Mesh Oriented datABase
(version 5.4.1)
00001 /** @example HelloMOAB.cpp 00002 * Description: read a mesh, get the entities.\n 00003 * HelloMOAB is a simple test file which is used to read meshes from VTK file and test how many 00004 * entities there are.\n 00005 * 00006 * To run: ./HelloMOAB [meshfile]\n 00007 * (default values can run if users don't specify a mesh file) 00008 */ 00009 00010 #include "moab/Core.hpp" 00011 #include <iostream> 00012 00013 using namespace moab; 00014 using namespace std; 00015 00016 #ifndef MESH_DIR 00017 #define MESH_DIR "." 00018 #endif 00019 00020 // Note: change the file name below to test a trivial "No such file or directory" error 00021 string test_file_name = string( MESH_DIR ) + string( "/3k-tri-sphere.vtk" ); 00022 00023 int main( int argc, char** argv ) 00024 { 00025 // Get MOAB instance 00026 Interface* mb = new( std::nothrow ) Core; 00027 if( NULL == mb ) return 1; 00028 00029 // Need option handling here for input filename 00030 if( argc > 1 ) 00031 { 00032 // User has input a mesh file 00033 test_file_name = argv[1]; 00034 } 00035 00036 // Load the mesh from vtk file 00037 ErrorCode rval = mb->load_mesh( test_file_name.c_str() );MB_CHK_ERR( rval ); 00038 00039 // Get verts entities, by type 00040 Range verts; 00041 rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_ERR( rval ); 00042 00043 // Get edge entities, by type 00044 Range edges; 00045 rval = mb->get_entities_by_type( 0, MBEDGE, edges );MB_CHK_ERR( rval ); 00046 00047 // Get faces, by dimension, so we stay generic to entity type 00048 Range faces; 00049 rval = mb->get_entities_by_dimension( 0, 2, faces );MB_CHK_ERR( rval ); 00050 00051 // Get regions, by dimension, so we stay generic to entity type 00052 Range elems; 00053 rval = mb->get_entities_by_dimension( 0, 3, elems );MB_CHK_ERR( rval ); 00054 00055 // Output the number of entities 00056 cout << "Number of vertices is " << verts.size() << endl; 00057 cout << "Number of edges is " << edges.size() << endl; 00058 cout << "Number of faces is " << faces.size() << endl; 00059 cout << "Number of elements is " << elems.size() << endl; 00060 00061 delete mb; 00062 00063 return 0; 00064 }
