * layer1 = vert_adj; 00191 iBase_EntitySetHandle setForHexas; 00192 00193 err = mk->imesh_instance()->createEntSet(false, setForHexas); 00194 IBERRCHK(err, "Failure to create set for loading the hexas"); 00195 // create in a loop layer 2 , and vertices in layer 2, and hexas 00196 // between layer 1 and layer2 00197 iBase_EntitySetHandle mesh_set2; 00198 for (int i = 0; i < nbLayers; i++) { 00199 for (int j = 0; j < numNodes; j++) { 00200 for (int k = 0; k < 3; k++) 00201 xyz[3 * j + k] += direction[k] * dArr[j] * grades[i]; 00202 } 00203 // now create new vertices at this position, layer 2 00204 iBase_EntityHandle * newVerts = NULL; // no vertices yet 00205 int size1, size2; 00206 iMesh_createVtxArr(mesh1, 00207 /*in*/numNodes, 00208 /*in*/iBase_INTERLEAVED, 00209 /*in*/xyz, 00210 /*in*/numNodes * 3, 00211 /*inout*/&newVerts, 00212 /*inout*/&size1, 00213 /*inout*/&size2, 00214 /*out*/&ierr); 00215 00216 int numHexa = numQuads; 00217 long int * adjacency = new long int[8 * numHexa]; 00218 iBase_EntityHandle * conn = (iBase_EntityHandle *) adjacency; 00219 for (int L = 0; L < numHexa; L++) { 00220 00221 for (int k = 0; k < 4; k++) { 00222 conn[8 * L + k] = layer1[indices[offsets[L] + k]]; 00223 conn[8 * L + k + 4] = newVerts[indices[offsets[L] + k]]; 00224 } 00225 } 00226 00227 int n = numHexa; 00228 int junk1 = n, junk2 = n, junk3 = n, junk4 = n; 00229 int * stat = new int[numHexa]; 00230 int* ptr2 = stat; 00231 //int ierr; 00232 iBase_EntityHandle * new_entity_handles = NULL; 00233 iMesh_createEntArr(mesh1, iMesh_HEXAHEDRON, conn, 8 * n, 00234 &new_entity_handles, &junk1, &junk2, &ptr2, &junk3, &junk4, &ierr); 00235 // add hexas to the setForHexas set 00236 iMesh_addEntArrToSet(mesh1, 00237 new_entity_handles, numHexa, 00238 setForHexas, 00239 &ierr ); 00240 // end copy 00241 // at the end, layer 1 becomes layer 2 00242 layer1 = newVerts; 00243 // if last layer, create top quads too 00244 if (i == nbLayers - 1) { 00245 // last layer, create top quads too 00246 for (int L = 0; L < numQuads; L++) { 00247 00248 for (int k = 0; k < 4; k++) { 00249 //conn[8*L+k] = layer1[ indices[offsets[L]+k ] ]; 00250 conn[4 * L + k] = newVerts[indices[offsets[L] + k]]; 00251 } 00252 } 00253 00254 iMesh_createEntArr(mesh1, iMesh_QUADRILATERAL, conn, 4 * n, 00255 &new_entity_handles, &junk1, &junk2, &ptr2, &junk3, &junk4, &ierr); 00256 // create another set 00257 create_a_set_with_tag_value(mesh1, new_entity_handles, numQuads, 00258 nsname, 11, 2, mesh_set2); // top 00259 } 00260 } 00261 00262 clock_t compute_time = clock(); 00263 00264 // now get MOAB , to use skin on the hexas, to get the rest of quads 00265 moab::Interface * mb = mk->moab_instance(); 00266 // get all hexas, and get the skin 00267 moab::Range hexas, iniQuads; 00268 mb->get_entities_by_type(0, moab::MBHEX, hexas); 00269 mb->get_entities_by_type(0, moab::MBQUAD, iniQuads); 00270 moab::Skinner skinner(mb); 00271 moab::Range allQuads; 00272 skinner.find_skin(0, hexas, 2, allQuads); 