MeshKit
1.0
00001 00010 #include "meshkit/MKCore.hpp" 00011 #include "meshkit/OneToOneSwept.hpp" 00012 #include "meshkit/SizingFunction.hpp" 00013 #include "meshkit/ModelEnt.hpp" 00014 #include "meshkit/Matrix.hpp" 00015 #include "meshkit/VertexMesher.hpp" 00016 #include "meshkit/CAMALPaver.hpp" 00017 #include "meshkit/FBiGeom.hpp" 00018 00019 00020 using namespace MeshKit; 00021 00022 MKCore *mk = NULL; 00023 00024 void test_ice(); 00025 00026 00027 int main(int argc, char **argv) 00028 { 00029 // start up MK and load the geometry 00030 mk = new MKCore(); 00031 int num_fail = 0;\ 00032 test_ice(); 00033 return num_fail; 00034 } 00035 00036 void test_ice() 00037 { 00038 std::string file_name = (std::string) MESH_DIR + "/volIce.h5m"; 00039 00040 FBiGeom * fbiGeom = new FBiGeom(); // true for smooth, false for linear 00041 int ix = mk->add_igeom_instance(fbiGeom); 00042 00043 iRel::PairHandle * pair; 00044 mk->irel_instance()->createPair ( 00045 fbiGeom->instance(), iRel::ENTITY, iRel::FBIGEOM_IFACE, iRel::ACTIVE, 00046 mk->imesh_instance()->instance(), iRel::SET, iRel::IMESH_IFACE, iRel::ACTIVE, pair); 00047 00048 int ixrel = mk->add_irel_pair(pair); 00049 char opts[]="SMOOTH;"; // relate , populate 00050 mk->load_geometry(file_name.c_str(), opts, ix, 0, ixrel, false, true); 00051 // get the volumes 00052 MEntVector vols, surfs, curves, vertices; 00053 mk->get_entities_by_dimension(3, vols); 00054 std::cout << "Volume size = " << vols.size() << std::endl; 00055 00056 ModelEnt *this_vol = (*vols.rbegin()); 00057 00058 // test getting surfaces 00059 this_vol->get_adjacencies(2, surfs); 00060 00061 // test getting edges 00062 this_vol->get_adjacencies(1, curves); 00063 00064 // test getting vertices 00065 this_vol->get_adjacencies(0, vertices); 00066 00067 MEntVector s1; 00068 s1.push_back(surfs[0]); 00069 (CAMALPaver*)mk->construct_meshop("CAMALPaver", s1); 00070 //set up the size 00071 SizingFunction * pavSize = new SizingFunction(mk, -1, 600); 00072 00073 s1[0]->sizing_function_index(pavSize->core_index()); 00074 00075 mk->setup_and_execute(); 00076 00077 //make a one-to-one sweeping 00078 OneToOneSwept *sw = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", vols); 00079 00080 sw->SetSourceSurface(0); 00081 sw->SetTargetSurface(1); 00082 SizingFunction swSize(mk, 5, -1); 00083 00084 this_vol->sizing_function_index(swSize.core_index()); 00085 00086 //mk->add_arc( cmp, sw);// it means paver will be setup first? 00087 //set up for the sweeping and sweep 00088 mk->setup_and_execute(); 00089 00090 //check the number of cells after OneToOneSwept 00091 moab::Range hex; 00092 mk->moab_instance()->get_entities_by_dimension(0, 3, hex); 00093 mk->save_mesh("OneToOneSwept.vtk"); 00094 00095 //delete sw; 00096 delete mk->vertex_mesher(); 00097 mk->clear_graph(); 00098 00099 } 00100
