MeshKit
1.0
00001 00015 // C++ 00016 #include <cstddef> 00017 #include <iostream> 00018 #include <string> 00019 #include <vector> 00020 00021 // MeshKit 00022 #include "meshkit/AF2DfltTriangleRules.hpp" 00023 #include "meshkit/AF2Edge3D.hpp" 00024 #include "meshkit/AF2Neighborhood.hpp" 00025 #include "meshkit/AF2PlaneProjection.hpp" 00026 #include "meshkit/AF2Point3D.hpp" 00027 #include "meshkit/AF2Rule.hpp" 00028 #include "meshkit/AF2RuleAppVisitor.hpp" 00029 #include "meshkit/MKCore.hpp" 00030 #include "meshkit/ModelEnt.hpp" 00031 #include "meshkit/Matrix.hpp" 00032 00033 // MeshKit testing 00034 #include "TestUtil.hpp" 00035 00036 // define the geometry file extension depending on the geometry model 00037 #if HAVE_OCC 00038 #define FILE_EXT "stp" 00039 #else 00040 #define FILE_EXT "facet" 00041 #endif 00042 00043 const AF2Rule* findRule( 00044 const AF2DfltTriangleRules & ruleSet, const std::string & ruleName); 00045 AF2LocalTransform* makePlaneProj(); 00046 void test180DegreeRuleQ1(); 00047 void test180DegreeRuleQ5(); 00048 void test180DegreeRuleQ10(); 00049 void test180DegreeRuleQ20(); 00050 void test60DegreeAngleRightRule(); 00051 void test60DegreeAngleLeftRule(); 00052 void test120DegreeAngleRightRule(); 00053 void test120DegreeAngleLeftRule(); 00054 void test120DegreeAngleBothRule(); 00055 void testFillTriangleRule(); 00056 void testConnectVertexRule(); 00057 void testConnectEdgeRule(); 00058 00059 class SaveLastVisitor : public AF2RuleAppVisitor 00060 { 00061 private: 00062 unsigned int count; 00063 AF2RuleApplication* lastRuleApp; 00064 public: 00065 SaveLastVisitor() 00066 { 00067 count = 0u; 00068 lastRuleApp = NULL; 00069 } 00070 00071 ~SaveLastVisitor() 00072 { 00073 if (lastRuleApp != NULL) 00074 { 00075 delete lastRuleApp; 00076 } 00077 } 00078 00079 void visit(AF2RuleApplication const & ruleApp) 00080 { 00081 ++count; 00082 if (lastRuleApp != NULL) 00083 { 00084 delete lastRuleApp; 00085 } 00086 lastRuleApp = new AF2RuleApplication(ruleApp); 00087 } 00088 00089 AF2RuleApplication* getLast() const 00090 { 00091 return lastRuleApp; 00092 } 00093 00094 unsigned int getVisitCount() const 00095 { 00096 return count; 00097 } 00098 }; 00099 00100 // This variable is at global scope because (1) calling deleteAll on 00101 // the MKCore geometry instance appears to cause memory inconsistencies 00102 // with later use of the geometry instance and (2) it is more efficient 00103 // to load the geometry model only once 00104 MeshKit::ModelEnt* square = NULL; 00105 00106 int main(int argc, char **argv) 00107 { 00108 // This variable is defined and used in main because a new MKCore 00109 // instance cannot be easily constructed after another MKCore 00110 // instance is deleted; there are problems with a tag left behind in 00111 // iGeom. 00112 MeshKit::MKCore* mk = new MeshKit::MKCore(); 00113 00114 // load a square in plane z = 0.5 with -1.0 <= x <= 0 and -0.5 <= y <= 0.5 00115 std::string file_name = TestDir + "/squaresurf." + FILE_EXT; 00116 mk->load_geometry_mesh(file_name.c_str(), file_name.c_str()); 00117 MeshKit::MEntVector surfs; 00118 mk->get_entities_by_dimension(2, surfs); 00119 square = *surfs.begin(); 00120 00121 // start up MK and load the geometry 00122 int num_fail = 0; 00123 00124 num_fail += RUN_TEST(test180DegreeRuleQ1); 00125 num_fail += RUN_TEST(test180DegreeRuleQ5); 00126 num_fail += RUN_TEST(test180DegreeRuleQ10); 00127 num_fail += RUN_TEST(test180DegreeRuleQ20); 00128 num_fail += RUN_TEST(test60DegreeAngleRightRule); 00129 num_fail += RUN_TEST(test60DegreeAngleLeftRule); 00130 num_fail += RUN_TEST(test120DegreeAngleRightRule); 00131 num_fail += RUN_TEST(test120DegreeAngleLeftRule); 00132 num_fail += RUN_TEST(test120DegreeAngleBothRule); 00133 num_fail += RUN_TEST(testFillTriangleRule); 00134 num_fail += RUN_TEST(testConnectVertexRule); 00135 num_fail += RUN_TEST(testConnectEdgeRule); 00136 00137 delete mk; 00138 00139 return num_fail; 00140 } 00141 00142 const AF2Rule* findRule( 00143 const AF2DfltTriangleRules & ruleSet, const std::string & ruleName) 00144 { 00145 typedef std::list<const AF2Rule*>::const_iterator RuleListItr; 00146 00147 std::list<const AF2Rule*> ruleList = ruleSet.getRules(); 00148 for (RuleListItr itr = ruleList.begin(); itr != ruleList.end(); ++itr) 00149 { 00150 if (ruleName == (*itr)->getName()) 00151 { 00152 return *itr; 00153 } 00154 } 00155 00156 return NULL; 00157 } 00158 00159 AF2LocalTransform* makePlaneProj() 00160 { 00161 MeshKit::Vector<3> origin; 00162 origin[0] = -0.5; 00163 origin[1] = 0.0; 00164 origin[2] = 0.5; 00165 MeshKit::Vector<3> normal; 00166 normal[0] = 0.0; 00167 normal[1] = 0.0; 00168 normal[2] = 1.0; 00169 MeshKit::Vector<3> xDir; 00170 xDir[0] = 1.0; 00171 xDir[1] = 0.0; 00172 xDir[2] = 0.0; 00173 00174 return new AF2PlaneProjection(square->igeom_instance(), 00175 square->geom_handle(), origin, normal, xDir, 0.125); 00176 } 00177 00178 void test180DegreeRuleQ1() 00179 { 00180 AF2DfltTriangleRules triRules; 00181 const AF2Rule* rule180DegreeQ1 = 00182 findRule(triRules, "Triangle Off Line, Quality Level 1"); 00183 00184 CHECK(rule180DegreeQ1 != NULL); 00185 00186 std::vector<AF2Point3D*> pointsVector; 00187 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 00188 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 00189 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 00190 pointsVector.push_back(new AF2Point3D(3, -0.25, 0.0, 0.5)); 00191 pointsVector.push_back(new AF2Point3D(4, -0.3748, 0.0, 0.5)); 00192 pointsVector.push_back(new AF2Point3D(5, -0.3123, 0.0876, 0.5)); 00193 pointsVector.push_back(new AF2Point3D(6, -0.4375, 0.1877, 0.5)); 00194 pointsVector.push_back(new AF2Point3D(7, -0.5627, 0.0876, 0.5)); 00195 pointsVector.push_back(new AF2Point3D(8, -0.5002, 0.0, 0.5)); 00196 00197 std::list<AF2Point3D*> points; 00198 00199 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00200 { 00201 points.push_back(pointsVector[pi]); 00202 } 00203 00204 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 00205 00206 std::list<const AF2Edge3D*> edges; 00207 // basic line 00208 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00209 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 00210 // lines bounding the expected free zone location 00211 edges.push_back(new AF2Edge3D(pointsVector[4], pointsVector[5])); 00212 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00213 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00214 edges.push_back(new AF2Edge3D(pointsVector[7], pointsVector[8])); 00215 00216 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00217 00218 SaveLastVisitor visitor; 00219 rule180DegreeQ1->applyRule(ngbhd, 1u, visitor); 00220 00221 CHECK_EQUAL(1u, visitor.getVisitCount()); 00222 std::cout << "Good: There is one way to apply the default triangle rule\n" 00223 << " named \"" << rule180DegreeQ1->getName() << "\"" << std::endl; 00224 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 00225 CHECK_REAL_EQUAL(0.866, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 00226 std::cout << "Good: The new point is located near (0.5, 0.866)" << std::endl; 00227 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 00228 std::cout << "Good: There is one new face" << std::endl; 00229 00230 SaveLastVisitor failVisitor; 00231 AF2Point3D failPointAlpha(9, -0.3752, 0.0001, 0.5); 00232 points.push_back(&failPointAlpha); 00233 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00234 rule180DegreeQ1->applyRule(failNgbhdAlpha, 1u, failVisitor); 00235 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00236 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00237 