Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2007 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /**\class moab::SimplexTemplateRefiner 00017 * 00018 * This is a concrete subclass of EntityRefiner that implements 00019 * refinement using templates applied to simplices. 00020 * Entities that are not simplices are divided into tetrahedra, 00021 * triangles, or lines before being processed. 00022 * Points are passed through unchanged. 00023 * 00024 * \author David Thompson 00025 * \author Philippe Pebay 00026 * 00027 * \date 24 December 2007 00028 */ 00029 #ifndef MB_SIMPLEX_TEMPLATE_REFINER_HPP 00030 #define MB_SIMPLEX_TEMPLATE_REFINER_HPP 00031 00032 #include "EntityRefiner.hpp" 00033 #include "SimplexTemplateTagAssigner.hpp" 00034 00035 #include "moab/Types.hpp" // for MB_DLL_EXPORT 00036 00037 namespace moab 00038 { 00039 00040 class RefinerTagManager; 00041 00042 class SimplexTemplateRefiner : public EntityRefiner 00043 { 00044 public: 00045 SimplexTemplateRefiner(); 00046 virtual ~SimplexTemplateRefiner(); 00047 00048 virtual bool refine_entity( EntityType etyp, EntityHandle entity ); 00049 virtual unsigned long get_heap_size_bound( int max_recursions ) const 00050 { 00051 return 48 * 4 * ( 1 << max_recursions ) + 8; 00052 } 00053 00054 virtual bool set_tag_assigner( SimplexTemplateTagAssigner* ta ); 00055 SimplexTemplateTagAssigner* get_tag_assigner() const 00056 { 00057 return this->tag_assigner; 00058 } 00059 00060 virtual bool prepare( RefinerTagManager* tmgr, EntityRefinerOutputFunctor* ofunc ); 00061 00062 protected: 00063 SimplexTemplateTagAssigner* tag_assigner; 00064 RefinerTagManager* tag_manager; 00065 std::vector< double > corner_coords; 00066 std::vector< void* > corner_tags; 00067 std::vector< EntityHandle > corner_handles; 00068 bool input_is_output; 00069 00070 static int template_index[64][2]; 00071 static int permutations_from_index[24][14]; 00072 static int templates[]; 00073 00074 void refine_0_simplex( const double* v0, const void* t0, EntityHandle h0 ); 00075 bool refine_1_simplex( int max_depth, 00076 const double* v0, 00077 const void* t0, 00078 EntityHandle h0, 00079 const double* v1, 00080 const void* t1, 00081 EntityHandle h1 ); 00082 bool refine_2_simplex( int max_depth, 00083 int move, 00084 const double* v0, 00085 const void* t0, 00086 EntityHandle h0, 00087 const double* v1, 00088 const void* t1, 00089 EntityHandle h1, 00090 const double* v2, 00091 const void* t2, 00092 EntityHandle h2 ); 00093 bool refine_3_simplex( int max_depth, 00094 double* v0, 00095 void* t0, 00096 EntityHandle h0, 00097 double* v1, 00098 void* t1, 00099 EntityHandle h1, 00100 double* v2, 00101 void* t2, 00102 EntityHandle h2, 00103 double* v3, 00104 void* t3, 00105 EntityHandle h3 ); 00106 00107 int best_tets( int* alternates, double* [14], int, int ) 00108 { 00109 return alternates[0]; 00110 } 00111 void assign_parametric_coordinates( int num_nodes, const double* src, double* tgt ); 00112 static bool compare_Hopf_cross_string_dist( const double* v00, 00113 const double* v01, 00114 const double* v10, 00115 const double* v11 ); 00116 }; 00117 00118 } // namespace moab 00119 00120 #endif // MB_SIMPLEX_TEMPLATE_REFINER_HPP
