MeshKit
1.0
00001 //-----------------------------------C++-------------------------------------// 00002 // File: src/algs/meshkit/AssyGen.hpp 00003 // 00004 // Brief: AssyGen class definition: 00005 // Creates reactor assembly geometry (ACIS or OCC format) and cubit mesh script as specified in a user defined input 00006 // class, AssyGen 00007 //---------------------------------------------------------------------------// 00008 00009 #ifndef MESHKIT_ASSYGEN_HPP 00010 #define MESHKIT_ASSYGEN_HPP 00011 00012 #include <cassert> 00013 #include <string> 00014 #include <vector> 00015 #include <set> 00016 00017 #include "meshkit/Types.hpp" 00018 #include "meshkit/Error.hpp" 00019 #include "meshkit/MeshScheme.hpp" 00020 #include "meshkit/ModelEnt.hpp" 00021 #include "meshkit/MKCore.hpp" 00022 #include "meshkit/SizingFunction.hpp" 00023 #include "meshkit/RegisterMeshOp.hpp" 00024 00025 #include "meshkit/LocalSet.hpp" 00026 #include "meshkit/LocalTag.hpp" 00027 #include "meshkit/Matrix.hpp" 00028 00029 #include "meshkit/iMesh.hpp" 00030 //#include "meshkit/iGeom.hpp" 00031 #include "iGeom.h" 00032 #include "MBCN.h" 00033 00034 #include "meshkit/SimpleArray.hpp" 00035 00036 #include "meshkit/vectortemplate.hpp" 00037 #include "meshkit/matrixtemplate.hpp" 00038 #include "meshkit/pincell.hpp" 00039 #include "meshkit/parser.hpp" 00040 #include "meshkit/clock.hpp" 00041 00042 namespace MeshKit { 00043 00044 #define DEFAULT_TEST_FILE "assygen_default" 00045 #define TEST_FILE_NAME "assygen_default" 00046 00047 //#define CHECK( STR ) if (err != iBase_SUCCESS) return Print_Error( STR, err, geom, __FILE__, __LINE__ ) 00048 00049 enum ErrorStates {PINCELLS, INVALIDINPUT, EMAT, EGEOMTYPE, EGEOMENGINE, ENEGATIVE, EALIAS, EPIN, EUNEQUAL}; 00050 00051 class MKCore; 00052 00053 class AssyGen : public MeshScheme 00054 { 00055 public: 00056 /* \brief Constructor 00057 * 00058 * Create a new AssyGen instance 00059 * \param impl the iGeom instance handle for the Geom 00060 */ 00061 AssyGen(MKCore *mk, const MEntVector &me_vec); 00062 00063 /* \brief Destructor 00064 */ 00065 virtual ~AssyGen(); 00066 00067 enum ErrorStates {PINCELLS, INVALIDINPUT, EMAT, EGEOMTYPE, EGEOMENGINE, ENEGATIVE, EALIAS, EPIN, EUNEQUAL}; 00068 00070 static const char* name(); 00071 00076 static bool can_mesh(iBase_EntityType dim); 00077 00084 static bool can_mesh(ModelEnt *me); 00085 00089 static const moab::EntityType* output_types(); 00090 00094 virtual const moab::EntityType* mesh_types_arr() const; 00095 00099 virtual bool add_modelent(ModelEnt *model_ent); 00100 00102 virtual void setup_this(); 00103 00105 virtual void execute_this(); 00106 00110 void PrepareIO (int argc, char *argv[], std::string TestDir); 00111 00115 void ReadCommonInp (); 00116 00120 void ReadInputPhase1 (); 00121 00125 void ReadAndCreate (); 00126 00130 void CreateAssyGenInputFiles(); 00131 00135 void Name_Faces( const std::string sMatName, const iBase_EntityHandle body, 00136 iBase_TagHandle this_tag); 00137 00141 void Center_Assm( char&); 00142 00146 void Section_Assm ( char&, double&, const std::string); 00147 00151 void Rotate_Assm ( char&, double&); 00152 00156 void Move_Assm ( double&, double&, double&); 00157 00161 void Create_HexAssm( std::string &); 00162 00166 void Create_CartAssm( std::string &); 00167 00171 void CreateOuterCovering(); 00172 00176 void Imprint_Merge (bool, bool); 00177 00181 void Subtract_Pins (); 00182 00186 void Create2DSurf(); 00187 00191 void ReadPinCellData( int i); 00192 00196 void CreatePinCell_Intersect( int i, double dX, 00197 double dY, double dZ); 00198 00202 void CreatePinCell( int i, double dX, 00203 double