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 00238 points.pop_back(); 00239 00240 AF2Point3D failPointBravo(10, -0.3127, 0.0874, 0.5); 00241 points.push_back(&failPointBravo); 00242 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00243 rule180DegreeQ1->applyRule(failNgbhdBravo, 1u, failVisitor); 00244 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00245 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00246 << " has a point at (-0.3127, 0.0874, 0.5)" << std::endl; 00247 points.pop_back(); 00248 00249 AF2Point3D failPointCharlie(11, -0.4375, 0.1873, 0.5); 00250 points.push_back(&failPointCharlie); 00251 AF2Neighborhood failNgbhdCharlie(points, 00252 baselineEdge, edges, makePlaneProj()); 00253 rule180DegreeQ1->applyRule(failNgbhdCharlie, 1u, failVisitor); 00254 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00255 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00256 << " has a point at (-0.4375, 0.1873, 0.5)" << std::endl; 00257 points.pop_back(); 00258 00259 AF2Point3D failPointDelta(12, -0.5623, 0.0874, 0.5); 00260 points.push_back(&failPointDelta); 00261 AF2Neighborhood failNgbhdDelta(points, 00262 baselineEdge, edges, makePlaneProj()); 00263 rule180DegreeQ1->applyRule(failNgbhdDelta, 1u, failVisitor); 00264 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00265 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00266 << " has a point at (-0.5623, 0.0874, 0.5)" << std::endl; 00267 points.pop_back(); 00268 00269 AF2Point3D failPointEcho(13, -0.4998, 0.0001, 0.5); 00270 points.push_back(&failPointEcho); 00271 AF2Neighborhood failNgbhdEcho(points, 00272 baselineEdge, edges, makePlaneProj()); 00273 rule180DegreeQ1->applyRule(failNgbhdEcho, 1u, failVisitor); 00274 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00275 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00276 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 00277 points.pop_back(); 00278 00279 00280 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00281 itr != edges.end(); ++itr) 00282 { 00283 delete *itr; 00284 } 00285 delete baselineEdge; 00286 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00287 { 00288 delete pointsVector[pi]; 00289 } 00290 00291 std::cout << "PASS: The 180DegreeRuleQ1 passes the test." << std::endl; 00292 } 00293 00294 void test180DegreeRuleQ5() 00295 { 00296 AF2DfltTriangleRules triRules; 00297 const AF2Rule* rule180DegreeQ5 = 00298 findRule(triRules, "Triangle Off Line, Quality Level 5"); 00299 00300 CHECK(rule180DegreeQ5 != NULL); 00301 00302 std::vector<AF2Point3D*> pointsVector; 00303 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 00304 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 00305 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 00306 pointsVector.push_back(new AF2Point3D(3, -0.25, 0.0, 0.5)); 00307 pointsVector.push_back(new AF2Point3D(4, -0.3748, 0.0, 0.5)); 00308 pointsVector.push_back(new AF2Point3D(5, -0.4248, 0.0676, 0.5)); 00309 pointsVector.push_back(new AF2Point3D(6, -0.4502, 0.0676, 0.5)); 00310 pointsVector.push_back(new AF2Point3D(7, -0.5002, 0.0, 0.5)); 00311 00312 std::list<AF2Point3D*> points; 00313 00314 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00315 { 00316 points.push_back(pointsVector[pi]); 00317 } 00318 00319 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 00320 00321 std::list<const AF2Edge3D*> edges; 00322 // basic line 00323 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00324 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 00325 // lines bounding the expected free zone location 00326 edges.push_back(new AF2Edge3D(pointsVector[4], pointsVector[5])); 00327 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00328 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00329 00330 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00331 00332 SaveLastVisitor visitor; 00333 rule180DegreeQ5->applyRule(ngbhd, 5u, visitor); 00334 00335 CHECK_EQUAL(1u, visitor.getVisitCount()); 00336 std::cout << "Good: There is one way to apply the default triangle rule\n" 00337 << " named \"" << rule180DegreeQ5->getName() << "\"" << std::endl; 00338 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 00339 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 00340 std::cout << "Good: The new point is located near (0.5, 0.5)" << std::endl; 00341 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 00342 std::cout << "Good: There is one new face" << std::endl; 00343 00344 SaveLastVisitor failVisitor; 00345 AF2Point3D failPointAlpha(8, -0.3752, 0.0001, 0.5); 00346 points.push_back(&failPointAlpha); 00347 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00348 rule180DegreeQ5->applyRule(failNgbhdAlpha, 5u, failVisitor); 00349 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00350 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00351 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 00352 points.pop_back(); 00353 00354 AF2Point3D failPointBravo(9, -0.4252, 0.0674, 0.5); 00355 points.push_back(&failPointBravo); 00356 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00357 rule180DegreeQ5->applyRule(failNgbhdBravo, 5u, failVisitor); 00358 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00359 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00360 << " has a point at (-0.4252, 0.0674, 0.5)" << std::endl; 00361 points.pop_back(); 00362 00363 AF2Point3D failPointCharlie(10, -0.4498, 0.0674, 0.5); 00364 points.push_back(&failPointCharlie); 00365 AF2Neighborhood failNgbhdCharlie(points, 00366 baselineEdge, edges, makePlaneProj()); 00367 rule180DegreeQ5->applyRule(failNgbhdCharlie, 5u, failVisitor); 00368 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00369 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00370 << " has a point at (-0.4498, 0.0674, 0.5)" << std::endl; 00371 points.pop_back(); 00372 00373 AF2Point3D failPointDelta(11, -0.4998, 0.0001, 0.5); 00374 points.push_back(&failPointDelta); 00375 AF2Neighborhood failNgbhdDelta(points, 00376 baselineEdge, edges, makePlaneProj()); 00377 rule180DegreeQ5->applyRule(failNgbhdDelta, 5u, failVisitor); 00378 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00379 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00380 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 00381 points.pop_back(); 00382 00383 00384 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00385 itr != edges.end(); ++itr) 00386 { 00387 delete *itr; 00388 } 00389 delete baselineEdge; 00390 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00391 { 00392 delete pointsVector[pi]; 00393 } 00394 00395 std::cout << "PASS: The 180DegreeRuleQ5 passes the test." << std::endl; 00396 } 00397 00398 void test180DegreeRuleQ10() 00399 { 00400 AF2DfltTriangleRules triRules; 00401 const AF2Rule* rule180DegreeQ10 = 00402 findRule(triRules, "Triangle Off Line, Quality Level 10"); 00403 00404 CHECK(rule180DegreeQ10 != NULL); 00405 00406 std::vector<AF2Point3D*> pointsVector; 00407 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 00408 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 00409 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 00410 pointsVector.push_back(new AF2Point3D(3, -0.25, 0.0, 0.5)); 00411 pointsVector.push_back(new AF2Point3D(4, -0.3748, 0.0, 0.5)); 00412 pointsVector.push_back(new AF2Point3D(5, -0.43105, 0.0401, 0.5)); 00413 pointsVector.push_back(new AF2Point3D(6, -0.44395, 0.0401, 0.5)); 00414 pointsVector.push_back(new AF2Point3D(7, -0.5002, 0.0, 0.5)); 00415 00416 std::list<AF2Point3D*> points; 00417 00418 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00419 { 00420 points.push_back(pointsVector[pi]); 00421 } 00422 00423 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 00424 00425 std::list<const AF2Edge3D*> edges; 00426 // basic line 00427 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00428 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 00429 // lines bounding the expected free zone location 00430 edges.push_back(new AF2Edge3D(pointsVector[4], pointsVector[5])); 00431 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00432 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00433 00434 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00435 00436 SaveLastVisitor visitor; 00437 rule180DegreeQ10->applyRule(ngbhd, 10u, visitor); 00438 00439 CHECK_EQUAL(1u, visitor.getVisitCount()); 00440 std::cout << "Good: There is one way to apply the default triangle rule\n" 00441 << " named \"" << rule180DegreeQ10->getName() << "\"" << std::endl; 00442 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 00443 CHECK_REAL_EQUAL(0.3, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 00444 std::cout << "Good: The new point is located near (0.5, 0.3)" << std::endl; 00445 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 00446 std::cout << "Good: There is one new face" << std::endl; 00447 00448 SaveLastVisitor failVisitor; 00449 AF2Point3D failPointAlpha(8, -0.3752, 0.0001, 0.5); 00450 points.push_back(&failPointAlpha); 00451 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00452 rule180DegreeQ10->applyRule(failNgbhdAlpha, 10u, failVisitor); 00453 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00454 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00455 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 00456 points.pop_back(); 00457 00458 AF2Point3D failPointBravo(9, -0.43145, 0.0399, 0.5); 00459 points.push_back(&failPointBravo); 00460 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00461 rule180DegreeQ10->applyRule(failNgbhdBravo, 10u, failVisitor); 00462 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00463 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00464 << " has a point at (-0.43145, 0.0399, 0.5)" << std::endl; 00465 points.pop_back(); 00466 00467 AF2Point3D failPointCharlie(10, -0.44355, 0.0399, 0.5); 00468 points.push_back(&failPointCharlie); 00469 AF2Neighborhood failNgbhdCharlie(points, 00470 baselineEdge, edges, makePlaneProj()); 00471 rule180DegreeQ10->applyRule(failNgbhdCharlie, 10u, failVisitor); 00472 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00473 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00474 << " has a point at (-0.44355, 0.0399, 0.5)" << std::endl; 00475 points.pop_back(); 00476 00477 AF2Point3D failPointDelta(11, -0.4998, 0.0001, 0.5); 00478 points.push_back(&failPointDelta); 00479 AF2Neighborhood failNgbhdDelta(points, 00480 baselineEdge, edges, makePlaneProj()); 00481 rule180DegreeQ10->applyRule(failNgbhdDelta, 10u, failVisitor); 00482 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00483 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00484 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 00485 points.pop_back(); 00486 00487 00488 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00489 itr != edges.end(); ++itr) 00490 { 00491 delete *itr; 00492 } 00493 delete baselineEdge; 00494 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00495 { 00496 delete pointsVector[pi]; 00497 } 00498 00499 std::cout << "PASS: The 180DegreeRuleQ10 passes the test." << std::endl; 00500 } 00501 00502 void test180DegreeRuleQ20() 00503 { 00504 AF2DfltTriangleRules triRules; 00505 const AF2Rule* rule180DegreeQ20 = 00506 findRule(triRules, "Triangle Off Line, Quality Level 20"); 00507 00508 CHECK(rule180DegreeQ20 != NULL); 00509 00510 std::vector<AF2Point3D*> pointsVector; 00511 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 00512 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 00513 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 00514 pointsVector.push_back(new AF2Point3D(3, -0.25, 0.0, 0.5)); 00515 pointsVector.push_back(new AF2Point3D(4, -0.3748, 0.0, 0.5)); 00516 pointsVector.push_back(new AF2Point3D(5, -0.434175, 0.013225, 0.5)); 00517 pointsVector.push_back(new AF2Point3D(6, -0.440825, 0.013225, 0.5)); 00518 pointsVector.push_back(new AF2Point3D(7, -0.5002, 0.0, 0.5)); 00519 00520 std::list<AF2Point3D*> points; 00521 00522 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00523 { 00524 points.push_back(pointsVector[pi]); 00525 } 00526 00527 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 00528 00529 std::list<const AF2Edge3D*> edges; 00530 // basic line 00531 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00532 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 00533 // lines bounding the expected free zone location 00534 edges.push_back(new AF2Edge3D(pointsVector[4], pointsVector[5])); 00535 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00536 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00537 00538 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00539 00540 SaveLastVisitor visitor; 00541 rule180DegreeQ20->applyRule(ngbhd, 20u, visitor); 00542 00543 CHECK_EQUAL(1u, visitor.getVisitCount()); 00544 std::cout << "Good: There is one way to apply the default triangle rule\n" 00545 << " named \"" << rule180DegreeQ20->getName() << "\"" << std::endl; 00546 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 00547 CHECK_REAL_EQUAL(0.1, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 00548 std::cout << "Good: The new point is located near (0.5, 0.1)" << std::endl; 00549 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 00550 std::cout << "Good: There is one new face" << std::endl; 00551 00552 SaveLastVisitor failVisitor; 00553 AF2Point3D failPointAlpha(8, -0.3756, 0.0001, 0.5); 00554 points.push_back(&failPointAlpha); 00555 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00556 rule180DegreeQ20->applyRule(failNgbhdAlpha, 20u, failVisitor); 00557 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00558 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00559 << " has a point at (-0.3756, 0.0001, 0.5)" << std::endl; 00560 points.pop_back(); 00561 00562 AF2Point3D failPointBravo(9, -0.434575, 0.013025, 0.5); 00563 points.push_back(&failPointBravo); 00564 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00565 rule180DegreeQ20->applyRule(failNgbhdBravo, 20u, failVisitor); 00566 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00567 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00568 << " has a point at (-0.434575, 0.013025, 0.5)" << std::endl; 00569 points.pop_back(); 00570 00571 AF2Point3D failPointCharlie(10, -0.440425, 0.013025, 0.5); 00572 points.push_back(&failPointCharlie); 00573 AF2Neighborhood failNgbhdCharlie(points, 00574 baselineEdge, edges, makePlaneProj()); 00575 rule180DegreeQ20->applyRule(failNgbhdCharlie, 20u, failVisitor); 00576 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00577 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00578 << " has a point at (-0.440425, 0.013025, 0.5)" << std::endl; 00579 points.pop_back(); 00580 00581 AF2Point3D failPointDelta(11, -0.4994, 0.0001, 0.5); 00582 points.push_back(&failPointDelta); 00583 AF2Neighborhood failNgbhdDelta(points, 00584 baselineEdge, edges, makePlaneProj()); 00585 rule180DegreeQ20->applyRule(failNgbhdDelta, 20u, failVisitor); 00586 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00587 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00588 << " has a point at (-0.4994, 0.0001, 0.5)" << std::endl; 00589 points.pop_back(); 