Mesh Oriented datABase
(version 5.4.1)
00001 #include "SphereDecomp.hpp"
00002 #include "moab/MeshTopoUtil.hpp"
00003 #include "moab/Range.hpp"
00004 #include "moab/CN.hpp"
00005 #include
00006 #include
00007 #include
00008
00009 #define RR \
00010 if( MB_SUCCESS != result ) return result
00011
00012 const char* SUBDIV_VERTICES_TAG_NAME = "subdiv_vertices";
00013
00014 using namespace moab;
00015
00016 SphereDecomp::SphereDecomp( Interface* impl )
00017 {
00018 mbImpl = impl;
00019 }
00020
00021 ErrorCode SphereDecomp::build_sphere_mesh( const char* sphere_radii_tag_name, EntityHandle* hex_set )
00022 {
00023 ErrorCode result = mbImpl->tag_get_handle( sphere_radii_tag_name, 1, MB_TYPE_DOUBLE, sphereRadiiTag );RR;
00024
00025 // need to make sure all interior edges and faces are created
00026 Range all_verts;
00027 result = mbImpl->get_entities_by_type( 0, MBVERTEX, all_verts );RR;
00028 MeshTopoUtil mtu( mbImpl );
00029 result = mtu.construct_aentities( all_verts );RR;
00030
00031 // create tag to hold vertices
00032 result = mbImpl->tag_get_handle( SUBDIV_VERTICES_TAG_NAME, 9, MB_TYPE_HANDLE, subdivVerticesTag,
00033 MB_TAG_DENSE | MB_TAG_EXCL );RR;
00034
00035 // compute nodal positions for each dimension element
00036 result = compute_nodes( 1 );RR;
00037 result = compute_nodes( 2 );RR;
00038 result = compute_nodes( 3 );RR;
00039
00040 // build hex elements
00041 std::vector< EntityHandle > sphere_hexes, interstic_hexes;
00042 result = build_hexes( sphere_hexes, interstic_hexes );RR;
00043
00044 result = mbImpl->tag_delete( subdivVerticesTag );RR;
00045
00046 if( NULL != hex_set )
00047 {
00048 if( 0 == *hex_set )
00049 {
00050 EntityHandle this_set;
00051 // make a new set
00052 result = mbImpl->create_meshset( MESHSET_SET, this_set );RR;
00053 *hex_set = this_set;
00054 }
00055
00056 // save all the hexes to this set
00057 result = mbImpl->add_entities( *hex_set, &sphere_hexes[0], sphere_hexes.size() );RR;
00058 result = mbImpl->add_entities( *hex_set, &interstic_hexes[0], interstic_hexes.size() );RR;
00059 }
00060
00061 return result;
00062 }
00063
00064 ErrorCode SphereDecomp::compute_nodes( const int dim )
00065 {
00066 // get facets of that dimension
00067 Range these_ents;
00068 const EntityType the_types[4] = { MBVERTEX, MBEDGE, MBTRI, MBTET };
00069
00070 ErrorCode result = mbImpl->get_entities_by_dimension( 0, dim, these_ents );RR;
00071 assert( mbImpl->type_from_handle( *these_ents.begin() ) == the_types[dim] &&
00072 mbImpl->type_from_handle( *these_ents.rbegin() ) == the_types[dim] );
00073
00074 EntityHandle subdiv_vertices[9];
00075 MeshTopoUtil mtu( mbImpl );
00076 double avg_pos[3], vert_pos[12], new_vert_pos[12], new_new_vert_pos[3];
00077 double radii[4], unitv[3];
00078 int num_verts = CN::VerticesPerEntity( the_types[dim] );
00079
00080 for( Range::iterator rit = these_ents.begin(); rit != these_ents.end(); ++rit )
00081 {
00082
00083 // get vertices
00084 const EntityHandle* connect;
00085 int num_connect;
00086 result = mbImpl->get_connectivity( *rit, connect, num_connect );RR;
00087
00088 // compute center
00089 result = mtu.get_average_position( connect, num_connect, avg_pos );RR;
00090
00091 // create center vertex
00092 result = mbImpl->create_vertex( avg_pos, subdiv_vertices[num_verts] );RR;
00093
00094 // get coords of other vertices
00095 result = mbImpl->get_coords( connect, num_connect, vert_pos );RR;
00096
00097 // get radii associated with each vertex
