Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /** 00017 * \class ReadGmsh 00018 * \brief Gmsh (http://www.geuz.org/gmsh) file reader 00019 * 00020 * See: http://geuz.org/gmsh/doc/texinfo/gmsh.html#MSH-ASCII-file-format 00021 * 00022 * \author Jason Kraftcheck 00023 */ 00024 00025 #include "ReadGmsh.hpp" 00026 #include "FileTokenizer.hpp" // for file tokenizer 00027 #include "Internals.hpp" 00028 #include "moab/Interface.hpp" 00029 #include "moab/ReadUtilIface.hpp" 00030 #include "moab/Range.hpp" 00031 #include "MBTagConventions.hpp" 00032 #include "MBParallelConventions.h" 00033 #include "moab/CN.hpp" 00034 #include "GmshUtil.hpp" 00035 00036 #include <cerrno> 00037 #include <cstring> 00038 #include <map> 00039 #include <set> 00040 00041 namespace moab 00042 { 00043 00044 ReaderIface* ReadGmsh::factory( Interface* iface ) 00045 { 00046 return new ReadGmsh( iface ); 00047 } 00048 00049 ReadGmsh::ReadGmsh( Interface* impl ) : mdbImpl( impl ), globalId( 0 ) 00050 { 00051 mdbImpl->query_interface( readMeshIface ); 00052 } 00053 00054 ReadGmsh::~ReadGmsh() 00055 { 00056 if( readMeshIface ) 00057 { 00058 mdbImpl->release_interface( readMeshIface ); 00059 readMeshIface = 0; 00060 } 00061 } 00062 00063 ErrorCode ReadGmsh::read_tag_values( const char* /* file_name */, 00064 const char* /* tag_name */, 00065 const FileOptions& /* opts */, 00066 std::vector< int >& /* tag_values_out */, 00067 const SubsetList* /* subset_list */ ) 00068 { 00069 return MB_NOT_IMPLEMENTED; 00070 } 00071 00072 ErrorCode ReadGmsh::load_file( const char* filename, 00073 const EntityHandle*, 00074 const FileOptions&, 00075 const ReaderIface::SubsetList* subset_list, 00076 const Tag* file_id_tag ) 00077 { 00078 int num_material_sets = 0; 00079 const int* material_set_list = 0; 00080 00081 if( subset_list ) 00082 { 00083 if( subset_list->tag_list_length > 1 && !strcmp( subset_list->tag_list[0].tag_name, MATERIAL_SET_TAG_NAME ) ) 00084 { 00085 MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "GMsh supports subset read only by material ID" ); 00086 } 00087 material_set_list = subset_list->tag_list[0].tag_values; 00088 num_material_sets = subset_list->tag_list[0].num_tag_values; 00089 } 00090 00091 geomSets.clear(); 00092 globalId = mdbImpl->globalId_tag(); 00093 00094 // Create set for more convenient check for material set ids 00095 std::set< int > blocks; 00096 for( const int* mat_set_end = material_set_list + num_material_sets; material_set_list != mat_set_end; 00097 ++material_set_list ) 00098 blocks.insert( *material_set_list ); 00099 00100 // Map of ID->handle for nodes 00101 std::map< long, EntityHandle > node_id_map; 00102 int data_size = 8; 00103 00104 // Open file and hand off pointer to tokenizer 00105 FILE* file_ptr = fopen( filename, "r" ); 00106 if( !file_ptr ) 00107 { 00108 MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, filename << ": " << strerror( errno ) ); 00109 } 00110 FileTokenizer tokens( file_ptr, readMeshIface ); 00111 00112 // Determine file format version 00113 const char* const start_tokens[] = { "$NOD", "$MeshFormat", 0 }; 00114 int format_version = tokens.match_token( start_tokens ); 00115 if( !format_version ) return MB_FILE_DOES_NOT_EXIST; 00116 00117 // If version 2.0, read additional header info 00118 if( 2 == format_version ) 00119 { 00120 double version; 00121 if( !tokens.get_doubles( 1, &version ) ) return MB_FILE_WRITE_ERROR; 00122 00123 if( version != 2.0 && version != 2.1 && version != 2.2 ) 00124 { 00125 MB_SET_ERR( MB_FILE_DOES_NOT_EXIST, filename << ": unknown format version: " << version ); 00126 return MB_FILE_DOES_NOT_EXIST; 00127 } 00128 00129 int file_format; 00130 if( !tokens.get_integers( 1, &file_format ) || !tokens.get_integers( 1, &data_size ) || 00131 !tokens.match_token( "$EndMeshFormat" ) ) 00132 return MB_FILE_WRITE_ERROR; 00133 // If physical entities in the gmsh file -> discard this 00134 const char* const phys_tokens[] = { "$Nodes", "$PhysicalNames", 0 }; 00135 int hasPhys = tokens.match_token( phys_tokens ); 00136 00137 if( hasPhys == 2 ) 00138 { 00139 long num_phys; 00140 if( !tokens.get_long_ints( 1, &num_phys ) ) return MB_FILE_WRITE_ERROR; 00141 for( long loop_phys = 0; loop_phys < num_phys; loop_phys++ ) 00142 { 00143 long physDim; 00144 long physGroupNum; 00145 // char const * physName; 00146 if( !tokens.get_long_ints( 1, &physDim ) ) return MB_FILE_WRITE_ERROR; 00147 if( !tokens.get_long_ints( 1, &physGroupNum ) ) return MB_FILE_WRITE_ERROR; 00148 const char* ptc = tokens.get_string(); 00149 if( !ptc ) return MB_FILE_WRITE_ERROR; 00150 // try to get to the end of the line, without reporting errors 00151 // really, we need to skip this 00152 while( !tokens.get_newline( false ) ) 00153 ptc = tokens.get_string(); 00154 } 00155 if( !tokens.match_token( "$EndPhysicalNames" ) || !tokens.match_token( "$Nodes" ) ) 00156 return MB_FILE_WRITE_ERROR; 00157 } 00158 } 00159 00160 // Read number of nodes 00161 long num_nodes; 00162 if( !tokens.get_long_ints( 1, &num_nodes ) ) return MB_FILE_WRITE_ERROR; 00163 00164 // Allocate nodes 00165 std::vector< double* > coord_arrays; 00166 EntityHandle handle = 0; 00167 ErrorCode result = readMeshIface->get_node_coords( 3, num_nodes, MB_START_ID, handle, coord_arrays ); 00168 if( MB_SUCCESS != result ) return result; 00169 00170 // Read nodes 00171 double *x = coord_arrays[0], *y = coord_arrays[1], *z = coord_arrays[2]; 00172 for( long i = 0; i < num_nodes; ++i, ++handle ) 00173 { 00174 long id; 00175 if( !tokens.get_long_ints( 1, &id ) || !tokens.get_doubles( 1, x++ ) || !tokens.get_doubles( 1, y++ ) || 00176 !tokens.get_doubles( 1, z++ ) ) 00177 return MB_FILE_WRITE_ERROR; 00178 00179 if( !node_id_map.insert( std::pair< long, EntityHandle >( id, handle ) ).second ) 00180 { 00181 MB_SET_ERR( MB_FILE_WRITE_ERROR, "Duplicate node ID at line " << tokens.line_number() ); 00182 } 00183 } 00184 00185 // Create reverse map from handle to id 00186 std::vector< int > ids( num_nodes ); 00187 std::vector< int >::iterator id_iter = ids.begin(); 00188 std::vector< EntityHandle > handles( num_nodes ); 00189 std::vector< EntityHandle >::iterator h_iter = handles.begin(); 00190 for( std::map< long, EntityHandle >::iterator i = node_id_map.begin(); i != node_id_map.end(); 00191 ++i, ++id_iter, ++h_iter ) 00192 { 00193 *id_iter = i->first; 00194 *h_iter = i->second; 00195 } 00196 // Store IDs in tags 00197 result = mdbImpl->tag_set_data( globalId, &handles[0], num_nodes, &ids[0] ); 00198 if( MB_SUCCESS != result ) return result; 00199 if( file_id_tag ) 00200 { 00201 result = mdbImpl->tag_set_data( *file_id_tag, &handles[0], num_nodes, &ids[0] ); 00202 if( MB_SUCCESS != result ) return result; 00203 } 00204 ids.clear(); 00205 handles.clear(); 00206 00207 // Get tokens signifying end of node data and start of elements 00208 if( !tokens.match_token( format_version == 1 ? "$ENDNOD" : "$EndNodes" ) || 00209 !tokens.match_token( format_version == 1 ? "$ELM" : "$Elements" ) ) 00210 return MB_FILE_WRITE_ERROR; 00211 00212 // Get element count 00213 long num_elem; 00214 if( !tokens.get_long_ints( 1, &num_elem ) ) return MB_FILE_WRITE_ERROR; 00215 00216 // Lists of data accumulated for elements 00217 std::vector< EntityHandle > connectivity; 00218 std::vector< int > mat_set_list, geom_set_list, part_set_list, id_list; 00219 // Temporary, per-element data 00220 std::vector< int > int_data( 5 ), tag_data( 2 ); 00221 std::vector< long > tmp_conn; 00222 int curr_elem_type = -1; 00223 for( long i = 0; i < num_elem; ++i ) 00224 { 00225 // Read element description 00226 // File format 1.0 00227 if( 1 == format_version ) 00228 { 00229 if( !tokens.get_integers( 5, &int_data[0] ) ) return MB_FILE_WRITE_ERROR; 00230 tag_data[0] = int_data[2]; 00231 tag_data[1] = int_data[3]; 00232 if( (unsigned)tag_data[1] < GmshUtil::numGmshElemType && 00233 GmshUtil::gmshElemTypes[tag_data[1]].num_nodes != (unsigned)int_data[4] ) 00234 { 00235 MB_SET_ERR( MB_FILE_WRITE_ERROR, 00236 "Invalid node count for element type at line " << tokens.line_number() ); 00237 } 00238 } 00239 // File format 2.0 00240 else 00241 { 00242 if( !tokens.get_integers( 3, &int_data[0] ) ) return MB_FILE_WRITE_ERROR; 00243 tag_data.resize( int_data[2] ); 00244 if( !tokens.get_integers( tag_data.size(), &tag_data[0] ) ) return MB_FILE_WRITE_ERROR; 00245 } 00246 00247 // If a list of material sets was specified in the 00248 // argument list, skip any elements for which the 00249 // material set is not specified or is not in the 00250 // passed list. 00251 if( !blocks.empty() && ( tag_data.empty() || blocks.find( tag_data[0] ) != blocks.end() ) ) continue; 00252 00253 // If the next element is not the same type as the last one, 00254 // create a sequence for the block of elements we've read 00255 // to this point (all of the same type), and clear accumulated 00256 // data. 00257 if( int_data[1] != curr_elem_type ) 00258 { 00259 if( !id_list.empty() ) 00260 { // First iteration 00261 result = create_elements( GmshUtil::gmshElemTypes[curr_elem_type], id_list, mat_set_list, geom_set_list, 00262 part_set_list, connectivity, file_id_tag ); 00263 if( MB_SUCCESS != result ) return result; 00264 } 00265 00266 id_list.clear(); 00267 mat_set_list.clear(); 00268 geom_set_list.clear(); 00269 part_set_list.clear(); 00270 connectivity.clear(); 00271 curr_elem_type = int_data[1]; 00272 if( (unsigned)curr_elem_type >= GmshUtil::numGmshElemType || 00273 GmshUtil::gmshElemTypes[curr_elem_type].mb_type == MBMAXTYPE ) 00274 { 00275 MB_SET_ERR( MB_FILE_WRITE_ERROR, 00276 "Unsupported element type " << curr_elem_type << " at line " << tokens.line_number() ); 00277 } 00278 tmp_conn.resize( GmshUtil::gmshElemTypes[curr_elem_type].num_nodes ); 00279 } 00280 00281 // Store data from element description 00282 id_list.push_back( int_data[0] ); 00283 if( tag_data.size() > 3 ) 00284 part_set_list.push_back( tag_data[3] ); // it must be new format for gmsh, >= 2.5 00285 // it could have negative partition ids, for ghost elements 00286 else if( tag_data.size() > 2 ) 00287 part_set_list.push_back( tag_data[2] ); // old format, partition id saved in 3rd tag field 00288 else 00289 part_set_list.push_back( 0 ); 00290 geom_set_list.push_back( tag_data.size() > 1 ? tag_data[1] : 0 ); 00291 mat_set_list.push_back( tag_data.size() > 0 ? tag_data[0] : 0 ); 00292 00293 // Get element connectivity 00294 if( !tokens.get_long_ints( tmp_conn.size(), &tmp_conn[0] ) ) return MB_FILE_WRITE_ERROR; 00295 00296 // Convert connectivity from IDs to handles 00297 for( unsigned j = 0; j < tmp_conn.size(); ++j ) 00298 { 00299 std::map< long, EntityHandle >::iterator k = node_id_map.find( tmp_conn[j] ); 00300 if( k == node_id_map.end() ) 00301 { 00302 MB_SET_ERR( MB_FILE_WRITE_ERROR, "Invalid node ID at line " << tokens.line_number() ); 00303 } 00304 connectivity.push_back( k->second ); 00305 } 00306 } // for (num_nodes) 00307 00308 // Create entity sequence for last element(s). 