00590 00591 00592 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00593 itr != edges.end(); ++itr) 00594 { 00595 delete *itr; 00596 } 00597 delete baselineEdge; 00598 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00599 { 00600 delete pointsVector[pi]; 00601 } 00602 00603 std::cout << "PASS: The 180DegreeRuleQ20 passes the test." << std::endl; 00604 } 00605 00606 void test60DegreeAngleRightRule() 00607 { 00608 AF2DfltTriangleRules triRules; 00609 const AF2Rule* rule60DegreeRight = 00610 findRule(triRules, "Angle at Right Vertex of 60 Degrees"); 00611 00612 CHECK(rule60DegreeRight != NULL); 00613 00614 std::vector<AF2Point3D*> pointsVector; 00615 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 00616 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 00617 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 00618 pointsVector.push_back(new AF2Point3D(3, -0.4375, 0.10825, 0.5)); 00619 pointsVector.push_back(new AF2Point3D(4, -0.3125, 0.10825, 0.5)); 00620 pointsVector.push_back(new AF2Point3D(5, -0.4375, 0.10845, 0.5)); 00621 pointsVector.push_back(new AF2Point3D(6, -0.515725, 0.0812875, 0.5)); 00622 pointsVector.push_back(new AF2Point3D(7, -0.5002, 0.0, 0.5)); 00623 00624 std::list<AF2Point3D*> points; 00625 00626 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00627 { 00628 points.push_back(pointsVector[pi]); 00629 } 00630 00631 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 00632 00633 std::list<const AF2Edge3D*> edges; 00634 // basic neighborhood edges 00635 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00636 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 00637 edges.push_back(new AF2Edge3D(pointsVector[3], pointsVector[4])); 00638 // lines bounding the expected free zone location 00639 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00640 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00641 00642 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00643 00644 SaveLastVisitor visitor; 00645 rule60DegreeRight->applyRule(ngbhd, 1u, visitor); 00646 00647 CHECK_EQUAL(1u, visitor.getVisitCount()); 00648 std::cout << "Good: There is one way to apply the default triangle rule\n" 00649 << " named \"" << rule60DegreeRight->getName() << "\"" << std::endl; 00650 CHECK_EQUAL(0u, visitor.getLast()->getNumNewPoints()); 00651 std::cout << "Good: There are no new points" << std::endl; 00652 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 00653 std::cout << "Good: There is one new face" << std::endl; 00654 00655 SaveLastVisitor failVisitor; 00656 AF2Point3D failPointAlpha(8, -0.4375, 0.10805, 0.5); 00657 points.push_back(&failPointAlpha); 00658 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00659 rule60DegreeRight->applyRule(failNgbhdAlpha, 1u, failVisitor); 00660 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00661 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00662 << " has a point at (-0.4375, 0.10805, 0.5)" << std::endl; 00663 points.pop_back(); 00664 00665 AF2Point3D failPointBravo(9, -0.515525, 0.0810875, 0.5); 00666 points.push_back(&failPointBravo); 00667 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00668 rule60DegreeRight->applyRule(failNgbhdBravo, 1u, failVisitor); 00669 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00670 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00671 << " has a point at (-0.515525, 0.0810875, 0.5)" << std::endl; 00672 points.pop_back(); 00673 00674 AF2Point3D failPointCharlie(10, -0.4998, 0.0001, 0.5); 00675 points.push_back(&failPointCharlie); 00676 AF2Neighborhood failNgbhdCharlie(points, 00677 baselineEdge, edges, makePlaneProj()); 00678 rule60DegreeRight->applyRule(failNgbhdCharlie, 1u, failVisitor); 00679 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00680 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00681 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 00682 points.pop_back(); 00683 00684 00685 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00686 itr != edges.end(); ++itr) 00687 { 00688 delete *itr; 00689 } 00690 delete baselineEdge; 00691 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00692 { 00693 delete pointsVector[pi]; 00694 } 00695 00696 std::cout << "PASS: The 60DegreeAngleRightRule passes the test." << std::endl; 00697 } 00698 00699 void test60DegreeAngleLeftRule() 00700 { 00701 AF2DfltTriangleRules triRules; 00702 const AF2Rule* rule60DegreeLeft = 00703 findRule(triRules, "Angle at Left Vertex of 60 Degrees"); 00704 00705 CHECK(rule60DegreeLeft != NULL); 00706 00707 std::vector<AF2Point3D*> pointsVector; 00708 pointsVector.push_back(new AF2Point3D(0, -0.5625, 0.10825, 0.5)); 00709 pointsVector.push_back(new AF2Point3D(1, -0.4375, 0.10825, 0.5)); 00710 pointsVector.push_back(new AF2Point3D(2, -0.5, 0.0, 0.5)); 00711 pointsVector.push_back(new AF2Point3D(3, -0.375, 0.0, 0.5)); 00712 pointsVector.push_back(new AF2Point3D(4, -0.25, 0.0, 0.5)); 00713 pointsVector.push_back(new AF2Point3D(5, -0.3748, 0.0, 0.5)); 00714 pointsVector.push_back(new AF2Point3D(6, -0.359275, 0.0812875, 0.5)); 00715 pointsVector.push_back(new AF2Point3D(7, -0.4375, 0.10845, 0.5)); 00716 00717 std::list<AF2Point3D*> points; 00718 00719 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00720 { 00721 points.push_back(pointsVector[pi]); 00722 } 00723 00724 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[2], pointsVector[3]); 00725 00726 std::list<const AF2Edge3D*> edges; 00727 // basic neighborhood edges 00728 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00729 edges.push_back(new AF2Edge3D(pointsVector[1], pointsVector[2])); 00730 edges.push_back(new AF2Edge3D(pointsVector[3], pointsVector[4])); 00731 // lines bounding the expected free zone location 00732 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00733 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00734 00735 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00736 00737 SaveLastVisitor visitor; 00738 rule60DegreeLeft->applyRule(ngbhd, 1u, visitor); 00739 00740 CHECK_EQUAL(1u, visitor.getVisitCount()); 00741 std::cout << "Good: There is one way to apply the default triangle rule\n" 00742 << " named \"" << rule60DegreeLeft->getName() << "\"" << std::endl; 00743 CHECK_EQUAL(0u, visitor.getLast()->getNumNewPoints()); 00744 std::cout << "Good: There are no new points" << std::endl; 00745 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 00746 std::cout << "Good: There is one new face" << std::endl; 00747 00748 SaveLastVisitor failVisitor; 00749 AF2Point3D failPointAlpha(8, -0.3752, 0.0001, 0.5); 00750 points.push_back(&failPointAlpha); 00751 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00752 rule60DegreeLeft->applyRule(failNgbhdAlpha, 1u, failVisitor); 00753 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00754 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00755 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 00756 points.pop_back(); 00757 00758 AF2Point3D failPointBravo(9, -0.359475, 0.0810875, 0.5); 00759 points.push_back(&failPointBravo); 00760 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00761 rule60DegreeLeft->applyRule(failNgbhdBravo, 1u, failVisitor); 00762 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00763 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00764 << " has a point at (-0.359475, 0.0810875, 0.5)" << std::endl; 00765 points.pop_back(); 00766 00767 AF2Point3D failPointCharlie(10, -0.4375, 0.10805, 0.5); 00768 points.push_back(&failPointCharlie); 00769 AF2Neighborhood failNgbhdCharlie(points, 00770 baselineEdge, edges, makePlaneProj()); 00771 