00098 result = mbImpl->tag_get_data( sphereRadiiTag, connect, num_connect, radii );RR;
00099
00100 // compute subdiv vertex position for each vertex
00101 for( int i = 0; i < num_verts; i++ )
00102 {
00103 for( int j = 0; j < 3; j++ )
00104 unitv[j] = avg_pos[j] - vert_pos[3 * i + j];
00105 double vlength = sqrt( unitv[0] * unitv[0] + unitv[1] * unitv[1] + unitv[2] * unitv[2] );
00106 if( vlength < radii[i] )
00107 {
00108 std::cout << "Radius too large at vertex " << i << std::endl;
00109 result = MB_FAILURE;
00110 continue;
00111 }
00112
00113 for( int j = 0; j < 3; j++ )
00114 unitv[j] /= vlength;
00115
00116 for( int j = 0; j < 3; j++ )
00117 new_vert_pos[3 * i + j] = vert_pos[3 * i + j] + radii[i] * unitv[j];
00118
00119 // create vertex at this position
00120 ErrorCode tmp_result = mbImpl->create_vertex( &new_vert_pos[3 * i], subdiv_vertices[i] );
00121 if( MB_SUCCESS != tmp_result ) result = tmp_result;
00122 }
00123
00124 if( MB_SUCCESS != result ) return result;
00125
00126 // compute subdiv vertex positions for vertices inside spheres; just mid-pt between
00127 // previous subdiv vertex and corner vertex
00128 for( int i = 0; i < num_verts; i++ )
00129 {
00130 for( int j = 0; j < 3; j++ )
00131 new_new_vert_pos[j] = .5 * ( vert_pos[3 * i + j] + new_vert_pos[3 * i + j] );
00132
00133 result = mbImpl->create_vertex( new_new_vert_pos, subdiv_vertices[num_verts + 1 + i] );
00134 }
00135
00136 // set the tag
00137 result = mbImpl->tag_set_data( subdivVerticesTag, &( *rit ), 1, subdiv_vertices );RR;
00138 }
00139
00140 return result;
00141 }
00142
00143 ErrorCode SphereDecomp::build_hexes( std::vector< EntityHandle >& sphere_hexes,
00144 std::vector< EntityHandle >& interstic_hexes )
00145 {
00146 // build hexes inside each tet element separately
00147 Range tets;
00148 ErrorCode result = mbImpl->get_entities_by_type( 0, MBTET, tets );RR;
00149
00150 for( Range::iterator vit = tets.begin(); vit != tets.end(); ++vit )
00151 {
00152 result = subdivide_tet( *vit, sphere_hexes, interstic_hexes );RR;
00153 }
00154
00155 return MB_SUCCESS;
00156 }
00157
00158 ErrorCode SphereDecomp::subdivide_tet( EntityHandle tet,
00159 std::vector< EntityHandle >& sphere_hexes,
00160 std::vector< EntityHandle >& interstic_hexes )
00161 {
00162 // 99: (#subdiv_verts/entity=9) * (#edges=6 + #faces=4 + 1=tet)
00163 EntityHandle subdiv_verts[99];
00164
00165 // get tet connectivity
00166 std::vector< EntityHandle > tet_conn;
00167 ErrorCode result = mbImpl->get_connectivity( &tet, 1, tet_conn );RR;
00168
00169 for( int dim = 1; dim <= 3; dim++ )
00170 {
00171 // get entities of this dimension
00172 std::vector< EntityHandle > ents;
00173 if( dim != 3 )
00174 {
00175 result = mbImpl->get_adjacencies( &tet, 1, dim, false, ents );RR;
00176 }
00177 else
00178 ents.push_back( tet );
00179
00180 // for each, get subdiv verts & put into vector
00181 for( std::vector< EntityHandle >::iterator vit = ents.begin(); vit != ents.end(); ++vit )
00182 {
00183 result = retrieve_subdiv_verts( tet, *vit, &tet_conn[0], dim, subdiv_verts );RR;
00184 }
00185 }
00186
00187 // ok, subdiv_verts are in canonical order; now create the hexes, using pre-computed templates
00188
00189 // Templates are specified in terms of the vertices making up each hex; vertices are specified
00190 // by specifying the facet index and type they resolve, and the index of that vertex in that
00191 // facet's subdivision vertices list.
