MeshKit
1.0
00001 00011 #include <iostream> 00012 00013 #include "meshkit/AF2PlaneProjection.hpp" 00014 #include "meshkit/AF2Point2D.hpp" 00015 #include "meshkit/AF2Point3D.hpp" 00016 #include "meshkit/MKCore.hpp" 00017 #include "meshkit/ModelEnt.hpp" 00018 #include "meshkit/Matrix.hpp" 00019 00020 using namespace MeshKit; 00021 00022 #include "TestUtil.hpp" 00023 00024 #if HAVE_OCC 00025 #define FILE_EXT "stp" 00026 double epsError = 1.e-12; 00027 #else 00028 #define FILE_EXT "facet" 00029 double epsError = 1.e-3; 00030 #endif 00031 00032 MKCore *mk = NULL; 00033 00034 void test_plane_projection(); 00035 bool testPlaneProj(); 00036 00037 int main(int argc, char **argv) 00038 { 00039 00040 // start up MK and load the geometry 00041 int num_fail = 0; 00042 00043 num_fail += RUN_TEST(test_plane_projection); 00044 00045 return num_fail; 00046 00047 } 00048 00049 void test_plane_projection() 00050 { 00051 CHECK(testPlaneProj()); 00052 } 00053 00054 bool testPlaneProj() 00055 { 00056 int failCount = 0; 00057 00058 mk = new MKCore(); 00059 00060 std::string file_name = TestDir + "/pieceOfTorus01." + FILE_EXT; 00061 mk->load_geometry_mesh(file_name.c_str(), file_name.c_str()); 00062 00063 MEntVector surfs; 00064 mk->get_entities_by_dimension(2, surfs); 00065 ModelEnt *this_surf = (*surfs.begin()); 00066 00067 MeshKit::Vector<3> origin; 00068 // point on surface is at approx (2.82842712474619, 2.82842712474619, 0) 00069 // = (4*sin(pi/4), 4*sin(pi/4), 0) = (4*sqrt(2)/2, 4*sqrt(2)/2, 0) 00070 origin[0] = 2.8; 00071 origin[1] = 2.8; 00072 origin[2] = 0.0; 00073 MeshKit::Vector<3> normal; 00074 normal[0] = 0.7071067811865476; // sqrt(2)/2 00075 normal[1] = 0.7071067811865476; 00076 normal[2] = 0.0; 00077 MeshKit::Vector<3> xDir; 00078 xDir[0] = -0.7071067811865476; 00079 xDir[1] = 0.7071067811865476; 00080 xDir[2] = 0.0; 00081 AF2PlaneProjection planeProj(this_surf->igeom_instance(), 00082 this_surf->geom_handle(), origin, normal, xDir, 1.0); 00083 std::cout << "Created plane passing through (2.8, 2.8, 0) " 00084 << "normal to (1, 1, 0)." << std::endl; 00085 std::cout << "The y-coordinate in the plane is in the direction of " 00086 << "the z-axis." << std::endl; 00087 00088 00089 // 2.8059735404411 is (sqrt(2)/2) * (3 + cos(asin(0.25))) 00090 AF2Point3D testPnt(0, 2.8059735404411, 2.8059735404411, 0.25); 00091 bool legal=true; 00092 AF2Point2D* planePnt = planeProj.transformFromSurface(testPnt, legal); 00093 std::cout << "Transform (" << testPnt.getX() << ", " << testPnt.getY() << ", " 00094 << testPnt.getZ() << ") from surface to plane." << std::endl; 00095 std::cout << "Coordinates in plane: (" << planePnt->getX() << ", " 00096 << planePnt->getY() << ")" << std::endl; 00097 if ((fabs(planePnt->getX() - 0.0) + fabs(planePnt->getY() - 0.25)) > epsError) 00098 { 00099 std::cout << "FAIL: The coordinates in the plane should be (0, 0.25)." 00100 << std::endl; 00101 ++failCount; 00102 } 00103 delete planePnt; 00104 00105 // 0.1539268506556547 is sin(acos(2.82 * sqrt(2) - 3)) 00106 AF2Point2D planeTestPntA(0, 0.1539268506556547); 00107 AF2Point3D* surfacePnt = planeProj.transformToSurface(planeTestPntA, 1); 00108 std::cout << "Transform (" << planeTestPntA.getX() << ", " 00109 << planeTestPntA.getY() << ") from plane to surface." << std::endl; 00110 std::cout << "Coordinates on surface: (" << surfacePnt->getX() << ", " 00111 << surfacePnt->getY() << ", " << surfacePnt->getZ() << ")" << std::endl; 00112 if ((fabs(surfacePnt->getX() - 2.82) + fabs(surfacePnt->getY() - 2.82) + 00113 fabs(surfacePnt->getZ() - 0.15392685065547)) > epsError) 00114 { 00115 std::cout << "FAIL: The coordinates on the surface should be\n" 00116 << " (2.82, 2.82, 0.15392685065547)." 