Mesh Oriented datABase
(version 5.4.1)
00001 #include "DataCoupler.hpp" 00002 #include "moab/Tree.hpp" 00003 #include "moab/TupleList.hpp" 00004 #include "moab/SpatialLocator.hpp" 00005 #include "moab/ElemEvaluator.hpp" 00006 #include "moab/Error.hpp" 00007 00008 #ifdef MOAB_HAVE_MPI 00009 #include "moab/ParallelComm.hpp" 00010 #endif 00011 00012 #include "iostream" 00013 #include <algorithm> 00014 #include <sstream> 00015 00016 #include <cstdio> 00017 #include <cassert> 00018 00019 namespace moab 00020 { 00021 00022 DataCoupler::DataCoupler( Interface* impl, 00023 Range& source_ents, 00024 int coupler_id, 00025 ParallelComm* pc, 00026 bool init_locator, 00027 int dim ) 00028 : mbImpl( impl ), myPcomm( pc ), myId( coupler_id ), myDim( dim ) 00029 { 00030 assert( NULL != mbImpl && ( myPcomm || !source_ents.empty() ) ); 00031 00032 // Now initialize the tree 00033 if( init_locator ) 00034 { 00035 myLocator = new SpatialLocator( mbImpl, source_ents ); 00036 myLocator->elem_eval( new ElemEvaluator( mbImpl ) ); 00037 00038 // Initialize element evaluator with the default for the entity types in source_ents; 00039 // can be replaced later by application if desired 00040 if( !source_ents.empty() ) 00041 { 00042 Range::pair_iterator pit = source_ents.pair_begin(); 00043 EntityType last_type = MBMAXTYPE; 00044 for( ; pit != source_ents.pair_end(); ++pit ) 00045 { 00046 EntityType this_type = mbImpl->type_from_handle( pit->first ); 00047 if( last_type == this_type ) continue; 00048 ErrorCode rval = myLocator->elem_eval()->set_eval_set( pit->first ); 00049 if( MB_SUCCESS != rval ) throw( rval ); 00050 last_type = this_type; 00051 } 00052 } 00053 } 00054 00055 if( -1 == dim && !source_ents.empty() ) myDim = mbImpl->dimension_from_handle( *source_ents.rbegin() ); 00056 } 00057 00058 /* Destructor 00059 */ 00060 DataCoupler::~DataCoupler() 00061 { 00062 delete myLocator->elem_eval(); 00063 delete myLocator; 00064 } 00065 00066 ErrorCode DataCoupler::locate_points( Range& targ_ents, 00067 const double rel_iter_tol, 00068 const double abs_iter_tol, 00069 const double inside_tol ) 00070 { 00071 targetEnts = targ_ents; 00072 00073 #ifdef MOAB_HAVE_MPI 00074 if( myPcomm && myPcomm->size() > 1 ) 00075 return myLocator->par_locate_points( myPcomm, targ_ents, rel_iter_tol, abs_iter_tol, inside_tol ); 00076 #endif 00077 00078 return myLocator->locate_points( targ_ents, rel_iter_tol, abs_iter_tol, inside_tol ); 00079 } 00080 00081 ErrorCode DataCoupler::locate_points( double* xyz, 00082 int num_points, 00083 const double rel_iter_tol, 00084 const double abs_iter_tol, 00085 const double inside_tol ) 00086 { 00087 #ifdef MOAB_HAVE_MPI 00088 if( myPcomm && myPcomm->size() > 1 ) 00089 return myLocator->par_locate_points( myPcomm, xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol ); 00090 #endif 00091 00092 return myLocator->locate_points( xyz, num_points, rel_iter_tol, abs_iter_tol, inside_tol ); 00093 } 00094 00095 ErrorCode DataCoupler::interpolate( /*DataCoupler::Method*/ int method, 00096 const std::string& interp_tag, 00097 double* interp_vals, 00098 std::vector< int >* point_indices, 00099 bool normalize ) 00100 { 00101 // Tag name input, translate to tag handle and pass down the chain 00102 