MeshKit
1.0
00001 00009 /* 00010 * 00011 * Test the MeshOp graph code in MeshKit. Do this by building a graph 00012 * which looks like: 00013 * 00014 * R 00015 * / \ 00016 * A B 00017 * / \ | 00018 * C D / 00019 * \ | / 00020 * \|/ 00021 * L 00022 * and traversing it using BFS and RBFS (reverse BFS). Do this by registering 00023 * a MeshOp that does nothing but print its name during the setup/execute 00024 * functions. 00025 * 00026 */ 00027 00028 #include "meshkit/MKCore.hpp" 00029 #include "meshkit/MeshOp.hpp" 00030 #include "meshkit/RegisterMeshOp.hpp" 00031 00032 using namespace MeshKit; 00033 00034 class MyScheme; 00035 00036 class MyScheme : public MeshKit::MeshOp 00037 { 00038 public: 00039 MyScheme(MKCore*, const MEntVector &); 00040 00041 inline void setup_this() 00042 {std::cout << "myScheme (setup), node " << get_name() << std::endl; 00043 } 00044 00045 inline void execute_this() 00046 {std::cout << "myScheme (execute), node " << get_name() << std::endl; 00047 } 00048 00049 inline void mesh_types(std::vector<moab::EntityType> &tps) 00050 { 00051 } 00052 00053 static const char* name() { return "MyScheme"; } 00054 static bool can_mesh(iBase_EntityType dim) { return dim == iBase_REGION; } 00055 static bool can_mesh(ModelEnt* ent) { return canmesh_region(ent); } 00056 static const moab::EntityType* output_types() 00057 { 00058 static moab::EntityType end = moab::MBMAXTYPE; 00059 return &end; 00060 } 00061 const moab::EntityType* mesh_types_arr() const 00062 { return output_types(); } 00063 00064 }; 00065 00066 inline MyScheme::MyScheme(MKCore *mk_core, const MEntVector & me_vec) 00067 : MeshOp(mk_core, me_vec) 00068 {} 00069 00070 //---------------------------------------------------------------------------// 00071 RegisterMeshOp<MyScheme> INIT; 00072 //---------------------------------------------------------------------------// 00073 00074 int main(int argc, char **argv) 00075 { 00076 // start up MK and register my scheme with it 00077 MKCore mk; 00078 00079 // create the scheme objects 00080 MeshOp *A = mk.construct_meshop("MyScheme"), 00081 *B = mk.construct_meshop("MyScheme"), 00082 *C = mk.construct_meshop("MyScheme"), 00083 *D = mk.construct_meshop("MyScheme"); 00084 00085 A->set_name("A"); 00086 B->set_name("B"); 00087 C->set_name("C"); 00088 D->set_name("D"); 00089 00090 // put them in the graph 00091 //mk.get_graph().addArc(A->get_node(), C->get_node()); 00092 mk.insert_node(A, C); 00093 //mk.get_graph().addArc(A->get_node(), D->get_node()); 00094 mk.insert_node(A, D); 00095 00096 // now traverse 00097 mk.setup(); 00098 00099 mk.execute(); 00100 00101 mk.print_graph(); 00102 } 00103 00104
