Mesh Oriented datABase
(version 5.4.1)
00001 /*========================================================================= 00002 00003 Module: $RCSfile: V_KnifeMetric.cpp,v $ 00004 00005 Copyright (c) 2006 Sandia Corporation. 00006 All rights reserved. 00007 See Copyright.txt or http://www.kitware.com/Copyright.htm for details. 00008 00009 This software is distributed WITHOUT ANY WARRANTY; without even 00010 the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR 00011 PURPOSE. See the above copyright notice for more information. 00012 00013 =========================================================================*/ 00014 00015 /* 00016 * 00017 * KnifeMetrics.cpp contains quality calculations for knives 00018 * 00019 * This file is part of VERDICT 00020 * 00021 */ 00022 00023 #define VERDICT_EXPORTS 00024 00025 #include "moab/verdict.h" 00026 #include "VerdictVector.hpp" 00027 #include <memory.h> 00028 00029 /* a knife element 00030 00031 3 00032 _/\_ 00033 _/ | \_ 00034 0 _/ \_ 2 00035 |\_ | ___/| 00036 | \ __/ | 00037 | 1\/ | | 00038 | \ | 00039 |_____\|_____| 00040 4 5 6 00041 00042 00043 (edge 3,5 is is a hidden line if you will) 00044 00045 if this is hard to visualize, consider a hex 00046 with nodes 5 and 7 becoming the same node 00047 00048 00049 */ 00050 00051 /*! 00052 calculates the volume of a knife element 00053 00054 this is done by dividing the knife into 4 tets 00055 and summing the volumes of each. 00056 */ 00057 00058 C_FUNC_DEF double v_knife_volume( int num_nodes, double coordinates[][3] ) 00059 { 00060 double volume = 0; 00061 VerdictVector side1, side2, side3; 00062 00063 if( num_nodes == 7 ) 00064 { 00065 00066 // divide the knife into 4 tets and calculate the volume 00067 00068 side1.set( coordinates[1][0] - coordinates[0][0], coordinates[1][1] - coordinates[0][1], 00069 coordinates[1][2] - coordinates[0][2] ); 00070 side2.set( coordinates[3][0] - coordinates[0][0], coordinates[3][1] - coordinates[0][1], 00071 coordinates[3][2] - coordinates[0][2] ); 00072 side3.set( coordinates[4][0] - coordinates[0][0], coordinates[4][1] - coordinates[0][1], 00073 coordinates[4][2] - coordinates[0][2] ); 00074 00075 volume = side3 % ( side1 * side2 ) / 6; 00076 00077 side1.set( coordinates[5][0] - coordinates[1][0], coordinates[5][1] - coordinates[1][1], 00078 coordinates[5][2] - coordinates[1][2] ); 00079 side2.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1], 00080 coordinates[3][2] - coordinates[1][2] ); 00081 side3.set( coordinates[4][0] - coordinates[1][0], coordinates[4][1] - coordinates[1][1], 00082 coordinates[4][2] - coordinates[1][2] ); 00083 00084 volume += side3 % ( side1 * side2 ) / 6; 00085 00086 side1.set( coordinates[2][0] - coordinates[1][0], coordinates[2][1] - coordinates[1][1], 00087 coordinates[2][2] - coordinates[1][2] ); 00088 side2.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1], 00089 coordinates[3][2] - coordinates[1][2] ); 00090 side3.set( coordinates[6][0] - coordinates[1][0], coordinates[6][1] - coordinates[1][1], 00091 coordinates[6][2] - coordinates[1][2] ); 00092 00093 volume += side3 % ( side1 * side2 ) / 6; 00094 00095 side1.set( coordinates[3][0] - coordinates[1][0], coordinates[3][1] - coordinates[1][1], 00096 coordinates[3][2] - coordinates[1][2] ); 00097 side2.set( coordinates[5][0] - coordinates[1][0], coordinates[5][1] - coordinates[1][1], 00098 coordinates[5][2] - coordinates[1][2] ); 00099 side3.set( coordinates[6][0] - coordinates[1][0], coordinates[6][1] - coordinates[1][1], 00100 coordinates[6][2] - coordinates[1][2] ); 00101 00102 volume += side3 % ( side1 * side2 ) / 6; 00103 } 00104 00105 return (double)volume; 00106 } 00107 00108 /*! 00109 00110 calculate the quality metrics of a knife element. 00111 00112 There is only one, but we put this here to be consistent with 00113 functions for other element types. Who knows if we'll add 00114 more metrics. 00115 */ 00116 00117 C_FUNC_DEF void v_knife_quality( int num_nodes, 00118 double coordinates[][3], 00119 unsigned int metrics_request_flag, 00120 KnifeMetricVals* metric_vals ) 00121 { 00122 memset( metric_vals, 0, sizeof( KnifeMetricVals ) ); 00123 00124 if( metrics_request_flag & V_KNIFE_VOLUME ) metric_vals->volume = v_knife_volume( num_nodes, coordinates ); 00125 }
