Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /** 00017 * Zoltan: class to get a mesh from MOAB and write a Zoltan partition set for 00018 * that mesh back into MOAB and to a file 00019 * 00020 */ 00021 00022 #ifndef ZOLTANPARTITIONER_HPP 00023 #define ZOLTANPARTITIONER_HPP 00024 00025 #include <cstdlib> 00026 #include "moab/PartitionerBase.hpp" 00027 #include "zoltan_cpp.h" 00028 #include <ctime> 00029 00030 #ifdef MOAB_HAVE_CGM 00031 #include <map> 00032 #include "GeometryQueryTool.hpp" 00033 #include "DLIList.hpp" 00034 class RefEntity; 00035 #endif 00036 00037 extern "C" { 00038 int mbGetNumberOfAssignedObjects( void* userDefinedData, int* err ); 00039 00040 void mbGetObjectList( void* userDefinedData, 00041 int numGlobalIds, 00042 int numLids, 00043 ZOLTAN_ID_PTR gids, 00044 ZOLTAN_ID_PTR lids, 00045 int wgt_dim, 00046 float* obj_wgts, 00047 int* err ); 00048 00049 int mbGetObjectSize( void* userDefinedData, int* err ); 00050 00051 void mbGetObject( void* userDefinedData, 00052 int numGlobalIds, 00053 int numLids, 00054 int numObjs, 00055 ZOLTAN_ID_PTR gids, 00056 ZOLTAN_ID_PTR lids, 00057 int numDim, 00058 double* pts, 00059 int* err ); 00060 00061 void mbGetNumberOfEdges( void* userDefinedData, 00062 int numGlobalIds, 00063 int numLids, 00064 int numObjs, 00065 ZOLTAN_ID_PTR gids, 00066 ZOLTAN_ID_PTR lids, 00067 int* numEdges, 00068 int* err ); 00069 00070 void mbGetEdgeList( void* userDefinedData, 00071 int numGlobalIds, 00072 int numLids, 00073 int numObjs, 00074 ZOLTAN_ID_PTR gids, 00075 ZOLTAN_ID_PTR lids, 00076 int* numEdges, 00077 ZOLTAN_ID_PTR nborGlobalIds, 00078 int* nborProcs, 00079 int wgt_dim, 00080 float* edge_wgts, 00081 int* err ); 00082 00083 void mbGetPart( void* userDefinedData, 00084 int numGlobalIds, 00085 int numLids, 00086 int numObjs, 00087 ZOLTAN_ID_PTR gids, 00088 ZOLTAN_ID_PTR lids, 00089 int* part, 00090 int* err ); 00091 00092 void mbShowError( int val, const char* s, int me ); 00093 00094 void mbPrintGlobalResult( const char* s, int begin, int import, int exp, int change ); 00095 } 00096 00097 #include <vector> 00098 00099 namespace moab 00100 { 00101 00102 class ParallelComm; 00103 class Interface; 00104 class Range; 00105 } // namespace moab 00106 00107 using namespace moab; 00108 00109 class ZoltanPartitioner : public PartitionerBase< int > 00110 { 00111 00112 public: 00113 ZoltanPartitioner( Interface* impl = NULL, 00114 #ifdef MOAB_HAVE_MPI 00115 ParallelComm* parcomm = NULL, 00116 #endif 00117 const bool use_coords = false, 00118 int argc = 0, 00119 char** argv = NULL 00120 #ifdef MOAB_HAVE_CGM 00121 , 00122 GeometryQueryTool* gqt = NULL 00123 #endif 00124 00125 ); 00126 00127 virtual ~ZoltanPartitioner(); 00128 00129 ErrorCode balance_mesh( const char* zmethod, 00130 const char* other_method, 00131 const bool write_as_sets = true, 00132 const bool write_as_tags = false ); 00133 00134 virtual ErrorCode partition_mesh_and_geometry( const double part_geom_mesh_size, 00135 const int nparts, 00136 const char* zmethod, 00137 const char* other_method, 00138 double imbal_tol, 00139 const int part_dim = 3, 00140 const bool write_as_sets = true, 00141 const bool write_as_tags = false, 00142 const int obj_weight = 0, 00143 const int edge_weight = 0, 00144 const bool part_surf = false, 00145 const bool ghost = false, 00146 const int projection_type = 0, 00147 const bool recompute_rcb_box = false, 00148 const bool print_time = false ); 00149 00150 virtual ErrorCode partition_mesh( const int nparts, 00151 const char* method, 00152 const int part_dim = 3, 00153 const bool write_as_sets = true, 00154 const bool write_as_tags = false, 00155 const bool partition_tagged_sets = false, 00156 const bool partition_tagged_ents = false, 00157 const char* aggregating_tag = NULL, 00158 const bool print_time = false ); 00159 00160 // given a processor assignment returned from Zoltan, use that to infer a partition 00161 // to generate processor assignment for a new MOAB mesh in specified fileset 00162 ErrorCode partition_inferred_mesh( EntityHandle sfileset, 00163 size_t num_parts, 00164 int part_dim = 3, 00165 const bool write_as_sets = true, 00166 int projection_type = 0 ); 00167 00168 // given a processor assignment returned from Zoltan, write that as a 00169 // processor assignment to MOAB 00170 virtual ErrorCode write_partition( const int nparts, 00171 Range& elems, 00172 const int* assignment, 