MeshKit
1.0
00001 #include "meshkit/CAMALTriAdvance.hpp" 00002 #include "meshkit/MeshScheme.hpp" 00003 #include "meshkit/ModelEnt.hpp" 00004 #include "moab/Interface.hpp" 00005 #include "moab/ReadUtilIface.hpp" 00006 #include "moab/Range.hpp" 00007 #include "meshkit/RegisterMeshOp.hpp" 00008 #include "CAMALSurfEval.hpp" 00009 #include "CAMALSizeEval.hpp" 00010 #include "CMLTriAdvance.hpp" 00011 #include "RefEntity.hpp" 00012 00013 #ifdef PARALLEL 00014 #ifdef HAVE_PARALLEL_MOAB 00015 #include "moab/ParallelComm.hpp" 00016 #endif 00017 #endif 00018 00019 #include <vector> 00020 00021 const bool debug_camaltriadv = false; 00022 00023 namespace MeshKit 00024 { 00025 00026 moab::EntityType CAMALTriAdvance::meshTps[] = {moab::MBVERTEX, moab::MBTRI, moab::MBMAXTYPE}; 00027 00028 CAMALTriAdvance::CAMALTriAdvance(MKCore *mk_core, const MEntVector &me_vec) 00029 : MeshScheme(mk_core, me_vec) 00030 { 00031 } 00032 00033 CAMALTriAdvance::~CAMALTriAdvance() 00034 { 00035 } 00036 00037 void CAMALTriAdvance::setup_this() 00038 { 00039 // just call setup_boundary, since that's the only constraint we have 00040 setup_boundary(); 00041 } 00042 00043 void CAMALTriAdvance::execute_this() 00044 { 00045 for (MEntSelection::iterator sit = mentSelection.begin(); sit != mentSelection.end(); sit++) { 00046 // make a me, for convenience 00047 ModelEnt *me = (*sit).first; 00048 00049 // create a surface evaluator for this modelent, and a size evaluator 00050 CAMALSurfEval cse(me); 00051 00052 SizingFunction * sz = mk_core()->sizing_function(me->sizing_function_index()); 00053 if (!sz->variable()) 00054 sz = NULL; // no function variable 00055 00056 CAMALSizeEval mesize(me->mesh_interval_size(), sz); 00057 // make sure the size isn't negative 00058 if (mesize.get_size() == -1) mesize.set_size(1.0); 00059 00060 // assemble bounding mesh 00061 std::vector<moab::EntityHandle> bdy; 00062 std::vector<int> group_sizes, bdy_ids; 00063 me->boundary(0, bdy, NULL, &group_sizes); 00064 00065 // convert the handles to integers for input to TriAdv 00066 moab::Range bdy_vrange; 00067 std::vector<double> coords; 00068 me->get_indexed_connect_coords(bdy, NULL, NULL, bdy_ids, coords, &bdy_vrange); 00069 00070 // now construct the CAMAL mesher, and pass it initial conditions 00071 CMLTriAdvance triadv(&cse, &mesize); 00072 bool success = triadv.set_boundary_mesh(bdy_vrange.size(), &coords[0], group_sizes.size(), &group_sizes[0], &bdy_ids[0]); 00073 if (!success) 00074 ECERRCHK(MK_FAILURE, "Trouble setting boundary mesh."); 00075 00076 // ok, now generate the mesh 00077 int num_pts, num_tris; 00078 success = triadv.generate_mesh(num_pts, num_tris); 00079 if (!success) { 00080 if (debug_camaltriadv) print_debug(me, coords, bdy_vrange, group_sizes, bdy_ids); 00081 ECERRCHK(MK_FAILURE, "Trouble generating tri mesh."); 00082 } 00083 00084 moab::Range &new_ents = (*sit).second; 00085 moab::ErrorCode rval; 00086 00087 // resize the coords array, then get the coords of the new points 00088 assert(num_pts >= (int)bdy_vrange.size()); 00089 if (num_pts > (int)bdy_vrange.size()) { 00090 coords.resize(3*(num_pts-bdy_vrange.size())); 00091 unsigned int pts_returned = triadv.get_points_buf(coords.size(), &coords[0], bdy_vrange.size()); 00092 if (pts_returned != num_pts-bdy_vrange.size()) 00093 ECERRCHK(MK_FAILURE, "Number of new points returned from TriAdv doesn't agree with previous value output."); 00094 00095 // create the new vertices' entities on the face 00096 rval = mk_core()->moab_instance()->create_vertices(&coords[0], pts_returned, new_ents); 00097 