Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * ParCommGraph.cpp 00003 * 00004 */ 00005 00006 #include "moab/ParCommGraph.hpp" 00007 // we need to recompute adjacencies for merging to work 00008 #include "moab/Core.hpp" 00009 #include "AEntityFactory.hpp" 00010 00011 #ifdef MOAB_HAVE_ZOLTAN 00012 #include "moab/ZoltanPartitioner.hpp" 00013 #endif 00014 00015 // #define VERBOSE 00016 // #define GRAPH_INFO 00017 00018 namespace moab 00019 { 00020 ParCommGraph::ParCommGraph( MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, int coid2 ) 00021 : comm( joincomm ), compid1( coid1 ), compid2( coid2 ) 00022 { 00023 // find out the tasks from each group, in the joint communicator 00024 find_group_ranks( group1, comm, senderTasks ); 00025 find_group_ranks( group2, comm, receiverTasks ); 00026 00027 rootSender = rootReceiver = false; 00028 rankInGroup1 = rankInGroup2 = rankInJoin = -1; // not initialized, or not part of the group 00029 00030 int mpierr = MPI_Group_rank( group1, &rankInGroup1 ); 00031 if( MPI_SUCCESS != mpierr || rankInGroup1 == MPI_UNDEFINED ) rankInGroup1 = -1; 00032 00033 mpierr = MPI_Group_rank( group2, &rankInGroup2 ); 00034 if( MPI_SUCCESS != mpierr || rankInGroup2 == MPI_UNDEFINED ) rankInGroup2 = -1; 00035 00036 mpierr = MPI_Comm_rank( comm, &rankInJoin ); 00037 if( MPI_SUCCESS != mpierr ) // it should be a fatal error 00038 rankInJoin = -1; 00039 00040 mpierr = MPI_Comm_size( comm, &joinSize ); 00041 if( MPI_SUCCESS != mpierr ) // it should be a fatal error 00042 joinSize = -1; 00043 00044 if( 0 == rankInGroup1 ) rootSender = true; 00045 if( 0 == rankInGroup2 ) rootReceiver = true; 00046 graph_type = INITIAL_MIGRATE; // 0 00047 context_id = -1; 00048 cover_set = 0; // refers to nothing yet 00049 } 00050 00051 // copy constructor will copy only few basic things; split ranges will not be copied 00052 ParCommGraph::ParCommGraph( const ParCommGraph& src ) 00053 { 00054 comm = src.comm; 00055 senderTasks = src.senderTasks; // these are the sender tasks in joint comm 00056 receiverTasks = src.receiverTasks; // these are all the receiver tasks in joint comm 00057 rootSender = src.rootSender; 00058 rootReceiver = src.rootReceiver; 00059 rankInGroup1 = src.rankInGroup1; 00060 rankInGroup2 = src.rankInGroup2; // group 1 is sender, 2 is receiver 00061 rankInJoin = src.rankInJoin; 00062 joinSize = src.joinSize; 00063 compid1 = src.compid1; 00064 compid2 = src.compid2; 00065 graph_type = src.graph_type; 00066 context_id = src.context_id; 00067 cover_set = src.cover_set; 00068 return; 00069 } 00070 00071 ParCommGraph::~ParCommGraph() 00072 { 00073 // TODO Auto-generated destructor stub 00074 } 00075 00076 // utility to find out the ranks of the processes of a group, with respect to a joint comm, 00077 // which spans for sure the group 00078 // it is used locally (in the constructor), but it can be used as a utility 00079 void ParCommGraph::find_group_ranks( MPI_Group group, MPI_Comm joincomm, std::vector< int >& ranks ) 00080 { 00081 MPI_Group global_grp; 00082 MPI_Comm_group( joincomm, &global_grp ); 00083 00084 int grp_size; 00085 00086 MPI_Group_size( group, &grp_size ); 00087 std::vector< int > rks( grp_size ); 00088 ranks.resize( grp_size ); 00089 00090 for( int i = 0; i < grp_size; i++ ) 00091 rks[i] = i; 00092 00093 MPI_Group_translate_ranks( group, grp_size, &rks[0], global_grp, &ranks[0] ); 00094 MPI_Group_free( &global_grp ); 00095 return; 00096 } 00097 00098 ErrorCode ParCommGraph::compute_trivial_partition( std::vector< int >& numElemsPerTaskInGroup1 ) 00099 { 00100 00101 recv_graph.clear(); 00102 recv_sizes.clear(); 00103 sender_graph.clear(); 00104 sender_sizes.clear(); 00105 00106 if( numElemsPerTaskInGroup1.size() != senderTasks.size() ) 00107 return MB_FAILURE; // each sender has a number of elements that it owns 00108 00109 // first find out total number of elements to be sent from all senders 00110 int total_elems = 0; 00111 std::vector< int > accum; 00112 accum.push_back( 0 ); 00113 00114 int num_senders = (int)senderTasks.size(); 00115 00116 for( size_t k = 0; k < numElemsPerTaskInGroup1.size(); k++ ) 00117 { 00118 total_elems += numElemsPerTaskInGroup1[k]; 00119 accum.push_back( total_elems ); 00120 } 00121 00122 int num_recv = ( (int)receiverTasks.size() ); 00123 // in trivial partition, every receiver should get about total_elems/num_receivers elements 00124 int num_per_receiver = (int)( total_elems / num_recv ); 00125 int leftover = total_elems - num_per_receiver * num_recv; 00126 00127 // so receiver k will receive [starts[k], starts[k+1] ) interval 00128 std::vector< int > starts; 00129 starts.resize( num_recv + 1 ); 00130 starts[0] = 0; 00131 for( int k = 0; k < num_recv; k++ ) 00132 { 00133 starts[k + 1] = starts[k] + num_per_receiver; 00134 if( k < leftover ) starts[k + 1]++; 00135 } 00136 00137 // each sender will send to a number of receivers, based on how the 00138 // arrays starts[0:num_recv] and accum[0:sendr] overlap 00139 int lastUsedReceiverRank = 0; // first receiver was not treated yet 00140 for( int j = 0; j < num_senders; j++ ) 00141 { 00142 // we could start the receiver loop with the latest receiver that received from previous 00143 // sender 00144 for( int k = lastUsedReceiverRank; k < num_recv; k++ ) 00145 { 00146 // if overlap: 00147 if( starts[k] < accum[j + 1] && starts[k + 1] > accum[j] ) 00148 { 00149 recv_graph[receiverTasks[k]].push_back( senderTasks[j] ); 00150 sender_graph[senderTasks[j]].push_back( receiverTasks[k] ); 00151 00152 // we still need to decide what is the overlap 00153 int sizeOverlap = 1; // at least 1, for sure 00154 // 1 00155 if( starts[k] >= accum[j] ) // one end is starts[k] 00156 { 00157 if( starts[k + 1] >= accum[j + 1] ) // the other end is accum[j+1] 00158 sizeOverlap = accum[j + 1] - starts[k]; 00159 else // 00160 sizeOverlap = starts[k + 1] - starts[k]; 00161 } 00162 else // one end is accum[j] 00163 { 00164 if( starts[k + 1] >= accum[j + 1] ) // the other end is accum[j+1] 00165 sizeOverlap = accum[j + 1] - accum[j]; 00166 else 00167 sizeOverlap = starts[k + 1] - accum[j]; 00168 } 00169 recv_sizes[receiverTasks[k]].push_back( sizeOverlap ); // basically, task k will receive from 00170 // sender j, sizeOverlap elems 00171 sender_sizes[senderTasks[j]].push_back( sizeOverlap ); 00172 if( starts[k] > accum[j + 1] ) 00173 { 00174 lastUsedReceiverRank = k - 1; // so next k loop will start a little higher, we 00175 // probably finished with first few receivers (up 00176 // to receiver lastUsedReceiverRank) 00177 break; // break the k loop, we distributed all elements from sender j to some 00178 // receivers 00179 } 00180 } 00181 } 00182 } 00183 00184 return MB_SUCCESS; 00185 } 00186 00187 ErrorCode ParCommGraph::pack_receivers_graph( std::vector< int >& packed_recv_array ) 00188 { 00189 // it will basically look at local data, to pack communication graph, each receiver task will 00190 // have to post receives for each sender task that will send data to it; the array will be 00191 // communicated to root receiver, and eventually distributed to receiver tasks 00192 00193 /* 00194 * packed_array will have receiver, number of senders, then senders, etc 00195 */ 00196 if( recv_graph.size() < receiverTasks.size() ) 00197 { 00198 // big problem, we have empty partitions in receive 00199 std::cout << " WARNING: empty partitions, some receiver tasks will receive nothing.