MeshKit
1.0
00001 00010 #include <iostream> 00011 #include <fstream> 00012 00013 #include <time.h> 00014 #include <stdlib.h> 00015 #include <cstring> 00016 00017 #include "meshkit/MKCore.hpp" 00018 #include "meshkit/MeshOp.hpp" 00019 #include "meshkit/ModelEnt.hpp" 00020 #include "meshkit/MBVolOp.hpp" 00021 #include "meshkit/MBSplitOp.hpp" 00022 00023 00024 using namespace MeshKit; 00025 00026 #include "TestUtil.hpp" 00027 #include "meshkit/ReadPolyLine.hpp" 00028 00029 MKCore *mk; 00030 00031 std::string usage_string = 00032 " <input file bottom> <input file top> input files.\n" 00033 "< direction > 3 doubles for sweeping direction\n" 00034 " <output file > output moab database \n"; 00035 00036 std::string filename_top; 00037 std::string filename_bot; 00038 double direction[3]={0., 0., 1.}; 00039 std::string output_file_name; 00040 00041 00042 int main(int argc, char* argv[]) 00043 { 00044 // check command line arg 00045 00046 filename_bot = TestDir + "/BedCropL3.h5m"; 00047 filename_top = TestDir + "/SurfCropL3.h5m";//"/polyPB.txt"; 00048 00049 output_file_name = "volumesIce.h5m"; // output 00050 00051 //number_tests_successful = 0; 00052 00053 if (argc<=1) 00054 { 00055 std::cout<<usage_string; 00056 std::cout << "\n\n"; 00057 std::cout<< "default arguments:" << filename_bot << " "<<filename_top << " " 00058 << " "<<direction[0] << " " << direction[1] << " "<< direction[2]<<" " << output_file_name <<"\n"; 00059 } 00060 else if (argc==7) 00061 { 00062 filename_bot = argv[1]; 00063 filename_top = argv[2]; 00064 direction[0] = atof(argv[3]); 00065 direction[1] = atof(argv[4]); 00066 direction[2] = atof(argv[5]); 00067 output_file_name= argv[6]; 00068 } 00069 else 00070 { 00071 std::cout << usage_string << " abort.\n"; 00072 return 1; 00073 } 00074 // initialize everything 00075 00076 mk = new MKCore(); 00077 mk->load_mesh(filename_bot.c_str()); 00078 MEntVector botFaces; 00079 // we should have 2 faces only, for top and bottom 00080 mk->get_entities_by_dimension(2, botFaces); 00081 // load a second one 00082 mk->load_mesh(filename_top.c_str()); 00083 MEntVector allFaces; 00084 mk->get_entities_by_dimension(2, allFaces); 00085 00086 MBVolOp *eVolOp = (MBVolOp*) mk->construct_meshop("MBVolOp", allFaces); 00087 00088 //selection.push_back(*dum.rbegin());// push just the last one retrieved from core 00089 eVolOp->set_direction(direction[0], direction[1], direction[2]); 00090 00091 std::cout<<"Total number of faces: " << allFaces.size() << "\n"; 00092 mk->setup_and_execute(); 00093 00094 if(output_file_name.length()>0) 00095 { 00096 std::cout << "writing output to " << output_file_name << std::endl; 00097 // output only the root set with the volume 00098 // 00099 MEntSelection & mentset = eVolOp->me_selection(); 00100 moab::Range rangeResult = (*(mentset.begin()) ).second; 00101 moab::EntityHandle resultSet = rangeResult[0]; // the first set 00102 mk->moab_instance()->write_mesh(output_file_name.c_str(), &resultSet, 1);// write the result set only 00103 } 00104 00105 return 0; 00106 } 00107
