MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/SurfaceFacetMeshReader.hpp" 00009 #include "meshkit/CurveFacetMeshReader.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 00012 00013 using namespace MeshKit; 00014 00015 #include "TestUtil.hpp" 00016 00017 MKCore *mk = NULL; 00018 00019 #ifdef HAVE_ACIS 00020 std::string extension = ".sat"; 00021 #elif HAVE_OCC 00022 std::string extension = ".stp"; 00023 #endif 00024 00025 // Basic Tests 00026 void read_cube_tris_test(); 00027 void read_cube_curves_test(); 00028 void read_cube_surfs_test(); 00029 void read_cube_vols_test(); 00030 void read_cube_vertex_pos_test(); 00031 00032 //Connectivity Tests 00033 void cube_verts_connectivity_test(); 00034 void cube_tris_connectivity_test(); 00035 void cube_tri_curve_coincidence_test(); 00036 void cube_edge_adjacencies_test(); 00037 void cube_tri_verts_test(); 00038 00039 //Other functions 00040 int count_topo_for_dim( int dim, iMesh::EntityTopology topo); 00041 void match_tri_edges_w_curves( std::vector<iMesh::EntityHandle> edges, MEntVector curves); 00042 00043 int main(int argc, char **argv) 00044 { 00045 00046 // start up MK and load the geometry 00047 mk = new MKCore(); 00048 00049 std::string filename = "cube" ; 00050 00051 filename = TestDir + "/" + filename + extension; 00052 00053 mk->load_geometry(&filename[0]); 00054 00055 MEntVector surfs; 00056 mk->get_entities_by_dimension(2,surfs); 00057 SurfaceFacetMeshReader *sfmr; 00058 00059 sfmr = (SurfaceFacetMeshReader*) mk->construct_meshop("SurfaceFacetMeshReader", surfs); 00060 00061 double facet_tol = 1e-04, geom_resabs = 1e-06; 00062 sfmr->set_mesh_params(facet_tol, geom_resabs); 00063 00064 mk->setup(); 00065 mk->execute(); 00066 00067 00068 //RUN TESTS 00069 int num_fail = 0; 00070 num_fail += RUN_TEST(read_cube_tris_test); 00071 num_fail += RUN_TEST(read_cube_curves_test); 00072 num_fail += RUN_TEST(read_cube_surfs_test); 00073 num_fail += RUN_TEST(read_cube_vols_test); 00074 num_fail += RUN_TEST(read_cube_vertex_pos_test); 00075 num_fail += RUN_TEST(cube_verts_connectivity_test); 00076 num_fail += RUN_TEST(cube_tris_connectivity_test); 00077 num_fail += RUN_TEST(cube_edge_adjacencies_test); 00078 num_fail += RUN_TEST(cube_tri_verts_test); 00079 00080 return num_fail; 00081 } 00082 00083 00084 //Tests 00085 // NOTE: all tests should be performed using the iMesh interface as that is where our faceted 00086 // information lives. It can, however, be compared to the iGeom information if desired. 00087 00088 00089 void read_cube_tris_test() 00090 { 00091 00092 // get the number of tris in the surface model ents 00093 int num_of_tris = count_topo_for_dim( 2, iMesh_TRIANGLE); 00094 00095 //For a cube, there should be exactly 2 triangles per face, totaling 12 for the cube. 00096 CHECK_EQUAL(12, num_of_tris); 00097 00098 } 00099 00100 void read_cube_curves_test() 00101 { 00102 00103 MEntVector ents; 00104 00105 // there should be 12 curve (dim==1) ModelEnts for a cube 00106 mk->get_entities_by_dimension(1,ents); 00107 00108 int num_of_curves = ents.size(); 00109 00110 CHECK_EQUAL(12, num_of_curves); 00111 } 00112 00113 void read_cube_surfs_test() 00114 { 00115 00116 MEntVector ents; 00117 