MeshKit
1.0
00001 00015 #include "meshkit/MKCore.hpp" 00016 #include "meshkit/FBiGeom.hpp" 00017 #include "meshkit/SizingFunction.hpp" 00018 #include "meshkit/ModelEnt.hpp" 00019 00020 using namespace MeshKit; 00021 00022 #include "stdlib.h" 00023 #include <iostream> 00024 #include <sstream> 00025 #include <fstream> 00026 #include <math.h> 00027 #include <assert.h> 00028 #include <string.h> 00029 #include <stdio.h> 00030 #include <time.h> 00031 #include "moab/CartVect.hpp" 00032 #include "moab/Interface.hpp" 00033 #include "moab/Skinner.hpp" 00034 //#include "MBiMesh.hpp" 00035 #include <vector> 00036 #include "TestUtil.hpp" 00037 00038 MKCore * mk; 00039 bool save_mesh = false; 00040 //std::string file_name; 00041 std::string bottom_mesh; //="quadsOnBed.vtk"; 00042 std::string top_filename; // "cropSE.h5m", to be smaller 00043 std::string out_mesh; // deleted by default 00044 int nbLayers; 00045 std::vector<double> grades; 00046 00047 void extrudeQuads(); 00048 // usually a NEUMANN set 00049 bool create_a_set_with_tag_value(iMesh_Instance meshIface, 00050 iBase_EntityHandle * ents, int num_ents, char * tag_name, 00051 int size_name_tag, int value, iBase_EntitySetHandle & mesh_set) 00052 { 00053 // will first create a new entity set in the mesh; will add the 00054 // entities; 00055 // will associate the tag with the given value (create the tag if not existent yet) 00056 // NEUMANN_SET 00057 int result = iBase_SUCCESS; 00058 00059 bool isList = false; 00060 //iBase_EntitySetHandle mesh_set; 00061 00062 iMesh_createEntSet(meshIface, isList, &mesh_set, &result); 00063 if (iBase_SUCCESS != result) 00064 return false; 00065 00066 iBase_TagHandle tag_handle; 00067 iMesh_getTagHandle(meshIface, tag_name, &tag_handle, &result, size_name_tag); 00068 assert (0 != tag_handle); 00069 iMesh_setEntSetIntData(meshIface, mesh_set, tag_handle, value, &result); 00070 if (iBase_SUCCESS != result) 00071 return false; 00072 // add the entities to the set 00073 // 00074 iMesh_addEntArrToSet(meshIface, ents, num_ents, mesh_set, &result); 00075 if (iBase_SUCCESS != result) 00076 return false; 00077 00078 return true; 00079 00080 } 00081 int main(int argc, char *argv[]) 00082 { 00083 // Check command line arg 00084 00085 nbLayers = 5; // a good number of layers 00086 if (argc < 4) { 00087 std::cout << "Usage: " << argv[0] 00088 << " <bottom_mesh> <top_filename> <out_mesh> [-n layers] <ratios> " 00089 00090 << std::endl; 00091 bottom_mesh = TestDir + "/" + "quadsOnBed.vtk"; 00092 top_filename = TestDir + "/" + "cropSE.h5m"; //, to be smaller 00093 out_mesh = "hexas.h5m"; // deleted by default 00094 std::cout << " Using : " << bottom_mesh << " " << top_filename << " " 00095 << out_mesh << " -n 5" << "\n"; 00096 00097 std::cout << " the default output file is deleted \n"; 00098 } else { 00099 bottom_mesh = argv[1]; 00100 top_filename = argv[2]; 00101 out_mesh = argv[3]; 00102 save_mesh = true; 00103 int argno = 4; 00104 while (argno < argc) { 00105 if (!strcmp(argv[argno], "-n")) { 00106 argno++; 00107 nbLayers = atoi(argv[argno]); 00108 argno++; 00109 } else { 00110 //everything that is not interpreted must be a ratio 00111 grades.push_back(atof(argv[argno])); 00112 argno++; 00113 } 00114 } 00115 } 00116 int nbGrades = (int) grades.size(); 00117 if (nbGrades > 0) { 00118 // add all grades, then divide by total to get the new accumulated ratios 00119 double total = 0.; 00120 int i; 00121 for (i = 0; i < nbGrades; i++) { 00122 total += grades[i]; 00123 //grades[i] = total; // accumulated so far 00124 } 00125 for (i = 0; i < nbGrades; i++) { 00126 grades[i] /= total; 00127 } 00128 nbLayers = nbGrades; 00129 } else { 00130 nbGrades = nbLayers; 00131 for (int i = 0; i < nbLayers; i++) 00132 grades.push_back(1. / nbLayers); 00133 } 00134 00135 int num_fail = 0; 00136 num_fail += RUN_TEST(extrudeQuads); 00137 00138 if (!save_mesh) 00139 { 00140 remove(out_mesh.c_str()); 00141 } 00142 return num_fail; 00143 } 00144 void extrudeQuads() 00145 { 00146 clock_t start_time = clock(); 00147 mk = new MKCore; 00148 iBase_ErrorType err; 00149 FBiGeom * fbiGeom = new FBiGeom(); // true for smooth, false for linear 00150 mk->add_igeom_instance(fbiGeom); 00151 // read initial mesh (quad mesh surface bottom) 00152 char opts[]="SMOOTH;"; 00153 err = fbiGeom->load(top_filename.c_str(), opts);// loading the top surface , as geometry 00154 IBERRCHK(err, "Failure to load smooth geometry."); 00155 clock_t load_time1 = clock();// load fb file (expensive), 00156 // load here the quads from bottom 00157 iBase_EntitySetHandle setForQuads; 00158 00159 err = mk->imesh_instance()->createEntSet(false, setForQuads); 00160 IBERRCHK(err, "Failure to create set for loading the quads"); 00161 // load the quads in this set 00162 err = mk->imesh_instance()->load(setForQuads, bottom_mesh.c_str()); 00163 IBERRCHK(err, "Failure to load quad file."); 00164 00165 clock_t load_time2 = clock(); 00166 // and quads file (cheap) 00167 // 00168 double direction[3] = { 0., 0., 1. }; // normalized 00169 // first get all nodes from bottom mesh 00170 /* // get the quads and the vertices in one shot 00171 std::vector<EntityHandle> entities_out; 00172 err = mk->imesh_instance()->getEntities( setForQuads, 00173 iBase_FACE, iMesh_QUADRILATERAL, 00174 entities_out ); 00175 std::vector<EntityHandle> vert_adj; 00176 std::vector<int> adj_indices_out; 00177 std::vector<int> offsets_out; 00178 iBase_EntityHandle *vert_adj = NULL; 00179 int vert_adj_alloc = 0, vert_adj_size, numQuads; 00180 int * offsets = NULL, offsets_alloc = 0, indices_size; 00181 int * indices = NULL, indices_alloc = 0, offsets_size; 00182 00183 err = mk->imesh_instance()->getAdjEntIndices(setForQuads, 00184 iBase_FACE, iMesh_QUADRILATERAL, 00185 iBase_VERTEX, 00186 entities_out, 00187 vert_adj, 00188 adj_indices_out, 00189 offsets_out ); 00190 00191 return ;*/ 00192 // 00193 // can we get to iMesh from iMesh.hpp? 00194 iMesh_Instance mesh1 = mk->imesh_instance()->instance(); 00195 00196 // first get all nodes from bottom mesh 00197 // get the quads and the vertices in one shot 00198 iBase_EntityHandle *quads = NULL; 00199 int quads_alloc = 0; 00200 iBase_EntityHandle *vert_adj = NULL; 00201 int vert_adj_alloc = 0, vert_adj_size, numQuads; 00202 int * offsets = NULL, offsets_alloc = 0, indices_size; 00203 int * indices = NULL, indices_alloc = 0, offsets_size; 00204 int ierr=0; 00205 iMesh_getAdjEntIndices(mesh1, setForQuads, iBase_FACE, iMesh_QUADRILATERAL, 00206 iBase_VERTEX, &quads, &quads_alloc, &numQuads, &vert_adj, 00207 &vert_adj_alloc, &vert_adj_size, &indices, &indices_alloc, &indices_size, 00208 &offsets, &offsets_alloc, &offsets_size, &ierr); 00209 00210 00211 00212 // create one set with desired tag (1) 00213 iBase_EntitySetHandle mesh_set1; 00214 char nsname[]= "NEUMANN_SET"; 00215 create_a_set_with_tag_value(mesh1, quads, numQuads, nsname , 11, 1, mesh_set1); 00216 /* get the coordinates in one array */ 00217 00218 // delete now the original set? 00219 int vert_coords_alloc = 0; 00220 double * xyz = 0; // not allocated 00221 int vertex_coord_size = 0; 00222 00223 iMesh_getVtxArrCoords(mesh1, vert_adj, vert_adj_size, iBase_INTERLEAVED, 00224 &xyz, &vert_coords_alloc, &vertex_coord_size, &ierr); 00225 //IBERRCHK(err, "failed to get vertex coordinates of entities."); 00226 00227 // then, go to shoot rays to decide the sweeping thickness 00228 int & numNodes = vert_adj_size; // to not change too much 00229 double * dArr = new double[numNodes]; 00230 // then, go to shoot rays 00231 int j = 0; 00232 int numRaysIntersected = 0; 00233 // double factorFloating = (1.-937./1026.); 00234 for (j = 0; j < numNodes; j++) { 00235 //dArr[j] = xyz[j * 3 + 2]; 00236 dArr[j] = 0; // no intersection situation, marked by 0 00237 // for a point, see if it is inside the polygon, with winding number 00238 00239 iBase_StorageOrder order=iBase_INTERLEAVED; 00240 std::vector<iGeom::EntityHandle> entities_out; 00241 std::vector<double> points_out; 00242 std::vector<double> params_out; 00243 00244 double pos[3] = { xyz[3 * j], xyz[3 * j + 1], xyz[3 * j + 2] }; 00245 err 00246 = fbiGeom->getPntRayIntsct(pos[0], pos[1], pos[2], direction[0], 00247 direction[1], direction[2], order, entities_out, points_out, 00248 params_out); 00249 // get the first coordinate 00250 if (err != 0 || entities_out.size() < 1) 00251 continue;// we should bail out 00252 //double zTop = points_out[2]; // the z of the top, intersection computation 00253 00254 // consider only the first intersection point 00255 dArr[j] = params_out[0]; // the first intersection only 00256 numRaysIntersected++; 00257 00258 } 00259 // to xyz coordinates, add some thickness, and (thick/layers), to create 00260 // a next layer, and the hexas 00261 iBase_EntityHandle * layer1 = vert_adj; 00262 iBase_EntitySetHandle setForHexas; 00263 00264 err = mk->imesh_instance()->createEntSet(false, setForHexas); 00265 IBERRCHK(err, "Failure to create set for loading the hexas"); 00266 // create in a loop layer 2 , and vertices in layer 2, and hexas 00267 // between layer 1 and layer2 00268 iBase_EntitySetHandle mesh_set2; 00269 for (int i = 0; i < nbLayers; i++) { 00270 for (int j = 0; j < numNodes; j++) { 00271 for (int k = 0; k < 3; k++) 00272 xyz[3 * j + k] += direction[k] * dArr[j] * grades[i]; 00273 } 00274 // now create new vertices at this position, layer 2 00275 iBase_EntityHandle * newVerts = NULL; // no vertices yet 00276 int size1, size2; 00277 iMesh_createVtxArr(mesh1, 00278 /*in*/numNodes, 00279 /*in*/iBase_INTERLEAVED, 00280 /*in*/xyz, 00281 /*in*/numNodes * 3, 00282 /*inout*/&newVerts, 00283 /*inout*/&size1, 00284 /*inout*/&size2, 00285 /*out*/&ierr); 00286 //IBERRCHK(err, "failed to create verts on new layer");// also, careful with the grounding line... 00287 00288 // the vertices are identified as the index in vert_adj 00289 // indices are the quads 00290 // i is index in quads 00291 // offsets[i], offsets[i+1] are offsets in indices 00292 // vertices of quad [i] have indices indices[offsets[i]+j], 00293 // j=0:(offsets[ i+1]-offsets[i])-1 00294 // start copy 00295 int numHexa = numQuads; 00296 long int * adjacency = new long int[8 * numHexa]; 00297 iBase_EntityHandle * conn = (iBase_EntityHandle *) adjacency; 00298 for (int L = 0; L < numHexa; L++) { 00299 00300 for (int k = 0; k < 4; k++) { 00301 conn[8 * L + k] = layer1[indices[offsets[L] + k]]; 00302 conn[8 * L + k + 4] = newVerts[indices[offsets[L] + k]]; 00303 } 00304 } 00305 00306 int n = numHexa; 00307 int