MeshKit
1.0
00001 #ifndef MESHKIT_EB_MESHER_HPP 00002 #define MESHKIT_EB_MESHER_HPP 00003 00004 #include <vector> 00005 #include <map> 00006 00007 #include "meshkit/Types.hpp" 00008 #include "meshkit/Error.hpp" 00009 #include "meshkit/MeshScheme.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 #include "meshkit/iMesh.hpp" 00012 00013 #include "moab/Interface.hpp" 00014 #include "moab/GeomTopoTool.hpp" 00015 #include "moab/OrientedBoxTreeTool.hpp" 00016 00018 enum EdgeStatus { 00019 INSIDE, 00020 OUTSIDE, 00021 BOUNDARY 00022 }; 00023 00025 struct CutFraction { 00026 std::vector<double> fraction[3]; 00027 00028 CutFraction() {}; 00029 00030 CutFraction(int dir, const std::vector<double>& val) { 00031 add(dir, val); 00032 }; 00033 00034 void add(int dir, const std::vector<double>& val) { 00035 for (unsigned int i = 0; i < val.size(); i++) { 00036 fraction[dir].push_back(val[i]); 00037 } 00038 } 00039 }; 00040 00043 struct CutCellSurfEdgeKey { 00044 int i, j, k, l; 00045 00046 CutCellSurfEdgeKey() { 00047 i = j = k = l = 0; 00048 }; 00049 00050 CutCellSurfEdgeKey(int ii, int jj, int kk, int ll) { 00051 i = ii; 00052 j = jj; 00053 k = kk; 00054 l = ll; 00055 }; 00056 }; 00057 00059 struct IntersectDist { 00060 double distance; 00061 int index; 00062 00063 IntersectDist() {}; 00064 00065 IntersectDist(double d, int i) { 00066 distance = d; 00067 index = i; 00068 }; 00069 }; 00070 00072 struct VolFrac { 00073 double vol; 00074 bool closed; 00075 double ePnt[6]; 00076 00077 VolFrac() {}; 00078 00079 VolFrac(double f, int c) { 00080 vol = f; 00081 closed = c; 00082 }; 00083 }; 00084 00085 struct LessThan 00086 { 00087 bool operator() (const CutCellSurfEdgeKey key1, const CutCellSurfEdgeKey key2) const 00088 { 00089 if (key1.i < key2.i) return true; 00090 else if (key1.i > key2.i) return false; 00091 else { 00092 if (key1.j < key2.j) return true; 00093 else if (key1.j > key2.j) return false; 00094 else { 00095 if (key1.k < key2.k) return true; 00096 else if (key1.k > key2.k) return false; 00097 else { 00098 if (key1.l < key2.l) return true; 00099 else return false; 00100 } 00101 } 00102 } 00103 }; 00104 }; 00105 00106 namespace MeshKit { 00107 00108 class MKCore; 00109 00110 00119 class EBMesher : public MeshScheme 00120 { 00121 public: 00122 00124 EBMesher(MKCore *mkcore, const MEntVector &me_vec, 00125 double size = -1., bool use_geom = true, 00126 int add_layer = 3); 00127 00129 virtual ~EBMesher(); 00130 00132 static const char* name() 00133 { return "EBMesher"; } 00134 00139 static bool can_mesh(iBase_EntityType dim) 00140 { return iBase_REGION == dim; } 00141 00148 static bool can_mesh(ModelEnt *me); 00149 00153 static const moab::EntityType* output_types(); 00154 00158 virtual const moab::EntityType* mesh_types_arr() const 00159 { return output_types(); } 00160 00161 00162 virtual bool add_modelent(ModelEnt *model_ent); 00163 00169 int set_division(double* min, double* max); 00170 00173 virtual void setup_this(); 00174 00177 virtual void execute_this(); 00178 00187 void get_grid_and_edges_techX(double* boxMin, double* boxMax, int* nDiv, 00188 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& rmdCutCellSurfEdge, 00189 std::vector<int>& rvnInsideCell, bool isCornerExterior = true); 00190 00200 bool get_grid_and_edges(double* boxMin, double* boxMax, int* nDiv, 00201 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& rmdCutCellEdge, 00202 std::vector<int>& rvnInsideCell, bool isCornerExterior = true); 00203 00208 bool get_volume_fraction(int vol_frac_div); 00209 00214 void export_mesh(const char* file_name, bool separate = false); 00215 00219 void set_num_interval(int* n_interval); 00220 00224 void increase_box(double box_increase); 00225 00229 void use_whole_geom(int use); 00230 00234 void use_mesh_geometry(bool use); 00235 00238 void set_obb_tree_box_dimension(); 00239 00240 protected: 00241 00242 private: 00243 00245 EBMesher(const EBMesher &); 00246 00247 MeshOp* get_scd_mesher(); 00248 00250 EBMesher &operator=(const EBMesher &); 00251 00252 iBase_TagHandle m_elemStatusTag, m_edgeCutFracLengthTag, 00253 