\n"; 00200 } 00201 for( std::map< int, std::vector< int > >::iterator it = recv_graph.begin(); it != recv_graph.end(); it++ ) 00202 { 00203 int recv = it->first; 00204 std::vector< int >& senders = it->second; 00205 packed_recv_array.push_back( recv ); 00206 packed_recv_array.push_back( (int)senders.size() ); 00207 00208 for( int k = 0; k < (int)senders.size(); k++ ) 00209 packed_recv_array.push_back( senders[k] ); 00210 } 00211 00212 return MB_SUCCESS; 00213 } 00214 00215 ErrorCode ParCommGraph::split_owned_range( int sender_rank, Range& owned ) 00216 { 00217 int senderTask = senderTasks[sender_rank]; 00218 std::vector< int >& distribution = sender_sizes[senderTask]; 00219 std::vector< int >& receivers = sender_graph[senderTask]; 00220 if( distribution.size() != receivers.size() ) // 00221 return MB_FAILURE; 00222 00223 Range current = owned; // get the full range first, then we will subtract stuff, for 00224 // the following ranges 00225 00226 Range rleftover = current; 00227 for( size_t k = 0; k < receivers.size(); k++ ) 00228 { 00229 Range newr; 00230 newr.insert( current.begin(), current.begin() + distribution[k] ); 00231 split_ranges[receivers[k]] = newr; 00232 00233 rleftover = subtract( current, newr ); 00234 current = rleftover; 00235 } 00236 00237 return MB_SUCCESS; 00238 } 00239 00240 // use for this the corresponding tasks and sizes 00241 ErrorCode ParCommGraph::split_owned_range( Range& owned ) 00242 { 00243 if( corr_tasks.size() != corr_sizes.size() ) // 00244 return MB_FAILURE; 00245 00246 Range current = owned; // get the full range first, then we will subtract stuff, for 00247 // the following ranges 00248 00249 Range rleftover = current; 00250 for( size_t k = 0; k < corr_tasks.size(); k++ ) 00251 { 00252 Range newr; 00253 newr.insert( current.begin(), current.begin() + corr_sizes[k] ); 00254 split_ranges[corr_tasks[k]] = newr; 00255 00256 rleftover = subtract( current, newr ); 00257 current = rleftover; 00258 } 00259 00260 return MB_SUCCESS; 00261 } 00262 00263 ErrorCode ParCommGraph::send_graph( MPI_Comm jcomm, std::vector< char >& zoltanBuffer ) 00264 { 00265 if( is_root_sender() ) 00266 { 00267 int ierr; 00268 // will need to build a communication graph, because each sender knows now to which receiver 00269 // to send data the receivers need to post receives for each sender that will send data to 00270 // them will need to gather on rank 0 on the sender comm, global ranks of sender with 00271 // receivers to send build communication matrix, each receiver will receive from what sender 00272 00273 std::vector< int > packed_recv_array; 00274 ErrorCode rval = pack_receivers_graph( packed_recv_array ); 00275 if( MB_SUCCESS != rval ) return rval; 00276 00277 int size_pack_array = (int)packed_recv_array.size() + 1; 00278 // the last integer 00279 // will signal if we have to send zoltan buffer too, in a separate message 0 for no, 1 for yes 00280 comm_graph = packed_recv_array; 00281 comm_graph.resize( size_pack_array ); // bigger by 1, to store the semaphore about zBuff 00282 // will add 1 or 2 requests; first one with comm graph, second with zoltan buffer if needed 00283 if( zoltanBuffer.size() > 0 ) 00284 { 00285 sendReqs.resize( 2 ); 00286 comm_graph[size_pack_array - 1] = 1; // send zoltanBuffer too :) 00287 zBuff = zoltanBuffer; // do a deep copy here, because the zoltanBuffer will go out of scope, and 00288 // we need to keep the sent buffer, after the non-blocking sent is executed; thanks Karen Devine ! 00289 } 00290 else 00291 { 00292 sendReqs.resize( 1 ); 00293 comm_graph[size_pack_array - 1] = 0; // do not send zoltan buffer 00294 } 00295 // we have to use global communicator if (ierr!=0) return MB_FAILURE;*/ 00296 ierr = MPI_Isend( &comm_graph[0], size_pack_array, MPI_INT, receiver( 0 ), 20, jcomm, 00297 &sendReqs[0] ); // we have to use global communicator 00298 if( ierr != 0 ) return MB_FAILURE; 00299 if( zBuff.size() > 0 ) 00300 { 00301 ierr = MPI_Isend( &zBuff[0], (int)zBuff.size(), MPI_CHAR, receiver( 0 ), 30, jcomm, 00302 &sendReqs[1] ); // we have to use global communicator 00303 if( ierr != 0 ) return MB_FAILURE; 00304 } 00305 } 00306 return MB_SUCCESS; 00307 } 00308 00309 // pco has MOAB too get_moab() 00310 // do we need to store "method" as a member variable ? 00311 ErrorCode ParCommGraph::send_mesh_parts( MPI_Comm jcomm, ParallelComm* pco, Range& owned ) 00312 { 00313 00314 ErrorCode rval; 00315 if( split_ranges.empty() ) // in trivial partition 00316 { 00317 rval = split_owned_range( rankInGroup1, owned ); 00318 if( rval != MB_SUCCESS ) return rval; 00319 // we know this on the sender side: 00320 corr_tasks = sender_graph[senderTasks[rankInGroup1]]; // copy 00321 corr_sizes = sender_sizes[senderTasks[rankInGroup1]]; // another copy 00322 } 00323 00324 int indexReq = 0; 00325 int ierr; // MPI error 00326 if( is_root_sender() ) indexReq = (int)sendReqs.size(); // we could have 1 or 2 MPI_Request's already 00327 sendReqs.resize( indexReq + split_ranges.size() ); 00328 for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ ) 00329 { 00330 int receiver_proc = it->first; 00331 Range ents = it->second; 00332 00333 // add necessary vertices too 00334 Range verts; 00335 rval = pco->get_moab()->get_adjacencies( ents, 0, false, verts, Interface::UNION ); 00336 if( rval != MB_SUCCESS ) 00337 { 00338 std::cout << " can't get adjacencies. for entities to send\n"; 00339 return rval; 00340 } 00341 ents.merge( verts ); 00342 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( ParallelComm::INITIAL_BUFF_SIZE ); 00343 buffer->reset_ptr( sizeof( int ) ); 00344 rval = pco->pack_buffer( ents, false, true, false, -1, buffer ); 00345 if( rval != MB_SUCCESS ) 00346 { 00347 std::cout << " can't pack buffer for entities to send\n"; 00348 return rval; 00349 } 00350 int size_pack = buffer->get_current_size(); 00351 00352 // TODO there could be an issue with endian things; check !!!!! 00353 // we are sending the size of the buffer first as an int!!! 00354 /// not anymore ! 00355 /* ierr = MPI_Isend(buffer->mem_ptr, 1, MPI_INT, receiver_proc, 1, jcomm, 00356 &sendReqs[indexReq]); // we have to use global communicator if (ierr!=0) return MB_FAILURE; 00357 indexReq++;*/ 00358 00359 ierr = MPI_Isend( buffer->mem_ptr, size_pack, MPI_CHAR, receiver_proc, 2, jcomm, 00360 &sendReqs[indexReq] ); // we have to use global communicator 00361 if( ierr != 0 ) return MB_FAILURE; 00362 indexReq++; 00363 localSendBuffs.push_back( 00364 buffer ); // these buffers will be cleared only after all MPI_Request's have been waited upon 00365 } 00366 return MB_SUCCESS; 00367 } 00368 00369 // this is called on receiver side 00370 ErrorCode ParCommGraph::receive_comm_graph( MPI_Comm jcomm, 00371 ParallelComm* pco, 00372 std::vector< int >& pack_array, 00373 std::vector< char >& zoltanBuffer ) 00374 { 00375 // first, receive from sender_rank 0, the communication graph (matrix), so each receiver 00376 // knows what data to expect 00377 MPI_Comm receive = pco->comm(); 00378 int size_pack_array, ierr; 00379 MPI_Status status; 00380 if( rootReceiver ) 00381 { 00382 ierr = MPI_Probe( sender( 0 ), 20, jcomm, &status ); 00383 if( 0 != ierr ) 00384 { 00385 std::cout << " MPI_Probe failure: " << ierr << "\n"; 00386 return MB_FAILURE; 00387 } 00388 // get the count of data received from the MPI_Status structure 00389 ierr = MPI_Get_count( &status, MPI_INT, &size_pack_array ); 00390 if( 0 != ierr ) 00391 { 00392 std::cout << " MPI_Get_count failure: " << ierr << "\n"; 00393 return MB_FAILURE; 00394 } 00395 #ifdef VERBOSE 00396 std::cout << " receive comm graph size: " << size_pack_array << "\n"; 00397 #endif 00398 pack_array.resize( size_pack_array ); 00399 ierr = MPI_Recv( &pack_array[0], size_pack_array, MPI_INT, sender( 0 ), 20, jcomm, &status ); 00400 if( 0 != ierr ) return MB_FAILURE; 00401 #ifdef VERBOSE 00402 std::cout << " receive comm graph "; 00403 for( int k = 0; k < (int)pack_array.size(); k++ ) 00404 std::cout << " " << pack_array[k]; 00405 std::cout << "\n"; 00406 #endif 00407 // the last int tells if we have another receive to do or not (for zoltan buffer) 00408 // look at the last value, to see if we receive zoltan buffer or not 00409 int semaphore = pack_array[size_pack_array - 1]; 00410 if( 1 == semaphore ) 00411 { 00412 // expect zoltanBuffer, the difference is the tag; we still need the joint comm 00413 // the buffer was sent with a nonblocking send, from the root sender 00414 ierr = MPI_Probe( sender( 0 ), 30, jcomm, &status ); // blocking call, to get size 00415 if( 0 != ierr ) 00416 { 00417 std::cout << " MPI_Probe failure: " << ierr << "\n"; 00418 return MB_FAILURE; 00419 } 00420 int incoming_msg_size; 00421 MPI_Get_count( &status, MPI_CHAR, &incoming_msg_size ); 00422 zoltanBuffer.resize( incoming_msg_size ); 00423 ierr = MPI_Recv( &zoltanBuffer[0], incoming_msg_size, MPI_CHAR, sender( 0 ), 30, jcomm, &status ); 00424 if( 0 != ierr ) 00425 { 00426 std::cout << " MPI_Recv failure: " << ierr << "\n"; 00427 return MB_FAILURE; 00428 } 00429 } 00430 } 00431 00432 // now broadcast this whole array to all receivers, so they know what to expect 00433 ierr = MPI_Bcast( &size_pack_array, 1, MPI_INT, 0, receive ); 00434 if( 0 != ierr ) return MB_FAILURE; 00435 pack_array.resize( size_pack_array ); 00436 ierr = MPI_Bcast( &pack_array[0], size_pack_array, MPI_INT, 0, receive ); 00437 if( 0 != ierr ) return MB_FAILURE; 00438 return MB_SUCCESS; 00439 } 00440 00441 ErrorCode ParCommGraph::receive_mesh( MPI_Comm jcomm, 00442 ParallelComm* pco, 00443 EntityHandle local_set, 00444 std::vector< int >& senders_local ) 00445 { 00446 ErrorCode rval; 00447 int ierr; 00448 