Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifdef WIN32 00017 #pragma warning( disable : 4786 ) 00018 #endif 00019 00020 #include "ReadABAQUS.hpp" 00021 00022 #include <algorithm> 00023 #include <ctime> 00024 #include <string> 00025 #include <cassert> 00026 #include <cstdio> 00027 #include <cmath> 00028 00029 #include "moab/Range.hpp" 00030 #include "moab/Interface.hpp" 00031 #include "MBTagConventions.hpp" 00032 #include "Internals.hpp" 00033 #include "moab/ReadUtilIface.hpp" 00034 #include "AffineXform.hpp" 00035 // #include "abaqus_order.h" 00036 #include "moab/FileOptions.hpp" 00037 00038 namespace moab 00039 { 00040 00041 #define ABQ_AMBIGUOUS "AMBIGUOUS" 00042 #define ABQ_UNDEFINED "UNDEFINED" 00043 #define DEG2RAD 0.017453292519943295769236907684886 00044 00045 #define MB_RETURN_IF_FAIL \ 00046 if( MB_SUCCESS != status ) return status 00047 00048 ReaderIface* ReadABAQUS::factory( Interface* iface ) 00049 { 00050 return new ReadABAQUS( iface ); 00051 } 00052 00053 ReadABAQUS::ReadABAQUS( Interface* impl ) 00054 : mdbImpl( impl ), readMeshIface( NULL ), lineNo( 0 ), next_line_type( abq_undefined_line ), mat_id( 0 ) 00055 { 00056 assert( impl != NULL ); 00057 reset(); 00058 00059 impl->query_interface( readMeshIface ); 00060 00061 // Initialize in case tag_get_handle fails below 00062 mMaterialSetTag = 0; 00063 mDirichletSetTag = 0; 00064 mNeumannSetTag = 0; 00065 mHasMidNodesTag = 0; 00066 00067 mSetTypeTag = 0; 00068 mPartHandleTag = 0; 00069 mInstancePIDTag = 0; 00070 mInstanceGIDTag = 0; 00071 mLocalIDTag = 0; 00072 mInstanceHandleTag = 0; 00073 mAssemblyHandleTag = 0; 00074 mSetNameTag = 0; 00075 mMatNameTag = 0; 00076 00077 //! Get and cache predefined tag handles 00078 int negone = -1, negonearr[] = { -1, -1, -1, -1 }; 00079 mMaterialSetTag = get_tag( MATERIAL_SET_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone ); 00080 mDirichletSetTag = get_tag( DIRICHLET_SET_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone ); 00081 mNeumannSetTag = get_tag( NEUMANN_SET_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone ); 00082 mHasMidNodesTag = get_tag( HAS_MID_NODES_TAG_NAME, 4, MB_TAG_SPARSE, MB_TYPE_INTEGER, negonearr ); 00083 00084 mSetTypeTag = get_tag( ABAQUS_SET_TYPE_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER ); 00085 mPartHandleTag = get_tag( ABAQUS_PART_HANDLE_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_HANDLE ); 00086 mInstanceHandleTag = get_tag( ABAQUS_INSTANCE_HANDLE_TAG_NAME, 1, MB_TAG_DENSE, MB_TYPE_HANDLE ); 00087 mAssemblyHandleTag = get_tag( ABAQUS_ASSEMBLY_HANDLE_TAG_NAME, 1, MB_TAG_DENSE, MB_TYPE_HANDLE ); 00088 mInstancePIDTag = get_tag( ABAQUS_INSTANCE_PART_ID_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER ); 00089 mInstanceGIDTag = get_tag( ABAQUS_INSTANCE_GLOBAL_ID_TAG_NAME, 1, MB_TAG_SPARSE, MB_TYPE_INTEGER, &negone ); 00090 mLocalIDTag = get_tag( ABAQUS_LOCAL_ID_TAG_NAME, 1, MB_TAG_DENSE, MB_TYPE_INTEGER ); 00091 mSetNameTag = get_tag( ABAQUS_SET_NAME_TAG_NAME, ABAQUS_SET_NAME_LENGTH, MB_TAG_SPARSE, MB_TYPE_OPAQUE, 0 ); 00092 mMatNameTag = get_tag( ABAQUS_MAT_NAME_TAG_NAME, ABAQUS_MAT_NAME_LENGTH, MB_TAG_SPARSE, MB_TYPE_OPAQUE, 0 ); 00093 } 00094 00095 void ReadABAQUS::reset() {} 00096 00097 ReadABAQUS::~ReadABAQUS() 00098 { 00099 mdbImpl->release_interface( readMeshIface ); 00100 if( abFile.fail() ) abFile.close(); 00101 } 00102 00103 /* 00104 00105 ErrorCode ReadABAQUS::check_file_stats() 00106 * check for existence of file 00107 * initialize meshsets, and offsets if necessary 00108 00109 */ 00110 00111 ErrorCode ReadABAQUS::read_tag_values( const char* /* file_name */, 00112 const char* /* tag_name */, 00113 const FileOptions& /* opts */, 00114 std::vector< int >& /* tag_values_out */, 00115 const SubsetList* /* subset_list */ ) 00116 { 00117 return MB_NOT_IMPLEMENTED; 00118 } 00119 00120 ErrorCode ReadABAQUS::load_file( const char* abaqus_file_name, 00121 const EntityHandle* file_set_ptr, 00122 const FileOptions& /*opts*/, 00123 const ReaderIface::SubsetList* subset_list, 00124 const Tag* /*file_id_tag*/ ) 00125 { 00126 ErrorCode status; 00127 00128 if( subset_list ) 00129 { 00130 MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for ABAQUS data" ); 00131 } 00132 00133 // Open file 00134 lineNo = 0; 00135 abFile.open( abaqus_file_name ); 00136 if( !abFile ) return MB_FILE_DOES_NOT_EXIST; 00137 00138 bool in_unsupported = false; 00139 00140 EntityHandle file_set; 00141 status = mdbImpl->create_meshset( MESHSET_SET, file_set ); 00142 if( MB_SUCCESS != status ) return status; 00143 00144 next_line_type = get_next_line_type(); 00145 while( next_line_type != abq_eof ) 00146 { 00147 switch( next_line_type ) 00148 { 00149 case abq_keyword_line: 00150 in_unsupported = false; 00151 switch( get_keyword() ) 00152 { 00153 case abq_heading: 00154 // Read header 00155 status = read_heading( file_set ); 00156 break; 00157 case abq_part: 00158 // Read parts until done 00159 status = read_part( file_set ); 00160 break; 00161 case abq_assembly: 00162 // Read assembly (or assemblies?) 00163 status = read_assembly( file_set ); 00164 break; 00165 default: 00166 // Skip reading other content for now 00167 // (e.g. material properties, loads, surface interactions, etc) 00168 in_unsupported = true; 00169 // std::cout << "Ignoring unsupported keyword: " << readline << std::endl; 00170 } 00171 MB_RETURN_IF_FAIL; 00172 break; 00173 case abq_comment_line: 00174 break; 00175 case abq_data_line: 00176 if( !in_unsupported ) 00177 { 00178 MB_SET_ERR( MB_FAILURE, "Expected Keyword" ); 00179 } 00180 break; 00181 default: 00182 MB_SET_ERR( MB_FAILURE, "Invalid/unrecognized line" ); 00183 } 00184 00185 next_line_type = get_next_line_type(); 00186 } 00187 00188 // Temporary??? delete parts 00189 // Get all node sets in part 00190 Range part_sets; 00191 int tag_val = ABQ_PART_SET; 00192 void* tag_data[] = { &tag_val }; 00193 status = mdbImpl->get_entities_by_type_and_tag( file_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, part_sets ); 00194 MB_RETURN_IF_FAIL; 00195 00196 for( Range::iterator part_set = part_sets.begin(); part_set != part_sets.end(); ++part_set ) 00197 { 00198 Range ent_sets; 00199 tag_val = ABQ_NODE_SET; 00200 tag_data[0] = &tag_val; 00201 00202 status = mdbImpl->get_entities_by_type_and_tag( *part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, ent_sets ); 00203 MB_RETURN_IF_FAIL; 00204 00205 status = mdbImpl->delete_entities( ent_sets ); 00206 MB_RETURN_IF_FAIL; 00207 00208 tag_val = ABQ_ELEMENT_SET; 00209 tag_data[0] = &tag_val; 00210 00211 status = mdbImpl->get_entities_by_type_and_tag( *part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, ent_sets ); 00212 MB_RETURN_IF_FAIL; 00213 00214 status = mdbImpl->delete_entities( ent_sets ); 00215 MB_RETURN_IF_FAIL; 00216 00217 Range node_list, ele_list; 00218 status = get_set_elements( *part_set, ele_list ); 00219 MB_RETURN_IF_FAIL; 00220 00221 status = mdbImpl->delete_entities( ele_list ); 00222 MB_RETURN_IF_FAIL; 00223 00224 status = mdbImpl->get_entities_by_dimension( *part_set, 0, node_list ); 00225 MB_RETURN_IF_FAIL; 00226 00227 status = mdbImpl->delete_entities( node_list ); 00228 MB_RETURN_IF_FAIL; 00229 } 00230 00231 if( file_set_ptr ) 00232 { 00233 status = mdbImpl->unite_meshset( *file_set_ptr, file_set ); 00234 MB_RETURN_IF_FAIL; 00235 } 00236 00237 return mdbImpl->delete_entities( &file_set, 1 ); 00238 } 00239 00240 ErrorCode ReadABAQUS::read_heading( EntityHandle /*file_set*/ ) 00241 { 00242 // Current line is only heading token. get next line 00243 next_line_type = get_next_line_type(); 00244 00245 // Perhaps keep first line and tag geometry with title? 00246 00247 while( abq_data_line == next_line_type || abq_comment_line == next_line_type ) 00248 next_line_type = get_next_line_type(); 00249 00250 return MB_SUCCESS; 00251 } 00252 00253 ErrorCode ReadABAQUS::read_assembly( EntityHandle file_set ) 00254 { 00255 ErrorCode status = MB_SUCCESS; 00256 00257 std::vector< std::string > tokens; 00258 std::map< std::string, std::string > params; 00259 std::map< std::string, abaqus_assembly_params > requiredParams; 00260 requiredParams["NAME"] = abq_assembly_name; 00261 00262 std::map< std::string, abaqus_assembly_params > allowableParams; 00263 allowableParams[ABQ_AMBIGUOUS] = abq_assembly_ambiguous; 00264 00265 abaqus_assembly_params param; 00266 00267 std::string assembly_name; 00268 00269 // Tokenize last line read 00270 tokenize( readline, tokens, ",\n" ); 00271 extract_keyword_parameters( tokens, params ); 00272 00273 // Search for required parameters 00274 for( std::map< std::string, abaqus_assembly_params >::iterator thisParam = requiredParams.begin(); 00275 thisParam != requiredParams.end(); ++thisParam ) 00276 { 00277 std::string param_key = match( ( *thisParam ).first, params ); 00278 param = requiredParams[param_key]; 00279 switch( param ) 00280 { 00281 case abq_assembly_name: 00282 assembly_name = params[param_key]; 00283 params.erase( param_key ); 00284 // std::cout << "Adding ASSEMBLY with name: " << assembly_name << std::endl; // 00285 // REMOVE 00286 break; 00287 default: 00288 // std::cout << "Missing required ASSEMBLY parameter " << (*thisParam).first << 00289 // std::endl; 00290 return MB_FAILURE; 00291 } 00292 } 00293 00294 // Process parameters 00295 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 00296 ++thisParam ) 00297 { 00298 // Look for unambiguous match with this node parameter 00299 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 00300 switch( param ) 00301 { 00302 case abq_assembly_ambiguous: 00303 // std::cout << "\tIgnoring ambiguous ASSEMBLY parameter: " << (*thisParam).first 00304 // << "=" << (*thisParam).second << std::endl; 00305 break; 00306 default: 00307 // std::cout << "\tIgnoring unsupported ASSEMBLY parameter: " << (*thisParam).first 00308 // << "=" << (*thisParam).second << std::endl; 00309 break; 00310 } 00311 } 00312 00313 EntityHandle assembly_set; 00314 00315 status = add_entity_set( file_set, ABQ_ASSEMBLY_SET, assembly_name, assembly_set ); 00316 00317 next_line_type = get_next_line_type(); 00318 00319 bool end_assembly = false; 00320 bool in_unsupported = false; 00321 00322 while( next_line_type != abq_eof && !end_assembly ) 00323 { 00324 switch( next_line_type ) 00325 { 00326 case abq_keyword_line: 00327 in_unsupported = false; 00328 switch( get_keyword() ) 00329 { 00330 case abq_end_assembly: 00331 end_assembly = true; 00332 break; 00333 case abq_instance: 00334 status = read_instance( assembly_set, file_set ); 00335 break; 00336 case abq_nset: 00337 status = read_node_set( assembly_set, file_set ); 00338 break; 00339 default: 00340 in_unsupported = true; 00341 // std::cout << "\tIgnoring unsupported keyword in this ASSEMBLY: " 00342 // << readline << std::endl; 00343 next_line_type = get_next_line_type(); 00344 break; 00345 } 00346 break; 00347 case abq_comment_line: 00348 next_line_type = get_next_line_type(); 00349 break; 00350 case abq_data_line: 00351 if( !in_unsupported ) 00352 { 00353 // std::cout << "Internal Error: Data lines not allowed in ASSEMBLY keyword." 00354 // << std::endl << readline << std::endl; 00355 return MB_FAILURE; 00356 } 00357 next_line_type = get_next_line_type(); 00358 break; 00359 case abq_blank_line: 00360 // std::cout << "Error: Blank lines are not allowed." << std::endl; 00361 return MB_FAILURE; 00362 default: 00363 // std::cout << "Error reading ASSEMBLY " << assembly_name << std::endl; 00364 return MB_FAILURE; 00365 } 00366 MB_RETURN_IF_FAIL; 00367 } 00368 00369 num_assembly_instances[assembly_set] = 0; 00370 00371 return MB_SUCCESS; 00372 } 00373 00374 ErrorCode ReadABAQUS::read_instance( EntityHandle assembly_set, EntityHandle file_set ) 00375 { 00376 ErrorCode status = MB_SUCCESS; 00377 00378 std::vector< std::string > tokens; 00379 std::map< std::string, std::string > params; 00380 std::map< std::string, abaqus_instance_params > requiredParams; 00381 requiredParams["NAME"] = abq_instance_name; 00382 requiredParams["PART"] = abq_instance_part; 00383 00384 std::map< std::string, abaqus_instance_params > allowableParams; 00385 allowableParams[ABQ_AMBIGUOUS] = abq_instance_ambiguous; 00386 00387 abaqus_instance_params param; 00388 00389 std::string instance_name, part_name; 00390 00391 // Tokenize last line read 00392 tokenize( readline, tokens, ",\n" ); 00393 extract_keyword_parameters( tokens, params ); 00394 00395 // Search for required parameters 00396 for( std::map< std::string, abaqus_instance_params >::iterator thisParam = requiredParams.begin(); 00397 thisParam != requiredParams.end(); ++thisParam ) 00398 { 00399 std::string param_key = match( ( *thisParam ).first, params ); 00400 param = requiredParams[param_key]; 00401 switch( param ) 00402 { 00403 case abq_instance_name: 00404 instance_name = params[param_key]; 00405 params.erase( param_key ); 00406 break; 00407 case abq_instance_part: 00408 part_name = params[param_key]; 00409 params.erase( param_key ); 00410 break; 00411 default: 00412 // std::cout << "Missing required INSTANCE parameter " << (*thisParam).first << 00413 // std::endl; 00414 return MB_FAILURE; 00415 } 00416 } 00417 // std::cout << "\tAdding INSTANCE with name: " << instance_name << " of PART wit name: " << 00418 // part_name << std::endl; // REMOVE 00419 00420 // Process parameters 00421 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 00422 ++thisParam ) 00423 { 00424 // Look for unambiguous match with this node parameter 00425 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 00426 switch( param ) 00427 { 00428 case abq_instance_ambiguous: 00429 // std::cout << "\t\tIgnoring ambiguous INSTANCE parameter: " << (*thisParam).first 00430 // << "=" << (*thisParam).second << std::endl; 00431 break; 00432 default: 00433 // std::cout << "\t\tIgnoring unsupported INSTANCE parameter: " << 00434 // (*thisParam).first 00435 // << "=" << (*thisParam).second << std::endl; 00436 break; 00437 } 00438 } 00439 00440 next_line_type = get_next_line_type(); 00441 00442 bool read_translation = false; 00443 bool read_rotation = false; 00444 std::vector< double > translation( 3, 0 ); 00445 std::vector< double > rotation( 7, 0 ); 00446 bool end_instance = false; 00447 bool in_unsupported = false; 00448 00449 EntityHandle instance_set; 00450 status = add_entity_set( assembly_set, ABQ_INSTANCE_SET, instance_name, instance_set ); 00451 MB_RETURN_IF_FAIL; 00452 00453 while( next_line_type != abq_eof && !end_instance ) 00454 { 00455 switch( next_line_type ) 00456 { 00457 case abq_keyword_line: 00458 in_unsupported = false; 00459 switch( get_keyword() ) 00460 { 00461 case abq_end_instance: 00462 end_instance = true; 00463 next_line_type = get_next_line_type(); 00464 break; 00465 case abq_node: 00466 status = read_node_list( instance_set, assembly_set ); 00467 break; 00468 case abq_element: 00469 status = read_element_list( instance_set, assembly_set ); 00470 break; 00471 case abq_nset: 00472 status = read_node_set( instance_set, file_set, assembly_set ); 00473 break; 00474 case abq_elset: 00475 status = read_element_set( instance_set, file_set, assembly_set ); 00476 break; 00477 case abq_solid_section: 00478 status = read_solid_section( instance_set ); 00479 break; 00480 default: 00481 in_unsupported = true; 00482 // std::cout << "\t\tIgnoring unsupported keyword in this INSTANCE: " 00483 // << readline << std::endl; 00484 next_line_type = get_next_line_type(); 00485 break; 00486 } 00487 break; 00488 case abq_comment_line: 00489 next_line_type = get_next_line_type(); 00490 break; 00491 case abq_data_line: 00492 if( !in_unsupported ) 00493 { 00494 tokenize( readline, tokens, ", \n" ); 00495 if( !read_translation ) 00496 { 00497 if( tokens.size() != 3 ) 00498 { 00499 MB_SET_ERR( MB_FAILURE, "Wrong number of entries on INSTANCE translation line" ); 00500 } 00501 00502 for( unsigned int i = 0; i < 3; i++ ) 00503 translation[i] = atof( tokens[i].c_str() ); 00504 00505 read_translation = true; 00506 } 00507 else if( !read_rotation ) 00508 { 00509 if( tokens.size() != 7 ) 00510 { 00511 MB_SET_ERR( MB_FAILURE, "Wrong number of entries on INSTANCE rotation line" ); 00512 } 00513 for( unsigned int i = 0; i < 7; i++ ) 00514 rotation[i] = atof( tokens[i].c_str() ); 00515 00516 read_rotation = true; 00517 } 00518 else 00519 { 00520 MB_SET_ERR( MB_FAILURE, "Too many data lines for this INSTANCE" ); 00521 } 00522 } // if (!in_unsupported) 00523 next_line_type = get_next_line_type(); 00524 break; 00525 case abq_blank_line: 00526 MB_SET_ERR( MB_FAILURE, "Error: Blank lines are not allowed" ); 00527 default: 00528 MB_SET_ERR( MB_FAILURE, "Error reading INSTANCE" ); 00529 } // switch (next_line_type) 00530 } // while (next_line_type != abq_eof && !end_instance) 00531 00532 status = create_instance_of_part( file_set, assembly_set, part_name, instance_name, instance_set, translation, 00533 rotation ); 00534 MB_RETURN_IF_FAIL; 00535 00536 return MB_SUCCESS; 00537 } 00538 00539 ErrorCode ReadABAQUS::read_part( EntityHandle file_set ) 00540 { 00541 ErrorCode status = MB_SUCCESS; 00542 00543 std::vector< std::string > tokens; 00544 std::map< std::string, std::string > params; 00545 std::map< std::string, abaqus_part_params > requiredParams; 00546 requiredParams["NAME"] = abq_part_name; 00547 00548 std::map< std::string, abaqus_part_params > allowableParams; 00549 allowableParams[ABQ_AMBIGUOUS] = abq_part_ambiguous; 00550 00551 abaqus_part_params param; 00552 00553 std::string part_name; 00554 00555 // Tokenize last line read 00556 tokenize( readline, tokens, ",\n" ); 00557 extract_keyword_parameters( tokens, params ); 00558 00559 // Search for required parameters 00560 for( std::map< std::string, abaqus_part_params >::iterator thisParam = requiredParams.begin(); 00561 thisParam != requiredParams.end(); ++thisParam ) 00562 { 00563 std::string param_key = match( ( *thisParam ).first, params ); 00564 param = requiredParams[param_key]; 00565 switch( param ) 00566 { 00567 case abq_part_name: 00568 part_name = params[param_key]; 00569 params.erase( param_key ); 00570 // std::cout << "Adding PART with name: " << part_name << std::endl; // REMOVE 00571 break; 00572 default: 00573 MB_SET_ERR( MB_FAILURE, "Missing required PART parameter" ); 00574 } 00575 } 00576 00577 // Process parameters 00578 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 00579 ++thisParam ) 00580 { 00581 // Look for unambiguous match with this node parameter 00582 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 00583 switch( param ) 00584 { 00585 case abq_part_ambiguous: 00586 // std::cout << "\tIgnoring ambiguous PART parameter: " << (*thisParam).first 00587 // << "=" << (*thisParam).second << std::endl; 00588 break; 00589 default: 00590 // std::cout << "\tIgnoring unsupported PART parameter: " << (*thisParam).first 00591 // << "=" << (*thisParam).second << std::endl; 00592 break; 00593 } 00594 } 00595 00596 EntityHandle part_set; 00597 00598 status = add_entity_set( file_set, ABQ_PART_SET, part_name, part_set ); 00599 00600 next_line_type = get_next_line_type(); 00601 00602 bool end_part = false; 00603 bool in_unsupported = false; 00604 00605 while( next_line_type != abq_eof && !end_part ) 00606 { 00607 switch( next_line_type ) 00608 { 00609 case abq_keyword_line: 00610 in_unsupported = false; 00611 switch( get_keyword() ) 00612 { 00613 case abq_end_part: 00614 end_part = true; 00615 break; 00616 case abq_node: 00617 status = read_node_list( part_set ); 00618 break; 00619 case abq_element: 00620 status = read_element_list( part_set ); 00621 break; 00622 case abq_nset: 00623 status = read_node_set( part_set ); 00624 break; 00625 case abq_elset: 00626 status = read_element_set( part_set ); 00627 break; 00628 case abq_solid_section: 00629 status = read_solid_section( part_set ); 00630 break; 00631 default: 00632 in_unsupported = true; 00633 // std::cout << "\tIgnoring unsupported keyword in this PART: " 00634 // << readline << std::endl; 00635 next_line_type = get_next_line_type(); 00636 break; 00637 } 00638 MB_RETURN_IF_FAIL; 00639 break; 00640 case abq_comment_line: 00641 next_line_type = get_next_line_type(); 00642 break; 00643 case abq_data_line: 00644 if( !in_unsupported ) 00645 { 00646 MB_SET_ERR( MB_FAILURE, "Data lines not allowed in PART keyword" ); 00647 } 00648 next_line_type = get_next_line_type(); 00649 break; 00650 case abq_blank_line: 00651 MB_SET_ERR( MB_FAILURE, "Blank lines are not allowed" ); 00652 default: 00653 MB_SET_ERR( MB_FAILURE, "Error reading PART" ); 00654 } 00655 } 00656 00657 num_part_instances[part_set] = 0; 00658 00659 return MB_SUCCESS; 00660 } 00661 00662 ErrorCode ReadABAQUS::read_solid_section( EntityHandle parent_set ) 00663 { 00664 ErrorCode status; 00665 00666 std::vector< std::string > tokens; 00667 std::map< std::string, std::string > params; 00668 std::map< std::string, abaqus_solid_section_params > requiredParams; 00669 requiredParams["ELSET"] = abq_solid_section_elset; 00670 requiredParams["MATERIAL"] = abq_solid_section_matname; 00671 00672 std::map< std::string, abaqus_solid_section_params > allowableParams; 00673 allowableParams[ABQ_AMBIGUOUS] = abq_solid_section_ambiguous; 00674 00675 abaqus_solid_section_params param; 00676 00677 // Tokenize last line read 00678 tokenize( readline, tokens, ",\n" ); 00679 extract_keyword_parameters( tokens, params ); 00680 00681 std::string elset_name, mat_name; 00682 00683 // Search for required parameters 00684 for( std::map< std::string, abaqus_solid_section_params >::iterator thisParam = requiredParams.begin(); 00685 thisParam != requiredParams.end(); ++thisParam ) 00686 { 00687 std::string param_key = match( ( *thisParam ).first, params ); 00688 param = requiredParams[param_key]; 00689 switch( param ) 00690 { 00691 case abq_solid_section_elset: 00692 elset_name = params[param_key]; 00693 params.erase( param_key ); 00694 break; 00695 case abq_solid_section_matname: 00696 mat_name = params[param_key]; 00697 params.erase( param_key ); 00698 break; 00699 default: 00700 MB_SET_ERR( MB_FAILURE, "Missing required SOLID SECTION parameter" ); 00701 } 00702 } 00703 // std::cout << "\tAdding SOLID SECTION with to ELEMENT SET: " << elset_name << " with material: 00704 // " << mat_name << std::endl; // REMOVE 00705 00706 // Process parameters 00707 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 00708 ++thisParam ) 00709 { 00710 // Look for unambiguous match with this node parameter 00711 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 00712 switch( param ) 00713 { 00714 case abq_solid_section_ambiguous: 00715 // std::cout << "\t\tIgnoring ambiguous SOLID_SECTION parameter: " << 00716 // (*thisParam).first 00717 // << "=" << (*thisParam).second << std::endl; 00718 break; 00719 default: 00720 // std::cout << "\t\tIgnoring unsupported SOLID_SECTION parameter: " << 00721 // (*thisParam).first 00722 // << "=" << (*thisParam).second << std::endl; 00723 break; 00724 } 00725 } 00726 00727 EntityHandle set_handle; 00728 status = get_set_by_name( parent_set, ABQ_ELEMENT_SET, elset_name, set_handle ); 00729 MB_RETURN_IF_FAIL; 00730 00731 status = mdbImpl->tag_set_data( mMatNameTag, &set_handle, 1, mat_name.c_str() ); 00732 MB_RETURN_IF_FAIL; 00733 00734 if( 0 == matIDmap[mat_name] ) matIDmap[mat_name] = ++mat_id; 00735 00736 status = mdbImpl->tag_set_data( mMaterialSetTag, &set_handle, 1, &( matIDmap[mat_name] ) ); 00737 MB_RETURN_IF_FAIL; 00738 00739 next_line_type = get_next_line_type(); 00740 00741 while( next_line_type != abq_eof && next_line_type != abq_keyword_line ) 00742 next_line_type = get_next_line_type(); 00743 00744 return MB_SUCCESS; 00745 } 00746 00747 ErrorCode ReadABAQUS::read_element_set( EntityHandle parent_set, EntityHandle file_set, EntityHandle assembly_set ) 00748 { 00749 ErrorCode status; 00750 00751 std::vector< std::string > tokens; 00752 std::map< std::string, std::string > params; 00753 std::map< std::string, abaqus_elset_params > requiredParams; 00754 requiredParams["ELSET"] = abq_elset_elset; 00755 00756 std::map< std::string, abaqus_elset_params > allowableParams; 00757 allowableParams[ABQ_AMBIGUOUS] = abq_elset_ambiguous; 00758 allowableParams["GENERATE"] = abq_elset_generate; 00759 allowableParams["INSTANCE"] = abq_elset_instance; 00760 00761 abaqus_elset_params param; 00762 00763 std::string elset_name; 00764 bool generate_elset = false; 00765 std::string instance_name; 00766 EntityHandle element_container_set = parent_set; 00767 00768 // Tokenize last line read 00769 tokenize( readline, tokens, ",\n" ); 00770 extract_keyword_parameters( tokens, params ); 00771 00772 Range element_range; 00773 00774 // Search for required parameters 00775 for( std::map< std::string, abaqus_elset_params >::iterator thisParam = requiredParams.begin(); 00776 thisParam != requiredParams.end(); ++thisParam ) 00777 { 00778 std::string param_key = match( ( *thisParam ).first, params ); 00779 param = requiredParams[param_key]; 00780 switch( param ) 00781 { 00782 case abq_elset_elset: 00783 elset_name = params[param_key]; 00784 params.erase( param_key ); 00785 // std::cout << "\tAdding ELSET with name: " << elset_name << std::endl; // REMOVE 00786 break; 00787 default: 00788 MB_SET_ERR( MB_FAILURE, "Missing required ELSET parameter" ); 00789 } 00790 } 00791 00792 // Process parameters 00793 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 00794 ++thisParam ) 00795 { 00796 // Look for unambiguous match with this node parameter 00797 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 00798 switch( param ) 00799 { 00800 case abq_elset_generate: 00801 generate_elset = true; 00802 break; 00803 case abq_elset_instance: 00804 instance_name = ( *thisParam ).second; 00805 status = get_set_by_name( parent_set, ABQ_INSTANCE_SET, instance_name, element_container_set ); 00806 MB_RETURN_IF_FAIL; 00807 break; 00808 case abq_elset_ambiguous: 00809 // std::cout << "\t\tIgnoring ambiguous ELSET parameter: " << (*thisParam).first 00810 // << "=" << (*thisParam).second << std::endl; 00811 break; 00812 default: 00813 // std::cout << "\t\tIgnoring unsupported ELSET parameter: " << (*thisParam).first 00814 // << "=" << (*thisParam).second << std::endl; 00815 break; 00816 } 00817 } 00818 00819 std::vector< int > element_list; 00820 Range tmp_element_range; 00821 00822 next_line_type = get_next_line_type(); 00823 00824 while( next_line_type != abq_eof && next_line_type != abq_keyword_line ) 00825 { 00826 if( abq_data_line == next_line_type ) 00827 { 00828 tokenize( readline, tokens, ", \n" ); 00829 if( generate_elset ) 00830 { 00831 if( tokens.size() != 3 ) 00832 { 00833 MB_SET_ERR( MB_FAILURE, "Wrong number of entries on GENERATE element set data line" ); 00834 } 00835 int e1 = atoi( tokens[0].c_str() ); 00836 int e2 = atoi( tokens[1].c_str() ); 00837 int incr = atoi( tokens[2].c_str() ); 00838 if( ( incr == 0 ) || ( ( ( e2 - e1 ) % incr ) != 0 ) ) 00839 { 00840 MB_SET_ERR( MB_FAILURE, "Invalid data on GENERATE element set data line" ); 00841 } 00842 for( int element_id = e1; element_id <= e2; element_id += incr ) 00843 element_list.push_back( element_id ); 00844 } 00845 else 00846 { 00847 for( unsigned int idx = 0; idx < tokens.size(); idx++ ) 00848 { 00849 if( isalpha( tokens[idx][0] ) ) 00850 { 00851 tmp_element_range.clear(); 00852 status = get_set_elements_by_name( element_container_set, ABQ_ELEMENT_SET, tokens[idx], 00853 tmp_element_range ); 00854 MB_RETURN_IF_FAIL; 00855 00856 element_range.merge( tmp_element_range ); 00857 } 00858 else 00859 element_list.push_back( atoi( tokens[idx].c_str() ) ); 00860 } 00861 } 00862 } // if (abq_data_line == next_line_type) 00863 00864 next_line_type = get_next_line_type(); 00865 } // while (next_line_type != abq_eof && next_line_type != abq_keyword_line) 00866 00867 tmp_element_range.clear(); 00868 status = get_elements_by_id( element_container_set, element_list, tmp_element_range ); 00869 MB_RETURN_IF_FAIL; 00870 00871 element_range.merge( tmp_element_range ); 00872 00873 EntityHandle element_set; 00874 00875 status = add_entity_set( parent_set, ABQ_ELEMENT_SET, elset_name, element_set ); 00876 MB_RETURN_IF_FAIL; 00877 00878 status = mdbImpl->add_entities( element_set, element_range ); 00879 MB_RETURN_IF_FAIL; 00880 00881 // SHOULD WE EVER DO THIS??? 00882 if( file_set ) 00883 { 00884 status = mdbImpl->add_entities( file_set, &element_set, 1 ); 00885 MB_RETURN_IF_FAIL; 00886 } 00887 00888 // SHOULD WE EVER DO THIS??? 00889 if( assembly_set ) 00890 { 00891 status = mdbImpl->add_entities( assembly_set, &element_set, 1 ); 00892 MB_RETURN_IF_FAIL; 00893 00894 status = mdbImpl->tag_set_data( mAssemblyHandleTag, &element_set, 1, &assembly_set ); 00895 MB_RETURN_IF_FAIL; 00896 } 00897 00898 return MB_SUCCESS; 00899 } 00900 00901 ErrorCode ReadABAQUS::read_node_set( EntityHandle parent_set, EntityHandle file_set, EntityHandle assembly_set ) 00902 { 00903 ErrorCode status; 00904 00905 std::vector< std::string > tokens; 00906 std::map< std::string, std::string > params; 00907 std::map< std::string, abaqus_nset_params > requiredParams; 00908 requiredParams["NSET"] = abq_nset_nset; 00909 00910 std::map< std::string, abaqus_nset_params > allowableParams; 00911 allowableParams[ABQ_AMBIGUOUS] = abq_nset_ambiguous; 00912 allowableParams["ELSET"] = abq_nset_elset; 00913 allowableParams["GENERATE"] = abq_nset_generate; 00914 allowableParams["INSTANCE"] = abq_nset_instance; 00915 00916 abaqus_nset_params param; 00917 00918 std::string nset_name; 00919 bool make_from_elset = false; 00920 bool generate_nset = false; 00921 std::string elset_name, instance_name; 00922 EntityHandle node_container_set = parent_set; 00923 00924 // Tokenize last line read 00925 tokenize( readline, tokens, ",\n" ); 00926 extract_keyword_parameters( tokens, params ); 00927 00928 Range node_range; 00929 00930 // Search for required parameters 00931 for( std::map< std::string, abaqus_nset_params >::iterator thisParam = requiredParams.begin(); 00932 thisParam != requiredParams.end(); ++thisParam ) 00933 { 00934 std::string param_key = match( ( *thisParam ).first, params ); 00935 param = requiredParams[param_key]; 00936 switch( param ) 00937 { 00938 case abq_nset_nset: 00939 nset_name = params[param_key]; 00940 params.erase( param_key ); 00941 // std::cout << "\tAdding NSET with name: " << nset_name << std::endl; // REMOVE 00942 break; 00943 default: 00944 MB_SET_ERR( MB_FAILURE, "Missing required NSET parameter" ); 00945 } 00946 } 00947 00948 // Process parameters 00949 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 00950 ++thisParam ) 00951 { 00952 // Look for unambiguous match with this node parameter 00953 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 00954 switch( param ) 00955 { 00956 case abq_nset_elset: 00957 make_from_elset = true; 00958 elset_name = ( *thisParam ).second; 00959 break; 00960 case abq_nset_generate: 00961 generate_nset = true; 00962 break; 00963 case abq_nset_instance: 00964 instance_name = ( *thisParam ).second; 00965 status = get_set_by_name( parent_set, ABQ_INSTANCE_SET, instance_name, node_container_set ); 00966 MB_RETURN_IF_FAIL; 00967 break; 00968 case abq_nset_ambiguous: 00969 // std::cout << "\t\tIgnoring ambiguous NSET parameter: " << (*thisParam).first 00970 // << "=" << (*thisParam).second << std::endl; 00971 break; 00972 default: 00973 // std::cout << "\t\tIgnoring unsupported NSET parameter: " << (*thisParam).first 00974 // << "=" << (*thisParam).second << std::endl; 00975 break; 00976 } 00977 } 00978 00979 if( make_from_elset && generate_nset ) 00980 { 00981 MB_SET_ERR( MB_FAILURE, "Incompatible NSET parameters ELSET & GENERATE" ); 00982 } 00983 00984 if( make_from_elset ) 00985 { 00986 status = get_set_nodes( parent_set, ABQ_ELEMENT_SET, elset_name, node_range ); 00987 MB_RETURN_IF_FAIL; 00988 } 00989 else 00990 { 00991 std::vector< int > node_list; 00992 Range tmp_node_range; 00993 00994 next_line_type = get_next_line_type(); 00995 00996 while( next_line_type != abq_eof && next_line_type != abq_keyword_line ) 00997 { 00998 if( abq_data_line == next_line_type ) 00999 { 01000 tokenize( readline, tokens, ", \n" ); 01001 if( generate_nset ) 01002 { 01003 if( tokens.size() != 3 ) 01004 { 01005 MB_SET_ERR( MB_FAILURE, "Wrong number of entries on GENERATE node set data line" ); 01006 } 01007 int n1 = atoi( tokens[0].c_str() ); 01008 int n2 = atoi( tokens[1].c_str() ); 01009 int incr = atoi( tokens[2].c_str() ); 01010 if( ( incr == 0 ) || ( ( ( n2 - n1 ) % incr ) != 0 ) ) 01011 { 01012 MB_SET_ERR( MB_FAILURE, "Invalid data on GENERATE node set data line" ); 01013 } 01014 for( int node_id = n1; node_id <= n2; node_id += incr ) 01015 node_list.push_back( node_id ); 01016 } 01017 else 01018 { 01019 for( unsigned int idx = 0; idx < tokens.size(); idx++ ) 01020 { 01021 if( isalpha( tokens[idx][0] ) ) 01022 { 01023 tmp_node_range.clear(); 01024 status = get_set_nodes( parent_set, ABQ_NODE_SET, tokens[idx], tmp_node_range ); 01025 MB_RETURN_IF_FAIL; 01026 01027 node_range.merge( tmp_node_range ); 01028 } 01029 else 01030 node_list.push_back( atoi( tokens[idx].c_str() ) ); 01031 } 01032 } 01033 } // if (abq_data_line == next_line_type) 01034 01035 next_line_type = get_next_line_type(); 01036 } // while (next_line_type != abq_eof && next_line_type != abq_keyword_line) 01037 01038 tmp_node_range.clear(); 01039 01040 status = get_nodes_by_id( node_container_set, node_list, tmp_node_range ); 01041 MB_RETURN_IF_FAIL; 01042 01043 node_range.merge( tmp_node_range ); 01044 } 01045 01046 EntityHandle node_set; 01047 01048 status = add_entity_set( parent_set, ABQ_NODE_SET, nset_name, node_set ); 01049 MB_RETURN_IF_FAIL; 01050 01051 status = mdbImpl->add_entities( node_set, node_range ); 01052 MB_RETURN_IF_FAIL; 01053 01054 if( file_set ) 01055 { 01056 status = mdbImpl->add_entities( file_set, &node_set, 1 ); 01057 MB_RETURN_IF_FAIL; 01058 } 01059 01060 if( assembly_set ) 01061 { 01062 status = mdbImpl->add_entities( assembly_set, &node_set, 1 ); 01063 MB_RETURN_IF_FAIL; 01064 01065 status = mdbImpl->tag_set_data( mAssemblyHandleTag, &node_set, 1, &assembly_set ); 01066 MB_RETURN_IF_FAIL; 01067 } 01068 01069 return MB_SUCCESS; 01070 } 01071 01072 ErrorCode ReadABAQUS::read_element_list( EntityHandle parent_set, EntityHandle assembly_set ) 01073 { 01074 ErrorCode status; 01075 01076 std::vector< std::string > tokens; 01077 std::map< std::string, std::string > params; 01078 std::map< std::string, abaqus_element_params > requiredParams; 01079 requiredParams["TYPE"] = abq_element_type; 01080 01081 std::map< std::string, abaqus_element_params > allowableParams; 01082 allowableParams[ABQ_AMBIGUOUS] = abq_element_ambiguous; 01083 allowableParams["ELSET"] = abq_element_elset; 01084 01085 abaqus_element_params param; 01086 01087 std::map< std::string, abaqus_element_type > elementTypes; 01088 std::map< abaqus_element_type, unsigned int > nodes_per_element; 01089 std::map< abaqus_element_type, EntityType > entityTypeMap; 01090 elementTypes["DC3D8"] = abq_eletype_dc3d8; 01091 nodes_per_element[abq_eletype_dc3d8] = 8; 01092 entityTypeMap[abq_eletype_dc3d8] = MBHEX; 01093 01094 elementTypes["DCC3D8"] = abq_eletype_dcc3d8; 01095 nodes_per_element[abq_eletype_dcc3d8] = 8; 01096 entityTypeMap[abq_eletype_dcc3d8] = MBHEX; 01097 01098 elementTypes["C3D4"] = abq_eletype_c3d4; 01099 nodes_per_element[abq_eletype_c3d4] = 4; 01100 entityTypeMap[abq_eletype_c3d4] = MBTET; 01101 01102 elementTypes["DC3D4"] = abq_eletype_dc3d4; 01103 nodes_per_element[abq_eletype_dc3d4] = 4; 01104 entityTypeMap[abq_eletype_dc3d4] = MBTET; 01105 01106 elementTypes["C3D8R"] = abq_eletype_c3d8r; 01107 nodes_per_element[abq_eletype_c3d8r] = 8; 01108 entityTypeMap[abq_eletype_c3d8r] = MBHEX; 01109 01110 elementTypes["DS4"] = abq_eletype_ds4; 01111 nodes_per_element[abq_eletype_ds4] = 4; 01112 entityTypeMap[abq_eletype_ds4] = MBQUAD; 01113 01114 abaqus_element_type element_type = abq_eletype_dc3d8; 01115 01116 bool make_element_set = false; 01117 std::string element_set_name; 01118 01119 // Tokenize last line read 01120 tokenize( readline, tokens, ",\n" ); 01121 extract_keyword_parameters( tokens, params ); 01122 01123 // Search for required parameters 01124 for( std::map< std::string, abaqus_element_params >::iterator thisParam = requiredParams.begin(); 01125 thisParam != requiredParams.end(); ++thisParam ) 01126 { 01127 std::string param_key = match( ( *thisParam ).first, params ); 01128 param = requiredParams[param_key]; 01129 switch( param ) 01130 { 01131 case abq_element_type: 01132 element_type = elementTypes[params[param_key]]; 01133 if( abq_eletype_unsupported == element_type ) 01134 { 01135 MB_SET_ERR( MB_FAILURE, "MOAB doesn't currently support this element type" ); 01136 } 01137 // std::cout << "\tAdding ELEMENTS of type: " << params[param_key] << std::endl; // 01138 // REMOVE 01139 params.erase( param_key ); 01140 break; 01141 case abq_element_undefined: 01142 MB_SET_ERR( MB_FAILURE, "Missing required ELEMENT parameter" ); 01143 default: 01144 break; 01145 } 01146 } 01147 01148 // Process parameters 01149 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 01150 ++thisParam ) 01151 { 01152 // Look for unambiguous match with this node parameter 01153 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 01154 switch( param ) 01155 { 01156 case abq_element_elset: 01157 make_element_set = true; 01158 element_set_name = ( *thisParam ).second; 01159 break; 01160 case abq_element_ambiguous: 01161 // std::cout << "\t\tIgnoring ambiguous ELEMENT parameter: " << (*thisParam).first 01162 // << "=" << (*thisParam).second << std::endl; 01163 break; 01164 default: 01165 // std::cout << "\t\tIgnoring unsupported ELEMENT parameter: " << (*thisParam).first 01166 // << "=" << (*thisParam).second << std::endl; 01167 break; 01168 } 01169 } 01170 01171 std::vector< int > connect_list, element_ids; 01172 01173 next_line_type = get_next_line_type(); 01174 01175 while( next_line_type != abq_eof && next_line_type != abq_keyword_line ) 01176 { 01177 if( abq_data_line == next_line_type ) 01178 { 01179 tokenize( readline, tokens, ", \n" ); 01180 if( tokens.size() < nodes_per_element[element_type] + 1 ) 01181 { 01182 MB_SET_ERR( MB_FAILURE, "Not enough data on node data line" ); 01183 } 01184 element_ids.push_back( atoi( tokens[0].c_str() ) ); 01185 for( unsigned int i = 1; i < nodes_per_element[element_type] + 1; i++ ) 01186 connect_list.push_back( atoi( tokens[i].c_str() ) ); 01187 } 01188 01189 next_line_type = get_next_line_type(); 01190 } 01191 01192 int num_elements = element_ids.size(); 01193 01194 // Get and fill element arrays 01195 EntityHandle start_element = 0; 01196 EntityHandle* connect; 01197 01198 status = readMeshIface->get_element_connect( num_elements, nodes_per_element[element_type], 01199 entityTypeMap[element_type], MB_START_ID, start_element, connect ); 01200 MB_RETURN_IF_FAIL; 01201 if( 0 == start_element ) return MB_FAILURE; 01202 01203 // ASSUME: elements must be defined after nodes! 01204 // Get list of node entity handles and node IDs 01205 Range node_list; 01206 status = mdbImpl->get_entities_by_dimension( parent_set, 0, node_list ); 01207 MB_RETURN_IF_FAIL; 01208 01209 std::vector< int > node_ids( node_list.size() ); 01210 status = mdbImpl->tag_get_data( mLocalIDTag, node_list, &node_ids[0] ); 01211 MB_RETURN_IF_FAIL; 01212 01213 std::map< int, EntityHandle > nodeIdMap; 01214 for( unsigned int idx = 0; idx < node_list.size(); idx++ ) 01215 nodeIdMap[node_ids[idx]] = node_list[idx]; 01216 01217 for( unsigned int node = 0; node < connect_list.size(); node++ ) 01218 connect[node] = nodeIdMap[connect_list[node]]; 01219 01220 Range element_range( start_element, start_element + num_elements - 1 ); 01221 01222 // Add elements to file_set 01223 // status = mdbImpl->add_entities(file_set, element_range); 01224 // MB_RETURN_IF_FAIL; 01225 01226 // Add elements to this parent_set 01227 status = mdbImpl->add_entities( parent_set, element_range ); 01228 MB_RETURN_IF_FAIL; 01229 01230 // Tag elements with their local ID's 01231 status = mdbImpl->tag_set_data( mLocalIDTag, element_range, &element_ids[0] ); 01232 MB_RETURN_IF_FAIL; 01233 01234 if( assembly_set ) 01235 { 01236 status = mdbImpl->add_entities( assembly_set, element_range ); 01237 MB_RETURN_IF_FAIL; 01238 01239 std::vector< EntityHandle > tmp_assembly_handles; 01240 tmp_assembly_handles.assign( element_range.size(), assembly_set ); 01241 status = mdbImpl->tag_set_data( mAssemblyHandleTag, element_range, &( tmp_assembly_handles[0] ) ); 01242 MB_RETURN_IF_FAIL; 01243 } 01244 01245 // These elements don't know their instance_set (probably not defined) 01246 01247 if( make_element_set ) 01248 { 01249 EntityHandle element_set; 01250 01251 status = add_entity_set( parent_set, ABQ_ELEMENT_SET, element_set_name, element_set ); 01252 MB_RETURN_IF_FAIL; 01253 01254 status = mdbImpl->add_entities( element_set, element_range ); 01255 MB_RETURN_IF_FAIL; 01256 01257 // This ad-hoc element set doesn't know its: 01258 // * part_set (probably parent_set) 01259 // * instance_set (probably not defined) 01260 // * assembly_set (probably not defined) 01261 } 01262 01263 return MB_SUCCESS; 01264 } 01265 01266 ErrorCode ReadABAQUS::read_node_list( EntityHandle parent_set, EntityHandle assembly_set ) 01267 { 01268 ErrorCode status; 01269 01270 std::vector< std::string > tokens; 01271 std::map< std::string, std::string > params; 01272 std::map< std::string, abaqus_node_params > allowableParams; 01273 01274 allowableParams[ABQ_AMBIGUOUS] = abq_node_ambiguous; 01275 allowableParams["NSET"] = abq_node_nset; 01276 allowableParams["SYSTEM"] = abq_node_system; 01277 01278 abaqus_node_params param; 01279 01280 bool make_node_set = false; 01281 std::string node_set_name; 01282 01283 char coord_system = 'R'; 01284 01285 // Tokenize last line read 01286 tokenize( readline, tokens, ",\n" ); 01287 extract_keyword_parameters( tokens, params ); 01288 01289 // std::cout << "\tAdding NODES" << std::endl; // REMOVE 01290 01291 // Process parameters 01292 for( std::map< std::string, std::string >::iterator thisParam = params.begin(); thisParam != params.end(); 01293 ++thisParam ) 01294 { 01295 // Look for unambiguous match with this node parameter 01296 param = allowableParams[match( ( *thisParam ).first, allowableParams )]; 01297 switch( param ) 01298 { 01299 case abq_node_nset: 01300 make_node_set = true; 01301 node_set_name = ( *thisParam ).second; 01302 break; 01303 case abq_node_system: 01304 // Store coordinate system 01305 coord_system = ( *thisParam ).second[0]; 01306 break; 01307 case abq_node_ambiguous: 01308 // std::cout << "\t\tIgnoring ambiguous NODE parameter: " << (*thisParam).first 01309 // << "=" << (*thisParam).second << std::endl; 01310 break; 01311 default: 01312 // std::cout << "\t\tIgnoring unsupported NODE parameter: " << (*thisParam).first 01313 // << "=" << (*thisParam).second << std::endl; 01314 break; 01315 } 01316 } 01317 01318 std::vector< double > coord_list; 01319 std::vector< int > node_ids; 01320 01321 next_line_type = get_next_line_type(); 01322 01323 while( next_line_type != abq_eof && next_line_type != abq_keyword_line ) 01324 { 01325 if( abq_data_line == next_line_type ) 01326 { 01327 tokenize( readline, tokens, ", \n" ); 01328 if( tokens.size() < 4 ) 01329 { 01330 MB_SET_ERR( MB_FAILURE, "Not enough data on node data line" ); 01331 } 01332 node_ids.push_back( atoi( tokens[0].c_str() ) ); 01333 for( unsigned int i = 1; i < 4; i++ ) 01334 coord_list.push_back( atof( tokens[i].c_str() ) ); 01335 } 01336 01337 next_line_type = get_next_line_type(); 01338 } 01339 01340 unsigned int num_nodes = node_ids.size(); 01341 01342 // Transform coordinate systems 01343 switch( coord_system ) 01344 { 01345 case 'R': 01346 break; 01347 case 'C': 01348 cyl2rect( coord_list ); 01349 break; 01350 case 'S': 01351 sph2rect( coord_list ); 01352 break; 01353 default: 01354 // std::cout << "Treating undefined coordinate system: " << coord_system 01355 // << " as rectangular/Cartesian." << std::endl; 01356 break; 01357 } 01358 01359 // Get and fill coordinate arrays 01360 std::vector< double* > coord_arrays( 3 ); 01361 EntityHandle start_node = 0; 01362 status = readMeshIface->get_node_coords( 3, num_nodes, MB_START_ID, start_node, coord_arrays ); 01363 MB_RETURN_IF_FAIL; 01364 01365 if( 0 == start_node ) return MB_FAILURE; 01366 01367 // Cppcheck warning (false positive): variable coord_arrays is assigned a value that is never 01368 // used 01369 for( unsigned int idx = 0; idx < num_nodes; idx++ ) 01370 { 01371 coord_arrays[0][idx] = coord_list[idx * 3]; 01372 coord_arrays[1][idx] = coord_list[idx * 3 + 1]; 01373 coord_arrays[2][idx] = coord_list[idx * 3 + 2]; 01374 } 01375 01376 Range node_range( start_node, start_node + num_nodes - 1 ); 01377 // Add nodes to file_set 01378 // status = mdbImpl->add_entities(file_set, node_range); 01379 // MB_RETURN_IF_FAIL; 01380 01381 // Add nodes to this parent_set 01382 status = mdbImpl->add_entities( parent_set, node_range ); 01383 MB_RETURN_IF_FAIL; 01384 01385 // Tag nodes with their local ID's 01386 status = mdbImpl->tag_set_data( mLocalIDTag, node_range, &node_ids[0] ); 01387 MB_RETURN_IF_FAIL; 01388 01389 if( assembly_set ) 01390 { 01391 status = mdbImpl->add_entities( assembly_set, node_range ); 01392 MB_RETURN_IF_FAIL; 01393 01394 