MeshKit
1.0
00001 00007 #include <iostream> 00008 00009 #include <time.h> 00010 #include <stdlib.h> 00011 #include <cstring> 00012 00013 #include "meshkit/MKCore.hpp" 00014 #include "meshkit/MeshOp.hpp" 00015 #include "meshkit/ModelEnt.hpp" 00016 #include "meshkit/QslimMesher.hpp" 00017 #include "meshkit/QslimOptions.hpp" 00018 00019 using namespace MeshKit; 00020 00021 #include "TestUtil.hpp" 00022 00023 MKCore *mk; 00024 00025 std::string usage_string = 00026 "-o <file> Output final model to given file.\n" 00027 "-s <count> Set the target number of faces.\n" 00028 "-i <timings> Intervals for timing reports.\n" 00029 "-e <thresh> Set the maximum error tolerance.\n" 00030 "-t <t> Set pair selection tolerance.\n" 00031 "-Q[pv] Select what constraint quadrics to use [default=p].\n" 00032 "-On Optimal placement policy.\n" 00033 " 0=endpoints, 1=endormid, 2=line, 3=optimal [default]\n" 00034 "-B <weight> Use boundary preservation planes with given weight.\n" 00035 "-b preserve boundary (do not use with -B option) \n" 00036 "-m Preserve mesh quality.\n" 00037 "-a Enable area weighting.\n" 00038 "-p Height fields positivity. Used for height fields, assume \n" 00039 " triangles are originally positively oriented. \n" 00040 "-d do not use delayed deletion \n" 00041 "-c keep costs in a (sparse!!!!) tag \n" 00042 "-r create the range with resulting triangles, and delete the original elements" 00043 "-k keep the topology unchanged, like holes, tunnels." 00044 "\n"; 00045 00046 std::string logging_usage_string = 00047 "-l <file> Log all simplification operations to given file.\n" 00048 "-L[xqcvfdA] Set information to be output.\n" 00049 " x=contractions, q=quadrics, c=cost\n" 00050 " v=vert. notes, f=face notes\n" 00051 " d=model defn, A=All.\n"; 00052 00053 int main(int argc, char* argv[]) 00054 { 00055 // check command line arg 00056 const char *filename = 0; 00057 const char *outfile = 0; 00058 00059 //process options 00060 QslimOptions options; 00061 // process all options, as given with regular qslim 00062 // the last argument must be the input file 00063 // one argument must be -o <the output file>, otherwise it is the standard output 00064 // in the process, a mesh file is read (instanced) and the 00065 // set of triangles is passed 00066 // it could be the root set for the mesh 00067 std::string fstr; 00068 if (argc<=1) 00069 { 00070 std::cout<<usage_string; 00071 std::cout << "\n\n"; 00072 fstr=TestDir + "/partBed.smf"; 00073 std::cout<< "default arguments: -s 4500 -B 1000 -p -o out.smf " << fstr <<" \n"; 00074 options.face_target = 4500; 00075 options.will_constrain_boundaries = true; 00076 options.boundary_constraint_weight = 1000; 00077 options.height_fields = 1; 00078 00079 filename = fstr.c_str(); 00080 // ostr = "out.smf"; 00081 // outfile = ostr.c_str(); 00082 } 00083 else 00084 { 00085 // the file should be the last argument; if not, we have a problem, we will not be able to read it 00086 filename = argv[argc-1]; 00087 int i=1;// will loop through arguments, and process them 00088 for (i=1; i<argc-1 ; i++) 00089 { 00090 if (argv[i][0]=='-') 00091 { 00092 switch (argv[i][1]) 00093 { 00094 case 'l': 00095 { 00096 // open a log file 00097 options.logfile = new std::ofstream(argv[i+1]); 00098 if (!options.logfile) 00099 { 00100 // cannot open log file, exit 00101 std::cout << "can't open log file\n"; 00102 return 1; 00103 } 00104 i++; 00105 break; 00106 } 00107 case 'L': 00108 // parse the logging options 00109 { 00110 char *c; 00111 int errflg = 0; 00112 c = argv[i]+2;// skip -L 00113 while( *c ) 00114 { 00115 if( *c=='x' ) 