MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/MeshOp.hpp" 00009 #include "meshkit/ModelEnt.hpp" 00010 #include "meshkit/AssyGen.hpp" 00011 #include "TestUtil.hpp" 00012 #include "meshkit/CAMALTetMesher.hpp" 00013 #include "meshkit/CopyGeom.hpp" 00014 00015 using namespace MeshKit; 00016 00017 MKCore *mk; 00018 00019 void test_assygen_default(int argc, char **argv); 00020 00021 int main(int argc, char *argv[]) 00022 { 00023 mk = new MKCore(); 00024 test_assygen_default(argc, argv); 00025 delete mk; 00026 return 0; 00027 } 00028 00029 void test_assygen_default(int argc, char **argv) 00030 { 00031 // create a model entity vector for construting assygen meshop, note that NO model entities are required for assygen meshop. 00032 MEntVector volso; 00033 00034 // construct the meshop and set name 00035 AssyGen *ag = (AssyGen*) mk->construct_meshop("AssyGen", volso); 00036 ag->set_name("assygen"); 00037 00038 // setup input/output assygen files for creating the 'Reactor Assembly' geometry 00039 ag->PrepareIO(argc, argv, TestDir); 00040 ag->setup_this(); 00041 ag->execute_this(); 00042 00043 // // now populate model ents to get the geometry created 00044 // mk->populate_model_ents(0, -1, -1); 00045 00046 // MEntVector vols; 00047 // mk->get_entities_by_dimension(3, vols); 00048 00049 // CopyGeom *cg = (CopyGeom*) mk->construct_meshop("CopyGeom", vols); 00050 // cg->set_name("copy_move_geom"); 00051 00052 // // set the location 00053 // Vector<3> dx; dx[0] = 23.5; dx[1] = 0; dx[2] = 0; 00054 // cg->set_location(dx); 00055 // cg->setup_this(); 00056 // cg->execute_this(); 00057 00058 // // merge and imprint the o/p geometry 00059 // std::vector<iBase_EntityHandle> entities_out; 00060 // mk->igeom_instance()->getEntities(0, iBase_REGION, entities_out); 00061 // double dTol = 1.0e-2; 00062 // mk->igeom_instance()->mergeEnts(&entities_out[0],entities_out.size(), dTol); 00063 00064 // // mk->save_geometry("t.sat"); 00065 // // TODO: mesh using camal and parallel mesher 00066 00067 // delete cg; 00068 delete ag; 00069 } 00070 00071 00072