rule60DegreeLeft->applyRule(failNgbhdCharlie, 1u, failVisitor); 00772 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00773 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00774 << " has a point at (-0.4375, 0.10805, 0.5)" << std::endl; 00775 points.pop_back(); 00776 00777 00778 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00779 itr != edges.end(); ++itr) 00780 { 00781 delete *itr; 00782 } 00783 delete baselineEdge; 00784 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00785 { 00786 delete pointsVector[pi]; 00787 } 00788 00789 std::cout << "PASS: The 60DegreeAngleLeftRule passes the test." << std::endl; 00790 } 00791 00792 void test120DegreeAngleRightRule() 00793 { 00794 AF2DfltTriangleRules triRules; 00795 const AF2Rule* rule120DegreeRight = 00796 findRule(triRules, "Angle at Right Vertex of 120 Degrees"); 00797 00798 CHECK(rule120DegreeRight != NULL); 00799 00800 std::vector<AF2Point3D*> pointsVector; 00801 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 00802 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 00803 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 00804 pointsVector.push_back(new AF2Point3D(3, -0.3125, 0.10825, 0.5)); 00805 pointsVector.push_back(new AF2Point3D(4, -0.1875, 0.10825, 0.5)); 00806 pointsVector.push_back(new AF2Point3D(5, -0.3124, 0.10835, 0.5)); 00807 pointsVector.push_back(new AF2Point3D(6, -0.375, 0.2167, 0.5)); 00808 pointsVector.push_back(new AF2Point3D(7, -0.5, 0.2167, 0.5)); 00809 pointsVector.push_back(new AF2Point3D(8, -0.5626, 0.10835, 0.5)); 00810 pointsVector.push_back(new AF2Point3D(9, -0.5002, 0.0, 0.5)); 00811 00812 std::list<AF2Point3D*> points; 00813 00814 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00815 { 00816 points.push_back(pointsVector[pi]); 00817 } 00818 00819 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 00820 00821 std::list<const AF2Edge3D*> edges; 00822 // basic neighborhood edges 00823 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00824 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 00825 edges.push_back(new AF2Edge3D(pointsVector[3], pointsVector[4])); 00826 // lines bounding the expected free zone location 00827 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00828 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00829 edges.push_back(new AF2Edge3D(pointsVector[7], pointsVector[8])); 00830 edges.push_back(new AF2Edge3D(pointsVector[8], pointsVector[9])); 00831 00832 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00833 00834 SaveLastVisitor visitor; 00835 rule120DegreeRight->applyRule(ngbhd, 1u, visitor); 00836 00837 CHECK_EQUAL(1u, visitor.getVisitCount()); 00838 std::cout << "Good: There is one way to apply the default triangle rule\n" 00839 << " named \"" << rule120DegreeRight->getName() << "\"" << std::endl; 00840 CHECK_EQUAL(1u, visitor.getLast()->getNumNewPoints()); 00841 std::cout << "Good: There is one new point" << std::endl; 00842 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 00843 CHECK_REAL_EQUAL(0.866, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 00844 std::cout << "Good: The new point is located near (0.5, 0.866)" << std::endl; 00845 CHECK_EQUAL(2u, visitor.getLast()->getNumNewFaces()); 00846 std::cout << "Good: There are two new faces" << std::endl; 00847 00848 SaveLastVisitor failVisitor; 00849 AF2Point3D failPointAlpha(10, -0.3126, 0.10815, 0.5); 00850 points.push_back(&failPointAlpha); 00851 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00852 rule120DegreeRight->applyRule(failNgbhdAlpha, 1u, failVisitor); 00853 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00854 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00855 << " has a point at (-0.3126, 0.10815, 0.5)" << std::endl; 00856 points.pop_back(); 00857 00858 AF2Point3D failPointBravo(11, -0.375, 0.2163, 0.5); 00859 points.push_back(&failPointBravo); 00860 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00861 rule120DegreeRight->applyRule(failNgbhdBravo, 1u, failVisitor); 00862 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00863 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00864 << " has a point at (-0.375, 0.2163, 0.5)" << std::endl; 00865 points.pop_back(); 00866 00867 AF2Point3D failPointCharlie(12, -0.5, 0.2163, 0.5); 00868 points.push_back(&failPointCharlie); 00869 AF2Neighborhood failNgbhdCharlie(points, 00870 baselineEdge, edges, makePlaneProj()); 00871 rule120DegreeRight->applyRule(failNgbhdCharlie, 1u, failVisitor); 00872 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00873 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00874 << " has a point at (-0.5, 0.2163, 0.5)" << std::endl; 00875 points.pop_back(); 00876 00877 AF2Point3D failPointDelta(13, -0.5624, 0.10815, 0.5); 00878 points.push_back(&failPointDelta); 00879 AF2Neighborhood failNgbhdDelta(points, 00880 baselineEdge, edges, makePlaneProj()); 00881 rule120DegreeRight->applyRule(failNgbhdDelta, 1u, failVisitor); 00882 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00883 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00884 << " has a point at (-0.5624, 0.10815, 0.5)" << std::endl; 00885 points.pop_back(); 00886 00887 AF2Point3D failPointEcho(14, -0.4998, 0.0001, 0.5); 00888 points.push_back(&failPointEcho); 00889 AF2Neighborhood failNgbhdEcho(points, 00890 baselineEdge, edges, makePlaneProj()); 00891 rule120DegreeRight->applyRule(failNgbhdEcho, 1u, failVisitor); 00892 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00893 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00894 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 00895 points.pop_back(); 00896 00897 00898 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 00899 itr != edges.end(); ++itr) 00900 { 00901 delete *itr; 00902 } 00903 delete baselineEdge; 00904 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00905 { 00906 delete pointsVector[pi]; 00907 } 00908 00909 std::cout << "PASS: The 120DegreeAngleRightRule passes the test." 00910 << std::endl; 00911 } 00912 00913 void test120DegreeAngleLeftRule() 00914 { 00915 AF2DfltTriangleRules triRules; 00916 const AF2Rule* rule120DegreeLeft = 00917 findRule(triRules, "Angle at Left Vertex of 120 Degrees"); 00918 00919 CHECK(rule120DegreeLeft != NULL); 00920 00921 std::vector<AF2Point3D*> pointsVector; 00922 pointsVector.push_back(new AF2Point3D(0, -0.6875, 0.10825, 0.5)); 00923 pointsVector.push_back(new AF2Point3D(1, -0.5625, 0.10825, 0.5)); 00924 pointsVector.push_back(new AF2Point3D(2, -0.5, 0.0, 0.5)); 00925 pointsVector.push_back(new AF2Point3D(3, -0.375, 0.0, 0.5)); 00926 pointsVector.push_back(new AF2Point3D(4, -0.25, 0.0, 0.5)); 00927 pointsVector.push_back(new AF2Point3D(5, -0.3748, 0.0, 0.5)); 00928 pointsVector.push_back(new AF2Point3D(6, -0.3124, 0.10835, 0.5)); 00929 pointsVector.push_back(new AF2Point3D(7, -0.375, 0.2167, 0.5)); 00930 pointsVector.push_back(new AF2Point3D(8, -0.5, 0.2167, 0.5)); 00931 pointsVector.push_back(new AF2Point3D(9, -0.5626, 0.10835, 0.5)); 00932 00933 std::list<AF2Point3D*> points; 00934 00935 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 00936 { 00937 points.push_back(pointsVector[pi]); 00938 } 00939 00940 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[2], pointsVector[3]); 00941 00942 std::list<const AF2Edge3D*> edges; 00943 // basic neighborhood edges 00944 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 00945 edges.push_back(new AF2Edge3D(pointsVector[1], pointsVector[2])); 00946 edges.push_back(new AF2Edge3D(pointsVector[3], pointsVector[4])); 00947 // lines bounding the expected free zone location 00948 