Mesh Oriented datABase
(version 5.4.1)
00001 /** \file iMOAB.cpp 00002 */ 00003 00004 #include "moab/MOABConfig.h" 00005 #include "moab/Core.hpp" 00006 #include "AEntityFactory.hpp" 00007 00008 #ifdef MOAB_HAVE_MPI 00009 #include "moab_mpi.h" 00010 #include "moab/ParallelComm.hpp" 00011 #include "moab/ParCommGraph.hpp" 00012 #include "moab/ParallelMergeMesh.hpp" 00013 #include "moab/IntxMesh/IntxUtils.hpp" 00014 #endif 00015 #include "DebugOutput.hpp" 00016 #include "moab/iMOAB.h" 00017 00018 /* this is needed because of direct access to hdf5/mhdf */ 00019 #ifdef MOAB_HAVE_HDF5 00020 #include "mhdf.h" 00021 #include <H5Tpublic.h> 00022 #endif 00023 00024 #include "moab/CartVect.hpp" 00025 #include "MBTagConventions.hpp" 00026 #include "moab/MeshTopoUtil.hpp" 00027 #include "moab/ReadUtilIface.hpp" 00028 #include "moab/MergeMesh.hpp" 00029 00030 #ifdef MOAB_HAVE_TEMPESTREMAP 00031 #include "STLStringHelper.h" 00032 #include "moab/IntxMesh/IntxUtils.hpp" 00033 00034 #include "moab/Remapping/TempestRemapper.hpp" 00035 #include "moab/Remapping/TempestOnlineMap.hpp" 00036 #endif 00037 00038 // C++ includes 00039 #include <cassert> 00040 #include <sstream> 00041 #include <iostream> 00042 00043 using namespace moab; 00044 00045 // #define VERBOSE 00046 00047 // global variables ; should they be organized in a structure, for easier references? 00048 // or how do we keep them global? 00049 00050 #ifdef __cplusplus 00051 extern "C" { 00052 #endif 00053 00054 #ifdef MOAB_HAVE_TEMPESTREMAP 00055 struct TempestMapAppData 00056 { 00057 moab::TempestRemapper* remapper; 00058 std::map< std::string, moab::TempestOnlineMap* > weightMaps; 00059 iMOAB_AppID pid_src; 00060 iMOAB_AppID pid_dest; 00061 }; 00062 #endif 00063 00064 struct appData 00065 { 00066 EntityHandle file_set; 00067 int global_id; // external component id, unique for application 00068 std::string name; 00069 Range all_verts; 00070 Range local_verts; // it could include shared, but not owned at the interface 00071 // these vertices would be all_verts if no ghosting was required 00072 Range ghost_vertices; // locally ghosted from other processors 00073 Range primary_elems; 00074 Range owned_elems; 00075 Range ghost_elems; 00076 int dimension; // 2 or 3, dimension of primary elements (redundant?) 00077 long num_global_elements; // reunion of all elements in primary_elements; either from hdf5 00078 // reading or from reduce 00079 long num_global_vertices; // reunion of all nodes, after sharing is resolved; it could be 00080 // determined from hdf5 reading 00081 Range mat_sets; 00082 std::map< int, int > matIndex; // map from global block id to index in mat_sets 00083 Range neu_sets; 00084 Range diri_sets; 00085 std::map< std::string, Tag > tagMap; 00086 std::vector< Tag > tagList; 00087 bool point_cloud; 00088 bool is_fortran; 00089 00090 #ifdef MOAB_HAVE_MPI 00091 // constructor for this ParCommGraph takes the joint comm and the MPI groups for each 00092 // application 00093 std::map< int, ParCommGraph* > pgraph; // map from context () to the parcommgraph* 00094 #endif 00095 00096 #ifdef MOAB_HAVE_TEMPESTREMAP 00097 TempestMapAppData tempestData; 00098 #endif 00099 }; 00100 00101 struct GlobalContext 00102 { 00103 // are there reasons to have multiple moab inits? Is ref count needed? 00104 Interface* MBI; 00105 // we should also have the default tags stored, initialized 00106 Tag material_tag, neumann_tag, dirichlet_tag, 00107 globalID_tag; // material, neumann, dirichlet, globalID 00108 int refCountMB; 00109 int iArgc; 00110 iMOAB_String* iArgv; 00111 int unused_pid; 00112 00113 std::map< std::string, int > appIdMap; // from app string (uppercase) to app id 00114 std::map< int, int > appIdCompMap; // from component id to app id 00115 00116 #ifdef MOAB_HAVE_MPI 00117 std::vector< ParallelComm* > pcomms; // created in order of applications, one moab::ParallelComm for each 00118 00119 #ifdef MOAB_HAVE_ZOLTAN 00120 // this data structure exists only on the root PE of the coupler 00121 // it will store the buffer with the RCB cuts from which the Zoltan zz structure can be de-serialized, 00122 // to be used in the partitioning 00123 // 00124 std::vector< char > uniqueZoltanBuffer; 00125 #endif 00126 00127 #endif 00128 00129 std::vector< appData > appDatas; // the same order as pcomms 00130 int globalrank, worldprocs; 00131 bool MPI_initialized; 00132 00133 GlobalContext() 00134 { 00135 MBI = 0; 00136 refCountMB = 0; 00137 unused_pid = 0; 00138 } 00139 }; 00140 00141 static struct GlobalContext context; 00142 00143 ErrCode iMOAB_Initialize( int argc, iMOAB_String* argv ) 00144 { 00145 if( argc ) IMOAB_CHECKPOINTER( argv, 1 ); 00146 00147 context.iArgc = argc; 00148 context.iArgv = argv; // shallow copy 00149 00150 if( 0 == context.refCountMB ) 00151 { 00152 context.MBI = new( std::nothrow ) moab::Core; 00153 // retrieve the default tags 00154 const char* const shared_set_tag_names[] = {MATERIAL_SET_TAG_NAME, NEUMANN_SET_TAG_NAME, DIRICHLET_SET_TAG_NAME, 00155 GLOBAL_ID_TAG_NAME}; 00156 // blocks, visible surfaceBC(neumann), vertexBC (Dirichlet), global id, parallel partition 00157 Tag gtags[4]; 00158 00159 for( int i = 0; i < 4; i++ ) 00160 { 00161 00162 ErrorCode rval = 00163 context.MBI->tag_get_handle( shared_set_tag_names[i], 1, MB_TYPE_INTEGER, gtags[i], MB_TAG_ANY );MB_CHK_ERR( rval ); 00164 } 00165 00166 context.material_tag = gtags[0]; 00167 context.neumann_tag = gtags[1]; 00168 context.dirichlet_tag = gtags[2]; 00169 context.globalID_tag = gtags[3]; 00170 } 00171 00172 context.MPI_initialized = false; 00173 #ifdef MOAB_HAVE_MPI 00174 int flagInit; 00175 MPI_Initialized( &flagInit ); 00176 00177 if( flagInit && !context.MPI_initialized ) 00178 { 00179 MPI_Comm_size( MPI_COMM_WORLD, &context.worldprocs ); 00180 MPI_Comm_rank( MPI_COMM_WORLD, &context.globalrank ); 00181 context.MPI_initialized = true; 00182 } 00183 #endif 00184 00185 context.refCountMB++; 00186 return moab::MB_SUCCESS; 00187 } 00188 00189 ErrCode iMOAB_InitializeFortran() 00190 { 00191 return iMOAB_Initialize( 0, 0 ); 00192 } 00193 00194 ErrCode iMOAB_Finalize() 00195 { 00196 context.refCountMB--; 00197 00198 if( 0 == context.refCountMB ) 00199 { 00200 delete context.MBI; 00201 } 00202 00203 return MB_SUCCESS; 00204 } 00205 00206 ErrCode iMOAB_RegisterApplication( const iMOAB_String app_name, 00207 #ifdef MOAB_HAVE_MPI 00208 MPI_Comm* comm, 00209 #endif 00210 int* compid, 00211 iMOAB_AppID pid ) 00212 { 00213 IMOAB_CHECKPOINTER( app_name, 1 ); 00214 #ifdef MOAB_HAVE_MPI 00215 IMOAB_CHECKPOINTER( comm, 2 ); 00216 IMOAB_CHECKPOINTER( compid, 3 ); 00217 #else 00218 IMOAB_CHECKPOINTER( compid, 2 ); 00219 #endif 00220 00221 // will create a parallel comm for this application too, so there will be a 00222 // mapping from *pid to file set and to parallel comm instances 00223 std::string name( app_name ); 00224 00225 if( context.appIdMap.find( name ) != context.appIdMap.end() ) 00226 { 00227 std::cout << " application " << name << " already registered \n"; 00228 return moab::MB_FAILURE; 00229 } 00230 00231 *pid = context.unused_pid++; 00232 context.appIdMap[name] = *pid; 00233 int rankHere = 0; 00234 #ifdef MOAB_HAVE_MPI 00235 MPI_Comm_rank( *comm, &rankHere ); 00236 #endif 00237 if( !rankHere ) std::cout << " application " << name << " with ID = " << *pid << " is registered now \n"; 00238 if( *compid <= 0 ) 00239 { 00240 std::cout << " convention for external application is to have its id positive \n"; 00241 return moab::MB_FAILURE; 00242 } 00243 00244 if( context.appIdCompMap.find( *compid ) != context.appIdCompMap.end() ) 00245 { 00246 std::cout << " external application with comp id " << *compid << " is already registered\n"; 00247 return moab::MB_FAILURE; 00248 } 00249 00250 context.appIdCompMap[*compid] = *pid; 00251 00252 // now create ParallelComm and a file set for this application 00253 #ifdef MOAB_HAVE_MPI 00254 if( *comm ) 00255 { 00256 ParallelComm* pco = new ParallelComm( context.MBI, *comm ); 00257 00258 #ifndef NDEBUG 00259 int index = pco->get_id(); // it could be useful to get app id from pcomm instance ... 00260 assert( index == *pid ); 00261 // here, we assert the the pid is the same as the id of the ParallelComm instance 00262 // useful for writing in parallel 00263 #endif 00264 context.pcomms.push_back( pco ); 00265 } 00266 else 00267 { 00268 context.pcomms.push_back( 0 ); 00269 } 00270 #endif 00271 00272 // create now the file set that will be used for loading the model in 00273 EntityHandle file_set; 00274 ErrorCode rval = context.MBI->create_meshset( MESHSET_SET, file_set );MB_CHK_ERR( rval ); 00275 00276 appData app_data; 00277 app_data.file_set = file_set; 00278 app_data.global_id = *compid; // will be used mostly for par comm graph 00279 app_data.name = name; // save the name of application 00280 00281 #ifdef MOAB_HAVE_TEMPESTREMAP 00282 app_data.tempestData.remapper = NULL; // Only allocate as needed 00283 #endif 00284 00285 app_data.point_cloud = false; 00286 app_data.is_fortran = false; 00287 00288 context.appDatas.push_back( 00289 app_data ); // it will correspond to app_FileSets[*pid] will be the file set of interest 00290 return moab::MB_SUCCESS; 00291 } 00292 00293 ErrCode iMOAB_RegisterApplicationFortran( const iMOAB_String app_name, 00294 #ifdef MOAB_HAVE_MPI 00295 int* comm, 00296 #endif 00297 int* compid, 00298 iMOAB_AppID pid ) 00299 { 00300 IMOAB_CHECKPOINTER( app_name, 1 ); 00301 #ifdef MOAB_HAVE_MPI 00302 IMOAB_CHECKPOINTER( comm, 2 ); 00303 IMOAB_CHECKPOINTER( compid, 3 ); 00304 #else 00305 IMOAB_CHECKPOINTER( compid, 2 ); 00306 #endif 00307 00308 ErrCode err; 00309 assert( app_name != nullptr ); 00310 std::string name( app_name ); 00311 00312 #ifdef MOAB_HAVE_MPI 00313 MPI_Comm ccomm; 00314 if( comm ) 00315 { 00316 // convert from Fortran communicator to a C communicator 00317 // see transfer of handles 00318 // http://www.mpi-forum.org/docs/mpi-2.2/mpi22-report/node361.htm 00319 ccomm = MPI_Comm_f2c( (MPI_Fint)*comm ); 00320 } 00321 #endif 00322 00323 // now call C style registration function: 00324 err = iMOAB_RegisterApplication( app_name, 00325 #ifdef MOAB_HAVE_MPI 00326 &ccomm, 00327 #endif 00328 compid, pid ); 00329 00330 // Now that we have created the application context, store that 00331 // the application being registered is from a Fortran context 00332 context.appDatas[*pid].is_fortran = true; 00333 00334 return err; 00335 } 00336 00337 ErrCode iMOAB_DeregisterApplication( iMOAB_AppID pid ) 00338 { 00339 // the file set , parallel comm are all in vectors indexed by *pid 00340 // assume we did not delete anything yet 00341 // *pid will not be reused if we register another application 00342 appData& data = context.appDatas[*pid]; 00343 int rankHere = 0; 00344 #ifdef MOAB_HAVE_MPI 00345 ParallelComm* pco = context.pcomms[*pid]; 00346 rankHere = pco->rank(); 00347 #endif 00348 if( !rankHere ) 00349 std::cout << " application with ID: " << *pid << " global id: " << data.global_id << " name: " << data.name 00350 << " is de-registered now \n"; 00351 00352 EntityHandle fileSet = data.file_set; 00353 // get all entities part of the file set 00354 Range fileents; 00355 ErrorCode rval = context.MBI->get_entities_by_handle( fileSet, fileents, /*recursive */ true );MB_CHK_ERR( rval ); 00356 00357 fileents.insert( fileSet ); 00358 00359 rval = context.MBI->get_entities_by_type( fileSet, MBENTITYSET, fileents );MB_CHK_ERR( rval ); // append all mesh sets 00360 00361 #ifdef MOAB_HAVE_TEMPESTREMAP 00362 if( data.tempestData.remapper ) delete data.tempestData.remapper; 00363 if( data.tempestData.weightMaps.size() ) data.tempestData.weightMaps.clear(); 00364 #endif 00365 00366 #ifdef MOAB_HAVE_MPI 00367 00368 // we could get the pco also with 00369 // ParallelComm * pcomm = ParallelComm::get_pcomm(context.MBI, *pid); 00370 00371 std::map< int, ParCommGraph* >& pargs = data.pgraph; 00372 00373 // free the parallel comm graphs associated with this app 00374 for( std::map< int, ParCommGraph* >::iterator mt = pargs.begin(); mt != pargs.end(); mt++ ) 00375 { 00376 ParCommGraph* pgr = mt->second; 00377 delete pgr; 00378 pgr = NULL; 00379 } 00380 if( pco ) delete pco; 00381 #endif 00382 00383 // delete first all except vertices 00384 Range vertices = fileents.subset_by_type( MBVERTEX ); 00385 Range noverts = subtract( fileents, vertices ); 00386 00387 rval = context.MBI->delete_entities( noverts );MB_CHK_ERR( rval ); 00388 // now retrieve connected elements that still exist (maybe in other sets, pids?) 00389 Range adj_ents_left; 00390 rval = context.MBI->get_adjacencies( vertices, 1, false, adj_ents_left, Interface::UNION );MB_CHK_ERR( rval ); 00391 rval = context.MBI->get_adjacencies( vertices, 2, false, adj_ents_left, Interface::UNION );MB_CHK_ERR( rval ); 00392 rval = context.MBI->get_adjacencies( vertices, 3, false, adj_ents_left, Interface::UNION );MB_CHK_ERR( rval ); 00393 00394 if( !adj_ents_left.empty() ) 00395 { 00396 Range conn_verts; 00397 rval = context.MBI->get_connectivity( adj_ents_left, conn_verts );MB_CHK_ERR( rval ); 00398 vertices = subtract( vertices, conn_verts ); 00399 } 00400 00401 rval = context.MBI->delete_entities( vertices );MB_CHK_ERR( rval ); 00402 00403 std::map< std::string, int >::iterator mit; 00404 00405 for( mit = context.appIdMap.begin(); mit != context.appIdMap.end(); mit++ ) 00406 { 00407 int pidx = mit->second; 00408 00409 if( *pid == pidx ) 00410 { 00411 break; 00412 } 00413 } 00414 00415 context.appIdMap.erase( mit ); 00416 std::map< int, int >::iterator mit1; 00417 00418 for( mit1 = context.appIdCompMap.begin(); mit1 != context.appIdCompMap.end(); mit1++ ) 00419 { 00420 int pidx = mit1->second; 00421 00422 if( *pid == pidx ) 00423 { 00424 break; 00425 } 00426 } 00427 00428 context.appIdCompMap.erase( mit1 ); 00429 00430 context.unused_pid--; // we have to go backwards always TODO 00431 context.appDatas.pop_back(); 00432 #ifdef MOAB_HAVE_MPI 00433 context.pcomms.pop_back(); 00434 #endif 00435 return moab::MB_SUCCESS; 00436 } 00437 00438 ErrCode iMOAB_DeregisterApplicationFortran( iMOAB_AppID pid ) 00439 { 00440 // release any Fortran specific allocations here before we pass it on 00441 context.appDatas[*pid].is_fortran = false; 00442 00443 // release all datastructure allocations 00444 return iMOAB_DeregisterApplication( pid ); 00445 } 00446 00447 // Utility function 00448 static void split_tag_names( std::string input_names, 00449 std::string& separator, 00450 std::vector< std::string >& list_tag_names ) 00451 { 00452 size_t pos = 0; 00453 std::string token; 00454 while( ( pos = input_names.find( separator ) ) != std::string::npos ) 00455 { 00456 token = input_names.substr( 0, pos ); 00457 if( !token.empty() ) list_tag_names.push_back( token ); 00458 // std::cout << token << std::endl; 00459 input_names.erase( 0, pos + separator.length() ); 00460 } 00461 if( !input_names.empty() ) 00462 { 00463 // if leftover something, or if not ended with delimiter 00464 list_tag_names.push_back( input_names ); 00465 } 00466 return; 00467 } 00468 00469 ErrCode iMOAB_ReadHeaderInfo( const iMOAB_String filename, 00470 int* num_global_vertices, 00471 int* num_global_elements, 00472 int* num_dimension, 00473 int* num_parts ) 00474 { 00475 IMOAB_CHECKPOINTER( filename, 1 ); 00476 IMOAB_ASSERT( strlen( filename ), "Invalid filename length." ); 00477 00478 #ifdef MOAB_HAVE_HDF5 00479 std::string filen( filename ); 00480 00481 int edges = 0; 00482 int faces = 0; 00483 int regions = 0; 00484 if( num_global_vertices ) *num_global_vertices = 0; 00485 if( num_global_elements ) *num_global_elements = 0; 00486 if( num_dimension ) *num_dimension = 0; 00487 if( num_parts ) *num_parts = 0; 00488 00489 mhdf_FileHandle file; 00490 mhdf_Status status; 00491 unsigned long max_id; 00492 struct mhdf_FileDesc* data; 00493 00494 file = mhdf_openFile( filen.c_str(), 0, &max_id, -1, &status ); 00495 00496 if( mhdf_isError( &status ) ) 00497 { 00498 fprintf( stderr, "%s: %s\n", filename, mhdf_message( &status ) ); 00499 return moab::MB_FAILURE; 00500 } 00501 00502 data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status, 00503 1 ); // will use extra set info; will get parallel partition tag info too! 00504 00505 if( mhdf_isError( &status ) ) 00506 { 00507 fprintf( stderr, "%s: %s\n", filename, mhdf_message( &status ) ); 00508 return moab::MB_FAILURE; 00509 } 00510 00511 if( num_dimension ) *num_dimension = data->nodes.vals_per_ent; 00512 if( num_global_vertices ) *num_global_vertices = (int)data->nodes.count; 00513 00514 for( int i = 0; i < data->num_elem_desc; i++ ) 00515 { 00516 struct mhdf_ElemDesc* el_desc = &( data->elems[i] ); 00517 struct mhdf_EntDesc* ent_d = &( el_desc->desc ); 00518 00519 if( 0 == strcmp( el_desc->type, mhdf_EDGE_TYPE_NAME ) ) 00520 { 00521 edges += ent_d->count; 00522 } 00523 00524 if( 0 == strcmp( el_desc->type, mhdf_TRI_TYPE_NAME ) ) 00525 { 00526 faces += ent_d->count; 00527 } 00528 00529 if( 0 == strcmp( el_desc->type, mhdf_QUAD_TYPE_NAME ) ) 00530 { 00531 faces += ent_d->count; 00532 } 00533 00534 if( 0 == strcmp( el_desc->type, mhdf_POLYGON_TYPE_NAME ) ) 00535 { 00536 faces += ent_d->count; 00537 } 00538 00539 if( 0 == strcmp( el_desc->type, mhdf_TET_TYPE_NAME ) ) 00540 { 00541 regions += ent_d->count; 00542 } 00543 00544 if( 0 == strcmp( el_desc->type, mhdf_PYRAMID_TYPE_NAME ) ) 00545 { 00546 regions += ent_d->count; 00547 } 00548 00549 if( 0 == strcmp( el_desc->type, mhdf_PRISM_TYPE_NAME ) ) 00550 { 00551 regions += ent_d->count; 00552 } 00553 00554 if( 0 == strcmp( el_desc->type, mdhf_KNIFE_TYPE_NAME ) ) 00555 { 00556 regions += ent_d->count; 00557 } 00558 00559 if( 0 == strcmp( el_desc->type, mdhf_HEX_TYPE_NAME ) ) 00560 { 00561 regions += ent_d->count; 00562 } 00563 00564 if( 0 == strcmp( el_desc->type, mhdf_POLYHEDRON_TYPE_NAME ) ) 00565 { 00566 regions += ent_d->count; 00567 } 00568 00569 if( 0 == strcmp( el_desc->type, mhdf_SEPTAHEDRON_TYPE_NAME ) ) 00570 { 00571 regions += ent_d->count; 00572 } 00573 } 00574 00575 if( num_parts ) *num_parts = data->numEntSets[0]; 00576 00577 // is this required? 00578 if( edges > 0 ) 00579 { 00580 if( num_dimension ) *num_dimension = 1; // I don't think it will ever return 1 00581 if( num_global_elements ) *num_global_elements = edges; 00582 } 00583 00584 if( faces > 0 ) 00585 { 00586 if( num_dimension ) *num_dimension = 2; 00587 if( num_global_elements ) *num_global_elements = faces; 00588 } 00589 00590 if( regions > 0 ) 00591 { 00592 if( num_dimension ) *num_dimension = 3; 00593 if( num_global_elements ) *num_global_elements = regions; 00594 } 00595 00596 mhdf_closeFile( file, &status ); 00597 00598 free( data ); 00599 00600 #else 00601 std::cout << filename 00602 << ": Please reconfigure with HDF5. Cannot retrieve header information for file " 00603 "formats other than a h5m file.