00117 << std::endl; 00118 ++failCount; 00119 } 00120 delete surfacePnt; 00121 00122 // 0.574682269122808 is sin(acos(2.7 * sqrt(2) - 3)) 00123 AF2Point2D planeTestPntB(0, 0.574682269122808); 00124 surfacePnt = planeProj.transformToSurface(planeTestPntB, 2); 00125 std::cout << "Transform (" << planeTestPntB.getX() << ", " 00126 << planeTestPntB.getY() << ") from plane to surface." << std::endl; 00127 std::cout << "Coordinates on surface: (" << surfacePnt->getX() << ", " 00128 << surfacePnt->getY() << ", " << surfacePnt->getZ() << ")" << std::endl; 00129 if ((fabs(surfacePnt->getX() - 2.7) + fabs(surfacePnt->getY() - 2.7) + 00130 fabs(surfacePnt->getZ() - 0.574682269122808)) > epsError) 00131 { 00132 std::cout << "FAIL: The coordinates on the surface should be\n" 00133 << " (2.7, 2.7, 0.574682269122808)." 00134 << std::endl; 00135 ++failCount; 00136 } 00137 delete surfacePnt; 00138 00139 00140 // create a plane projection (with a normal that does not agree with the 00141 // normal of any plane tangent to the surface) such that there will 00142 // be points on the surface on both sides of the plane 00143 origin[0] = 3.5; 00144 origin[1] = 0.0; 00145 origin[2] = 0.0; 00146 normal[0] = -0.7071067811865476; // -sqrt(2)/2 00147 normal[1] = 0.0; 00148 normal[2] = 0.7071067811865476; 00149 xDir[0] = 0.7071067811865476; 00150 xDir[1] = 0.0; 00151 xDir[2] = 0.7071067811865476; 00152 AF2PlaneProjection wackyProj(this_surf->igeom_instance(), 00153 this_surf->geom_handle(), origin, normal, xDir, 1.0); 00154 std::cout << "Created plane passing through (3.5, 0, 0) " 00155 << "normal to (-1, 0, 1)." << std::endl; 00156 std::cout << "The y-coordinate in the plane is in the direction of " 00157 << "the y-axis." << std::endl; 00158 00159 // test projecting a point from this plane onto the surface 00160 // given x = 3.95, y = 0.1, 00161 // z = sqrt(-8 + 6 * sqrt (x * x + y * y) - x * x - y * y) 00162 // ~ 0.3083726968400695 is the coordinate of the point on the surface 00163 // this projects to roughly (3.87918634842, 0.1, 0.37918634842) as a 00164 // 3-dimensional pooint on the plane, computing z-coordinate there as 00165 // z + (0.45 - z)/2. Thus 2-dimensional planar coordinates are as 00166 // follows, with the first coordinat as 3-d z-coord divided by sqrt(2)/2 00167 AF2Point2D planeTestPntC(0.53625047660234298437463798744018, 0.1); 00168 surfacePnt = wackyProj.transformToSurface(planeTestPntC, 3); 00169 std::cout << "Transform (" << planeTestPntC.getX() << ", " 00170 << planeTestPntC.getY() << ") from plane to surface." << std::endl; 00171 std::cout << "Coordinates on surface: (" << surfacePnt->getX() << ", " 00172 << surfacePnt->getY() << ", " << surfacePnt->getZ() << ")" << std::endl; 00173 // expect ~ (3.95, 0.1, 0.3083726968400695) 00174 if ((fabs(surfacePnt->getX() - 3.95) + fabs(surfacePnt->getY() - 0.1) + 00175 fabs(surfacePnt->getZ() - 0.3083726968400695)) > epsError) 00176 { 00177 std::cout << "FAIL: The coordinates on the surface should be\n" 00178 << " (3.95, 0.1, 0.3083726968400695)." 