00192
00193 // Each facet is subdivided into:
00194 // - a mid vertex
00195 // - one vertex for each corner vertex on the facet (located on a line between the mid vertex
00196 // and
00197 // the corresponding corner vertex, a distance equal to the sphere radius away from the corner
00198 // vertex)
00199 // - one vertex midway between each corner vertex and the corresponding "sphere surface" vertex
00200 // For edges, tris and tets this gives 5, 7 and 9 subdivision vertices, respectively.
00201 // Subdivision vertices appear in the list in the order: sphere surface vertices, mid vertex,
00202 // sphere interior vertices. In each of those sub lists, vertices are listed in the canonical
00203 // order of the corresponding corner vertices for that facet.
00204
00205 // Subdivision vertices for facetes are indexed by listing the facet type they resolve (EDGE,
00206 // FACE, TET), the index of that facet (integer = 0..5, 0..3, 0 for edges, tris, tet, resp), and
00207 // subdivision index (AINDEX..EINDEX for edges, AINDEX..GINDEX for tris, AINDEX..IINDEX for
00208 // tets).
00209
00210 // Subdivision vertices for all facets of a tet are stored in one subdivision vertex vector, in
00211 // order of increasing facet dimension and index (index varies fastest). The ESV, FSV, and TSV
00212 // macros are used to compute the indices into that vector for various parameters. The CV macro
00213 // is used to index into the tet connectivity vector.
00214
00215 // Subdivision templates for splitting the tet into 28 hexes were derived by hand, and are
00216 // listed below (using the indexing scheme described above).
00217
00218 #define EDGE 0
00219 #define FACE 1
00220 #define TET 2
00221 #define AINDEX 0
00222 #define BINDEX 1
00223 #define CINDEX 2
00224 #define DINDEX 3
00225 #define EINDEX 4
00226 #define FINDEX 5
00227 #define GINDEX 6
00228 #define HINDEX 7
00229 #define IINDEX 8
00230 #define V0INDEX 0
00231 #define V1INDEX 1
00232 #define V2INDEX 2
00233 #define V3INDEX 3
00234 #define CV( a ) tet_conn[a]
00235 #define ESV( a, b ) subdiv_verts[(a)*9 + ( b )]
00236 #define FSV( a, b ) subdiv_verts[54 + (a)*9 + ( b )]
00237 #define TSV( a, b ) subdiv_verts[90 + (a)*9 + ( b )]
00238
00239 EntityHandle this_connect[8], this_hex;
00240
00241 // first, interstices hexes, three per vertex/spherical surface
00242 // V0:
00243 int i = 0;
00244 this_connect[i++] = ESV( 0, AINDEX );
00245 this_connect[i++] = ESV( 0, CINDEX );
00246 this_connect[i++] = FSV( 3, DINDEX );
00247 this_connect[i++] = FSV( 3, AINDEX );
00248 this_connect[i++] = FSV( 0, AINDEX );
00249 this_connect[i++] = FSV( 0, DINDEX );
00250 this_connect[i++] = TSV( 0, EINDEX );
00251 this_connect[i++] = TSV( 0, AINDEX );
00252 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00253 interstic_hexes.push_back( this_hex );
00254
00255 i = 0;
00256 this_connect[i++] = FSV( 0, AINDEX );
00257 this_connect[i++] = FSV( 0, DINDEX );
00258 this_connect[i++] = TSV( 0, EINDEX );
00259 this_connect[i++] = TSV( 0, AINDEX );
00260 this_connect[i++] = ESV( 3, AINDEX );