std::vector< EntityHandle > tmp_assembly_handles; 01395 tmp_assembly_handles.assign( node_range.size(), assembly_set ); 01396 status = mdbImpl->tag_set_data( mAssemblyHandleTag, node_range, &( tmp_assembly_handles[0] ) ); 01397 MB_RETURN_IF_FAIL; 01398 } 01399 01400 // These nodes don't know their instance_set (probably not defined) 01401 01402 if( make_node_set ) 01403 { 01404 EntityHandle node_set; 01405 01406 status = add_entity_set( parent_set, ABQ_NODE_SET, node_set_name, node_set ); 01407 MB_RETURN_IF_FAIL; 01408 01409 status = mdbImpl->add_entities( node_set, node_range ); 01410 MB_RETURN_IF_FAIL; 01411 01412 // This ad-hoc node set doesn't know its: 01413 // * part_set (probably parent_set) 01414 // * instance_set (probably not defined) 01415 // * assembly_set (probably not defined) 01416 } 01417 01418 return MB_SUCCESS; 01419 } 01420 01421 // SET CREATION & ACCESS UTILITIES 01422 01423 ErrorCode ReadABAQUS::get_elements_by_id( EntityHandle parent_set, 01424 std::vector< int > element_ids_subset, 01425 Range& element_range ) 01426 { 01427 ErrorCode status; 01428 Range all_elements; 01429 01430 status = get_set_elements( parent_set, all_elements ); 01431 MB_RETURN_IF_FAIL; 01432 01433 std::vector< int > element_ids( all_elements.size() ); 01434 status = mdbImpl->tag_get_data( mLocalIDTag, all_elements, &element_ids[0] ); 01435 MB_RETURN_IF_FAIL; 01436 01437 std::map< int, EntityHandle > elementIdMap; 01438 for( unsigned int idx = 0; idx < all_elements.size(); idx++ ) 01439 elementIdMap[element_ids[idx]] = all_elements[idx]; 01440 01441 for( std::vector< int >::iterator element = element_ids_subset.begin(); element != element_ids_subset.end(); 01442 ++element ) 01443 element_range.insert( elementIdMap[*element] ); 01444 01445 return MB_SUCCESS; 01446 } 01447 01448 ErrorCode ReadABAQUS::get_nodes_by_id( EntityHandle parent_set, std::vector< int > node_ids_subset, Range& node_range ) 01449 { 01450 ErrorCode status; 01451 01452 Range all_nodes; 01453 status = mdbImpl->get_entities_by_type( parent_set, MBVERTEX, all_nodes ); 01454 MB_RETURN_IF_FAIL; 01455 01456 std::vector< int > node_ids( all_nodes.size() ); 01457 status = mdbImpl->tag_get_data( mLocalIDTag, all_nodes, &node_ids[0] ); 01458 MB_RETURN_IF_FAIL; 01459 01460 std::map< int, EntityHandle > nodeIdMap; 01461 for( unsigned int idx = 0; idx < all_nodes.size(); idx++ ) 01462 nodeIdMap[node_ids[idx]] = all_nodes[idx]; 01463 01464 for( std::vector< int >::iterator node = node_ids_subset.begin(); node != node_ids_subset.end(); ++node ) 01465 node_range.insert( nodeIdMap[*node] ); 01466 01467 return MB_SUCCESS; 01468 } 01469 01470 ErrorCode ReadABAQUS::get_set_by_name( EntityHandle parent_set, 01471 int ABQ_set_type, 01472 const std::string& set_name, 01473 EntityHandle& set_handle ) 01474 { 01475 ErrorCode status; 01476 01477 char this_set_name[ABAQUS_SET_NAME_LENGTH]; 01478 01479 set_handle = 0; 01480 01481 Range sets; 01482 void* tag_data[] = { &ABQ_set_type }; 01483 status = mdbImpl->get_entities_by_type_and_tag( parent_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, sets );MB_CHK_SET_ERR( status, "Did not find any sets of that type" ); 01484 01485 for( Range::iterator this_set = sets.begin(); this_set != sets.end() && 0 == set_handle; ++this_set ) 01486 { 01487 std::fill( this_set_name, this_set_name + ABAQUS_SET_NAME_LENGTH, '\0' ); 01488 status = mdbImpl->tag_get_data( mSetNameTag, &( *this_set ), 1, &this_set_name[0] ); 01489 if( MB_SUCCESS != status && MB_TAG_NOT_FOUND != status ) return status; 01490 01491 if( set_name == std::string( this_set_name ) ) set_handle = *this_set; 01492 } 01493 01494 if( 0 == set_handle ) 01495 { 01496 MB_SET_ERR( MB_FAILURE, "Did not find requested set" ); 01497 } 01498 01499 return MB_SUCCESS; 01500 } 01501 01502 ErrorCode ReadABAQUS::get_set_elements( EntityHandle set_handle, Range& element_range ) 01503 { 01504 ErrorCode status; 01505 01506 Range dim_ent_list; 01507 01508 // Could have elements of multiple dimensions in this set??? 01509 for( int dim = 1; dim <= 3; dim++ ) 01510 { 01511 dim_ent_list.clear(); 01512 status = mdbImpl->get_entities_by_dimension( set_handle, dim, dim_ent_list ); 01513 MB_RETURN_IF_FAIL; 01514 01515 element_range.merge( dim_ent_list ); 01516 } 01517 01518 return MB_SUCCESS; 01519 } 01520 01521 ErrorCode ReadABAQUS::get_set_elements_by_name( EntityHandle parent_set, 01522 int ABQ_set_type, 01523 const std::string& set_name, 01524 Range& element_range ) 01525 { 01526 ErrorCode status; 01527 01528 EntityHandle set_handle; 01529 status = get_set_by_name( parent_set, ABQ_set_type, set_name, set_handle ); 01530 MB_RETURN_IF_FAIL; 01531 01532 status = get_set_elements( set_handle, element_range ); 01533 MB_RETURN_IF_FAIL; 01534 01535 if( element_range.size() == 0 ) 01536 { 01537 // std::cout << "No elements were found in set " << set_name << std::endl; 01538 } 01539 01540 return MB_SUCCESS; 01541 } 01542 01543 ErrorCode ReadABAQUS::get_set_nodes( EntityHandle parent_set, 01544 int ABQ_set_type, 01545 const std::string& set_name, 01546 Range& node_range ) 01547 { 01548 ErrorCode status; 01549 01550 EntityHandle set_handle; 01551 status = get_set_by_name( parent_set, ABQ_set_type, set_name, set_handle ); 01552 MB_RETURN_IF_FAIL; 01553 01554 Range ent_list; 01555 Range dim_ent_list; 01556 // Could have elements of multiple dimensions in this set??? 01557 for( int dim = 0; dim <= 3; dim++ ) 01558 { 01559 dim_ent_list.clear(); 01560 status = mdbImpl->get_entities_by_dimension( set_handle, dim, dim_ent_list ); 01561 MB_RETURN_IF_FAIL; 01562 01563 ent_list.merge( dim_ent_list ); 01564 } 01565 01566 status = mdbImpl->get_adjacencies( ent_list, 0, false, node_range ); 01567 MB_RETURN_IF_FAIL; 01568 01569 if( node_range.size() == 0 ) 01570 { 01571 std::cout << "No nodes were found in set " << set_name << std::endl; 01572 } 01573 01574 return MB_SUCCESS; 01575 } 01576 01577 Tag ReadABAQUS::get_tag( const char* tag_name, 01578 int tag_size, 01579 TagType tag_type, 01580 DataType tag_data_type, 01581 const void* def_val ) 01582 { 01583 Tag retval; 01584 01585 ErrorCode rval = 01586 mdbImpl->tag_get_handle( tag_name, tag_size, tag_data_type, retval, tag_type | MB_TAG_CREAT, def_val ); 01587 assert( MB_SUCCESS == rval ); 01588 return MB_SUCCESS == rval ? retval : 0; 01589 } 01590 01591 ErrorCode ReadABAQUS::create_instance_of_part( const EntityHandle file_set, 01592 const EntityHandle assembly_set, 01593 const std::string& part_name, 01594 const std::string& /*instance_name*/, 01595 EntityHandle& instance_set, 01596 const std::vector< double >& translation, 01597 const std::vector< double >& rotation ) 01598 { 01599 ErrorCode status; 01600 01601 EntityHandle part_set; 01602 status = get_set_by_name( file_set, ABQ_PART_SET, part_name, part_set ); 01603 MB_RETURN_IF_FAIL; 01604 01605 // Cross-reference 01606 status = mdbImpl->tag_set_data( mPartHandleTag, &instance_set, 1, &part_set ); 01607 MB_RETURN_IF_FAIL; 01608 01609 int instance_id = ++num_part_instances[part_set]; 01610 status = mdbImpl->tag_set_data( mInstancePIDTag, &instance_set, 1, &instance_id ); 01611 MB_RETURN_IF_FAIL; 01612 01613 status = mdbImpl->tag_set_data( mAssemblyHandleTag, &instance_set, 1, &assembly_set ); 01614 MB_RETURN_IF_FAIL; 01615 01616 instance_id = ++num_assembly_instances[assembly_set]; 01617 status = mdbImpl->tag_set_data( mInstanceGIDTag, &instance_set, 1, &instance_id ); 01618 MB_RETURN_IF_FAIL; 01619 01620 // Create maps to cross-reference the part and instance versions of each entity 01621 std::map< EntityHandle, EntityHandle > p2i_nodes, p2i_elements; 01622 01623 // ---- NODES ---- 01624 01625 // Get all nodes and IDs 01626 Range part_node_list; 01627 status = mdbImpl->get_entities_by_dimension( part_set, 0, part_node_list ); 01628 MB_RETURN_IF_FAIL; 01629 01630 if( 0 < part_node_list.size() ) 01631 { 01632 std::vector< int > node_ids( part_node_list.size() ); 01633 status = mdbImpl->tag_get_data( mLocalIDTag, part_node_list, &node_ids[0] ); 01634 MB_RETURN_IF_FAIL; 01635 01636 // std::map<int, EntityHandle> nodeIdMap; 01637 // for (unsigned int idx = 0; idx < part_node_list.size(); idx++) 01638 // nodeIdMap[node_ids[idx]] = part_node_list[idx]; 01639 01640 // Create new nodes 01641 std::vector< double* > coord_arrays( 3 ); 01642 EntityHandle start_node = 0; 01643 status = readMeshIface->get_node_coords( 3, part_node_list.size(), MB_START_ID, start_node, coord_arrays ); 01644 MB_RETURN_IF_FAIL; 01645 01646 if( 0 == start_node ) return MB_FAILURE; 01647 01648 // Copy coordinates into new coord_arrays 01649 status = mdbImpl->get_coords( part_node_list, coord_arrays[0], coord_arrays[1], coord_arrays[2] ); 01650 01651 // Rotate to new position 01652 double rot_axis[3]; 01653 rot_axis[0] = rotation[3] - rotation[0]; 01654 rot_axis[1] = rotation[4] - rotation[1]; 01655 rot_axis[2] = rotation[5] - rotation[2]; 01656 01657 AffineXform rotationXform; 01658 if( rotation[6] != 0 ) rotationXform = AffineXform::rotation( rotation[6] * DEG2RAD, rot_axis ); 01659 01660 // Translate to new position 01661 for( unsigned int idx = 0; idx < part_node_list.size(); idx++ ) 01662 { 01663 double coords[3]; 01664 01665 // Transform to new location and then shift origin of rotation 01666 for( unsigned int dim = 0; dim < 3; dim++ ) 01667 coords[dim] = coord_arrays[dim][idx] + translation[dim] - rotation[dim]; 01668 01669 // Rotate around this origin 01670 if( rotation[6] != 0 ) rotationXform.xform_vector( coords ); 01671 01672 // Transform origin of rotation back 01673 for( unsigned int dim = 0; dim < 3; dim++ ) 01674 coord_arrays[dim][idx] = coords[dim] + rotation[dim]; 01675 } 01676 01677 Range instance_node_list( start_node, start_node + part_node_list.size() - 1 ); 01678 01679 // (DO NOT) add nodes to file_set 01680 // status = mdbImpl->add_entities(file_set, instance_node_list); 01681 // MB_RETURN_IF_FAIL; 01682 01683 // Add nodes to this instance_set 01684 status = mdbImpl->add_entities( instance_set, instance_node_list ); 01685 MB_RETURN_IF_FAIL; 01686 01687 // Add nodes to this assembly_set 01688 status = mdbImpl->add_entities( assembly_set, instance_node_list ); 01689 MB_RETURN_IF_FAIL; 01690 01691 // Tag nodes with their local ID's 01692 status = mdbImpl->tag_set_data( mLocalIDTag, instance_node_list, &node_ids[0] ); 01693 MB_RETURN_IF_FAIL; 01694 01695 // Create a map of old handles to new handles!!! 