MeshKit
1.0
00001 00015 #include "meshkit/MKCore.hpp" 00016 #include "meshkit/OneToOneSwept.hpp" 00017 #include "meshkit/SizingFunction.hpp" 00018 #include "meshkit/ModelEnt.hpp" 00019 #include "meshkit/Matrix.hpp" 00020 #include "meshkit/VertexMesher.hpp" 00021 00022 00023 using namespace MeshKit; 00024 00025 00026 00027 std::string gfile_name; 00028 std::string mfile_name; 00029 00030 // these are indices in the volume for source and target surfaces 00031 int index_source, index_target; 00032 int mesh_intervals; 00033 00034 MKCore *mk = NULL; 00035 00036 void test_brick(); 00037 00038 00039 int main(int argc, char **argv) 00040 { 00041 if (argc==1) 00042 { 00043 #if HAVE_OCC 00044 gfile_name = (std::string) MESH_DIR + "/brick.stp"; 00045 mfile_name = (std::string) MESH_DIR + "/sf.h5m"; 00046 index_source = 0; index_target = 1; mesh_intervals = 6; 00047 #else 00048 gfile_name = (std::string) MESH_DIR + "/BrickWithSrcMeshed.cub"; 00049 mfile_name = gfile_name; 00050 index_source = 1; index_target = 0; mesh_intervals = 6; 00051 #endif 00052 std::cout<<"using default arguments: "; 00053 } 00054 else if (argc==6) 00055 { 00056 gfile_name = argv[1]; 00057 mfile_name = argv[2]; 00058 index_source = atoi(argv[3]); 00059 index_target = atoi(argv[4]); 00060 mesh_intervals = atoi(argv[5]); 00061 std::cout << "Using arguments: "; 00062 } 00063 else 00064 { 00065 std::cout<<"Usage: " << argv[0] << " <geo_file> <mesh_file> <index_src> <index_tar> <mesh_intervals>\n"; 00066 return 1; // error 00067 } 00068 std::cout << argv[0] << " " << gfile_name << " " 00069 << mfile_name << " " << index_source << " " << index_target << " " << mesh_intervals << 00070 "\n"; 00071 // start up MK and load the geometry 00072 mk = new MKCore(); 00073 00074 int num_fail = 0; 00075 00076 test_brick(); 00077 00078 return num_fail; 00079 00080 } 00081 00082 void test_brick() 00083 { 00084 00085 mk->load_geometry_mesh(gfile_name.c_str(), mfile_name.c_str()); 00086 00087 // get the volumes 00088 MEntVector vols, surfs, curves, vertices; 00089 mk->get_entities_by_dimension(3, vols); 00090 std::cout << "Volume size = " << vols.size() << std::endl; 00091 00092 ModelEnt *this_vol = (*vols.rbegin()); 00093 00094 //make a one-to-one sweeping 00095 OneToOneSwept *sw = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", vols); 00096 00097 sw->SetSourceSurface(index_source); 00098 sw->SetTargetSurface(index_target); 00099 00100 //set up the size 00101 SizingFunction swSize(mk, mesh_intervals, -1); 00102 this_vol->sizing_function_index(swSize.core_index()); 00103 00104 //set up for the sweeping and sweep 00105 mk->setup_and_execute(); 00106 00107 //check the number of cells after OneToOneSwept 00108 moab::Range hex; 00109 mk->moab_instance()->get_entities_by_dimension(0, 3, hex); 00110 std::cout << " generated " << hex.size() << " hexahedrons\n"; 00111 00112 mk->save_mesh("OneToOneSwept.h5m"); 00113 00114 delete sw; 00115 delete mk->vertex_mesher(); 00116 mk->clear_graph(); 00117 00118 } 00119