00261 this_connect[i++] = ESV( 3, CINDEX );
00262 this_connect[i++] = FSV( 2, DINDEX );
00263 this_connect[i++] = FSV( 2, AINDEX );
00264 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00265 interstic_hexes.push_back( this_hex );
00266
00267 i = 0;
00268 this_connect[i++] = FSV( 3, AINDEX );
00269 this_connect[i++] = FSV( 3, DINDEX );
00270 this_connect[i++] = ESV( 2, CINDEX );
00271 this_connect[i++] = ESV( 2, BINDEX );
00272 this_connect[i++] = TSV( 0, AINDEX );
00273 this_connect[i++] = TSV( 0, EINDEX );
00274 this_connect[i++] = FSV( 2, DINDEX );
00275 this_connect[i++] = FSV( 2, AINDEX );
00276 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00277 interstic_hexes.push_back( this_hex );
00278
00279 // V1:
00280 i = 0;
00281 this_connect[i++] = ESV( 0, CINDEX );
00282 this_connect[i++] = ESV( 0, BINDEX );
00283 this_connect[i++] = FSV( 3, CINDEX );
00284 this_connect[i++] = FSV( 3, DINDEX );
00285 this_connect[i++] = FSV( 0, DINDEX );
00286 this_connect[i++] = FSV( 0, BINDEX );
00287 this_connect[i++] = TSV( 0, BINDEX );
00288 this_connect[i++] = TSV( 0, EINDEX );
00289 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00290 interstic_hexes.push_back( this_hex );
00291
00292 i = 0;
00293 this_connect[i++] = FSV( 0, DINDEX );
00294 this_connect[i++] = FSV( 0, BINDEX );
00295 this_connect[i++] = TSV( 0, BINDEX );
00296 this_connect[i++] = TSV( 0, EINDEX );
00297 this_connect[i++] = ESV( 4, CINDEX );
00298 this_connect[i++] = ESV( 4, AINDEX );
00299 this_connect[i++] = FSV( 1, AINDEX );
00300 this_connect[i++] = FSV( 1, DINDEX );
00301 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00302 interstic_hexes.push_back( this_hex );
00303
00304 i = 0;
00305 this_connect[i++] = FSV( 1, DINDEX );
00306 this_connect[i++] = FSV( 1, AINDEX );
00307 this_connect[i++] = TSV( 0, BINDEX );
00308 this_connect[i++] = TSV( 0, EINDEX );
00309 this_connect[i++] = ESV( 1, CINDEX );
00310 this_connect[i++] = ESV( 1, AINDEX );
00311 this_connect[i++] = FSV( 3, CINDEX );
00312 this_connect[i++] = FSV( 3, DINDEX );
00313 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00314 interstic_hexes.push_back( this_hex );
00315
00316 // V2:
00317 i = 0;
00318 this_connect[i++] = FSV( 3, DINDEX );
00319 this_connect[i++] = ESV( 1, CINDEX );
00320 this_connect[i++] = ESV( 1, BINDEX );
00321 this_connect[i++] = FSV( 3, BINDEX );
00322 this_connect[i++] = TSV( 0, EINDEX );
00323 this_connect[i++] = FSV( 1, DINDEX );
00324 this_connect[i++] = FSV( 1, BINDEX );
00325 this_connect[i++] = TSV( 0, CINDEX );
00326 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00327 interstic_hexes.push_back( this_hex );
00328
00329 i = 0;
00330 this_connect[i++] = TSV( 0, EINDEX );
00331 this_connect[i++] = FSV( 1, DINDEX );
00332 this_connect[i++] = FSV( 1, BINDEX );
00333 this_connect[i++] = TSV( 0, CINDEX );
00334 this_connect[i++] = FSV( 2, DINDEX );
00335 this_connect[i++] = ESV( 5, CINDEX );
00336 this_connect[i++] = ESV( 5, AINDEX );
00337 this_connect[i++] = FSV( 2, CINDEX );
