Mesh Oriented datABase
(version 5.4.1)
00001 /** @example copyPartition.cpp copy partition info on a mesh file from a point cloud 00002 * this tool will take an existing h5m phys grid partition file (point cloud) and copy the 00003 * partition information on a pg2 mesh file, for better viewing with VisIt 00004 * 00005 * example of usage: 00006 * ./copyPartition -p AtmPhys.h5m -g wholeATM_PG2.h5m -o atm_PG2_part.h5m 00007 * 00008 * the *PG2" style atm mesh is available in E3SM only for pg2 runs, something like 00009 * --res ne30pg2_r05_oECv3_ICG --compset A_WCYCL1850S_CMIP6 00010 * or 00011 * --res ne4pg2_ne4pg2 --compset FC5AV1C-L 00012 */ 00013 #include "moab/ProgOptions.hpp" 00014 #include "moab/Core.hpp" 00015 00016 #include <cmath> 00017 #include <sstream> 00018 00019 using namespace moab; 00020 00021 int main( int argc, char* argv[] ) 00022 { 00023 00024 ProgOptions opts; 00025 00026 std::string physfile, pg2file, outfile; 00027 00028 opts.addOpt< std::string >( "physgridfile,p", "phys grid filename", &physfile ); 00029 opts.addOpt< std::string >( "pg2file,g", "pg2 mesh file", &pg2file ); 00030 opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile ); 00031 00032 opts.parseCommandLine( argc, argv ); 00033 00034 std::cout << "phys grid cloud file: " << physfile << "\n"; 00035 std::cout << "pg2 mesh file: " << pg2file << "\n"; 00036 std::cout << "output file: " << outfile << "\n"; 00037 00038 if( physfile.empty() ) 00039 { 00040 opts.printHelp(); 00041 return 0; 00042 } 00043 ErrorCode rval; 00044 Core* mb = new Core(); 00045 00046 rval = mb->load_file( physfile.c_str() );MB_CHK_SET_ERR( rval, "can't load phys grid file" ); 00047 00048 Core* mb2 = new Core(); 00049 rval = mb2->load_file( pg2file.c_str() );MB_CHK_SET_ERR( rval, "can't load pg2 mesh file" ); 00050 00051 Tag globalIDTag1 = mb->globalId_tag(); 00052 Tag parti; 00053 rval = mb->tag_get_handle( "partition", parti );MB_CHK_SET_ERR( rval, "can't get partition tag phys grid mesh " ); 00054 00055 Tag globalIDTag2 = mb2->globalId_tag(); 00056 00057 Range verts1; 00058 rval = mb->get_entities_by_dimension( 0, 0, verts1 );MB_CHK_SET_ERR( rval, "can't get vertices " ); 00059 00060 std::vector< int > partValues; 00061 partValues.resize( verts1.size() ); 00062 rval = mb->tag_get_data( parti, verts1, &partValues[0] );MB_CHK_SET_ERR( rval, "can't get parts values on vertices " ); 00063 00064 Range cells; 00065 rval = mb2->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get 2d cells " ); 00066 std::vector< int > globalIdsCells; 00067 globalIdsCells.resize( cells.size() ); 00068 rval = mb2->tag_get_data( globalIDTag2, cells, &globalIdsCells[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); 00069 00070 std::vector< int > globalIdsVerts; 00071 globalIdsVerts.resize( verts1.size() ); 00072 rval = mb->tag_get_data( globalIDTag1, verts1, &globalIdsVerts[0] );MB_CHK_SET_ERR( rval, "can't get global ids cells " ); 00073 00074 Tag partTag; 00075 rval = mb2->tag_get_handle( "PARALLEL_PARTITION", partTag );MB_CHK_SET_ERR( rval, "can't partition tag " ); 00076 00077 Range sets; 00078 rval = mb2->get_entities_by_type_and_tag( 0, MBENTITYSET, &partTag, NULL, 1, sets );MB_CHK_ERR( rval ); 00079 00080 std::vector< int > setValues; 00081 setValues.resize( sets.size() ); 00082 rval = mb2->tag_get_data( partTag, sets, &setValues[0] );MB_CHK_ERR( rval ); 00083 00084 std::map< int, EntityHandle > valToSet; 00085 int i = 0; 00086 for( Range::iterator st = sets.begin(); st != sets.end(); ++st, i++ ) 00087 { 00088 valToSet[setValues[i]] = *st; 00089 } 00090 // now, every cell will be put into one set, by looking at the global id of cell 00091 00092 std::map< int, EntityHandle > gidToCell; 00093 i = 0; 00094 for( Range::iterator it = cells.begin(); it != cells.end(); ++it, i++ ) 00095 { 00096 gidToCell[globalIdsCells[i]] = *it; 00097 } 00098 // empty all sets 00099 rval = mb2->clear_meshset( sets );MB_CHK_ERR( rval ); 00100 00101 // look now at parti values for vertices, and their global ids 00102 for( i = 0; i < (int)verts1.size(); i++ ) 00103 { 00104 int part = partValues[i]; 00105 int gid = globalIdsVerts[i]; 00106 EntityHandle set1 = valToSet[part]; 00107 EntityHandle cell = gidToCell[gid]; 00108 rval = mb2->add_entities( set1, &cell, 1 );MB_CHK_ERR( rval ); 00109 } 00110 00111 rval = mb2->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" ); 00112 00113 delete mb; 00114 delete mb2; 00115 00116 return 0; 00117 }
