Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /**\class moab::EdgeSizeSimpleImplicit 00017 * 00018 * This is an simple example edge evaluator tha subdivides edges based 00019 * on their midpoint's distance to a simple, fixed-form implicit surface 00020 * written as \f$ x^T A x + B x + C \f$ where \f$x\f$ is a column vector of 00021 * holding the edge midpoint coordinates, \f$A\f$ is a symmetric 3x3 matrix, 00022 * \f$B\f$ is a 1x3 row vector, and \f$C\f$ is a scalar. 00023 * Whenever the implicit function divided by half of the edge length is smaller than 00024 * some minimum ratio (which defaults to 1), the edge is marked for subdivision. 00025 * 00026 * \author David Thompson 00027 * 00028 * \date 19 November 2007 00029 */ 00030 #ifndef MOAB_EDGE_SIZE_SIMPLE_IMPLICIT_HPP 00031 #define MOAB_EDGE_SIZE_SIMPLE_IMPLICIT_HPP 00032 00033 #include "EdgeSizeEvaluator.hpp" 00034 00035 namespace moab 00036 { 00037 00038 class EdgeSizeSimpleImplicit : public EdgeSizeEvaluator 00039 { 00040 public: 00041 /// Construct an evaluator. 00042 EdgeSizeSimpleImplicit(); 00043 /// Destruction is virtual so subclasses may clean up after refinement. 00044 virtual ~EdgeSizeSimpleImplicit(); 00045 00046 /** \brief Given an edge of length L, true when edge midpoint is within $\alpha^2$ of 00047 * $\left(\frac{2f(x,y,z)}{L}\right)^2$. 00048 */ 00049 virtual bool evaluate_edge( const double* p0, 00050 const void* t0, 00051 double* p1, 00052 void* t1, 00053 const double* p2, 00054 const void* t2 ); 00055 00056 /// Set the 10 coefficients of the implicit function. The vector contains the entries of A, 00057 /// followed by B, followed by C. 00058 virtual void set_implicit_function( double* coeffs ); 00059 /// Get the 10 coefficients of the implicit function. The vector contains the entries of A, 00060 /// followed by B, followed by C. 00061 void get_implicit_function( double*& coeffs ); 00062 00063 /// Set the threshold ratio of function value to half-edge length that triggers subdivision. 00064 virtual void set_ratio( double r ) 00065 { 00066 this->ratio = r; 00067 } 00068 /// Get the threshold ratio of function value to half-edge length that triggers subdivision. 00069 double get_ratio() 00070 { 00071 return this->ratio; 00072 } 00073 00074 protected: 00075 double coeffA[6]; 00076 double coeffB[3]; 00077 double coeffC; 00078 double ratio; 00079 }; 00080 00081 } // namespace moab 00082 00083 #endif // MOAB_EDGE_SIZE_SIMPLE_IMPLICIT_HPP
