MeshKit
1.0
00001 /* 00002 * AF2Rule.hpp 00003 * 00004 * \brief An AF2Rule defines a two-dimensional pattern for advancing the front 00005 * of a two-dimensional advancing front algorithm. 00006 * 00007 * The pattern consists of a number of existing edges and existing vertices, 00008 * a free zone definition, new vertices, new edges, and new faces. 00009 * In order for the advancing algorithm to apply the pattern, there must 00010 * be edges and points on the advancing front in the neighborhood 00011 * of some baseline edge that match the defined existing edges and existing 00012 * vertices of the pattern. Depending on the particular binding of 00013 * existing edges and vertices to edges and points in the neighborhood, 00014 * as well as the quality level, the free zone definition will define 00015 * a free zone. This free zone must not contain any of the neighborhood's 00016 * points or intersect any of its edges, or the algorithm will not apply 00017 * the pattern. 00018 * 00019 * There is also a maximum quality defined on the rule. If the baseline 00020 * edge is currently of higher quality than the specified maximum quality, 00021 * i.e., if the quality level number is smaller than the defined maximum 00022 * quality level number, then the rule may not be applied. 00023 * 00024 * If the pattern can be successfully applied, then applying the pattern 00025 * involves adding the new vertices, new edges, and new faces of the pattern 00026 * to the mesh. Since there may be several different ways to apply 00027 * the pattern or several different patterns that could be applied, 00028 * each potential successful application of the pattern is handed off 00029 * to a visitor for processing. The rule makes no guarantee that 00030 * the new faces are not inverted, and the visitor should verify any 00031 * desired properties before committing the results to the mesh. 00032 */ 00033 #ifndef AF2RULE_HPP 00034 #define AF2RULE_HPP 00035 00036 // C++ 00037 #include <list> 00038 #include <map> 00039 #include <string> 00040 00041 // MeshKit 00042 #include "meshkit/AF2Edge2D.hpp" 00043 #include "meshkit/AF2FreeZoneDef.hpp" 00044 #include "meshkit/AF2Neighborhood.hpp" 00045 #include "meshkit/AF2Point2D.hpp" 00046 #include "meshkit/AF2RuleAppVisitor.hpp" 00047 #include "meshkit/AF2RuleExistEdge.hpp" 00048 #include "meshkit/AF2RuleExistVertex.hpp" 00049 #include "meshkit/AF2RuleNewEdge.hpp" 00050 #include "meshkit/AF2RuleNewFace.hpp" 00051 #include "meshkit/AF2RuleNewVertex.hpp" 00052 00053 class AF2Rule 00054 { 00055 private: 00056 00057 const std::string ruleName; 00058 const unsigned int maxQualityLevel; 00059 const unsigned int numExVertices, numExEdges; 00060 const AF2FreeZoneDef* const freeZoneDef; 00061 const unsigned int numNewVertices, numNewEdges, numNewFaces; 00062 const AF2RuleExistVertex** exVertices; 00063 const AF2RuleExistEdge** exEdges; 00064 const AF2RuleNewVertex** newVertices; 00065 const AF2RuleNewEdge** newEdges; 00066 const AF2RuleNewFace** newFaces; 00067 unsigned int numExIsoVertices; 00068 const AF2RuleExistVertex** exIsoVertices; 00069 00089 void applyRuleStageTwo(AF2Neighborhood const & ngbhd, 00090 unsigned int matchQuality, AF2RuleAppVisitor & visitor, 00091 std::map<const AF2RuleExistVertex*, 00092 std::list<const AF2Point2D*>*>* const & matchingVerticesMap, 00093 AF2Binding & binding) const; 00094 00115 void applyRuleStageThree(AF2Neighborhood const & ngbhd, 00116 unsigned int matchQuality, AF2RuleAppVisitor & visitor, 00117 AF2Binding const & binding) const; 00118 00126 std::map<const AF2RuleExistEdge*, std::list<const AF2Edge2D*>*>* 00127 findPotentialEdgeMatches(AF2Neighborhood const & ngbhd, 00128 unsigned int matchQuality) const; 00129 00138 std::map<const AF2RuleExistVertex*, std::list<const AF2Point2D*>*>* 00139 findPotentialVertexMatches(AF2Neighborhood const & ngbhd, 00140 unsigned int matchQuality) const; 00141 00154 void checkExEndpointsAndFindIsolatedVertices(); 00155 00172 bool isMatchingEdge(AF2Edge2D const & edge, 00173 AF2RuleExistEdge const & ruleEdge, unsigned int matchQuality) const; 00174 00191 bool isMatchingVertex(AF2Point2D const & point, 00192 AF2RuleExistVertex const & ruleVertex, unsigned int matchQuality) const; 00193 00194 public: 00195 00245 AF2Rule(std::string const & ruleNameArg, unsigned int maxQuality, 00246 std::list<const AF2RuleExistVertex*> const & ruleVertices, 00247 const AF2RuleExistEdge* baselineEdge, 00248 std::list<const AF2RuleExistEdge*> const & otherRuleEdges, 00249 const AF2FreeZoneDef* freeZoneDef, 00250 std::list<const AF2RuleNewVertex*> const & ruleNewVertices, 00251 std::list<const AF2RuleNewEdge*> const & ruleNewEdges, 00252 std::list<const AF2RuleNewFace*> const & ruleNewFaces); 00253 00257 ~AF2Rule(); 00258 00265 AF2Rule(const AF2Rule & toCopy); 00266 00273 AF2Rule& operator=(const AF2Rule & rhs); 00274 00292 void applyRule(AF2Neighborhood const & ngbhd, unsigned int matchQuality, 00293 AF2RuleAppVisitor & visitor) const; 00294 00300 std::string getName() const; 00301 }; 00302 00303 #endif