MPI_Status status; 00449 // we also need to fill corresponding mesh info on the other side 00450 corr_tasks = senders_local; 00451 Range newEnts; 00452 00453 Tag orgSendProcTag; // this will be a tag set on the received mesh, with info about from what 00454 // task / PE the 00455 // primary element came from, in the joint communicator ; this will be forwarded by coverage 00456 // mesh 00457 int defaultInt = -1; // no processor, so it was not migrated from somewhere else 00458 rval = pco->get_moab()->tag_get_handle( "orig_sending_processor", 1, MB_TYPE_INTEGER, orgSendProcTag, 00459 MB_TAG_DENSE | MB_TAG_CREAT, &defaultInt );MB_CHK_SET_ERR( rval, "can't create original sending processor tag" ); 00460 if( !senders_local.empty() ) 00461 { 00462 for( size_t k = 0; k < senders_local.size(); k++ ) 00463 { 00464 int sender1 = senders_local[k]; 00465 // first receive the size of the buffer using probe 00466 /* 00467 * MPI_Probe( 00468 int source, 00469 int tag, 00470 MPI_Comm comm, 00471 MPI_Status* status) 00472 * 00473 */ 00474 ierr = MPI_Probe( sender1, 2, jcomm, &status ); 00475 if( 0 != ierr ) 00476 { 00477 std::cout << " MPI_Probe failure in ParCommGraph::receive_mesh " << ierr << "\n"; 00478 return MB_FAILURE; 00479 } 00480 // get the count of data received from the MPI_Status structure 00481 int size_pack; 00482 ierr = MPI_Get_count( &status, MPI_CHAR, &size_pack ); 00483 if( 0 != ierr ) 00484 { 00485 std::cout << " MPI_Get_count failure in ParCommGraph::receive_mesh " << ierr << "\n"; 00486 return MB_FAILURE; 00487 } 00488 00489 /* ierr = MPI_Recv (&size_pack, 1, MPI_INT, sender1, 1, jcomm, &status); 00490 if (0!=ierr) return MB_FAILURE;*/ 00491 // now resize the buffer, then receive it 00492 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_pack ); 00493 // buffer->reserve(size_pack); 00494 00495 ierr = MPI_Recv( buffer->mem_ptr, size_pack, MPI_CHAR, sender1, 2, jcomm, &status ); 00496 if( 0 != ierr ) 00497 { 00498 std::cout << " MPI_Recv failure in ParCommGraph::receive_mesh " << ierr << "\n"; 00499 return MB_FAILURE; 00500 } 00501 // now unpack the buffer we just received 00502 Range entities; 00503 std::vector< std::vector< EntityHandle > > L1hloc, L1hrem; 00504 std::vector< std::vector< int > > L1p; 00505 std::vector< EntityHandle > L2hloc, L2hrem; 00506 std::vector< unsigned int > L2p; 00507 00508 buffer->reset_ptr( sizeof( int ) ); 00509 std::vector< EntityHandle > entities_vec( entities.size() ); 00510 std::copy( entities.begin(), entities.end(), entities_vec.begin() ); 00511 rval = pco->unpack_buffer( buffer->buff_ptr, false, -1, -1, L1hloc, L1hrem, L1p, L2hloc, L2hrem, L2p, 00512 entities_vec ); 00513 delete buffer; 00514 if( MB_SUCCESS != rval ) return rval; 00515 00516 std::copy( entities_vec.begin(), entities_vec.end(), range_inserter( entities ) ); 00517 // we have to add them to the local set 00518 rval = pco->get_moab()->add_entities( local_set, entities ); 00519 if( MB_SUCCESS != rval ) return rval; 00520 // corr_sizes is the size of primary entities received 00521 Range verts = entities.subset_by_dimension( 0 ); 00522 Range local_primary_ents = subtract( entities, verts ); 00523 if( local_primary_ents.empty() ) 00524 { 00525 // it is possible that all ents sent were vertices (point cloud) 00526 // then consider primary entities the vertices 00527 local_primary_ents = verts; 00528 } 00529 else 00530 { 00531 // set a tag with the original sender for the primary entity 00532 // will be used later for coverage mesh 00533 std::vector< int > orig_senders( local_primary_ents.size(), sender1 ); 00534 rval = pco->get_moab()->tag_set_data( orgSendProcTag, local_primary_ents, &orig_senders[0] ); 00535 } 00536 corr_sizes.push_back( (int)local_primary_ents.size() ); 00537 00538 newEnts.merge( entities ); 00539 // make these in split ranges 00540 split_ranges[sender1] = local_primary_ents; 00541 00542 #ifdef VERBOSE 00543 std::ostringstream partial_outFile; 00544 00545 partial_outFile << "part_send_" << sender1 << "." 00546 << "recv" << rankInJoin << ".vtk"; 00547 00548 // the mesh contains ghosts too, but they are not part of mat/neumann set 00549 // write in serial the file, to see what tags are missing 00550 std::cout << " writing from receiver " << rankInJoin << " from sender " << sender1 00551 << " entities: " << entities.size() << std::endl; 00552 rval = pco->get_moab()->write_file( partial_outFile.str().c_str(), 0, 0, &local_set, 00553 1 ); // everything on local set received 00554 if( MB_SUCCESS != rval ) return rval; 00555 #endif 00556 } 00557 } 00558 // make sure adjacencies are updated on the new elements 00559 00560 if( newEnts.empty() ) 00561 { 00562 std::cout << "task:" << rankInGroup2 << " in receiver did not receive any entities \n"; 00563 } 00564 else 00565 { 00566 // in order for the merging to work, we need to be sure that the adjacencies are updated 00567 // (created) 00568 Range local_verts = newEnts.subset_by_type( MBVERTEX ); 00569 newEnts = subtract( newEnts, local_verts ); 00570 Core* mb = (Core*)pco->get_moab(); 00571 AEntityFactory* adj_fact = mb->a_entity_factory(); 00572 if( !adj_fact->vert_elem_adjacencies() ) 00573 adj_fact->create_vert_elem_adjacencies(); 00574 else 00575 { 00576 for( Range::iterator it = newEnts.begin(); it != newEnts.end(); ++it ) 00577 { 00578 EntityHandle eh = *it; 00579 const EntityHandle* conn = NULL; 00580 int num_nodes = 0; 00581 rval = mb->get_connectivity( eh, conn, num_nodes ); 00582 if( MB_SUCCESS != rval ) return rval; 00583 adj_fact->notify_create_entity( eh, conn, num_nodes ); 00584 } 00585 } 00586 } 00587 return MB_SUCCESS; 00588 } 00589 00590 // VSM: Why is the communicator never used. Remove the argument ? 00591 ErrorCode ParCommGraph::release_send_buffers() 00592 { 00593 int ierr, nsize = (int)sendReqs.size(); 00594 std::vector< MPI_Status > mult_status; 00595 mult_status.resize( sendReqs.size() ); 00596 ierr = MPI_Waitall( nsize, &sendReqs[0], &mult_status[0] ); 00597 00598 if( ierr != 0 ) return MB_FAILURE; 00599 // now we can free all buffers 00600 comm_graph.clear(); 00601 zBuff.clear(); // this is for zoltan buffer, it will be used only when sending the 00602 // the RCB tree from component (sender) root to coupler (receiver) root 00603 std::vector< ParallelComm::Buffer* >::iterator vit; 00604 for( vit = localSendBuffs.begin(); vit != localSendBuffs.end(); ++vit ) 00605 delete( *vit ); 00606 localSendBuffs.clear(); 00607 return MB_SUCCESS; 00608 } 00609 00610 // again, will use the send buffers, for nonblocking sends; 00611 // should be the receives non-blocking too? 00612 ErrorCode ParCommGraph::send_tag_values( MPI_Comm jcomm, 00613 ParallelComm* pco, 00614 Range& owned, 00615 std::vector< Tag >& tag_handles ) 00616 { 00617 // basically, owned.size() needs to be equal to sum(corr_sizes) 00618 // get info about the tag size, type, etc 00619 int ierr; 00620 Core* mb = (Core*)pco->get_moab(); 00621 // get info about the tag 00622 //! Get the size of the specified tag in bytes 00623 int total_bytes_per_entity = 0; // we need to know, to allocate buffers 00624 ErrorCode rval; 00625 std::vector< int > vect_bytes_per_tag; 00626 #ifdef VERBOSE 00627 std::vector< int > tag_sizes; 00628 #endif 00629 for( size_t i = 0; i < tag_handles.size(); i++ ) 00630 { 00631 int bytes_per_tag; 00632 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00633 int tag_size1; // length 00634 rval = mb->tag_get_length( tag_handles[i], tag_size1 );MB_CHK_ERR( rval ); 00635 if( graph_type == DOF_BASED ) 00636 bytes_per_tag = bytes_per_tag / tag_size1; // we know we have one double per tag , per ID sent; 00637 // could be 8 for double, 4 for int, etc 00638 total_bytes_per_entity += bytes_per_tag; 00639 vect_bytes_per_tag.push_back( bytes_per_tag ); 00640 #ifdef VERBOSE 00641 int tag_size; 00642 rval = mb->tag_get_length( tag_handles[i], tag_size );MB_CHK_ERR( rval ); 00643 tag_sizes.push_back( tag_size ); 00644 #endif 00645 } 00646 00647 int indexReq = 0; 00648 if( graph_type == INITIAL_MIGRATE ) // original send 00649 { 00650 // use the buffers data structure to allocate memory for sending the tags 00651 sendReqs.resize( split_ranges.size() ); 00652 00653 for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ ) 00654 { 00655 int receiver_proc = it->first; 00656 Range ents = it->second; // primary entities, with the tag data 00657 int size_buffer = 4 + total_bytes_per_entity * 00658 (int)ents.size(); // hopefully, below 2B; if more, we have a big problem ... 