00309 if( !id_list.empty() ) 00310 { 00311 result = create_elements( GmshUtil::gmshElemTypes[curr_elem_type], id_list, mat_set_list, geom_set_list, 00312 part_set_list, connectivity, file_id_tag ); 00313 if( MB_SUCCESS != result ) return result; 00314 } 00315 00316 // Construct parent-child relations for geometric sets. 00317 // Note: At the time this comment was written, the following 00318 // function was not implemented. 00319 result = create_geometric_topology(); 00320 geomSets.clear(); 00321 return result; 00322 } 00323 00324 //! Create an element sequence 00325 ErrorCode ReadGmsh::create_elements( const GmshElemType& type, 00326 const std::vector< int >& elem_ids, 00327 const std::vector< int >& matl_ids, 00328 const std::vector< int >& geom_ids, 00329 const std::vector< int >& prtn_ids, 00330 const std::vector< EntityHandle >& connectivity, 00331 const Tag* file_id_tag ) 00332 { 00333 ErrorCode result; 00334 00335 // Make sure input is consistent 00336 const unsigned long num_elem = elem_ids.size(); 00337 const int node_per_elem = type.num_nodes; 00338 if( matl_ids.size() != num_elem || geom_ids.size() != num_elem || prtn_ids.size() != num_elem || 00339 connectivity.size() != num_elem * node_per_elem ) 00340 return MB_FAILURE; 00341 00342 // Create the element sequence 00343 // for points, simply gather the connectivities and create the materials 00344 if( type.mb_type == MBVERTEX ) 00345 { 00346 Range elements; 00347 elements.insert< std::vector< EntityHandle > >( connectivity.begin(), connectivity.end() ); 00348 result = create_sets( type.mb_type, elements, matl_ids, 0 ); 00349 if( MB_SUCCESS != result ) return result; 00350 00351 return MB_SUCCESS; 00352 } 00353 EntityHandle handle = 0; 00354 EntityHandle* conn_array; 00355 result = 00356 readMeshIface->get_element_connect( num_elem, node_per_elem, type.mb_type, MB_START_ID, handle, conn_array ); 00357 if( MB_SUCCESS != result ) return result; 00358 00359 // Copy passed element connectivity into entity sequence data. 00360 if( type.node_order ) 00361 { 00362 for( unsigned long i = 0; i < num_elem; ++i ) 00363 for( int j = 0; j < node_per_elem; ++j ) 00364 conn_array[i * node_per_elem + type.node_order[j]] = connectivity[i * node_per_elem + j]; 00365 } 00366 else 00367 { 00368 memcpy( conn_array, &connectivity[0], connectivity.size() * sizeof( EntityHandle ) ); 00369 } 00370 00371 // Notify MOAB of the new elements 00372 result = readMeshIface->update_adjacencies( handle, num_elem, node_per_elem, conn_array ); 00373 if( MB_SUCCESS != result ) return result; 00374 00375 // Store element IDs 00376 Range elements( handle, handle + num_elem - 1 ); 00377 result = mdbImpl->tag_set_data( globalId, elements, &elem_ids[0] ); 00378 if( MB_SUCCESS != result ) return result; 00379 if( file_id_tag ) 00380 { 00381 result = mdbImpl->tag_set_data( *file_id_tag, elements, &elem_ids[0] ); 00382 if( MB_SUCCESS != result ) return result; 00383 } 00384 00385 // Add elements to material sets 00386 result = create_sets( type.mb_type, elements, matl_ids, 0 ); 00387 if( MB_SUCCESS != result ) return result; 00388 // Add elements to geometric sets 00389 result = create_sets( type.mb_type, elements, geom_ids, 1 ); 00390 if( MB_SUCCESS != result ) return result; 00391 // Add elements to parallel partitions 00392 result = create_sets( type.mb_type, elements, prtn_ids, 2 ); 00393 if( MB_SUCCESS != result ) return result; 00394 00395 return MB_SUCCESS; 00396 } 00397 00398 //! Add elements to sets as dictated by grouping ID in file. 00399 ErrorCode ReadGmsh::create_sets( EntityType type, 00400 const Range& elements, 00401 const std::vector< int >& set_ids, 00402 int set_type ) 00403 { 00404 ErrorCode result; 00405 00406 // Get a unique list of set IDs 00407 std::set< int > ids; 00408 for( std::vector< int >::const_iterator i = set_ids.begin(); i != set_ids.end(); ++i ) 00409 ids.insert( *i ); 00410 00411 // No Sets? 00412 