MeshKit
1.0
00001 #include "meshkit/ProjectShell.hpp" 00002 #include "meshkit/MKCore.hpp" 00003 #include "meshkit/ModelEnt.hpp" 00004 #include "meshkit/SizingFunction.hpp" 00005 #include "meshkit/RegisterMeshOp.hpp" 00006 #include "moab/ReadUtilIface.hpp" 00007 00008 00009 #include <math.h> 00010 #include <sstream> 00011 #include <queue> 00012 #include <algorithm> 00013 #include <string.h> 00014 00015 #define ERROR(msg) \ 00016 do { \ 00017 Error err(0, "%s, line %d: %s", __FILE__, __LINE__, (msg));\ 00018 throw err; \ 00019 } while(false) 00020 00021 #define ERROR1(fmt, arg1) \ 00022 do { \ 00023 Error err(0, "%s, line %d: " fmt, __FILE__, __LINE__, arg1); \ 00024 throw err; \ 00025 } while(false) 00026 00027 #define ERROR2(fmt, arg1,arg2) \ 00028 do { \ 00029 Error err(0, "%s, line %d: " fmt, __FILE__, __LINE__, arg1,arg2); \ 00030 throw err; \ 00031 } while(false) 00032 00033 #define ERROR3(fmt, arg1,arg2,arg3) \ 00034 do { \ 00035 Error err(0, "%s, line %d: " fmt, __FILE__, __LINE__, arg1,arg2,arg3); \ 00036 throw err; \ 00037 } while(false) 00038 00039 00040 namespace MeshKit { 00041 00042 double epsilon = 1.e-5; // cm, for coincident points in P, the intersection area 00043 00044 //---------------------------------------------------------------------------// 00045 // Construction Function for Project Shell 00046 ProjectShell::ProjectShell(MKCore *mk_core, const MEntVector &me_vec) 00047 : MeshScheme(mk_core, me_vec), 00048 m_numNodes(0), 00049 m_numTriangles(0), 00050 m_xyz(NULL), // original coordinates 00051 m_triangles(NULL), // original triangles 00052 ps_edges(NULL), 00053 ps_nodes(NULL), 00054 ps_triangles(NULL), 00055 m_xy(NULL), // 2d coordinates after projection 00056 m_redMesh(NULL), 00057 m_blueMesh(NULL), 00058 m_num2dPoints(0), 00059 m_dbg(false) 00060 { 00061 double direction[3] = {1.0, 0.0, 0.0}; 00062 m_direction = Vector<3>(direction); 00063 } 00064 00065 //---------------------------------------------------------------------------// 00066 // return the type of entities this mesh creates 00067 void ProjectShell::mesh_types(std::vector<moab::EntityType> &tps) 00068 { 00069 tps.push_back(moab::MBVERTEX); 00070 tps.push_back(moab::MBEDGE); 00071 tps.push_back(moab::MBTRI); 00072 } 00073 00074 00075 //set up the projection parameters: the direction of projection 00076 void ProjectShell::setup_this() 00077 { 00078 // Need to set the direction here 00079 } 00080 00081 //---------------------------------------------------------------------------// 00082 // execute function: Generate the projected 2D 00083 void ProjectShell::execute_this(){ 00084 double dist1= length(m_direction); 00085 if (dist1==0.0) ERROR("Null direction of projection"); 00086 // normalize direction 00087 m_direction/=dist1; 00088 int ret = getMesh(); 00089 if(ret) ERROR("Bad input mesh"); 00090 00091 // we have now the 3D mesh 00092 // verify orientation of the triangles; is it manifold? 00093 ret = checkMeshValidity(); 00094 if(ret) ERROR("Bad shell"); 00095 00096 ret = projectIn2D(); 00097 if(ret) ERROR("Cannot project in 2D"); 00098 00099 ret = computeIntersections(); 00100 if(ret) ERROR("Error in computing intersections"); 00101 00102 ret = commitMesh(); 00103 if(ret) ERROR("Error in committing the computed shell"); 00104 } 00105 00106 00107 int ProjectShell::getEdge(ProjectShell::Node & v1, ProjectShell::Node & v2, int & edgeId, ProjectShell::Edge * edgesArr, int sizeArr) 00108 { 00109 // not found -- return 0 00110 std::list<int> & L = v1.edges; 00111 std::list<int>::iterator i; 00112 for (i=L.begin(); i!=L.end(); i++) 00113 { 00114 int edge = *i; 00115 int ae = abs(edge); 00116 if (ae>sizeArr || ae ==0 ) ERROR("Bad index in getEdge"); 00117 00118 ProjectShell::Edge & pse = edgesArr[ae-1]; 00119 // int sig = (edge<0) ? -1 : 1; 00120 if (pse.v[0] == v1.id && pse.v[1] == v2.id) 00121 { 00122 edgeId = edge; 00123 return 1; 00124 } 00125 if (pse.v[0] == v2.id && pse.v[1] == v1.id) 00126 { 00127 edgeId = edge; 00128 return 1; 00129 } 00130 } 00131 return 0;// did not find any edge between v1 and v2 00132 } 00133 00134 // Destructor 00135 ProjectShell::~ProjectShell() 00136 { 00137 delete [] ps_edges; 00138 delete [] ps_nodes; 00139 delete [] ps_triangles; 00140 delete [] m_xyz; 00141 delete [] m_triangles; 00142 delete [] m_xy; 00143 delete [] m_redMesh; 00144 delete [] m_blueMesh; 00145 } 00146 #if 0 00147 int ProjectShell::getShellMesh() 00148 { 00149 00150 // get original coordinates of mesh 00151 iBase_EntityHandle *verts = NULL; 00152 int verts_alloc = 0; 00153 00154 int vert_coords_alloc = 0; 00155 int vertex_coord_size; 00156 00157 /* check storage order */ 00158 int result; 00159 int this_order; 00160 iMesh_Instance m_mesh = NULL; 00161 iBase_EntitySetHandle m_hRootSet = NULL; 00162 00163 iMesh_getDfltStorage(m_mesh, &this_order, &result); 00164 if (iBase_SUCCESS != result) 00165 ERROR("failed to get preferred storage order in getMesh"); 00166 00167 00168 /* now get the vertex coordinates from a vertex array */ 00169 /* need to get the vertices in the model */ 00170 verts = NULL; 00171 verts_alloc = 0; 00172 iMesh_getEntities(m_mesh, m_hRootSet, iBase_VERTEX, 00173 iMesh_POINT, &verts, &verts_alloc, &m_numNodes, &result); 00174 IBERRCHK(result, "Failed to get vertices"); 00175 /* 00176 iMesh_getNumOfType ( iMesh_Instance instance, 00177 const iBase_EntitySetHandle entity_set_handle, 00178 const int entity_type,6 00179 int * num_type, 00180 int * err 00181 ) */ 00182 int numEdges=0; 00183 iMesh_getNumOfType (m_mesh, m_hRootSet, iBase_EDGE, 00184 &numEdges, &result); 00185 00186 // get the triangles and the vertices in one shot 00187 iBase_EntityHandle *triangles = NULL; 00188 int triangles_alloc = 0; 00189 iBase_EntityHandle *vert_adj = NULL; 00190 int vert_adj_alloc = 0, vert_adj_size; 00191 int * offsets = NULL, offsets_alloc = 0, indices_size; 00192 int * indices = NULL, indices_alloc = 0, offsets_size; 00193 iMesh_getAdjEntIndices( m_mesh, m_hRootSet, 00194 iBase_FACE, iMesh_TRIANGLE, iBase_VERTEX, 00195 &triangles, &triangles_alloc, &m_numTriangles, 00196 &vert_adj, &vert_adj_alloc, &vert_adj_size, 00197 &indices, &indices_alloc, &indices_size, 00198 &offsets, &offsets_alloc, &offsets_size, 00199 &result ); 00200 if (iBase_SUCCESS != result) { 00201 ERROR("failed to get triangles and vertices."); 00202 } 00203 00204 00205 /* get the coordinates in one array */ 00206 00207 vert_coords_alloc = 0; 00208 00209 iMesh_getVtxArrCoords(m_mesh, vert_adj, vert_adj_size, iBase_INTERLEAVED, 00210 &m_xyz, &vert_coords_alloc, &vertex_coord_size, &result); 00211 if (iBase_SUCCESS != result || 3*m_numNodes!=vertex_coord_size) { 00212 ERROR("failed to get vertex coordinates of entities in getMeshData."); 00213 } 00214 00215 00216 // build list of edges; we cannot rely on iMesh to give them to us 00217 // can we force imesh to give the edges? It does not seem like that 00218 00219 // the vertices are identified as the index in vert_adj 00220 // indices are the triangles 00221 // i is index in triangles 00222 // offsets[i], offsets[i+1] are offsets in indices 00223 // vertices of triangle [i] have indices indices[offsets[i]+j], j=0:(offsets[i+1]-offsets[i])-1 00224 00225 // first, determine the edges of triangle i 00226 if (offsets_size - 1 != m_numTriangles) 00227 { 00228 ERROR("bad indexing"); 00229 } 00230 int i=0;// index used everywhere 00231 for (i=0; i<m_numTriangles; i++) 00232 { 00233 if (offsets[i+1]-offsets[i] !=3) 00234 { 00235 ERROR("Not a triangle"); 00236 } 00237 } 00238 // build edges from triangle information 00239 ps_edges = new ProjectShell::Edge [m_numTriangles*3];// overestimate; probably only half will be created 00240 ps_nodes = new ProjectShell::Node [m_numNodes]; 00241 ps_triangles = new ProjectShell::Triangle3D [m_numTriangles]; 00242 // 00243 for (i=0; i<m_numNodes; i++) 00244 { 00245 ProjectShell::Node & psn = ps_nodes[i]; 00246 psn.id = i;// this can be found by address in the array, but why bother 00247 for (int j=0; j<3; j++) 00248 { 00249 psn.xyz[j] = m_xyz[3*i+j]; 00250 } 00251 } 00252 // index in edge: 00253 int edgeIndex = 0; 00254 int j=0; 00255 for (j=0; j<m_numTriangles; j++) 00256 { 00257 ProjectShell::Triangle3D & curTria = ps_triangles[j]; 00258 int ii=0; 00259 for (ii=0; ii<3; ii++) 00260 curTria.v[ii]=indices[offsets[j]+ii]; 00261 for (ii=0; ii<3; ii++) 00262 { 00263 ProjectShell::Node & v1= ps_nodes[curTria.v[ii]]; 00264 int nextii = ii+1; 00265 if (ii==2) 00266 nextii=0; 00267 ProjectShell::Node & v2= ps_nodes[curTria.v[nextii]]; 00268 // is there an edge from v1 to v2, or from v2 to v1 00269 int edgeId; 00270 int exi = getEdge(v1, v2, edgeId, ps_edges, edgeIndex);// will be created if not existing already 00271 if (exi) 00272 { 00273 curTria.e[ii] = edgeId; 00274 ProjectShell::Edge & foundEdge = ps_edges[abs(edgeId)-1]; 00275 foundEdge.used++; 00276 if(foundEdge.used>2) 00277 { 00278 ERROR("Bad indexing in ps_edge"); 00279 } 00280 foundEdge.t[1]=j; // mark the triangle it belongs to 00281 } 00282 else 00283 { 00284 int cId = curTria.e[ii]=edgeIndex+1; 00285 ProjectShell::Edge & newEdge = ps_edges[edgeIndex]; 00286 newEdge.v[0] = curTria.v[ii]; 00287 newEdge.v[1]=curTria.v[nextii]; 00288 v1.edges.push_back(cId); // positive means starts at vertex 00289 v2.edges.push_back(-cId);// negative means incident to the vertex 00290 edgeIndex++; 00291 newEdge.used=1; 00292 newEdge.t[0] = j; // index for triangles 00293 } 00294 } 00295 } 00296 m_numEdges = edgeIndex; 00297 // fill up now the triangle neighbor information 00298 for (j=0; j<m_numTriangles; j++) 00299 { 00300 ProjectShell::Triangle3D & tri = ps_triangles[j]; 00301 for (int k=0; k<3; k++) 00302 { 00303 int edgeId = tri.e[k]; 00304 int ae = abs(edgeId); 00305 ProjectShell::Edge & edge = ps_edges[ae-1]; 00306 int t0 = edge.t[0], t1 = edge.t[1]; 00307 if (t0==j) 00308 tri.t[k] = t1; 00309 else if (t1==j) 00310 tri.t[k] = t0; 00311 } 00312 } 00313 00314 free(verts); 00315 free(triangles); 00316 free(vert_adj); 00317 free (indices); 00318 free (offsets); 00319 00320 //free(vert_coords); 00321 return 0; 00322 } 00323 #endif 00324 int ProjectShell::checkMeshValidity() 00325 { 00326 // basically, see if the edges are all used 2 times, and each is is used in each direction 00327 int i=0; 00328 for (i=0; i<m_numEdges; i++) 00329 { 00330 ProjectShell::Edge & edge = ps_edges[i]; 00331 if (edge.used!=2) 00332 { 00333 ERROR("Edge not used exactly 2 times"); 00334 } 00335 int edgeId = i+1; 00336 int sum=0; 00337 for (int k=0; k<2; k++) 00338 { 00339 ProjectShell::Triangle3D & tr1=ps_triangles[edge.t[k]]; 00340 for (int kk=0; kk<3; kk++) 00341 { 00342 int ec= tr1.e[kk]; 00343 if (abs(ec)==edgeId) 00344 { 00345 sum+=ec; 00346 break; 00347 } 00348 00349 } 00350 } 00351 if (sum!=0) 00352 ERROR1("Edge %d not used exactly 2 times", edgeId); 00353 } 00354 // check that all triangles have 3 neighbors 00355 for (i=0; i<m_numTriangles; i++) 00356 { 00357 ProjectShell::Triangle3D & tr = ps_triangles[i]; 00358 for (int k=0; k<3; k++) 00359 { 00360 int t = tr.t[k]; 00361 if (t==i || t < 0 || t >= m_numTriangles) 00362 ERROR1("triangle %d does not have 3 neighbors", i); 00363 } 00364 } 00365 00366 return 0; // everything is OK 00367 } 00368 00369 00370 int ProjectShell::projectIn2D() 00371 { 00372 // considering the direction, classify each projected triangle as red or blue 00373 // the red ones are positive (inbound), blue ones are negative 00374 // first decide the other 2 vectors 00375 double v[3] = {0.,-1.,0.