\n"; 00604 if( num_global_vertices ) *num_global_vertices = 0; 00605 if( num_global_elements ) *num_global_elements = 0; 00606 if( num_dimension ) *num_dimension = 0; 00607 if( num_parts ) *num_parts = 0; 00608 #endif 00609 00610 return moab::MB_SUCCESS; 00611 } 00612 00613 ErrCode iMOAB_LoadMesh( iMOAB_AppID pid, 00614 const iMOAB_String filename, 00615 const iMOAB_String read_options, 00616 int* num_ghost_layers ) 00617 { 00618 IMOAB_CHECKPOINTER( filename, 2 ); 00619 IMOAB_ASSERT( strlen( filename ), "Invalid filename length." ); 00620 00621 // make sure we use the file set and pcomm associated with the *pid 00622 std::ostringstream newopts; 00623 if( read_options ) newopts << read_options; 00624 00625 #ifdef MOAB_HAVE_MPI 00626 00627 if( context.MPI_initialized ) 00628 { 00629 if( context.worldprocs > 1 ) 00630 { 00631 std::string opts( ( read_options ? read_options : "" ) ); 00632 std::string pcid( "PARALLEL_COMM=" ); 00633 std::size_t found = opts.find( pcid ); 00634 00635 if( found != std::string::npos ) 00636 { 00637 std::cerr << " cannot specify PARALLEL_COMM option, it is implicit \n"; 00638 return moab::MB_FAILURE; 00639 } 00640 00641 // in serial, apply PARALLEL_COMM option only for h5m files; it does not work for .g 00642 // files (used in test_remapping) 00643 std::string filen( filename ); 00644 std::string::size_type idx = filen.rfind( '.' ); 00645 00646 if( idx != std::string::npos ) 00647 { 00648 std::string extension = filen.substr( idx + 1 ); 00649 if( ( extension == std::string( "h5m" ) ) || ( extension == std::string( "nc" ) ) ) 00650 newopts << ";;PARALLEL_COMM=" << *pid; 00651 } 00652 00653 if( *num_ghost_layers >= 1 ) 00654 { 00655 // if we want ghosts, we will want additional entities, the last .1 00656 // because the addl ents can be edges, faces that are part of the neumann sets 00657 std::string pcid2( "PARALLEL_GHOSTS=" ); 00658 std::size_t found2 = opts.find( pcid2 ); 00659 00660 if( found2 != std::string::npos ) 00661 { 00662 std::cout << " PARALLEL_GHOSTS option is already specified, ignore passed " 00663 "number of layers \n"; 00664 } 00665 else 00666 { 00667 // dimension of primary entities is 3 here, but it could be 2 for climate 00668 // meshes; we would need to pass PARALLEL_GHOSTS explicitly for 2d meshes, for 00669 // example: ";PARALLEL_GHOSTS=2.0.1" 00670 newopts << ";PARALLEL_GHOSTS=3.0." << *num_ghost_layers << ".3"; 00671 } 00672 } 00673 } 00674 } 00675 #else 00676 IMOAB_ASSERT( *num_ghost_layers == 0, "Cannot provide ghost layers in serial." ); 00677 #endif 00678 00679 // Now let us actually load the MOAB file with the appropriate read options 00680 ErrorCode rval = context.MBI->load_file( filename, &context.appDatas[*pid].file_set, newopts.str().c_str() );MB_CHK_ERR( rval ); 00681 00682 #ifdef VERBOSE 00683 // some debugging stuff 00684 std::ostringstream outfile; 00685 #ifdef MOAB_HAVE_MPI 00686 int rank = context.pcomms[*pid]->rank(); 00687 int nprocs = context.pcomms[*pid]->size(); 00688 outfile << "TaskMesh_n" << nprocs << "." << rank << ".h5m"; 00689 #else 00690 outfile << "TaskMesh_n1.0.h5m"; 00691 #endif 00692 // the mesh contains ghosts too, but they are not part of mat/neumann set 00693 // write in serial the file, to see what tags are missing 00694 rval = context.MBI->write_file( outfile.str().c_str() );MB_CHK_ERR( rval ); // everything on current task, written in serial 00695 #endif 00696 00697 // Update mesh information 00698 return iMOAB_UpdateMeshInfo( pid ); 00699 } 00700 00701 ErrCode iMOAB_WriteMesh( iMOAB_AppID pid, const iMOAB_String filename, const iMOAB_String write_options ) 00702 { 00703 IMOAB_CHECKPOINTER( filename, 2 ); 00704 IMOAB_ASSERT( strlen( filename ), "Invalid filename length." ); 00705 00706 appData& data = context.appDatas[*pid]; 00707 EntityHandle fileSet = data.file_set; 00708 00709 std::ostringstream newopts; 00710 #ifdef MOAB_HAVE_MPI 00711 std::string write_opts( ( write_options ? write_options : "" ) ); 00712 std::string pcid( "PARALLEL_COMM=" ); 00713 std::size_t found = write_opts.find( pcid ); 00714 00715 if( found != std::string::npos ) 00716 { 00717 std::cerr << " cannot specify PARALLEL_COMM option, it is implicit \n"; 00718 return moab::MB_FAILURE; 00719 } 00720 00721 // if write in parallel, add pc option, to be sure about which ParallelComm instance is used 00722 std::string pw( "PARALLEL=WRITE_PART" ); 00723 found = write_opts.find( pw ); 00724 00725 if( found != std::string::npos ) 00726 { 00727 newopts << "PARALLEL_COMM=" << *pid << ";"; 00728 } 00729 00730 #endif 00731 00732 if( write_options ) newopts << write_options; 00733 00734 std::vector< Tag > copyTagList = data.tagList; 00735 // append Global ID and Parallel Partition 00736 std::string gid_name_tag( "GLOBAL_ID" ); 00737 00738 // export global id tag, we need it always 00739 if( data.tagMap.find( gid_name_tag ) == data.tagMap.end() ) 00740 { 00741 Tag gid = context.MBI->globalId_tag(); 00742 copyTagList.push_back( gid ); 00743 } 00744 // also Parallel_Partition PARALLEL_PARTITION 00745 std::string pp_name_tag( "PARALLEL_PARTITION" ); 00746 00747 // write parallel part tag too, if it exists 00748 if( data.tagMap.find( pp_name_tag ) == data.tagMap.end() ) 00749 { 00750 Tag ptag; 00751 context.MBI->tag_get_handle( pp_name_tag.c_str(), ptag ); 00752 if( ptag ) copyTagList.push_back( ptag ); 00753 } 00754 00755 // Now let us actually write the file to disk with appropriate options 00756 ErrorCode rval = context.MBI->write_file( filename, 0, newopts.str().c_str(), &fileSet, 1, ©TagList[0], 00757 (int)copyTagList.size() );MB_CHK_ERR( rval ); 00758 00759 return moab::MB_SUCCESS; 00760 } 00761 00762 ErrCode iMOAB_WriteLocalMesh( iMOAB_AppID pid, iMOAB_String prefix ) 00763 { 00764 IMOAB_CHECKPOINTER( prefix, 2 ); 00765 IMOAB_ASSERT( strlen( prefix ), "Invalid prefix string length." ); 00766 00767 std::ostringstream file_name; 00768 int rank = 0, size = 1; 00769 #ifdef MOAB_HAVE_MPI 00770 rank = context.pcomms[*pid]->rank(); 00771 size = context.pcomms[*pid]->size(); 00772 #endif 00773 file_name << prefix << "_" << size << "_" << rank << ".h5m"; 00774 // Now let us actually write the file to disk with appropriate options 00775 ErrorCode rval = context.MBI->write_file( file_name.str().c_str(), 0, 0, &context.appDatas[*pid].file_set, 1 );MB_CHK_ERR( rval ); 00776 00777 return moab::MB_SUCCESS; 00778 } 00779 00780 ErrCode iMOAB_UpdateMeshInfo( iMOAB_AppID pid ) 00781 { 00782 // this will include ghost elements info 00783 appData& data = context.appDatas[*pid]; 00784 EntityHandle fileSet = data.file_set; 00785 00786 // first clear all data ranges; this can be called after ghosting 00787 data.all_verts.clear(); 00788 data.primary_elems.clear(); 00789 data.local_verts.clear(); 00790 data.ghost_vertices.clear(); 00791 data.owned_elems.clear(); 00792 data.ghost_elems.clear(); 00793 data.mat_sets.clear(); 00794 data.neu_sets.clear(); 00795 data.diri_sets.clear(); 00796 00797 // Let us get all the vertex entities 00798 ErrorCode rval = context.MBI->get_entities_by_type( fileSet, MBVERTEX, data.all_verts, true );MB_CHK_ERR( rval ); // recursive 00799 00800 // Let us check first entities of dimension = 3 00801 data.dimension = 3; 00802 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, data.primary_elems, true );MB_CHK_ERR( rval ); // recursive 00803 00804 if( data.primary_elems.empty() ) 00805 { 00806 // Now 3-D elements. Let us check entities of dimension = 2 00807 data.dimension = 2; 00808 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, data.primary_elems, true );MB_CHK_ERR( rval ); // recursive 00809 00810 if( data.primary_elems.empty() ) 00811 { 00812 // Now 3-D/2-D elements. Let us check entities of dimension = 1 00813 data.dimension = 1; 00814 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, data.primary_elems, true );MB_CHK_ERR( rval ); // recursive 00815 00816 if( data.primary_elems.empty() ) 00817 { 00818 // no elements of dimension 1 or 2 or 3; it could happen for point clouds 00819 data.dimension = 0; 00820 if( data.all_verts.size() == 0 ) data.dimension = -1; // nothing on this 00821 } 00822 } 00823 } 00824 00825 // check if the current mesh is just a point cloud 00826 data.point_cloud = ( ( data.primary_elems.size() == 0 && data.all_verts.size() > 0 ) || data.dimension == 0 ); 00827 00828 #ifdef MOAB_HAVE_MPI 00829 00830 if( context.MPI_initialized ) 00831 { 00832 ParallelComm* pco = context.pcomms[*pid]; 00833 00834 // filter ghost vertices, from local 00835 rval = pco->filter_pstatus( data.all_verts, PSTATUS_GHOST, PSTATUS_NOT, -1, &data.local_verts );MB_CHK_ERR( rval ); 00836 00837 // Store handles for all ghosted entities 00838 data.ghost_vertices = subtract( data.all_verts, data.local_verts ); 00839 00840 // filter ghost elements, from local 00841 rval = pco->filter_pstatus( data.primary_elems, PSTATUS_GHOST, PSTATUS_NOT, -1, &data.owned_elems );MB_CHK_ERR( rval ); 00842 00843 data.ghost_elems = subtract( data.primary_elems, data.owned_elems ); 00844 } 00845 else 00846 { 00847 data.local_verts = data.all_verts; 00848 data.owned_elems = data.primary_elems; 00849 } 00850 00851 #else 00852 00853 data.local_verts = data.all_verts; 00854 data.owned_elems = data.primary_elems; 00855 00856 #endif 00857 00858 // Get the references for some standard internal tags such as material blocks, BCs, etc 00859 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.material_tag ), 0, 1, 00860 data.mat_sets, Interface::UNION );MB_CHK_ERR( rval ); 00861 00862 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.neumann_tag ), 0, 1, 00863 data.neu_sets, Interface::UNION );MB_CHK_ERR( rval ); 00864 00865 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.dirichlet_tag ), 0, 1, 00866 data.diri_sets, Interface::UNION );MB_CHK_ERR( rval ); 00867 00868 return moab::MB_SUCCESS; 00869 } 00870 00871 ErrCode iMOAB_GetMeshInfo( iMOAB_AppID pid, 00872 int* num_visible_vertices, 00873 int* num_visible_elements, 00874 int* num_visible_blocks, 00875 int* num_visible_surfaceBC, 00876 int* num_visible_vertexBC ) 00877 { 00878 ErrorCode rval; 00879 appData& data = context.appDatas[*pid]; 00880 EntityHandle fileSet = data.file_set; 00881 00882 // this will include ghost elements 00883 // first clear all data ranges; this can be called after ghosting 00884 if( num_visible_elements ) 00885 { 00886 num_visible_elements[2] = static_cast< int >( data.primary_elems.size() ); 00887 // separate ghost and local/owned primary elements 00888 num_visible_elements[0] = static_cast< int >( data.owned_elems.size() ); 00889 num_visible_elements[1] = static_cast< int >( data.ghost_elems.size() ); 00890 } 00891 if( num_visible_vertices ) 00892 { 00893 num_visible_vertices[2] = static_cast< int >( data.all_verts.size() ); 00894 num_visible_vertices[1] = static_cast< int >( data.ghost_vertices.size() ); 00895 // local are those that are not ghosts 00896 num_visible_vertices[0] = num_visible_vertices[2] - num_visible_vertices[1]; 00897 } 00898 00899 if( num_visible_blocks ) 00900 { 00901 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.material_tag ), 0, 1, 00902 data.mat_sets, Interface::UNION );MB_CHK_ERR( rval ); 00903 00904 num_visible_blocks[2] = data.mat_sets.size(); 00905 num_visible_blocks[0] = num_visible_blocks[2]; 00906 num_visible_blocks[1] = 0; 00907 } 00908 00909 if( num_visible_surfaceBC ) 00910 { 00911 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.neumann_tag ), 0, 1, 00912 data.neu_sets, Interface::UNION );MB_CHK_ERR( rval ); 00913 00914 num_visible_surfaceBC[2] = 0; 00915 // count how many faces are in each neu set, and how many regions are 00916 // adjacent to them; 00917 int numNeuSets = (int)data.neu_sets.size(); 00918 00919 for( int i = 0; i < numNeuSets; i++ ) 00920 { 00921 Range subents; 00922 EntityHandle nset = data.neu_sets[i]; 00923 rval = context.MBI->get_entities_by_dimension( nset, data.dimension - 1, subents );MB_CHK_ERR( rval ); 00924 00925 for( Range::iterator it = subents.begin(); it != subents.end(); ++it ) 00926 { 00927 EntityHandle subent = *it; 00928 Range adjPrimaryEnts; 00929 rval = context.MBI->get_adjacencies( &subent, 1, data.dimension, false, adjPrimaryEnts );MB_CHK_ERR( rval ); 00930 00931 num_visible_surfaceBC[2] += (int)adjPrimaryEnts.size(); 00932 } 00933 } 00934 00935 num_visible_surfaceBC[0] = num_visible_surfaceBC[2]; 00936 num_visible_surfaceBC[1] = 0; 00937 } 00938 00939 if( num_visible_vertexBC ) 00940 { 00941 rval = context.MBI->get_entities_by_type_and_tag( fileSet, MBENTITYSET, &( context.dirichlet_tag ), 0, 1, 00942 data.diri_sets, Interface::UNION );MB_CHK_ERR( rval ); 00943 00944 num_visible_vertexBC[2] = 0; 00945 int numDiriSets = (int)data.diri_sets.size(); 00946 00947 for( int i = 0; i < numDiriSets; i++ ) 00948 { 00949 Range verts; 00950 EntityHandle diset = data.diri_sets[i]; 00951 rval = context.MBI->get_entities_by_dimension( diset, 0, verts );MB_CHK_ERR( rval ); 00952 00953 num_visible_vertexBC[2] += (int)verts.size(); 00954 } 00955 00956 num_visible_vertexBC[0] = num_visible_vertexBC[2]; 00957 num_visible_vertexBC[1] = 0; 00958 } 00959 00960 return moab::MB_SUCCESS; 00961 } 00962 00963 ErrCode iMOAB_GetVertexID( iMOAB_AppID pid, int* vertices_length, iMOAB_GlobalID* global_vertex_ID ) 00964 { 00965 IMOAB_CHECKPOINTER( vertices_length, 2 ); 00966 IMOAB_CHECKPOINTER( global_vertex_ID, 3 ); 00967 00968 const Range& verts = context.appDatas[*pid].all_verts; 00969 // check for problems with array length 00970 IMOAB_ASSERT( *vertices_length == static_cast< int >( verts.size() ), "Invalid vertices length provided" ); 00971 00972 // global id tag is context.globalID_tag 00973 return context.MBI->tag_get_data( context.globalID_tag, verts, global_vertex_ID ); 00974 } 00975 00976 ErrCode iMOAB_GetVertexOwnership( iMOAB_AppID pid, int* vertices_length, int* visible_global_rank_ID ) 00977 { 00978 assert( vertices_length && *vertices_length ); 00979 assert( visible_global_rank_ID ); 00980 00981 Range& verts = context.appDatas[*pid].all_verts; 00982 int i = 0; 00983 #ifdef MOAB_HAVE_MPI 00984 ParallelComm* pco = context.pcomms[*pid]; 00985 00986 for( Range::iterator vit = verts.begin(); vit != verts.end(); vit++, i++ ) 00987 { 00988 ErrorCode rval = pco->get_owner( *vit, visible_global_rank_ID[i] );MB_CHK_ERR( rval ); 00989 } 00990 00991 if( i != *vertices_length ) 00992 { 00993 return moab::MB_FAILURE; 00994 } // warning array allocation problem 00995 00996 #else 00997 00998 /* everything owned by proc 0 */ 00999 if( (int)verts.size() != *vertices_length ) 01000 { 01001 return moab::MB_FAILURE; 01002 } // warning array allocation problem 01003 01004 for( Range::iterator vit = verts.begin(); vit != verts.end(); vit++, i++ ) 01005 { 01006 visible_global_rank_ID[i] = 0; 01007 } // all vertices are owned by processor 0, as this is serial run 01008 01009 #endif 01010 01011 return moab::MB_SUCCESS; 01012 } 01013 01014 ErrCode iMOAB_GetVisibleVerticesCoordinates( iMOAB_AppID pid, int* coords_length, double* coordinates ) 01015 { 01016 Range& verts = context.appDatas[*pid].all_verts; 01017 01018 // interleaved coordinates, so that means deep copy anyway 01019 if( *coords_length != 3 * (int)verts.size() ) 01020 { 01021 return moab::MB_FAILURE; 01022 } 01023 01024 ErrorCode rval = context.MBI->get_coords( verts, coordinates );MB_CHK_ERR( rval ); 01025 01026 return moab::MB_SUCCESS; 01027 } 01028 01029 ErrCode iMOAB_GetBlockID( iMOAB_AppID pid, int* block_length, iMOAB_GlobalID* global_block_IDs ) 01030 { 01031 // local id blocks? they are counted from 0 to number of visible blocks ... 01032 // will actually return material set tag value for global 01033 Range& matSets = context.appDatas[*pid].mat_sets; 01034 01035 if( *block_length != (int)matSets.size() ) 01036 { 01037 return moab::MB_FAILURE; 01038 } 01039 01040 // return material set tag gtags[0 is material set tag 01041 ErrorCode rval = context.MBI->tag_get_data( context.material_tag, matSets, global_block_IDs );MB_CHK_ERR( rval ); 01042 01043 // populate map with index 01044 std::map< int, int >& matIdx = context.appDatas[*pid].matIndex; 01045 for( unsigned i = 0; i < matSets.size(); i++ ) 01046 { 01047 matIdx[global_block_IDs[i]] = i; 01048 } 01049 01050 return moab::MB_SUCCESS; 01051 } 01052 01053 ErrCode iMOAB_GetBlockInfo( iMOAB_AppID pid, 01054 iMOAB_GlobalID* global_block_ID, 01055 int* vertices_per_element, 01056 int* num_elements_in_block ) 01057 { 01058 assert( global_block_ID ); 01059 01060 std::map< int, int >& matMap = context.appDatas[*pid].matIndex; 01061 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01062 01063 if( it == matMap.end() ) 01064 { 01065 return moab::MB_FAILURE; 01066 } // error in finding block with id 01067 01068 int blockIndex = matMap[*global_block_ID]; 01069 EntityHandle matMeshSet = context.appDatas[*pid].mat_sets[blockIndex]; 01070 Range blo_elems; 01071 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, blo_elems ); 01072 01073 if( MB_SUCCESS != rval || blo_elems.empty() ) 01074 { 01075 return moab::MB_FAILURE; 01076 } 01077 01078 EntityType type = context.MBI->type_from_handle( blo_elems[0] ); 01079 01080 if( !blo_elems.all_of_type( type ) ) 01081 { 01082 return moab::MB_FAILURE; 01083 } // not all of same type 01084 01085 const EntityHandle* conn = NULL; 01086 int num_verts = 0; 01087 rval = context.MBI->get_connectivity( blo_elems[0], conn, num_verts );MB_CHK_ERR( rval ); 01088 01089 *vertices_per_element = num_verts; 01090 *num_elements_in_block = (int)blo_elems.size(); 01091 01092 return moab::MB_SUCCESS; 01093 } 01094 01095 ErrCode iMOAB_GetVisibleElementsInfo( iMOAB_AppID pid, 01096 int* num_visible_elements, 01097 iMOAB_GlobalID* element_global_IDs, 01098 int* ranks, 01099 iMOAB_GlobalID* block_IDs ) 01100 { 01101 appData& data = context.appDatas[*pid]; 01102 #ifdef MOAB_HAVE_MPI 01103 ParallelComm* pco = context.pcomms[*pid]; 01104 #endif 01105 01106 ErrorCode rval = context.MBI->tag_get_data( context.globalID_tag, data.primary_elems, element_global_IDs );MB_CHK_ERR( rval ); 01107 01108 int i = 0; 01109 01110 for( Range::iterator eit = data.primary_elems.begin(); eit != data.primary_elems.end(); ++eit, ++i ) 01111 { 01112 #ifdef MOAB_HAVE_MPI 01113 rval = pco->get_owner( *eit, ranks[i] );MB_CHK_ERR( rval ); 01114 01115 #else 01116 /* everything owned by task 0 */ 01117 ranks[i] = 0; 01118 #endif 01119 } 01120 01121 for( Range::iterator mit = data.mat_sets.begin(); mit != data.mat_sets.end(); ++mit ) 01122 { 01123 EntityHandle matMeshSet = *mit; 01124 Range elems; 01125 rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01126 01127 int valMatTag; 01128 rval = context.MBI->tag_get_data( context.material_tag, &matMeshSet, 1, &valMatTag );MB_CHK_ERR( rval ); 01129 01130 for( Range::iterator eit = elems.begin(); eit != elems.end(); ++eit ) 01131 { 01132 EntityHandle eh = *eit; 01133 int index = data.primary_elems.index( eh ); 01134 01135 if( -1 == index ) 01136 { 01137 return moab::MB_FAILURE; 01138 } 01139 01140 if( -1 >= *num_visible_elements ) 01141 { 01142 return moab::MB_FAILURE; 01143 } 01144 01145 block_IDs[index] = valMatTag; 01146 } 01147 } 01148 01149 return moab::MB_SUCCESS; 01150 } 01151 01152 ErrCode iMOAB_GetBlockElementConnectivities( iMOAB_AppID pid, 01153 iMOAB_GlobalID* global_block_ID, 01154 int* connectivity_length, 01155 int* element_connectivity ) 01156 { 01157 assert( global_block_ID ); // ensure global block ID argument is not null 01158 assert( connectivity_length ); // ensure connectivity length argument is not null 01159 01160 appData& data = context.appDatas[*pid]; 01161 std::map< int, int >& matMap = data.matIndex; 01162 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01163 01164 if( it == matMap.end() ) 01165 { 01166 return moab::MB_FAILURE; 01167 } // error in finding block with id 01168 01169 int blockIndex = matMap[*global_block_ID]; 01170 EntityHandle matMeshSet = data.mat_sets[blockIndex]; 01171 std::vector< EntityHandle > elems; 01172 01173 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01174 01175 if( elems.empty() ) 01176 { 01177 return moab::MB_FAILURE; 01178 } 01179 01180 std::vector< EntityHandle > vconnect; 01181 rval = context.MBI->get_connectivity( &elems[0], elems.size(), vconnect );MB_CHK_ERR( rval ); 01182 01183 if( *connectivity_length != (int)vconnect.size() ) 01184 { 01185 return moab::MB_FAILURE; 01186 } // mismatched sizes 01187 01188 for( int i = 0; i < *connectivity_length; i++ ) 01189 { 01190 int inx = data.all_verts.index( vconnect[i] ); 01191 01192 if( -1 == inx ) 01193 { 01194 return moab::MB_FAILURE; 01195 } // error, vertex not in local range 01196 01197 element_connectivity[i] = inx; 01198 } 01199 01200 return moab::MB_SUCCESS; 01201 } 01202 01203 ErrCode iMOAB_GetElementConnectivity( iMOAB_AppID pid, 01204 iMOAB_LocalID* elem_index, 01205 int* connectivity_length, 01206 int* element_connectivity ) 01207 { 01208 assert( elem_index ); // ensure element index argument is not null 01209 assert( connectivity_length ); // ensure connectivity length argument is not null 01210 01211 appData& data = context.appDatas[*pid]; 01212 assert( ( *elem_index >= 0 ) && ( *elem_index < (int)data.primary_elems.size() ) ); 01213 01214 int num_nodes; 01215 const EntityHandle* conn; 01216 01217 EntityHandle eh = data.primary_elems[*elem_index]; 01218 01219 ErrorCode rval = context.MBI->get_connectivity( eh, conn, num_nodes );MB_CHK_ERR( rval ); 01220 01221 if( *connectivity_length < num_nodes ) 01222 { 01223 return moab::MB_FAILURE; 01224 } // wrong number of vertices 01225 01226 for( int i = 0; i < num_nodes; i++ ) 01227 { 01228 int index = data.all_verts.index( conn[i] ); 01229 01230 if( -1 == index ) 01231 { 01232 return moab::MB_FAILURE; 01233 } 01234 01235 element_connectivity[i] = index; 01236 } 01237 01238 *connectivity_length = num_nodes; 01239 01240 return moab::MB_SUCCESS; 01241 } 01242 01243 ErrCode iMOAB_GetElementOwnership( iMOAB_AppID pid, 01244 iMOAB_GlobalID* global_block_ID, 01245 int* num_elements_in_block, 01246 int* element_ownership ) 01247 { 01248 assert( global_block_ID ); // ensure global block ID argument is not null 01249 assert( num_elements_in_block ); // ensure number of elements in block argument is not null 01250 01251 std::map< int, int >& matMap = context.appDatas[*pid].matIndex; 01252 01253 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01254 01255 if( it == matMap.end() ) 01256 { 01257 return moab::MB_FAILURE; 01258 } // error in finding block with id 01259 01260 int blockIndex = matMap[*global_block_ID]; 01261 EntityHandle matMeshSet = context.appDatas[*pid].mat_sets[blockIndex]; 01262 Range elems; 01263 01264 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01265 01266 if( elems.empty() ) 01267 { 01268 return moab::MB_FAILURE; 01269 } 01270 01271 if( *num_elements_in_block != (int)elems.size() ) 01272 { 01273 return moab::MB_FAILURE; 01274 } // bad memory allocation 01275 01276 int i = 0; 01277 #ifdef MOAB_HAVE_MPI 01278 ParallelComm* pco = context.pcomms[*pid]; 01279 #endif 01280 01281 for( Range::iterator vit = elems.begin(); vit != elems.end(); vit++, i++ ) 01282 { 01283 #ifdef MOAB_HAVE_MPI 01284 rval = pco->get_owner( *vit, element_ownership[i] );MB_CHK_ERR( rval ); 01285 #else 01286 element_ownership[i] = 0; /* owned by 0 */ 01287 #endif 01288 } 01289 01290 return moab::MB_SUCCESS; 01291 } 01292 01293 ErrCode iMOAB_GetElementID( iMOAB_AppID pid, 01294 iMOAB_GlobalID* global_block_ID, 01295 int* num_elements_in_block, 01296 iMOAB_GlobalID* global_element_ID, 01297 iMOAB_LocalID* local_element_ID ) 01298 { 01299 assert( global_block_ID ); // ensure global block ID argument is not null 01300 assert( num_elements_in_block ); // ensure number of elements in block argument is not null 01301 01302 appData& data = context.appDatas[*pid]; 01303 std::map< int, int >& matMap = data.matIndex; 01304 01305 std::map< int, int >::iterator it = matMap.find( *global_block_ID ); 01306 01307 if( it == matMap.end() ) 01308 { 01309 return moab::MB_FAILURE; 01310 } // error in finding block with id 01311 01312 int blockIndex = matMap[*global_block_ID]; 01313 EntityHandle matMeshSet = data.mat_sets[blockIndex]; 01314 Range elems; 01315 ErrorCode rval = context.MBI->get_entities_by_handle( matMeshSet, elems );MB_CHK_ERR( rval ); 01316 01317 if( elems.empty() ) 01318 { 01319 return moab::MB_FAILURE; 01320 } 01321 01322 if( *num_elements_in_block != (int)elems.size() ) 01323 { 01324 return moab::MB_FAILURE; 01325 } // bad memory allocation 01326 01327 rval = context.MBI->tag_get_data( context.globalID_tag, elems, global_element_ID );MB_CHK_ERR( rval ); 01328 01329 // check that elems are among primary_elems in data 01330 for( int i = 0; i < *num_elements_in_block; i++ ) 01331 { 01332 local_element_ID[i] = data.primary_elems.index( elems[i] ); 01333 01334 if( -1 == local_element_ID[i] ) 01335 { 01336 return moab::MB_FAILURE; 01337 } // error, not in local primary elements 01338 } 01339 01340 return moab::MB_SUCCESS; 01341 } 01342 01343 ErrCode iMOAB_GetPointerToSurfaceBC( iMOAB_AppID pid, 01344 int* surface_BC_length, 01345 iMOAB_LocalID* local_element_ID, 01346 int* reference_surface_ID, 01347 int* boundary_condition_value ) 01348 { 01349 // we have to fill bc data for neumann sets;/ 01350 ErrorCode rval; 01351 01352 // it was counted above, in GetMeshInfo 01353 appData& data = context.appDatas[*pid]; 01354 int numNeuSets = (int)data.neu_sets.size(); 01355 01356 int index = 0; // index [0, surface_BC_length) for the arrays returned 01357 01358 for( int i = 0; i < numNeuSets; i++ ) 01359 { 01360 Range subents; 01361 EntityHandle nset = data.neu_sets[i]; 01362 rval = context.MBI->get_entities_by_dimension( nset, data.dimension - 1, subents );MB_CHK_ERR( rval ); 01363 01364 int neuVal; 01365 rval = context.MBI->tag_get_data( context.neumann_tag, &nset, 1, &neuVal );MB_CHK_ERR( rval ); 01366 01367 for( Range::iterator it = subents.begin(); it != subents.end(); ++it ) 01368 { 01369 EntityHandle subent = *it; 01370 Range adjPrimaryEnts; 01371 rval = context.MBI->get_adjacencies( &subent, 1, data.dimension, false, adjPrimaryEnts );MB_CHK_ERR( rval ); 01372 01373 // get global id of the primary ents, and side number of the quad/subentity 01374 // this is moab ordering 01375 for( Range::iterator pit = adjPrimaryEnts.begin(); pit != adjPrimaryEnts.end(); pit++ ) 01376 { 01377 EntityHandle primaryEnt = *pit; 01378 // get global id 01379 /*int globalID; 01380 rval = context.MBI->tag_get_data(gtags[3], &primaryEnt, 1, &globalID); 01381 if (MB_SUCCESS!