Mesh Oriented datABase
(version 5.4.1)
00001 #include "WriteGmsh.hpp" 00002 #include "moab/CN.hpp" 00003 #include "MBTagConventions.hpp" 00004 #include "MBParallelConventions.h" 00005 #include "moab/Interface.hpp" 00006 #include "moab/Range.hpp" 00007 #include "moab/WriteUtilIface.hpp" 00008 #include "moab/FileOptions.hpp" 00009 #include "GmshUtil.hpp" 00010 00011 #include <fstream> 00012 #include <map> 00013 #include <set> 00014 00015 namespace moab 00016 { 00017 00018 const int DEFAULT_PRECISION = 10; 00019 00020 WriterIface* WriteGmsh::factory( Interface* iface ) 00021 { 00022 return new WriteGmsh( iface ); 00023 } 00024 00025 WriteGmsh::WriteGmsh( Interface* impl ) : mbImpl( impl ) 00026 { 00027 impl->query_interface( mWriteIface ); 00028 } 00029 00030 WriteGmsh::~WriteGmsh() 00031 { 00032 mbImpl->release_interface( mWriteIface ); 00033 } 00034 00035 // A structure to store per-element information. 00036 struct ElemInfo 00037 { 00038 void set( int st, int idt ) 00039 { 00040 while( count < st ) 00041 sets[count++] = 0; 00042 sets[count++] = idt; 00043 } 00044 int count; // Number of valid entries in sets[] 00045 int sets[3]; // IDs of owning block, geom, and partition; respectively 00046 int id; // Global ID of element 00047 int type; // Gmsh element type 00048 }; 00049 00050 //! Writes out a file 00051 ErrorCode WriteGmsh::write_file( const char* file_name, 00052 const bool overwrite, 00053 const FileOptions& options, 00054 const EntityHandle* output_list, 00055 const int num_sets, 00056 const std::vector< std::string >& /* qa_list */, 00057 const Tag* /* tag_list */, 00058 int /* num_tags */, 00059 int /* export_dimension */ ) 00060 { 00061 ErrorCode rval; 00062 Tag global_id = 0, block_tag = 0, geom_tag = 0, prtn_tag = 0; 00063 00064 if( !overwrite ) 00065 { 00066 rval = mWriteIface->check_doesnt_exist( file_name ); 00067 if( MB_SUCCESS != rval ) return rval; 00068 } 00069 00070 // Get tags 00071 global_id = mbImpl->globalId_tag(); 00072 mbImpl->tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, block_tag ); 00073 if( global_id ) mbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag ); 00074 mbImpl->tag_get_handle( PARALLEL_PARTITION_TAG_NAME, 1, MB_TYPE_INTEGER, prtn_tag ); 00075 00076 // Define arrays to hold entity sets of interest 00077 Range sets[3]; 00078 Tag set_tags[] = { block_tag, geom_tag, prtn_tag }; 00079 Tag set_ids[] = { block_tag, 0 /*global_id*/, prtn_tag }; 00080 00081 // Get entities to write 00082 Range elements, nodes; 00083 if( !output_list ) 00084 { 00085 rval = mbImpl->get_entities_by_dimension( 0, 0, nodes, false ); 00086 if( MB_SUCCESS != rval ) return rval; 00087 for( int d = 1; d <= 3; ++d ) 00088 { 00089 Range tmp_range; 00090 rval = mbImpl->get_entities_by_dimension( 0, d, tmp_range, false ); 00091 if( MB_SUCCESS != rval ) return rval; 00092 elements.merge( tmp_range ); 00093 } 00094 00095 for( int s = 0; s < 3; ++s ) 00096 { 00097 if( set_tags[s] ) 00098 { 00099 rval = mbImpl->get_entities_by_type_and_tag( 0, MBENTITYSET, set_tags + s, 0, 1, sets[s] ); 00100 if( MB_SUCCESS != rval ) return rval; 00101 } 00102 } 00103 } 00104 else 00105 { 00106 