m_edgeCutFracTag, m_volFracLengthTag, m_volFracHandleTag, m_volFracTag, m_bbTag; 00254 iMesh_Instance m_mesh; 00255 iBase_EntitySetHandle m_hRootSet; 00256 std::vector<IntersectDist> m_vIntersection; 00257 int m_nTri, m_nHex, m_iInter, m_nFraction, m_iStartHex, m_nMove, m_nAddLayer, 00258 m_nIteration, m_iOverlap, m_iElem, m_nNode[3], m_nDiv[3], 00259 m_iFirstP, m_iSecondP; 00260 double m_dFirstP, m_dSecondP, m_curPnt, m_prevPnt, m_boxIncrease, 00261 m_dIntervalSize[3], m_origin_coords[3], m_dInputSize, 00262 m_min[3], m_max[3]; 00263 EdgeStatus m_nStatus; 00264 bool m_bMovedOnce, m_bUseGeom, m_bUseWholeGeom, m_bUseMeshGeom; 00265 std::vector<iBase_EntityHandle> m_vhVertex; 00266 std::vector<int> m_vnHexStatus; 00267 std::map<int, CutFraction> m_mdCutFraction; 00268 std::vector<EdgeStatus> m_vnEdgeStatus[3]; 00269 00275 EdgeStatus get_edge_status(const double dZ, int& iSkip); 00276 00284 bool set_neighbor_hex_status(int dir, int i, int j, int k); 00285 00292 bool set_hex_status(int index, EdgeStatus value, int dir); 00293 00298 bool set_edge_status(int dir); 00299 00303 void set_tag_info(); 00304 00312 void write_mesh(const char* file_name, int type, 00313 iBase_EntityHandle* handles, int& n_elem); 00314 00320 double get_edge_fraction(int idHex, int dir); 00321 00329 double get_uncut_edge_fraction(int i, int j, int k, int dir); 00330 00335 bool is_shared_overlapped_surf(int index); 00336 00343 bool move_intersections(int n_dir, int n_inter, double start_pnt[3]); 00344 00349 bool get_inside_hex(std::vector<int>& rvnInsideCell); 00350 00356 bool is_ray_move_and_set_overlap_surf(bool& bMoveOnce); 00357 00358 void remove_intersection_duplicates(); 00359 00360 // test function 1 for debugging 00361 bool export_fraction_edges(std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& rmdCutCellSurfEdge); 00362 00363 // test functions 2 for debugging 00364 bool export_fraction_points(std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& mdCutCellEdge); 00365 00366 // test functions 3 for debugging 00367 bool make_edge(double ePnt[6], std::vector<iBase_EntityHandle>& edge_handles); 00368 00370 static int init; 00371 00375 moab::Interface* moab_instance() {return mk_core()->moab_instance();} 00376 00386 iBase_TagHandle get_tag(const char* name, int size, unsigned flags, moab::DataType type, 00387 const void* def_value = NULL, bool create_if_missing = true); 00388 00395 iBase_TagHandle get_various_length_tag(const char* name, 00396 unsigned store, moab::DataType type); 00397 00401 int make_scd_hexes(); 00402 00406 int make_uscd_hexes(); 00407 00412 int construct_obb_tree(); 00413 00417 void set_tree_root(ModelEnt* me); 00418 00422 void set_division(); 00423 00426 void find_intersections(); 00427 00432 void fire_rays(int dir); 00433 00443 bool fire_ray(int& nIntersect, double startPnt[3], 00444 double endPnt[3], double tol, int dir, 00445 double rayLength); 00446 00456 bool move_ray(int& nIntersect, double* startPnt, double* endPnt, 00457 double tol, int dir, bool bMoveOnce); 00458 00464 bool is_same_direct_to_ray(int i, int dir); 00465 00466 // ! GeomTopoTool instance 00467 moab::GeomTopoTool* m_GeomTopoTool; 00468 00469 // ! Tree root 00470 moab::EntityHandle m_hTreeRoot; 00471 00472 // ! OBB tree tool instance 00473 moab::OrientedBoxTreeTool* m_hObbTree; 00474 00475 // ! intersected surface geometry list 00476 std::vector<moab::EntityHandle> m_vhInterSurf; 00477 00478 // ! intersected facet list 00479 std::vector<moab::EntityHandle> m_vhInterFacet; 00480 00481 // ! overlapped surface list 00482 std::map<moab::EntityHandle, int> m_mhOverlappedSurf; 00483 00484 std::map<moab::EntityHandle, moab::EntityHandle> m_mRootSets; 00485 00486 double m_minCoord[3], m_maxCoord[3]; 00487 }; 00488 00489 inline void EBMesher::increase_box(double box_increase) 00490 { 00491 m_boxIncrease = box_increase; 00492 } 00493 00494 inline void EBMesher::use_whole_geom(int use) 00495 { 00496 m_bUseWholeGeom = use; 00497 } 00498 00499 inline void EBMesher::use_mesh_geometry(bool use) 00500 { 00501 m_bUseMeshGeom = use; 00502 } 00503 } 00504 00505 #endif 00506 00507