junk1 = n, junk2 = n, junk3 = n, junk4 = n; 00308 int * stat = new int[numHexa]; 00309 int* ptr2 = stat; 00310 //int ierr; 00311 iBase_EntityHandle * new_entity_handles = NULL; 00312 iMesh_createEntArr(mesh1, iMesh_HEXAHEDRON, conn, 8 * n, 00313 &new_entity_handles, &junk1, &junk2, &ptr2, &junk3, &junk4, &ierr); 00314 // add hexas to the setForHexas set 00315 iMesh_addEntArrToSet(mesh1, 00316 new_entity_handles, numHexa, 00317 setForHexas, 00318 &ierr ); 00319 // end copy 00320 // at the end, layer 1 becomes layer 2 00321 layer1 = newVerts; 00322 // if last layer, create top quads too 00323 if (i == nbLayers - 1) { 00324 // last layer, create top quads too 00325 for (int L = 0; L < numQuads; L++) { 00326 00327 for (int k = 0; k < 4; k++) { 00328 //conn[8*L+k] = layer1[ indices[offsets[L]+k ] ]; 00329 conn[4 * L + k] = newVerts[indices[offsets[L] + k]]; 00330 } 00331 } 00332 00333 iMesh_createEntArr(mesh1, iMesh_QUADRILATERAL, conn, 4 * n, 00334 &new_entity_handles, &junk1, &junk2, &ptr2, &junk3, &junk4, &ierr); 00335 // create another set 00336 create_a_set_with_tag_value(mesh1, new_entity_handles, numQuads, 00337 nsname, 11, 2, mesh_set2); // top 00338 } 00339 } 00340 00341 clock_t compute_time = clock(); 00342 00343 // now get MOAB , to use skin on the hexas, to get the rest of quads 00344 moab::Interface * mb = mk->moab_instance(); 00345 // get all hexas, and get the skin 00346 moab::Range hexas, iniQuads; 00347 moab::ErrorCode rval = mb->get_entities_by_type(0, moab::MBHEX, hexas); 00348 MBERRCHK(rval, mb); 00349 rval = mb->get_entities_by_type(0, moab::MBQUAD, iniQuads); 00350 MBERRCHK(rval, mb); 00351 moab::Skinner skinner(mb); 00352 moab::Range allQuads; 00353 rval = skinner.find_skin(0, hexas, 2, allQuads); 00354 00355 moab::Range latQuads = subtract(allQuads, iniQuads); 00356 00357 // add this one too to the hexa set 00358 moab::EntityHandle latSet; 00359 mb->create_meshset(moab::MESHSET_SET, latSet); 00360 mb->add_entities(latSet, latQuads); 00361 00362 // add range and tag 00363 moab::Tag ntag; 00364 rval = mb->tag_get_handle("NEUMANN_SET", 1, 00365 moab::MB_TYPE_INTEGER, ntag); 00366 int val = 3; 00367 rval = mb->tag_set_data(ntag, &latSet, 1, (void*) &val); 00368 00369 // to the hexa set, add chlidren sets, mesh_set1, etc 00370 rval = mb->add_parent_child( (moab::EntityHandle)setForHexas, 00371 (moab::EntityHandle) mesh_set1); 00372 rval = mb->add_parent_child( (moab::EntityHandle)setForHexas, 00373 (moab::EntityHandle) mesh_set2); 00374 rval = mb->add_parent_child( (moab::EntityHandle)setForHexas, 00375 latSet); 00376 00377 delete fbiGeom; 00378 assert(iBase_SUCCESS == err); 00379 iMesh_save(mesh1, setForHexas, out_mesh.c_str(), 0, &ierr, out_mesh.length(), 0); 00380 if (iBase_SUCCESS != err) { 00381 std::cerr << "ERROR saving mesh to " << out_mesh << std::endl; 00382 return; 00383 } 00384 clock_t out_time = clock(); 00385 std::cout << "Total time is " << (double) (out_time - start_time) 00386 / CLOCKS_PER_SEC << " s\n load top : " << (double) (load_time1 00387 - start_time) / CLOCKS_PER_SEC << " s\n load bottom : " 00388 << (double) (load_time2 - load_time1) / CLOCKS_PER_SEC 00389 << " s\n compute time : " << (double) (compute_time - load_time2) 00390 / CLOCKS_PER_SEC << " s\n write time : " << (double) (out_time 00391 - compute_time) / CLOCKS_PER_SEC << std::endl; 00392 std::cout << "num rays intersected : " << numRaysIntersected << "\n"; 00393 00394 free(xyz); 00395 delete[] dArr; 00396 00397 return; 00398 } 00399