00659 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00660 00661 buffer->reset_ptr( sizeof( int ) ); 00662 for( size_t i = 0; i < tag_handles.size(); i++ ) 00663 { 00664 // copy tag data to buffer->buff_ptr, and send the buffer (we could have used 00665 // regular char arrays) 00666 rval = mb->tag_get_data( tag_handles[i], ents, (void*)( buffer->buff_ptr ) );MB_CHK_ERR( rval ); 00667 // advance the butter 00668 buffer->buff_ptr += vect_bytes_per_tag[i] * ents.size(); 00669 } 00670 *( (int*)buffer->mem_ptr ) = size_buffer; 00671 // int size_pack = buffer->get_current_size(); // debug check 00672 ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm, 00673 &sendReqs[indexReq] ); // we have to use global communicator 00674 if( ierr != 0 ) return MB_FAILURE; 00675 indexReq++; 00676 localSendBuffs.push_back( buffer ); // we will release them after nonblocking sends are completed 00677 } 00678 } 00679 else if( graph_type == COVERAGE ) 00680 { 00681 // we know that we will need to send some tag data in a specific order 00682 // first, get the ids of the local elements, from owned Range; arrange the buffer in order 00683 // of increasing global id 00684 Tag gidTag = mb->globalId_tag(); 00685 std::vector< int > gids; 00686 gids.resize( owned.size() ); 00687 rval = mb->tag_get_data( gidTag, owned, &gids[0] );MB_CHK_ERR( rval ); 00688 std::map< int, EntityHandle > gidToHandle; 00689 size_t i = 0; 00690 for( Range::iterator it = owned.begin(); it != owned.end(); it++ ) 00691 { 00692 EntityHandle eh = *it; 00693 gidToHandle[gids[i++]] = eh; 00694 } 00695 // now, pack the data and send it 00696 sendReqs.resize( involved_IDs_map.size() ); 00697 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00698 mit != involved_IDs_map.end(); mit++ ) 00699 { 00700 int receiver_proc = mit->first; 00701 std::vector< int >& eids = mit->second; 00702 int size_buffer = 4 + total_bytes_per_entity * 00703 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00704 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00705 buffer->reset_ptr( sizeof( int ) ); 00706 #ifdef VERBOSE 00707 std::ofstream dbfile; 00708 std::stringstream outf; 00709 outf << "from_" << rankInJoin << "_send_to_" << receiver_proc << ".txt"; 00710 dbfile.open( outf.str().c_str() ); 00711 dbfile << "from " << rankInJoin << " send to " << receiver_proc << "\n"; 00712 #endif 00713 // copy tag data to buffer->buff_ptr, and send the buffer (we could have used regular 00714 // char arrays) pack data by tag, to be consistent with above, even though we loop 00715 // through the entities for each tag 00716 00717 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++ ) 00718 { 00719 int eID = *it; 00720 EntityHandle eh = gidToHandle[eID]; 00721 for( i = 0; i < tag_handles.size(); i++ ) 00722 { 00723 rval = mb->tag_get_data( tag_handles[i], &eh, 1, (void*)( buffer->buff_ptr ) ); 00724 if( rval != MB_SUCCESS ) 00725 { 00726 delete buffer; // free parallel comm buffer first 00727 00728 MB_SET_ERR( rval, "Tag get data failed" ); 00729 } 00730 #ifdef VERBOSE 00731 dbfile << "global ID " << eID << " local handle " << mb->id_from_handle( eh ) << " vals: "; 00732 double* vals = (double*)( buffer->buff_ptr ); 00733 for( int kk = 0; kk < tag_sizes[i]; kk++ ) 00734 { 00735 dbfile << " " << *vals; 00736 vals++; 00737 } 00738 dbfile << "\n"; 00739 #endif 00740 buffer->buff_ptr += vect_bytes_per_tag[i]; 00741 } 00742 } 00743 00744 #ifdef VERBOSE 00745 dbfile.close(); 00746 #endif 00747 *( (int*)buffer->mem_ptr ) = size_buffer; 00748 // int size_pack = buffer->get_current_size(); // debug check 00749 ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm, 00750 &sendReqs[indexReq] ); // we have to use global communicator 00751 if( ierr != 0 ) return MB_FAILURE; 00752 indexReq++; 00753 localSendBuffs.push_back( buffer ); // we will release them after nonblocking sends are completed 00754 } 00755 } 00756 else if( graph_type == DOF_BASED ) 00757 { 00758 // need to fill up the buffer, in the order desired, send it 00759 // get all the tags, for all owned entities, and pack the buffers accordingly 00760 // we do not want to get the tags by entity, it may be too expensive 00761 std::vector< std::vector< double > > valuesTags; 00762 valuesTags.resize( tag_handles.size() ); 00763 for( size_t i = 0; i < tag_handles.size(); i++ ) 00764 { 00765 00766 int bytes_per_tag; 00767 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00768 valuesTags[i].resize( owned.size() * bytes_per_tag / sizeof( double ) ); 00769 // fill the whole array, we will pick up from here 00770 rval = mb->tag_get_data( tag_handles[i], owned, (void*)( &( valuesTags[i][0] ) ) );MB_CHK_ERR( rval ); 00771 } 00772 // now, pack the data and send it 00773 sendReqs.resize( involved_IDs_map.size() ); 00774 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00775 mit != involved_IDs_map.end(); mit++ ) 00776 { 00777 int receiver_proc = mit->first; 00778 std::vector< int >& eids = mit->second; 00779 std::vector< int >& index_in_values = map_index[receiver_proc]; 00780 std::vector< int >& index_ptr = map_ptr[receiver_proc]; // this is eids.size()+1; 00781 int size_buffer = 4 + total_bytes_per_entity * 00782 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00783 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00784 buffer->reset_ptr( sizeof( int ) ); 00785 #ifdef VERBOSE 00786 std::ofstream dbfile; 00787 std::stringstream outf; 00788 outf << "from_" << rankInJoin << "_send_to_" << receiver_proc << ".txt"; 00789 dbfile.open( outf.str().c_str() ); 00790 dbfile << "from " << rankInJoin << " send to " << receiver_proc << "\n"; 00791 #endif 00792 // copy tag data to buffer->buff_ptr, and send the buffer 00793 // pack data by tag, to be consistent with above 00794 int j = 0; 00795 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++, j++ ) 00796 { 00797 int index_in_v = index_in_values[index_ptr[j]]; 00798 for( size_t i = 0; i < tag_handles.size(); i++ ) 00799 { 00800 // right now, move just doubles; but it could be any type of tag 00801 *( (double*)( buffer->buff_ptr ) ) = valuesTags[i][index_in_v]; 00802 buffer->buff_ptr += 8; // we know we are working with doubles only !!! 00803 } 00804 }; 00805 *( (int*)buffer->mem_ptr ) = size_buffer; 00806 // int size_pack = buffer->get_current_size(); // debug check 00807 ierr = MPI_Isend( buffer->mem_ptr, size_buffer, MPI_CHAR, receiver_proc, 222, jcomm, 00808 &sendReqs[indexReq] ); // we have to use global communicator 00809 if( ierr != 0 ) return MB_FAILURE; 00810 indexReq++; 00811 localSendBuffs.push_back( buffer ); // we will release them after nonblocking sends are completed 00812 } 00813 } 00814 return MB_SUCCESS; 00815 } 00816 00817 ErrorCode ParCommGraph::receive_tag_values( MPI_Comm jcomm, 00818 ParallelComm* pco, 00819 Range& owned, 00820 std::vector< Tag >& tag_handles ) 00821 { 00822 // opposite to sending, we will use blocking receives 00823 int ierr; 00824 MPI_Status status; 00825 // basically, owned.size() needs to be equal to sum(corr_sizes) 00826 // get info about the tag size, type, etc 00827 Core* mb = (Core*)pco->get_moab(); 00828 // get info about the tag 00829 //! Get the size of the specified tag in bytes 00830 ErrorCode rval; 00831 int total_bytes_per_entity = 0; 00832 std::vector< int > vect_bytes_per_tag; 00833 #ifdef VERBOSE 00834 std::vector< int > tag_sizes; 00835 #endif 00836 for( size_t i = 0; i < tag_handles.size(); i++ ) 00837 { 00838 int bytes_per_tag; 00839 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00840 total_bytes_per_entity += bytes_per_tag; 00841 vect_bytes_per_tag.push_back( bytes_per_tag ); 00842 #ifdef VERBOSE 00843 int tag_size; 00844 rval = mb->tag_get_length( tag_handles[i], tag_size );MB_CHK_ERR( rval ); 00845 tag_sizes.push_back( tag_size ); 00846 #endif 00847 } 00848 00849 if( graph_type == INITIAL_MIGRATE ) 00850 { 00851 // std::map<int, Range> split_ranges; 00852 // rval = split_owned_range ( owned);MB_CHK_ERR ( rval ); 00853 00854 // use the buffers data structure to allocate memory for receiving the tags 00855 for( std::map< int, Range >::iterator it = split_ranges.begin(); it != split_ranges.end(); it++ ) 00856 { 00857 int sender_proc = it->first; 00858 Range ents = it->second; // primary entities, with the tag data, we will receive 00859 int size_buffer = 4 + total_bytes_per_entity * 00860 (int)ents.size(); // hopefully, below 2B; if more, we have a big problem ... 