MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/OneToOneSwept.hpp" 00009 #include "meshkit/SizingFunction.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 #include "meshkit/Matrix.hpp" 00012 #include "meshkit/VertexMesher.hpp" 00013 #include "meshkit/CAMALPaver.hpp" 00014 #include "meshkit/FBiGeom.hpp" 00015 00016 00017 using namespace MeshKit; 00018 00019 #include "TestUtil.hpp" 00020 00021 MKCore *mk = NULL; 00022 00023 void test_ice(); 00024 00025 00026 int main(int argc, char **argv) 00027 { 00028 00029 // start up MK and load the geometry 00030 mk = new MKCore(); 00031 00032 int num_fail = 0; 00033 00034 num_fail += RUN_TEST(test_ice); 00035 00036 return num_fail; 00037 } 00038 00039 void test_ice() 00040 { 00041 std::string file_name = TestDir + "/volIce.h5m"; 00042 00043 FBiGeom * fbiGeom = new FBiGeom(); // true for smooth, false for linear 00044 int ix = mk->add_igeom_instance(fbiGeom); 00045 00046 iRel::PairHandle * pair; 00047 iBase_ErrorType err = mk->irel_instance()->createPair ( 00048 fbiGeom->instance(), iRel::ENTITY, iRel::FBIGEOM_IFACE, iRel::ACTIVE, 00049 mk->imesh_instance()->instance(), iRel::SET, iRel::IMESH_IFACE, iRel::ACTIVE, pair); 00050 00051 CHECK_EQUAL(0, (int)err); 00052 00053 int ixrel = mk->add_irel_pair(pair); 00054 char opts[]="SMOOTH;"; // relate , populate 00055 mk->load_geometry(file_name.c_str(), opts, ix, 0, ixrel, false, true); 00056 // get the volumes 00057 MEntVector vols, surfs, curves, vertices; 00058 mk->get_entities_by_dimension(3, vols); 00059 std::cout << "Volume size = " << vols.size() << std::endl; 00060 00061 ModelEnt *this_vol = (*vols.rbegin()); 00062 00063 // test getting surfaces 00064 this_vol->get_adjacencies(2, surfs); 00065 //CHECK_EQUAL(6, (int)surfs.size()); 00066 00067 // test getting edges 00068 this_vol->get_adjacencies(1, curves); 00069 //CHECK_EQUAL(12, (int)curves.size()); 00070 00071 // test getting vertices 00072 this_vol->get_adjacencies(0, vertices); 00073 //CHECK_EQUAL(8, (int)vertices.size()); 00074 00075 MEntVector s1; 00076 s1.push_back(surfs[0]); 00077 /*CAMALPaver * cmp = (CAMALPaver*)*/mk->construct_meshop("CAMALPaver", s1); 00078 //set up the size 00079 SizingFunction * pavSize = new SizingFunction(mk, -1, 600); 00080 00081 s1[0]->sizing_function_index(pavSize->core_index()); 00082 00083 mk->setup_and_execute(); 00084 00085 //make a one-to-one sweeping 00086 OneToOneSwept *sw = (OneToOneSwept*) mk->construct_meshop("OneToOneSwept", vols); 00087 00088 sw->SetSourceSurface(0); 00089 sw->SetTargetSurface(1); 00090 SizingFunction swSize(mk, 5, -1); 00091 00092 this_vol->sizing_function_index(swSize.core_index()); 00093 00094 00095 00096 //mk->add_arc( cmp, sw);// it means paver will be setup first? 00097 //set up for the sweeping and sweep 00098 mk->setup_and_execute(); 00099 00100 //check the number of cells after OneToOneSwept 00101 moab::Range hex; 00102 moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension(0, 3, hex); 00103 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00104 //CHECK_EQUAL(600, (int)hex.size()); 00105 00106 mk->save_mesh("OneToOneSwept.vtk"); 00107 00108 //delete sw; 00109 delete mk->vertex_mesher(); 00110 mk->clear_graph(); 00111 00112 } 00113
