Mesh Oriented datABase
(version 5.4.1)
00001 /** @example StructuredMeshSimple.cpp
00002 * \brief Show creation and query of structured mesh, serial or parallel, through MOAB's structured
00003 * mesh interface. This is an example showing creation and query of a 3D structured mesh. In
00004 * serial, a single N*N*N block of elements is created; in parallel, each proc gets an N*N*N block,
00005 * with blocks arranged in a 1d column, sharing vertices and faces at their interfaces (proc 0 has
00006 * no left neighbor and proc P-1 no right neighbor). Each square block of hex elements is then
00007 * referenced by its ijk parameterization. 1D and 2D examples could be made simply by changing the
00008 * dimension parameter passed into the MOAB functions. \n
00009 *
00010 * This example :
00011 * -# Instantiate MOAB and get the structured mesh interface
00012 * -# Decide what the local parameters of the mesh will be, based on parallel/serial and rank.
00013 * -# Create a N^d structured mesh, which includes (N+1)^d vertices and N^d elements.
00014 * -# Get the vertices and elements from moab and check their numbers against (N+1)^d and N^d,
00015 * resp.
00016 * -# Loop over elements in d nested loops over i, j, k; for each (i,j,k):
00017 * -# Get the element corresponding to (i,j,k)
00018 * -# Get the connectivity of the element
00019 * -# Get the coordinates of the vertices comprising that element
00020 * -# Release the structured mesh interface and destroy the MOAB instance
00021 *
00022 * To run: ./StructuredMeshSimple [d [N] ] \n
00023 * (default values so can run w/ no user interaction)
00024 */
00025
00026 #include "moab/Core.hpp"
00027 #include "moab/ScdInterface.hpp"
00028 #include "moab/ProgOptions.hpp"
00029 #include "moab/CN.hpp"
00030 #ifdef MOAB_HAVE_MPI
00031 #include "moab_mpi.h"
00032 #endif
00033 #include
00034 #include
00035
00036 using namespace moab;
00037 using namespace std;
00038
00039 int main( int argc, char** argv )
00040 {
00041 int N = 10, dim = 3;
00042
00043 #ifdef MOAB_HAVE_MPI
00044 MPI_Init( &argc, &argv );
00045 #endif
00046
00047 ProgOptions opts;
00048 opts.addOpt< int >( string( "dim,d" ), string( "Dimension of mesh (default=3)" ), &dim );
00049 opts.addOpt< int >( string( ",n" ), string( "Number of elements on a side (default=10)" ), &N );
00050 opts.parseCommandLine( argc, argv );
00051
00052 // 0. Instantiate MOAB and get the structured mesh interface
00053 Interface* mb = new( std::nothrow ) Core;
00054 if( NULL == mb ) return 1;
00055 ScdInterface* scdiface;
00056 ErrorCode rval = mb->query_interface( scdiface );MB_CHK_ERR( rval ); // Get a ScdInterface object through moab instance
00057
00058 // 1. Decide what the local parameters of the mesh will be, based on parallel/serial and rank.
00059 #ifdef MOAB_HAVE_MPI
00060 int rank = 0, nprocs = 1;
00061 MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
00062 MPI_Comm_rank( MPI_COMM_WORLD, &rank );
00063 int ilow = rank * N, ihigh = ilow + N;
00064 #else
00065 int rank = 0;
00066 int ilow = 0, ihigh = N;
00067 #endif
00068
00069 // 2. Create a N^d structured mesh, which includes (N+1)^d vertices and N^d elements.
00070 ScdBox* box;
00071 rval = scdiface->construct_box(
00072 HomCoord( ilow, ( dim > 1 ? 0 : -1 ),
00073 ( dim > 2 ? 0 : -1 ) ), // Use in-line logical tests to handle dimensionality
00074 HomCoord( ihigh, ( dim > 1 ? N : -1 ), ( dim > 2 ? N : -1 ) ), NULL,
00075 0, // NULL coords vector and 0 coords (don't specify coords for now)
00076 box );MB_CHK_ERR( rval ); // box is the structured box object providing the parametric
00077 // structured mesh interface for this rectangle of elements
00078
00079 // 3. Get the vertices and elements from moab and check their numbers against (N+1)^d and N^d,
00080 // resp.
00081 Range verts, elems;
00082 rval = mb->get_entities_by_dimension( 0, 0, verts );MB_CHK_ERR( rval ); // First '0' specifies "root set", or entire MOAB instance, second the
00083 // entity dimension being requested
00084 rval = mb->get_entities_by_dimension( 0, dim, elems );MB_CHK_ERR( rval );
00085
00086 #define MYSTREAM( a ) \
00087 if( !rank ) cout << ( a ) << endl
00088
00089 if( pow( N, dim ) == (int)elems.size() && pow( N + 1, dim ) == (int)verts.size() )
00090 { // Expected #e and #v are N^d and (N+1)^d, resp.
00091 #ifdef MOAB_HAVE_MPI
00092 MYSTREAM( "Proc 0: " );
00093 #endif
00094 MYSTREAM( "Created " << elems.size() << " " << CN::EntityTypeName( mb->type_from_handle( *elems.begin() ) )
00095 << " elements and " << verts.size() << " vertices." << endl );
00096 }
00097 else
00098 cout << "Created the wrong number of vertices or hexes!" << endl;
00099
00100 // 4. Loop over elements in 3 nested loops over i, j, k; for each (i,j,k):
00101 vector< double > coords( 3 * pow( N + 1, dim ) );
00102 vector< EntityHandle > connect;
00103 for( int k = 0; k < ( dim > 2 ? N : 1 ); k++ )
00104 {
00105 for( int j = 0; j < ( dim > 1 ? N : 1 ); j++ )
00106 {
00107 for( int i = 0; i < N - 1; i++ )
00108 {
00109 // 4a. Get the element corresponding to (i,j,k)
00110 EntityHandle ehandle = box->get_element( i, j, k );
00111 if( 0 == ehandle ) return MB_FAILURE;
00112 // 4b. Get the connectivity of the element
00113 rval = mb->get_connectivity( &ehandle, 1, connect );MB_CHK_ERR( rval ); // Get the connectivity, in canonical order
00114 // 4c. Get the coordinates of the vertices comprising that element
00115 rval = mb->get_coords( &connect[0], connect.size(), &coords[0] );MB_CHK_ERR( rval ); // Get the coordinates of those vertices
00116 }
00117 }
00118 }
00119
00120 // 5. Release the structured mesh interface and destroy the MOAB instance
00121 mb->release_interface( scdiface ); // Tell MOAB we're done with the ScdInterface
00122
00123 #ifdef MOAB_HAVE_MPI
00124 MPI_Finalize();
00125 #endif
00126
00127 return 0;
00128 }