00118 // there should be 6 surf (dim==1) ModelEnts for a cube 00119 mk->get_entities_by_dimension(2,ents); 00120 00121 int num_of_surfs = ents.size(); 00122 00123 CHECK_EQUAL(6, num_of_surfs); 00124 } 00125 00126 00127 void read_cube_vols_test() 00128 { 00129 00130 MEntVector ents; 00131 00132 // there should be 1 vol (dim==1) ModelEnts for a cube 00133 mk->get_entities_by_dimension(3,ents); 00134 00135 int num_of_surfs = ents.size(); 00136 00137 CHECK_EQUAL(1, num_of_surfs); 00138 } 00139 00140 void read_cube_vertex_pos_test() 00141 { 00142 00143 MEntVector ents; 00144 00145 mk->get_entities_by_dimension(0, ents); 00146 00147 int num_of_verts = ents.size(); 00148 00149 // should be 8 vertex model ents for the cube 00150 CHECK_EQUAL(8, num_of_verts); 00151 00152 // get the vertex coordinates 00153 double x[8]; 00154 double y[8]; 00155 double z[8]; 00156 00157 for(unsigned int i = 0; i < ents.size(); i++) 00158 { 00159 //get the iMesh EntityHandle for the vert 00160 iMesh::EntitySetHandle sh = IBSH(ents[i]->mesh_handle()); 00161 00162 std::vector<iMesh::EntityHandle> vert; 00163 mk->imesh_instance()->getEntities(sh, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, vert); 00164 00165 int vert_size = vert.size(); 00166 // there should only be one entity in this set. If not, there is a problem. 00167 assert(1 == vert_size); 00168 00169 //now get the vertex coords 00170 mk->imesh_instance()->getVtxCoord(vert[0], x[i], y[i], z[i]); 00171 } 00172 00173 //Check against known locations of the vertices 00174 00175 std::vector<double> x_ref; 00176 std::vector<double> y_ref; 00177 std::vector<double> z_ref; 00178 00179 // Vertex 1 00180 x_ref.push_back( 5 ); 00181 y_ref.push_back( -5 ); 00182 z_ref.push_back( 5 ); 00183 00184 // Vertex 2 00185 x_ref.push_back( 5 ); 00186 y_ref.push_back( 5 ); 00187 z_ref.push_back( 5 ); 00188 00189 // Vertex 3 00190 x_ref.push_back( -5 ); 00191 y_ref.push_back( 5 ); 00192 z_ref.push_back( 5 ); 00193 00194 // Vertex 4 00195 x_ref.push_back( -5 ); 00196 y_ref.push_back( -5 ); 00197 z_ref.push_back( 5 ); 00198 00199 // Vertex 5 00200 x_ref.push_back( 5 ); 00201 y_ref.push_back( 5 ); 00202 z_ref.push_back( -5 ); 00203 00204 // Vertex 6 00205 x_ref.push_back( 5 ); 00206 y_ref.push_back( -5 ); 00207 z_ref.push_back( -5 ); 00208 00209 // Vertex 7 00210 x_ref.push_back( -5 ); 00211 y_ref.push_back( -5 ); 00212 z_ref.push_back( -5 ); 00213 00214 // Vertex 8 00215 x_ref.push_back( -5 ); 00216 y_ref.push_back( 5 ); 00217 z_ref.push_back( -5 ); 00218 00219 00220 for(unsigned int i=0; i<ents.size(); i++) 00221 { 00222 for(unsigned int j=0; j<x_ref.size(); j++) 00223 { 00224 if( x[i]==x_ref[j] && y[i]==y_ref[j] && z[i]==z_ref[j] ) 00225 { 00226 x_ref.erase( x_ref.begin()+j ); 00227 y_ref.erase( y_ref.begin()+j ); 00228 z_ref.erase( z_ref.begin()+j ); 00229 } 00230 } 00231 } 00232 00233 //After looping through each vertex loaded from the mesh 00234 //there should be no entities left in the reference vector 00235 int leftovers = x_ref.size(); 00236 CHECK_EQUAL( 0, leftovers ); 00237 00238 } 00239 00240 void cube_verts_connectivity_test() 00241 { 00242 00243 MEntVector verts; 00244 mk->get_entities_by_dimension(0, verts); 00245 00246 