for( int i = 0; i < num_sets; ++i ) 00107 { 00108 EntityHandle set = output_list[i]; 00109 for( int d = 1; d < 3; ++d ) 00110 { 00111 Range tmp_range, tmp_nodes; 00112 rval = mbImpl->get_entities_by_dimension( set, d, tmp_range, true ); 00113 if( rval != MB_SUCCESS ) return rval; 00114 elements.merge( tmp_range ); 00115 rval = mbImpl->get_adjacencies( tmp_range, set, false, tmp_nodes ); 00116 if( rval != MB_SUCCESS ) return rval; 00117 nodes.merge( tmp_nodes ); 00118 } 00119 00120 for( int s = 0; s < 3; ++s ) 00121 { 00122 if( set_tags[s] ) 00123 { 00124 Range tmp_range; 00125 rval = mbImpl->get_entities_by_type_and_tag( set, MBENTITYSET, set_tags + s, 0, 1, tmp_range ); 00126 if( MB_SUCCESS != rval ) return rval; 00127 sets[s].merge( tmp_range ); 00128 int junk; 00129 rval = mbImpl->tag_get_data( set_tags[s], &set, 1, &junk ); 00130 if( MB_SUCCESS == rval ) sets[s].insert( set ); 00131 } 00132 } 00133 } 00134 } 00135 00136 if( elements.empty() ) 00137 { 00138 MB_SET_ERR( MB_ENTITY_NOT_FOUND, "Nothing to write" ); 00139 } 00140 00141 // Get global IDs for all elements. 00142 // First try to get from tag. If tag is not defined or not set 00143 // for all elements, use handle value instead. 00144 std::vector< int > global_id_array( elements.size() ); 00145 std::vector< int >::iterator id_iter; 00146 if( !global_id || MB_SUCCESS != mbImpl->tag_get_data( global_id, elements, &global_id_array[0] ) ) 00147 { 00148 id_iter = global_id_array.begin(); 00149 for( Range::iterator i = elements.begin(); i != elements.end(); ++i, ++id_iter ) 00150 *id_iter = mbImpl->id_from_handle( *i ); 00151 } 00152 00153 // Figure out the maximum ID value so we know where to start allocating 00154 // new IDs when we encounter ID conflicts. 00155 int max_id = 0; 00156 for( id_iter = global_id_array.begin(); id_iter != global_id_array.end(); ++id_iter ) 00157 if( *id_iter > max_id ) max_id = *id_iter; 00158 00159 // Initialize ElemInfo struct for each element 00160 std::map< EntityHandle, ElemInfo > elem_sets; // Per-element info 00161 std::set< int > elem_global_ids; // Temporary for finding duplicate IDs 00162 id_iter = global_id_array.begin(); 00163 // Iterate backwards to give highest-dimension entities first dibs for 00164 // a conflicting ID. 00165 for( Range::reverse_iterator i = elements.rbegin(); i != elements.rend(); ++i ) 00166 { 00167 int id = *id_iter; 00168 ++id_iter; 00169 if( !elem_global_ids.insert( id ).second ) id = ++max_id; 00170 00171 ElemInfo& ei = elem_sets[*i]; 00172 ei.count = 0; 00173 ei.id = id; 00174 00175 EntityType type = mbImpl->type_from_handle( *i ); 00176 int num_vtx; 00177 const EntityHandle* conn; 00178 rval = mbImpl->get_connectivity( *i, conn, num_vtx ); 00179 if( MB_SUCCESS != rval ) return rval; 00180 00181 ei.type = GmshUtil::get_gmsh_type( type, num_vtx ); 00182 if( ei.type < 0 ) 00183 { 00184 MB_SET_ERR( MB_FILE_WRITE_ERROR, "Gmem file format does not support element of type " 00185 << CN::EntityTypeName( type ) << " with " << num_vtx << " vertices" ); 00186 } 00187 } 00188 // Don't need these any more, free memory. 