}; 00376 Vector<3> vv(v); 00377 m_dirX = vector_product(m_direction, vv); 00378 00379 double d1 = length(m_dirX); 00380 if (d1<1.e-5)// consider another direction 00381 { 00382 vv[1]=0.; vv[2]=-1.; 00383 m_dirX = vector_product(m_direction, vv); 00384 d1 = length(m_dirX); 00385 if (d1<1.e-5) 00386 ERROR("cannot find a suitable direction; abort"); 00387 } 00388 m_dirX /= d1; 00389 m_dirY = vector_product(m_direction, m_dirX); 00390 // dirY must be already normalized, but why worry 00391 d1 = length(m_dirY); 00392 if (d1==0.) 00393 ERROR("Get out of here, it is hopeless"); 00394 m_dirY /= d1; 00395 00396 // now do the projection in 2d 00397 // we have 3 vectors, m_dirX, m_dirY, m_direction 00398 // for every point, A, the projection in xy plane will be just 00399 // xA = A . u; yA = A . v (dirX and dirY) 00400 00401 // also, it is important to compute the normal 00402 // some triangles will be reverted and some may be projecting to a line 00403 00404 // coordinates of the projected nodes on 2D 00405 // what could be a good estimate for total number of points in 2D? 00406 // we start with 2d capacity 3* m_numNodes 00407 m_2dcapacity = m_numNodes*3; 00408 m_num2dPoints = m_numNodes; // directly project 3d nodes in 2d, keep the ids 00409 m_xy = new double [3*m_2dcapacity]; 00410 // this array will be parallel with the original mesh 00411 // new nodes will appear after intersection computation 00412 // triangles are characterized by their orientation: negative, positive or 0 00413 00414 // the neighbors will be preserved 00415 // some edges will be collapsed, and also some triangles 00416 // in those cases, what will be the neighbors? 00417 // flag them with a high number () 00418 00419 //m_finalNodes.resize(3*m_numNodes); // the actual size is n_numNodes first 00420 for (int k=0; k<m_numNodes; k++) 00421 { 00422 // double xx= dot( ps_nodes[k].xyz, m_dirX); 00423 // double yy= dot( ps_nodes[k].xyz, m_dirY); 00424 // _finalNodes[k].x = dot( ps_nodes[k].xyz, m_dirX); 00425 // _finalNodes[k].y = dot( ps_nodes[k].xyz, m_dirY); 00426 m_xy[3*k] = inner_product( ps_nodes[k].xyz, m_dirX); 00427 m_xy[3*k+1] = inner_product( ps_nodes[k].xyz, m_dirY); 00428 // m_finalNodes[k].x = m_xy[2*k]; 00429 // m_finalNodes[k].y = m_xy[2*k+1]; 00430 } 00431 for (int k=0; k<m_2dcapacity; k++) 00432 m_xy[3*k+2] = 0;// the z ccordinate is always 0 !! 00433 // if any edges are collapsed, the corresponding triangles should be collapsed too 00434 // we will collapse the triangles first, then the edges 00435 // when a triangle is collapsed on an edge, it should break in 2 other triangles 00436 // we should really form another triangle array, in 2D 00437 00438 // first, loop over edges and see which are eliminated; 00439 00440 double *edgeLen2D=new double [m_numEdges]; 00441 for (int k=0; k<m_numEdges; k++) 00442 { 00443 00444 int v0 = ps_edges[k].v[0]; 00445 int v1 = ps_edges[k].v[1]; 00446 edgeLen2D[k] = length(Vector<2>(&m_xy[3*v0])-Vector<2>(&m_xy[3*v1])); 00447 } 00448 double *triArea = new double [m_numTriangles]; 00449 for (int k=0; k<m_numTriangles; k++) 00450 { 00451 const int * pV =&( ps_triangles[k].v[0]); 00452 triArea[k] = area2D(Vector<2>(&m_xy[ 3*pV[0]]), 00453 Vector<2>(&m_xy[ 3*pV[1]]), 00454 Vector<2>(&m_xy[ 3*pV[2]])); 00455 } 00456 // if an edge is length 0, we must collapse the nodes, and 2 triangles 00457 // first construct a new 2d mesh 00458 // we will have to classify all triangles, edges 00459 // for each triangle we need to know its original triangle 00460 00461 // first mark all triangles; then count positive, negative and zero area (some tolerance is needed) 00462 int numNeg = 0, numPos = 0, numZero = 0; 00463 // those that are negative will be reverted in the new array 00464 int * newTriId = new int [m_numTriangles]; 00465 for (int k=0; k<m_numTriangles ; k++) 00466 { 00467 if (triArea[k] > 0) 00468 { 00469 //numPos++; 00470 newTriId[k] = numPos++; 00471 } 00472 else if (triArea[k] <0) 00473 { 00474 //numNeg ++; 00475 newTriId[k] = numNeg++; 00476 } 00477 else 00478 { 00479 numZero ++; 00480 newTriId[k] = -1;// receive no Id, as it will not be carried along 00481 } 00482 } 00483 // there are 2 groups: red (positive), blue (negative) 00484 // revert the negative ones, and decide the neighbors 00485 00486 // red triangles are positive, blue are negative 00487 // the negative ones need to be reverted; revert the nodes, first, then edges 00488 // do we really need the edges? or just the neighboring triangles? 00489 // if a neighbor is the other sign or zero, will become boundary marker (large number, m_numTriangles+1) 00490 // 00491 // we need to find first 2 triangles (red and blue) that are intersecting 00492 // they will be the seeds 00493 m_redMesh = new ProjectShell::Triangle2D [numPos] ; 00494 m_blueMesh = new ProjectShell::Triangle2D [numNeg]; 00495 m_numPos = numPos; 00496 m_numNeg = numNeg; 00497 // do another loop, to really build the 2D mesh we start with 00498 // we may have potential starting triangles for the marching along, if the sign of one of the neighbors is 00499 // different 00500 for (int k=0; k<m_numTriangles ; k++) 00501 { 00502 ProjectShell::Triangle3D & orgTria = ps_triangles[k]; 00503 if (triArea[k] > 0) 00504 { 00505 //numPos++; 00506 ProjectShell::Triangle2D & redTria= m_redMesh[newTriId[k]]; 00507 redTria.oldId = k ; // index 00508 redTria.area = triArea[k]; 00509 for (int j=0; j<3; j++) 00510 { 00511 00512 // copy the edge information too 