00173 const bool write_as_sets, 00174 const bool write_as_tags ); 00175 00176 // given x, y, z and a starting id, return where to send to each (x[i],y[i],z[i]) point 00177 ErrorCode repartition( std::vector< double >& x, 00178 std::vector< double >& y, 00179 std::vector< double >& z, 00180 int StartID, 00181 const char* zmethod, 00182 Range& localGIDs ); 00183 00184 // partition owned cell in a new number of parts, based on adjacency 00185 // we might have some extra adjacencies expressed in extraAdjCellsId, which could point to a 00186 // cell on a different task 00187 00188 ErrorCode partition_owned_cells( Range& owned, 00189 std::multimap< int, int >& extraGraphEdges, 00190 std::map< int, int > procs, 00191 int& numNewPartitions, 00192 std::map< int, Range >& distribution, 00193 int met, 00194 std::vector< char >& ZoltanBuffer ); 00195 00196 #ifdef MOAB_HAVE_CGM 00197 ErrorCode write_partition( const int nparts, 00198 DLIList< RefEntity* > entities, 00199 const int* assignment, 00200 std::vector< double >& obj_weights, 00201 const bool part_surf, 00202 const bool ghost ); 00203 00204 ErrorCode partition_surface( const int nparts, 00205 DLIList< RefEntity* > entities, 00206 const int* assignment, 00207 std::vector< double >& obj_weights ); 00208 #endif 00209 00210 // put closure of entities in the part sets too 00211 ErrorCode include_closure(); 00212 00213 // virtual ErrorCode write_file(const char *filename, const char *out_file); 00214 00215 void SetOCTPART_Parameters( const char* oct_method ); 00216 00217 void SetPARMETIS_Parameters( const char* parmetis_method ); 00218 00219 void SetHypergraph_Parameters( const char* phg_method ); 00220 00221 void SetHSFC_Parameters(); 00222 00223 void SetRIB_Parameters(); 00224 00225 void SetRCB_Parameters( const bool recompute_rcb_box = false ); 00226 00227 private: 00228 Zoltan* myZZ; 00229 00230 Range partSets; 00231 00232 int myNumPts; 00233 00234 int argcArg; 00235 00236 char** argvArg; 00237 00238 int mbGlobalSuccess( int rc ); 00239 00240 void mbPrintGlobalResult( const char* s, int begin, int import, int exp, int change ); 00241 00242 void mbShowError( int val, const char* s ); 00243 00244 // given the dimension, assemble the vertices and store in coords and 00245 // moab_ids 00246 ErrorCode assemble_graph( const int dimension, 00247 std::vector< double >& coords, 00248 std::vector< int >& moab_ids, 00249 std::vector< int >& adjacencies, 00250 std::vector< int >& length, 00251 Range& elems, 00252 bool part_geom = false, 00253 const int projection_type = 0 ); 00254 00255 #ifdef MOAB_HAVE_CGM 00256 std::map< int, int > body_vertex_map, surf_vertex_map; 00257 00258 ErrorCode assemble_graph( const int dimension, 00259 std::vector< double >& coords, 00260 std::vector< int >& moab_ids, 00261 std::vector< int >& adjacencies, 00262 std::vector< int >& length, 00263 std::vector< double >& obj_weights, 00264 std::vector< double >& edge_weights, 00265 std::vector< int >& parts, 00266 DLIList< RefEntity* >& entities, 00267 const double part_geom_mesh_size, 00268 const int n_part ); 00269 00270 ErrorCode partition_round_robin( const int n_part ); 00271 00272 ErrorCode partition_child_entities( const int dim, 00273 const int n_part, 00274 const bool partition_surf, 00275 const bool ghost = false ); 00276 00277 double estimate_face_mesh_load( RefEntity* face, const double h ); 00278 double estimate_face_comm_load( RefEntity* face, const double h ); 00279 #endif 00280 00281 void mbFinalizePoints( int npts, int numExport, ZOLTAN_ID_PTR exportLocalIDs, int* exportProcs, int** assignment ); 00282 00283 int mbInitializePoints( int npts, 00284 double* pts, 00285 int* ids, 00286 int* adjs, 00287 int* length, 00288 double* obj_weights = NULL, 00289 double* edge_weights = NULL, 00290 int* parts = NULL, 00291 bool part_geom = false ); 00292 00293 #ifdef MOAB_HAVE_CGM 00294 GeometryQueryTool* gti; 00295 #endif 00296 }; 00297 00298 inline ErrorCode ZoltanPartitioner::partition_mesh( const int nparts, 00299 const char* method, 00300 const int part_dim, 00301 const bool write_as_sets, 00302 const bool write_as_tags, 00303 const bool, 00304 const bool, 00305 const char*, 00306 const bool print_time ) 00307 { 00308 return partition_mesh_and_geometry( -1.0, nparts, method, NULL, 1.03, part_dim, write_as_sets, write_as_tags, 0, 0, 00309 false, false, 0, false, print_time ); 00310 } 00311 00312 #endif