=rval) 01382 return moab::MB_FAILURE; 01383 global_element_ID[index] = globalID;*/ 01384 01385 // get local element id 01386 local_element_ID[index] = data.primary_elems.index( primaryEnt ); 01387 01388 if( -1 == local_element_ID[index] ) 01389 { 01390 return moab::MB_FAILURE; 01391 } // did not find the element locally 01392 01393 int side_number, sense, offset; 01394 rval = context.MBI->side_number( primaryEnt, subent, side_number, sense, offset );MB_CHK_ERR( rval ); 01395 01396 reference_surface_ID[index] = side_number + 1; // moab is from 0 to 5, it needs 1 to 6 01397 boundary_condition_value[index] = neuVal; 01398 index++; 01399 } 01400 } 01401 } 01402 01403 if( index != *surface_BC_length ) 01404 { 01405 return moab::MB_FAILURE; 01406 } // error in array allocations 01407 01408 return moab::MB_SUCCESS; 01409 } 01410 01411 ErrCode iMOAB_GetPointerToVertexBC( iMOAB_AppID pid, 01412 int* vertex_BC_length, 01413 iMOAB_LocalID* local_vertex_ID, 01414 int* boundary_condition_value ) 01415 { 01416 ErrorCode rval; 01417 01418 // it was counted above, in GetMeshInfo 01419 appData& data = context.appDatas[*pid]; 01420 int numDiriSets = (int)data.diri_sets.size(); 01421 int index = 0; // index [0, *vertex_BC_length) for the arrays returned 01422 01423 for( int i = 0; i < numDiriSets; i++ ) 01424 { 01425 Range verts; 01426 EntityHandle diset = data.diri_sets[i]; 01427 rval = context.MBI->get_entities_by_dimension( diset, 0, verts );MB_CHK_ERR( rval ); 01428 01429 int diriVal; 01430 rval = context.MBI->tag_get_data( context.dirichlet_tag, &diset, 1, &diriVal );MB_CHK_ERR( rval ); 01431 01432 for( Range::iterator vit = verts.begin(); vit != verts.end(); ++vit ) 01433 { 01434 EntityHandle vt = *vit; 01435 /*int vgid; 01436 rval = context.MBI->tag_get_data(gtags[3], &vt, 1, &vgid); 01437 if (MB_SUCCESS!=rval) 01438 return moab::MB_FAILURE; 01439 global_vertext_ID[index] = vgid;*/ 01440 local_vertex_ID[index] = data.all_verts.index( vt ); 01441 01442 if( -1 == local_vertex_ID[index] ) 01443 { 01444 return moab::MB_FAILURE; 01445 } // vertex was not found 01446 01447 boundary_condition_value[index] = diriVal; 01448 index++; 01449 } 01450 } 01451 01452 if( *vertex_BC_length != index ) 01453 { 01454 return moab::MB_FAILURE; 01455 } // array allocation issue 01456 01457 return moab::MB_SUCCESS; 01458 } 01459 01460 ErrCode iMOAB_DuplicateAppMesh( iMOAB_AppID pid, iMOAB_AppID poid ) 01461 { 01462 // the file set , parallel comm are all in vectors indexed by *pid 01463 appData& data = context.appDatas[*pid]; 01464 appData& dataout = context.appDatas[*poid]; 01465 int rankHere = 0; 01466 #ifdef MOAB_HAVE_MPI 01467 ParallelComm* pco = context.pcomms[*pid]; 01468 ParallelComm* pcout = context.pcomms[*poid]; 01469 rankHere = pco->rank(); 01470 #endif 01471 01472 #ifdef VERBOSE 01473 if( !rankHere ) 01474 std::cout << " Mesh for application with ID: " << *pid << " global id: " << data.global_id 01475 << " name: " << data.name << "\n is copied in application with ID " << *poid << " name " 01476 << dataout.name << "\n"; 01477 #endif 01478 EntityHandle fileSet = data.file_set; 01479 EntityHandle outFileSet = dataout.file_set; 01480 // get all entities part of the file set 01481 Range verts; 01482 ErrorCode rval = context.MBI->get_entities_by_dimension( fileSet, 0, verts );MB_CHK_ERR( rval ); 01483 Range primaryCells; 01484 rval = context.MBI->get_entities_by_dimension( fileSet, data.dimension, primaryCells );MB_CHK_ERR( rval ); 01485 Range connVerts; 01486 rval = context.MBI->get_connectivity( primaryCells, connVerts );MB_CHK_ERR( rval ); 01487 verts.merge( connVerts ); 01488 // first, deep copy vertices 01489 std::vector< double > coords; 01490 coords.resize( verts.size() * 3 ); 01491 01492 rval = context.MBI->get_coords( verts, &coords[0] );MB_CHK_ERR( rval ); 01493 std::vector< int > globalIds; 01494 globalIds.resize( verts.size() ); 01495 Tag gid = context.MBI->globalId_tag(); 01496 rval = context.MBI->tag_get_data( gid, verts, &globalIds[0] );MB_CHK_ERR( rval ); 01497 01498 Range newVerts; 01499 int nverts = (int)verts.size(); 01500 rval = context.MBI->create_vertices( &coords[0], nverts, newVerts );MB_CHK_ERR( rval ); 01501 // set global ID the same 01502 rval = context.MBI->tag_set_data( gid, newVerts, &globalIds[0] );MB_CHK_ERR( rval ); 01503 rval = context.MBI->add_entities( outFileSet, newVerts );MB_CHK_ERR( rval ); 01504 // create new cells, cell by cell, and add them to the file set, and set the global id too 01505 // use the vertex global id for identification 01506 std::map< EntityHandle, int > oldMap; 01507 std::map< int, EntityHandle > newMap; 01508 int i = 0; 01509 for( auto it = verts.begin(); it != verts.end(); ++it, ++i ) 01510 { 01511 EntityHandle oldVert = *it; 01512 EntityHandle newVert = newVerts[i]; 01513 int globalId = globalIds[i]; 01514 oldMap[oldVert] = globalId; 01515 newMap[globalId] = newVert; 01516 } 01517 Range newCells; 01518 for( auto it = primaryCells.begin(); it != primaryCells.end(); ++it ) 01519 { 01520 EntityHandle oldCell = *it; 01521 int nnodes; 01522 const EntityHandle* conn = NULL; 01523 rval = context.MBI->get_connectivity( oldCell, conn, nnodes );MB_CHK_ERR( rval ); 01524 std::vector< EntityHandle > newConn; 01525 newConn.resize( nnodes ); 01526 EntityType type = context.MBI->type_from_handle( oldCell ); 01527 for( int i = 0; i < nnodes; i++ ) 01528 { 01529 newConn[i] = newMap[oldMap[conn[i]]]; 01530 } 01531 EntityHandle newCell; 01532 rval = context.MBI->create_element( type, &newConn[0], nnodes, newCell );MB_CHK_ERR( rval ); 01533 rval = context.MBI->add_entities( outFileSet, &newCell, 1 );MB_CHK_ERR( rval ); 01534 int globalIdCell = 0; 01535 rval = context.MBI->tag_get_data( gid, &oldCell, 1, &globalIdCell );MB_CHK_ERR( rval ); 01536 rval = context.MBI->tag_set_data( gid, &newCell, 1, &globalIdCell );MB_CHK_ERR( rval ); 01537 newCells.insert( newCell ); 01538 } 01539 // adjacencies need to be added explicitly 01540 Core* mb = (Core*)context.MBI; 01541 AEntityFactory* adj_fact = mb->a_entity_factory(); 01542 if( !adj_fact->vert_elem_adjacencies() ) 01543 adj_fact->create_vert_elem_adjacencies(); 01544 else 01545 { 01546 for( Range::iterator it = newCells.begin(); it != newCells.end(); ++it ) 01547 { 01548 EntityHandle eh = *it; 01549 const EntityHandle* conn = NULL; 01550 int num_nodes = 0; 01551 rval = mb->get_connectivity( eh, conn, num_nodes );MB_CHK_ERR( rval ); 01552 adj_fact->notify_create_entity( eh, conn, num_nodes ); 01553 } 01554 } 01555 01556 #ifdef MOAB_HAVE_MPI 01557 rval = iMOAB_ResolveSharedEntities( poid, &nverts, &globalIds[0] );MB_CHK_ERR( rval ); 01558 #endif 01559 01560 rval = iMOAB_UpdateMeshInfo( poid );MB_CHK_ERR( rval ); 01561 return moab::MB_SUCCESS; 01562 } 01563 01564 ErrCode iMOAB_DefineTagStorage( iMOAB_AppID pid, 01565 const iMOAB_String tag_storage_name, 01566 int* tag_type, 01567 int* components_per_entity, 01568 int* tag_index ) 01569 { 01570 // see if the tag is already existing, and if yes, check the type, length 01571 if( *tag_type < DENSE_INTEGER || *tag_type > SPARSE_ENTITYHANDLE ) 01572 { 01573 return moab::MB_FAILURE; 01574 } // we have 6 types of tags supported so far in enum MOAB_TAG_TYPE 01575 01576 DataType tagDataType; 01577 TagType tagType; 01578 void* defaultVal = NULL; 01579 int* defInt = new int[*components_per_entity]; 01580 double* defDouble = new double[*components_per_entity]; 01581 EntityHandle* defHandle = new EntityHandle[*components_per_entity]; 01582 01583 for( int i = 0; i < *components_per_entity; i++ ) 01584 { 01585 defInt[i] = 0; 01586 defDouble[i] = -1e+10; 01587 defHandle[i] = (EntityHandle)0; 01588 } 01589 01590 switch( *tag_type ) 01591 { 01592 case DENSE_INTEGER: 01593 tagDataType = MB_TYPE_INTEGER; 01594 tagType = MB_TAG_DENSE; 01595 defaultVal = defInt; 01596 break; 01597 01598 case DENSE_DOUBLE: 01599 tagDataType = MB_TYPE_DOUBLE; 01600 tagType = MB_TAG_DENSE; 01601 defaultVal = defDouble; 01602 break; 01603 01604 case DENSE_ENTITYHANDLE: 01605 tagDataType = MB_TYPE_HANDLE; 01606 tagType = MB_TAG_DENSE; 01607 defaultVal = defHandle; 01608 break; 01609 01610 case SPARSE_INTEGER: 01611 tagDataType = MB_TYPE_INTEGER; 01612 tagType = MB_TAG_SPARSE; 01613 defaultVal = defInt; 01614 break; 01615 01616 case SPARSE_DOUBLE: 01617 tagDataType = MB_TYPE_DOUBLE; 01618 tagType = MB_TAG_SPARSE; 01619 defaultVal = defDouble; 01620 break; 01621 01622 case SPARSE_ENTITYHANDLE: 01623 tagDataType = MB_TYPE_HANDLE; 01624 tagType = MB_TAG_SPARSE; 01625 defaultVal = defHandle; 01626 break; 01627 01628 default: { 01629 delete[] defInt; 01630 delete[] defDouble; 01631 delete[] defHandle; 01632 return moab::MB_FAILURE; 01633 } // error 01634 } 01635 01636 Tag tagHandle; 01637 // split storage names if separated list 01638 01639 std::string tag_name( tag_storage_name ); 01640 01641 // first separate the names of the tags 01642 // we assume that there are separators ":" between the tag names 01643 std::vector< std::string > tagNames; 01644 std::string separator( ":" ); 01645 split_tag_names( tag_name, separator, tagNames ); 01646 01647 ErrorCode rval = moab::MB_SUCCESS; // assume success already :) 01648 appData& data = context.appDatas[*pid]; 01649 int already_defined_tags = 0; 01650 01651 for( size_t i = 0; i < tagNames.size(); i++ ) 01652 { 01653 rval = context.MBI->tag_get_handle( tagNames[i].c_str(), *components_per_entity, tagDataType, tagHandle, 01654 tagType | MB_TAG_EXCL | MB_TAG_CREAT, defaultVal ); 01655 01656 if( MB_ALREADY_ALLOCATED == rval ) 01657 { 01658 std::map< std::string, Tag >& mTags = data.tagMap; 01659 std::map< std::string, Tag >::iterator mit = mTags.find( tagNames[i].c_str() ); 01660 01661 if( mit == mTags.end() ) 01662 { 01663 // add it to the map 01664 mTags[tagNames[i]] = tagHandle; 01665 // push it to the list of tags, too 01666 *tag_index = (int)data.tagList.size(); 01667 data.tagList.push_back( tagHandle ); 01668 } 01669 rval = MB_SUCCESS; 01670 already_defined_tags++; 01671 } 01672 else if( MB_SUCCESS == rval ) 01673 { 01674 data.tagMap[tagNames[i]] = tagHandle; 01675 *tag_index = (int)data.tagList.size(); 01676 data.tagList.push_back( tagHandle ); 01677 } 01678 else 01679 { 01680 rval = moab::MB_FAILURE; // some tags were not created 01681 } 01682 } 01683 // we don't need default values anymore, avoid leaks 01684 int rankHere = 0; 01685 #ifdef MOAB_HAVE_MPI 01686 ParallelComm* pco = context.pcomms[*pid]; 01687 rankHere = pco->rank(); 01688 #endif 01689 if( !rankHere && already_defined_tags ) 01690 std::cout << " application with ID: " << *pid << " global id: " << data.global_id << " name: " << data.name 01691 << " has " << already_defined_tags << " already defined tags out of " << tagNames.size() 01692 << " tags \n"; 01693 delete[] defInt; 01694 delete[] defDouble; 01695 delete[] defHandle; 01696 return rval; 01697 } 01698 01699 ErrCode iMOAB_SetIntTagStorage( iMOAB_AppID pid, 01700 const iMOAB_String tag_storage_name, 01701 int* num_tag_storage_length, 01702 int* ent_type, 01703 int* tag_storage_data ) 01704 { 01705 std::string tag_name( tag_storage_name ); 01706 01707 // Get the application data 01708 appData& data = context.appDatas[*pid]; 01709 01710 if( data.tagMap.find( tag_name ) == data.tagMap.end() ) 01711 { 01712 return moab::MB_FAILURE; 01713 } // tag not defined 01714 01715 Tag tag = data.tagMap[tag_name]; 01716 01717 int tagLength = 0; 01718 ErrorCode rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01719 01720 DataType dtype; 01721 rval = context.MBI->tag_get_data_type( tag, dtype ); 01722 01723 if( MB_SUCCESS != rval || dtype != MB_TYPE_INTEGER ) 01724 { 01725 return moab::MB_FAILURE; 01726 } 01727 01728 // set it on a subset of entities, based on type and length 01729 Range* ents_to_set; 01730 if( *ent_type == TAG_VERTEX ) // vertices 01731 { 01732 ents_to_set = &data.all_verts; 01733 } 01734 else // if (*ent_type == TAG_ELEMENT) // *ent_type can be TAG_VERTEX or TAG_ELEMENT 01735 { 01736 ents_to_set = &data.primary_elems; 01737 } 01738 01739 int nents_to_be_set = *num_tag_storage_length / tagLength; 01740 01741 if( nents_to_be_set > (int)ents_to_set->size() || nents_to_be_set < 1 ) 01742 { 01743 return moab::MB_FAILURE; 01744 } // to many entities to be set or too few 01745 01746 // restrict the range; everything is contiguous; or not? 01747 01748 // Range contig_range ( * ( ents_to_set->begin() ), * ( ents_to_set->begin() + nents_to_be_set - 01749 // 1 ) ); 01750 rval = context.MBI->tag_set_data( tag, *ents_to_set, tag_storage_data );MB_CHK_ERR( rval ); 01751 01752 return moab::MB_SUCCESS; // no error 01753 } 01754 01755 ErrCode iMOAB_GetIntTagStorage( iMOAB_AppID pid, 01756 const iMOAB_String tag_storage_name, 01757 int* num_tag_storage_length, 01758 int* ent_type, 01759 int* tag_storage_data ) 01760 { 01761 ErrorCode rval; 01762 std::string tag_name( tag_storage_name ); 01763 01764 appData& data = context.appDatas[*pid]; 01765 01766 if( data.tagMap.find( tag_name ) == data.tagMap.end() ) 01767 { 01768 return moab::MB_FAILURE; 01769 } // tag not defined 01770 01771 Tag tag = data.tagMap[tag_name]; 01772 01773 int tagLength = 0; 01774 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01775 01776 DataType dtype; 01777 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 01778 01779 if( dtype != MB_TYPE_INTEGER ) 01780 { 01781 return moab::MB_FAILURE; 01782 } 01783 01784 // set it on a subset of entities, based on type and length 01785 Range* ents_to_get; 01786 if( *ent_type == TAG_VERTEX ) // vertices 01787 { 01788 ents_to_get = &data.all_verts; 01789 } 01790 else // if (*ent_type == TAG_ELEMENT) 01791 { 01792 ents_to_get = &data.primary_elems; 01793 } 01794 01795 int nents_to_get = *num_tag_storage_length / tagLength; 01796 01797 if( nents_to_get > (int)ents_to_get->size() || nents_to_get < 1 ) 01798 { 01799 return moab::MB_FAILURE; 01800 } // to many entities to get, or too little 01801 01802 // restrict the range; everything is contiguous; or not? 01803 // Range contig_range ( * ( ents_to_get->begin() ), * ( ents_to_get->begin() + nents_to_get - 1 01804 // ) ); 01805 01806 rval = context.MBI->tag_get_data( tag, *ents_to_get, tag_storage_data );MB_CHK_ERR( rval ); 01807 01808 return moab::MB_SUCCESS; // no error 01809 } 01810 01811 ErrCode iMOAB_SetDoubleTagStorage( iMOAB_AppID pid, 01812 const iMOAB_String tag_storage_names, 01813 int* num_tag_storage_length, 01814 int* ent_type, 01815 double* tag_storage_data ) 01816 { 01817 ErrorCode rval; 01818 std::string tag_names( tag_storage_names ); 01819 // exactly the same code as for int tag :) maybe should check the type of tag too 01820 std::vector< std::string > tagNames; 01821 std::vector< Tag > tagHandles; 01822 std::string separator( ":" ); 01823 split_tag_names( tag_names, separator, tagNames ); 01824 01825 appData& data = context.appDatas[*pid]; 01826 Range* ents_to_set = NULL; 01827 01828 if( *ent_type == TAG_VERTEX ) // vertices 01829 { 01830 ents_to_set = &data.all_verts; 01831 } 01832 else // TAG_ELEMENT 01833 { 01834 ents_to_set = &data.primary_elems; 01835 } 01836 01837 int nents_to_be_set = (int)( *ents_to_set ).size(); 01838 int position = 0; 01839 01840 for( size_t i = 0; i < tagNames.size(); i++ ) 01841 { 01842 if( data.tagMap.find( tagNames[i] ) == data.tagMap.end() ) 01843 { 01844 return moab::MB_FAILURE; 01845 } // some tag not defined yet in the app 01846 01847 Tag tag = data.tagMap[tagNames[i]]; 01848 01849 int tagLength = 0; 01850 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01851 01852 DataType dtype; 01853 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 01854 01855 if( dtype != MB_TYPE_DOUBLE ) 01856 { 01857 return moab::MB_FAILURE; 01858 } 01859 01860 // set it on the subset of entities, based on type and length 01861 if( position + tagLength * nents_to_be_set > *num_tag_storage_length ) 01862 return moab::MB_FAILURE; // too many entity values to be set 01863 01864 rval = context.MBI->tag_set_data( tag, *ents_to_set, &tag_storage_data[position] );MB_CHK_ERR( rval ); 01865 // increment position to next tag 01866 position = position + tagLength * nents_to_be_set; 01867 } 01868 return moab::MB_SUCCESS; // no error 01869 } 01870 01871 ErrCode iMOAB_SetDoubleTagStorageWithGid( iMOAB_AppID pid, 01872 const iMOAB_String tag_storage_names, 01873 int* num_tag_storage_length, 01874 int* ent_type, 01875 double* tag_storage_data, 01876 int* globalIds ) 01877 { 01878 ErrorCode rval; 01879 std::string tag_names( tag_storage_names ); 01880 // exactly the same code as for int tag :) maybe should check the type of tag too 01881 std::vector< std::string > tagNames; 01882 std::vector< Tag > tagHandles; 01883 std::string separator( ":" ); 01884 split_tag_names( tag_names, separator, tagNames ); 01885 01886 appData& data = context.appDatas[*pid]; 01887 Range* ents_to_set = NULL; 01888 01889 if( *ent_type == TAG_VERTEX ) // vertices 01890 { 01891 ents_to_set = &data.all_verts; 01892 } 01893 else // TAG_ELEMENT 01894 { 01895 ents_to_set = &data.primary_elems; 01896 } 01897 01898 int nents_to_be_set = (int)( *ents_to_set ).size(); 01899 01900 Tag gidTag = context.MBI->globalId_tag(); 01901 std::vector< int > gids; 01902 gids.resize( nents_to_be_set ); 01903 rval = context.MBI->tag_get_data( gidTag, *ents_to_set, &gids[0] );MB_CHK_ERR( rval ); 01904 01905 // so we will need to set the tags according to the global id passed; 01906 // so the order in tag_storage_data is the same as the order in globalIds, but the order 01907 // in local range is gids 01908 std::map< int, EntityHandle > eh_by_gid; 01909 int i = 0; 01910 for( Range::iterator it = ents_to_set->begin(); it != ents_to_set->end(); ++it, ++i ) 01911 { 01912 eh_by_gid[gids[i]] = *it; 01913 } 01914 01915 std::vector< int > tagLengths( tagNames.size() ); 01916 std::vector< Tag > tagList; 01917 size_t total_tag_len = 0; 01918 for( size_t i = 0; i < tagNames.size(); i++ ) 01919 { 01920 if( data.tagMap.find( tagNames[i] ) == data.tagMap.end() ) 01921 { 01922 MB_SET_ERR( moab::MB_FAILURE, "tag missing" ); 01923 } // some tag not defined yet in the app 01924 01925 Tag tag = data.tagMap[tagNames[i]]; 01926 tagList.push_back( tag ); 01927 01928 int tagLength = 0; 01929 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 01930 01931 total_tag_len += tagLength; 01932 tagLengths[i] = tagLength; 01933 DataType dtype; 01934 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 01935 01936 if( dtype != MB_TYPE_DOUBLE ) 01937 { 01938 MB_SET_ERR( moab::MB_FAILURE, "tag not double type" ); 01939 } 01940 } 01941 bool serial = true; 01942 #ifdef MOAB_HAVE_MPI 01943 ParallelComm* pco = context.pcomms[*pid]; 01944 unsigned num_procs = pco->size(); 01945 if( num_procs > 1 ) serial = false; 01946 #endif 01947 01948 if( serial ) 01949 { 01950 assert( total_tag_len * nents_to_be_set - *num_tag_storage_length == 0 ); 01951 // tags are unrolled, we loop over global ids first, then careful about tags 01952 for( int i = 0; i < nents_to_be_set; i++ ) 01953 { 01954 int gid = globalIds[i]; 01955 EntityHandle eh = eh_by_gid[gid]; 01956 // now loop over tags 01957 int indexInTagValues = 0; // 01958 for( size_t j = 0; j < tagList.size(); j++ ) 01959 { 01960 indexInTagValues += i * tagLengths[j]; 01961 rval = context.MBI->tag_set_data( tagList[j], &eh, 1, &tag_storage_data[indexInTagValues] );MB_CHK_ERR( rval ); 01962 // advance the pointer/index 01963 indexInTagValues += ( nents_to_be_set - i ) * tagLengths[j]; // at the end of tag data 01964 } 01965 } 01966 } 01967 #ifdef MOAB_HAVE_MPI 01968 else // it can be not serial only if pco->size() > 1, parallel 01969 { 01970 // in this case, we have to use 2 crystal routers, to send data to the processor that needs it 01971 // we will create first a tuple to rendevous points, then from there send to the processor that requested it 01972 // it is a 2-hop global gather scatter 01973 int nbLocalVals = *num_tag_storage_length / ( (int)tagNames.size() ); 01974 assert( nbLocalVals * tagNames.size() - *num_tag_storage_length == 0 ); 01975 TupleList TLsend; 01976 TLsend.initialize( 2, 0, 0, total_tag_len, nbLocalVals ); // to proc, marker(gid), total_tag_len doubles 01977 TLsend.enableWriteAccess(); 01978 // the processor id that processes global_id is global_id / num_ents_per_proc 01979 01980 int indexInRealLocal = 0; 01981 for( int i = 0; i < nbLocalVals; i++ ) 01982 { 01983 // to proc, marker, element local index, index in el 01984 int marker = globalIds[i]; 01985 int to_proc = marker % num_procs; 01986 int n = TLsend.get_n(); 01987 TLsend.vi_wr[2 * n] = to_proc; // send to processor 01988 TLsend.vi_wr[2 * n + 1] = marker; 01989 int indexInTagValues = 0; 01990 // tag data collect by number of tags 01991 for( size_t j = 0; j < tagList.size(); j++ ) 01992 { 01993 indexInTagValues += i * tagLengths[j]; 01994 for( int k = 0; k < tagLengths[j]; k++ ) 01995 { 01996 TLsend.vr_wr[indexInRealLocal++] = tag_storage_data[indexInTagValues + k]; 01997 } 01998 indexInTagValues += ( nbLocalVals - i ) * tagLengths[j]; 01999 } 02000 TLsend.inc_n(); 02001 } 02002 02003 assert( nbLocalVals * total_tag_len - indexInRealLocal == 0 ); 02004 // send now requests, basically inform the rendez-vous point who needs a particular global id 02005 // send the data to the other processors: 02006 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLsend, 0 ); 02007 TupleList TLreq; 02008 TLreq.initialize( 2, 0, 0, 0, nents_to_be_set ); 02009 TLreq.enableWriteAccess(); 02010 for( int i = 0; i < nents_to_be_set; i++ ) 02011 { 02012 // to proc, marker 02013 int marker = gids[i]; 02014 int to_proc = marker % num_procs; 02015 int n = TLreq.get_n(); 02016 TLreq.vi_wr[2 * n] = to_proc; // send to processor 02017 TLreq.vi_wr[2 * n + 1] = marker; 02018 // tag data collect by number of tags 02019 TLreq.inc_n(); 02020 } 02021 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLreq, 0 ); 02022 02023 // we know now that process TLreq.vi_wr[2 * n] needs tags for gid TLreq.vi_wr[2 * n + 1] 02024 // we should first order by global id, and then build the new TL with send to proc, global id and 02025 // tags for it 02026 // sort by global ids the tuple lists 02027 moab::TupleList::buffer sort_buffer; 02028 sort_buffer.buffer_init( TLreq.get_n() ); 02029 TLreq.sort( 1, &sort_buffer ); 02030 sort_buffer.reset(); 02031 sort_buffer.buffer_init( TLsend.get_n() ); 02032 TLsend.sort( 1, &sort_buffer ); 02033 sort_buffer.reset(); 02034 // now send the tag values to the proc that requested it 02035 // in theory, for a full partition, TLreq and TLsend should have the same size, and 02036 // each dof should have exactly one target proc. Is that true or not in general ? 02037 // how do we plan to use this? Is it better to store the comm graph for future 02038 02039 // start copy from comm graph settle 02040 TupleList TLBack; 02041 TLBack.initialize( 3, 0, 0, total_tag_len, 0 ); // to proc, marker, tag from proc , tag values 02042 TLBack.enableWriteAccess(); 02043 02044 int n1 = TLreq.get_n(); 02045 int n2 = TLsend.get_n(); 02046 02047 int indexInTLreq = 0; 02048 int indexInTLsend = 0; // advance both, according to the marker 02049 if( n1 > 0 && n2 > 0 ) 02050 { 02051 02052 while( indexInTLreq < n1 && indexInTLsend < n2 ) // if any is over, we are done 02053 { 02054 int currentValue1 = TLreq.vi_rd[2 * indexInTLreq + 1]; 02055 int currentValue2 = TLsend.vi_rd[2 * indexInTLsend + 1]; 02056 if( currentValue1 < currentValue2 ) 02057 { 02058 // we have a big problem; basically, we are saying that 02059 // dof currentValue is on one model and not on the other 02060 // std::cout << " currentValue1:" << currentValue1 << " missing in comp2" << "\n"; 02061 indexInTLreq++; 02062 continue; 02063 } 02064 if( currentValue1 > currentValue2 ) 02065 { 02066 // std::cout << " currentValue2:" << currentValue2 << " missing in comp1" << "\n"; 02067 indexInTLsend++; 02068 continue; 02069 } 02070 int size1 = 1; 02071 int size2 = 1; 02072 while( indexInTLreq + size1 < n1 && currentValue1 == TLreq.vi_rd[2 * ( indexInTLreq + size1 ) + 1] ) 02073 size1++; 02074 while( indexInTLsend + size2 < n2 && currentValue2 == TLsend.vi_rd[2 * ( indexInTLsend + size2 ) + 1] ) 02075 size2++; 02076 // must be found in both lists, find the start and end indices 02077 for( int i1 = 0; i1 < size1; i1++ ) 02078 { 02079 for( int i2 = 0; i2 < size2; i2++ ) 02080 { 02081 // send the info back to components 02082 int n = TLBack.get_n(); 02083 TLBack.reserve(); 02084 TLBack.vi_wr[3 * n] = TLreq.vi_rd[2 * ( indexInTLreq + i1 )]; // send back to the proc marker 02085 // came from, info from comp2 02086 TLBack.vi_wr[3 * n + 1] = currentValue1; // initial value (resend, just for verif ?) 02087 TLBack.vi_wr[3 * n + 2] = TLsend.vi_rd[2 * ( indexInTLsend + i2 )]; // from proc on comp2 02088 // also fill tag values 02089 for( size_t k = 0; k < total_tag_len; k++ ) 02090 { 02091 TLBack.vr_rd[total_tag_len * n + k] = 02092 TLsend.vr_rd[total_tag_len * indexInTLsend + k]; // deep copy of tag values 02093 } 02094 } 02095 } 02096 indexInTLreq += size1; 02097 indexInTLsend += size2; 02098 } 02099 } 02100 ( pco->proc_config().crystal_router() )->gs_transfer( 1, TLBack, 0 ); 02101 // end copy from comm graph 02102 // after we are done sending, we need to set those tag values, in a reverse process compared to send 02103 n1 = TLBack.get_n(); 02104 double* ptrVal = &TLBack.vr_rd[0]; // 02105 for( int i = 0; i < n1; i++ ) 02106 { 02107 int gid = TLBack.vi_rd[3 * i + 1]; // marker 02108 EntityHandle eh = eh_by_gid[gid]; 02109 // now loop over tags 02110 02111 for( size_t j = 0; j < tagList.size(); j++ ) 02112 { 02113 rval = context.MBI->tag_set_data( tagList[j], &eh, 1, (void*)ptrVal );MB_CHK_ERR( rval ); 02114 // advance the pointer/index 02115 ptrVal += tagLengths[j]; // at the end of tag data per call 02116 } 02117 } 02118 } 02119 #endif 02120 return MB_SUCCESS; 02121 } 02122 ErrCode iMOAB_GetDoubleTagStorage( iMOAB_AppID pid, 02123 const iMOAB_String tag_storage_names, 02124 int* num_tag_storage_length, 02125 int* ent_type, 02126 double* tag_storage_data ) 02127 { 02128 ErrorCode rval; 02129 // exactly the same code, except tag type check 02130 std::string tag_names( tag_storage_names ); 02131 // exactly the same code as for int tag :) maybe should check the type of tag too 02132 std::vector< std::string > tagNames; 02133 std::vector< Tag > tagHandles; 02134 std::string separator( ":" ); 02135 split_tag_names( tag_names, separator, tagNames ); 02136 02137 appData& data = context.appDatas[*pid]; 02138 02139 // set it on a subset of entities, based on type and length 02140 Range* ents_to_get = NULL; 02141 if( *ent_type == TAG_VERTEX ) // vertices 02142 { 02143 ents_to_get = &data.all_verts; 02144 } 02145 else // TAG_ELEMENT 02146 { 02147 ents_to_get = &data.primary_elems; 02148 } 02149 02150 int nents_to_get = (int)ents_to_get->size(); 02151 int position = 0; 02152 for( size_t i = 0; i < tagNames.size(); i++ ) 02153 { 02154 if( data.tagMap.find( tagNames[i] ) == data.tagMap.end() ) 02155 { 02156 return moab::MB_FAILURE; 02157 } // tag not defined 02158 02159 Tag tag = data.tagMap[tagNames[i]]; 02160 02161 int tagLength = 0; 02162 rval = context.MBI->tag_get_length( tag, tagLength );MB_CHK_ERR( rval ); 02163 02164 DataType dtype; 02165 rval = context.MBI->tag_get_data_type( tag, dtype );MB_CHK_ERR( rval ); 02166 02167 if( dtype != MB_TYPE_DOUBLE ) 02168 { 02169 return moab::MB_FAILURE; 02170 } 02171 02172 if( position + nents_to_get * tagLength > *num_tag_storage_length ) 02173 return moab::MB_FAILURE; // too many entity values to get 02174 02175 rval = context.MBI->tag_get_data( tag, *ents_to_get, &tag_storage_data[position] );MB_CHK_ERR( rval ); 02176 position = position + nents_to_get * tagLength; 02177 } 02178 02179 return moab::MB_SUCCESS; // no error 02180 } 02181 02182 ErrCode iMOAB_SynchronizeTags( iMOAB_AppID pid, int* num_tag, int* tag_indices, int* ent_type ) 02183 { 02184 #ifdef MOAB_HAVE_MPI 02185 appData& data = context.appDatas[*pid]; 02186 Range ent_exchange; 02187 std::vector< Tag > tags; 02188 02189 for( int i = 0; i < *num_tag; i++ ) 02190 { 02191 if( tag_indices[i] < 0 || tag_indices[i] >= (int)data.tagList.size() ) 02192 { 02193 return moab::MB_FAILURE; 02194 } // error in tag index 02195 02196 tags.push_back( data.tagList[tag_indices[i]] ); 02197 } 02198 02199 if( *ent_type == 0 ) 02200 { 02201 ent_exchange = data.all_verts; 02202 } 02203 else if( *ent_type == 1 ) 02204 { 02205 ent_exchange = data.primary_elems; 02206 } 02207 else 02208 { 02209 return moab::MB_FAILURE; 02210 } // unexpected type 02211 02212 ParallelComm* pco = context.pcomms[*pid]; 02213 02214 ErrorCode rval = pco->exchange_tags( tags, tags, ent_exchange );MB_CHK_ERR( rval ); 02215 02216 #else 02217 /* do nothing if serial */ 02218 // just silence the warning 02219 // do not call sync tags in serial! 02220 int k = *pid + *num_tag + *tag_indices + *ent_type; 02221 k++; 02222 #endif 02223 02224 return moab::MB_SUCCESS; 02225 } 02226 02227 ErrCode iMOAB_ReduceTagsMax( iMOAB_AppID pid, int* tag_index, int* ent_type ) 02228 { 02229 #ifdef MOAB_HAVE_MPI 02230 appData& data = context.appDatas[*pid]; 02231 Range ent_exchange; 02232 02233 if( *tag_index < 0 || *tag_index >= (int)data.tagList.size() ) 02234 { 02235 return moab::MB_FAILURE; 02236 } // error in tag index 02237 02238 Tag tagh = data.tagList[*tag_index]; 02239 02240 if( *ent_type == 0 ) 02241 { 02242 ent_exchange = data.all_verts; 02243 } 02244 else if( *ent_type == 1 ) 02245 { 02246 ent_exchange = data.primary_elems; 02247 } 02248 else 02249 { 02250 return moab::MB_FAILURE; 02251 } // unexpected type 02252 02253 ParallelComm* pco = context.pcomms[*pid]; 02254 // we could do different MPI_Op; do not bother now, we will call from fortran 02255 ErrorCode rval = pco->reduce_tags( tagh, MPI_MAX, ent_exchange );MB_CHK_ERR( rval ); 02256 02257 #else 02258 /* do nothing if serial */ 02259 // just silence the warning 02260 // do not call sync tags in serial! 02261 int k = *pid + *tag_index + *ent_type; 02262 k++; // just do junk, to avoid complaints 02263 #endif 02264 return moab::MB_SUCCESS; 02265 } 02266 02267 ErrCode iMOAB_GetNeighborElements( iMOAB_AppID pid, 02268 iMOAB_LocalID* local_index, 02269 int* num_adjacent_elements, 02270 iMOAB_LocalID* adjacent_element_IDs ) 02271 { 02272 ErrorCode rval; 02273 02274 // one neighbor for each subentity of dimension-1 02275 MeshTopoUtil mtu( context.MBI ); 02276 appData& data = context.appDatas[*pid]; 02277 EntityHandle eh = data.primary_elems[*local_index]; 02278 Range adjs; 02279 rval = mtu.get_bridge_adjacencies( eh, data.dimension - 1, data.dimension, adjs );MB_CHK_ERR( rval ); 02280 02281 if( *num_adjacent_elements < (int)adjs.size() ) 02282 { 02283 return moab::MB_FAILURE; 02284 } // not dimensioned correctly 02285 02286 *num_adjacent_elements = (int)adjs.size(); 02287 02288 for( int i = 0; i < *num_adjacent_elements; i++ ) 02289 { 02290 adjacent_element_IDs[i] = data.primary_elems.index( adjs[i] ); 02291 } 02292 02293 return moab::MB_SUCCESS; 02294 } 02295 02296 #if 0 02297 02298 ErrCode iMOAB_GetNeighborVertices ( iMOAB_AppID pid, iMOAB_LocalID* local_vertex_ID, int* num_adjacent_vertices, iMOAB_LocalID* adjacent_vertex_IDs ) 02299 { 02300 return moab::MB_SUCCESS; 02301 } 02302 02303 #endif 02304 02305 ErrCode iMOAB_CreateVertices( iMOAB_AppID pid, int* coords_len, int* dim, double* coordinates ) 02306 { 02307 ErrorCode rval; 02308 appData& data = context.appDatas[*pid]; 02309 02310 if( !data.local_verts.empty() ) // we should have no vertices in the app 02311 { 02312 return moab::MB_FAILURE; 02313 } 02314 02315 int nverts = *coords_len / *dim; 02316 02317 rval = context.MBI->create_vertices( coordinates, nverts, data.local_verts );MB_CHK_ERR( rval ); 02318 02319 rval = context.MBI->add_entities( data.file_set, data.local_verts );MB_CHK_ERR( rval ); 02320 02321 // also add the vertices to the all_verts range 02322 data.all_verts.merge( data.local_verts ); 02323 return moab::MB_SUCCESS; 02324 } 02325 02326 ErrCode iMOAB_CreateElements( iMOAB_AppID pid, 02327 int* num_elem, 02328 int* type, 02329 int* num_nodes_per_element, 02330 int* connectivity, 02331 int* block_ID ) 02332 { 02333 // Create elements 02334 appData& data = context.appDatas[*pid]; 02335 02336 ReadUtilIface* read_iface; 02337 ErrorCode rval = context.MBI->query_interface( read_iface );MB_CHK_ERR( rval ); 02338 02339 EntityType mbtype = ( EntityType )( *type ); 02340 EntityHandle actual_start_handle; 02341 EntityHandle* array = NULL; 02342 rval = read_iface->get_element_connect( *num_elem, *num_nodes_per_element, mbtype, 1, actual_start_handle, array );MB_CHK_ERR( rval ); 02343 02344 // fill up with actual connectivity from input; assume the vertices are in order, and start 02345 // vertex is the first in the current data vertex range 02346 EntityHandle firstVertex = data.local_verts[0]; 02347 02348 for( int j = 0; j < *num_elem * ( *num_nodes_per_element ); j++ ) 02349 { 02350 array[j] = connectivity[j] + firstVertex - 1; 02351 } // assumes connectivity uses 1 based array (from fortran, mostly) 02352 02353 Range new_elems( actual_start_handle, actual_start_handle + *num_elem - 1 ); 02354 02355 rval = context.MBI->add_entities( data.file_set, new_elems );MB_CHK_ERR( rval ); 02356 02357 data.primary_elems.merge( new_elems ); 02358 02359 // add to adjacency 02360 rval = read_iface->update_adjacencies( actual_start_handle, *num_elem, *num_nodes_per_element, array );MB_CHK_ERR( rval ); 02361 // organize all new elements in block, with the given block ID; if the block set is not 02362 // existing, create a new mesh set; 02363 Range sets; 02364 int set_no = *block_ID; 02365 const void* setno_ptr = &set_no; 02366 rval = context.MBI->get_entities_by_type_and_tag( data.file_set, MBENTITYSET, &context.material_tag, &setno_ptr, 1, 02367 sets ); 02368 EntityHandle block_set; 02369 02370 if( MB_FAILURE == rval || sets.empty() ) 02371 { 02372 // create a new set, with this block ID 02373 rval = context.MBI->create_meshset( MESHSET_SET, block_set );MB_CHK_ERR( rval ); 02374 02375 rval = context.MBI->tag_set_data( context.material_tag, &block_set, 1, &set_no );MB_CHK_ERR( rval ); 02376 02377 // add the material set to file set 02378 rval = context.MBI->add_entities( data.file_set, &block_set, 1 );MB_CHK_ERR( rval ); 02379 } 02380 else 02381 { 02382 block_set = sets[0]; 02383 } // first set is the one we want 02384 02385 /// add the new ents to the clock set 02386 rval = context.MBI->add_entities( block_set, new_elems );MB_CHK_ERR( rval ); 02387 02388 return moab::MB_SUCCESS; 02389 } 02390 02391 ErrCode iMOAB_SetGlobalInfo( iMOAB_AppID pid, int* num_global_verts, int* num_global_elems ) 02392 { 02393 appData& data = context.appDatas[*pid]; 02394 data.num_global_vertices = *num_global_verts; 02395 data.num_global_elements = *num_global_elems; 02396 return moab::MB_SUCCESS; 02397 } 02398 02399 ErrCode iMOAB_GetGlobalInfo( iMOAB_AppID pid, int* num_global_verts, int* num_global_elems ) 02400 { 02401 appData& data = context.appDatas[*pid]; 02402 if( NULL != num_global_verts ) 02403 { 02404 *num_global_verts = data.num_global_vertices; 02405 } 02406 if( NULL != num_global_elems ) 02407 { 02408 *num_global_elems = data.num_global_elements; 02409 } 02410 02411 return moab::MB_SUCCESS; 02412 } 02413 02414 #ifdef MOAB_HAVE_MPI 02415 02416 // this makes sense only for parallel runs 02417 ErrCode iMOAB_ResolveSharedEntities( iMOAB_AppID pid, int* num_verts, int* marker ) 02418 { 02419 appData& data = context.appDatas[*pid]; 02420 ParallelComm* pco = context.pcomms[*pid]; 02421 EntityHandle cset = data.file_set; 02422 int dum_id = 0; 02423 ErrorCode rval; 02424 if( data.primary_elems.empty() ) 02425 { 02426 // skip actual resolve, assume vertices are distributed already , 02427 // no need to share them 02428 } 02429 else 02430 { 02431 // create an integer tag for resolving ; maybe it can be a long tag in the future 02432 // (more than 2 B vertices;) 02433 02434 Tag stag; 02435 rval = context.MBI->tag_get_handle( "__sharedmarker", 1, MB_TYPE_INTEGER, stag, MB_TAG_CREAT | MB_TAG_DENSE, 02436 &dum_id );MB_CHK_ERR( rval ); 02437 02438 if( *num_verts > (int)data.local_verts.size() ) 02439 { 02440 return moab::MB_FAILURE; 02441 } // we are not setting the size 02442 02443 rval = context.MBI->tag_set_data( stag, data.local_verts, (void*)marker );MB_CHK_ERR( rval ); // assumes integer tag 02444 02445 rval = pco->resolve_shared_ents( cset, -1, -1, &stag );MB_CHK_ERR( rval ); 02446 02447 rval = context.MBI->tag_delete( stag );MB_CHK_ERR( rval ); 02448 } 02449 // provide partition tag equal to rank 02450 Tag part_tag; 02451 dum_id = -1; 02452 rval = context.MBI->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_tag, 02453 MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id ); 02454 02455 if( part_tag == NULL || ( ( rval != MB_SUCCESS ) && ( rval != MB_ALREADY_ALLOCATED ) ) ) 02456 { 02457 std::cout << " can't get par part tag.\n"; 02458 return moab::MB_FAILURE; 02459 } 02460 02461 int rank = pco->rank(); 02462 rval = context.MBI->tag_set_data( part_tag, &cset, 1, &rank );MB_CHK_ERR( rval ); 02463 02464 return moab::MB_SUCCESS; 02465 } 02466 02467 // this assumes that this was not called before 02468 ErrCode iMOAB_DetermineGhostEntities( iMOAB_AppID pid, int* ghost_dim, int* num_ghost_layers, int* bridge_dim ) 02469 { 02470 ErrorCode rval; 02471 02472 // verify we have valid ghost layers input specified. If invalid, exit quick. 02473 if( *num_ghost_layers <= 0 ) 02474 { 02475 return moab::MB_SUCCESS; 02476 } // nothing to do 02477 02478 appData& data = context.appDatas[*pid]; 02479 ParallelComm* pco = context.pcomms[*pid]; 02480 02481 int addl_ents = 02482 0; // maybe we should be passing this too; most of the time we do not need additional ents collective call 02483 rval = 02484 pco->exchange_ghost_cells( *ghost_dim, *bridge_dim, *num_ghost_layers, addl_ents, true, true, &data.file_set );MB_CHK_ERR( rval ); 02485 02486 // now re-establish all mesh info; will reconstruct mesh info, based solely on what is in the file set 02487 return iMOAB_UpdateMeshInfo( pid ); 02488 } 02489 02490 ErrCode iMOAB_SendMesh( iMOAB_AppID pid, MPI_Comm* join, MPI_Group* receivingGroup, int* rcompid, int* method ) 02491 { 02492 assert( join != nullptr ); 02493 assert( receivingGroup != nullptr ); 02494 assert( rcompid != nullptr ); 02495 02496 ErrorCode rval; 02497 int ierr; 02498 appData& data = context.appDatas[*pid]; 02499 ParallelComm* pco = context.pcomms[*pid]; 02500 02501 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02502 MPI_Group recvGroup = 02503 ( data.is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( receivingGroup ) ) : *receivingGroup ); 02504 MPI_Comm sender = pco->comm(); // the sender comm is obtained from parallel comm in moab; no need to pass it along 02505 // first see what are the processors in each group; get the sender group too, from the sender communicator 02506 MPI_Group senderGroup; 02507 ierr = MPI_Comm_group( sender, &senderGroup ); 02508 if( ierr != 0 ) return moab::MB_FAILURE; 02509 02510 // instantiate the par comm graph 02511 // ParCommGraph::ParCommGraph(MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, 02512 // int coid2) 02513 ParCommGraph* cgraph = 02514 new ParCommGraph( global, senderGroup, recvGroup, context.appDatas[*pid].global_id, *rcompid ); 02515 // we should search if we have another pcomm with the same comp ids in the list already 02516 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 02517 context.appDatas[*pid].pgraph[*rcompid] = cgraph; 02518 02519 int sender_rank = -1; 02520 MPI_Comm_rank( sender, &sender_rank ); 02521 02522 // decide how to distribute elements to each processor 02523 // now, get the entities on local processor, and pack them into a buffer for various processors 02524 // we will do trivial partition: first get the total number of elements from "sender" 02525 std::vector< int > number_elems_per_part; 02526 // how to distribute local elements to receiving tasks? 