00513 redTria.e[j] = orgTria.e[j]; 00514 // qualify the neighbors 00515 // 00516 int t = orgTria.t[j]; 00517 redTria.v[j] = orgTria.v[j]; 00518 if (triArea[t]>0) 00519 { 00520 redTria.t[j] = newTriId[t];// will be the index in red mesh 00521 } 00522 else 00523 { 00524 redTria.t[j] = numPos; // marker for boundary 00525 } 00526 } 00527 00528 } 00529 else if (triArea[k] <0) 00530 { 00531 //numNeg ++; 00532 ProjectShell::Triangle2D & blueTria= m_blueMesh[newTriId[k]]; 00533 blueTria.oldId = k; 00534 blueTria.area =triArea[k]; // this is for debugging I think 00535 for (int j=0; j<3; j++) 00536 { 00537 // copy the edge information too 00538 blueTria.e[j] = orgTria.e[j]; 00539 // qualify the neighbors 00540 // 00541 int t = orgTria.t[j]; 00542 blueTria.v[j] = orgTria.v[j]; 00543 if (triArea[t]<0) 00544 { 00545 blueTria.t[j] = newTriId[t];// will be the index in red mesh 00546 } 00547 else 00548 { 00549 blueTria.t[j] = numNeg; // marker for boundary 00550 } 00551 } 00552 00553 } 00554 else 00555 { 00556 // numZero ++; 00557 // newTriId[k] = -1;// receive no Id, as it will not be carried along 00558 // nothing to do for null triangles 00559 } 00560 } 00561 // revert the blue triangles, so they become positive oriented too 00562 for (int k=0; k<numNeg; k++) 00563 { 00564 // 00565 ProjectShell::Triangle2D & blueTri = m_blueMesh[k]; 00566 int tmp = blueTri.v[1]; 00567 blueTri.v[1] = blueTri.v[2]; 00568 blueTri.v[2] = tmp; 00569 // this is really stupid: 00570 // we should have switched triangle 1 and 3, not 2 and 3 00571 // hard to catch 00572 tmp = blueTri.t[0]; 00573 blueTri.t[0] = blueTri.t[2]; 00574 blueTri.t[2] = tmp; 00575 // reverse the edges too 00576 tmp = blueTri.e[0]; 00577 blueTri.e[0] = -blueTri.e[2]; 00578 blueTri.e[1] = -blueTri.e[1]; 00579 blueTri.e[2] = -tmp; 00580 } 00581 // at this point, we have red triangles and blue triangles, and 2d nodes array 00582 // we will start creating new triangles, step by step, pointing to the nodes in _finalNodes 00583 m_numCurrentNodes = m_numNodes; 00584 if (m_dbg) 00585 { 00586 m_dbg_out.open("dbg.m"); 00587 m_dbg_out << "P=[ \n"; 00588 for (int i=0; i<m_numNodes; i++) 00589 { 00590 m_dbg_out << m_xy[3*i] << " " << m_xy[3*i+1] << "\n"; 00591 } 00592 m_dbg_out << "];\n "; 00593 m_dbg_out << "Ta=[ \n"; 00594 for (int k=0; k<m_numPos; k++) 00595 { 00596 ProjectShell::Triangle2D & redTri = m_redMesh[k]; 00597 for (int j=0; j<3; j++) 00598 m_dbg_out << redTri.v[j]+1 << " " ; 00599 for (int jj=0; jj<3; jj++) 00600 { 00601 m_dbg_out << redTri.t[jj]+1 << " " ; 00602 } 00603 m_dbg_out << "\n"; 00604 } 00605 m_dbg_out << "]; \n"; 00606 m_dbg_out << "Tb=[ \n"; 00607 for (int kk=0; kk<m_numNeg; kk++) 00608 { 00609 ProjectShell::Triangle2D & blueTri = m_blueMesh[kk]; 00610 for (int j=0; j<3; j++) 00611 m_dbg_out << blueTri.v[j]+1 << " " ; 00612 for (int jj=0; jj<3; jj++) 00613 { 00614 m_dbg_out << blueTri.t[jj]+1 << " " ; 00615 } 00616 m_dbg_out << "\n"; 00617 } 00618 m_dbg_out << "]; \n"; 00619 m_dbg_out.close(); 00620 00621 } 00622 delete [] edgeLen2D; 00623 delete [] triArea; 00624 delete [] newTriId; 00625 return 0; 00626 } 00627 00628 int ProjectShell::computeIntersections() 00629 { 00630 // will start at 2 triangles, and advance an intersection front (2 queues, one for red triangles, one for blue ..) 00631 // will mark a red triangle that is processed, and add to the queue 00632 // for each red triangle will find all the blue triangles that are intersected 00633 // find first 2 triangles that intersect: these will be the seeds for intersection 00634 00635 int startRed=0; 00636 int startBlue = 0; 00637 for (startBlue = 0; startBlue<m_numNeg; startBlue++) 00638 { 00639 double area = 0; 00640 // if area is > 0 , we have intersections 00641 double P[24]; // max 6 points, but it may grow bigger; why worry 00642 int nP = 0; 00643 int n[3];// sides 00644 computeIntersectionBetweenRedAndBlue(/* red */0, startBlue, P, nP, area,n); 00645 if (area>0) 00646 break; // found 2 triangles that intersect; these will be the seeds 00647 } 00648 if (startBlue==m_numNeg) 00649 ERROR("Can't find any triangle"); 00650 00651 // on the red edges, we will keep a list of new points (in 2D) 00652 // they will be used to create or not new points for points P from intersection 00653 // (sometimes the points P are either on sides, or on vertices of blue or even red triangles) 00654 00655 /* 00656 matlab code: 00657 function M=InterfaceMatrix(Na,Ta,Nb,Tb); 00658 % INTERFACEMATRIX projection matrix for nonmatching triangular grids 00659 % M=InterfaceMatrix(Na,Ta,Nb,Tb); takes two triangular meshes Ta 00660 % and Tb with associated nodal coordinates in Na and Nb and 00661 % computes the interface projection matrix M 00662 00663 bl=[1]; % bl: list of triangles of Tb to treat 00664 bil=[1]; % bil: list of triangles Ta to start with 00665 bd=zeros(size(Tb,1)+1,1); % bd: flag for triangles in Tb treated 00666 bd(end)=1; % guard, to treat boundaries 00667 bd(1)=1; % mark first triangle in b list. 00668 M=sparse(size(Nb,2),size(Na,2)); 00669 while length(bl)>0 00670 bc=bl(1); bl=bl(2:end); % bc: current triangle of Tb 00671 al=bil(1); bil=bil(2:end); % triangle of Ta to start with 00672 ad=zeros(size(Ta,1)+1,1); % same as for bd 00673 ad(end)=1; 00674 ad(al)=1; 00675 n=[0 0 0]; % triangles intersecting with neighbors 00676 while length(al)>0 00677 ac=al(1); al=al(2:end); % take next candidate 00678 [P,nc,Mc]=Intersect(Nb(:,Tb(bc,1:3)),Na(:,Ta(ac,1:3))); 00679 if ~isempty(P) % intersection found 00680 M(Tb(bc,1:3),Ta(ac,1:3))=M(Tb(bc,1:3),Ta(ac,1:3))+Mc; 00681 t=Ta(ac,3+find(ad(Ta(ac,4:6))==0)); 00682 al=[al t]; % add neighbors 00683 ad(t)=1; 