00338 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00339 interstic_hexes.push_back( this_hex );
00340
00341 i = 0;
00342 this_connect[i++] = TSV( 0, CINDEX );
00343 this_connect[i++] = FSV( 2, CINDEX );
00344 this_connect[i++] = ESV( 2, AINDEX );
00345 this_connect[i++] = FSV( 3, BINDEX );
00346 this_connect[i++] = TSV( 0, EINDEX );
00347 this_connect[i++] = FSV( 2, DINDEX );
00348 this_connect[i++] = ESV( 2, CINDEX );
00349 this_connect[i++] = FSV( 3, DINDEX );
00350 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00351 interstic_hexes.push_back( this_hex );
00352
00353 // V3:
00354 i = 0;
00355 this_connect[i++] = TSV( 0, EINDEX );
00356 this_connect[i++] = FSV( 1, DINDEX );
00357 this_connect[i++] = ESV( 5, CINDEX );
00358 this_connect[i++] = FSV( 2, DINDEX );
00359 this_connect[i++] = TSV( 0, DINDEX );
00360 this_connect[i++] = FSV( 1, CINDEX );
00361 this_connect[i++] = ESV( 5, BINDEX );
00362 this_connect[i++] = FSV( 2, BINDEX );
00363 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00364 interstic_hexes.push_back( this_hex );
00365
00366 i = 0;
00367 this_connect[i++] = FSV( 0, DINDEX );
00368 this_connect[i++] = ESV( 4, CINDEX );
00369 this_connect[i++] = FSV( 1, DINDEX );
00370 this_connect[i++] = TSV( 0, EINDEX );
00371 this_connect[i++] = FSV( 0, CINDEX );
00372 this_connect[i++] = ESV( 4, BINDEX );
00373 this_connect[i++] = FSV( 1, CINDEX );
00374 this_connect[i++] = TSV( 0, DINDEX );
00375 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00376 interstic_hexes.push_back( this_hex );
00377
00378 i = 0;
00379 this_connect[i++] = ESV( 3, CINDEX );
00380 this_connect[i++] = FSV( 0, DINDEX );
00381 this_connect[i++] = TSV( 0, EINDEX );
00382 this_connect[i++] = FSV( 2, DINDEX );
00383 this_connect[i++] = ESV( 3, BINDEX );
00384 this_connect[i++] = FSV( 0, CINDEX );
00385 this_connect[i++] = TSV( 0, DINDEX );
00386 this_connect[i++] = FSV( 2, BINDEX );
00387 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00388 interstic_hexes.push_back( this_hex );
00389
00390 // now, the sphere interiors, four hexes per vertex sphere
00391
00392 // V0:
00393 i = 0;
00394 this_connect[i++] = CV( V0INDEX );
00395 this_connect[i++] = ESV( 0, DINDEX );
00396 this_connect[i++] = FSV( 3, EINDEX );
00397 this_connect[i++] = ESV( 2, EINDEX );
00398 this_connect[i++] = ESV( 3, DINDEX );
00399 this_connect[i++] = FSV( 0, EINDEX );
00400 this_connect[i++] = TSV( 0, FINDEX );
00401 this_connect[i++] = FSV( 2, EINDEX );
00402 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00403 sphere_hexes.push_back( this_hex );
00404
00405 i = 0;
00406 this_connect[i++] = ESV( 0, DINDEX );
00407 this_connect[i++] = ESV( 0, AINDEX );
00408 this_connect[i++] = FSV( 3, AINDEX );
00409 this_connect[i++] = FSV( 3, EINDEX );
00410 this_connect[i++] = FSV( 0, EINDEX );
00411 this_connect[i++] = FSV( 0, AINDEX );
00412 this_connect[i++] = TSV( 0, AINDEX );
00413 this_connect[i++] = TSV( 0, FINDEX );
00414 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00415 sphere_hexes.push_back( this_hex );
00416
00417 i = 0;
00418 this_connect[i++] = FSV( 3, EINDEX );