01696 for( unsigned int idx = 0; idx < part_node_list.size(); idx++ ) 01697 p2i_nodes[part_node_list[idx]] = instance_node_list[idx]; 01698 } 01699 01700 // ---- ELEMENTS ---- 01701 01702 Range part_element_list; 01703 status = get_set_elements( part_set, part_element_list ); 01704 MB_RETURN_IF_FAIL; 01705 01706 if( 0 < part_element_list.size() ) 01707 { 01708 std::vector< int > part_element_ids( part_element_list.size() ); 01709 status = mdbImpl->tag_get_data( mLocalIDTag, part_element_list, &part_element_ids[0] ); 01710 MB_RETURN_IF_FAIL; 01711 01712 // std::map<int, EntityHandle> elementIdMap; 01713 // for (unsigned int idx = 0; idx < part_element_list.size(); idx++) 01714 // elementIdMap[part_element_ids[idx]] = part_element_list[idx]; 01715 01716 // Create new elements 01717 Range instance_element_list; 01718 instance_element_list.clear(); 01719 01720 // Cross-referencing storage and pointers/iterators 01721 std::vector< int > instance_element_ids; 01722 std::vector< int >::iterator part_element_id = part_element_ids.begin(); 01723 01724 for( Range::iterator part_element = part_element_list.begin(); part_element != part_element_list.end(); 01725 ++part_element, ++part_element_id ) 01726 { 01727 EntityType element_type = mdbImpl->type_from_handle( *part_element ); 01728 std::vector< EntityHandle > part_connectivity, instance_connectivity; 01729 EntityHandle new_element; 01730 status = mdbImpl->get_connectivity( &( *part_element ), 1, part_connectivity ); 01731 MB_RETURN_IF_FAIL; 01732 01733 instance_connectivity.clear(); 01734 for( std::vector< EntityHandle >::iterator connectivity_node = part_connectivity.begin(); 01735 connectivity_node != part_connectivity.end(); ++connectivity_node ) 01736 instance_connectivity.push_back( p2i_nodes[*connectivity_node] ); 01737 01738 status = mdbImpl->create_element( element_type, &instance_connectivity[0], instance_connectivity.size(), 01739 new_element ); 01740 MB_RETURN_IF_FAIL; 01741 01742 instance_element_list.insert( new_element ); 01743 p2i_elements[*part_element] = new_element; 01744 instance_element_ids.push_back( *part_element_id ); 01745 } 01746 01747 // (DO NOT) add elements to file_set 01748 // status = mdbImpl->add_entities(file_set, instance_element_list); 01749 // MB_RETURN_IF_FAIL; 01750 01751 // Add elements to this instance_set 01752 status = mdbImpl->add_entities( instance_set, instance_element_list ); 01753 MB_RETURN_IF_FAIL; 01754 01755 // Add elements to this assembly_set 01756 status = mdbImpl->add_entities( assembly_set, instance_element_list ); 01757 MB_RETURN_IF_FAIL; 01758 01759 // Tag elements with their local ID's 01760 status = mdbImpl->tag_set_data( mLocalIDTag, instance_element_list, &( instance_element_ids[0] ) ); 01761 MB_RETURN_IF_FAIL; 01762 } 01763 01764 // ----- NODE SETS ----- 01765 01766 // Get all node sets in part 01767 Range part_node_sets; 01768 int tag_val = ABQ_NODE_SET; 01769 void* tag_data[] = { &tag_val }; 01770 status = mdbImpl->get_entities_by_type_and_tag( part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, part_node_sets ); 01771 MB_RETURN_IF_FAIL; 01772 01773 Range part_node_set_list, instance_node_set_list; 01774 for( Range::iterator part_node_set = part_node_sets.begin(); part_node_set != part_node_sets.end(); 01775 ++part_node_set ) 01776 { 01777 char node_set_name[ABAQUS_SET_NAME_LENGTH]; 01778 std::fill( node_set_name, node_set_name + ABAQUS_SET_NAME_LENGTH, '\0' ); 01779 status = mdbImpl->tag_get_data( mSetNameTag, &( *part_node_set ), 1, &node_set_name[0] ); 01780 if( MB_SUCCESS != status && MB_TAG_NOT_FOUND != status ) return status; 01781 01782 part_node_set_list.clear(); 01783 status = mdbImpl->get_entities_by_dimension( *part_node_set, 0, part_node_set_list ); 01784 01785 instance_node_set_list.clear(); 01786 for( Range::iterator set_node = part_node_set_list.begin(); set_node != part_node_set_list.end(); ++set_node ) 01787 instance_node_set_list.insert( p2i_nodes[*set_node] ); 01788 01789 EntityHandle instance_node_set; 01790 01791 status = add_entity_set( instance_set, ABQ_NODE_SET, node_set_name, instance_node_set ); 01792 MB_RETURN_IF_FAIL; 01793 01794 status = mdbImpl->add_entities( instance_node_set, instance_node_set_list ); 01795 MB_RETURN_IF_FAIL; 01796 01797 status = mdbImpl->add_entities( assembly_set, &instance_node_set, 1 ); 01798 MB_RETURN_IF_FAIL; 01799 01800 status = mdbImpl->tag_set_data( mPartHandleTag, &instance_node_set, 1, &part_set ); 01801 MB_RETURN_IF_FAIL; 01802 01803 status = mdbImpl->tag_set_data( mAssemblyHandleTag, &instance_node_set, 1, &assembly_set ); 01804 MB_RETURN_IF_FAIL; 01805 } 01806 01807 // ----- ELEMENT SETS ----- 01808 01809 // Get all element sets in part 01810 Range part_element_sets; 01811 tag_val = ABQ_ELEMENT_SET; 01812 tag_data[0] = &tag_val; 01813 status = 01814 mdbImpl->get_entities_by_type_and_tag( part_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, part_element_sets ); 01815 MB_RETURN_IF_FAIL; 01816 01817 Range part_element_set_list, instance_element_set_list; 01818 for( Range::iterator part_element_set = part_element_sets.begin(); part_element_set != part_element_sets.end(); 01819 ++part_element_set ) 01820 { 01821 char element_set_name[ABAQUS_SET_NAME_LENGTH]; 01822 std::fill( element_set_name, element_set_name + ABAQUS_SET_NAME_LENGTH, '\0' ); 01823 status = mdbImpl->tag_get_data( mSetNameTag, &( *part_element_set ), 1, &element_set_name[0] ); 01824 if( MB_SUCCESS != status && MB_TAG_NOT_FOUND != status ) return status; 01825 01826 part_element_set_list.clear(); 01827 status = get_set_elements( *part_element_set, part_element_set_list ); 01828 01829 instance_element_set_list.clear(); 01830 for( Range::iterator set_element = part_element_set_list.begin(); set_element != part_element_set_list.end(); 01831 ++set_element ) 01832 instance_element_set_list.insert( p2i_elements[*set_element] ); 01833 01834 EntityHandle instance_element_set; 01835 status = add_entity_set( instance_set, ABQ_ELEMENT_SET, element_set_name, instance_element_set ); 01836 MB_RETURN_IF_FAIL; 01837 01838 // std::cerr << instance_set << "\t" << instance_element_set << std::endl; 01839 status = mdbImpl->add_entities( instance_element_set, instance_element_set_list ); 01840 MB_RETURN_IF_FAIL; 01841 01842 status = mdbImpl->add_entities( assembly_set, &instance_element_set, 1 ); 01843 MB_RETURN_IF_FAIL; 01844 01845 // status = mdbImpl->add_entities(file_set, &instance_element_set, 1); 01846 // MB_RETURN_IF_FAIL; 01847 01848 status = mdbImpl->tag_set_data( mPartHandleTag, &instance_element_set, 1, &part_set ); 01849 MB_RETURN_IF_FAIL; 01850 01851 status = mdbImpl->tag_set_data( mAssemblyHandleTag, &instance_element_set, 1, &assembly_set ); 01852 MB_RETURN_IF_FAIL; 01853 01854 char element_set_matname[ABAQUS_SET_NAME_LENGTH]; 01855 std::fill( element_set_matname, element_set_matname + ABAQUS_SET_NAME_LENGTH, '\0' ); 01856 status = mdbImpl->tag_get_data( mMatNameTag, &( *part_element_set ), 1, &element_set_matname[0] ); 01857 if( MB_SUCCESS != status && MB_TAG_NOT_FOUND != status ) return status; 01858 01859 if( MB_TAG_NOT_FOUND != status ) 01860 { 01861 status = mdbImpl->tag_set_data( mMatNameTag, &instance_element_set, 1, element_set_matname ); 01862 MB_RETURN_IF_FAIL; 01863 } 01864 01865 int element_set_mat_id; 01866 status = mdbImpl->tag_get_data( mMaterialSetTag, &( *part_element_set ), 1, &element_set_mat_id ); 01867 if( MB_SUCCESS != status && MB_TAG_NOT_FOUND != status ) return status; 01868 01869 if( MB_TAG_NOT_FOUND != status ) 01870 { 01871 status = mdbImpl->tag_set_data( mMaterialSetTag, &instance_element_set, 1, &element_set_mat_id ); 01872 MB_RETURN_IF_FAIL; 01873 } 01874 } 01875 01876 // Tag everything with their instance