00861 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00862 00863 buffer->reset_ptr( sizeof( int ) ); 00864 00865 *( (int*)buffer->mem_ptr ) = size_buffer; 00866 // int size_pack = buffer->get_current_size(); // debug check 00867 00868 ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status ); 00869 if( ierr != 0 ) return MB_FAILURE; 00870 // now set the tag 00871 // copy to tag 00872 00873 for( size_t i = 0; i < tag_handles.size(); i++ ) 00874 { 00875 rval = mb->tag_set_data( tag_handles[i], ents, (void*)( buffer->buff_ptr ) ); 00876 buffer->buff_ptr += vect_bytes_per_tag[i] * ents.size(); 00877 } 00878 delete buffer; // no need for it afterwards 00879 MB_CHK_ERR( rval ); 00880 } 00881 } 00882 else if( graph_type == COVERAGE ) // receive buffer, then extract tag data, in a loop 00883 { 00884 // we know that we will need to receive some tag data in a specific order (by ids stored) 00885 // first, get the ids of the local elements, from owned Range; unpack the buffer in order 00886 Tag gidTag = mb->globalId_tag(); 00887 std::vector< int > gids; 00888 gids.resize( owned.size() ); 00889 rval = mb->tag_get_data( gidTag, owned, &gids[0] );MB_CHK_ERR( rval ); 00890 std::map< int, EntityHandle > gidToHandle; 00891 size_t i = 0; 00892 for( Range::iterator it = owned.begin(); it != owned.end(); it++ ) 00893 { 00894 EntityHandle eh = *it; 00895 gidToHandle[gids[i++]] = eh; 00896 } 00897 // 00898 // now, unpack the data and set it to the tag 00899 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00900 mit != involved_IDs_map.end(); mit++ ) 00901 { 00902 int sender_proc = mit->first; 00903 std::vector< int >& eids = mit->second; 00904 int size_buffer = 4 + total_bytes_per_entity * 00905 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00906 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00907 buffer->reset_ptr( sizeof( int ) ); 00908 *( (int*)buffer->mem_ptr ) = size_buffer; // this is really not necessary, it should receive this too 00909 00910 // receive the buffer 00911 ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status ); 00912 if( ierr != 0 ) return MB_FAILURE; 00913 // start copy 00914 #ifdef VERBOSE 00915 std::ofstream dbfile; 00916 std::stringstream outf; 00917 outf << "recvFrom_" << sender_proc << "_on_proc_" << rankInJoin << ".txt"; 00918 dbfile.open( outf.str().c_str() ); 00919 dbfile << "recvFrom_" << sender_proc << " on proc " << rankInJoin << "\n"; 00920 #endif 00921 00922 // copy tag data from buffer->buff_ptr 00923 // data is arranged by tag , and repeat the loop for each entity () 00924 // maybe it should be arranged by entity now, not by tag (so one loop for entities, 00925 // outside) 00926 00927 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++ ) 00928 { 00929 int eID = *it; 00930 std::map< int, EntityHandle >::iterator mit2 = gidToHandle.find( eID ); 00931 if( mit2 == gidToHandle.end() ) 00932 { 00933 std::cout << " on rank: " << rankInJoin << " cannot find entity handle with global ID " << eID 00934 << "\n"; 00935 return MB_FAILURE; 00936 } 00937 EntityHandle eh = mit2->second; 00938 for( i = 0; i < tag_handles.size(); i++ ) 00939 { 00940 rval = mb->tag_set_data( tag_handles[i], &eh, 1, (void*)( buffer->buff_ptr ) );MB_CHK_ERR( rval ); 00941 #ifdef VERBOSE 00942 dbfile << "global ID " << eID << " local handle " << mb->id_from_handle( eh ) << " vals: "; 00943 double* vals = (double*)( buffer->buff_ptr ); 00944 for( int kk = 0; kk < tag_sizes[i]; kk++ ) 00945 { 00946 dbfile << " " << *vals; 00947 vals++; 00948 } 00949 dbfile << "\n"; 00950 #endif 00951 buffer->buff_ptr += vect_bytes_per_tag[i]; 00952 } 00953 } 00954 00955 // delete receive buffer 00956 delete buffer; 00957 #ifdef VERBOSE 00958 dbfile.close(); 00959 #endif 00960 } 00961 } 00962 else if( graph_type == DOF_BASED ) 00963 { 00964 // need to fill up the values for each tag, in the order desired, from the buffer received 00965 // 00966 // get all the tags, for all owned entities, and pack the buffers accordingly 00967 // we do not want to get the tags by entity, it may be too expensive 00968 std::vector< std::vector< double > > valuesTags; 00969 valuesTags.resize( tag_handles.size() ); 00970 for( size_t i = 0; i < tag_handles.size(); i++ ) 00971 { 00972 int bytes_per_tag; 00973 rval = mb->tag_get_bytes( tag_handles[i], bytes_per_tag );MB_CHK_ERR( rval ); 00974 valuesTags[i].resize( owned.size() * bytes_per_tag / sizeof( double ) ); 00975 // fill the whole array, we will pick up from here 00976 // we will fill this array, using data from received buffer 00977 // rval = mb->tag_get_data(owned, (void*)( &(valuesTags[i][0])) );MB_CHK_ERR ( rval ); 00978 } 00979 // now, unpack the data and set the tags 00980 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 00981 mit != involved_IDs_map.end(); mit++ ) 00982 { 00983 int sender_proc = mit->first; 00984 std::vector< int >& eids = mit->second; 00985 std::vector< int >& index_in_values = map_index[sender_proc]; 00986 std::vector< int >& index_ptr = map_ptr[sender_proc]; // this is eids.size()+1; 00987 int size_buffer = 4 + total_bytes_per_entity * 00988 (int)eids.size(); // hopefully, below 2B; if more, we have a big problem ... 00989 ParallelComm::Buffer* buffer = new ParallelComm::Buffer( size_buffer ); 00990 buffer->reset_ptr( sizeof( int ) ); 00991 00992 // receive the buffer 00993 ierr = MPI_Recv( buffer->mem_ptr, size_buffer, MPI_CHAR, sender_proc, 222, jcomm, &status ); 00994 if( ierr != 0 ) return MB_FAILURE; 00995 // use the values in buffer to populate valuesTag arrays, fill it up! 00996 int j = 0; 00997 for( std::vector< int >::iterator it = eids.begin(); it != eids.end(); it++, j++ ) 00998 { 00999 for( size_t i = 0; i < tag_handles.size(); i++ ) 01000 { 01001 // right now, move just doubles; but it could be any type of tag 01002 double val = *( (double*)( buffer->buff_ptr ) ); 01003 buffer->buff_ptr += 8; // we know we are working with doubles only !!! 01004 for( int k = index_ptr[j]; k < index_ptr[j + 1]; k++ ) 01005 valuesTags[i][index_in_values[k]] = val; 01006 } 01007 } 01008 // we are done with the buffer in which we received tags, release / delete it 01009 delete buffer; 01010 } 01011 // now we populated the values for all tags; set now the tags! 01012 for( size_t i = 0; i < tag_handles.size(); i++ ) 01013 { 01014 // we will fill this array, using data from received buffer 01015 rval = mb->tag_set_data( tag_handles[i], owned, (void*)( &( valuesTags[i][0] ) ) );MB_CHK_ERR( rval ); 01016 } 01017 } 01018 return MB_SUCCESS; 01019 } 01020 /* 01021 * for example 01022 */ 01023 ErrorCode ParCommGraph::settle_send_graph( TupleList& TLcovIDs ) 01024 { 01025 // fill involved_IDs_map with data 01026 // will have "receiving proc" and global id of element 01027 int n = TLcovIDs.get_n(); 01028 graph_type = COVERAGE; // do not rely only on involved_IDs_map.size(); this can be 0 in some cases 01029 for( int i = 0; i < n; i++ ) 01030 { 01031 int to_proc = TLcovIDs.vi_wr[2 * i]; 01032 int globalIdElem = TLcovIDs.vi_wr[2 * i + 1]; 01033 involved_IDs_map[to_proc].push_back( globalIdElem ); 01034 } 01035 #ifdef VERBOSE 01036 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); mit != involved_IDs_map.end(); 01037 mit++ ) 01038 { 01039 std::cout << " towards task " << mit->first << " send: " << mit->second.size() << " cells " << std::endl; 01040 for( size_t i = 0; i < mit->second.size(); i++ ) 01041 { 01042 std::cout << " " << mit->second[i]; 01043 } 01044 std::cout << std::endl; 01045 } 01046 #endif 01047 return MB_SUCCESS; 01048 } 01049 01050 // this will set involved_IDs_map will store all ids to be received from one sender task 01051 void ParCommGraph::SetReceivingAfterCoverage( 01052 std::map< int, std::set< int > >& idsFromProcs ) // will make sense only on receivers, right now after cov 01053 { 01054 for( std::map< int, std::set< int > >::iterator mt = idsFromProcs.begin(); mt != idsFromProcs.end(); mt++ ) 01055 { 01056 int fromProc = mt->first; 01057 std::set< int >& setIds = mt->second; 01058 involved_IDs_map[fromProc].resize( setIds.size() ); 01059 std::vector< int >& listIDs = involved_IDs_map[fromProc]; 01060 size_t indx = 0; 01061 for( std::set< int >::iterator st = setIds.begin(); st != setIds.end(); st++ ) 01062 { 01063 int valueID = *st; 01064 listIDs[indx++] = valueID; 01065 } 01066 } 01067 graph_type = COVERAGE; 01068 return; 01069 } 01070 //#define VERBOSE 01071 void ParCommGraph::settle_comm_by_ids( int comp, TupleList& TLBackToComp, std::vector< int >& valuesComp ) 01072 { 01073 // settle comm graph on comp 01074 if( rootSender || rootReceiver ) std::cout << " settle comm graph by id on component " << comp << "\n"; 