MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/OneToOneSwept.hpp" 00009 #include "meshkit/SizingFunction.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 #include "meshkit/Matrix.hpp" 00012 #include "meshkit/VertexMesher.hpp" 00013 00014 00015 using namespace MeshKit; 00016 00017 #include "TestUtil.hpp" 00018 00019 std::string gfile_name; 00020 std::string mfile_name; 00021 00022 // these are indices in the volume for source and target surfaces 00023 int index_source, index_target; 00024 int mesh_intervals; 00025 00026 MKCore *mk = NULL; 00027 00028 void test_brick(); 00029 00030 int main(int argc, char **argv) 00031 { 00032 if (argc==1) 00033 { 00034 #if HAVE_OCC 00035 gfile_name = TestDir + "/brick.stp"; 00036 mfile_name = TestDir + "/sf.h5m"; 00037 index_source = 0; index_target = 1; mesh_intervals = 6; 00038 #else 00039 gfile_name = TestDir + "/multiconnected.cub"; 00040 mfile_name = gfile_name; 00041 index_source = 2; index_target = 3; mesh_intervals = 10; 00042 00043 #endif 00044 std::cout<<"using default arguments: "; 00045 } 00046 else if (argc==6) 00047 { 00048 gfile_name = argv[1]; 00049 mfile_name = argv[2]; 00050 index_source = atoi(argv[3]); 00051 index_target = atoi(argv[4]); 00052 mesh_intervals = atoi(argv[5]); 00053 std::cout << "Using arguments: "; 00054 } 00055 else 00056 { 00057 std::cout<<"Usage: " << argv[0] << " <geo_file> <mesh_file> <index_src> <index_tar> <mesh_intervals>\n"; 00058 return 1; // error 00059 } 00060 std::cout << argv[0] << " " << gfile_name << " " 00061 << mfile_name << " " << index_source << " " << index_target << " " << mesh_intervals << 00062 "\n"; 00063 // start up MK and load the geometry 00064 mk = new MKCore(); 00065 00066 int num_fail = 0; 00067 00068 num_fail += RUN_TEST(test_brick); 00069 return num_fail; 00070 00071 } 00072 00073 void test_brick() 00074 { 00075 00076 mk->load_geometry_mesh(gfile_name.c_str(), mfile_name.c_str()); 00077 00078 // get the volumes 00079 MEntVector vols, surfs, curves, vertices; 00080 mk->get_entities_by_dimension(3, vols); 00081 std::cout << "Volume size = " << vols.size() << std::endl; 00082 00083 ModelEnt *this_vol = (*vols.rbegin()); 00084 00085 //make a one-to-one sweeping 00086 OneToOneSwept *sw = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", vols); 00087 00088 sw->SetSourceSurface(index_source); 00089 sw->SetTargetSurface(index_target); 00090 00091 //set up the size 00092 SizingFunction swSize(mk, mesh_intervals, -1); 00093 this_vol->sizing_function_index(swSize.core_index()); 00094 00095 //set up for the sweeping and sweep 00096 mk->setup_and_execute(); 00097 00098 //check the number of cells after OneToOneSwept 00099 moab::Range hex; 00100 moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 3, hex); 00101 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00102 std::cout << " generated " << hex.size() << " hexahedrons\n"; 00103 00104 mk->save_mesh("OneToOneSwept.h5m"); 00105 mk->save_mesh("OneToOneSwept.vtk"); 00106 00107 delete sw; 00108 delete mk->vertex_mesher(); 00109 mk->clear_graph(); 00110 00111 } 00112
