MeshKit
1.0
00001 /* 00002 * MBVolOp.h 00003 * 00004 * Created on: Jan 13, 2012 00005 */ 00006 00007 #ifndef MBVOLOP_H_ 00008 #define MBVOLOP_H_ 00009 00010 #include "meshkit/MeshScheme.hpp" 00011 #include "moab/GeomTopoTool.hpp" 00012 #include "moab/FBEngine.hpp" 00013 00014 namespace MeshKit { 00015 00016 class MBVolOp: public MeshKit::MeshScheme { 00017 public: 00018 MBVolOp(MKCore *mk_core, const MEntVector &me_vec); 00019 virtual ~MBVolOp(); 00020 // globalIds: to identify / single out the gfaces to be weaved 00021 // the gface will be found among gfaces in the mentSelection 00022 // gface sources, targets 00023 void add_pair(int source, int target);// these are global ids in input ment vectors 00024 // or maybe orders in some lists? 00025 00026 // this is the main direction of sweeping / weaving 00027 void set_direction(double x, double y, double z) 00028 {_direction[0]=x; _direction[1]=y; _direction[2]=z;} 00029 //set up the weaving, needed for volume creation 00030 virtual void setup_this(); 00031 00032 // construct the mesh 00033 virtual void execute_this(); 00034 00036 static const char* name() 00037 { 00038 return "MBVolOp"; 00039 } 00040 00041 static bool can_mesh(iBase_EntityType dim) 00042 { 00043 return false; 00044 } 00045 00052 static bool can_mesh(ModelEnt *me) 00053 { 00054 return false;// this is not used for meshing, but for geometry creation 00055 } 00056 00060 static const moab::EntityType* output_types(); 00061 00065 virtual const moab::EntityType* mesh_types_arr() const 00066 { 00067 return output_types(); 00068 } 00069 00070 00071 private: 00076 void establish_mapping(); 00077 00078 double _direction[3]; 00079 moab::GeomTopoTool * _pGTT ; 00080 moab::EntityHandle _rootSet;// this is the root set for gtt result 00081 std::map<moab::EntityHandle, moab::EntityHandle> vertexMap; 00082 std::map<moab::EntityHandle, moab::EntityHandle> edgeMap; 00083 std::map<moab::EntityHandle, moab::EntityHandle> faceMap; 00084 moab::FBEngine * _fbe; 00085 }; 00086 00087 }// namespace MeshKit 00088 00089 #endif /* MBVOLOP_H_ */
