Mesh Oriented datABase
(version 5.4.1)
00001 /** @example BoundaryContinents
00002 * Description: read boundary points and loops that form islands and continents
00003 and create an edge mesh file \n
00004 *
00005 * BoundaryContinents
00006 * (default values can run if users don't specify input files)
00007 */
00008
00009 #include "moab/Core.hpp"
00010 #include "moab/ReadUtilIface.hpp"
00011 #include "moab/CartVect.hpp"
00012 #include
00013 #include
00014
00015 using namespace moab;
00016 using namespace std;
00017
00018 string bd_name = string( MESH_DIR ) + string( "/../examples/earth/boundary_points.dat" );
00019 string loops = string( MESH_DIR ) + string( "/../examples/earth/SaveLoopCounts" );
00020
00021 double getLat( CartVect p )
00022 {
00023 p.normalize();
00024 return asin( p[2] );
00025 }
00026 double getLon( CartVect p )
00027 {
00028 p.normalize();
00029 double lon;
00030
00031 lon = atan2( p[1], p[0] );
00032 if( lon < -2.95 )
00033 { // this is Behring Strait :)
00034 return 2.0 * M_PI + lon;
00035 }
00036 else
00037 {
00038 return lon;
00039 }
00040 }
00041
00042 int main( int argc, char** argv )
00043 {
00044 // Get MOAB instance
00045 Interface* mb = new( std::nothrow ) Core;
00046 if( NULL == mb ) return 1;
00047
00048 if( argc > 1 )
00049 {
00050 // User has input file for boundary describing continents
00051 bd_name = argv[1];
00052 }
00053 if( argc > 2 )
00054 {
00055 // User has input file for loops for continents/islands
00056 loops = argv[2];
00057 }
00058
00059 std::vector< double > coords;
00060 ifstream bdFile( bd_name.c_str() );
00061 if( !bdFile )
00062 {
00063 cout << endl << "Failed to open file " << bd_name << endl;
00064 ;
00065 return 1;
00066 }
00067 coords.resize( 0 );
00068 while( !bdFile.eof() )
00069 {
00070 double co;
00071 bdFile >> co;
00072 coords.push_back( co );
00073 }
00074 cout << " number of boundary points:" << coords.size() / 3 << "\n";
00075 /// get loops for boundaries
00076 vector< int > loopsindx;
00077 ifstream loopFile( loops.c_str() );
00078 while( !loopFile.eof() )
00079 {
00080 int indx;
00081 loopFile >> indx;
00082 loopsindx.push_back( indx );
00083 }
00084 cout << "number of loops: " << loopsindx.size() / 2 << "\n";
00085 ReadUtilIface* readMeshIface;
00086 mb->query_interface( readMeshIface );
00087 Range verts;
00088
00089 ErrorCode rval = mb->create_vertices( &coords[0], coords.size() / 3, verts );MB_CHK_SET_ERR( rval, "do not create boundary vertices" );
00090
00091 Tag gid = mb->globalId_tag();
00092
00093 int num_edges = 0;
00094 for( size_t i = 0; i < loopsindx.size() / 2; i++ )
00095 {
00096 num_edges += ( loopsindx[2 * i + 1] - loopsindx[2 * i] + 1 );
00097 }
00098 EntityHandle handle;
00099 EntityHandle* conn_array;
00100 rval = readMeshIface->get_element_connect( num_edges, 2, MBEDGE, 1, handle, conn_array );MB_CHK_SET_ERR( rval, "do not elems" );
00101 int i1 = 0; // index in edge connectivity
00102 for( size_t i = 0; i < loopsindx.size() / 2; i++ )
00103 {
00104 for( int j = loopsindx[2 * i]; j <= loopsindx[2 * i + 1]; j++ )
00105 {
00106 int j2;
00107 j2 = j;
00108 if( j == loopsindx[2 * i + 1] ) j2 = loopsindx[2 * i] - 1; // close the loop
00109 conn_array[2 * i1] = verts[j - 1]; // vertices for sure start at 1
00110 conn_array[2 * i1 + 1] = verts[j2]; // vertices for sure start at 1
00111 i1++;
00112 }
00113 // the last vertex is first one in the loop
00114 }
00115
00116 Range bedges( handle, handle + num_edges - 1 );
00117 EntityHandle bound_set;
00118 rval = mb->create_meshset( MESHSET_SET, bound_set );MB_CHK_SET_ERR( rval, "Can't create boundary edges set" );
00119
00120 rval = mb->add_entities( bound_set, bedges );MB_CHK_SET_ERR( rval, "Can't add edges to boundary set" );
00121
00122 // set global ids for vertices and edges
00123 vector< int > gids;
00124 gids.resize( verts.size() );
00125 for( int j = 0; j < (int)verts.size(); j++ )
00126 {
00127 gids[j] = j + 1;
00128 }
00129 rval = mb->tag_set_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global ids on verts" );
00130 // we have less edges than vertices, we can reuse the array for edges too
00131 rval = mb->tag_set_data( gid, bedges, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global ids on edges" );
00132
00133 mb->write_file( "bound.vtk", 0, 0, &bound_set, 1 );
00134
00135 // now project the mesh in 2d plane
00136 // get all the vertices coordinates
00137 std::vector< CartVect > co3;
00138 co3.resize( verts.size() );
00139 rval = mb->get_coords( verts, &( co3[0][0] ) );MB_CHK_SET_ERR( rval, "Can't get vertex coords" );
00140 for( size_t i = 0; i < verts.size(); i++ )
00141 {
00142 CartVect p = co3[i];
00143 double lat1 = getLat( p );
00144 double lon1 = getLon( p );
00145 co3[i] = CartVect( lon1, lat1, 0. );
00146 }
00147 rval = mb->set_coords( verts, &( co3[0][0] ) );MB_CHK_SET_ERR( rval, "Can't set new vertex coords" );
00148 // remove edges in 2d that are too long (longer than 6; they are on the other side..., periodic)
00149
00150 Range longEdges;
00151 for( Range::iterator eit = bedges.begin(); eit != bedges.end(); ++eit )
00152 {
00153 EntityHandle eh = *eit;
00154 const EntityHandle* conn;
00155 int nconn;
00156 rval = mb->get_connectivity( eh, conn, nconn );MB_CHK_ERR( rval );
00157 // get coordinates of nodes
00158 CartVect c2[2];
00159 rval = mb->get_coords( conn, 2, &( c2[0][0] ) );MB_CHK_ERR( rval );
00160 double dist = ( c2[1] - c2[0] ).length_squared();
00161 if( dist > 36. ) // too long edge in 2d, remove it
00162 longEdges.insert( eh );
00163 }
00164 rval = mb->delete_entities( longEdges );MB_CHK_ERR( rval );
00165
00166 mb->write_file( "bound2d.vtk" );
00167 delete mb;
00168
00169 return 0;
00170 }