MEntVector::iterator i; 00247 for( i = verts.begin(); i != verts.end(); i++) 00248 { 00249 std::vector<iMesh::EntityHandle> adj_tris; 00250 std::vector<int> dum; 00251 iMesh::EntitySetHandle sh = IBSH((*i)->mesh_handle()); 00252 mk->imesh_instance()->getAdjEntities(sh, iBase_ALL_TYPES, iMesh_POINT, iBase_FACE, adj_tris, dum); 00253 00254 int num_adj_tris = adj_tris.size(); 00255 CHECK( num_adj_tris >=4 && num_adj_tris <=6); 00256 00257 } 00258 00259 } 00260 00261 00262 void cube_tris_connectivity_test() 00263 { 00264 00265 //get all triangles from the model ents 00266 MEntVector surfs; 00267 mk->get_entities_by_dimension(2, surfs); 00268 00269 int expected_num_of_adj_tris = 3; 00270 00271 MEntVector::iterator i; 00272 00273 for( i = surfs.begin(); i != surfs.end(); i++) 00274 { 00275 //get the triangles for each surface 00276 std::vector<int> dum; 00277 iMesh::EntitySetHandle sh = IBSH((*i)->mesh_handle()); 00278 std::vector<iMesh::EntityHandle> surf_tris; 00279 mk->imesh_instance()->getEntities( sh, iBase_FACE, iMesh_TRIANGLE, surf_tris); 00280 00281 //each triangle should be adjacent to exactly 3 other triangles 00282 for( std::vector<iMesh::EntityHandle>::iterator j = surf_tris.begin(); 00283 j != surf_tris.end(); j++) 00284 { 00285 std::vector<iMesh::EntityHandle> adjacent_tris; 00286 mk->imesh_instance()->getEnt2ndAdj( *j, iBase_EDGE, iBase_FACE, adjacent_tris); 00287 00288 00289 for(unsigned int k = 0; k < adjacent_tris.size(); k++) 00290 { 00291 00292 iMesh::EntityTopology topo; 00293 mk->imesh_instance()->getEntTopo(adjacent_tris[k], topo); 00294 std::cout << topo <<std::endl; 00295 00296 } 00297 00298 CHECK(expected_num_of_adj_tris == int(adjacent_tris.size())); 00299 } 00300 } 00301 00302 } 00303 00304 void cube_tri_curve_coincidence_test() 00305 { 00306 //get all curves from the mesh 00307 MEntVector curves; 00308 mk->get_entities_by_dimension(1, curves); 00309 00310 //get all triangles from the mesh 00311 std::vector<iMesh::EntityHandle> tris; 00312 mk->imesh_instance()->getEntities(0, iBase_FACE, iMesh_TRIANGLE, tris); 00313 00314 std::vector<iMesh::EntityHandle>::iterator i; 00315 for( i = tris.begin(); i != tris.end(); i++) 00316 { 00317 00318 //get the edges for this triangle 00319 std::vector<iMesh::EntityHandle> tri_edges; 00320 mk->imesh_instance()->getEntAdj( *i, iBase_EDGE, tri_edges); 00321 //make sure we've retrieved two edges for this triangle 00322 CHECK( 2 == int(tri_edges.size()) ); 00323 match_tri_edges_w_curves( tri_edges, curves ); 00324 00325 } 00326 00327 00328 00329 } 00330 00331 void match_tri_edges_w_curves( std::vector<iMesh::EntityHandle> edges, MEntVector curves) 00332 { 00333 00334 int match_counter = 0; 00335 int num_of_tri_edges = edges.size(); 00336 CHECK(num_of_tri_edges); 00337 00338 for(std::vector<iMesh::EntityHandle>::iterator i = edges.begin(); 00339 i != edges.end(); i++) 00340 { 00341 for(MEntVector::iterator j = curves.begin(); j != curves.end(); 00342 j++) 00343 { 00344 //get the curve edges (there should be only one per curve for a cube) 00345 iMesh::EntitySetHandle sh = IBSH((*j)->mesh_handle()); 00346 std::vector<iMesh::EntityHandle> cedges; 00347 mk->imesh_instance()->getEntities( sh, iBase_EDGE, iMesh_LINE_SEGMENT, cedges); 