00103 Tag tag; 00104 ErrorCode result = mbImpl->tag_get_handle( interp_tag.c_str(), tag );MB_CHK_SET_ERR( result, "Failed to get handle for interpolation tag \"" << interp_tag << "\"" ); 00105 00106 return interpolate( method, tag, interp_vals, point_indices, normalize ); 00107 } 00108 00109 ErrorCode DataCoupler::interpolate( /*DataCoupler::Method*/ int* /* methods */, 00110 Tag* tags, 00111 int* points_per_method, 00112 int num_methods, 00113 double* interp_vals, 00114 std::vector< int >* point_indices, 00115 bool /*normalize*/ ) 00116 { 00117 // Lowest-level interpolate function, does actual interpolation using calls to ElemEvaluator 00118 00119 ErrorCode result = MB_SUCCESS; 00120 00121 unsigned int pts_total = 0; 00122 for( int i = 0; i < num_methods; i++ ) 00123 pts_total += ( points_per_method ? points_per_method[i] : targetEnts.size() ); 00124 00125 unsigned int num_indices = ( point_indices ? point_indices->size() : targetEnts.size() ); 00126 // # points and indices should be identical 00127 if( pts_total != num_indices ) return MB_FAILURE; 00128 00129 // Since each tuple contains one interpolated tag, if we're interpolating multiple tags, every 00130 // tuple needs to be able to store up to max tag size 00131 int max_tsize = -1; 00132 for( int i = 0; i < num_methods; i++ ) 00133 { 00134 int tmp_tsize; 00135 result = mbImpl->tag_get_length( tags[i], tmp_tsize ); 00136 if( MB_SUCCESS != result ) return MB_FAILURE; 00137 max_tsize = std::max( max_tsize, tmp_tsize ); 00138 } 00139 00140 if( myPcomm && myPcomm->size() > 1 ) 00141 { 00142 // Build up the tuple list to distribute from my target points; assume that 00143 // all procs use same method/tag input 00144 TupleList TLob; // TLob structure: (pto_i, ridx_i, lidx_i, meth_tagidx_i) 00145 TLob.initialize( 4, 0, 0, 0, num_indices ); 00146 int tn = 0; // The tuple number we're currently on 00147 TLob.enableWriteAccess(); 00148 for( int m = 0; m < num_methods; m++ ) 00149 { 00150 int num_points = ( points_per_method ? points_per_method[m] : targetEnts.size() ); 00151 for( int j = 0; j < num_points; j++ ) 00152 { 00153 int idx = ( point_indices ? ( *point_indices )[j] 00154 : j ); // The index in my targetEnts for this interpolation point 00155 00156 // Remote proc/idx from myLocator->parLocTable 00157 TLob.vi_wr[4 * tn] = myLocator->par_loc_table().vi_rd[2 * idx]; // proc 00158 TLob.vi_wr[4 * tn + 1] = myLocator->par_loc_table().vi_rd[2 * idx + 1]; // Remote idx 00159 00160 // Local entity index, tag/method index from my data 00161 TLob.vi_wr[4 * tn + 2] = idx; 00162 TLob.vi_wr[4 * tn + 3] = m; 00163 TLob.inc_n(); 00164 tn++; 00165 } 00166 } 00167 00168 // Scatter/gather interpolation points 00169 myPcomm->proc_config().crystal_router()->gs_transfer( 1, TLob, 0 ); 00170 00171 // Perform interpolation on local source mesh; put results into TLinterp 00172 TupleList TLinterp; // TLinterp structure: (pto_i, ridx_i, vals[max_tsize]_d) 00173 TLinterp.initialize( 2, 0, 0, max_tsize, TLob.get_n() ); 00174 TLinterp.set_n( TLob.get_n() ); // Set the size right away 00175 TLinterp.enableWriteAccess(); 00176 00177 for( unsigned int i = 0; i < TLob.get_n(); i++ ) 00178 { 00179 int lidx = TLob.vi_rd[4 * i + 1]; // Index into myLocator's