if( ids.empty() || ( ids.size() == 1 && *ids.begin() == 0 ) ) return MB_SUCCESS; // no sets (all ids are zero) 00413 00414 // Get/create tag handles 00415 int num_tags; 00416 Tag tag_handles[2]; 00417 int tag_val; 00418 const void* tag_values[2] = { &tag_val, NULL }; 00419 00420 switch( set_type ) 00421 { 00422 default: 00423 return MB_FAILURE; 00424 case 0: 00425 case 2: { 00426 const char* name = set_type ? PARALLEL_PARTITION_TAG_NAME : MATERIAL_SET_TAG_NAME; 00427 result = mdbImpl->tag_get_handle( name, 1, MB_TYPE_INTEGER, tag_handles[0], MB_TAG_SPARSE | MB_TAG_CREAT ); 00428 if( MB_SUCCESS != result ) return result; 00429 num_tags = 1; 00430 break; 00431 } 00432 case 1: { 00433 result = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, tag_handles[1], 00434 MB_TAG_SPARSE | MB_TAG_CREAT ); 00435 if( MB_SUCCESS != result ) return result; 00436 tag_values[1] = NULL; 00437 tag_handles[0] = globalId; 00438 num_tags = 2; 00439 break; 00440 } 00441 } // switch 00442 00443 // For each unique set ID... 00444 for( std::set< int >::iterator i = ids.begin(); i != ids.end(); ++i ) 00445 { 00446 // Skip "null" set ID 00447 if( *i == 0 ) continue; 00448 00449 // Get all entities with the current set ID 00450 Range entities, sets; 00451 std::vector< int >::const_iterator j = set_ids.begin(); 00452 for( Range::iterator k = elements.begin(); k != elements.end(); ++j, ++k ) 00453 if( *i == *j ) entities.insert( *k ); 00454 00455 // Get set by ID 00456 // Cppcheck warning (false positive): variable tag_val is assigned a value that is never 00457 // used 00458 tag_val = *i; 00459 result = mdbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, tag_handles, tag_values, num_tags, sets ); 00460 if( MB_SUCCESS != result && MB_ENTITY_NOT_FOUND != result ) return result; 00461 00462 // Don't use existing geometry sets (from some other file) 00463 if( 1 == set_type ) // Geometry 00464 sets = intersect( sets, geomSets ); 00465 00466 // Get set handle 00467 EntityHandle set; 00468 // If no sets with ID, create one 00469 if( sets.empty() ) 00470 { 00471 result = mdbImpl->create_meshset( MESHSET_SET, set ); 00472 if( MB_SUCCESS != result ) return result; 00473 00474 result = mdbImpl->tag_set_data( tag_handles[0], &set, 1, &*i ); 00475 if( MB_SUCCESS != result ) return result; 00476 00477 if( 1 == set_type ) 00478 { // Geometry 00479 int dim = CN::Dimension( type ); 00480 result = mdbImpl->tag_set_data( tag_handles[1], &set, 1, &dim ); 00481 if( MB_SUCCESS != result ) return result; 00482 geomSets.insert( set ); 00483 } 00484 } 00485 else 00486 { 00487 set = *sets.begin(); 00488 if( 1 == set_type ) 00489 { // Geometry 00490 int dim = CN::Dimension( type ); 00491 // Get dimension of set 00492 int dim2; 00493 result = mdbImpl->tag_get_data( tag_handles[1], &set, 1, &dim2 ); 00494 if( MB_SUCCESS != result ) return result; 00495 // If we're putting geometry of a higher dimension into the 00496 // set, increase the dimension of the set. 00497 if( dim > dim2 ) 00498 { 00499 result = mdbImpl->tag_set_data( tag_handles[1], &set, 1, &dim ); 00500 if( MB_SUCCESS != result ) return result; 00501 } 00502 } 00503 } 00504 00505 // Put the mesh entities into the set 00506 result = mdbImpl->add_entities( set, entities ); 00507 if( MB_SUCCESS != result ) return result; 00508 } // for (ids) 00509 00510 return MB_SUCCESS; 00511 } 00512 00513 //! NOT IMPLEMENTED 00514 //! Reconstruct parent-child relations for geometry sets from 00515 //! mesh connectivity. 00516 ErrorCode ReadGmsh::create_geometric_topology() 00517 { 00518 if( geomSets.empty() ) return MB_SUCCESS; 00519 00520 // Not implemented yet 00521 geomSets.clear(); 00522 return MB_SUCCESS; 00523 } 00524 00525 } // namespace moab