00189 elem_global_ids.clear(); 00190 global_id_array.clear(); 00191 00192 // For each material set, geometry set, or partition; store 00193 // the ID of the set on each element. 00194 for( int s = 0; s < 3; ++s ) 00195 { 00196 if( !set_tags[s] ) continue; 00197 00198 for( Range::iterator i = sets[s].begin(); i != sets[s].end(); ++i ) 00199 { 00200 int id; 00201 if( set_ids[s] ) 00202 { 00203 rval = mbImpl->tag_get_data( set_ids[s], &*i, 1, &id ); 00204 if( MB_SUCCESS != rval ) return rval; 00205 } 00206 else 00207 id = mbImpl->id_from_handle( *i ); 00208 00209 Range elems; 00210 rval = mbImpl->get_entities_by_handle( *i, elems ); 00211 if( MB_SUCCESS != rval ) return rval; 00212 00213 elems = intersect( elems, elements ); 00214 for( Range::iterator j = elems.begin(); j != elems.end(); ++j ) 00215 elem_sets[*j].set( s, id ); 00216 } 00217 } 00218 00219 // Create file 00220 std::ofstream out( file_name ); 00221 if( !out ) return MB_FILE_DOES_NOT_EXIST; 00222 00223 // Write header 00224 out << "$MeshFormat" << std::endl; 00225 out << "2.0 0 " << sizeof( double ) << std::endl; 00226 out << "$EndMeshFormat" << std::endl; 00227 00228 // Set precision for node coordinates 00229 int precision; 00230 if( MB_SUCCESS != options.get_int_option( "PRECISION", precision ) ) precision = DEFAULT_PRECISION; 00231 const int old_precision = out.precision(); 00232 out.precision( precision ); 00233 00234 // Write nodes 00235 out << "$Nodes" << std::endl; 00236 out << nodes.size() << std::endl; 00237 std::vector< double > coords( 3 * nodes.size() ); 00238 rval = mbImpl->get_coords( nodes, &coords[0] ); 00239 if( MB_SUCCESS != rval ) return rval; 00240 std::vector< double >::iterator c = coords.begin(); 00241 for( Range::iterator i = nodes.begin(); i != nodes.end(); ++i ) 00242 { 00243 out << mbImpl->id_from_handle( *i ); 00244 out << " " << *c; 00245 ++c; 00246 out << " " << *c; 00247 ++c; 00248 out << " " << *c; 00249 ++c; 00250 out << std::endl; 00251 } 00252 out << "$EndNodes" << std::endl; 00253 coords.clear(); 00254 00255 // Restore stream state 00256 out.precision( old_precision ); 00257 00258 // Write elements 00259 out << "$Elements" << std::endl; 00260 out << elem_sets.size() << std::endl; 00261 for( std::map< EntityHandle, ElemInfo >::iterator i = elem_sets.begin(); i != elem_sets.end(); ++i ) 00262 { 00263 int num_vtx; 00264 const EntityHandle* conn; 00265 rval = mbImpl->get_connectivity( i->first, conn, num_vtx ); 00266 if( MB_SUCCESS != rval ) return rval; 00267 out << i->second.id << ' ' << i->second.type << ' ' << i->second.count; 00268 for( int j = 0; j < i->second.count; ++j ) 00269 out << ' ' << i->second.sets[j]; 00270 00271 const int* order = GmshUtil::gmshElemTypes[i->second.type].node_order; 00272 00273 // Need to re-order vertices 00274 if( order ) 00275 { 00276 for( int j = 0; j < num_vtx; ++j ) 00277 out << ' ' << mbImpl->id_from_handle( conn[order[j]] ); 00278 } 00279 else 00280 { 00281 for( int j = 0; j < num_vtx; ++j ) 00282 out << ' ' << mbImpl->id_from_handle( conn[j] ); 00283 } 00284 out << std::endl; 00285 } 00286 out << "$EndElements" << std::endl; 00287 00288 // Done 00289 return MB_SUCCESS; 00290 } 00291 00292 } // namespace moab
