MeshKit
1.0
00001 00008 #include "meshkit/MKCore.hpp" 00009 #include "meshkit/MeshOp.hpp" 00010 #include "meshkit/MeshOpTemplate.hpp" 00011 #include "meshkit/TFIMapping.hpp" 00012 #include "meshkit/OneToOneSwept.hpp" 00013 #include "meshkit/EdgeMesher.hpp" 00014 #include <algorithm> 00015 00016 using namespace MeshKit; 00017 00018 #include "TestUtil.hpp" 00019 00020 MKCore *mk; 00021 00022 bool save_mesh = false; 00023 void test_mesh_op_template(); 00024 00025 int main(int argc, char **argv) 00026 { 00027 mk = new MKCore(); 00028 int num_fail = 0; 00029 00030 num_fail += RUN_TEST(test_mesh_op_template); 00031 00032 delete mk; 00033 return num_fail; 00034 } 00035 00036 void test_mesh_op_template() 00037 { 00038 // Make the brick! // v Don't need this 00039 MeshOpTemplate *mot = (MeshOpTemplate*) mk->construct_meshop("MeshOpTemplate", MEntVector()); 00040 mot->set_name("MeshOpTemplate"); 00041 00042 // Do work! 00043 mk->setup(); 00044 mk->execute(); 00045 mk->clear_graph(); 00046 00047 if(save_mesh) { 00048 #ifdef HAVE_ACIS 00049 mk->save_geometry("un_meshed_brick.sat"); 00050 mk->save_mesh("meshed_brick.exo"); 00051 #elif defined(HAVE_OCC) 00052 mk->save_geometry("un_meshed_brick.stp"); 00053 mk->save_mesh("meshed_brick.exo"); 00054 #endif 00055 } 00056 00057 return; 00058 } 00059