MBERRCHK(rval, mk_core()->moab_instance()); 00098 } 00099 00100 // for tris, pre-allocate connectivity 00101 moab::ReadUtilIface *iface; 00102 rval = mk_core()-> moab_instance() -> query_interface(iface); 00103 MBERRCHK(rval, mk_core()->moab_instance()); 00104 00105 //create the tris, get a direct ptr to connectivity 00106 moab::EntityHandle starth, *connect; 00107 rval = iface->get_element_connect(num_tris, 3, moab::MBTRI, 1, starth, connect); 00108 MBERRCHK(rval, mk_core()->moab_instance()); 00109 00110 // read connectivity directly into that array, as int's 00111 int *connecti = (int*) connect; 00112 int tris_returned = triadv.get_tris_buf(3*num_tris, connecti); 00113 if (tris_returned != num_tris) 00114 ECERRCHK(MK_FAILURE, "Number of new tris returned from TriAdv doesn't agree with previous value output."); 00115 00116 // put vertex handles into an indexible array 00117 std::vector<moab::EntityHandle> bdy_vvec; 00118 std::copy(bdy_vrange.begin(), bdy_vrange.end(), std::back_inserter(bdy_vvec)); 00119 std::copy(new_ents.begin(), new_ents.end(), std::back_inserter(bdy_vvec)); 00120 00121 // now convert vertex indices into handles in-place, working from the back 00122 for (int i = 3*num_tris-1; i >= 0; i--) { 00123 assert(connecti[i] >= 0 && connecti[i] < (int)bdy_vvec.size()); 00124 connect[i] = bdy_vvec[connecti[i]]; 00125 } 00126 00127 // put new tris into new entity range, then commit the mesh 00128 new_ents.insert(starth, starth+num_tris-1); 00129 me->commit_mesh(new_ents, COMPLETE_MESH); 00130 } 00131 } 00132 00133 void CAMALTriAdvance::print_debug(ModelEnt *me, std::vector<double> &coords, 00134 moab::Range &bdy_vrange, std::vector<int> &group_sizes, 00135 std::vector<int> &bdy_ids) 00136 { 00137 std::cout << "Surface_bounadry_mesh: mesh_size = " 00138 << me->mesh_interval_size() << std::endl; 00139 00140 for (int i = 0; i < (int) bdy_vrange.size(); i++) { 00141 std::cout << coords[3 * i] << " " << coords[3 * i + 1] 00142 << " " << coords[3 * i + 2] << std::endl; 00143 } 00144 00145 std::cout << "bdy_vertex_size:" << bdy_vrange.size() 00146 << ", group_size:" << group_sizes.size() << std::endl; 00147 00148 int index = 0; 00149 for (int i = 0; i < (int) group_sizes.size(); i++) { 00150 int g_size = group_sizes[i]; 00151 std::cout << "boundary_order_group" << i + 1 << ", group_size=" 00152 << g_size << std::endl; 00153 for (int j = 0; j < g_size; j++) { 00154 std::cout << bdy_ids[index + j] << " "; 00155 } 00156 std::cout << std::endl; 00157 index += g_size; 00158 } 00159 00160 moab::ErrorCode rval; 00161 moab::EntityHandle outset; 00162 std::string outfile; 00163 std::stringstream ss; 00164 00165 RefEntity* entity = reinterpret_cast<RefEntity*> (me->geom_handle()); 00166 ss << "CAMALTri_boundary_surf"; 00167 ss << entity->id(); 00168 ss << "_"; 00169 #ifdef PARALLEL 00170 #ifdef HAVE_PARALLEL_MOAB 00171 moab::ParallelComm* pcomm = moab::ParallelComm::get_pcomm(mk_core()->moab_instance(), 0); 00172 ss << "proc"; 00173 ss << pcomm->proc_config().proc_rank(); 00174 #endif 00175 #endif 00176 ss >> outfile; 00177 outfile += ".vtk"; 00178 rval = mk_core()->moab_instance()->create_meshset(0, outset); 00179 MBERRCHK(rval, mk_core()->moab_instance()); 00180 rval = mk_core()->moab_instance()->add_entities(outset, bdy_vrange); 00181 MBERRCHK(rval, mk_core()->moab_instance()); 00182 rval = mk_core()->moab_instance()->write_mesh(outfile.c_str(), &outset, 1); 00183 MBERRCHK(rval, mk_core()->moab_instance()); 00184 std::cout << outfile.c_str() << " is saved." << std::endl; 00185 } 00186 } // namespace MeshKit