01075 int n = TLBackToComp.get_n(); 01076 // third_method = true; // do not rely only on involved_IDs_map.size(); this can be 0 in some 01077 // cases 01078 std::map< int, std::set< int > > uniqueIDs; 01079 01080 for( int i = 0; i < n; i++ ) 01081 { 01082 int to_proc = TLBackToComp.vi_wr[3 * i + 2]; 01083 int globalId = TLBackToComp.vi_wr[3 * i + 1]; 01084 uniqueIDs[to_proc].insert( globalId ); 01085 } 01086 01087 // Vector to store element 01088 // with respective present index 01089 std::vector< std::pair< int, int > > vp; 01090 vp.reserve( valuesComp.size() ); 01091 01092 // Inserting element in pair vector 01093 // to keep track of previous indexes in valuesComp 01094 for( int i = 0; i < (int)valuesComp.size(); ++i ) 01095 { 01096 vp.push_back( std::make_pair( valuesComp[i], i ) ); 01097 } 01098 // Sorting pair vector 01099 sort( vp.begin(), vp.end() ); 01100 01101 // vp[i].first, second 01102 01103 // count now how many times some value appears in ordered (so in valuesComp) 01104 for( std::map< int, std::set< int > >::iterator it = uniqueIDs.begin(); it != uniqueIDs.end(); it++ ) 01105 { 01106 int procId = it->first; 01107 std::set< int >& nums = it->second; 01108 std::vector< int >& indx = map_ptr[procId]; 01109 std::vector< int >& indices = map_index[procId]; 01110 indx.resize( nums.size() + 1 ); 01111 int indexInVp = 0; 01112 int indexVal = 0; 01113 indx[0] = 0; // start from 0 01114 for( std::set< int >::iterator sst = nums.begin(); sst != nums.end(); sst++, indexVal++ ) 01115 { 01116 int val = *sst; 01117 involved_IDs_map[procId].push_back( val ); 01118 indx[indexVal + 1] = indx[indexVal]; 01119 while( ( indexInVp < (int)valuesComp.size() ) && ( vp[indexInVp].first <= val ) ) // should be equal ! 01120 { 01121 if( vp[indexInVp].first == val ) 01122 { 01123 indx[indexVal + 1]++; 01124 indices.push_back( vp[indexInVp].second ); 01125 } 01126 indexInVp++; 01127 } 01128 } 01129 } 01130 #ifdef VERBOSE 01131 std::stringstream f1; 01132 std::ofstream dbfile; 01133 f1 << "Involve_" << comp << "_" << rankInJoin << ".txt"; 01134 dbfile.open( f1.str().c_str() ); 01135 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); mit != involved_IDs_map.end(); 01136 mit++ ) 01137 { 01138 int corrTask = mit->first; 01139 std::vector< int >& corrIds = mit->second; 01140 std::vector< int >& indx = map_ptr[corrTask]; 01141 std::vector< int >& indices = map_index[corrTask]; 01142 01143 dbfile << " towards proc " << corrTask << " \n"; 01144 for( int i = 0; i < (int)corrIds.size(); i++ ) 01145 { 01146 dbfile << corrIds[i] << " [" << indx[i] << "," << indx[i + 1] << ") : "; 01147 for( int j = indx[i]; j < indx[i + 1]; j++ ) 01148 dbfile << indices[j] << " "; 01149 dbfile << "\n"; 01150 } 01151 dbfile << " \n"; 01152 } 01153 dbfile.close(); 01154 #endif 01155 01156 graph_type = DOF_BASED; 01157 // now we need to fill back and forth information, needed to fill the arrays 01158 // for example, from spectral to involved_IDs_map, in case we want to send data from 01159 // spectral to phys 01160 } 01161 //#undef VERBOSE 01162 // new partition calculation 01163 ErrorCode ParCommGraph::compute_partition( ParallelComm* pco, Range& owned, int met, std::vector< char >& zoltanBuffer ) 01164 { 01165 // we are on a task on sender, and need to compute a new partition; 01166 // primary cells need to be distributed to nb receivers tasks 01167 // first, we will use graph partitioner, with zoltan; 01168 // in the graph that we need to build, the first layer of ghosts is needed; 01169 // can we avoid that ? For example, we can find out from each boundary edge/face what is the 01170 // other cell (on the other side), then form the global graph, and call zoltan in parallel met 1 01171 // would be a geometric partitioner, and met 2 would be a graph partitioner for method 1 we do 01172 // not need any ghost exchange 01173 01174 // find first edges that are shared 01175 if( owned.empty() ) 01176 return MB_SUCCESS; // nothing to do? empty partition is not allowed, maybe we should return 01177 // error? 01178 Core* mb = (Core*)pco->get_moab(); 01179 01180 double t1, t2, t3; 01181 t1 = MPI_Wtime(); 01182 int primaryDim = mb->dimension_from_handle( *owned.rbegin() ); 01183 int interfaceDim = primaryDim - 1; // should be 1 or 2 01184 Range sharedEdges; 01185 ErrorCode rval; 01186 01187 std::vector< int > shprocs( MAX_SHARING_PROCS ); 01188 std::vector< EntityHandle > shhandles( MAX_SHARING_PROCS ); 01189 01190 Tag gidTag = mb->globalId_tag(); 01191 int np; 01192 unsigned char pstatus; 01193 01194 std::multimap< int, int > extraGraphEdges; 01195 // std::map<int, int> adjCellsId; 01196 std::map< int, int > extraCellsProc; 01197 // if method is 2, no need to do the exchange for adjacent cells across partition boundary 01198 // these maps above will be empty for method 2 (geometry) 01199 if( 1 == met ) 01200 { 01201 rval = pco->get_shared_entities( /*int other_proc*/ -1, sharedEdges, interfaceDim, 01202 /*const bool iface*/ true );MB_CHK_ERR( rval ); 01203 01204 #ifdef VERBOSE 01205 std::cout << " on sender task " << pco->rank() << " number of shared interface cells " << sharedEdges.size() 01206 << "\n"; 01207 #endif 01208 // find to what processors we need to send the ghost info about the edge 01209 // first determine the local graph; what elements are adjacent to each cell in owned range 01210 // cells that are sharing a partition interface edge, are identified first, and form a map 01211 TupleList TLe; // tuple list for cells 01212 TLe.initialize( 2, 0, 1, 0, sharedEdges.size() ); // send to, id of adj cell, remote edge 01213 TLe.enableWriteAccess(); 01214 01215 std::map< EntityHandle, int > edgeToCell; // from local boundary edge to adjacent cell id 01216 // will be changed after 01217 for( Range::iterator eit = sharedEdges.begin(); eit != sharedEdges.end(); eit++ ) 01218 { 01219 EntityHandle edge = *eit; 01220 // get the adjacent cell 01221 Range adjEnts; 01222 rval = mb->get_adjacencies( &edge, 1, primaryDim, false, adjEnts );MB_CHK_ERR( rval ); 01223 if( adjEnts.size() > 0 ) 01224 { 01225 EntityHandle adjCell = adjEnts[0]; 01226 int gid; 01227 rval = mb->tag_get_data( gidTag, &adjCell, 1, &gid );MB_CHK_ERR( rval ); 01228 rval = pco->get_sharing_data( edge, &shprocs[0], &shhandles[0], pstatus, np );MB_CHK_ERR( rval ); 01229 int n = TLe.get_n(); 01230 TLe.vi_wr[2 * n] = shprocs[0]; 01231 TLe.vi_wr[2 * n + 1] = gid; 01232 TLe.vul_wr[n] = shhandles[0]; // the remote edge corresponding to shared edge 01233 edgeToCell[edge] = gid; // store the map between edge and local id of adj cell 01234 TLe.inc_n(); 01235 } 01236 } 01237 01238 #ifdef VERBOSE 01239 std::stringstream ff2; 01240 ff2 << "TLe_" << pco->rank() << ".txt"; 01241 TLe.print_to_file( ff2.str().c_str() ); 01242 #endif 01243 // send the data to the other processors: 01244 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLe, 0 ); 01245 // on receiver side, each local edge will have the remote cell adjacent to it! 01246 01247 int ne = TLe.get_n(); 01248 for( int i = 0; i < ne; i++ ) 01249 { 01250 int sharedProc = TLe.vi_rd[2 * i]; // this info is coming from here, originally 01251 int remoteCellID = TLe.vi_rd[2 * i + 1]; // this is the id of the remote cell, on sharedProc 01252 EntityHandle localCell = TLe.vul_rd[i]; // this is now local edge/face on this proc 01253 int localCellId = edgeToCell[localCell]; // this is the local cell adjacent to edge/face 01254 // now, we will need to add to the graph the pair <localCellId, remoteCellID> 01255 std::pair< int, int > extraAdj = std::make_pair( localCellId, remoteCellID ); 01256 extraGraphEdges.insert( extraAdj ); 01257 // adjCellsId [edgeToCell[localCell]] = remoteCellID; 01258 extraCellsProc[remoteCellID] = sharedProc; 01259 #ifdef VERBOSE 01260 std::cout << "local ID " << edgeToCell[localCell] << " remote cell ID: " << remoteCellID << "\n"; 01261 #endif 01262 } 01263 } 01264 t2 = MPI_Wtime(); 01265 if( rootSender ) std::cout << " time preparing the input for Zoltan:" << t2 - t1 << " seconds. \n"; 01266 // so adj cells ids; need to call zoltan for parallel partition 01267 #ifdef MOAB_HAVE_ZOLTAN 01268 ZoltanPartitioner* mbZTool = new ZoltanPartitioner( mb, pco ); 01269 if( 1 <= met ) // partition in zoltan, either graph or geometric partitioner 01270 { 01271 std::map< int, Range > distribution; // how to distribute owned elements by processors in receiving groups 01272 // in how many tasks do we want to be distributed? 