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 00949 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 00950 edges.push_back(new AF2Edge3D(pointsVector[7], pointsVector[8])); 00951 edges.push_back(new AF2Edge3D(pointsVector[8], pointsVector[9])); 00952 00953 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 00954 00955 SaveLastVisitor visitor; 00956 rule120DegreeLeft->applyRule(ngbhd, 1u, visitor); 00957 00958 CHECK_EQUAL(1u, visitor.getVisitCount()); 00959 std::cout << "Good: There is one way to apply the default triangle rule\n" 00960 << " named \"" << rule120DegreeLeft->getName() << "\"" << std::endl; 00961 CHECK_EQUAL(1u, visitor.getLast()->getNumNewPoints()); 00962 std::cout << "Good: There is one new point" << std::endl; 00963 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 00964 CHECK_REAL_EQUAL(0.866, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 00965 std::cout << "Good: The new point is located near (0.5, 0.866)" << std::endl; 00966 CHECK_EQUAL(2u, visitor.getLast()->getNumNewFaces()); 00967 std::cout << "Good: There are two new faces" << std::endl; 00968 00969 SaveLastVisitor failVisitor; 00970 AF2Point3D failPointAlpha(10, -0.3752, 0.0001, 0.5); 00971 points.push_back(&failPointAlpha); 00972 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 00973 rule120DegreeLeft->applyRule(failNgbhdAlpha, 1u, failVisitor); 00974 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00975 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00976 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 00977 points.pop_back(); 00978 00979 AF2Point3D failPointBravo(11, -0.3126, 0.10815, 0.5); 00980 points.push_back(&failPointBravo); 00981 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 00982 rule120DegreeLeft->applyRule(failNgbhdBravo, 1u, failVisitor); 00983 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00984 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00985 << " has a point at (-0.3126, 0.10815, 0.5)" << std::endl; 00986 points.pop_back(); 00987 00988 AF2Point3D failPointCharlie(12, -0.375, 0.2163, 0.5); 00989 points.push_back(&failPointCharlie); 00990 AF2Neighborhood failNgbhdCharlie(points, 00991 baselineEdge, edges, makePlaneProj()); 00992 rule120DegreeLeft->applyRule(failNgbhdCharlie, 1u, failVisitor); 00993 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 00994 std::cout << "Good: The rule fails to apply when the neighborhood\n" 00995 << " has a point at (-0.375, 0.2163, 0.5)" << std::endl; 00996 points.pop_back(); 00997 00998 AF2Point3D failPointDelta(13, -0.5, 0.2163, 0.5); 00999 points.push_back(&failPointDelta); 01000 AF2Neighborhood failNgbhdDelta(points, 01001 baselineEdge, edges, makePlaneProj()); 01002 rule120DegreeLeft->applyRule(failNgbhdDelta, 1u, failVisitor); 01003 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01004 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01005 << " has a point at (-0.5, 0.2163, 0.5)" << std::endl; 01006 points.pop_back(); 01007 01008 AF2Point3D failPointEcho(14, -0.5624, 0.10815, 0.5); 01009 points.push_back(&failPointEcho); 01010 AF2Neighborhood failNgbhdEcho(points, 01011 baselineEdge, edges, makePlaneProj()); 01012 rule120DegreeLeft->applyRule(failNgbhdEcho, 1u, failVisitor); 01013 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01014 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01015 << " has a point at (-0.5624, 0.10815, 0.5)" << std::endl; 01016 points.pop_back(); 01017 01018 01019 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 01020 itr != edges.end(); ++itr) 01021 { 01022 delete *itr; 01023 } 01024 delete baselineEdge; 01025 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01026 { 01027 delete pointsVector[pi]; 01028 } 01029 01030 std::cout << "PASS: The 120DegreeAngleLeftRule passes the test." 01031 << std::endl; 01032 } 01033 01034 void test120DegreeAngleBothRule() 01035 { 01036 AF2DfltTriangleRules triRules; 01037 const AF2Rule* rule120DegreeBoth = 01038 findRule(triRules, "Angles at Both Vertices of 120 Degrees"); 01039 01040 CHECK(rule120DegreeBoth != NULL); 01041 01042 std::vector<AF2Point3D*> pointsVector; 01043 pointsVector.push_back(new AF2Point3D(0, -0.6875, 0.10825, 0.5)); 01044 pointsVector.push_back(new AF2Point3D(1, -0.5625, 0.10825, 0.5)); 01045 pointsVector.push_back(new AF2Point3D(2, -0.5, 0.0, 0.5)); 01046 pointsVector.push_back(new AF2Point3D(3, -0.375, 0.0, 0.5)); 01047 pointsVector.push_back(new AF2Point3D(4, -0.3125, 0.10825, 0.5)); 01048 pointsVector.push_back(new AF2Point3D(5, -0.1875, 0.10825, 0.5)); 01049 pointsVector.push_back(new AF2Point3D(6, -0.3124, 0.10835, 0.5)); 01050 pointsVector.push_back(new AF2Point3D(7, -0.375, 0.162575, 0.5)); 01051 pointsVector.push_back(new AF2Point3D(8, -0.5, 0.162575, 0.5)); 01052 pointsVector.push_back(new AF2Point3D(9, -0.5626, 0.10835, 0.5)); 01053 01054 std::list<AF2Point3D*> points; 01055 01056 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01057 { 01058 points.push_back(pointsVector[pi]); 01059 } 01060 01061 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[2], pointsVector[3]); 01062 01063 std::list<const AF2Edge3D*> edges; 01064 // basic neighborhood edges 01065 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 01066 edges.push_back(new AF2Edge3D(pointsVector[1], pointsVector[2])); 01067 edges.push_back(new AF2Edge3D(pointsVector[3], pointsVector[4])); 01068 edges.push_back(new AF2Edge3D(pointsVector[4], pointsVector[5])); 01069 // lines bounding the expected free zone location 01070 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 01071 edges.push_back(new AF2Edge3D(pointsVector[7], pointsVector[8])); 01072 edges.push_back(new AF2Edge3D(pointsVector[8], pointsVector[9])); 01073 01074 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 01075 01076 SaveLastVisitor visitor; 01077 rule120DegreeBoth->applyRule(ngbhd, 1u, visitor); 01078 01079 CHECK_EQUAL(1u, visitor.getVisitCount()); 01080 std::cout << "Good: There is one way to apply the default triangle rule\n" 01081 << " named \"" << rule120DegreeBoth->getName() << "\"" << std::endl; 01082 CHECK_EQUAL(1u, visitor.getLast()->getNumNewPoints()); 01083 std::cout << "Good: There is one new point" << std::endl; 01084 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 01085 CHECK_REAL_EQUAL(0.866, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 01086 std::cout << "Good: The new point is located near (0.5, 0.866)" << std::endl; 01087 CHECK_EQUAL(3u, visitor.getLast()->getNumNewFaces()); 01088 std::cout << "Good: There are three new faces" << std::endl; 01089 01090 SaveLastVisitor failVisitor; 01091 AF2Point3D failPointAlpha(10, -0.3126, 0.10815, 0.5); 01092 points.push_back(&failPointAlpha); 01093 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 01094 rule120DegreeBoth->applyRule(failNgbhdAlpha, 1u, failVisitor); 01095 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01096 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01097 << " has a point at (-0.3126, 0.10815, 0.5)" << std::endl; 01098 points.pop_back(); 01099 01100 AF2Point3D failPointBravo(11, -0.375, 0.162175, 0.5); 01101 points.push_back(&failPointBravo); 01102 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 01103 rule120DegreeBoth->applyRule(failNgbhdBravo, 1u, failVisitor); 01104 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01105 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01106 << " has a point at (-0.375, 0.162175, 0.5)" << std::endl; 01107 points.pop_back(); 01108 01109 AF2Point3D failPointCharlie(12, -0.5, 0.162175, 0.5); 01110 points.push_back(&failPointCharlie); 01111 AF2Neighborhood