Mesh Oriented datABase
(version 5.4.1)
00001 /** @example TestErrorHandlingPar.cpp \n
00002 * Description: This example tests MOAB's trace back error handler in parallel.\n
00003 *
00004 * To run: mpiexec -np ./TestErrorHandlingPar \n
00005 */
00006
00007 #include "moab/Core.hpp"
00008 #ifdef MOAB_HAVE_MPI
00009 #include "moab_mpi.h"
00010 #endif
00011
00012 #include
00013
00014 using namespace moab;
00015 using namespace std;
00016
00017 // In this test case, a global fatal error MB_NOT_IMPLEMENTED is returned by MOAB
00018 // Note, it is printed by root processor 0 only
00019 ErrorCode TestErrorHandlingPar_1()
00020 {
00021 Core moab;
00022 Interface& mb = moab;
00023
00024 string opts = ";;";
00025 #ifdef MOAB_HAVE_MPI
00026 // Use parallel options
00027 opts += "PARALLEL=READ_PART;PARTITION_METHOD=SQIJ";
00028 #endif
00029
00030 // Load a CAM-FV file and read a variable on edges (not supported yet)
00031 string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" );
00032 opts += ";VARIABLE=US";
00033 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, opts.c_str() );MB_CHK_ERR( rval );
00034
00035 return MB_SUCCESS;
00036 }
00037
00038 // In this test case, a per-processor relevant error MB_FAILURE is returned by MOAB
00039 // Note, it is printed by all processors
00040 ErrorCode TestErrorHandlingPar_2()
00041 {
00042 Core moab;
00043 Interface& mb = moab;
00044
00045 string opts = ";;";
00046 #ifdef MOAB_HAVE_MPI
00047 // Use parallel options
00048 opts += "PARALLEL=READ_PART;PARTITION_METHOD=UNKNOWN";
00049 #endif
00050
00051 // Load a CAM-FV file with an unknown partition method specified
00052 string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" );
00053 opts += ";VARIABLE=T";
00054 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, opts.c_str() );MB_CHK_ERR( rval );
00055
00056 return MB_SUCCESS;
00057 }
00058
00059 int main( int argc, char** argv )
00060 {
00061 if( argc < 2 )
00062 {
00063 cout << "Usage: " << argv[0] << " " << endl;
00064 return 0;
00065 }
00066
00067 #ifdef MOAB_HAVE_MPI
00068 MPI_Init( &argc, &argv );
00069 #endif
00070
00071 // Initialize error handler, optional for this example (using moab instances)
00072 MBErrorHandler_Init();
00073
00074 ErrorCode rval = MB_SUCCESS;
00075
00076 int test_case_num = atoi( argv[1] );
00077 switch( test_case_num )
00078 {
00079 case 1:
00080 rval = TestErrorHandlingPar_1();MB_CHK_ERR( rval );
00081 break;
00082 case 2:
00083 rval = TestErrorHandlingPar_2();MB_CHK_ERR( rval );
00084 break;
00085 default:
00086 break;
00087 }
00088
00089 // Finalize error handler, optional for this example (using moab instances)
00090 MBErrorHandler_Finalize();
00091
00092 #ifdef MOAB_HAVE_MPI
00093 MPI_Finalize();
00094 #endif
00095
00096 return 0;
00097 }
