MeshKit
1.0
00001 00017 #include "meshkit/MKCore.hpp" 00018 00019 #include "meshkit/IAInterface.hpp" 00020 #include "meshkit/IAVariable.hpp" 00021 #include "meshkit/TFIMapping.hpp" 00022 00023 #include <stdio.h> 00024 #include <iostream> 00025 #ifdef HAVE_ACIS 00026 #define INTASSIGN_TEST_FILE "quadface.sat" 00027 #elif defined(HAVE_OCC) 00028 #define INTASSIGN_TEST_FILE "quadface.stp" 00029 #endif 00030 00031 MeshKit::MKCore *mk; 00032 00033 MeshKit::IAInterface *new_ia_interface() 00034 { 00035 return 00036 (MeshKit::IAInterface*) mk->construct_meshop("IntervalAssignment"); 00037 } 00038 00039 void mapping_test() 00040 { 00041 00042 } 00043 00044 int main(int argv, char* argc[]) 00045 { 00046 // currently unable to create more than one mk called IntervalAssignment 00047 mk = new MeshKit::MKCore(); 00048 MeshKit::IAInterface *ia_interface = new_ia_interface(); 00049 ia_interface->destroy_data(); 00050 00051 std::string file_name = (std::string) MESH_DIR + "/" + INTASSIGN_TEST_FILE; 00052 printf("opening %s\n", file_name.c_str()); 00053 mk->load_geometry_mesh(file_name.c_str(), NULL); 00054 00055 //check the number of geometrical edges 00056 MeshKit::MEntVector surfs, loops; 00057 mk->get_entities_by_dimension(2, surfs); 00058 MeshKit::ModelEnt *this_surf = (*surfs.rbegin()); 00059 00060 MeshKit::MEntVector curves; 00061 std::vector<int> senses, loop_sizes; 00062 this_surf->boundary(1, curves, &senses, &loop_sizes); 00063 00064 MeshKit::SizingFunction esize(mk, 3, -1); 00065 surfs[0]->sizing_function_index(esize.core_index()); 00066 00067 MeshKit::MEntVector side1, side2; 00068 side1.push_back(curves[0]); side2.push_back(curves[2]); 00069 ia_interface->constrain_sum_equal(ia_interface->make_constraint_group(side1), 00070 ia_interface->make_constraint_group(side2)); 00071 side1.clear(); side2.clear(); 00072 side1.push_back(curves[1]); side2.push_back(curves[3]); 00073 ia_interface->constrain_sum_equal(ia_interface->make_constraint_group(side1), 00074 ia_interface->make_constraint_group(side2)); 00075 00076 // if there are loops, and the loops have strictly less than 4 curves, then 00077 // ia_interface->constrain_sum_even( ia_interface->make_constraint_group(curves in loop) ); 00078 00079 //now, do the TFIMapping 00080 (MeshKit::TFIMapping*) mk->construct_meshop("TFIMapping", surfs); 00081 mk->setup_and_execute(); 00082 mk->save_mesh("intassign.h5m"); 00083 return 0; 00084 }