00348 00349 CHECK( 1 == int(cedges.size()) ); 00350 00351 iMesh::EntityHandle curve_edge_handle = cedges[0]; 00352 iMesh::EntityHandle tri_edge_handle = *i; 00353 if( tri_edge_handle == curve_edge_handle ) match_counter++; 00354 } 00355 00356 00357 } 00358 00359 //make sure we found a match for each triangle edge to a curve edge 00360 CHECK( num_of_tri_edges == match_counter ); 00361 } 00362 00363 void cube_edge_adjacencies_test() 00364 { 00365 00366 //get all the curves of the cube 00367 MEntVector curves; 00368 mk->get_entities_by_dimension( 1, curves); 00369 00370 for(MEntVector::iterator i = curves.begin(); i != curves.end(); i++) 00371 { 00372 00373 //get the iMesh set handle for the curve 00374 iMesh::EntitySetHandle sh = IBSH( (*i)->mesh_handle() ); 00375 00376 //get the curve edges 00377 std::vector<iMesh::EntityHandle> curve_edges; 00378 mk->imesh_instance()->getEntities( sh, iBase_EDGE, iMesh_LINE_SEGMENT, curve_edges); 00379 00380 //for a cube there should only be one edge per curve 00381 CHECK( 1 == int(curve_edges.size()) ); 00382 00383 //check that each edge is adjacent to no more than 2 triangles 00384 for(unsigned int i = 0; i < curve_edges.size(); i++) 00385 { 00386 00387 //get the adjacent triangles to the curve edge 00388 std::vector<iMesh::EntityHandle> adj_tris; 00389 mk->imesh_instance()->getEntAdj( curve_edges[i], iBase_FACE, adj_tris ); 00390 00391 //check that the entities returned are triangles 00392 for( unsigned int j = 0; j < adj_tris.size(); j++) 00393 { 00394 iMesh::EntityTopology topo; 00395 mk->imesh_instance()->getEntTopo( adj_tris[j], topo); 00396 CHECK( iMesh_TRIANGLE == topo ); 00397 } 00398 00399 //check that there are no more than two triangles adjacent to this edge 00400 CHECK( 2 <= int(adj_tris.size()) ); 00401 00402 } //end curve edges loop 00403 } // end curves loop 00404 00405 } 00406 00407 void cube_tri_verts_test() 00408 { 00409 00410 //get all of the triangles in the instance 00411 std::vector<iMesh::EntityHandle> tris; 00412 mk->imesh_instance()->getEntities( 0, iBase_FACE, iMesh_TRIANGLE, tris); 00413 00414 std::vector<iMesh::EntityHandle>::iterator i; 00415 for( i = tris.begin(); i != tris.end(); i++) 00416 { 00417 //get the triangle vertices 00418 std::vector<iMesh::EntityHandle> tri_verts; 00419 mk->imesh_instance()->getEntAdj( *i, iBase_VERTEX, tri_verts); 00420 00421 //check that there are three of them 00422 CHECK( 3 == int(tri_verts.size()) ); 00423 //check that none of the vertices are the same 00424 CHECK( tri_verts[0] != tri_verts[1] ); 00425 CHECK( tri_verts[1] != tri_verts[2] ); 00426 CHECK( tri_verts[2] != tri_verts[0] ); 00427 } 00428 00429 } 00430 00431 00432 int count_topo_for_dim( int dim, iMesh::EntityTopology topo) 00433 { 00434 00435 MEntVector ents; 00436 mk->get_entities_by_dimension(dim, ents); 00437 00438 int counter = 0; 00439 00440 for(unsigned int i = 0; i < ents.size(); i++) 00441 { 00442 int temp = 0; 00443 iMesh::EntitySetHandle set_handle = IBSH(ents[i]->mesh_handle()); 00444 mk->imesh_instance()->getNumOfTopo(set_handle, topo, temp); 00445 00446 counter += temp; 00447 temp = 0; 00448 } 00449 00450 return counter; 00451 } 00452