02527 // trivial partition: compute first the total number of elements need to be sent 02528 Range owned = context.appDatas[*pid].owned_elems; 02529 std::vector< char > zoltanBuffer; 02530 if( owned.size() == 0 ) 02531 { 02532 // must be vertices that we want to send then 02533 owned = context.appDatas[*pid].local_verts; 02534 // we should have some vertices here 02535 } 02536 02537 if( *method == 0 ) // trivial partitioning, old method 02538 { 02539 int local_owned_elem = (int)owned.size(); 02540 int size = pco->size(); 02541 int rank = pco->rank(); 02542 number_elems_per_part.resize( size ); // 02543 number_elems_per_part[rank] = local_owned_elem; 02544 #if( MPI_VERSION >= 2 ) 02545 // Use "in place" option 02546 ierr = MPI_Allgather( MPI_IN_PLACE, 0, MPI_DATATYPE_NULL, &number_elems_per_part[0], 1, MPI_INT, sender ); 02547 #else 02548 { 02549 std::vector< int > all_tmp( size ); 02550 ierr = MPI_Allgather( &number_elems_per_part[rank], 1, MPI_INT, &all_tmp[0], 1, MPI_INT, sender ); 02551 number_elems_per_part = all_tmp; 02552 } 02553 #endif 02554 02555 if( ierr != 0 ) 02556 { 02557 return moab::MB_FAILURE; 02558 } 02559 02560 // every sender computes the trivial partition, it is cheap, and we need to send it anyway 02561 // to each sender 02562 rval = cgraph->compute_trivial_partition( number_elems_per_part );MB_CHK_ERR( rval ); 02563 02564 // nothing in z buff, just to compile 02565 rval = cgraph->send_graph( global, zoltanBuffer );MB_CHK_ERR( rval ); 02566 } 02567 #ifdef MOAB_HAVE_ZOLTAN 02568 else // *method != 0, so it is either graph or geometric, parallel 02569 { 02570 // it is assumed the method 4 was called in advance 02571 if( *method == 5 ) 02572 { 02573 zoltanBuffer = context.uniqueZoltanBuffer; 02574 } 02575 rval = cgraph->compute_partition( pco, owned, *method, zoltanBuffer );MB_CHK_ERR( rval ); 02576 // basically, send the graph to the receiver side, with unblocking send 02577 rval = cgraph->send_graph_partition( pco, global, zoltanBuffer );MB_CHK_ERR( rval ); 02578 } 02579 #endif // #ifdef MOAB_HAVE_ZOLTAN 02580 // pco is needed to pack, not for communication 02581 rval = cgraph->send_mesh_parts( global, pco, owned );MB_CHK_ERR( rval ); 02582 02583 // mark for deletion 02584 MPI_Group_free( &senderGroup ); 02585 return moab::MB_SUCCESS; 02586 } 02587 02588 ErrCode iMOAB_ReceiveMesh( iMOAB_AppID pid, MPI_Comm* join, MPI_Group* sendingGroup, int* scompid ) 02589 { 02590 assert( join != nullptr ); 02591 assert( sendingGroup != nullptr ); 02592 assert( scompid != nullptr ); 02593 02594 ErrorCode rval; 02595 appData& data = context.appDatas[*pid]; 02596 ParallelComm* pco = context.pcomms[*pid]; 02597 MPI_Comm receive = pco->comm(); 02598 EntityHandle local_set = data.file_set; 02599 02600 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02601 MPI_Group sendGroup = 02602 ( data.is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( sendingGroup ) ) : *sendingGroup ); 02603 02604 // first see what are the processors in each group; get the sender group too, from the sender 02605 // communicator 02606 MPI_Group receiverGroup; 02607 int ierr = MPI_Comm_group( receive, &receiverGroup );CHK_MPI_ERR( ierr ); 02608 02609 // instantiate the par comm graph 02610 ParCommGraph* cgraph = 02611 new ParCommGraph( global, sendGroup, receiverGroup, *scompid, context.appDatas[*pid].global_id ); 02612 // TODO we should search if we have another pcomm with the same comp ids in the list already 02613 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 02614 context.appDatas[*pid].pgraph[*scompid] = cgraph; 02615 02616 int receiver_rank = -1; 02617 MPI_Comm_rank( receive, &receiver_rank ); 02618 02619 // first, receive from sender_rank 0, the communication graph (matrix), so each receiver 02620 // knows what data to expect 02621 std::vector< int > pack_array; 02622 std::vector< char > zoltanBuff; 02623 rval = cgraph->receive_comm_graph( global, pco, pack_array, zoltanBuff );MB_CHK_ERR( rval ); 02624 02625 // senders across for the current receiver 02626 int current_receiver = cgraph->receiver( receiver_rank ); 02627 #ifdef MOAB_HAVE_ZOLTAN 02628 if( zoltanBuff.size() > 0 ) // it could happen only on root of receiver; store it in a global context member 02629 // the corresponding send it with method 4, for sure 02630 context.uniqueZoltanBuffer = zoltanBuff; 02631 #endif 02632 std::vector< int > senders_local; 02633 size_t n = 0; 02634 02635 while( n < pack_array.size() - 1 ) // now, the last int was already processed, if it has zoltan or not 02636 { 02637 if( current_receiver == pack_array[n] ) 02638 { 02639 for( int j = 0; j < pack_array[n + 1]; j++ ) 02640 { 02641 senders_local.push_back( pack_array[n + 2 + j] ); 02642 } 02643 02644 break; 02645 } 02646 02647 n = n + 2 + pack_array[n + 1]; 02648 } 02649 02650 #ifdef VERBOSE 02651 std::cout << " receiver " << current_receiver << " at rank " << receiver_rank << " will receive from " 02652 << senders_local.size() << " tasks: "; 02653 02654 for( int k = 0; k < (int)senders_local.size(); k++ ) 02655 { 02656 std::cout << " " << senders_local[k]; 02657 } 02658 02659 std::cout << "\n"; 02660 #endif 02661 02662 if( senders_local.empty() ) 02663 { 02664 std::cout << " we do not have any senders for receiver rank " << receiver_rank << "\n"; 02665 } 02666 rval = cgraph->receive_mesh( global, pco, local_set, senders_local );MB_CHK_ERR( rval ); 02667 02668 // after we are done, we could merge vertices that come from different senders, but 02669 // have the same global id 02670 Tag idtag; 02671 rval = context.MBI->tag_get_handle( "GLOBAL_ID", idtag );MB_CHK_ERR( rval ); 02672 02673 // data.point_cloud = false; 02674 Range local_ents; 02675 rval = context.MBI->get_entities_by_handle( local_set, local_ents );MB_CHK_ERR( rval ); 02676 02677 // do not do merge if point cloud 02678 if( !local_ents.empty() ) 02679 { 02680 if( !local_ents.all_of_type( MBVERTEX ) ) 02681 { 02682 if( (int)senders_local.size() >= 2 ) // need to remove duplicate vertices 02683 // that might come from different senders 02684 { 02685 02686 Range local_verts = local_ents.subset_by_type( MBVERTEX ); 02687 Range local_elems = subtract( local_ents, local_verts ); 02688 02689 // remove from local set the vertices 02690 rval = context.MBI->remove_entities( local_set, local_verts );MB_CHK_ERR( rval ); 02691 02692 #ifdef VERBOSE 02693 std::cout << "current_receiver " << current_receiver << " local verts: " << local_verts.size() << "\n"; 02694 #endif 02695 MergeMesh mm( context.MBI ); 02696 02697 rval = mm.merge_using_integer_tag( local_verts, idtag );MB_CHK_ERR( rval ); 02698 02699 Range new_verts; // local elems are local entities without vertices 02700 rval = context.MBI->get_connectivity( local_elems, new_verts );MB_CHK_ERR( rval ); 02701 02702 #ifdef VERBOSE 02703 std::cout << "after merging: new verts: " << new_verts.size() << "\n"; 02704 #endif 02705 rval = context.MBI->add_entities( local_set, new_verts );MB_CHK_ERR( rval ); 02706 } 02707 } 02708 else 02709 data.point_cloud = true; 02710 } 02711 // it could be point cloud empty ? 02712 if( !data.point_cloud ) 02713 { 02714 // still need to resolve shared entities (in this case, vertices ) 02715 rval = pco->resolve_shared_ents( local_set, -1, -1, &idtag );MB_CHK_ERR( rval ); 02716 } 02717 else 02718 { 02719 // if partition tag exists, set it to current rank; just to make it visible in VisIt 02720 Tag densePartTag; 02721 rval = context.MBI->tag_get_handle( "partition", densePartTag ); 02722 if( NULL != densePartTag && MB_SUCCESS == rval ) 02723 { 02724 Range local_verts; 02725 rval = context.MBI->get_entities_by_dimension( local_set, 0, local_verts );MB_CHK_ERR( rval ); 02726 std::vector< int > vals; 02727 int rank = pco->rank(); 02728 vals.resize( local_verts.size(), rank ); 02729 rval = context.MBI->tag_set_data( densePartTag, local_verts, &vals[0] );MB_CHK_ERR( rval ); 02730 } 02731 } 02732 // set the parallel partition tag 02733 Tag part_tag; 02734 int dum_id = -1; 02735 rval = context.MBI->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_tag, 02736 MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id ); 02737 02738 if( part_tag == NULL || ( ( rval != MB_SUCCESS ) && ( rval != MB_ALREADY_ALLOCATED ) ) ) 02739 { 02740 std::cout << " can't get par part tag.\n"; 02741 return moab::MB_FAILURE; 02742 } 02743 02744 int rank = pco->rank(); 02745 rval = context.MBI->tag_set_data( part_tag, &local_set, 1, &rank );MB_CHK_ERR( rval ); 02746 02747 // populate the mesh with current data info 02748 rval = iMOAB_UpdateMeshInfo( pid );MB_CHK_ERR( rval ); 02749 02750 // mark for deletion 02751 MPI_Group_free( &receiverGroup ); 02752 02753 return moab::MB_SUCCESS; 02754 } 02755 02756 // need to send the zoltan buffer from coupler root towards the component root 02757 ErrCode iMOAB_RetrieveZBuffer( MPI_Group* cmpGrp, MPI_Group* cplGrp, MPI_Comm* joint, int* is_fortran ) 02758 { 02759 // need to use MPI_Group_translate_ranks to find the rank of sender root and the rank of receiver root, 02760 // in the joint communicator 02761 assert( cmpGrp != nullptr ); 02762 assert( cplGrp != nullptr ); 02763 assert( joint != nullptr ); 02764 02765 MPI_Group cmpGroup = ( *is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( cmpGrp ) ) : *cmpGrp ); 02766 MPI_Group cplGroup = ( *is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( cplGrp ) ) : *cplGrp ); 02767 MPI_Comm jointComm = ( *is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( joint ) ) : *joint ); 02768 02769 int rootRank = 0; 02770 int rankCompRoot = -1; // this will receive the buffer 02771 int rankCouplerRoot = -1; // this will send the coupler 02772 int rank, ierr; 02773 MPI_Group global_grp; 02774 MPI_Comm_group( jointComm, &global_grp ); 02775 MPI_Group_translate_ranks( cmpGroup, 1, &rootRank, global_grp, &rankCompRoot ); 02776 MPI_Group_translate_ranks( cplGroup, 1, &rootRank, global_grp, &rankCouplerRoot ); 02777 MPI_Comm_rank( jointComm, &rank ); 02778 MPI_Group_free( &global_grp ); // we do not need the global group anymore 02779 #ifdef MOAB_HAVE_ZOLTAN 02780 // send from root of coupler, towards the root of component 02781 if( rankCouplerRoot != rankCompRoot ) // we do not send / receive if we do not have to; it is a blocking send/recv 02782 { 02783 if( rank == rankCouplerRoot ) 02784 { 02785 // do a send of context.uniqueZoltanBuffer, towards the rankCompRoot 02786 ierr = MPI_Send( &context.uniqueZoltanBuffer[0], (int)context.uniqueZoltanBuffer.size(), MPI_CHAR, 02787 rankCompRoot, 123, jointComm );CHK_MPI_ERR( ierr ); 02788 } 02789 if( rank == rankCompRoot ) 02790 { 02791 // first a probe, then a MPI_Recv 02792 MPI_Status status; 02793 ierr = MPI_Probe( rankCouplerRoot, 123, jointComm, &status );CHK_MPI_ERR( ierr ); 02794 // get the count of data received from the MPI_Status structure 02795 int size_buff; 02796 ierr = MPI_Get_count( &status, MPI_CHAR, &size_buff );CHK_MPI_ERR( ierr ); 02797 02798 context.uniqueZoltanBuffer.resize( size_buff ); 02799 ierr = MPI_Recv( &context.uniqueZoltanBuffer[0], size_buff, MPI_CHAR, rankCouplerRoot, 123, jointComm, 02800 &status );CHK_MPI_ERR( ierr ); 02801 } 02802 } 02803 #endif 02804 return moab::MB_SUCCESS; 02805 } 02806 02807 ErrCode iMOAB_SendElementTag( iMOAB_AppID pid, const iMOAB_String tag_storage_name, MPI_Comm* join, int* context_id ) 02808 { 02809 02810 appData& data = context.appDatas[*pid]; 02811 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *context_id ); 02812 if( mt == data.pgraph.end() ) 02813 { 02814 return moab::MB_FAILURE; 02815 } 02816 ParCommGraph* cgraph = mt->second; 02817 ParallelComm* pco = context.pcomms[*pid]; 02818 Range owned = data.owned_elems; 02819 ErrorCode rval; 02820 EntityHandle cover_set; 02821 02822 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02823 if( data.point_cloud ) 02824 { 02825 owned = data.local_verts; 02826 } 02827 02828 // another possibility is for par comm graph to be computed from iMOAB_ComputeCommGraph, for 02829 // after atm ocn intx, from phys (case from imoab_phatm_ocn_coupler.cpp) get then the cover set 02830 // from ints remapper 02831 #ifdef MOAB_HAVE_TEMPESTREMAP 02832 if( data.tempestData.remapper != NULL ) // this is the case this is part of intx;; 02833 { 02834 cover_set = data.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 02835 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02836 // should still have only quads ? 02837 } 02838 #else 02839 // now, in case we are sending from intx between ocn and atm, we involve coverage set 02840 // how do I know if this receiver already participated in an intersection driven by coupler? 02841 // also, what if this was the "source" mesh in intx? 02842 // in that case, the elements might have been instantiated in the coverage set locally, the 02843 // "owned" range can be different the elements are now in tempestRemap coverage_set 02844 cover_set = cgraph->get_cover_set(); // this will be non null only for intx app ? 02845 02846 if( 0 != cover_set ) 02847 { 02848 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02849 } 02850 #endif 02851 02852 std::string tag_name( tag_storage_name ); 02853 02854 // basically, we assume everything is defined already on the tag, 02855 // and we can get the tags just by its name 02856 // we assume that there are separators ":" between the tag names 02857 std::vector< std::string > tagNames; 02858 std::vector< Tag > tagHandles; 02859 std::string separator( ":" ); 02860 split_tag_names( tag_name, separator, tagNames ); 02861 for( size_t i = 0; i < tagNames.size(); i++ ) 02862 { 02863 Tag tagHandle; 02864 rval = context.MBI->tag_get_handle( tagNames[i].c_str(), tagHandle ); 02865 if( MB_SUCCESS != rval || NULL == tagHandle ) 02866 { 02867 std::cout << " can't get tag handle for tag named:" << tagNames[i].c_str() << " at index " << i << "\n";MB_CHK_SET_ERR( rval, "can't get tag handle" ); 02868 } 02869 tagHandles.push_back( tagHandle ); 02870 } 02871 02872 // pco is needed to pack, and for moab instance, not for communication! 02873 // still use nonblocking communication, over the joint comm 02874 rval = cgraph->send_tag_values( global, pco, owned, tagHandles );MB_CHK_ERR( rval ); 02875 // now, send to each corr_tasks[i] tag data for corr_sizes[i] primary entities 02876 02877 return moab::MB_SUCCESS; 02878 } 02879 02880 ErrCode iMOAB_ReceiveElementTag( iMOAB_AppID pid, const iMOAB_String tag_storage_name, MPI_Comm* join, int* context_id ) 02881 { 02882 appData& data = context.appDatas[*pid]; 02883 02884 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *context_id ); 02885 if( mt == data.pgraph.end() ) 02886 { 02887 return moab::MB_FAILURE; 02888 } 02889 ParCommGraph* cgraph = mt->second; 02890 02891 MPI_Comm global = ( data.is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02892 ParallelComm* pco = context.pcomms[*pid]; 02893 Range owned = data.owned_elems; 02894 02895 // how do I know if this receiver already participated in an intersection driven by coupler? 02896 // also, what if this was the "source" mesh in intx? 02897 // in that case, the elements might have been instantiated in the coverage set locally, the 02898 // "owned" range can be different the elements are now in tempestRemap coverage_set 02899 EntityHandle cover_set = cgraph->get_cover_set(); 02900 ErrorCode rval; 02901 if( 0 != cover_set ) 02902 { 02903 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02904 } 02905 if( data.point_cloud ) 02906 { 02907 owned = data.local_verts; 02908 } 02909 // another possibility is for par comm graph to be computed from iMOAB_ComputeCommGraph, for 02910 // after atm ocn intx, from phys (case from imoab_phatm_ocn_coupler.cpp) get then the cover set 02911 // from ints remapper 02912 #ifdef MOAB_HAVE_TEMPESTREMAP 02913 if( data.tempestData.remapper != NULL ) // this is the case this is part of intx;; 02914 { 02915 cover_set = data.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 02916 rval = context.MBI->get_entities_by_dimension( cover_set, 2, owned );MB_CHK_ERR( rval ); 02917 // should still have only quads ? 02918 } 02919 #endif 02920 /* 02921 * data_intx.remapper exists though only on the intersection application 02922 * how do we get from here ( we know the pid that receives, and the commgraph used by migrate 02923 * mesh ) 02924 */ 02925 02926 std::string tag_name( tag_storage_name ); 02927 02928 // we assume that there are separators ";" between the tag names 02929 std::vector< std::string > tagNames; 02930 std::vector< Tag > tagHandles; 02931 std::string separator( ":" ); 02932 split_tag_names( tag_name, separator, tagNames ); 02933 for( size_t i = 0; i < tagNames.size(); i++ ) 02934 { 02935 Tag tagHandle; 02936 rval = context.MBI->tag_get_handle( tagNames[i].c_str(), tagHandle ); 02937 if( MB_SUCCESS != rval || NULL == tagHandle ) 02938 { 02939 std::cout << " can't get tag handle for tag named:" << tagNames[i].c_str() << " at index " << i << "\n";MB_CHK_SET_ERR( rval, "can't get tag handle" ); 02940 } 02941 tagHandles.push_back( tagHandle ); 02942 } 02943 02944 #ifdef VERBOSE 02945 std::cout << pco->rank() << ". Looking to receive data for tags: " << tag_name 02946 << " and file set = " << ( data.file_set ) << "\n"; 02947 #endif 02948 // pco is needed to pack, and for moab instance, not for communication! 02949 // still use nonblocking communication 02950 rval = cgraph->receive_tag_values( global, pco, owned, tagHandles );MB_CHK_ERR( rval ); 02951 02952 #ifdef VERBOSE 02953 std::cout << pco->rank() << ". Looking to receive data for tags: " << tag_name << "\n"; 02954 #endif 02955 02956 return moab::MB_SUCCESS; 02957 } 02958 02959 ErrCode iMOAB_FreeSenderBuffers( iMOAB_AppID pid, int* context_id ) 02960 { 02961 // need first to find the pgraph that holds the information we need 02962 // this will be called on sender side only 02963 appData& data = context.appDatas[*pid]; 02964 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *context_id ); 02965 if( mt == data.pgraph.end() ) return moab::MB_FAILURE; // error 02966 02967 mt->second->release_send_buffers(); 02968 return moab::MB_SUCCESS; 02969 } 02970 02971 /** 02972 \brief compute a comm graph between 2 moab apps, based on ID matching 02973 <B>Operations:</B> Collective 02974 */ 02975 //#define VERBOSE 02976 ErrCode iMOAB_ComputeCommGraph( iMOAB_AppID pid1, 02977 iMOAB_AppID pid2, 02978 MPI_Comm* join, 02979 MPI_Group* group1, 02980 MPI_Group* group2, 02981 int* type1, 02982 int* type2, 02983 int* comp1, 02984 int* comp2 ) 02985 { 02986 assert( join ); 02987 assert( group1 ); 02988 assert( group2 ); 02989 ErrorCode rval = MB_SUCCESS; 02990 int localRank = 0, numProcs = 1; 02991 02992 bool isFortran = false; 02993 if( *pid1 >= 0 ) isFortran = isFortran || context.appDatas[*pid1].is_fortran; 02994 if( *pid2 >= 0 ) isFortran = isFortran || context.appDatas[*pid2].is_fortran; 02995 02996 MPI_Comm global = ( isFortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 02997 MPI_Group srcGroup = ( isFortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( group1 ) ) : *group1 ); 02998 MPI_Group tgtGroup = ( isFortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( group2 ) ) : *group2 ); 02999 03000 MPI_Comm_rank( global, &localRank ); 03001 MPI_Comm_size( global, &numProcs ); 03002 // instantiate the par comm graph 03003 03004 // we should search if we have another pcomm with the same comp ids in the list already 03005 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 03006 bool already_exists = false; 03007 if( *pid1 >= 0 ) 03008 { 03009 appData& data = context.appDatas[*pid1]; 03010 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *comp2 ); 03011 if( mt != data.pgraph.end() ) already_exists = true; 03012 } 03013 if( *pid2 >= 0 ) 03014 { 03015 appData& data = context.appDatas[*pid2]; 03016 std::map< int, ParCommGraph* >::iterator mt = data.pgraph.find( *comp1 ); 03017 if( mt != data.pgraph.end() ) already_exists = true; 03018 } 03019 // nothing to do if it already exists 03020 if( already_exists ) 03021 { 03022 #ifdef VERBOSE 03023 if( !localRank ) 03024 std::cout << " parcomgraph already existing between components " << *comp1 << " and " << *comp2 03025 << ". Do not compute again\n"; 03026 #endif 03027 return moab::MB_SUCCESS; 03028 } 03029 03030 // ParCommGraph::ParCommGraph(MPI_Comm joincomm, MPI_Group group1, MPI_Group group2, int coid1, 03031 // int coid2) 03032 ParCommGraph* cgraph = NULL; 03033 if( *pid1 >= 0 ) cgraph = new ParCommGraph( global, srcGroup, tgtGroup, *comp1, *comp2 ); 03034 ParCommGraph* cgraph_rev = NULL; 03035 if( *pid2 >= 0 ) cgraph_rev = new ParCommGraph( global, tgtGroup, srcGroup, *comp2, *comp1 ); 03036 03037 if( *pid1 >= 0 ) context.appDatas[*pid1].pgraph[*comp2] = cgraph; // the context will be the other comp 03038 if( *pid2 >= 0 ) context.appDatas[*pid2].pgraph[*comp1] = cgraph_rev; // from 2 to 1 03039 // each model has a list of global ids that will need to be sent by gs to rendezvous the other 03040 // model on the joint comm 03041 TupleList TLcomp1; 03042 TLcomp1.