handle 01877 // some nodes are assigned outside of this routine so query final list of all 01878 // instance nodes, elements, etc 01879 Range instance_entity_list; 01880 status = mdbImpl->get_entities_by_dimension( instance_set, 0, instance_entity_list ); 01881 MB_RETURN_IF_FAIL; 01882 01883 std::vector< EntityHandle > tmp_instance_handles; 01884 tmp_instance_handles.assign( instance_entity_list.size(), instance_set ); 01885 status = mdbImpl->tag_set_data( mInstanceHandleTag, instance_entity_list, &tmp_instance_handles[0] ); 01886 MB_RETURN_IF_FAIL; 01887 01888 instance_entity_list.clear(); 01889 status = get_set_elements( instance_set, instance_entity_list ); 01890 MB_RETURN_IF_FAIL; 01891 01892 tmp_instance_handles.clear(); 01893 tmp_instance_handles.assign( instance_entity_list.size(), instance_set ); 01894 status = mdbImpl->tag_set_data( mInstanceHandleTag, instance_entity_list, &tmp_instance_handles[0] ); 01895 MB_RETURN_IF_FAIL; 01896 01897 // Get all node sets in instance 01898 instance_entity_list.clear(); 01899 tag_val = ABQ_NODE_SET; 01900 tag_data[0] = &tag_val; 01901 status = mdbImpl->get_entities_by_type_and_tag( instance_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, 01902 instance_entity_list ); 01903 MB_RETURN_IF_FAIL; 01904 01905 tmp_instance_handles.clear(); 01906 tmp_instance_handles.assign( instance_entity_list.size(), instance_set ); 01907 status = mdbImpl->tag_set_data( mInstanceHandleTag, instance_entity_list, &tmp_instance_handles[0] ); 01908 MB_RETURN_IF_FAIL; 01909 01910 // Get all element sets in part 01911 instance_entity_list.clear(); 01912 tag_val = ABQ_ELEMENT_SET; 01913 tag_data[0] = &tag_val; 01914 status = mdbImpl->get_entities_by_type_and_tag( instance_set, MBENTITYSET, &mSetTypeTag, tag_data, 1, 01915 instance_entity_list ); 01916 MB_RETURN_IF_FAIL; 01917 01918 tmp_instance_handles.clear(); 01919 tmp_instance_handles.assign( instance_entity_list.size(), instance_set ); 01920 status = mdbImpl->tag_set_data( mInstanceHandleTag, instance_entity_list, &tmp_instance_handles[0] ); 01921 MB_RETURN_IF_FAIL; 01922 01923 return MB_SUCCESS; 01924 } 01925 01926 ErrorCode ReadABAQUS::add_entity_set( EntityHandle parent_set, 01927 int ABQ_Set_Type, 01928 const std::string& set_name, 01929 EntityHandle& entity_set ) 01930 { 01931 ErrorCode status; 01932 01933 status = mdbImpl->create_meshset( MESHSET_SET, entity_set ); 01934 MB_RETURN_IF_FAIL; 01935 01936 status = mdbImpl->tag_set_data( mSetTypeTag, &entity_set, 1, &ABQ_Set_Type ); 01937 MB_RETURN_IF_FAIL; 01938 01939 status = mdbImpl->tag_set_data( mSetNameTag, &entity_set, 1, set_name.c_str() ); 01940 MB_RETURN_IF_FAIL; 01941 01942 status = mdbImpl->add_entities( parent_set, &entity_set, 1 ); 01943 MB_RETURN_IF_FAIL; 01944 01945 return MB_SUCCESS; 01946 } 01947 01948 void ReadABAQUS::cyl2rect( std::vector< double > coord_list ) 01949 { 01950 int num_nodes = coord_list.size() / 3; 01951 double x, y, r, t; 01952 01953 for( int node = 0; node < num_nodes; node++ ) 01954 { 01955 r = coord_list[3 * node]; 01956 t = coord_list[3 * node + 1] * DEG2RAD; 01957 01958 x = r * cos( t ); 01959 y = r * sin( t ); 01960 01961 coord_list[3 * node] = x; 01962 coord_list[3 * node + 1] = y; 01963 } 01964 } 01965 01966 void ReadABAQUS::sph2rect( std::vector< double > coord_list ) 01967 { 01968 int num_nodes = coord_list.size() / 3; 01969 double x, y, z, r, t, p; 01970 01971 for( int node = 0; node < num_nodes; node++ ) 01972 { 01973 r = coord_list[3 * node]; 01974 t = coord_list[3 * node + 1] * DEG2RAD; 01975 p = coord_list[3 * node + 2] * DEG2RAD; 01976 01977 x = r * cos( p ) * cos( t ); 01978 y = r * cos( p ) * sin( t ); 01979 z = r * sin( p ); 01980 01981 coord_list[3 * node] = x; 01982 coord_list[3 * node + 1] = y; 01983 coord_list[3 * node + 2] = z; 01984 } 01985 } 01986 01987 // PARSING RECOGNITION 01988 01989 abaqus_line_types ReadABAQUS::get_next_line_type() 01990 { 01991 readline.clear(); 01992 std::getline( abFile, readline ); 01993 ++lineNo; 01994 01995 if( abFile.eof() ) return abq_eof; 01996 01997 std::string::size_type pos = readline.find_first_not_of( ' ' ); 01998 01999 if( std::string::npos == pos ) return abq_blank_line; 02000 02001 if( '*' == readline[pos] ) 02002 if( '*' == readline[pos + 1] ) 02003 return abq_comment_line; 02004 else 02005 return abq_keyword_line; 02006 else 02007 return abq_data_line; 02008 } 02009 02010 abaqus_keyword_type ReadABAQUS::get_keyword() 02011 { 02012 std::vector< std::string > tokens; 02013 std::map< std::string, abaqus_keyword_type > keywords; 02014 02015 // Set up list of supported keywords 02016 // Note: any attempt to match something not in the keyword list 02017 // using the [] operator will create a new entry in the map 02018 // but that entry will have value abq_undefined based on the 02019 // definition of the abaqus_keyword_type enum. 02020 keywords[ABQ_AMBIGUOUS] = abq_ambiguous; 02021 keywords["HEADING"] = abq_heading; 02022 keywords["PART"] = abq_part; 02023 keywords["END PART"] = abq_end_part; 02024 keywords["ASSEMBLY"] = abq_assembly; 02025 keywords["END ASSEMBLY"] = abq_end_assembly; 02026 keywords["NODE"] = abq_node; 02027 keywords["ELEMENT"] = abq_element; 02028 keywords["NSET"] = abq_nset; 02029 keywords["ELSET"] = abq_elset; 02030 keywords["SOLID SECTION"] = abq_solid_section; 02031 keywords["INSTANCE"] = abq_instance; 02032 keywords["END INSTANCE"] = abq_end_instance; 02033 02034 tokenize( readline, tokens, "*,\n" ); 02035 02036 // Convert to upper case and test for unambiguous match/partial match 02037 stringToUpper( tokens[0], tokens[0] ); 02038 return keywords[match( tokens[0], keywords )]; 02039 } 02040 02041 // PARSING UTILITY FUNCTIONS 02042 02043 // For a map of strings to values of type T 02044 // search the key list of the map for an unambiguous partial match with the token 02045 template < typename T > 02046 std::string ReadABAQUS::match( const std::string& token, std::map< std::string, T >& tokenList ) 02047 { 02048 // Initialize with no match and ABQ_UNDEFINED as return string 02049 bool found_match = false; 02050 std::string best_match = ABQ_UNDEFINED; 02051 02052 // Search the map 02053 for( typename std::map< std::string, T >::iterator thisToken = tokenList.begin(); thisToken != tokenList.end(); 02054 ++thisToken ) 02055 { 02056 // If a perfect match break the loop (assume keyword list is unambiguous) 02057 if( token == ( *thisToken ).first ) 02058 { 02059 best_match = token; 02060 break; 02061 } 02062 else 02063 { 02064 int short_length = 02065 ( token.length() < ( *thisToken ).first.length() ? token.length() : ( *thisToken ).first.length() ); 02066 // If the token matches the first token.length() characters of the keyword 02067 // consider this a match 02068 if( token.substr( short_length ) == ( *thisToken ).first.substr( short_length ) ) 02069 { 02070 if( !found_match ) 02071 { 02072 // If no match already, record match and matching keyword 02073 found_match = true; 02074 best_match = ( *thisToken ).first; 02075 } 02076 else 02077 // If match already set matching keyword to ABQ_AMBIGUOUS 02078 best_match = ABQ_AMBIGUOUS; 02079 } 02080 } 02081 } 02082 02083 // Possible return values: ABQ_UNDEFINED, keyword from list, ABQ_AMBIGUOUS 02084 return best_match; 02085 } 02086 02087 // Convert a string to upper case 02088 void ReadABAQUS::stringToUpper( const std::string& toBeConverted, std::string& converted ) 02089 { 02090 converted = toBeConverted; 02091 02092 for( unsigned int i = 0; i < toBeConverted.length(); i++ ) 02093 converted[i] = toupper( toBeConverted[i] ); 02094 } 02095 02096 // Extract key/value pairs from parameter list 02097 void ReadABAQUS::extract_keyword_parameters( const std::vector< std::string >& tokens, 02098 std::map< std::string, std::string >& params ) 02099 { 02100 std::string key, value; 02101 02102 // NOTE: skip first token - it is the keyword 02103 for( std::vector< std::string >::const_iterator token = tokens.begin() + 1; token != tokens.end(); ++token ) 02104 { 02105 std::string::size_type pos = token->find( '=' ); 02106 stringToUpper( token->substr( 0, pos ), key ); 02107 if( std::string::npos != pos ) 02108 value = token->substr( pos + 1 ); 02109 else 02110 value = ""; 02111 pos = key.find_first_not_of( ' ', 0 ); 02112 key = key.substr( pos ); 02113 params[key] = value; 02114 } 02115 } 02116 02117 // Tokenize a string based on a set of possible delimiters 02118 void ReadABAQUS::tokenize( const std::string& str, std::vector< std::string >& tokens, const char* delimiters ) 02119 { 02120 tokens.clear(); 02121 02122 std::string::size_type pos, last = str.find_first_not_of( delimiters, 0 ); 02123 02124 while( std::string::npos != last ) 02125 { 02126 pos = str.find_first_of( delimiters, last ); 02127 if( std::string::npos == pos ) 02128 { 02129 tokens.push_back( str.substr( last ) ); 02130 last = std::string::npos; 02131 } 02132 else 02133 { 02134 tokens.push_back( str.substr( last, pos - last ) ); 02135 last = str.find_first_not_of( delimiters, pos ); 02136 } 02137 } 02138 } 02139 02140 } // namespace moab
