MeshKit
1.0
00001 00020 #include "meshkit/MKCore.hpp" 00021 #include "meshkit/MeshOp.hpp" 00022 #include "meshkit/RegisterMeshOp.hpp" 00023 00024 using namespace MeshKit; 00025 00026 class MyScheme; 00027 00028 class MyScheme : public MeshKit::MeshOp 00029 { 00030 public: 00031 MyScheme(MKCore*, const MEntVector &); 00032 00033 inline void setup_this() 00034 {std::cout << "myScheme (setup), node " << get_name() << std::endl; 00035 } 00036 00037 inline void execute_this() 00038 {std::cout << "myScheme (execute), node " << get_name() << std::endl; 00039 } 00040 00041 inline void mesh_types(std::vector<moab::EntityType> &tps) 00042 { 00043 } 00044 00045 static const char* name() { return "MyScheme"; } 00046 static bool can_mesh(iBase_EntityType dim) { return dim == iBase_REGION; } 00047 static bool can_mesh(ModelEnt* ent) { return canmesh_region(ent); } 00048 static const moab::EntityType* output_types() 00049 { 00050 static moab::EntityType end = moab::MBMAXTYPE; 00051 return &end; 00052 } 00053 const moab::EntityType* mesh_types_arr() const 00054 { return output_types(); } 00055 00056 }; 00057 00058 inline MyScheme::MyScheme(MKCore *mk_core, const MEntVector & me_vec) 00059 : MeshOp(mk_core, me_vec) 00060 {} 00061 00062 //---------------------------------------------------------------------------// 00063 RegisterMeshOp<MyScheme> INIT; 00064 //---------------------------------------------------------------------------// 00065 00066 int main(int argc, char **argv) 00067 { 00068 // start up MK and register my scheme with it 00069 MKCore mk; 00070 00071 // create the scheme objects 00072 MeshOp *A = mk.construct_meshop("MyScheme"), 00073 *B = mk.construct_meshop("MyScheme"), 00074 *C = mk.construct_meshop("MyScheme"), 00075 *D = mk.construct_meshop("MyScheme"); 00076 00077 A->set_name("A"); 00078 B->set_name("B"); 00079 C->set_name("C"); 00080 D->set_name("D"); 00081 00082 // put them in the graph 00083 //mk.get_graph().addArc(A->get_node(), C->get_node()); 00084 mk.insert_node(A, C); 00085 //mk.get_graph().addArc(A->get_node(), D->get_node()); 00086 mk.insert_node(A, D); 00087 00088 // now traverse 00089 mk.setup(); 00090 00091 mk.execute(); 00092 00093 mk.print_graph(); 00094 } 00095 00096