00179 << std::endl; 00180 ++failCount; 00181 } 00182 // The line also intersects the surface near (3.30723, 0.1, 0.951148), 00183 // but that point is farther away from the plane than the expected result. 00184 delete surfacePnt; 00185 00186 00187 // Perform a similar test with the plane origin at x = 2.6 00188 origin[0] = 2.6; 00189 AF2PlaneProjection wackyProjShift01(this_surf->igeom_instance(), 00190 this_surf->geom_handle(), origin, normal, xDir, 1.0); 00191 std::cout << "Created plane passing through (2.6, 0, 0) " 00192 << "normal to (-1, 0, 1)." << std::endl; 00193 std::cout << "The y-coordinate in the plane is in the direction of " 00194 << "the y-axis." << std::endl; 00195 00196 AF2Point2D planeTestPntD(1.17264657967023277, 0.1); 00197 surfacePnt = wackyProjShift01.transformToSurface(planeTestPntD, 4); 00198 std::cout << "Transform (" << planeTestPntD.getX() << ", " 00199 << planeTestPntD.getY() << ") from plane to surface." << std::endl; 00200 std::cout << "Coordinates on surface: (" << surfacePnt->getX() << ", " 00201 << surfacePnt->getY() << ", " << surfacePnt->getZ() << ")" << std::endl; 00202 if ((fabs(surfacePnt->getX() - 3.3072251285719) + 00203 fabs(surfacePnt->getY() - 0.1) + 00204 fabs(surfacePnt->getZ() - 0.9511475682682)) > epsError) 00205 { 00206 std::cout << "FAIL: The coordinates on the surface should be\n" 00207 << " (3.30722512857195, 0.1, 0.9511475682682)." 00208 << std::endl; 00209 ++failCount; 00210 } 00211 // The line also intersects the surface near (3.95, 0.1, 0.3083726968400695) 00212 // but that point is farther away from the plane than the expected result. 00213 delete surfacePnt; 00214 00215 00216 // Perform a similar test with the plane origin at x = 2.1 00217 origin[0] = 2.1; 00218 AF2PlaneProjection wackyProjShift02(this_surf->igeom_instance(), 00219 this_surf->geom_handle(), origin, normal, xDir, 1.0); 00220 std::cout << "Created plane passing through (2.1, 0, 0) " 00221 << "normal to (-1, 0, 1)." << std::endl; 00222 std::cout << "The y-coordinate in the plane is in the direction of " 00223 << "the y-axis." << std::endl; 00224 00225 AF2Point2D planeTestPntE(1.5261999702635065, 0.1); 00226 surfacePnt = wackyProjShift02.transformToSurface(planeTestPntE, 5); 00227 std::cout << "Transform (" << planeTestPntE.getX() << ", " 00228 << planeTestPntE.getY() << ") from plane to surface." << std::endl; 00229 std::cout << "Coordinates on surface: (" << surfacePnt->getX() << ", " 00230 << surfacePnt->getY() << ", " << surfacePnt->getZ() << ")" << std::endl; 00231 if ((fabs(surfacePnt->getX() - 3.3072251285719) + 00232 fabs(surfacePnt->getY() - 0.1) + 00233 fabs(surfacePnt->getZ() - 0.9511475682682)) > epsError) 00234 { 00235 std::cout << "FAIL: The coordinates on the surface should be\n" 00236 << " (3.30722512857195, 0.1, 0.9511475682682)." 00237 << std::endl; 00238 ++failCount; 00239 } 00240 // The line also intersects the surface near (3.95, 0.1, 0.3083726968400695) 00241 // but that point is farther away from the plane than the expected result. 00242 // Both points are in the negative normal direction from the plane. 00243 delete surfacePnt; 00244 00245 delete mk; 00246 00247 return ( failCount == 0 ); 00248 }