00419 this_connect[i++] = FSV( 3, AINDEX );
00420 this_connect[i++] = ESV( 2, BINDEX );
00421 this_connect[i++] = ESV( 2, EINDEX );
00422 this_connect[i++] = TSV( 0, FINDEX );
00423 this_connect[i++] = TSV( 0, AINDEX );
00424 this_connect[i++] = FSV( 2, AINDEX );
00425 this_connect[i++] = FSV( 2, EINDEX );
00426 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00427 sphere_hexes.push_back( this_hex );
00428
00429 i = 0;
00430 this_connect[i++] = TSV( 0, FINDEX );
00431 this_connect[i++] = TSV( 0, AINDEX );
00432 this_connect[i++] = FSV( 2, AINDEX );
00433 this_connect[i++] = FSV( 2, EINDEX );
00434 this_connect[i++] = FSV( 0, EINDEX );
00435 this_connect[i++] = FSV( 0, AINDEX );
00436 this_connect[i++] = ESV( 3, AINDEX );
00437 this_connect[i++] = ESV( 3, DINDEX );
00438 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00439 sphere_hexes.push_back( this_hex );
00440
00441 // V1:
00442 i = 0;
00443 this_connect[i++] = CV( V1INDEX );
00444 this_connect[i++] = ESV( 1, DINDEX );
00445 this_connect[i++] = FSV( 3, GINDEX );
00446 this_connect[i++] = ESV( 0, EINDEX );
00447 this_connect[i++] = ESV( 4, DINDEX );
00448 this_connect[i++] = FSV( 1, EINDEX );
00449 this_connect[i++] = TSV( 0, GINDEX );
00450 this_connect[i++] = FSV( 0, FINDEX );
00451 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00452 sphere_hexes.push_back( this_hex );
00453
00454 i = 0;
00455 this_connect[i++] = FSV( 3, GINDEX );
00456 this_connect[i++] = ESV( 1, DINDEX );
00457 this_connect[i++] = ESV( 1, AINDEX );
00458 this_connect[i++] = FSV( 3, CINDEX );
00459 this_connect[i++] = TSV( 0, GINDEX );
00460 this_connect[i++] = FSV( 1, EINDEX );
00461 this_connect[i++] = FSV( 1, AINDEX );
00462 this_connect[i++] = TSV( 0, BINDEX );
00463 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00464 sphere_hexes.push_back( this_hex );
00465
00466 i = 0;
00467 this_connect[i++] = TSV( 0, GINDEX );
00468 this_connect[i++] = FSV( 1, EINDEX );
00469 this_connect[i++] = FSV( 1, AINDEX );
00470 this_connect[i++] = TSV( 0, BINDEX );
00471 this_connect[i++] = FSV( 0, FINDEX );
00472 this_connect[i++] = ESV( 4, DINDEX );
00473 this_connect[i++] = ESV( 4, AINDEX );
00474 this_connect[i++] = FSV( 0, BINDEX );
00475 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00476 sphere_hexes.push_back( this_hex );
00477
00478 i = 0;
00479 this_connect[i++] = ESV( 0, BINDEX );
00480 this_connect[i++] = ESV( 0, EINDEX );
00481 this_connect[i++] = FSV( 3, GINDEX );
00482 this_connect[i++] = FSV( 3, CINDEX );
00483 this_connect[i++] = FSV( 0, BINDEX );
00484 this_connect[i++] = FSV( 0, FINDEX );
00485 this_connect[i++] = TSV( 0, GINDEX );
00486 this_connect[i++] = TSV( 0, BINDEX );
00487 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00488 sphere_hexes.push_back( this_hex );
00489
00490 // V2:
00491 i = 0;
00492 this_connect[i++] = ESV( 1, BINDEX );
00493 this_connect[i++] = ESV( 1, EINDEX );
00494 this_connect[i++] = FSV( 3, FINDEX );
00495 this_connect[i++] = FSV( 3, BINDEX );
00496 this_connect[i++] = FSV( 1, BINDEX );