00273 00274 moab::Range latQuads = subtract(allQuads, iniQuads); 00275 00276 // add this one too to the hexa set 00277 moab::EntityHandle latSet; 00278 mb->create_meshset(moab::MESHSET_SET, latSet); 00279 mb->add_entities(latSet, latQuads); 00280 00281 // add range and tag 00282 moab::Tag ntag; 00283 mb->tag_get_handle("NEUMANN_SET", 1, 00284 moab::MB_TYPE_INTEGER, ntag); 00285 int val = 3; 00286 mb->tag_set_data(ntag, &latSet, 1, (void*) &val); 00287 00288 // to the hexa set, add chlidren sets, mesh_set1, etc 00289 mb->add_parent_child( (moab::EntityHandle)setForHexas, 00290 (moab::EntityHandle) mesh_set1); 00291 mb->add_parent_child( (moab::EntityHandle)setForHexas, 00292 (moab::EntityHandle) mesh_set2); 00293 mb->add_parent_child( (moab::EntityHandle)setForHexas, 00294 latSet); 00295 00296 delete fbiGeom; 00297 assert(iBase_SUCCESS == err); 00298 iMesh_save(mesh1, setForHexas, out_mesh.c_str(), 0, &ierr, out_mesh.length(), 0); 00299 if (iBase_SUCCESS != err) { 00300 std::cerr << "ERROR saving mesh to " << out_mesh << std::endl; 00301 return 0; 00302 } 00303 clock_t out_time = clock(); 00304 std::cout << "Total time is " << (double) (out_time - start_time) 00305 / CLOCKS_PER_SEC << " s\n load top : " << (double) (load_time1 00306 - start_time) / CLOCKS_PER_SEC << " s\n load bottom : " 00307 << (double) (load_time2 - load_time1) / CLOCKS_PER_SEC 00308 << " s\n compute time : " << (double) (compute_time - load_time2) 00309 / CLOCKS_PER_SEC << " s\n write time : " << (double) (out_time 00310 - compute_time) / CLOCKS_PER_SEC << std::endl; 00311 std::cout << "num rays intersected : " << numRaysIntersected << "\n"; 00312 00313 free(xyz); 00314 delete[] dArr; 00315 00316 if (!save_mesh) 00317 { 00318 remove(out_mesh.c_str()); 00319 } 00320 return 0; 00321 } 00322 00323 // Helper function: usually a NEUMANN set 00324 bool create_a_set_with_tag_value(iMesh_Instance meshIface, 00325 iBase_EntityHandle * ents, int num_ents, char * tag_name, 00326 int size_name_tag, int value, iBase_EntitySetHandle & mesh_set) 00327 { 00328 // will first create a new entity set in the mesh; will add the 00329 // entities; 00330 // will associate the tag with the given value (create the tag if not existent yet) 00331 // NEUMANN_SET 00332 int result = iBase_SUCCESS; 00333 00334 bool isList = false; 00335 //iBase_EntitySetHandle mesh_set; 00336 00337 iMesh_createEntSet(meshIface, isList, &mesh_set, &result); 00338 if (iBase_SUCCESS != result) 00339 return false; 00340 00341 iBase_TagHandle tag_handle; 00342 iMesh_getTagHandle(meshIface, tag_name, &tag_handle, &result, size_name_tag); 00343 assert (0 != tag_handle); 00344 iMesh_setEntSetIntData(meshIface, mesh_set, tag_handle, value, &result); 00345 if (iBase_SUCCESS != result) 00346 return false; 00347 // add the entities to the set 00348 // 00349 iMesh_addEntArrToSet(meshIface, ents, num_ents, mesh_set, &result); 00350 if (iBase_SUCCESS != result) 00351 return false; 00352 00353 return true; 00354 }
