MeshKit
1.0
00001 #include "HarmonicMapper.hpp" 00002 #include <iostream> 00003 #include <math.h> 00004 #include <map> 00005 00006 namespace MeshKit { 00007 00008 HarmonicMapper::HarmonicMapper(MKCore* core, vector<Vertex> &v, vector<Face> &t, vector<Edge> &e, vector<set<int> > a) 00009 { 00010 mk_core = core; 00011 vtx.insert(vtx.begin(), v.begin(), v.end()); 00012 tri.insert(tri.begin(), t.begin(), t.end()); 00013 edges.insert(edges.begin(), e.begin(), e.end()); 00014 adj.insert(adj.begin(), a.begin(), a.end()); 00015 00016 } 00017 00018 void HarmonicMapper::execute() 00019 { 00020 _iterative_map(0.001); 00021 00022 } 00023 00024 void HarmonicMapper::getUV(vector<Vertex> &v) 00025 { 00026 int count = -1; 00027 for (vector<Vertex>::iterator it = vtx.begin(); it != vtx.end(); it++){ 00028 count++; 00029 if (it->onBoundary) continue; 00030 v[count].uv[0] = it->uv[0]; 00031 v[count].uv[1] = it->uv[1]; 00032 //std::cout << "HarmonicMapper index = " << count << "\tuv = {" << it->uv[0] << "," << it->uv[1] << "}\n"; 00033 } 00034 00035 } 00036 00037 //matrix method 00038 void HarmonicMapper::_map() 00039 { 00040 int n_interior = 0, n_boundary = 0; 00041 for (vector<Vertex>::iterator it = vtx.begin(); it != vtx.end(); it++){ 00042 if (it->onBoundary){ 00043 it->id = n_boundary; 00044 n_boundary++; 00045 } 00046 else{ 00047 it->id = n_interior; 00048 n_interior++; 00049 } 00050 } 00051 00052 //using Armadillo to solve linear equations 00053 mat A = zeros<mat>(n_interior, n_interior); 00054 mat B = zeros<mat>(n_interior, n_boundary); 00055 //setting up the matrix A 00056 00057 for (vector<Vertex>::iterator it = vtx.begin(); it != vtx.end(); it++){ 00058 if (it->onBoundary) continue; 00059 int index_i = it->id; 00060 double sw = 0.0; 00061 for (set<int>::iterator it_adj = adj[it->index].begin(); it_adj != adj[it->index].end(); it_adj++){ 00062 int index_vtx = -1; 00063 if (edges[*it_adj].connect[0]->index == it->index) 00064 index_vtx = edges[*it_adj].connect[1]->index; 00065 else 00066 index_vtx = edges[*it_adj].connect[0]->index; 00067 int index_j = vtx[index_vtx].id; 00068 double w = edges[*it_adj].e; 00069 if (vtx[index_vtx].onBoundary) 00070 B(index_i, index_j) = w; 00071 else 00072 A(index_i, index_j) = -1.0*w; 00073 00074 sw += w; 00075 } 00076 A(index_i, index_i) = sw; 00077 } 00078 00079 mat b = zeros<mat>(n_interior, 2); 00080 00081 for (vector<Vertex>::iterator it = vtx.begin(); it != vtx.end(); it++){ 00082 if (!it->onBoundary) continue; 00083 b(it->id,0) = it->uv[0]; 00084 b(it->id,1) = it->uv[1]; 00085 } 00086 mat c = B * b;//n_interior * 2 00087 mat uv_coord = solve(A, c); 00088 00089 int count = -1; 00090 for (vector<Vertex>::iterator it = vtx.begin(); it != vtx.end(); it++){ 00091 if (it->onBoundary) continue; 00092 count++; 00093 it->uv[0] = uv_coord(count, 0); 00094 it->uv[1] = uv_coord(count, 1); 00095 } 00096 00097 00098 } 00099 00100 //iterative method 00101 void HarmonicMapper::_iterative_map(double epsilon) 00102 { 00103 //move interior vertices to its center of neighbors 00104 //boundary nodes are set to (0,0) 00105 vector<int> interior; 00106 for (std::vector<Vertex>::iterator it = vtx.begin(); it != vtx.end(); it++) 00107 if (!it->onBoundary){ 00108 interior.push_back(it->index); 00109 it->uv[0] = 0.0; 00110 it->uv[1] = 0.0; 00111 } 00112 00113 00114 while(true){ 00115 double error = -1.0e+10; 00116 00117 00118 for (std::vector<int>::iterator it = interior.begin(); it != interior.end(); it++){ 00119 Vector2D uv; 00120 uv[0] = 0.0; 00121 uv[1] = 0.0; 00122 double weight = 0.0; 00123 for (set<int>::iterator it_e = adj[*it].begin(); it_e != adj[*it].end(); it_e++){ 00124 int adj_v = -1; 00125 if (edges[*it_e].connect[0]->index == (*it)) 00126 adj_v = edges[*it_e].connect[1]->index; 00127 else 00128 adj_v = edges[*it_e].connect[0]->index; 00129 uv[0] += edges[*it_e].e*vtx[adj_v].uv[0]; 00130 uv[1] += edges[*it_e].e*vtx[adj_v].uv[1]; 00131 weight += edges[*it_e].e; 00132 } 00133 Vector2D pre_uv; 00134 pre_uv[0] = vtx[*it].uv[0]; 00135 pre_uv[1] = vtx[*it].uv[1]; 00136 vtx[*it].uv[0] = uv[0]/weight; 00137 vtx[*it].uv[1] = uv[1]/weight; 00138 double v_err = sqrt(pow(pre_uv[0]-vtx[*it].uv[0],2)+pow(pre_uv[1]-vtx[*it].uv[1],2)); 00139 error = (v_err > error)? v_err : error; 00140 } 00141 00142 if (error < epsilon) break; 00143 } 00144 } 00145 00146 00147 HarmonicMapper::~HarmonicMapper() 00148 { 00149 std::cout << "It is over now in smoothing" << endl; 00150 } 00151 00152 }