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 03043 TupleList TLcomp2; 03044 TLcomp2.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 03045 // will push_back a new tuple, if needed 03046 03047 TLcomp1.enableWriteAccess(); 03048 03049 // tags of interest are either GLOBAL_DOFS or GLOBAL_ID 03050 Tag gdsTag; 03051 // find the values on first cell 03052 int lenTagType1 = 1; 03053 if( 1 == *type1 || 1 == *type2 ) 03054 { 03055 rval = context.MBI->tag_get_handle( "GLOBAL_DOFS", gdsTag );MB_CHK_ERR( rval ); 03056 rval = context.MBI->tag_get_length( gdsTag, lenTagType1 );MB_CHK_ERR( rval ); // usually it is 16 03057 } 03058 Tag tagType2 = context.MBI->globalId_tag(); 03059 03060 std::vector< int > valuesComp1; 03061 // populate first tuple 03062 if( *pid1 >= 0 ) 03063 { 03064 appData& data1 = context.appDatas[*pid1]; 03065 EntityHandle fset1 = data1.file_set; 03066 // in case of tempest remap, get the coverage set 03067 #ifdef MOAB_HAVE_TEMPESTREMAP 03068 if( data1.tempestData.remapper != NULL ) // this is the case this is part of intx;; 03069 { 03070 fset1 = data1.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 03071 // should still have only quads ? 03072 } 03073 #endif 03074 Range ents_of_interest; 03075 if( *type1 == 1 ) 03076 { 03077 assert( gdsTag ); 03078 rval = context.MBI->get_entities_by_type( fset1, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 03079 valuesComp1.resize( ents_of_interest.size() * lenTagType1 ); 03080 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); 03081 } 03082 else if( *type1 == 2 ) 03083 { 03084 rval = context.MBI->get_entities_by_type( fset1, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 03085 valuesComp1.resize( ents_of_interest.size() ); 03086 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 03087 } 03088 else if( *type1 == 3 ) // for FV meshes, just get the global id of cell 03089 { 03090 rval = context.MBI->get_entities_by_dimension( fset1, 2, ents_of_interest );MB_CHK_ERR( rval ); 03091 valuesComp1.resize( ents_of_interest.size() ); 03092 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 03093 } 03094 else 03095 { 03096 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 or 3 03097 } 03098 // now fill the tuple list with info and markers 03099 // because we will send only the ids, order and compress the list 03100 std::set< int > uniq( valuesComp1.begin(), valuesComp1.end() ); 03101 TLcomp1.resize( uniq.size() ); 03102 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 03103 { 03104 // to proc, marker, element local index, index in el 03105 int marker = *sit; 03106 int to_proc = marker % numProcs; 03107 int n = TLcomp1.get_n(); 03108 TLcomp1.vi_wr[2 * n] = to_proc; // send to processor 03109 TLcomp1.vi_wr[2 * n + 1] = marker; 03110 TLcomp1.inc_n(); 03111 } 03112 } 03113 03114 ProcConfig pc( global ); // proc config does the crystal router 03115 pc.crystal_router()->gs_transfer( 1, TLcomp1, 03116 0 ); // communication towards joint tasks, with markers 03117 // sort by value (key 1) 03118 #ifdef VERBOSE 03119 std::stringstream ff1; 03120 ff1 << "TLcomp1_" << localRank << ".txt"; 03121 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 03122 #endif 03123 moab::TupleList::buffer sort_buffer; 03124 sort_buffer.buffer_init( TLcomp1.get_n() ); 03125 TLcomp1.sort( 1, &sort_buffer ); 03126 sort_buffer.reset(); 03127 #ifdef VERBOSE 03128 // after sorting 03129 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 03130 #endif 03131 // do the same, for the other component, number2, with type2 03132 // start copy 03133 TLcomp2.enableWriteAccess(); 03134 // populate second tuple 03135 std::vector< int > valuesComp2; 03136 if( *pid2 >= 0 ) 03137 { 03138 appData& data2 = context.appDatas[*pid2]; 03139 EntityHandle fset2 = data2.file_set; 03140 // in case of tempest remap, get the coverage set 03141 #ifdef MOAB_HAVE_TEMPESTREMAP 03142 if( data2.tempestData.remapper != NULL ) // this is the case this is part of intx;; 03143 { 03144 fset2 = data2.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 03145 // should still have only quads ? 03146 } 03147 #endif 03148 03149 Range ents_of_interest; 03150 if( *type2 == 1 ) 03151 { 03152 assert( gdsTag ); 03153 rval = context.MBI->get_entities_by_type( fset2, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 03154 valuesComp2.resize( ents_of_interest.size() * lenTagType1 ); 03155 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &valuesComp2[0] );MB_CHK_ERR( rval ); 03156 } 03157 else if( *type2 == 2 ) 03158 { 03159 rval = context.MBI->get_entities_by_type( fset2, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 03160 valuesComp2.resize( ents_of_interest.size() ); // stride is 1 here 03161 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp2[0] );MB_CHK_ERR( rval ); // just global ids 03162 } 03163 else if( *type2 == 3 ) 03164 { 03165 rval = context.MBI->get_entities_by_dimension( fset2, 2, ents_of_interest );MB_CHK_ERR( rval ); 03166 valuesComp2.resize( ents_of_interest.size() ); // stride is 1 here 03167 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp2[0] );MB_CHK_ERR( rval ); // just global ids 03168 } 03169 else 03170 { 03171 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 03172 } 03173 // now fill the tuple list with info and markers 03174 std::set< int > uniq( valuesComp2.begin(), valuesComp2.end() ); 03175 TLcomp2.resize( uniq.size() ); 03176 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 03177 { 03178 // to proc, marker, element local index, index in el 03179 int marker = *sit; 03180 int to_proc = marker % numProcs; 03181 int n = TLcomp2.get_n(); 03182 TLcomp2.vi_wr[2 * n] = to_proc; // send to processor 03183 TLcomp2.vi_wr[2 * n + 1] = marker; 03184 TLcomp2.inc_n(); 03185 } 03186 } 03187 pc.crystal_router()->gs_transfer( 1, TLcomp2, 03188 0 ); // communication towards joint tasks, with markers 03189 // sort by value (key 1) 03190 #ifdef VERBOSE 03191 std::stringstream ff2; 03192 ff2 << "TLcomp2_" << localRank << ".txt"; 03193 TLcomp2.print_to_file( ff2.str().c_str() ); 03194 #endif 03195 sort_buffer.buffer_reserve( TLcomp2.get_n() ); 03196 TLcomp2.sort( 1, &sort_buffer ); 03197 sort_buffer.reset(); 03198 // end copy 03199 #ifdef VERBOSE 03200 TLcomp2.print_to_file( ff2.str().c_str() ); 03201 #endif 03202 // need to send back the info, from the rendezvous point, for each of the values 03203 /* so go over each value, on local process in joint communicator 03204 03205 now have to send back the info needed for communication; 03206 loop in in sync over both TLComp1 and TLComp2, in local process; 03207 So, build new tuple lists, to send synchronous communication 03208 populate them at the same time, based on marker, that is indexed 03209 */ 03210 03211 TupleList TLBackToComp1; 03212 TLBackToComp1.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc on comp2, 03213 TLBackToComp1.enableWriteAccess(); 03214 03215 TupleList TLBackToComp2; 03216 TLBackToComp2.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc, 03217 TLBackToComp2.enableWriteAccess(); 03218 03219 int n1 = TLcomp1.get_n(); 03220 int n2 = TLcomp2.get_n(); 03221 03222 int indexInTLComp1 = 0; 03223 int indexInTLComp2 = 0; // advance both, according to the marker 03224 if( n1 > 0 && n2 > 0 ) 03225 { 03226 03227 while( indexInTLComp1 < n1 && indexInTLComp2 < n2 ) // if any is over, we are done 03228 { 03229 int currentValue1 = TLcomp1.vi_rd[2 * indexInTLComp1 + 1]; 03230 int currentValue2 = TLcomp2.vi_rd[2 * indexInTLComp2 + 1]; 03231 if( currentValue1 < currentValue2 ) 03232 { 03233 // we have a big problem; basically, we are saying that 03234 // dof currentValue is on one model and not on the other 03235 // std::cout << " currentValue1:" << currentValue1 << " missing in comp2" << "\n"; 03236 indexInTLComp1++; 03237 continue; 03238 } 03239 if( currentValue1 > currentValue2 ) 03240 { 03241 // std::cout << " currentValue2:" << currentValue2 << " missing in comp1" << "\n"; 03242 indexInTLComp2++; 03243 continue; 03244 } 03245 int size1 = 1; 03246 int size2 = 1; 03247 while( indexInTLComp1 + size1 < n1 && currentValue1 == TLcomp1.vi_rd[2 * ( indexInTLComp1 + size1 ) + 1] ) 03248 size1++; 03249 while( indexInTLComp2 + size2 < n2 && currentValue2 == TLcomp2.vi_rd[2 * ( indexInTLComp2 + size2 ) + 1] ) 03250 size2++; 03251 // must be found in both lists, find the start and end indices 03252 for( int i1 = 0; i1 < size1; i1++ ) 03253 { 03254 for( int i2 = 0; i2 < size2; i2++ ) 03255 { 03256 // send the info back to components 03257 int n = TLBackToComp1.get_n(); 03258 TLBackToComp1.reserve(); 03259 TLBackToComp1.vi_wr[3 * n] = 03260 TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // send back to the proc marker 03261 // came from, info from comp2 03262 TLBackToComp1.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 03263 TLBackToComp1.vi_wr[3 * n + 2] = TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // from proc on comp2 03264 n = TLBackToComp2.get_n(); 03265 TLBackToComp2.reserve(); 03266 TLBackToComp2.vi_wr[3 * n] = 03267 TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // send back info to original 03268 TLBackToComp2.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 03269 TLBackToComp2.vi_wr[3 * n + 2] = TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // from proc on comp1 03270 // what if there are repeated markers in TLcomp2? increase just index2 03271 } 03272 } 03273 indexInTLComp1 += size1; 03274 indexInTLComp2 += size2; 03275 } 03276 } 03277 pc.crystal_router()->gs_transfer( 1, TLBackToComp1, 0 ); // communication towards original tasks, with info about 03278 pc.crystal_router()->gs_transfer( 1, TLBackToComp2, 0 ); 03279 03280 if( *pid1 >= 0 ) 03281 { 03282 // we are on original comp 1 tasks 03283 // before ordering 03284 // now for each value in TLBackToComp1.vi_rd[3*i+1], on current proc, we know the 03285 // processors it communicates with 03286 #ifdef VERBOSE 03287 std::stringstream f1; 03288 f1 << "TLBack1_" << localRank << ".txt"; 03289 TLBackToComp1.print_to_file( f1.str().c_str() ); 03290 #endif 03291 sort_buffer.buffer_reserve( TLBackToComp1.get_n() ); 03292 TLBackToComp1.sort( 1, &sort_buffer ); 03293 sort_buffer.reset(); 03294 #ifdef VERBOSE 03295 TLBackToComp1.print_to_file( f1.str().c_str() ); 03296 #endif 03297 // so we are now on pid1, we know now each marker were it has to go 03298 // add a new method to ParCommGraph, to set up the involved_IDs_map 03299 cgraph->settle_comm_by_ids( *comp1, TLBackToComp1, valuesComp1 ); 03300 } 03301 if( *pid2 >= 0 ) 03302 { 03303 // we are on original comp 1 tasks 03304 // before ordering 03305 // now for each value in TLBackToComp1.vi_rd[3*i+1], on current proc, we know the 03306 // processors it communicates with 03307 #ifdef VERBOSE 03308 std::stringstream f2; 03309 f2 << "TLBack2_" << localRank << ".txt"; 03310 TLBackToComp2.print_to_file( f2.str().c_str() ); 03311 #endif 03312 sort_buffer.buffer_reserve( TLBackToComp2.get_n() ); 03313 TLBackToComp2.sort( 2, &sort_buffer ); 03314 sort_buffer.reset(); 03315 #ifdef VERBOSE 03316 TLBackToComp2.print_to_file( f2.str().c_str() ); 03317 #endif 03318 cgraph_rev->settle_comm_by_ids( *comp2, TLBackToComp2, valuesComp2 ); 03319 // 03320 } 03321 return moab::MB_SUCCESS; 03322 } 03323 03324 //#undef VERBOSE 03325 03326 ErrCode iMOAB_MergeVertices( iMOAB_AppID pid ) 03327 { 03328 appData& data = context.appDatas[*pid]; 03329 ParallelComm* pco = context.pcomms[*pid]; 03330 // collapse vertices and transform cells into triangles/quads /polys 03331 // tags we care about: area, frac, global id 03332 std::vector< Tag > tagsList; 03333 Tag tag; 03334 ErrorCode rval = context.MBI->tag_get_handle( "GLOBAL_ID", tag ); 03335 if( !tag || rval != MB_SUCCESS ) return moab::MB_FAILURE; // fatal error, abort 03336 tagsList.push_back( tag ); 03337 rval = context.MBI->tag_get_handle( "area", tag ); 03338 if( tag && rval == MB_SUCCESS ) tagsList.push_back( tag ); 03339 rval = context.MBI->tag_get_handle( "frac", tag ); 03340 if( tag && rval == MB_SUCCESS ) tagsList.push_back( tag ); 03341 double tol = 1.0e-9; 03342 rval = IntxUtils::remove_duplicate_vertices( context.MBI, data.file_set, tol, tagsList );MB_CHK_ERR( rval ); 03343 03344 // clean material sets of cells that were deleted 03345 rval = context.MBI->get_entities_by_type_and_tag( data.file_set, MBENTITYSET, &( context.material_tag ), 0, 1, 03346 data.mat_sets, Interface::UNION );MB_CHK_ERR( rval ); 03347 03348 if( !data.mat_sets.empty() ) 03349 { 03350 EntityHandle matSet = data.mat_sets[0]; 03351 Range elems; 03352 rval = context.MBI->get_entities_by_dimension( matSet, 2, elems );MB_CHK_ERR( rval ); 03353 rval = context.MBI->remove_entities( matSet, elems );MB_CHK_ERR( rval ); 03354 // put back only cells from data.file_set 03355 elems.clear(); 03356 rval = context.MBI->get_entities_by_dimension( data.file_set, 2, elems );MB_CHK_ERR( rval ); 03357 rval = context.MBI->add_entities( matSet, elems );MB_CHK_ERR( rval ); 03358 } 03359 rval = iMOAB_UpdateMeshInfo( pid );MB_CHK_ERR( rval ); 03360 03361 ParallelMergeMesh pmm( pco, tol ); 03362 rval = pmm.merge( data.file_set, 03363 /* do not do local merge*/ false, 03364 /* 2d cells*/ 2 );MB_CHK_ERR( rval ); 03365 03366 // assign global ids only for vertices, cells have them fine 03367 rval = pco->assign_global_ids( data.file_set, /*dim*/ 0 );MB_CHK_ERR( rval ); 03368 03369 // set the partition tag on the file set 03370 Tag part_tag; 03371 int dum_id = -1; 03372 rval = context.MBI->tag_get_handle( "PARALLEL_PARTITION", 1, MB_TYPE_INTEGER, part_tag, 03373 MB_TAG_CREAT | MB_TAG_SPARSE, &dum_id ); 03374 03375 if( part_tag == NULL || ( ( rval != MB_SUCCESS ) && ( rval != MB_ALREADY_ALLOCATED ) ) ) 03376 { 03377 std::cout << " can't get par part tag.\n"; 03378 return moab::MB_FAILURE; 03379 } 03380 03381 int rank = pco->rank(); 03382 rval = context.MBI->tag_set_data( part_tag, &data.file_set, 1, &rank );MB_CHK_ERR( rval ); 03383 03384 return moab::MB_SUCCESS; 03385 } 03386 03387 #ifdef MOAB_HAVE_TEMPESTREMAP 03388 03389 // this call must be collective on the joint communicator 03390 // intersection tasks on coupler will need to send to the components tasks the list of 03391 // id elements that are relevant: they intersected some of the target elements (which are not needed 03392 // here) 03393 // in the intersection 03394 ErrCode iMOAB_CoverageGraph( MPI_Comm* join, 03395 iMOAB_AppID pid_src, 03396 iMOAB_AppID pid_migr, 03397 iMOAB_AppID pid_intx, 03398 int* src_id, 03399 int* migr_id, 03400 int* context_id ) 03401 { 03402 // first, based on the scompid and migrcomp, find the parCommGraph corresponding to this 03403 // exchange 03404 ErrorCode rval; 03405 std::vector< int > srcSenders; 03406 std::vector< int > receivers; 03407 ParCommGraph* sendGraph = NULL; 03408 int ierr; 03409 int default_context_id = -1; 03410 bool is_fortran_context = false; 03411 03412 // First, find the original graph between PE sets 03413 // And based on this one, we will build the newly modified one for coverage 03414 if( *pid_src >= 0 ) 03415 { 03416 default_context_id = *migr_id; // the other one 03417 assert( context.appDatas[*pid_src].global_id == *src_id ); 03418 is_fortran_context = context.appDatas[*pid_src].is_fortran || is_fortran_context; 03419 sendGraph = context.appDatas[*pid_src].pgraph[default_context_id]; // maybe check if it does not exist 03420 03421 // report the sender and receiver tasks in the joint comm 03422 srcSenders = sendGraph->senders(); 03423 receivers = sendGraph->receivers(); 03424 #ifdef VERBOSE 03425 std::cout << "senders: " << srcSenders.size() << " first sender: " << srcSenders[0] << std::endl; 03426 #endif 03427 } 03428 03429 ParCommGraph* recvGraph = NULL; // will be non null on receiver tasks (intx tasks) 03430 if( *pid_migr >= 0 ) 03431 { 03432 is_fortran_context = context.appDatas[*pid_migr].is_fortran || is_fortran_context; 03433 // find the original one 03434 default_context_id = *src_id; 03435 assert( context.appDatas[*pid_migr].global_id == *migr_id ); 03436 recvGraph = context.appDatas[*pid_migr].pgraph[default_context_id]; 03437 // report the sender and receiver tasks in the joint comm, from migrated mesh pt of view 03438 srcSenders = recvGraph->senders(); 03439 receivers = recvGraph->receivers(); 03440 #ifdef VERBOSE 03441 std::cout << "receivers: " << receivers.size() << " first receiver: " << receivers[0] << std::endl; 03442 #endif 03443 } 03444 03445 if( *pid_intx >= 0 ) is_fortran_context = context.appDatas[*pid_intx].is_fortran || is_fortran_context; 03446 03447 // loop over pid_intx elements, to see what original processors in joint comm have sent the 03448 // coverage mesh; 03449 // If we are on intx tasks, send coverage info towards original component tasks, 03450 // about needed cells 03451 TupleList TLcovIDs; 03452 TLcovIDs.initialize( 2, 0, 0, 0, 0 ); // to proc, GLOBAL ID; estimate about 100 IDs to be sent 03453 // will push_back a new tuple, if needed 03454 TLcovIDs.enableWriteAccess(); 03455 // the crystal router will send ID cell to the original source, on the component task 03456 // if we are on intx tasks, loop over all intx elements and 03457 03458 MPI_Comm global = ( is_fortran_context ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( join ) ) : *join ); 03459 int currentRankInJointComm = -1; 03460 ierr = MPI_Comm_rank( global, ¤tRankInJointComm );CHK_MPI_ERR( ierr ); 03461 03462 // if currentRankInJointComm is in receivers list, it means that we are on intx tasks too, we 03463 // need to send information towards component tasks 03464 if( find( receivers.begin(), receivers.end(), currentRankInJointComm ) != 03465 receivers.end() ) // we are on receivers tasks, we can request intx info 03466 { 03467 // find the pcomm for the intx pid 03468 if( *pid_intx >= (int)context.appDatas.size() ) return moab::MB_FAILURE; 03469 03470 appData& dataIntx = context.appDatas[*pid_intx]; 03471 Tag parentTag, orgSendProcTag; 03472 03473 rval = context.MBI->tag_get_handle( "SourceParent", parentTag );MB_CHK_ERR( rval ); // global id of the blue, source element 03474 if( !parentTag ) return moab::MB_FAILURE; // fatal error, abort 03475 03476 rval = context.MBI->tag_get_handle( "orig_sending_processor", orgSendProcTag );MB_CHK_ERR( rval ); 03477 if( !orgSendProcTag ) return moab::MB_FAILURE; // fatal error, abort 03478 03479 // find the file set, red parents for intx cells, and put them in tuples 03480 EntityHandle intxSet = dataIntx.file_set; 03481 Range cells; 03482 // get all entities from the set, and look at their RedParent 03483 rval = context.MBI->get_entities_by_dimension( intxSet, 2, cells );MB_CHK_ERR( rval ); 03484 03485 std::map< int, std::set< int > > idsFromProcs; // send that info back to enhance parCommGraph cache 03486 for( Range::iterator it = cells.begin(); it != cells.end(); it++ ) 03487 { 03488 EntityHandle intx_cell = *it; 03489 int gidCell, origProc; // look at receivers 03490 03491 rval = context.MBI->tag_get_data( parentTag, &intx_cell, 1, &gidCell );MB_CHK_ERR( rval ); 03492 rval = context.MBI->tag_get_data( orgSendProcTag, &intx_cell, 1, &origProc );MB_CHK_ERR( rval ); 03493 // we have augmented the overlap set with ghost cells ; in that case, the 03494 // orig_sending_processor is not set so it will be -1; 03495 if( origProc < 0 ) continue; 03496 03497 std::set< int >& setInts = idsFromProcs[origProc]; 03498 setInts.insert( gidCell ); 03499 } 03500 // questionable ?? 03501 #if 0 03502 // if we have no intx cells, it means we are on point clouds; quick fix just use all cells 03503 // from coverage set 03504 if( cells.empty() ) 03505 { 03506 // get coverage set 03507 assert( *pid_intx >= 0 ); 03508 appData& dataIntx = context.appDatas[*pid_intx]; 03509 EntityHandle cover_set = dataIntx.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 03510 03511 // get all cells from coverage set 03512 Tag gidTag; 03513 rval = context.MBI->tag_get_handle( "GLOBAL_ID", gidTag );MB_CHK_ERR( rval ); 03514 rval = context.MBI->get_entities_by_dimension( cover_set, 2, cells );MB_CHK_ERR( rval ); 03515 // look at their orig_sending_processor 03516 for( Range::iterator it = cells.begin(); it != cells.end(); it++ ) 03517 { 03518 EntityHandle covCell = *it; 03519 int gidCell, origProc; // look at o 03520 03521 rval = context.MBI->tag_get_data( gidTag, &covCell, 1, &gidCell );MB_CHK_ERR( rval ); 03522 rval = context.MBI->tag_get_data( orgSendProcTag, &covCell, 1, &origProc );MB_CHK_ERR( rval ); 03523 // we have augmented the overlap set with ghost cells ; in that case, the 03524 // orig_sending_processor is not set so it will be -1; 03525 if( origProc < 0 ) // it cannot < 0, I think 03526 continue; 03527 std::set< int >& setInts = idsFromProcs[origProc]; 03528 setInts.insert( gidCell ); 03529 } 03530 } 03531 #endif // #if 0 03532 03533 #ifdef VERBOSE 03534 std::ofstream dbfile; 03535 std::stringstream outf; 03536 outf << "idsFromProc_0" << currentRankInJointComm << ".txt"; 03537 dbfile.open( outf.str().c_str() ); 03538 dbfile << "Writing this to a file.