MeshKit
1.0
00001 00015 #include <iostream> 00016 00017 #include <time.h> 00018 #include <stdlib.h> 00019 #include <cstring> 00020 #include <cstring> 00021 00022 #include "meshkit/MKCore.hpp" 00023 #include "meshkit/MeshOp.hpp" 00024 #include "meshkit/ModelEnt.hpp" 00025 #include "meshkit/MBGeomOp.hpp" 00026 00027 using namespace MeshKit; 00028 00029 00030 00031 MKCore *mk; 00032 00033 std::string usage_string = 00034 "<input file> input file \n" 00035 "<output file> Output final model to given file \n" 00036 "\n"; 00037 00038 int main(int argc, char* argv[]) 00039 { 00040 // check command line arg 00041 const char *filename = 0; 00042 const char *outfile = 0; 00043 std::string fstr; 00044 if (argc==3) 00045 { 00046 filename = argv[1]; 00047 outfile = argv[2]; 00048 } 00049 else 00050 { 00051 std::cout << usage_string ; 00052 fstr=(std::string) MESH_DIR + "/partBed.smf"; 00053 std::cout << "using default input file:" << fstr <<", no output\n"; 00054 filename = fstr.c_str(); 00055 } 00056 00057 // initialize everything 00058 00059 mk = new MKCore(); 00060 mk->load_mesh(filename); 00061 MEntVector selection, dum; 00062 mk->get_entities_by_dimension(2, dum); 00063 selection.push_back(*dum.rbegin());// push just the last one retrieved from core 00064 00065 mk->construct_meshop("MBGeomOp", selection); 00066 00067 mk->setup_and_execute(); 00068 00069 if(outfile) 00070 { 00071 std::cout << "writing the set output to " << outfile << std::endl; 00072 moab::EntityHandle outset= (*dum.begin())->mesh_handle(); 00073 mk->moab_instance()->write_mesh(outfile, &outset, 1);// write the original mesh set 00074 // it will write its children too 00075 } 00076 return 0; 00077 00078 } 00079 00080 //process options