dY, double dZ); 00204 00208 void CreateCubitJournal(); 00209 00213 void ComputePinCentroid( int, CMatrix<std::string>, int, int, 00214 double&, double&, double&); 00215 00216 private: 00217 // iGeom Impl for calling geometry creation/manipulation operations 00218 iGeom *igeomImpl; 00219 00220 // number of sides in the geometry 00221 int m_nSides; 00222 00223 // file Input 00224 std::ifstream m_FileInput, m_FileCommon; 00225 00226 // journal file Output 00227 std::ofstream m_FileOutput, m_SchemesFile, m_AssmInfo, m_PyCubGeomFile; 00228 00229 // string for file names 00230 std::string m_szSmooth, m_szAssmInfo, m_szLogFile, m_szCommonFile, m_szFile, m_szInFile, 00231 m_szGeomFile, m_szGeomFile1, m_szJouFile, m_szSchFile, m_szPyCubGeom; 00232 00233 // matrix for holding pincell arrangement 00234 CMatrix<std::string> m_Assembly; 00235 00236 // matrix for holding verts coordinates used in tet-meshing 00237 CMatrix<double> m_dMTopSurfCoords; 00238 00239 // vector for duct specification 00240 CMatrix<double> m_dMAssmPitch, m_dMAssmPitchX, m_dMAssmPitchY, m_dMXYAssm, m_dMZAssm; 00241 00242 // vector for material names 00243 CVector<std::string> m_szAssmMat, m_szAssmMatAlias; 00244 CMatrix<std::string> m_szMMAlias; 00245 00246 // vector holding a pincell 00247 CVector<CPincell> m_Pincell; 00248 00249 CVector<double> m_dAxialSize, m_dBLMatBias; 00250 00251 // string for geomtype, engine, meshtype 00252 std::string m_szEngine; 00253 std::string m_szGeomType; 00254 std::string m_szMeshType; 00255 std::string m_szSideset; 00256 std::vector<std::string> m_szDuctMats; 00257 // integers for vectors sizes, err etc 00258 int m_nAssemblyMat, m_nDimensions, m_nPincells , m_nAssmVol, m_nPin, m_nPinX, m_nPinY, err, m_nLineNumber, m_nPlanar, 00259 m_nNeumannSetId, m_nMaterialSetId, m_nDuct, m_nDuctNum, m_nJouFlag, m_nAssyGenInputFiles, m_nTotalPincells; 00260 00261 // doubles for pincell pitch, pi and mesh sizes resp. 00262 double m_dPitch, pi, m_dRadialSize, m_dTetMeshSize, m_dMergeTol, m_dZstart, m_dZend; 00263 00264 // igeom related 00265 SimpleArray<iBase_EntityHandle> assms, in_pins; 00266 //iGeom_Instance geom; 00267 iBase_EntitySetHandle root_set; 00268 00269 00270 // error handlers 00271 void IOErrorHandler (ErrorStates) const; 00272 friend class CPincell; 00273 00274 struct superblocks{ 00275 int m_nSuperBlockId; 00276 std::string m_szSuperBlockAlias; 00277 int m_nNumSBContents; 00278 CVector<int> m_nSBContents; 00279 }; 00280 00281 int m_nSuperBlocks; 00282 CVector<superblocks> sb; 00283 int tmpSB; 00284 00285 // parsing related 00286 std::string szInputString; 00287 std::string szComment; 00288 int MAXCHARS, MAXLINES; 00289 00290 std::vector< std::vector<iBase_EntityHandle> > cp_inpins; 00291 00292 CVector<std::string> m_szBLAssmMat; 00293 CVector<int> m_nListMatSet, m_nListNeuSet, m_nBLMatIntervals; 00294 00295 int m_edgeInterval; 00296 int m_nStartpinid; 00297 std::string m_szInfo; 00298 std::string m_szMeshScheme; 00299 std::string pin_name; 00300 int m_nHblock; 00301 bool m_bCreateMatFiles; 00302 bool save_exodus, m_bmerge, m_bimprint; 00303 bool have_common; 00304 int com_run_count; 00305 int m_nBLAssemblyMat; 00306 std::string m_szInnerDuct; 00307 }; 00308 00309 inline const char* AssyGen::name() 00310 { 00311 return "AssyGen"; 00312 } 00313 00314 inline bool AssyGen::can_mesh(iBase_EntityType) 00315 { 00316 return false; 00317 } 00318 00319 inline bool AssyGen::can_mesh(ModelEnt *) 00320 { 00321 return true; 00322 } 00323 00324 inline const moab::EntityType* AssyGen::mesh_types_arr() const 00325 { 00326 return output_types(); 00327 } 00328 00329 } // namespace MeshKit 00330 #endif
