Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef LINEAR_TET_HPP 00002 #define LINEAR_TET_HPP 00003 /**\brief Shape function space for trilinear tetrahedron, obtained by a pushforward of the canonical 00004 * linear (affine) functions. */ 00005 00006 #include "moab/ElemEvaluator.hpp" 00007 #include "moab/CN.hpp" 00008 00009 namespace moab 00010 { 00011 00012 class LinearTet 00013 { 00014 public: 00015 /** \brief Forward-evaluation of field at parametric coordinates */ 00016 static ErrorCode evalFcn( const double* params, 00017 const double* field, 00018 const int ndim, 00019 const int num_tuples, 00020 double* work, 00021 double* result ); 00022 00023 /** \brief Reverse-evaluation of parametric coordinates at physical space position */ 00024 static ErrorCode reverseEvalFcn( EvalFcn eval, 00025 JacobianFcn jacob, 00026 InsideFcn ins, 00027 const double* posn, 00028 const double* verts, 00029 const int nverts, 00030 const int ndim, 00031 const double iter_tol, 00032 const double inside_tol, 00033 double* work, 00034 double* params, 00035 int* is_inside ); 00036 00037 /** \brief Evaluate the normal at a specified facet*/ 00038 static ErrorCode normalFcn( const int ientDim, 00039 const int facet, 00040 const int nverts, 00041 const double* verts, 00042 double normal[] ); 00043 00044 /** \brief Evaluate the jacobian at a specified parametric position */ 00045 static ErrorCode jacobianFcn( const double* params, 00046 const double* verts, 00047 const int nverts, 00048 const int ndim, 00049 double* work, 00050 double* result ); 00051 00052 /** \brief Forward-evaluation of field at parametric coordinates */ 00053 static ErrorCode integrateFcn( const double* field, 00054 const double* verts, 00055 const int nverts, 00056 const int ndim, 00057 const int num_tuples, 00058 double* work, 00059 double* result ); 00060 00061 /** \brief Initialize this EvalSet */ 00062 static ErrorCode initFcn( const double* verts, const int nverts, double*& work ); 00063 00064 /** \brief Function that returns whether or not the parameters are inside the natural space of 00065 * the element */ 00066 static int insideFcn( const double* params, const int ndim, const double tol ); 00067 00068 static ErrorCode evaluate_reverse( EvalFcn eval, 00069 JacobianFcn jacob, 00070 InsideFcn inside_f, 00071 const double* posn, 00072 const double* verts, 00073 const int nverts, 00074 const int ndim, 00075 const double iter_tol, 00076 const double inside_tol, 00077 double* work, 00078 double* params, 00079 int* inside ); 00080 00081 static EvalSet eval_set() 00082 { 00083 return EvalSet( evalFcn, reverseEvalFcn, normalFcn, jacobianFcn, integrateFcn, initFcn, insideFcn ); 00084 } 00085 00086 static bool compatible( EntityType tp, int numv, EvalSet& eset ) 00087 { 00088 if( tp == MBTET && numv >= 4 ) 00089 { 00090 eset = eval_set(); 00091 return true; 00092 } 00093 else 00094 return false; 00095 } 00096 00097 protected: 00098 static const double corner[4][3]; 00099 }; // class LinearTet 00100 00101 } // namespace moab 00102 00103 #endif