01273 int numNewPartitions = (int)receiverTasks.size(); 01274 Range primaryCells = owned.subset_by_dimension( primaryDim ); 01275 rval = mbZTool->partition_owned_cells( primaryCells, extraGraphEdges, extraCellsProc, numNewPartitions, 01276 distribution, met, zoltanBuffer );MB_CHK_ERR( rval ); 01277 for( std::map< int, Range >::iterator mit = distribution.begin(); mit != distribution.end(); mit++ ) 01278 { 01279 int part_index = mit->first; 01280 assert( part_index < numNewPartitions ); 01281 split_ranges[receiverTasks[part_index]] = mit->second; 01282 } 01283 } 01284 // delete now the partitioner 01285 delete mbZTool; 01286 #endif 01287 t3 = MPI_Wtime(); 01288 if( rootSender ) std::cout << " time spent by Zoltan " << t3 - t2 << " seconds. \n"; 01289 return MB_SUCCESS; 01290 } 01291 01292 // after map read, we need to know what entities we need to send to receiver 01293 ErrorCode ParCommGraph::set_split_ranges( int comp, 01294 TupleList& TLBackToComp1, 01295 std::vector< int >& valuesComp1, 01296 int lenTag, 01297 Range& ents_of_interest, 01298 int /*type*/ ) 01299 { 01300 // settle split_ranges // same role as partitioning 01301 if( rootSender ) std::cout << " find split_ranges on component " << comp << " according to read map \n"; 01302 // Vector to store element 01303 // with respective present index 01304 int n = TLBackToComp1.get_n(); 01305 // third_method = true; // do not rely only on involved_IDs_map.size(); this can be 0 in some 01306 // cases 01307 std::map< int, std::set< int > > uniqueIDs; 01308 01309 for( int i = 0; i < n; i++ ) 01310 { 01311 int to_proc = TLBackToComp1.vi_wr[3 * i + 2]; 01312 int globalId = TLBackToComp1.vi_wr[3 * i + 1]; 01313 uniqueIDs[to_proc].insert( globalId ); 01314 } 01315 01316 for( int i = 0; i < (int)ents_of_interest.size(); i++ ) 01317 { 01318 EntityHandle ent = ents_of_interest[i]; 01319 for( int j = 0; j < lenTag; j++ ) 01320 { 01321 int marker = valuesComp1[i * lenTag + j]; 01322 for( auto mit = uniqueIDs.begin(); mit != uniqueIDs.end(); mit++ ) 01323 { 01324 int proc = mit->first; 01325 std::set< int >& setIds = mit->second; 01326 if( setIds.find( marker ) != setIds.end() ) 01327 { 01328 split_ranges[proc].insert( ent ); 01329 } 01330 } 01331 } 01332 } 01333 01334 return MB_SUCCESS; 01335 } 01336 01337 // new methods to migrate mesh after reading map 01338 ErrorCode ParCommGraph::form_tuples_to_migrate_mesh( Interface* mb, 01339 TupleList& TLv, 01340 TupleList& TLc, 01341 int type, 01342 int lenTagType1 ) 01343 { 01344 // we will always need GlobalID tag 01345 Tag gidtag = mb->globalId_tag(); 01346 // for Type1, we need GLOBAL_DOFS tag; 01347 Tag gds; 01348 ErrorCode rval; 01349 if( type == 1 ) 01350 { 01351 rval = mb->tag_get_handle( "GLOBAL_DOFS", gds ); 01352 } 01353 // find vertices to be sent, for each of the split_ranges procs 01354 std::map< int, Range > verts_to_proc; 01355 int numv = 0, numc = 0; 01356 for( auto it = split_ranges.begin(); it != split_ranges.end(); it++ ) 01357 { 01358 int to_proc = it->first; 01359 Range verts; 01360 if( type != 2 ) 01361 { 01362 rval = mb->get_connectivity( it->second, verts );MB_CHK_ERR( rval ); 01363 numc += (int)it->second.size(); 01364 } 01365 else 01366 verts = it->second; 01367 verts_to_proc[to_proc] = verts; 01368 numv += (int)verts.size(); 01369 } 01370 // first vertices: 01371 TLv.initialize( 2, 0, 0, 3, numv ); // to proc, GLOBAL ID, 3 real coordinates 01372 TLv.enableWriteAccess(); 01373 // use the global id of vertices for connectivity 01374 for( auto it = verts_to_proc.begin(); it != verts_to_proc.end(); it++ ) 01375 { 01376 int to_proc = it->first; 01377 Range& verts = it->second; 01378 for( Range::iterator vit = verts.begin(); vit != verts.end(); ++vit ) 01379 { 01380 EntityHandle v = *vit; 01381 int n = TLv.get_n(); // current size of tuple list 01382 TLv.vi_wr[2 * n] = to_proc; // send to processor 01383 01384 rval = mb->tag_get_data( gidtag, &v, 1, &( TLv.vi_wr[2 * n + 1] ) );MB_CHK_ERR( rval ); 01385 rval = mb->get_coords( &v, 1, &( TLv.vr_wr[3 * n] ) );MB_CHK_ERR( rval ); 01386 TLv.inc_n(); // increment tuple list size 01387 } 01388 } 01389 if( type == 2 ) return MB_SUCCESS; // no need to fill TLc 01390 // to proc, ID cell, gdstag, nbv, id conn, 01391 int size_tuple = 2 + ( ( type != 1 ) ? 0 : lenTagType1 ) + 1 + 10; // 10 is the max number of vertices in cell 01392 01393 std::vector< int > gdvals; 01394 01395 TLc.initialize( size_tuple, 0, 0, 0, numc ); // to proc, GLOBAL ID, 3 real coordinates 01396 TLc.enableWriteAccess(); 01397 for( auto it = split_ranges.begin(); it != split_ranges.end(); it++ ) 01398 { 01399 int to_proc = it->first; 01400 Range& cells = it->second; 01401 for( Range::iterator cit = cells.begin(); cit != cells.end(); ++cit ) 01402 { 01403 EntityHandle cell = *cit; 01404 int n = TLc.get_n(); // current size of tuple list 01405 TLc.vi_wr[size_tuple * n] = to_proc; 01406 int current_index = 2; 01407 rval = mb->tag_get_data( gidtag, &cell, 1, &( TLc.vi_wr[size_tuple * n + 1] ) );MB_CHK_ERR( rval ); 01408 if( 1 == type ) 01409 { 01410 rval = mb->tag_get_data( gds, &cell, 1, &( TLc.vi_wr[size_tuple * n + current_index] ) );MB_CHK_ERR( rval ); 01411 current_index += lenTagType1; 01412 } 01413 // now get connectivity 01414 const EntityHandle* conn = NULL; 01415 int nnodes = 0; 01416 rval = mb->get_connectivity( cell, conn, nnodes );MB_CHK_ERR( rval ); 01417 // fill nnodes: 01418 TLc.vi_wr[size_tuple * n + current_index] = nnodes; 01419 rval = mb->tag_get_data( gidtag, conn, nnodes, &( TLc.vi_wr[size_tuple * n + current_index + 1] ) );MB_CHK_ERR( rval ); 01420 TLc.inc_n(); // increment tuple list size 01421 } 01422 } 01423 return MB_SUCCESS; 01424 } 01425 ErrorCode ParCommGraph::form_mesh_from_tuples( Interface* mb, 01426 TupleList& TLv, 01427 TupleList& TLc, 01428 int type, 01429 int lenTagType1, 01430 EntityHandle fset, 01431 Range& primary_ents, 01432 std::vector< int >& values_entities ) 01433 { 01434 // might need to fill also the split_range things 01435 // we will always need GlobalID tag 01436 Tag gidtag = mb->globalId_tag(); 01437 // for Type1, we need GLOBAL_DOFS tag; 01438 Tag gds; 01439 ErrorCode rval; 01440 std::vector< int > def_val( lenTagType1, 0 ); 01441 if( type == 1 ) 01442 { 01443 // we may need to create this tag 01444 rval = mb->tag_get_handle( "GLOBAL_DOFS", lenTagType1, MB_TYPE_INTEGER, gds, MB_TAG_CREAT | MB_TAG_DENSE, 01445 &def_val[0] );MB_CHK_ERR( rval ); 01446 } 01447 01448 std::map< int, EntityHandle > vertexMap; // 01449 Range verts; 01450 // always form vertices and add them to the fset; 01451 int n = TLv.get_n(); 01452 EntityHandle vertex; 01453 for( int i = 0; i < n; i++ ) 01454 { 01455 int gid = TLv.vi_rd[2 * i + 1]; 01456 if( vertexMap.find( gid ) == vertexMap.end() ) 01457 { 01458 // need to form this vertex 01459 rval = mb->create_vertex( &( TLv.vr_rd[3 * i] ), vertex );MB_CHK_ERR( rval ); 01460 vertexMap[gid] = vertex; 01461 verts.insert( vertex ); 01462 rval = mb->tag_set_data( gidtag, &vertex, 1, &gid );MB_CHK_ERR( rval ); 01463 // if point cloud, 01464 } 01465 if( 2 == type ) // point cloud, add it to the split_ranges ? 01466 { 01467 split_ranges[TLv.vi_rd[2 * i]].insert( vertexMap[gid] ); 01468 } 01469 // todo : when to add the values_entities ? 01470 } 01471 rval = mb->add_entities( fset, verts );MB_CHK_ERR( rval ); 01472 if( 2 == type ) 01473 { 01474 primary_ents = verts; 01475 values_entities.resize( verts.size() ); // just get the ids of vertices 01476 rval = mb->tag_get_data( gidtag, verts, &values_entities[0] );MB_CHK_ERR( rval ); 01477 return MB_SUCCESS; 01478 } 01479 01480 n = TLc.get_n(); 01481 int size_tuple = 2 + ( ( type != 1 ) ? 