00684 n(find(nc>0))=ac; % ac is starting candidate for neighbor 00685 end 00686 end 00687 tmp=find(bd(Tb(bc,4:6))==0); % find non-treated neighbors 00688 idx=find(n(tmp)>0); % take those which intersect 00689 t=Tb(bc,3+tmp(idx)); 00690 bl=[bl t]; % and add them 00691 bil=[bil n(tmp(idx))]; % with starting candidates Ta 00692 bd(t)=1; 00693 end 00694 */ 00695 std::queue<int> blueQueue; // these are corresponding to Ta, 00696 blueQueue.push( startBlue); 00697 std::queue<int> redQueue; 00698 redQueue.push (startRed); 00699 // the flags are used for marking the triangles already considered 00700 int * blueFlag = new int [m_numNeg+1]; // number of blue triangles + 1, to account for the boundary 00701 int k=0; 00702 for (k=0; k<m_numNeg; k++) 00703 blueFlag[k] = 0; 00704 blueFlag[m_numNeg] = 1; // mark the "boundary"; stop at the boundary 00705 blueFlag[startBlue] = 1; // mark also the first one 00706 // also, red flag is declared outside the loop 00707 int * redFlag = new int [m_numPos+1]; 00708 00709 if (m_dbg) 00710 m_dbg_out.open("patches.m"); 00711 while( !blueQueue.empty() ) 00712 { 00713 int n[3]; // flags for the side : indices in red mesh start from 0!!! (-1 means not found ) 00714 for (k=0; k<3; k++) 00715 n[k] = -1; // a paired red not found yet for the neighbors of blue 00716 int currentBlue = blueQueue.front(); 00717 blueQueue.pop(); 00718 for (k=0; k<m_numPos; k++) 00719 redFlag[k] = 0; 00720 redFlag[m_numPos] = 1; // to guard for the boundary 00721 int currentRed = redQueue.front(); // where do we check for redQueue???? 00722 // red and blue queues are parallel 00723 redQueue.pop();// 00724 redFlag[currentRed] = 1; // 00725 std::queue<int> localRed; 00726 localRed.push(currentRed); 00727 while( !localRed.empty()) 00728 { 00729 // 00730 int redT = localRed.front(); 00731 localRed.pop(); 00732 double P[24], area; 00733 int nP = 0; // intersection points 00734 int nc[3]= {0, 0, 0}; // means no intersection on the side (markers) 00735 computeIntersectionBetweenRedAndBlue(/* red */redT, currentBlue, P, nP, area,nc); 00736 if (nP>0) 00737 { 00738 // intersection found: output P and original triangles if nP > 2 00739 if (m_dbg && area>0) 00740 { 00741 //std::cout << "area: " << area<< " nP:"<<nP << " sources:" << redT+1 << ":" << m_redMesh[redT].oldId << 00742 // " " << currentBlue+1<< ":" << m_blueMesh[currentBlue].oldId << std::endl; 00743 } 00744 if (m_dbg) 00745 { 00746 m_dbg_out << "pa=[\n"; 00747 00748 for (k=0; k<nP; k++) 00749 { 00750 00751 m_dbg_out << P[2*k] << "\t " ; 00752 } 00753 00754 m_dbg_out << "\n"; 00755 for (k=0; k<nP; k++) 00756 { 00757 00758 m_dbg_out << P[2*k+1] << "\t "; 00759 } 00760 00761 m_dbg_out << " ]; \n"; 00762 m_dbg_out << " patch(pa(1,:),pa(2,:),'m'); \n"; 00763 } 00764 // add neighbors to the localRed queue, if they are not marked 00765 for (int nn= 0; nn<3; nn++) 00766 { 00767 int neighbor = m_redMesh[redT].t[nn]; 00768 if (redFlag[neighbor] == 0) 00769 { 00770 localRed.push(neighbor); 00771 redFlag[neighbor] =1; // flag it to not be added anymore 00772 } 00773 // n(find(nc>0))=ac; % ac is starting candidate for neighbor 00774 if (nc[nn]>0) // intersected 00775 n[nn] = redT;// start from 0!! 00776 } 00777 if (nP>1) // this will also construct triangles, if needed 00778 findNodes(redT, currentBlue, P, nP); 00779 } 00780 00781 } 00782 for (int j=0; j<3; j++) 00783 { 00784 int blueNeigh = m_blueMesh[currentBlue].t[j]; 00785 if (blueFlag[blueNeigh]==0 && n[j] >=0 ) // not treated yet and marked as a neighbor 00786 { 00787 // we identified triangle n[j] as intersecting with neighbor j of the blue triangle 00788 blueQueue.push(blueNeigh); 00789 redQueue.push(n[j]); 00790 if (m_dbg) 00791 std::cout << "new triangles pushed: blue, red:" << blueNeigh+1 << " " << n[j]+1 << std::endl; 00792 blueFlag[blueNeigh] = 1; 00793 } 00794 } 00795 } 00796 delete [] redFlag; 00797 redFlag = NULL; 00798 00799 delete [] blueFlag; // get rid of it 00800 blueFlag = NULL; 00801 if (m_dbg) 00802 m_dbg_out.close(); 00803 return 0; 00804 } 00805 00806 00807 int borderPointsOfXinY(double * X, double * Y, double * P) 00808 { 00809 // 2 triangles, 3 corners, is the corner of X in Y? 00810 // Y must have a positive area 00811 /* 00812 function P=PointsOfXInY(X,Y); 00813 % POINTSOFXINY finds corners of one triangle within another one 00814 % P=PointsOfXInY(X,Y); computes for the two given triangles X 00815 % and Y (point coordinates are stored column-wise, in counter clock 00816 % order) the corners P of X which lie in the interior of Y. 00817 00818 k=0;P=[]; 00819 v0=Y(:,2)-Y(:,1); v1=Y(:,3)-Y(:,1); % find interior points of X in Y 00820 d00=v0'*v0; d01=v0'*v1; d11=v1'*v1; % using baricentric coordinates 00821 id=1/(d00*d11-d01*d01); 00822 for i=1:3 00823 v2=X(:,i)-Y(:,1); d02=v0'*v2; d12=v1'*v2; 00824 u=(d11*d02-d01*d12)*id; v=(d00*d12-d01*d02)*id; 00825 if u>=0 & v>=0 & u+v<=1 % also include nodes on the boundary 00826 k=k+1; P(:,k)=X(:,i); 00827 end; 00828 end; 00829 */ 00830 int extraPoint = 0; 00831 for (int i=0; i<3; i++) 00832 { 00833 // compute twice the area of all 3 triangles formed by a side of Y and a corner of X; if one is negative, stop 00834 double A[2]; 00835 for (int k=0; k<2; k++) 00836 A[k] = X[2*i+k]; 00837 int inside=1; 00838 for (int j=0; j<3; j++) 00839 { 00840 double B[2], C[2]; 00841 for (int k=0; k<2; k++) 00842 { 00843 B[k] = Y[2*j+k]; 00844 int j1 = (j+1)%3; 00845 C[k] = Y[2*j1+k]; 00846 } 00847 00848 double area2 = (B[0]-A[0])*(C[1]-A[1])-(C[0]-A[0])*(B[1]-A[1]); 00849 if (area2<0.) 