00116 options.selected_output |= OUTPUT_CONTRACTIONS; 00117 else if( *c=='q' ) 00118 options.selected_output |= OUTPUT_QUADRICS; 00119 else if( *c=='c' ) 00120 options.selected_output |= OUTPUT_COST; 00121 else if( *c=='v' ) 00122 options.selected_output |= OUTPUT_VERT_NOTES; 00123 else if( *c=='f' ) 00124 options.selected_output |= OUTPUT_FACE_NOTES; 00125 else if( *c=='d' ) 00126 options.selected_output |= OUTPUT_MODEL_DEFN; 00127 else if( *c=='A' ) 00128 options.selected_output |= OUTPUT_ALL; 00129 else 00130 errflg++; 00131 c++; 00132 } 00133 if (errflg>0) 00134 { 00135 std::cout<<logging_usage_string; 00136 std::cout<< "!! Ignore the error it\n"; 00137 00138 } 00139 break; 00140 } 00141 case 'a': 00142 { 00143 options.will_weight_by_area = 1; 00144 break; 00145 } 00146 case 'B': 00147 { 00148 options.boundary_constraint_weight = atof(argv[i+1]); 00149 options.will_constrain_boundaries = 1; 00150 i++; 00151 break; 00152 } 00153 case 's': 00154 { 00155 options.face_target = atoi(argv[i+1]); 00156 i++; 00157 break; 00158 } 00159 case 't': 00160 { 00161 options.pair_selection_tolerance = atof(argv[i+1]); 00162 i++; 00163 break; 00164 } 00165 case 'o': 00166 { 00167 outfile = argv[i+1]; 00168 i++; 00169 break; 00170 } 00171 00172 case 'O': 00173 { 00174 char * c ; 00175 c = argv[i]+2; 00176 int ival = atoi(c); 00177 if( ival < 0 || ival > PLACE_OPTIMAL ) 00178 ival=PLACE_OPTIMAL; 00179 options.placement_policy = ival; 00180 break; 00181 } 00182 00183 case 'Q': 00184 { 00185 options.will_use_plane_constraint = false; 00186 options.will_use_vertex_constraint = false; 00187 options.will_use_plane_constraint = false; 00188 00189 char * c ; 00190 c = argv[i]+2; 00191 while( *c ) 00192 { 00193 if( *c=='p' ) 00194 options.will_use_plane_constraint = true; 00195 else if( *c=='v' ) 00196 options.will_use_vertex_constraint = true; 00197 else 00198 { 00199 std::cout<< "wrong input " << argv[i] << std::endl; 00200 } 00201 c++; 00202 } 00203 break; 00204 } 00205 00206 case 'e': 00207 { 00208 options.error_tolerance = atof(argv[i+1]); 00209 i++; 00210 break; 00211 } 00212 00213 case 'b': 00214 { 00215 options.will_preserve_boundaries = true; 00216 break; 00217 } 00218 00219 case 'm': 00220 { 00221 options.will_preserve_mesh_quality = true; 00222 break; 00223 } 00224 00225 case 'p': 00226 { 00227 options.height_fields = true; 00228 break; 00229 } 00230 case 'i': 00231 { 00232 options.timingIntervals=atof(argv[i+1]); 00233 i++; 00234 break; 00235 } 00236 case 'd': 00237 { 00238 options.useDelayedDeletion = false; 00239 break; 00240 } 00241 case 'c': 00242 { 00243 options.plotCost = 1; 00244 break; 00245 } 00246 case 'r': 00247 { 00248 options.create_range = true; 00249 break; 00250 } 00251 case 'k': 00252 { 00253 options.topology = 1; 00254 break; 00255 } 00256 default : 00257 { 00258 std::cout << "unsupported wrong input argument " << argv[i] <<std::endl; 00259 return 0; 00260 } 00261 } 00262 } 00263 } 00264 } 00265 // initialize everything 00266 00267 mk = new MKCore(); 00268 mk->load_mesh(filename); 00269 MEntVector selection, dum; 00270 mk->get_entities_by_dimension(2, dum); 00271 selection.push_back(*dum.rbegin());// push just the last one retrieved from core 00272 00273 QslimMesher *qm = (QslimMesher*) mk->construct_meshop("QslimMesher", selection); 00274 00275 qm->set_options(options); 00276 00277 mk->setup_and_execute(); 00278 00279 if(outfile) 00280 { 00281 std::cout << "writing output to " << outfile << std::endl; 00282 mk->moab_instance()->write_mesh(outfile);// write everything left 00283 } 00284 00285 return 0; 00286 }