0 : lenTagType1 ) + 1 + 10; // 10 is the max number of vertices in cell 01482 01483 EntityHandle new_element; 01484 Range cells; 01485 std::map< int, EntityHandle > cellMap; // do no tcreate one if it already exists, maybe from other processes 01486 for( int i = 0; i < n; i++ ) 01487 { 01488 int from_proc = TLc.vi_rd[size_tuple * i]; 01489 int globalIdEl = TLc.vi_rd[size_tuple * i + 1]; 01490 if( cellMap.find( globalIdEl ) == cellMap.end() ) // need to create the cell 01491 { 01492 int current_index = 2; 01493 if( 1 == type ) current_index += lenTagType1; 01494 int nnodes = TLc.vi_rd[size_tuple * i + current_index]; 01495 std::vector< EntityHandle > conn; 01496 conn.resize( nnodes ); 01497 for( int j = 0; j < nnodes; j++ ) 01498 { 01499 conn[j] = vertexMap[TLc.vi_rd[size_tuple * i + current_index + j + 1]]; 01500 } 01501 // 01502 EntityType entType = MBQUAD; 01503 if( nnodes > 4 ) entType = MBPOLYGON; 01504 if( nnodes < 4 ) entType = MBTRI; 01505 rval = mb->create_element( entType, &conn[0], nnodes, new_element );MB_CHK_SET_ERR( rval, "can't create new element " ); 01506 cells.insert( new_element ); 01507 cellMap[globalIdEl] = new_element; 01508 rval = mb->tag_set_data( gidtag, &new_element, 1, &globalIdEl );MB_CHK_SET_ERR( rval, "can't set global id tag on cell " ); 01509 if( 1 == type ) 01510 { 01511 // set the gds tag 01512 rval = mb->tag_set_data( gds, &new_element, 1, &( TLc.vi_rd[size_tuple * i + 2] ) );MB_CHK_SET_ERR( rval, "can't set gds tag on cell " ); 01513 } 01514 } 01515 split_ranges[from_proc].insert( cellMap[globalIdEl] ); 01516 } 01517 rval = mb->add_entities( fset, cells );MB_CHK_ERR( rval ); 01518 primary_ents = cells; 01519 if( 1 == type ) 01520 { 01521 values_entities.resize( lenTagType1 * primary_ents.size() ); 01522 rval = mb->tag_get_data( gds, primary_ents, &values_entities[0] );MB_CHK_ERR( rval ); 01523 } 01524 else // type == 3 01525 { 01526 values_entities.resize( primary_ents.size() ); // just get the ids ! 01527 rval = mb->tag_get_data( gidtag, primary_ents, &values_entities[0] );MB_CHK_ERR( rval ); 01528 } 01529 return MB_SUCCESS; 01530 } 01531 01532 // at this moment, each sender task has split_ranges formed; 01533 // we need to aggregate that info and send it to receiver 01534 ErrorCode ParCommGraph::send_graph_partition( ParallelComm* pco, MPI_Comm jcomm, std::vector< char >& zoltanBuffer ) 01535 { 01536 // first, accumulate the info to root of sender; use gatherv 01537 // first, accumulate number of receivers from each sender, to the root receiver 01538 int numberReceivers = 01539 (int)split_ranges.size(); // these are ranges of elements to be sent to each receiver, from this task 01540 int nSenders = (int)senderTasks.size(); // 01541 // this sender will have to send to this many receivers 01542 std::vector< int > displs( 1 ); // displacements for gatherv 01543 std::vector< int > counts( 1 ); 01544 if( is_root_sender() ) 01545 { 01546 displs.resize( nSenders + 1 ); 01547 counts.resize( nSenders ); 01548 } 01549 01550 int ierr = MPI_Gather( &numberReceivers, 1, MPI_INT, &counts[0], 1, MPI_INT, 0, pco->comm() ); 01551 if( ierr != MPI_SUCCESS ) return MB_FAILURE; 01552 // compute now displacements 01553 if( is_root_sender() ) 01554 { 01555 displs[0] = 0; 01556 for( int k = 0; k < nSenders; k++ ) 01557 { 01558 displs[k + 1] = displs[k] + counts[k]; 01559 } 01560 } 01561 std::vector< int > buffer; 01562 if( is_root_sender() ) buffer.resize( displs[nSenders] ); // the last one will have the total count now 01563 01564 std::vector< int > recvs; 01565 for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ ) 01566 { 01567 recvs.push_back( mit->first ); 01568 } 01569 ierr = 01570 MPI_Gatherv( &recvs[0], numberReceivers, MPI_INT, &buffer[0], &counts[0], &displs[0], MPI_INT, 0, pco->comm() ); 01571 if( ierr != MPI_SUCCESS ) return MB_FAILURE; 01572 01573 // now form recv_graph map; points from the 01574 // now form the graph to be sent to the other side; only on root 01575 if( is_root_sender() ) 01576 { 01577 #ifdef GRAPH_INFO 01578 std::ofstream dbfileSender; 01579 std::stringstream outf; 01580 outf << "S_" << compid1 << "_R_" << compid2 << "_SenderGraph.txt"; 01581 dbfileSender.open( outf.str().c_str() ); 01582 dbfileSender << " number senders: " << nSenders << "\n"; 01583 dbfileSender << " senderRank \treceivers \n"; 01584 for( int k = 0; k < nSenders; k++ ) 01585 { 01586 int indexInBuff = displs[k]; 01587 int senderTask = senderTasks[k]; 01588 dbfileSender << senderTask << "\t\t"; 01589 for( int j = 0; j < counts[k]; j++ ) 01590 { 01591 int recvTask = buffer[indexInBuff + j]; 01592 dbfileSender << recvTask << " "; 01593 } 01594 dbfileSender << "\n"; 01595 } 01596 dbfileSender.close(); 01597 #endif 01598 for( int k = 0; k < nSenders; k++ ) 01599 { 01600 int indexInBuff = displs[k]; 01601 int senderTask = senderTasks[k]; 01602 for( int j = 0; j < counts[k]; j++ ) 01603 { 01604 int recvTask = buffer[indexInBuff + j]; 01605 recv_graph[recvTask].push_back( senderTask ); // this will be packed and sent to root receiver, with 01606 // nonblocking send 01607 } 01608 } 01609 #ifdef GRAPH_INFO 01610 std::ofstream dbfile; 01611 std::stringstream outf2; 01612 outf2 << "S_" << compid1 << "_R_" << compid2 << "_RecvGraph.txt"; 01613 dbfile.open( outf2.str().c_str() ); 01614 dbfile << " number receivers: " << recv_graph.size() << "\n"; 01615 dbfile << " receiverRank \tsenders \n"; 01616 for( std::map< int, std::vector< int > >::iterator mit = recv_graph.begin(); mit != recv_graph.end(); mit++ ) 01617 { 01618 int recvTask = mit->first; 01619 std::vector< int >& senders = mit->second; 01620 dbfile << recvTask << "\t\t"; 01621 for( std::vector< int >::iterator vit = senders.begin(); vit != senders.end(); vit++ ) 01622 dbfile << *vit << " "; 01623 dbfile << "\n"; 01624 } 01625 dbfile.close(); 01626 #endif 01627 // this is the same as trivial partition 01628 ErrorCode rval = send_graph( jcomm, zoltanBuffer );MB_CHK_ERR( rval ); 01629 } 01630 01631 return MB_SUCCESS; 01632 } 01633 // method to expose local graph info: sender id, receiver id, sizes of elements to send, after or 01634 // before intersection 01635 ErrorCode ParCommGraph::dump_comm_information( const std::string & prefix, int is_send, int verbose ) 01636 { 01637 // 01638 if( -1 != rankInGroup1 && 1 == is_send ) // it is a sender task 01639 { 01640 std::ofstream dbfile; 01641 std::stringstream outf; 01642 outf << prefix << "_sender_" << rankInGroup1 << "_joint" << rankInJoin << "_type_" << (int)graph_type << ".txt"; 01643 dbfile.open( outf.str().c_str() ); 01644 01645 if( graph_type == COVERAGE ) 01646 { 01647 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01648 mit != involved_IDs_map.end(); mit++ ) 01649 { 01650 int receiver_proc = mit->first; 01651 std::vector< int >& eids = mit->second; 01652 dbfile << "receiver: " << receiver_proc << " size:" << eids.size() << "\n"; 01653 if( verbose >= 1 ) 01654 { 01655 for( size_t i = 0; i < eids.size(); i++ ) 01656 { 01657 dbfile << eids[i] << " "; 01658 if( i % 20 == 19 ) dbfile << "\n"; 01659 } 01660 dbfile << "\n"; 01661 } 01662 } 01663 } 01664 else if( graph_type == INITIAL_MIGRATE ) // just after migration 01665 { 01666 for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ ) 01667 { 01668 int receiver_proc = mit->first; 01669 Range& eids = mit->second; 01670 dbfile << "receiver: " << receiver_proc << " size:" << eids.size() << "\n"; 01671 } 01672 } 01673 else if( graph_type == DOF_BASED ) // just after migration, or from computeGraph 01674 { 01675 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01676 mit != involved_IDs_map.end(); mit++ ) 01677 { 01678 int receiver_proc = mit->first; 01679 dbfile << "receiver: " << receiver_proc << " size:" << mit->second.size() << "\n"; 01680 } 01681 } 01682 dbfile.close(); 01683 } 01684 if( -1 != rankInGroup2 && 0 == is_send ) // it is a receiver task 01685 { 01686 std::ofstream dbfile; 01687 std::stringstream outf; 01688 outf << prefix << "_receiver_" << rankInGroup2 << "_joint" << rankInJoin << "_type_" << (int)graph_type 01689 << ".txt"; 01690 dbfile.open( outf.str().c_str() ); 01691 01692 if( graph_type == COVERAGE ) 01693 { 01694 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01695 mit != involved_IDs_map.end(); mit++ ) 01696 { 01697 int sender_proc = mit->first; 01698 std::vector< int >& eids = mit->second; 01699 dbfile << "sender: " << sender_proc << " size:" << eids.size() << "\n"; 01700 if( verbose >= 1 ) 01701 { 01702 for( size_t i = 0; i < eids.size(); i++ ) 01703 { 01704 dbfile << eids[i] << " "; 01705 if( i % 20 == 19 ) dbfile << "\n"; 01706 } 01707 dbfile << "\n"; 01708 } 01709 } 01710 } 01711 else if( graph_type == INITIAL_MIGRATE ) // just after migration 01712 { 01713 for( std::map< int, Range >::iterator mit = split_ranges.begin(); mit != split_ranges.end(); mit++ ) 01714 { 01715 int sender_proc = mit->first; 01716 Range& eids = mit->second; 01717 dbfile << "sender: " << sender_proc << " size:" << eids.size() << "\n"; 01718 } 01719 } 01720 else if( graph_type == DOF_BASED ) // just after migration 01721 { 01722 for( std::map< int, std::vector< int > >::iterator mit = involved_IDs_map.begin(); 01723 mit != involved_IDs_map.end(); mit++ ) 01724 { 01725 int sender_proc = mit->first; 01726 dbfile << "receiver: " << sender_proc << " size:" << mit->second.size() << "\n"; 01727 } 01728 } 01729 dbfile.close(); 01730 } 01731 return MB_SUCCESS; 01732 } 01733 } // namespace moab