00850 { 00851 inside = 0; break; 00852 } 00853 } 00854 if (inside) 00855 { 00856 P[extraPoint*2 ] = A[0]; 00857 P[extraPoint*2+1] = A[1]; 00858 extraPoint++; 00859 } 00860 } 00861 return extraPoint; 00862 } 00863 00864 /* 00865 function P=SortAndRemoveDoubles(P); 00866 % SORTANDREMOVEDOUBLES sort points and remove duplicates 00867 % P=SortAndRemoveDoubles(P); orders polygon corners in P counter 00868 % clock wise and removes duplicates 00869 00870 ep=10*eps; % tolerance for identical nodes 00871 m=size(P,2); 00872 if m>0 00873 c=sum(P')'/m; % order polygon corners counter 00874 for i=1:m % clockwise 00875 d=P(:,i)-c; ao(i)=angle(d(1)+sqrt(-1)*d(2)); 00876 end; 00877 [tmp,id]=sort(ao); 00878 P=P(:,id); 00879 i=1;j=2; % remove duplicates 00880 while j<=m 00881 if norm(P(:,i)-P(:,j))>ep 00882 i=i+1;P(:,i)=P(:,j);j=j+1; 00883 else 00884 j=j+1; 00885 end; 00886 end; 00887 P=P(:,1:i); 00888 end; 00889 */ 00890 00891 int swap (double * p , double * q) 00892 { 00893 double tmp = *p; 00894 *p = *q; 00895 *q = tmp; 00896 return 0; 00897 } 00898 int SortAndRemoveDoubles(double * P, int & nP) 00899 { 00900 if (nP<2) 00901 return 0; // nothing to do 00902 // center of gravity for the points 00903 double c[2] = {0., 0.}; 00904 int k=0; 00905 for (k=0; k<nP; k++) 00906 { 00907 c[0]+=P[2*k]; 00908 c[1]+=P[2*k+1]; 00909 } 00910 c[0]/=nP; 00911 c[1]/=nP; 00912 double angle[12]; // could be at most 12 points; much less usually 00913 for (k=0; k<nP; k++) 00914 { 00915 double x = P[2*k] - c[0], y = P[2*k+1] - c[1] ; 00916 if ( x!= 0. || y!=0.) 00917 angle[k] = atan2(y, x); 00918 else 00919 { 00920 angle[k] = 0; 00921 // this means that the points are on a line, or all coincident // degenerate case 00922 } 00923 } 00924 // sort according to angle; also eliminate close points 00925 int sorted = 1; 00926 do 00927 { 00928 sorted = 1; 00929 for(k=0; k<nP-1; k++) 00930 { 00931 if (angle[k]>angle[k+1]) 00932 { 00933 sorted = 0; 00934 swap ( angle+k, angle+k+1); 00935 swap ( P+(2*k), P+(2*k+2)); 00936 swap ( P+(2*k+1), P+(2*k+3)); 00937 } 00938 } 00939 } 00940 while (!sorted); 00941 // eliminate doubles 00942 00943 int i=0, j=1; // the next one; j may advance faster than i 00944 // check the unit 00945 // these are cm; 2 points are the same if the distance is less than epsilon 00946 while (j<nP) 00947 { 00948 double d2 = length(Vector<2>(&P[2*i])-Vector<2>(&P[2*j])); 00949 if (d2 > epsilon) 00950 { 00951 i++; 00952 P[2*i] = P[2*j]; 00953 P[2*i+1] = P[2*j+1]; 00954 } 00955 j++; 00956 } 00957 // test also the last point with the first one (index 0) 00958 00959 double d2 = length(Vector<2>(P)-Vector<2>(&P[2*i])); // check the first and last points (ordered from -pi to +pi) 00960 if (d2 > epsilon) 00961 { 00962 nP = i+1; 00963 } 00964 else 00965 nP = i; // effectively delete the last point (that would have been the same with first) 00966 if (nP==0) 00967 nP=1; // we should be left with at least one point we already tested if nP is 0 originally 00968 return 0; 00969 } 00970 00971 // this method computed intersection between 2 triangles: will output n points, area, affected sides 00972 int ProjectShell::computeIntersectionBetweenRedAndBlue(int red, int blue, double * P, int & nP, double & area, int mark[3]) { 00973 // the points will be at most 9; they will describe a convex patch, after the points will be ordered and 00974 // collapsed (eliminate doubles) 00975 // the area is not really required 00976 ProjectShell::Triangle2D & redTri = m_redMesh[red]; 00977 ProjectShell::Triangle2D & blueTri = m_blueMesh[blue]; 00978 double redTriangle[6];// column wise 00979 double blueTriangle[6]; 00980 for (int i=0; i<3; i++) 00981 { 00982 // node i, 2 coordinates 00983 for (int k=0; k<2; k++) 00984 { 00985 int node = redTri.v[i]; 00986 redTriangle[2*i+k] = m_xy[3*node+k]; 00987 00988 node = blueTri.v[i]; 00989 blueTriangle[2*i+k] = m_xy[3*node+k]; 00990 } 00991 } 00992 /* Matlab source code: 00993 function [P,n,M]=Intersect(X,Y); 00994 % INTERSECT intersection of two triangles and mortar contribution 00995 % [P,n,M]=Intersect(X,Y); computes for the two given triangles X and 00996 % Y (point coordinates are stored column-wise, in counter clock 00997 % order) the points P where they intersect, in n the indices of 00998 % which neighbors of X are also intersecting with Y, and the local 00999 % mortar matrix M of contributions of the P1 elements X on the P1 01000 % element Y. The numerical challenges are handled by including 01001 % points on the boundary and removing duplicates at the end. 01002 01003 [P,n]=EdgeIntersections(X,Y); 01004 P1=PointsOfXInY(X,Y); 01005 if size(P1,2)>1 % if two or more interior points 01006 n=[1 1 1]; % the triangle is candidate for all 01007 end % neighbors 01008 P=[P P1]; 01009 P=[P PointsOfXInY(Y,X)]; 01010 P=SortAndRemoveDoubles(P); % sort counter clock wise 01011 M=zeros(3,3); 01012 if size(P,2)>0 01013 for j=2:size(P,2)-1 % compute interface matrix 01014 M=M+MortarInt(P(:,[1 j j+1]),X,Y); 01015 end; 01016 patch(P(1,:),P(2,:),'m') % draw intersection for illustration 01017 % H=line([P(1,:) P(1,1)],[P(2,:),P(2,1)]); 01018 % set(H,'LineWidth',3,'Color','m'); 01019 pause(0) 01020 end; 01021 01022 01023 */ 01024 //we do not really need the mortar matrix 01025 01026 //int n[3]={0, 0, 0};// no intersection of side red with blue 01027 //double area= 0.; 01028 // X corresponds to blue, Y to red 01029 nP=0; // number of intersection points 01030 int ret = edgeIntersections(blueTriangle, redTriangle, mark, P, nP); 01031 if (ret!