MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/SubMapping.hpp" 00009 #include "meshkit/SizingFunction.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 #include "meshkit/Matrix.hpp" 00012 #include "meshkit/EdgeMesher.hpp" 00013 #include "meshkit/SubMapping.hpp" 00014 00015 using namespace MeshKit; 00016 00017 #include "TestUtil.hpp" 00018 00019 MKCore *mk = NULL; 00020 00021 void test_SubMappingcubit(); 00022 00023 int main(int argc, char **argv) 00024 { 00025 00026 // start up MK and load the geometry 00027 mk = new MKCore(); 00028 00029 int num_fail = 0; 00030 00031 //num_fail += RUN_TEST(test_TFImapping); 00032 00033 num_fail += RUN_TEST(test_SubMappingcubit); 00034 00035 00036 #if HAVE_OCC 00037 return 0; 00038 #else 00039 return num_fail; 00040 #endif 00041 } 00042 00043 void test_SubMappingcubit() 00044 { 00045 std::string file_name = TestDir + "/submapping_simple_example.cub"; 00046 mk->load_geometry_mesh(file_name.c_str(), file_name.c_str()); 00047 00048 //check the number of geometrical edges 00049 MEntVector surfs, curves, loops; 00050 mk->get_entities_by_dimension(2, surfs); 00051 ModelEnt *this_surf = (*surfs.rbegin()); 00052 00053 this_surf->get_adjacencies(1, curves); 00054 00055 //CHECK_EQUAL(4, (int)curves.size()); 00056 00057 //check the number of mesh line segments 00058 moab::Range edges; 00059 moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 1, edges); 00060 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00061 //CHECK_EQUAL(40, (int)edges.size()); 00062 00063 SizingFunction swSize(mk, -1, 0.5); 00064 this_surf->sizing_function_index(swSize.core_index()); 00065 //now, do the SubMapping 00066 SubMapping *tm = (SubMapping*)mk->construct_meshop("SubMapping", surfs); 00067 //tm->SetupMeshSize(5.0); 00068 00069 mk->setup_and_execute(); 00070 00071 //check the number of quads 00072 moab::Range faces; 00073 rval = mk->moab_instance()->get_entities_by_dimension(0, 2, faces); 00074 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00075 //CHECK_EQUAL(100, (int)faces.size()); 00076 00077 mk->save_mesh("submapping.vtk"); 00078 00079 delete tm; 00080 mk->clear_graph(); 00081 00082 } 00083 00084