\n"; 03539 03540 dbfile << " map size:" << idsFromProcs.size() 03541 << std::endl; // on the receiver side, these show how much data to receive 03542 // from the sender (how many ids, and how much tag data later; we need to size up the 03543 // receiver buffer) arrange in tuples , use map iterators to send the ids 03544 for( std::map< int, std::set< int > >::iterator mt = idsFromProcs.begin(); mt != idsFromProcs.end(); mt++ ) 03545 { 03546 std::set< int >& setIds = mt->second; 03547 dbfile << "from id: " << mt->first << " receive " << setIds.size() << " cells \n"; 03548 int counter = 0; 03549 for( std::set< int >::iterator st = setIds.begin(); st != setIds.end(); st++ ) 03550 { 03551 int valueID = *st; 03552 dbfile << " " << valueID; 03553 counter++; 03554 if( counter % 10 == 0 ) dbfile << "\n"; 03555 } 03556 dbfile << "\n"; 03557 } 03558 dbfile.close(); 03559 #endif 03560 if( NULL != recvGraph ) 03561 { 03562 ParCommGraph* recvGraph1 = new ParCommGraph( *recvGraph ); // just copy 03563 recvGraph1->set_context_id( *context_id ); 03564 recvGraph1->SetReceivingAfterCoverage( idsFromProcs ); 03565 // this par comm graph will need to use the coverage set 03566 // so we are for sure on intx pes (the receiver is the coupler mesh) 03567 assert( *pid_intx >= 0 ); 03568 appData& dataIntx = context.appDatas[*pid_intx]; 03569 EntityHandle cover_set = dataIntx.tempestData.remapper->GetMeshSet( Remapper::CoveringMesh ); 03570 recvGraph1->set_cover_set( cover_set ); 03571 context.appDatas[*pid_migr].pgraph[*context_id] = recvGraph1; // possible memory leak if context_id is same 03572 } 03573 // initial loop to see how much space we need for TLcovIDs 03574 size_t nbIds = 0; 03575 for( std::map< int, std::set< int > >::iterator mit = idsFromProcs.begin(); mit != idsFromProcs.end(); mit++ ) 03576 { 03577 std::set< int >& idSet = mit->second; 03578 nbIds += idSet.size(); 03579 } 03580 03581 TLcovIDs.resize( nbIds ); 03582 03583 for( std::map< int, std::set< int > >::iterator mit = idsFromProcs.begin(); mit != idsFromProcs.end(); mit++ ) 03584 { 03585 int procToSendTo = mit->first; 03586 std::set< int >& idSet = mit->second; 03587 for( std::set< int >::iterator sit = idSet.begin(); sit != idSet.end(); sit++ ) 03588 { 03589 int n = TLcovIDs.get_n(); 03590 TLcovIDs.vi_wr[2 * n] = procToSendTo; // send to processor 03591 TLcovIDs.vi_wr[2 * n + 1] = *sit; // global id needs index in the local_verts range 03592 TLcovIDs.inc_n(); 03593 } 03594 } 03595 } 03596 03597 ProcConfig pc( global ); // proc config does the crystal router 03598 pc.crystal_router()->gs_transfer( 1, TLcovIDs, 03599 0 ); // communication towards component tasks, with what ids are needed 03600 // for each task from receiver 03601 03602 // a test to know if we are on the sender tasks (original component, in this case, atmosphere) 03603 if( NULL != sendGraph ) 03604 { 03605 // collect TLcovIDs tuple, will set in a local map/set, the ids that are sent to each 03606 // receiver task 03607 ParCommGraph* sendGraph1 = new ParCommGraph( *sendGraph ); // just copy 03608 sendGraph1->set_context_id( *context_id ); 03609 context.appDatas[*pid_src].pgraph[*context_id] = sendGraph1; 03610 rval = sendGraph1->settle_send_graph( TLcovIDs );MB_CHK_ERR( rval ); 03611 } 03612 return moab::MB_SUCCESS; // success 03613 } 03614 03615 ErrCode iMOAB_DumpCommGraph( iMOAB_AppID pid, int* context_id, int* is_sender, int* verbose, const iMOAB_String prefix ) 03616 { 03617 03618 ParCommGraph* cgraph = context.appDatas[*pid].pgraph[*context_id]; 03619 std::string prefix_str( prefix ); 03620 03621 if( NULL != cgraph ) 03622 cgraph->dump_comm_information( prefix_str, *is_sender, *verbose ); 03623 else 03624 { 03625 std::cout << " cannot find ParCommGraph on app with pid " << *pid << " name: " << context.appDatas[*pid].name 03626 << " context: " << *context_id << "\n"; 03627 } 03628 return moab::MB_SUCCESS; 03629 } 03630 03631 #endif // #ifdef MOAB_HAVE_TEMPESTREMAP 03632 03633 #endif // #ifdef MOAB_HAVE_MPI 03634 03635 #ifdef MOAB_HAVE_TEMPESTREMAP 03636 03637 #ifdef MOAB_HAVE_NETCDF 03638 ErrCode iMOAB_LoadMappingWeightsFromFile( 03639 iMOAB_AppID pid_intersection, 03640 iMOAB_AppID pid_cpl, 03641 int* col_or_row, 03642 int* type, 03643 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 03644 const iMOAB_String remap_weights_filename ) 03645 { 03646 ErrorCode rval; 03647 bool row_based_partition = true; 03648 if( *col_or_row == 1 ) row_based_partition = false; // do a column based partition; 03649 03650 // get the local degrees of freedom, from the pid_cpl and type of mesh 03651 03652 // Get the source and target data and pcomm objects 03653 appData& data_intx = context.appDatas[*pid_intersection]; 03654 TempestMapAppData& tdata = data_intx.tempestData; 03655 03656 // Get the handle to the remapper object 03657 if( tdata.remapper == NULL ) 03658 { 03659 // Now allocate and initialize the remapper object 03660 #ifdef MOAB_HAVE_MPI 03661 ParallelComm* pco = context.pcomms[*pid_intersection]; 03662 tdata.remapper = new moab::TempestRemapper( context.MBI, pco ); 03663 #else 03664 tdata.remapper = new moab::TempestRemapper( context.MBI ); 03665 #endif 03666 tdata.remapper->meshValidate = true; 03667 tdata.remapper->constructEdgeMap = true; 03668 // Do not create new filesets; Use the sets from our respective applications 03669 tdata.remapper->initialize( false ); 03670 tdata.remapper->GetMeshSet( moab::Remapper::OverlapMesh ) = data_intx.file_set; 03671 } 03672 03673 // Setup loading of weights onto TempestOnlineMap 03674 // Set the context for the remapping weights computation 03675 tdata.weightMaps[std::string( solution_weights_identifier )] = new moab::TempestOnlineMap( tdata.remapper ); 03676 03677 // Now allocate and initialize the remapper object 03678 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 03679 assert( weightMap != NULL ); 03680 03681 if( *pid_cpl >= 0 ) // it means we are looking for how to distribute the degrees of freedom, new map reader 03682 { 03683 appData& data1 = context.appDatas[*pid_cpl]; 03684 EntityHandle fset1 = data1.file_set; // this is source or target, depending on direction 03685 03686 // tags of interest are either GLOBAL_DOFS or GLOBAL_ID 03687 Tag gdsTag; 03688 03689 // find the values on first cell 03690 int lenTagType1 = 1; 03691 if( *type == 1 ) 03692 { 03693 rval = context.MBI->tag_get_handle( "GLOBAL_DOFS", gdsTag );MB_CHK_ERR( rval ); 03694 rval = context.MBI->tag_get_length( gdsTag, lenTagType1 );MB_CHK_ERR( rval ); // usually it is 16 03695 } 03696 Tag tagType2 = context.MBI->globalId_tag(); 03697 03698 std::vector< int > dofValues; 03699 03700 // populate first tuple 03701 Range 03702 ents_of_interest; // will be filled with entities on coupler, from which we will get the DOFs, based on type 03703 int ndofPerEl = 1; 03704 03705 if( *type == 1 ) 03706 { 03707 assert( gdsTag ); 03708 rval = context.MBI->get_entities_by_type( fset1, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 03709 dofValues.resize( ents_of_interest.size() * lenTagType1 ); 03710 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &dofValues[0] );MB_CHK_ERR( rval ); 03711 ndofPerEl = lenTagType1; 03712 } 03713 else if( *type == 2 ) 03714 { 03715 rval = context.MBI->get_entities_by_type( fset1, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 03716 dofValues.resize( ents_of_interest.size() ); 03717 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &dofValues[0] );MB_CHK_ERR( rval ); // just global ids 03718 } 03719 else if( *type == 3 ) // for FV meshes, just get the global id of cell 03720 { 03721 rval = context.MBI->get_entities_by_dimension( fset1, 2, ents_of_interest );MB_CHK_ERR( rval ); 03722 dofValues.resize( ents_of_interest.size() ); 03723 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &dofValues[0] );MB_CHK_ERR( rval ); // just global ids 03724 } 03725 else 03726 { 03727 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 or 3 03728 } 03729 // pass ordered dofs, and unique 03730 std::vector< int > orderDofs( dofValues.begin(), dofValues.end() ); 03731 03732 std::sort( orderDofs.begin(), orderDofs.end() ); 03733 orderDofs.erase( std::unique( orderDofs.begin(), orderDofs.end() ), orderDofs.end() ); // remove duplicates 03734 03735 rval = weightMap->ReadParallelMap( remap_weights_filename, orderDofs, row_based_partition );MB_CHK_ERR( rval ); 03736 03737 // if we are on target mesh (row based partition) 03738 if( row_based_partition ) 03739 { 03740 tdata.pid_dest = pid_cpl; 03741 tdata.remapper->SetMeshSet( Remapper::TargetMesh, fset1, ents_of_interest ); 03742 weightMap->SetDestinationNDofsPerElement( ndofPerEl ); 03743 weightMap->set_row_dc_dofs( dofValues ); // will set row_dtoc_dofmap 03744 } 03745 else 03746 { 03747 tdata.pid_src = pid_cpl; 03748 tdata.remapper->SetMeshSet( Remapper::SourceMesh, fset1, ents_of_interest ); 03749 weightMap->SetSourceNDofsPerElement( ndofPerEl ); 03750 weightMap->set_col_dc_dofs( dofValues ); // will set col_dtoc_dofmap 03751 } 03752 } 03753 else // old reader, trivial distribution by row 03754 { 03755 std::vector< int > tmp_owned_ids; // this will do a trivial row distribution 03756 rval = weightMap->ReadParallelMap( remap_weights_filename, tmp_owned_ids, row_based_partition );MB_CHK_ERR( rval ); 03757 } 03758 03759 return moab::MB_SUCCESS; 03760 } 03761 03762 ErrCode iMOAB_WriteMappingWeightsToFile( 03763 iMOAB_AppID pid_intersection, 03764 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 03765 const iMOAB_String remap_weights_filename ) 03766 { 03767 assert( solution_weights_identifier && strlen( solution_weights_identifier ) ); 03768 assert( remap_weights_filename && strlen( remap_weights_filename ) ); 03769 03770 ErrorCode rval; 03771 03772 // Get the source and target data and pcomm objects 03773 appData& data_intx = context.appDatas[*pid_intersection]; 03774 TempestMapAppData& tdata = data_intx.tempestData; 03775 03776 // Get the handle to the remapper object 03777 assert( tdata.remapper != NULL ); 03778 03779 // Now get online weights object and ensure it is valid 03780 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 03781 assert( weightMap != NULL ); 03782 03783 std::string filename = std::string( remap_weights_filename ); 03784 03785 // Write the map file to disk in parallel using either HDF5 or SCRIP interface 03786 rval = weightMap->WriteParallelMap( filename );MB_CHK_ERR( rval ); 03787 03788 return moab::MB_SUCCESS; 03789 } 03790 03791 #ifdef MOAB_HAVE_MPI 03792 ErrCode iMOAB_MigrateMapMesh( iMOAB_AppID pid1, 03793 iMOAB_AppID pid2, 03794 iMOAB_AppID pid3, 03795 MPI_Comm* jointcomm, 03796 MPI_Group* groupA, 03797 MPI_Group* groupB, 03798 int* type, 03799 int* comp1, 03800 int* comp2, 03801 int* direction ) 03802 { 03803 assert( jointcomm ); 03804 assert( groupA ); 03805 assert( groupB ); 03806 bool is_fortran = false; 03807 if( *pid1 >= 0 ) is_fortran = context.appDatas[*pid1].is_fortran || is_fortran; 03808 if( *pid2 >= 0 ) is_fortran = context.appDatas[*pid2].is_fortran || is_fortran; 03809 if( *pid3 >= 0 ) is_fortran = context.appDatas[*pid3].is_fortran || is_fortran; 03810 03811 MPI_Comm joint_communicator = 03812 ( is_fortran ? MPI_Comm_f2c( *reinterpret_cast< MPI_Fint* >( jointcomm ) ) : *jointcomm ); 03813 MPI_Group group_first = ( is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( groupA ) ) : *groupA ); 03814 MPI_Group group_second = ( is_fortran ? MPI_Group_f2c( *reinterpret_cast< MPI_Fint* >( groupB ) ) : *groupB ); 03815 03816 ErrorCode rval = MB_SUCCESS; 03817 int localRank = 0, numProcs = 1; 03818 03819 // Get the local rank and number of processes in the joint communicator 03820 MPI_Comm_rank( joint_communicator, &localRank ); 03821 MPI_Comm_size( joint_communicator, &numProcs ); 03822 03823 // Next instantiate the par comm graph 03824 // here we need to look at direction 03825 // this direction is good for atm source -> ocn target coupler example 03826 ParCommGraph* cgraph = NULL; 03827 if( *pid1 >= 0 ) cgraph = new ParCommGraph( joint_communicator, group_first, group_second, *comp1, *comp2 ); 03828 03829 ParCommGraph* cgraph_rev = NULL; 03830 if( *pid3 >= 0 ) cgraph_rev = new ParCommGraph( joint_communicator, group_second, group_first, *comp2, *comp1 ); 03831 03832 // we should search if we have another pcomm with the same comp ids in the list already 03833 // sort of check existing comm graphs in the map context.appDatas[*pid].pgraph 03834 if( *pid1 >= 0 ) context.appDatas[*pid1].pgraph[*comp2] = cgraph; // the context will be the other comp 03835 if( *pid3 >= 0 ) context.appDatas[*pid3].pgraph[*comp1] = cgraph_rev; // from 2 to 1 03836 03837 // each model has a list of global ids that will need to be sent by gs to rendezvous the other 03838 // model on the joint_communicator 03839 TupleList TLcomp1; 03840 TLcomp1.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 03841 TupleList TLcomp2; 03842 TLcomp2.initialize( 2, 0, 0, 0, 0 ); // to proc, marker 03843 03844 // will push_back a new tuple, if needed 03845 TLcomp1.enableWriteAccess(); 03846 03847 // tags of interest are either GLOBAL_DOFS or GLOBAL_ID 03848 Tag gdsTag; 03849 03850 // find the values on first cell 03851 int lenTagType1 = 1; 03852 if( *type == 1 ) 03853 { 03854 rval = context.MBI->tag_get_handle( "GLOBAL_DOFS", gdsTag );MB_CHK_ERR( rval ); 03855 rval = context.MBI->tag_get_length( gdsTag, lenTagType1 );MB_CHK_ERR( rval ); // usually it is 16 03856 } 03857 Tag tagType2 = context.MBI->globalId_tag(); 03858 03859 std::vector< int > valuesComp1; 03860 03861 // populate first tuple 03862 Range ents_of_interest; // will be filled with entities on pid1, that need to be distributed, 03863 // rearranged in split_ranges map 03864 if( *pid1 >= 0 ) 03865 { 03866 appData& data1 = context.appDatas[*pid1]; 03867 EntityHandle fset1 = data1.file_set; 03868 03869 if( *type == 1 ) 03870 { 03871 assert( gdsTag ); 03872 rval = context.MBI->get_entities_by_type( fset1, MBQUAD, ents_of_interest );MB_CHK_ERR( rval ); 03873 valuesComp1.resize( ents_of_interest.size() * lenTagType1 ); 03874 rval = context.MBI->tag_get_data( gdsTag, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); 03875 } 03876 else if( *type == 2 ) 03877 { 03878 rval = context.MBI->get_entities_by_type( fset1, MBVERTEX, ents_of_interest );MB_CHK_ERR( rval ); 03879 valuesComp1.resize( ents_of_interest.size() ); 03880 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 03881 } 03882 else if( *type == 3 ) // for FV meshes, just get the global id of cell 03883 { 03884 rval = context.MBI->get_entities_by_dimension( fset1, 2, ents_of_interest );MB_CHK_ERR( rval ); 03885 valuesComp1.resize( ents_of_interest.size() ); 03886 rval = context.MBI->tag_get_data( tagType2, ents_of_interest, &valuesComp1[0] );MB_CHK_ERR( rval ); // just global ids 03887 } 03888 else 03889 { 03890 MB_CHK_ERR( MB_FAILURE ); // we know only type 1 or 2 or 3 03891 } 03892 // now fill the tuple list with info and markers 03893 // because we will send only the ids, order and compress the list 03894 std::set< int > uniq( valuesComp1.begin(), valuesComp1.end() ); 03895 TLcomp1.resize( uniq.size() ); 03896 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 03897 { 03898 // to proc, marker, element local index, index in el 03899 int marker = *sit; 03900 int to_proc = marker % numProcs; 03901 int n = TLcomp1.get_n(); 03902 TLcomp1.vi_wr[2 * n] = to_proc; // send to processor 03903 TLcomp1.vi_wr[2 * n + 1] = marker; 03904 TLcomp1.inc_n(); 03905 } 03906 } 03907 03908 ProcConfig pc( joint_communicator ); // proc config does the crystal router 03909 pc.crystal_router()->gs_transfer( 1, TLcomp1, 03910 0 ); // communication towards joint tasks, with markers 03911 // sort by value (key 1) 03912 #ifdef VERBOSE 03913 std::stringstream ff1; 03914 ff1 << "TLcomp1_" << localRank << ".txt"; 03915 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 03916 #endif 03917 moab::TupleList::buffer sort_buffer; 03918 sort_buffer.buffer_init( TLcomp1.get_n() ); 03919 TLcomp1.sort( 1, &sort_buffer ); 03920 sort_buffer.reset(); 03921 #ifdef VERBOSE 03922 // after sorting 03923 TLcomp1.print_to_file( ff1.str().c_str() ); // it will append! 03924 #endif 03925 // do the same, for the other component, number2, with type2 03926 // start copy 03927 TLcomp2.enableWriteAccess(); 03928 03929 moab::TempestOnlineMap* weightMap = NULL; // declare it outside, but it will make sense only for *pid >= 0 03930 // we know that :) (or *pid2 >= 0, it means we are on the coupler PEs, read map exists, and coupler procs exist) 03931 // populate second tuple with ids from read map: we need row_gdofmap and col_gdofmap 03932 std::vector< int > valuesComp2; 03933 if( *pid2 >= 0 ) // we are now on coupler, map side 03934 { 03935 appData& data2 = context.appDatas[*pid2]; 03936 TempestMapAppData& tdata = data2.tempestData; 03937 // should be only one map, read from file 03938 assert( tdata.weightMaps.size() == 1 ); 03939 // maybe we need to check it is the map we expect 03940 weightMap = tdata.weightMaps.begin()->second; 03941 // std::vector<int> ids_of_interest; 03942 // do a deep copy of the ids of interest: row ids or col ids, target or source direction 03943 if( *direction == 1 ) 03944 { 03945 // we are interested in col ids, source 03946 // new method from moab::TempestOnlineMap 03947 rval = weightMap->fill_col_ids( valuesComp2 );MB_CHK_ERR( rval ); 03948 } 03949 else if( *direction == 2 ) 03950 { 03951 // we are interested in row ids, for target ids 03952 rval = weightMap->fill_row_ids( valuesComp2 );MB_CHK_ERR( rval ); 03953 } 03954 // 03955 03956 // now fill the tuple list with info and markers 03957 std::set< int > uniq( valuesComp2.begin(), valuesComp2.end() ); 03958 TLcomp2.resize( uniq.size() ); 03959 for( std::set< int >::iterator sit = uniq.begin(); sit != uniq.end(); sit++ ) 03960 { 03961 // to proc, marker, element local index, index in el 03962 int marker = *sit; 03963 int to_proc = marker % numProcs; 03964 int n = TLcomp2.get_n(); 03965 TLcomp2.vi_wr[2 * n] = to_proc; // send to processor 03966 TLcomp2.vi_wr[2 * n + 1] = marker; 03967 TLcomp2.inc_n(); 03968 } 03969 } 03970 pc.crystal_router()->gs_transfer( 1, TLcomp2, 03971 0 ); // communication towards joint tasks, with markers 03972 // sort by value (key 1) 03973 // in the rendez-vous approach, markers meet at meet point (rendez-vous) processor marker % nprocs 03974 #ifdef VERBOSE 03975 std::stringstream ff2; 03976 ff2 << "TLcomp2_" << localRank << ".txt"; 03977 TLcomp2.print_to_file( ff2.str().c_str() ); 03978 #endif 03979 sort_buffer.buffer_reserve( TLcomp2.get_n() ); 03980 TLcomp2.sort( 1, &sort_buffer ); 03981 sort_buffer.reset(); 03982 // end copy 03983 #ifdef VERBOSE 03984 TLcomp2.print_to_file( ff2.str().c_str() ); 03985 #endif 03986 // need to send back the info, from the rendezvous point, for each of the values 03987 /* so go over each value, on local process in joint communicator, 03988 03989 now have to send back the info needed for communication; 03990 loop in in sync over both TLComp1 and TLComp2, in local process; 03991 So, build new tuple lists, to send synchronous communication 03992 populate them at the same time, based on marker, that is indexed 03993 */ 03994 03995 TupleList TLBackToComp1; 03996 TLBackToComp1.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc on comp2, 03997 TLBackToComp1.enableWriteAccess(); 03998 03999 TupleList TLBackToComp2; 04000 TLBackToComp2.initialize( 3, 0, 0, 0, 0 ); // to proc, marker, from proc, 04001 TLBackToComp2.enableWriteAccess(); 04002 04003 int n1 = TLcomp1.get_n(); 04004 int n2 = TLcomp2.get_n(); 04005 04006 int indexInTLComp1 = 0; 04007 int indexInTLComp2 = 0; // advance both, according to the marker 04008 if( n1 > 0 && n2 > 0 ) 04009 { 04010 04011 while( indexInTLComp1 < n1 && indexInTLComp2 < n2 ) // if any is over, we are done 04012 { 04013 int currentValue1 = TLcomp1.vi_rd[2 * indexInTLComp1 + 1]; 04014 int currentValue2 = TLcomp2.vi_rd[2 * indexInTLComp2 + 1]; 04015 if( currentValue1 < currentValue2 ) 04016 { 04017 // we have a big problem; basically, we are saying that 04018 // dof currentValue is on one model and not on the other 04019 // std::cout << " currentValue1:" << currentValue1 << " missing in comp2" << "\n"; 04020 indexInTLComp1++; 04021 continue; 04022 } 04023 if( currentValue1 > currentValue2 ) 04024 { 04025 // std::cout << " currentValue2:" << currentValue2 << " missing in comp1" << "\n"; 04026 indexInTLComp2++; 04027 continue; 04028 } 04029 int size1 = 1; 04030 int size2 = 1; 04031 while( indexInTLComp1 + size1 < n1 && currentValue1 == TLcomp1.vi_rd[2 * ( indexInTLComp1 + size1 ) + 1] ) 04032 size1++; 04033 while( indexInTLComp2 + size2 < n2 && currentValue2 == TLcomp2.vi_rd[2 * ( indexInTLComp2 + size2 ) + 1] ) 04034 size2++; 04035 // must be found in both lists, find the start and end indices 04036 for( int i1 = 0; i1 < size1; i1++ ) 04037 { 04038 for( int i2 = 0; i2 < size2; i2++ ) 04039 { 04040 // send the info back to components 04041 int n = TLBackToComp1.get_n(); 04042 TLBackToComp1.reserve(); 04043 TLBackToComp1.vi_wr[3 * n] = 04044 TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // send back to the proc marker 04045 // came from, info from comp2 04046 TLBackToComp1.