=0) ERROR("Something went wrong"); 01032 01033 int extraPoints = borderPointsOfXinY(blueTriangle, redTriangle, &(P[2*nP])); 01034 if (extraPoints>1) 01035 { 01036 mark[0] = mark[1] = mark[2]=1; 01037 } 01038 nP+=extraPoints; 01039 extraPoints = borderPointsOfXinY(redTriangle, blueTriangle, &(P[2*nP])); 01040 nP+=extraPoints; 01041 01042 // now sort and orient the points in P, such that they are forming a convex polygon 01043 // this will be the foundation of our new mesh 01044 // 01045 SortAndRemoveDoubles (P, nP); // nP should be at most 6 in the end 01046 // if there are more than 3 points, some area will be positive 01047 area = 0.; 01048 if (nP>=3) 01049 { 01050 for (int k=1; k<nP-1; k++) 01051 area += area2D(Vector<2>(P), Vector<2>(&P[2*k]), Vector<2>(&P[2*k+2])); 01052 } 01053 return 0; // no error 01054 } 01055 01056 int ProjectShell::findNodes(int red, int blue, double * iP, int nP) 01057 { 01058 // first of all, check against red and blue vertices 01059 // 01060 if (m_dbg) 01061 { 01062 std::cout<< "red, blue, nP, P " << red << " " << blue << " " << nP <<"\n"; 01063 for (int n=0; n<nP; n++) 01064 std::cout << " \t" << iP[2*n] << "\t" << iP[2*n+1] << "\n"; 01065 01066 } 01067 int * foundIds = new int [nP]; 01068 for (int i=0; i<nP; i++) 01069 { 01070 double * pp = &iP[2*i];// iP+2*i 01071 int found = 0; 01072 // first, are they on vertices from red or blue? 01073 ProjectShell::Triangle2D & redTri = m_redMesh[red]; 01074 int j=0; 01075 for (j=0; j<3&& !found; j++) 01076 { 01077 int node = redTri.v[j]; 01078 double d2 = length(Vector<2>(pp)-Vector<2>(m_xy+(3*node))); 01079 if (m_dbg && i==0) 01080 std::cout<< " red node " << j << " " << node << " " << m_xy[3*node] << " " << m_xy[3*node+1] << " d2:" << d2 << " \n"; 01081 if (d2<epsilon) 01082 { 01083 foundIds[i] = node; // no new node 01084 found = 1; 01085 } 01086 } 01087 ProjectShell::Triangle2D & blueTri = m_blueMesh[blue]; 01088 for (j=0; j<3 && !found; j++) 01089 { 01090 int node = blueTri.v[j]; 01091 double d2 = length(Vector<2>(pp)-Vector<2>(m_xy+(3*node))); 01092 if (m_dbg && i==0) 01093 std::cout<< " blue node " << j << " " << node << " " << m_xy[3*node] << " " << m_xy[3*node+1] << " d2:" << d2 << " \n"; 01094 if (d2<epsilon) 01095 { 01096 foundIds[i] = node; // no new node 01097 found = 1; 01098 } 01099 } 01100 if (!found) 01101 { 01102 // find the edge it belongs, first 01103 // 01104 for (j=0; j<3; j++) 01105 { 01106 int edge = redTri.e[j]; 01107 int ae = abs(edge); 01108 int v1 = ps_edges[ae-1].v[0]; 01109 int v2 = ps_edges[ae-1].v[1]; 01110 double area = area2D (Vector<2>(&m_xy[3*v1]), 01111 Vector<2>(&m_xy[3*v2]), 01112 Vector<2>(pp)); 01113 if (m_dbg) 01114 std::cout << " edge " << j << ": " << edge << " " << v1 << " " << v2 << " area : " << area << "\n"; 01115 if ( fabs(area) < epsilon*epsilon ) 01116 { 01117 // found the edge; now find if there is a point in the list here 01118 std::list<int> & expts = ps_edges[ae-1].extraNodes; 01119 // if the points pp is between extra points, then just give that id 01120 // if not, create a new point, (check the id) 01121 // 01122 std::list<int>::iterator it; 01123 for ( it = expts.begin(); it!=expts.end() && !found; it++) 01124 { 01125 int pnt = *it; 01126 double d2 = length(Vector<2>(pp)-Vector<2>(&m_xy[3*pnt])); 01127 if (d2<epsilon) 01128 { 01129 found = 1; 01130 foundIds[i] = pnt; 01131 } 01132 } 01133 if (!found) 01134 { 01135 // create a new point in 2d (at the intersection) 01136 foundIds [i] = m_num2dPoints; 01137 expts.push_back(m_num2dPoints); 01138 if (m_2dcapacity < m_num2dPoints+1) 01139 { 01140 // Underestimated the number of intersection points 01141 //std::cout << " underestimated capacity for 2d array\n"; 01142 // double the capacity of m_xy array 01143 01144 double * new_xy = new double [6* m_2dcapacity]; 01145 int jj=0; 01146 for (jj=0; jj<3*m_2dcapacity; jj++) 01147 { 01148 new_xy[jj] = m_xy[jj]; 01149 01150 } 01151 for (jj=3*m_2dcapacity-1; jj<6*m_2dcapacity; jj+=3) 01152 new_xy[jj] = 0.; 01153 // make 0 the z coordinate 01154 m_2dcapacity *= 2; 01155 delete [] m_xy; 01156 m_xy = new_xy; 01157 } 01158 m_xy[3*m_num2dPoints] = pp[0]; 01159 m_xy[3*m_num2dPoints+1] = pp[1]; 01160 m_num2dPoints++; 01161 if (m_dbg) 01162 { 01163 std::cout<< " new 2d " << m_num2dPoints - 1 << " : " << pp[0] << " " << pp[1] << "on edge " << ae << "\n"; 01164 } 01165 found = 1; 01166 } 01167 } 01168 } 01169 } 01170 if (!found) 01171 { 01172 ERROR3("Point (%g,%g) is not on a red triangle %d", pp[0], pp[1], red); 01173 } 01174 } 01175 // now we can build the triangles, from P array, with foundIds 01176 if (nP>=3) 01177 { 01178 // what are the triangles 01179 FinalTriangle ftr; 01180 ftr.redTriangle = red; 01181 ftr.blueTriangle = blue; 01182 ftr.v[0] = foundIds[0]; 01183 for (int i=1; i<=nP-2; i++) 01184 { 01185 // triangle 0, i, i+1 01186 ftr.v[1]=foundIds[i]; 01187 ftr.v[2] = foundIds[i+1]; 01188 m_finalMesh.push_back(ftr); 01189 if (m_dbg) 01190 { 01191 std::cout << " triangle " << ftr.v[0] << " " << ftr.v[1] << " " << ftr.v[2] << "\n"; 01192 } 01193 } 01194 } 01195 delete [] foundIds; 01196 foundIds = NULL; 01197 return 0; 01198 } 01199 01200 #if 0 01201 int ProjectShell::commitProjectedMesh() 01202 { 01203 // here we will create new vertices, and use the coordinates in 2D 01204 // m_num2dPoints is the number of nodes (some are not used, because they were probably // collapsed 01205 // we do not specifically merge red and blue nodes, but we are looking first for 01206 // nodes in red , then blue, then on red edges; some will not appear, according 01207 // to the tolerance 01208 // 01209 //iMesh_Instance mesh = this->mk_core()->imesh_instance(); 01210 iMesh_Instance mesh = NULL; 01211 iBase_EntityHandle * newVerts = NULL; // no vertices yet 01212 // iBase_INTERLEAVED 01213 int err= 0; 01214 int size1, size2; 01215 iMesh_createVtxArr(mesh, 01216 /*in*/ m_num2dPoints, 01217 /*in*/ iBase_INTERLEAVED, 01218 /*in*/ m_xy, 01219 /*in*/ m_num2dPoints*3, 01220 /*inout*/ &newVerts, 01221 /*inout*/ &size1, 01222 /*inout*/ &size2, 01223 /*out*/ &err); 01224 if (err!