00497 this_connect[i++] = FSV( 1, FINDEX );
00498 this_connect[i++] = TSV( 0, HINDEX );
00499 this_connect[i++] = TSV( 0, CINDEX );
00500 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00501 sphere_hexes.push_back( this_hex );
00502
00503 i = 0;
00504 this_connect[i++] = FSV( 3, FINDEX );
00505 this_connect[i++] = ESV( 1, EINDEX );
00506 this_connect[i++] = CV( V2INDEX );
00507 this_connect[i++] = ESV( 2, DINDEX );
00508 this_connect[i++] = TSV( 0, HINDEX );
00509 this_connect[i++] = FSV( 1, FINDEX );
00510 this_connect[i++] = ESV( 5, DINDEX );
00511 this_connect[i++] = FSV( 2, GINDEX );
00512 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00513 sphere_hexes.push_back( this_hex );
00514
00515 i = 0;
00516 this_connect[i++] = TSV( 0, HINDEX );
00517 this_connect[i++] = FSV( 1, FINDEX );
00518 this_connect[i++] = ESV( 5, DINDEX );
00519 this_connect[i++] = FSV( 2, GINDEX );
00520 this_connect[i++] = TSV( 0, CINDEX );
00521 this_connect[i++] = FSV( 1, BINDEX );
00522 this_connect[i++] = ESV( 5, AINDEX );
00523 this_connect[i++] = FSV( 2, CINDEX );
00524 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00525 sphere_hexes.push_back( this_hex );
00526
00527 i = 0;
00528 this_connect[i++] = FSV( 3, BINDEX );
00529 this_connect[i++] = FSV( 3, FINDEX );
00530 this_connect[i++] = ESV( 2, DINDEX );
00531 this_connect[i++] = ESV( 2, AINDEX );
00532 this_connect[i++] = TSV( 0, CINDEX );
00533 this_connect[i++] = TSV( 0, HINDEX );
00534 this_connect[i++] = FSV( 2, GINDEX );
00535 this_connect[i++] = FSV( 2, CINDEX );
00536 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00537 sphere_hexes.push_back( this_hex );
00538
00539 // V3:
00540 i = 0;
00541 this_connect[i++] = FSV( 0, CINDEX );
00542 this_connect[i++] = ESV( 4, BINDEX );
00543 this_connect[i++] = FSV( 1, CINDEX );
00544 this_connect[i++] = TSV( 0, DINDEX );
00545 this_connect[i++] = FSV( 0, GINDEX );
00546 this_connect[i++] = ESV( 4, EINDEX );
00547 this_connect[i++] = FSV( 1, GINDEX );
00548 this_connect[i++] = TSV( 0, IINDEX );
00549 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00550 sphere_hexes.push_back( this_hex );
00551
00552 i = 0;
00553 this_connect[i++] = ESV( 3, BINDEX );
00554 this_connect[i++] = FSV( 0, CINDEX );
00555 this_connect[i++] = TSV( 0, DINDEX );
00556 this_connect[i++] = FSV( 2, BINDEX );
00557 this_connect[i++] = ESV( 3, EINDEX );
00558 this_connect[i++] = FSV( 0, GINDEX );
00559 this_connect[i++] = TSV( 0, IINDEX );
00560 this_connect[i++] = FSV( 2, FINDEX );
00561 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00562 sphere_hexes.push_back( this_hex );
00563
00564 i = 0;
00565 this_connect[i++] = TSV( 0, DINDEX );
00566 this_connect[i++] = FSV( 1, CINDEX );
00567 this_connect[i++] = ESV( 5, BINDEX );
00568 this_connect[i++] = FSV( 2, BINDEX );
00569 this_connect[i++] = TSV( 0, IINDEX );
00570 this_connect[i++] = FSV( 1, GINDEX );
00571 this_connect[i++] = ESV( 5, EINDEX );
00572 this_connect[i++] = FSV( 2, FINDEX );
00573 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00574 sphere_hexes.push_back( this_hex );