failNgbhdCharlie(points, 01112 baselineEdge, edges, makePlaneProj()); 01113 rule120DegreeBoth->applyRule(failNgbhdCharlie, 1u, failVisitor); 01114 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01115 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01116 << " has a point at (-0.5, 0.162175, 0.5)" << std::endl; 01117 points.pop_back(); 01118 01119 AF2Point3D failPointDelta(13, -0.5624, 0.10815, 0.5); 01120 points.push_back(&failPointDelta); 01121 AF2Neighborhood failNgbhdDelta(points, 01122 baselineEdge, edges, makePlaneProj()); 01123 rule120DegreeBoth->applyRule(failNgbhdDelta, 1u, failVisitor); 01124 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01125 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01126 << " has a point at (-0.5624, 0.10815, 0.5)" << std::endl; 01127 points.pop_back(); 01128 01129 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 01130 itr != edges.end(); ++itr) 01131 { 01132 delete *itr; 01133 } 01134 delete baselineEdge; 01135 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01136 { 01137 delete pointsVector[pi]; 01138 } 01139 01140 std::cout << "PASS: The 120DegreeAngleBothRule passes the test." 01141 << std::endl; 01142 } 01143 01144 void testFillTriangleRule() 01145 { 01146 AF2DfltTriangleRules triRules; 01147 const AF2Rule* fillTriangleRule = 01148 findRule(triRules, "Fill Triangle"); 01149 01150 CHECK(fillTriangleRule != NULL); 01151 01152 std::vector<AF2Point3D*> pointsVector; 01153 pointsVector.push_back(new AF2Point3D(0, -0.5, 0.0, 0.5)); 01154 pointsVector.push_back(new AF2Point3D(1, -0.375, 0.0, 0.5)); 01155 pointsVector.push_back(new AF2Point3D(2, -0.4375, 0.10825, 0.5)); 01156 01157 std::list<AF2Point3D*> points; 01158 01159 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01160 { 01161 points.push_back(pointsVector[pi]); 01162 } 01163 01164 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[0], pointsVector[1]); 01165 01166 std::list<const AF2Edge3D*> edges; 01167 // basic neighborhood edges 01168 edges.push_back(new AF2Edge3D(pointsVector[1], pointsVector[2])); 01169 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[0])); 01170 01171 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 01172 01173 SaveLastVisitor visitor; 01174 fillTriangleRule->applyRule(ngbhd, 1u, visitor); 01175 01176 CHECK_EQUAL(1u, visitor.getVisitCount()); 01177 std::cout << "Good: There is one way to apply the default triangle rule\n" 01178 << " named \"" << fillTriangleRule->getName() << "\"" << std::endl; 01179 CHECK_EQUAL(0u, visitor.getLast()->getNumNewPoints()); 01180 std::cout << "Good: There are no new points" << std::endl; 01181 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 01182 std::cout << "Good: There is one new face" << std::endl; 01183 01184 SaveLastVisitor failVisitor; 01185 AF2Point3D failPointAlpha(3, -0.4375, 0.10815, 0.5); 01186 points.push_back(&failPointAlpha); 01187 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 01188 fillTriangleRule->applyRule(failNgbhdAlpha, 1u, failVisitor); 01189 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01190 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01191 << " has a point at (-0.4375, 0.10815, 0.5)" << std::endl; 01192 points.pop_back(); 01193 01194 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 01195 itr != edges.end(); ++itr) 01196 { 01197 delete *itr; 01198 } 01199 delete baselineEdge; 01200 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01201 { 01202 delete pointsVector[pi]; 01203 } 01204 01205 std::cout << "PASS: The fillTriangleRule passes the test." 01206 << std::endl; 01207 } 01208 01209 void testConnectVertexRule() 01210 { 01211 AF2DfltTriangleRules triRules; 01212 const AF2Rule* connectVertexRule = 01213 findRule(triRules, "Connect to Opposite Vertex"); 01214 01215 CHECK(connectVertexRule != NULL); 01216 01217 std::vector<AF2Point3D*> pointsVector; 01218 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 01219 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 01220 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 01221 pointsVector.push_back(new AF2Point3D(3, -0.25, 0.0, 0.5)); 01222 pointsVector.push_back(new AF2Point3D(4, -0.4375, 0.10825, 0.5)); 01223 pointsVector.push_back(new AF2Point3D(5, -0.3748, 0.0, 0.5)); 01224 pointsVector.push_back(new AF2Point3D(6, -0.3499, 0.086725, 0.5)); 01225 pointsVector.push_back(new AF2Point3D(7, -0.4375, 0.10845, 0.5)); 01226 pointsVector.push_back(new AF2Point3D(8, -0.5251, 0.086725, 0.5)); 01227 pointsVector.push_back(new AF2Point3D(9, -0.5002, 0.0, 0.5)); 01228 01229 std::list<AF2Point3D*> points; 01230 01231 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01232 { 01233 points.push_back(pointsVector[pi]); 01234 } 01235 01236 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 01237 01238 std::list<const AF2Edge3D*> edges; 01239 // basic neighborhood edges 01240 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 01241 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 01242 // lines bounding the expected free zone location 01243 edges.push_back(new AF2Edge3D(pointsVector[5], pointsVector[6])); 01244 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 01245 edges.push_back(new AF2Edge3D(pointsVector[7], pointsVector[8])); 01246 edges.push_back(new AF2Edge3D(pointsVector[8], pointsVector[9])); 01247 01248 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 01249 01250 SaveLastVisitor visitor; 01251 connectVertexRule->applyRule(ngbhd, 1u, visitor); 01252 01253 CHECK_EQUAL(1u, visitor.getVisitCount()); 01254 std::cout << "Good: There is one way to apply the default triangle rule\n" 01255 << " named \"" << connectVertexRule->getName() << "\"" << std::endl; 01256 CHECK_EQUAL(0u, visitor.getLast()->getNumNewPoints()); 01257 std::cout << "Good: There are no new points" << std::endl; 01258 CHECK_EQUAL(1u, visitor.getLast()->getNumNewFaces()); 01259 std::cout << "Good: There is one new face" << std::endl; 01260 01261 SaveLastVisitor failVisitor; 01262 AF2Point3D failPointAlpha(10, -0.3752, 0.0001, 0.5); 01263 points.push_back(&failPointAlpha); 01264 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 01265 connectVertexRule->applyRule(failNgbhdAlpha, 1u, failVisitor); 01266 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01267 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01268 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 01269 points.pop_back(); 01270 01271 AF2Point3D failPointBravo(11, -0.3501, 0.086525, 0.5); 01272 points.push_back(&failPointBravo); 01273 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 01274 connectVertexRule->applyRule(failNgbhdBravo, 1u, failVisitor); 01275 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01276 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01277 << " has a point at (-0.3501, 0.086525, 0.5)" << std::endl; 01278 points.pop_back(); 01279 01280 AF2Point3D failPointCharlie(12, -0.5249, 0.086525, 0.5); 01281 points.push_back(&failPointCharlie); 01282 AF2Neighborhood failNgbhdCharlie(points, 01283 baselineEdge, edges, makePlaneProj()); 01284 connectVertexRule->applyRule(failNgbhdCharlie, 1u, failVisitor); 01285 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01286 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01287 << " has a point at (-0.5249, 0.086525, 0.5)" << std::endl; 01288 points.pop_back(); 01289 01290 AF2Point3D failPointDelta(13, -0.4998, 0.0001, 0.5); 01291 points.push_back(&failPointDelta); 01292 AF2Neighborhood failNgbhdDelta(points, 01293 baselineEdge, edges, makePlaneProj()); 01294 connectVertexRule->applyRule(failNgbhdDelta, 1u, failVisitor); 