=0) 01225 { 01226 std::cout<<"can't create vertices\n"; 01227 exit (1); 01228 } 01229 // size of 01230 // then entity set, then elements (triangles) 01231 // 01232 int numTriangles = m_finalMesh.size(); 01233 long int * adjacency = new long int [3*numTriangles]; 01234 iBase_EntityHandle * conn = (iBase_EntityHandle *)adjacency; 01235 for (int L =0; L<numTriangles; L++) 01236 { 01237 FinalTriangle & tria = m_finalMesh[L]; 01238 01239 01240 for (int k=0; k<3; k++) 01241 { 01242 int indexInV = tria.v[k]; 01243 conn[3*L+k] = newVerts[indexInV]; 01244 } 01245 } 01246 int numElements = numTriangles; 01247 iBase_EntitySetHandle orig_set; 01248 iMesh_createEntSet(mesh, 0, &orig_set, &err); 01249 int n = numTriangles; 01250 int junk1 = n, junk2 = n, junk3 = n, junk4 = n; 01251 int * stat = new int [numElements]; 01252 int* ptr2 = stat; 01253 int ierr; 01254 iBase_EntityHandle * new_entity_handles = NULL; 01255 iMesh_createEntArr( mesh, 01256 iMesh_TRIANGLE, 01257 conn, 3*numElements, 01258 &new_entity_handles, &junk1, &junk2, 01259 &ptr2, &junk3, &junk4, 01260 &ierr ); 01261 if (ierr!=0) 01262 { 01263 std::cout<<" can't create triangles\n"; 01264 exit (1); 01265 } 01266 iMesh_addEntArrToSet ( mesh, 01267 new_entity_handles, 01268 numElements, 01269 orig_set, 01270 &ierr); 01271 if (ierr!=0) 01272 { 01273 std::cout<< " can't add to entity set \n"; 01274 exit(1); 01275 } 01276 // now, look at the tags : red is positive, blue is negative oriented triangle 01277 iBase_TagHandle pos_tag_handle; 01278 01279 const char * tagName1 = "Positive"; 01280 iMesh_createTag ( mesh, 01281 tagName1, 01282 /* size ? */ 1, 01283 iBase_INTEGER , 01284 &pos_tag_handle, 01285 &ierr, 01286 strlen(tagName1) ) ; 01287 01288 if (ierr!=0) 01289 { 01290 std::cout<< " can't create positive tag \n"; 01291 exit(1); 01292 } 01293 int * tagValues = new int [numElements]; 01294 for (int e=0; e<numElements; e++) 01295 { 01296 int redId = m_finalMesh[e].redTriangle; 01297 tagValues[e] = m_redMesh[ redId ].oldId; 01298 01299 } 01300 // positive or negative triangles 01301 iMesh_setIntArrData ( mesh, 01302 new_entity_handles, 01303 numElements, 01304 pos_tag_handle, 01305 tagValues, 01306 numElements, 01307 &ierr); 01308 if (ierr!=0) 01309 { 01310 std::cout<< " can't create positive tag field \n"; 01311 exit(1); 01312 } 01313 // now blue tag 01314 // now, look at the tags : red is positive, blue is negative oriented triangle 01315 iBase_TagHandle neg_tag_handle; 01316 01317 const char * tagName2 = "Negative"; 01318 iMesh_createTag ( mesh, 01319 tagName2, 01320 /* size ? */ 1, 01321 iBase_INTEGER , 01322 &neg_tag_handle, 01323 &ierr, 01324 strlen(tagName1) ) ; 01325 01326 if (ierr!=0) 01327 { 01328 std::cout<< " can't create negative tag \n"; 01329 exit(1); 01330 } 01331 for (int e=0; e<numElements; e++) 01332 { 01333 int blueId = m_finalMesh[e].blueTriangle; 01334 tagValues[e] = m_blueMesh[ blueId ].oldId; 01335 01336 } 01337 // positive or negative triangles 01338 iMesh_setIntArrData ( mesh, 01339 new_entity_handles, 01340 numElements, 01341 neg_tag_handle, 01342 tagValues, 01343 numElements, 01344 &ierr); 01345 if (ierr!=0) 01346 { 01347 std::cout<< " can't create negative tag field \n"; 01348 exit(1); 01349 } 01350 delete [] tagValues; 01351 delete [] adjacency; 01352 return 0; 01353 } 01354 #endif 01355 int edgeIntersections(double * red, double * blue, int mark[3], double * points, int & nPoints) 01356 { 01357 /* EDGEINTERSECTIONS computes edge intersections of two triangles 01358 [P,n]=EdgeIntersections(X,Y) computes for the two given triangles * red 01359 and blue ( stored column wise ) 01360 (point coordinates are stored column-wise, in counter clock 01361 order) the points P where their edges intersect. In addition, 01362 in n the indices of which neighbors of red are also intersecting 01363 with blue are given. 01364 */ 01365 01366 // points is an array with 12 slots (12 * 2 doubles) 01367 nPoints = 0; 01368 mark[0] = mark[1] = mark[2]=0 ; // no neighbors of red involved yet 01369 /*for i=1:3 % find all intersections of edges 01370 for j=1:3 01371 b=Y(:,j)-X(:,i); 01372 A=[X(:,mod(i,3)+1)-X(:,i) -Y(:,mod(j,3)+1)+Y(:,j)]; 01373 if rank(A)==2 % edges not parallel 01374 r=A\b; 01375 if r(1)>=0 & r(1)<=1 & r(2)>=0 & r(2)<=1, % intersection found 01376 k=k+1; P(:,k)=X(:,i)+r(1)*(X(:,mod(i,3)+1)-X(:,i)); n(i)=1; 01377 end; 01378 end; 01379 end; 01380 end;*/ 01381 for (int i=0; i<3; i++) 01382 { 01383 for (int j=0; j<3; j++) 01384 { 01385 double b[2]; 01386 double a[2][2]; // 2*2 01387 int iPlus1 = (i+1)%3; 01388 int jPlus1 = (j+1)%3; 01389 for (int k=0; k<2; k++) 01390 { 01391 b[k] = blue[2*j+k] - red[2*i+k]; 01392 // row k of a: a(k, 0), a(k, 1) 01393 a[ k ][0] = red [ 2*iPlus1 + k] - red [2*i + k]; 01394 a[ k ][1] = blue [ 2 * j + k] - blue [2*jPlus1 +k]; 01395 01396 } 01397 double delta = a[0][0]*a[1][1] - a[0][1]*a[1][0]; 01398 if (delta != 0.) 01399 { 01400 // not parallel 01401 double alfa = (b[0]*a[1][1]-a[0][1]*b[1])/delta; 01402 double beta = (-b[0] * a[1][0] + b[1] * a[0][0])/delta; 01403 if (0<= alfa && alfa <=1. && 0<= beta && beta <= 1.) 01404 { 01405 // the intersection is good 01406 for (int k=0; k<2; k++) 01407 { 01408 points[2*nPoints+k] = red[2*i+k] + alfa*(red[2*iPlus1+k]-red[2*i+k]); 01409 } 01410 mark[i] = 1; // so neighbor number i will be considered too. 01411 nPoints++; 01412 } 01413 } 01414 01415 } 01416 } 01417 return 0; 01418 } 01419 01420 }//namespace MeshKit 01421 01422 01423 01424 01425 01426 01427
