00001 /* 00002 * Intx2Mesh.hpp 00003 * 00004 * Created on: Oct 2, 2012 00005 * 00006 */ 00007 00008 #ifndef INTX2MESH_HPP_ 00009 #define INTX2MESH_HPP_ 00010 00011 #include 00012 #include 00013 #include 00014 #include 00015 #include 00016 #include 00017 #include 00018 #include 00019 #include "moab/Core.hpp" 00020 #include "moab/Interface.hpp" 00021 #include "moab/Range.hpp" 00022 #include "moab/CartVect.hpp" 00023 #include "moab/IntxMesh/IntxUtils.hpp" 00024 00025 // #define ENABLE_DEBUG 00026 00027 // maximum number of edges on each convex polygon of interest 00028 #define MAXEDGES 10 00029 #define MAXEDGES2 20 // used for coordinates in plane 00030 #define CORRTAGNAME "__correspondent" 00031 00032 namespace moab 00033 { 00034 00035 #define ERRORR( rval, str ) \ 00036 if( MB_SUCCESS != ( rval ) ) \ 00037 { \ 00038 std::cout << ( str ) << "\n"; \ 00039 return rval; \ 00040 } 00041 00042 #define ERRORV( rval, str ) \ 00043 if( MB_SUCCESS != ( rval ) ) \ 00044 { \ 00045 std::cout << ( str ) << "\n"; \ 00046 return; \ 00047 } 00048 00049 #ifdef MOAB_HAVE_MPI 00050 // forward declarations 00051 class ParallelComm; 00052 class TupleList; 00053 #endif 00054 00055 class Intx2Mesh 00056 { 00057 public: 00058 Intx2Mesh( Interface* mbimpl ); 00059 00060 virtual ~Intx2Mesh(); 00061 00062 /* 00063 * computes intersection between 2 sets; 00064 * set 2 (mbs2) should be completely covered by set mbs1, as all elements 00065 * from set 2 will be decomposed in polygons ; an area verification is done, and 00066 * will signal elements from set 2 that are not "recovered" 00067 * 00068 * the resulting polygons are inserted in output set; total area from output set should be 00069 * equal to total area of elements in set 2 (check that!) 00070 */ 00071 ErrorCode intersect_meshes( EntityHandle mbs1, EntityHandle mbs2, EntityHandle& outputSet ); 00072 00073 /* 00074 * slower intx, use kd tree only, no adjacency, no adv front 00075 */ 00076 ErrorCode intersect_meshes_kdtree( EntityHandle mbset1, EntityHandle mbset2, EntityHandle& outputSet ); 00077 00078 // mark could be (3 or 4, depending on type: ) no, it could go to 10 00079 // no, it will be MAXEDGES = 10 00080 // this is pure abstract, this needs to be implemented by 00081 // all derivations 00082 // the max number of intersection points could be 2*MAXEDGES 00083 // so P must be dimensioned to 4*MAXEDGES (2*2*MAXEDGES) 00084 // so, if you intersect 2 convex polygons with MAXEDGES , you will get a convex polygon 00085 // with 2*MAXEDGES, at most 00086 // will also return the number of nodes of tgt and src elements 00087 virtual ErrorCode computeIntersectionBetweenTgtAndSrc( EntityHandle tgt, 00088 EntityHandle src, 00089 double* P, 00090 int& nP, 00091 double& area, 00092 int markb[MAXEDGES], 00093 int markr[MAXEDGES], 00094 int& nsidesSrc, 00095 int& nsidesTgt, 00096 bool check_boxes_first = false ) = 0; 00097 00098 // this is also abstract 00099 virtual ErrorCode findNodes( EntityHandle tgt, int nsTgt, EntityHandle src, int nsSrc, double* iP, int nP ) = 0; 00100 00101 // this is also computing the area of the tgt cell in plane (gnomonic plane for sphere) 00102 // setting the local variables: 00103 // this will be done once per tgt cell, and once per localQueue for src cells 00104 // const EntityHandle * tgtConn; 00105 // CartVect redCoords[MAXEDGES]; 00106 // double redCoords2D[MAXEDGES2]; // these are in plane 00107 00108 virtual double setup_tgt_cell( EntityHandle tgt, int& nsTgt ) = 0; 00109 00110 virtual ErrorCode FindMaxEdgesInSet( EntityHandle eset, int& max_edges ); 00111 virtual ErrorCode FindMaxEdges( EntityHandle set1, 00112 EntityHandle set2 ); // this needs to be called before any 00113 // covering communication in parallel 00114 00115 virtual ErrorCode createTags(); 00116 00117 ErrorCode DetermineOrderedNeighbors( EntityHandle inputSet, int max_edges, Tag& neighTag ); 00118 00119 void set_error_tolerance( double eps ) 00120 { 00121 epsilon_1 = eps; 00122 epsilon_area = eps * sqrt( eps ); 00123 } 00124 00125 #ifdef MOAB_HAVE_MPI 00126 void set_parallel_comm( moab::ParallelComm* pcomm ) 00127 { 00128 parcomm = pcomm; 00129 } 00130 #endif 00131 // void SetEntityType (EntityType tp) { type=tp;} 00132 00133 // clean some memory allocated 00134 void clean(); 00135 00136 void set_box_error( double berror ) 00137 { 00138 box_error = berror; 00139 } 00140 00141 ErrorCode create_departure_mesh_2nd_alg( EntityHandle& euler_set, EntityHandle& covering_lagr_set ); 00142 00143 // in this method, used in parallel, each departure elements are already created, and at their 00144 // positions the covering_set is output, will contain the departure cells that cover the euler 00145 // set; some of these departure cells might come from different processors so the covering_set 00146 // contains some elements from lagr_set and some elements that come from other procs we need to 00147 // keep track of what processors "sent" the elements so we know were to send back the info about 00148 // the tracers masses 00149 00150 ErrorCode