Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef WRITE_GMSH_HPP 00017 #define WRITE_GMSH_HPP 00018 00019 #include "moab/Forward.hpp" 00020 #include "moab/WriterIface.hpp" 00021 #include <cstdio> 00022 00023 namespace moab 00024 { 00025 00026 class WriteUtilIface; 00027 00028 /** 00029 * \brief Export Gmsh files. 00030 * \author Jason Kraftcheck 00031 * 00032 * Known limitations: 00033 * - Tag data and most sets cannot be saved. 00034 * - For blocks, geometry sets, and parallel partitions, the 00035 * sets are saved but the IDs may be lost. 00036 * - File format does not support general polygons or polyhedra. 00037 * - File format does not support higher-order volume elements 00038 * other than TET10 and HEX27. 00039 */ 00040 class WriteGmsh : public WriterIface 00041 { 00042 00043 public: 00044 //! factory method 00045 static WriterIface* factory( Interface* ); 00046 00047 //! Constructor 00048 WriteGmsh( Interface* impl ); 00049 00050 //! Destructor 00051 virtual ~WriteGmsh(); 00052 00053 //! writes out a file 00054 ErrorCode write_file( const char* file_name, 00055 const bool overwrite, 00056 const FileOptions& opts, 00057 const EntityHandle* output_list, 00058 const int num_sets, 00059 const std::vector< std::string >& qa_list, 00060 const Tag* tag_list = NULL, 00061 int num_tags = 0, 00062 int export_dimension = 3 ); 00063 00064 private: 00065 //! interface instance 00066 Interface* mbImpl; 00067 WriteUtilIface* mWriteIface; 00068 }; 00069 00070 } // namespace moab 00071 00072 #endif