local table 00180 // Method and tag indexed with same index 00181 ///*Method*/ int method = methods[TLob.vi_rd[4*i + 3]]; 00182 Tag tag = tags[TLob.vi_rd[4 * i + 3]]; 00183 // Copy proc/remote index from TLob 00184 TLinterp.vi_wr[2 * i] = TLob.vi_rd[4 * i]; 00185 TLinterp.vi_wr[2 * i + 1] = TLob.vi_rd[4 * i + 2]; 00186 00187 // Set up the evaluator for the tag and entity, then interpolate, putting result in 00188 // TLinterp 00189 myLocator->elem_eval()->set_tag_handle( tag ); 00190 myLocator->elem_eval()->set_ent_handle( myLocator->loc_table().vul_rd[lidx] ); 00191 result = 00192 myLocator->elem_eval()->eval( myLocator->loc_table().vr_rd + 3 * lidx, TLinterp.vr_rd + i * max_tsize ); 00193 if( MB_SUCCESS != result ) return result; 00194 } 00195 00196 // Scatter/gather interpolation data 00197 myPcomm->proc_config().crystal_router()->gs_transfer( 1, TLinterp, 0 ); 00198 00199 // Copy the interpolated field as a unit 00200 std::copy( TLinterp.vr_rd, TLinterp.vr_rd + TLinterp.get_n() * max_tsize, interp_vals ); 00201 } 00202 else 00203 { 00204 // If called serially, interpolate directly from local locations/entities, 00205 // into either interp_vals or by setting data directly on tags on those entities 00206 std::vector< double > tmp_vals; 00207 std::vector< EntityHandle > tmp_ents; 00208 double* tmp_dbl = interp_vals; 00209 for( int i = 0; i < num_methods; i++ ) 00210 { 00211 int num_points = ( points_per_method ? points_per_method[i] : targetEnts.size() ); 00212 00213 // Interpolated data is tsize long, which is either max size (if data passed back to 00214 // caller in interp_vals) or tag size (if data will be set on entities, in which case it 00215 // shouldn't have padding) set sizes here, inside loop over methods, to reduce memory 00216 // usage 00217 int tsize = max_tsize, tsize_bytes = 0; 00218 if( !interp_vals ) 00219 { 00220 tmp_vals.resize( num_points * max_tsize ); 00221 tmp_dbl = &tmp_vals[0]; 00222 tmp_ents.resize( num_points ); 00223 result = mbImpl->tag_get_length( tags[i], tsize ); 00224 if( MB_SUCCESS != result ) return result; 00225 result = mbImpl->tag_get_bytes( tags[i], tsize_bytes ); 00226 if( MB_SUCCESS != result ) return result; 00227 } 00228 00229 for( int j = 0; j < num_points; j++ ) 00230 { 00231 int lidx; 00232 if( point_indices ) 00233 lidx = ( *point_indices )[j]; 00234 else 00235 lidx = j; 00236 00237 myLocator->elem_eval()->set_tag_handle( tags[i] ); 00238 myLocator->elem_eval()->set_ent_handle( myLocator->loc_table().vul_rd[lidx] ); 00239 if( !interp_vals ) tmp_ents[j] = targetEnts[lidx]; // Could be performance-sensitive, thus the if test 00240 result = myLocator->elem_eval()->eval( myLocator->loc_table().vr_rd + 3 * lidx, tmp_dbl ); 00241 tmp_dbl += tsize; 00242 if( MB_SUCCESS != result ) return result; 00243 } // for j over points 00244 00245 if( !interp_vals ) 00246 { 00247 // Set tags on tmp_ents; data is already w/o padding, due to tsize setting above 00248 result = mbImpl->tag_set_data( tags[i], &tmp_ents[0], tmp_ents.size(), &tmp_vals[0] ); 00249 if( MB_SUCCESS != result ) return result; 00250 } 00251 00252 } // for i over methods 00253 } // if myPcomm 00254 00255 // Done 00256 return MB_SUCCESS; 00257 } 00258 00259 } // namespace moab