create_departure_mesh_3rd_alg( EntityHandle& lagr_set, EntityHandle& covering_set ); 00151 00152 /* in this method, used in parallel, each cell from first mesh need to be sent to the 00153 * tasks whose second mesh bounding boxes intersects bounding box of the cell 00154 * this method assumes that the bounding boxes for the second mesh were computed already in a 00155 * previous method (called build_processor_euler_boxes) 00156 * 00157 * the covering_set is output, will cover the second mesh (set) from the task; 00158 * Some of the cells in the first mesh will be sent to multiple processors; we keep track of 00159 * them using the global id of the vertices and global ids of the cells (we do not want to 00160 * create multiple vertices with the same ids). The global id of the cells are needed just for 00161 * debugging, the cells cannot come from 2 different tasks, but the vertices can 00162 * 00163 * Right now, we use crystal router, but an improvement might be to use direct communication 00164 * (send_entities) on parallel comm 00165 * 00166 * param initial_distributed_set (IN) : the initial distribution of the first mesh (set) 00167 * 00168 * param (OUT) : the covering set in first mesh , which completely covers the second mesh set 00169 */ 00170 #ifdef MOAB_HAVE_MPI 00171 00172 virtual ErrorCode build_processor_euler_boxes( EntityHandle euler_set, Range& local_verts ); 00173 #endif 00174 void correct_polygon( EntityHandle* foundIds, int& nP ); 00175 #ifdef MOAB_HAVE_MPI 00176 // share vertices between the intersection target domains 00177 ErrorCode resolve_intersection_sharing(); 00178 #endif 00179 #ifdef ENABLE_DEBUG 00180 void enable_debug() 00181 { 00182 dbg_1 = 1; 00183 } 00184 void disable_debug() 00185 { 00186 dbg_1 = 0; 00187 } 00188 #endif 00189 00190 #ifdef MOAB_HAVE_TEMPESTREMAP 00191 friend class TempestRemapper; 00192 #endif 00193 00194 protected: // so it can be accessed in derived classes, InPlane and OnSphere 00195 Interface* mb; 00196 00197 EntityHandle mbs1; 00198 EntityHandle mbs2; 00199 Range rs1; // range set 1 (departure set, lagrange set, src set, manufactured set, target mesh) 00200 Range rs2; // range set 2 (arrival set, euler set, tgt set, initial set, source mesh) 00201 00202 EntityHandle outSet; // will contain intersection 00203 Tag gid; // global id tag will be used to set the parents of the intersection cell 00204 00205 // tags used in computation, advancing front 00206 Tag TgtFlagTag; // to mark tgt quads already considered 00207 00208 Range TgtEdges; // 00209 00210 // tgt parent and src parent tags 00211 // these will be on the out mesh 00212 Tag tgtParentTag; 00213 Tag srcParentTag; 00214 Tag countTag; 00215 00216 Tag srcNeighTag; // will store neighbors for navigating easily in advancing front, for first 00217 // mesh (src, target, lagrange) 00218 Tag tgtNeighTag; // will store neighbors for navigating easily in advancing front, for second 00219 // mesh (tgt, source, euler) 00220 00221 Tag neighTgtEdgeTag; // will store edge borders for each tgt cell 00222 00223 Tag orgSendProcTag; /// for coverage mesh, will store the original sender 00224 00225 // EntityType type; // this will be tri, quad or MBPOLYGON... 00226 00227 const EntityHandle* tgtConn; 00228 const EntityHandle* srcConn; 00229 CartVect tgtCoords[MAXEDGES]; 00230 CartVect srcCoords[MAXEDGES]; 00231 double tgtCoords2D[MAXEDGES2]; // these are in plane 00232 double srcCoords2D[MAXEDGES2]; // these are in plane 00233 00234 #ifdef ENABLE_DEBUG 00235 static int dbg_1; 00236 std::ofstream mout_1[6]; // some debug files 00237 #endif 00238 // for each tgt edge, we keep a vector of extra nodes, coming from intersections 00239 // use the index in TgtEdges range 00240 // so the extra nodes on each tgt edge are kept track of 00241 // only entity handles are in the vector, not the actual coordinates; 00242 // actual coordinates are retrieved every time, which could be expensive 00243 // maybe we should store the coordinates too, along with entity handles (more memory used, 00244 // faster to retrieve) 00245 std::vector< std::vector< EntityHandle >* > extraNodesVec; 00246 00247 double epsilon_1; 00248 double epsilon_area; 00249 00250 std::vector< double > allBoxes; 00251 double box_error; 00252 /* \brief Local root of the kdtree */ 00253 EntityHandle localRoot; 00254 Range localEnts; // this range is for local elements of interest, euler cells, or "first mesh" 00255 unsigned int my_rank; 00256 00257 #ifdef MOAB_HAVE_MPI 00258 ParallelComm* parcomm; 00259 TupleList* remote_cells; // not used anymore for communication, just a container 00260 TupleList* remote_cells_with_tracers; // these will be used now to update tracers on remote procs 00261 std::map< int, EntityHandle > globalID_to_eh; // needed for parallel, mostly 00262 #endif 00263 int max_edges_1; // maximum number of edges in the lagrange set (first set, src) 00264 int max_edges_2; // maximum number of edges in the euler set (second set, tgt) 00265 int counting; 00266 }; 00267 00268 } /* namespace moab */ 00269 #endif /* INTX2MESH_HPP_ */