01295 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01296 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01297 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 01298 points.pop_back(); 01299 01300 // This vertex of the free zone cannot be tested by adding a point at 01301 // (-0.4375, 0.10805) because the rule will just choose the vertex at 01302 // (-0.4375, 0.10805) as the one it should connect to 01303 pointsVector.push_back(new AF2Point3D(14, -0.125, 0.10805, 0.5)); 01304 pointsVector.push_back(new AF2Point3D(15, -0.875, 0.10805, 0.5)); 01305 points.push_back(pointsVector[10]); 01306 points.push_back(pointsVector[11]); 01307 edges.push_back(new AF2Edge3D(pointsVector[10], pointsVector[11])); 01308 AF2Neighborhood failNgbhdEcho(points, 01309 baselineEdge, edges, makePlaneProj()); 01310 connectVertexRule->applyRule(failNgbhdEcho, 1u, failVisitor); 01311 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01312 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01313 << " has an edge from (-0.125, 0.10805) to (-0.875, 0.10805, 0.5)" 01314 << std::endl; 01315 points.pop_back(); 01316 01317 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 01318 itr != edges.end(); ++itr) 01319 { 01320 delete *itr; 01321 } 01322 delete baselineEdge; 01323 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01324 { 01325 delete pointsVector[pi]; 01326 } 01327 01328 std::cout << "PASS: The connectVertexRule passes the test." << std::endl; 01329 } 01330 01331 void testConnectEdgeRule() 01332 { 01333 AF2DfltTriangleRules triRules; 01334 const AF2Rule* connectEdgeRule = 01335 findRule(triRules, "Connect to Opposite Edge"); 01336 01337 CHECK(connectEdgeRule != NULL); 01338 01339 std::vector<AF2Point3D*> pointsVector; 01340 pointsVector.push_back(new AF2Point3D(0, -0.625, 0.0, 0.5)); 01341 pointsVector.push_back(new AF2Point3D(1, -0.5, 0.0, 0.5)); 01342 pointsVector.push_back(new AF2Point3D(2, -0.375, 0.0, 0.5)); 01343 pointsVector.push_back(new AF2Point3D(3, -0.25, 0.0, 0.5)); 01344 pointsVector.push_back(new AF2Point3D(4, -0.375, 0.2165, 0.5)); 01345 pointsVector.push_back(new AF2Point3D(5, -0.5, 0.2165, 0.5)); 01346 pointsVector.push_back(new AF2Point3D(6, -0.3748, 0.0, 0.5)); 01347 pointsVector.push_back(new AF2Point3D(7, -0.3123, 0.10825, 0.5)); 01348 pointsVector.push_back(new AF2Point3D(8, -0.3748, 0.2165, 0.5)); 01349 pointsVector.push_back(new AF2Point3D(9, -0.5002, 0.2165, 0.5)); 01350 pointsVector.push_back(new AF2Point3D(10, -0.5627, 0.10825, 0.5)); 01351 pointsVector.push_back(new AF2Point3D(11, -0.5002, 0.0, 0.5)); 01352 01353 std::list<AF2Point3D*> points; 01354 01355 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01356 { 01357 points.push_back(pointsVector[pi]); 01358 } 01359 01360 AF2Edge3D* baselineEdge = new AF2Edge3D(pointsVector[1], pointsVector[2]); 01361 01362 std::list<const AF2Edge3D*> edges; 01363 // basic neighborhood edges 01364 edges.push_back(new AF2Edge3D(pointsVector[0], pointsVector[1])); 01365 edges.push_back(new AF2Edge3D(pointsVector[2], pointsVector[3])); 01366 edges.push_back(new AF2Edge3D(pointsVector[4], pointsVector[5])); 01367 // lines bounding the expected free zone location 01368 edges.push_back(new AF2Edge3D(pointsVector[6], pointsVector[7])); 01369 edges.push_back(new AF2Edge3D(pointsVector[7], pointsVector[8])); 01370 edges.push_back(new AF2Edge3D(pointsVector[9], pointsVector[10])); 01371 edges.push_back(new AF2Edge3D(pointsVector[10], pointsVector[11])); 01372 01373 AF2Neighborhood ngbhd(points, baselineEdge, edges, makePlaneProj()); 01374 01375 SaveLastVisitor visitor; 01376 connectEdgeRule->applyRule(ngbhd, 3u, visitor); 01377 01378 CHECK_EQUAL(1u, visitor.getVisitCount()); 01379 std::cout << "Good: There is one way to apply the default triangle rule\n" 01380 << " named \"" << connectEdgeRule->getName() << "\"" << std::endl; 01381 CHECK_EQUAL(1u, visitor.getLast()->getNumNewPoints()); 01382 std::cout << "Good: There is one new point" << std::endl; 01383 CHECK_REAL_EQUAL(0.5, visitor.getLast()->getNewPoint(0u)->getX(), 1e-14); 01384 CHECK_REAL_EQUAL(0.866, visitor.getLast()->getNewPoint(0u)->getY(), 1e-14); 01385 std::cout << "Good: The new point is located near (0.5, 0.866)" << std::endl; 01386 CHECK_EQUAL(2u, visitor.getLast()->getNumNewFaces()); 01387 std::cout << "Good: There are two new faces" << std::endl; 01388 01389 SaveLastVisitor failVisitor; 01390 AF2Point3D failPointAlpha(12, -0.3752, 0.0001, 0.5); 01391 points.push_back(&failPointAlpha); 01392 AF2Neighborhood failNgbhdAlpha(points, baselineEdge, edges, makePlaneProj()); 01393 connectEdgeRule->applyRule(failNgbhdAlpha, 3u, failVisitor); 01394 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01395 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01396 << " has a point at (-0.3752, 0.0001, 0.5)" << std::endl; 01397 points.pop_back(); 01398 01399 AF2Point3D failPointBravo(13, -0.3127, 0.10825, 0.5); 01400 points.push_back(&failPointBravo); 01401 AF2Neighborhood failNgbhdBravo(points, baselineEdge, edges, makePlaneProj()); 01402 connectEdgeRule->applyRule(failNgbhdBravo, 3u, failVisitor); 01403 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01404 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01405 << " has a point at (-0.3127, 0.10825, 0.5)" << std::endl; 01406 points.pop_back(); 01407 01408 AF2Point3D failPointCharlie(14, -0.3752, 0.2164, 0.5); 01409 points.push_back(&failPointCharlie); 01410 AF2Neighborhood failNgbhdCharlie(points, 01411 baselineEdge, edges, makePlaneProj()); 01412 connectEdgeRule->applyRule(failNgbhdCharlie, 3u, failVisitor); 01413 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01414 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01415 << " has a point at (-0.3752, 0.2164, 0.5)" << std::endl; 01416 points.pop_back(); 01417 01418 AF2Point3D failPointDelta(15, -0.4998, 0.2164, 0.5); 01419 points.push_back(&failPointDelta); 01420 AF2Neighborhood failNgbhdDelta(points, 01421 baselineEdge, edges, makePlaneProj()); 01422 connectEdgeRule->applyRule(failNgbhdDelta, 3u, failVisitor); 01423 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01424 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01425 << " has a point at (-0.4998, 0.2164, 0.5)" << std::endl; 01426 points.pop_back(); 01427 01428 AF2Point3D failPointEcho(16, -0.5623, 0.10825, 0.5); 01429 points.push_back(&failPointEcho); 01430 AF2Neighborhood failNgbhdEcho(points, 01431 baselineEdge, edges, makePlaneProj()); 01432 connectEdgeRule->applyRule(failNgbhdEcho, 3u, failVisitor); 01433 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01434 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01435 << " has a point at (-0.5623, 0.10825, 0.5)" << std::endl; 01436 points.pop_back(); 01437 01438 AF2Point3D failPointFoxtrot(17, -0.4998, 0.0001, 0.5); 01439 points.push_back(&failPointFoxtrot); 01440 AF2Neighborhood failNgbhdFoxtrot(points, 01441 baselineEdge, edges, makePlaneProj()); 01442 connectEdgeRule->applyRule(failNgbhdFoxtrot, 3u, failVisitor); 01443 CHECK_EQUAL(0u, failVisitor.getVisitCount()); 01444 std::cout << "Good: The rule fails to apply when the neighborhood\n" 01445 << " has a point at (-0.4998, 0.0001, 0.5)" << std::endl; 01446 points.pop_back(); 01447 01448 for (std::list<const AF2Edge3D*>::iterator itr = edges.begin(); 01449 itr != edges.end(); ++itr) 01450 { 01451 delete *itr; 01452 } 01453 delete baselineEdge; 01454 for (unsigned int pi = 0; pi < pointsVector.size(); ++pi) 01455 { 01456 delete pointsVector[pi]; 01457 } 01458 01459 std::cout << "PASS: The connectEdgeRule passes the test." << std::endl; 01460 }