00575
00576 i = 0;
00577 this_connect[i++] = FSV( 0, GINDEX );
00578 this_connect[i++] = ESV( 4, EINDEX );
00579 this_connect[i++] = FSV( 1, GINDEX );
00580 this_connect[i++] = TSV( 0, IINDEX );
00581 this_connect[i++] = ESV( 3, EINDEX );
00582 this_connect[i++] = CV( V3INDEX );
00583 this_connect[i++] = ESV( 5, EINDEX );
00584 this_connect[i++] = FSV( 2, FINDEX );
00585 result = mbImpl->create_element( MBHEX, this_connect, 8, this_hex );RR;
00586 sphere_hexes.push_back( this_hex );
00587
00588 return result;
00589 }
00590
00591 ErrorCode SphereDecomp::retrieve_subdiv_verts( EntityHandle tet,
00592 EntityHandle this_ent,
00593 const EntityHandle* tet_conn,
00594 const int dim,
00595 EntityHandle* subdiv_verts )
00596 {
00597 // get the subdiv verts for this entity
00598 ErrorCode result;
00599
00600 // if it's a tet, just put them on the end & return
00601 if( tet == this_ent )
00602 {
00603 result = mbImpl->tag_get_data( subdivVerticesTag, &this_ent, 1, &subdiv_verts[90] );
00604 return MB_SUCCESS;
00605 }
00606
00607 // if it's a sub-entity, need to find index, relative orientation, and offset
00608 // get connectivity of sub-entity
00609 std::vector< EntityHandle > this_conn;
00610 result = mbImpl->get_connectivity( &this_ent, 1, this_conn );RR;
00611
00612 // get relative orientation
00613 std::vector< int > conn_tet_indices( this_conn.size() );
00614 for( size_t i = 0; i < this_conn.size(); ++i )
00615 conn_tet_indices[i] = std::find( tet_conn, tet_conn + 4, this_conn[i] ) - tet_conn;
00616 int sense, side_no, offset;
00617 int success = CN::SideNumber( MBTET, &conn_tet_indices[0], this_conn.size(), dim, side_no, sense, offset );
00618 if( -1 == success ) return MB_FAILURE;
00619
00620 // start of this entity's subdiv_verts; edges go first, then preceding sides, then this one;
00621 // this assumes 6 edges/tet
00622 EntityHandle* subdiv_start = &subdiv_verts[( ( dim - 1 ) * 6 + side_no ) * 9];
00623
00624 // get subdiv_verts and put them into proper place
00625 result = mbImpl->tag_get_data( subdivVerticesTag, &this_ent, 1, subdiv_start );
00626
00627 // could probably do this more elegantly, but isn't worth it
00628 #define SWITCH( a, b ) \
00629 { \
00630 EntityHandle tmp_handle = a; \
00631 ( a ) = b; \
00632 ( b ) = tmp_handle; \
00633 }
00634 switch( dim )
00635 {
00636 case 1:
00637 if( offset != 0 || sense == -1 )
00638 {
00639 SWITCH( subdiv_start[0], subdiv_start[1] );
00640 SWITCH( subdiv_start[3], subdiv_start[4] );
00641 }
00642 break;
00643 case 2:
00644 // rotate first
00645 if( 0 != offset )
00646 {
00647 std::rotate( subdiv_start, subdiv_start + offset, subdiv_start + 3 );
00648 std::rotate( subdiv_start + 4, subdiv_start + 4 + offset, subdiv_start + 7 );
00649 }
00650 // now flip, if necessary
00651 if( -1 == sense )
00652 {
00653 SWITCH( subdiv_start[1], subdiv_start[2] );
00654 SWITCH( subdiv_start[5], subdiv_start[6] );
00655 }
00656 break;
00657 default:
00658 return MB_FAILURE;
00659 }
00660
00661 // ok, we're done
00662 return MB_SUCCESS;
00663 }