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 04047 TLBackToComp1.vi_wr[3 * n + 2] = TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // from proc on comp2 04048 n = TLBackToComp2.get_n(); 04049 TLBackToComp2.reserve(); 04050 TLBackToComp2.vi_wr[3 * n] = 04051 TLcomp2.vi_rd[2 * ( indexInTLComp2 + i2 )]; // send back info to original 04052 TLBackToComp2.vi_wr[3 * n + 1] = currentValue1; // initial value (resend?) 04053 TLBackToComp2.vi_wr[3 * n + 2] = TLcomp1.vi_rd[2 * ( indexInTLComp1 + i1 )]; // from proc on comp1 04054 // what if there are repeated markers in TLcomp2? increase just index2 04055 } 04056 } 04057 indexInTLComp1 += size1; 04058 indexInTLComp2 += size2; 04059 } 04060 } 04061 pc.crystal_router()->gs_transfer( 1, TLBackToComp1, 0 ); // communication towards original tasks, with info about 04062 pc.crystal_router()->gs_transfer( 1, TLBackToComp2, 0 ); 04063 04064 TupleList TLv; // vertices 04065 TupleList TLc; // cells if needed (not type 2) 04066 04067 if( *pid1 >= 0 ) 04068 { 04069 // we are on original comp 1 tasks 04070 // before ordering 04071 // now for each value in TLBackToComp1.vi_rd[3*i+1], on current proc, we know the 04072 // processors it communicates with 04073 #ifdef VERBOSE 04074 std::stringstream f1; 04075 f1 << "TLBack1_" << localRank << ".txt"; 04076 TLBackToComp1.print_to_file( f1.str().c_str() ); 04077 #endif 04078 // so we are now on pid1, we know now each marker were it has to go 04079 // add a new method to ParCommGraph, to set up the split_ranges and involved_IDs_map 04080 rval = cgraph->set_split_ranges( *comp1, TLBackToComp1, valuesComp1, lenTagType1, ents_of_interest, *type );MB_CHK_ERR( rval ); 04081 // we can just send vertices and elements, with crystal routers; 04082 // on the receiving end, make sure they are not duplicated, by looking at the global id 04083 // if *type is 1, also send global_dofs tag in the element tuple 04084 rval = cgraph->form_tuples_to_migrate_mesh( context.MBI, TLv, TLc, *type, lenTagType1 );MB_CHK_ERR( rval ); 04085 } 04086 else 04087 { 04088 TLv.initialize( 2, 0, 0, 3, 0 ); // no vertices here, for sure 04089 TLv.enableWriteAccess(); // to be able to receive stuff, even if nothing is here yet, on this task 04090 if( *type != 2 ) // for point cloud, we do not need to initialize TLc (for cells) 04091 { 04092 // we still need to initialize the tuples with the right size, as in form_tuples_to_migrate_mesh 04093 int size_tuple = 2 + ( ( *type != 1 ) ? 0 : lenTagType1 ) + 1 + 04094 10; // 10 is the max number of vertices in cell; kind of arbitrary 04095 TLc.initialize( size_tuple, 0, 0, 0, 0 ); 04096 TLc.enableWriteAccess(); 04097 } 04098 } 04099 pc.crystal_router()->gs_transfer( 1, TLv, 0 ); // communication towards coupler tasks, with mesh vertices 04100 if( *type != 2 ) pc.crystal_router()->gs_transfer( 1, TLc, 0 ); // those are cells 04101 04102 if( *pid3 >= 0 ) // will receive the mesh, on coupler pes! 04103 { 04104 appData& data3 = context.appDatas[*pid3]; 04105 EntityHandle fset3 = data3.file_set; 04106 Range primary_ents3; // vertices for type 2, cells of dim 2 for type 1 or 3 04107 std::vector< int > values_entities; // will be the size of primary_ents3 * lenTagType1 04108 rval = cgraph_rev->form_mesh_from_tuples( context.MBI, TLv, TLc, *type, lenTagType1, fset3, primary_ents3, 04109 values_entities );MB_CHK_ERR( rval ); 04110 iMOAB_UpdateMeshInfo( pid3 ); 04111 int ndofPerEl = 1; 04112 if( 1 == *type ) ndofPerEl = (int)( sqrt( lenTagType1 ) ); 04113 // because we are on the coupler, we know that the read map pid2 exists 04114 assert( *pid2 >= 0 ); 04115 appData& dataIntx = context.appDatas[*pid2]; 04116 TempestMapAppData& tdata = dataIntx.tempestData; 04117 04118 // if we are on source coverage, direction 1, we can set covering mesh, covering cells 04119 if( 1 == *direction ) 04120 { 04121 tdata.pid_src = pid3; 04122 tdata.remapper->SetMeshSet( Remapper::CoveringMesh, fset3, primary_ents3 ); 04123 weightMap->SetSourceNDofsPerElement( ndofPerEl ); 04124 weightMap->set_col_dc_dofs( values_entities ); // will set col_dtoc_dofmap 04125 } 04126 // if we are on target, we can set the target cells 04127 else 04128 { 04129 tdata.pid_dest = pid3; 04130 tdata.remapper->SetMeshSet( Remapper::TargetMesh, fset3, primary_ents3 ); 04131 weightMap->SetDestinationNDofsPerElement( ndofPerEl ); 04132 weightMap->set_row_dc_dofs( values_entities ); // will set row_dtoc_dofmap 04133 } 04134 } 04135 04136 return moab::MB_SUCCESS; 04137 } 04138 04139 #endif // #ifdef MOAB_HAVE_MPI 04140 04141 #endif // #ifdef MOAB_HAVE_NETCDF 04142 04143 #define USE_API 04144 static ErrCode ComputeSphereRadius( iMOAB_AppID pid, double* radius ) 04145 { 04146 ErrorCode rval; 04147 moab::CartVect pos; 04148 04149 Range& verts = context.appDatas[*pid].all_verts; 04150 moab::EntityHandle firstVertex = ( verts[0] ); 04151 04152 // coordinate data 04153 rval = context.MBI->get_coords( &( firstVertex ), 1, (double*)&( pos[0] ) );MB_CHK_ERR( rval ); 04154 04155 // compute the distance from origin 04156 // TODO: we could do this in a loop to verify if the pid represents a spherical mesh 04157 *radius = pos.length(); 04158 return moab::MB_SUCCESS; 04159 } 04160 04161 ErrCode iMOAB_ComputeMeshIntersectionOnSphere( iMOAB_AppID pid_src, iMOAB_AppID pid_tgt, iMOAB_AppID pid_intx ) 04162 { 04163 ErrorCode rval; 04164 ErrCode ierr; 04165 bool validate = true; 04166 04167 double radius_source = 1.0; 04168 double radius_target = 1.0; 04169 04170 const double epsrel = ReferenceTolerance; // ReferenceTolerance is defined in Defines.h in tempestremap source ; 04171 const double boxeps = 1.e-6; 04172 04173 // Get the source and target data and pcomm objects 04174 appData& data_src = context.appDatas[*pid_src]; 04175 appData& data_tgt = context.appDatas[*pid_tgt]; 04176 appData& data_intx = context.appDatas[*pid_intx]; 04177 #ifdef MOAB_HAVE_MPI 04178 ParallelComm* pco_intx = context.pcomms[*pid_intx]; 04179 #endif 04180 04181 // Mesh intersection has already been computed; Return early. 04182 TempestMapAppData& tdata = data_intx.tempestData; 04183 if( tdata.remapper != NULL ) return moab::MB_SUCCESS; // nothing to do 04184 04185 bool is_parallel = false, is_root = true; 04186 int rank = 0; 04187 #ifdef MOAB_HAVE_MPI 04188 if( pco_intx ) 04189 { 04190 rank = pco_intx->rank(); 04191 is_parallel = ( pco_intx->size() > 1 ); 04192 is_root = ( rank == 0 ); 04193 rval = pco_intx->check_all_shared_handles();MB_CHK_ERR( rval ); 04194 } 04195 #endif 04196 04197 moab::DebugOutput outputFormatter( std::cout, rank, 0 ); 04198 outputFormatter.set_prefix( "[iMOAB_ComputeMeshIntersectionOnSphere]: " ); 04199 04200 ierr = iMOAB_UpdateMeshInfo( pid_src );MB_CHK_ERR( ierr ); 04201 ierr = iMOAB_UpdateMeshInfo( pid_tgt );MB_CHK_ERR( ierr ); 04202 04203 // Rescale the radius of both to compute the intersection 04204 ComputeSphereRadius( pid_src, &radius_source ); 04205 ComputeSphereRadius( pid_tgt, &radius_target ); 04206 #ifdef VERBOSE 04207 if( is_root ) 04208 outputFormatter.printf( 0, "Radius of spheres: source = %12.14f, and target = %12.14f\n", radius_source, 04209 radius_target ); 04210 #endif 04211 04212 /* Let make sure that the radius match for source and target meshes. If not, rescale now and 04213 * unscale later. */ 04214 double defaultradius = 1.0; 04215 if( fabs( radius_source - radius_target ) > 1e-10 ) 04216 { /* the radii are different */ 04217 rval = IntxUtils::ScaleToRadius( context.MBI, data_src.file_set, defaultradius );MB_CHK_ERR( rval ); 04218 rval = IntxUtils::ScaleToRadius( context.MBI, data_tgt.file_set, defaultradius );MB_CHK_ERR( rval ); 04219 } 04220 04221 // Default area_method = lHuiller; Options: Girard, GaussQuadrature (if TR is available) 04222 #ifdef MOAB_HAVE_TEMPESTREMAP 04223 IntxAreaUtils areaAdaptor( IntxAreaUtils::GaussQuadrature ); 04224 #else 04225 IntxAreaUtils areaAdaptor( IntxAreaUtils::lHuiller ); 04226 #endif 04227 04228 // print verbosely about the problem setting 04229 bool use_kdtree_search = false; 04230 double srctgt_areas[2], srctgt_areas_glb[2]; 04231 { 04232 moab::Range rintxverts, rintxelems; 04233 rval = context.MBI->get_entities_by_dimension( data_src.file_set, 0, rintxverts );MB_CHK_ERR( rval ); 04234 rval = context.MBI->get_entities_by_dimension( data_src.file_set, data_src.dimension, rintxelems );MB_CHK_ERR( rval ); 04235 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_src.file_set );MB_CHK_ERR( rval ); 04236 rval = 04237 areaAdaptor.positive_orientation( context.MBI, data_src.file_set, defaultradius /*radius_source*/, rank );MB_CHK_ERR( rval ); 04238 srctgt_areas[0] = areaAdaptor.area_on_sphere( context.MBI, data_src.file_set, defaultradius /*radius_source*/ ); 04239 #ifdef VERBOSE 04240 if( is_root ) 04241 outputFormatter.printf( 0, "The red set contains %d vertices and %d elements \n", rintxverts.size(), 04242 rintxelems.size() ); 04243 #endif 04244 04245 moab::Range bintxverts, bintxelems; 04246 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, 0, bintxverts );MB_CHK_ERR( rval ); 04247 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, data_tgt.dimension, bintxelems );MB_CHK_ERR( rval ); 04248 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_tgt.file_set );MB_CHK_ERR( rval ); 04249 rval = 04250 areaAdaptor.positive_orientation( context.MBI, data_tgt.file_set, defaultradius /*radius_target*/, rank );MB_CHK_ERR( rval ); 04251 srctgt_areas[1] = areaAdaptor.area_on_sphere( context.MBI, data_tgt.file_set, defaultradius /*radius_target*/ ); 04252 #ifdef VERBOSE 04253 if( is_root ) 04254 outputFormatter.printf( 0, "The blue set contains %d vertices and %d elements \n", bintxverts.size(), 04255 bintxelems.size() ); 04256 #endif 04257 #ifdef MOAB_HAVE_MPI 04258 MPI_Allreduce( &srctgt_areas[0], &srctgt_areas_glb[0], 2, MPI_DOUBLE, MPI_SUM, pco_intx->comm() ); 04259 #else 04260 srctgt_areas_glb[0] = srctgt_areas[0]; 04261 srctgt_areas_glb[1] = srctgt_areas[1]; 04262 #endif 04263 use_kdtree_search = ( srctgt_areas_glb[0] < srctgt_areas_glb[1] ); 04264 } 04265 04266 data_intx.dimension = data_tgt.dimension; 04267 // set the context for the source and destination applications 04268 tdata.pid_src = pid_src; 04269 tdata.pid_dest = pid_tgt; 04270 04271 // Now allocate and initialize the remapper object 04272 #ifdef MOAB_HAVE_MPI 04273 tdata.remapper = new moab::TempestRemapper( context.MBI, pco_intx ); 04274 #else 04275 tdata.remapper = new moab::TempestRemapper( context.MBI ); 04276 #endif 04277 tdata.remapper->meshValidate = true; 04278 tdata.remapper->constructEdgeMap = true; 04279 04280 tdata.remapper->set_intx_name( data_intx.name ); 04281 // Do not create new filesets; Use the sets from our respective applications 04282 tdata.remapper->initialize( false ); 04283 tdata.remapper->GetMeshSet( moab::Remapper::SourceMesh ) = data_src.file_set; 04284 tdata.remapper->GetMeshSet( moab::Remapper::TargetMesh ) = data_tgt.file_set; 04285 tdata.remapper->GetMeshSet( moab::Remapper::OverlapMesh ) = data_intx.file_set; 04286 04287 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::SourceMesh );MB_CHK_ERR( rval ); 04288 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::TargetMesh );MB_CHK_ERR( rval ); 04289 04290 #ifdef VERBOSE_ZOLTAN_TIMINGS 04291 #ifdef MOAB_HAVE_MPI 04292 double t1; 04293 if( is_root ) t1 = MPI_Wtime(); 04294 #endif 04295 #endif 04296 // First, compute the covering source set. 04297 rval = tdata.remapper->ConstructCoveringSet( epsrel, 1.0, 1.0, boxeps, false );MB_CHK_ERR( rval ); 04298 #ifdef VERBOSE_ZOLTAN_TIMINGS 04299 #ifdef MOAB_HAVE_MPI 04300 double t2; 04301 if( is_root ) 04302 { 04303 t2 = MPI_Wtime(); 04304 std::cout << "[LOG] Time: coverage mesh:" << t2 - t1 << "\n"; 04305 } 04306 #endif 04307 #endif 04308 // Next, compute intersections with MOAB. 04309 rval = tdata.remapper->ComputeOverlapMesh( use_kdtree_search, false );MB_CHK_ERR( rval ); 04310 04311 // Mapping computation done 04312 if( validate ) 04313 { 04314 double local_area, 04315 global_areas[3]; // Array for Initial area, and through Method 1 and Method 2 04316 local_area = areaAdaptor.area_on_sphere( context.MBI, data_intx.file_set, radius_source, rank ); 04317 04318 global_areas[0] = srctgt_areas_glb[0]; 04319 global_areas[1] = srctgt_areas_glb[1]; 04320 04321 #ifdef MOAB_HAVE_MPI 04322 if( is_parallel ) 04323 { 04324 MPI_Reduce( &local_area, &global_areas[2], 1, MPI_DOUBLE, MPI_SUM, 0, pco_intx->comm() ); 04325 } 04326 else 04327 { 04328 global_areas[2] = local_area; 04329 } 04330 #else 04331 global_areas[2] = local_area; 04332 #endif 04333 if( is_root ) 04334 { 04335 outputFormatter.printf( 0, 04336 "initial area: source mesh = %12.14f, target mesh = %12.14f, " 04337 "overlap mesh = %12.14f\n", 04338 global_areas[0], global_areas[1], global_areas[2] ); 04339 outputFormatter.printf( 0, " relative error w.r.t source = %12.14e, and target = %12.14e\n", 04340 fabs( global_areas[0] - global_areas[2] ) / global_areas[0], 04341 fabs( global_areas[1] - global_areas[2] ) / global_areas[1] ); 04342 } 04343 } 04344 04345 return moab::MB_SUCCESS; 04346 } 04347 04348 ErrCode iMOAB_ComputePointDoFIntersection( iMOAB_AppID pid_src, iMOAB_AppID pid_tgt, iMOAB_AppID pid_intx ) 04349 { 04350 ErrorCode rval; 04351 ErrCode ierr; 04352 04353 double radius_source = 1.0; 04354 double radius_target = 1.0; 04355 04356 const double epsrel = ReferenceTolerance; // ReferenceTolerance is defined in Defines.h in tempestremap source ; 04357 const double boxeps = 1.e-8; 04358 04359 // Get the source and target data and pcomm objects 04360 appData& data_src = context.appDatas[*pid_src]; 04361 appData& data_tgt = context.appDatas[*pid_tgt]; 04362 appData& data_intx = context.appDatas[*pid_intx]; 04363 int rank = 0; 04364 #ifdef MOAB_HAVE_MPI 04365 ParallelComm* pco_intx = context.pcomms[*pid_intx]; 04366 rank = pco_intx->rank(); 04367 #endif 04368 04369 // Mesh intersection has already been computed; Return early. 04370 TempestMapAppData& tdata = data_intx.tempestData; 04371 if( tdata.remapper != NULL ) return moab::MB_SUCCESS; // nothing to do 04372 04373 #ifdef MOAB_HAVE_MPI 04374 if( pco_intx ) 04375 { 04376 rval = pco_intx->check_all_shared_handles();MB_CHK_ERR( rval ); 04377 } 04378 #endif 04379 04380 ierr = iMOAB_UpdateMeshInfo( pid_src );MB_CHK_ERR( ierr ); 04381 ierr = iMOAB_UpdateMeshInfo( pid_tgt );MB_CHK_ERR( ierr ); 04382 04383 // Rescale the radius of both to compute the intersection 04384 ComputeSphereRadius( pid_src, &radius_source ); 04385 ComputeSphereRadius( pid_tgt, &radius_target ); 04386 04387 IntxAreaUtils areaAdaptor; 04388 // print verbosely about the problem setting 04389 { 04390 moab::Range rintxverts, rintxelems; 04391 rval = context.MBI->get_entities_by_dimension( data_src.file_set, 0, rintxverts );MB_CHK_ERR( rval ); 04392 rval = context.MBI->get_entities_by_dimension( data_src.file_set, 2, rintxelems );MB_CHK_ERR( rval ); 04393 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_src.file_set );MB_CHK_ERR( rval ); 04394 rval = areaAdaptor.positive_orientation( context.MBI, data_src.file_set, radius_source, rank );MB_CHK_ERR( rval ); 04395 #ifdef VERBOSE 04396 std::cout << "The red set contains " << rintxverts.size() << " vertices and " << rintxelems.size() 04397 << " elements \n"; 04398 #endif 04399 04400 moab::Range bintxverts, bintxelems; 04401 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, 0, bintxverts );MB_CHK_ERR( rval ); 04402 rval = context.MBI->get_entities_by_dimension( data_tgt.file_set, 2, bintxelems );MB_CHK_ERR( rval ); 04403 rval = IntxUtils::fix_degenerate_quads( context.MBI, data_tgt.file_set );MB_CHK_ERR( rval ); 04404 rval = areaAdaptor.positive_orientation( context.MBI, data_tgt.file_set, radius_target, rank );MB_CHK_ERR( rval ); 04405 #ifdef VERBOSE 04406 std::cout << "The blue set contains " << bintxverts.size() << " vertices and " << bintxelems.size() 04407 << " elements \n"; 04408 #endif 04409 } 04410 04411 data_intx.dimension = data_tgt.dimension; 04412 // set the context for the source and destination applications 04413 // set the context for the source and destination applications 04414 tdata.pid_src = pid_src; 04415 tdata.pid_dest = pid_tgt; 04416 data_intx.point_cloud = ( data_src.point_cloud || data_tgt.point_cloud ); 04417 assert( data_intx.point_cloud == true ); 04418 04419 // Now allocate and initialize the remapper object 04420 #ifdef MOAB_HAVE_MPI 04421 tdata.remapper = new moab::TempestRemapper( context.MBI, pco_intx ); 04422 #else 04423 tdata.remapper = new moab::TempestRemapper( context.MBI ); 04424 #endif 04425 tdata.remapper->meshValidate = true; 04426 tdata.remapper->constructEdgeMap = true; 04427 04428 // Do not create new filesets; Use the sets from our respective applications 04429 tdata.remapper->initialize( false ); 04430 tdata.remapper->GetMeshSet( moab::Remapper::SourceMesh ) = data_src.file_set; 04431 tdata.remapper->GetMeshSet( moab::Remapper::TargetMesh ) = data_tgt.file_set; 04432 tdata.remapper->GetMeshSet( moab::Remapper::OverlapMesh ) = data_intx.file_set; 04433 04434 /* Let make sure that the radius match for source and target meshes. If not, rescale now and 04435 * unscale later. */ 04436 if( fabs( radius_source - radius_target ) > 1e-10 ) 04437 { /* the radii are different */ 04438 rval = IntxUtils::ScaleToRadius( context.MBI, data_src.file_set, 1.0 );MB_CHK_ERR( rval ); 04439 rval = IntxUtils::ScaleToRadius( context.MBI, data_tgt.file_set, 1.0 );MB_CHK_ERR( rval ); 04440 } 04441 04442 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::SourceMesh );MB_CHK_ERR( rval ); 04443 rval = tdata.remapper->ConvertMeshToTempest( moab::Remapper::TargetMesh );MB_CHK_ERR( rval ); 04444 04445 // First, compute the covering source set. 04446 rval = tdata.remapper->ConstructCoveringSet( epsrel, 1.0, 1.0, boxeps, false );MB_CHK_ERR( rval ); 04447 04448 #ifdef MOAB_HAVE_MPI 04449 /* VSM: This context should be set on the data_src but it would overwrite the source 04450 covering set context in case it is coupled to another APP as well. 04451 This needs a redesign. */ 04452 // data_intx.covering_set = tdata.remapper->GetCoveringSet(); 04453 // data_src.covering_set = tdata.remapper->GetCoveringSet(); 04454 #endif 04455 04456 // Now let us re-convert the MOAB mesh back to Tempest representation 04457 rval = tdata.remapper->ComputeGlobalLocalMaps();MB_CHK_ERR( rval ); 04458 04459 return moab::MB_SUCCESS; 04460 } 04461 04462 ErrCode iMOAB_ComputeScalarProjectionWeights( 04463 iMOAB_AppID pid_intx, 04464 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 04465 const iMOAB_String disc_method_source, 04466 int* disc_order_source, 04467 const iMOAB_String disc_method_target, 04468 int* disc_order_target, 04469 int* fNoBubble, 04470 int* fMonotoneTypeID, 04471 int* fVolumetric, 04472 int* fInverseDistanceMap, 04473 int* fNoConservation, 04474 int* fValidate, 04475 const iMOAB_String source_solution_tag_dof_name, 04476 const iMOAB_String target_solution_tag_dof_name ) 04477 { 04478 moab::ErrorCode rval; 04479 04480 assert( disc_order_source && disc_order_target && *disc_order_source > 0 && *disc_order_target > 0 ); 04481 assert( solution_weights_identifier && strlen( solution_weights_identifier ) ); 04482 assert( disc_method_source && strlen( disc_method_source ) ); 04483 assert( disc_method_target && strlen( disc_method_target ) ); 04484 assert( source_solution_tag_dof_name && strlen( source_solution_tag_dof_name ) ); 04485 assert( target_solution_tag_dof_name && strlen( target_solution_tag_dof_name ) ); 04486 04487 // Get the source and target data and pcomm objects 04488 appData& data_intx = context.appDatas[*pid_intx]; 04489 TempestMapAppData& tdata = data_intx.tempestData; 04490 04491 // Setup computation of weights 04492 // Set the context for the remapping weights computation 04493 tdata.weightMaps[std::string( solution_weights_identifier )] = new moab::TempestOnlineMap( tdata.remapper ); 04494 04495 // Call to generate the remap weights with the tempest meshes 04496 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 04497 assert( weightMap != NULL ); 04498 04499 GenerateOfflineMapAlgorithmOptions mapOptions; 04500 mapOptions.nPin = *disc_order_source; 04501 mapOptions.nPout = *disc_order_target; 04502 mapOptions.fSourceConcave = false; 04503 mapOptions.fTargetConcave = false; 04504 04505 mapOptions.strMethod = ""; 04506 if( fMonotoneTypeID ) 04507 { 04508 switch( *fMonotoneTypeID ) 04509 { 04510 case 0: 04511 mapOptions.fMonotone = false; 04512 break; 04513 case 3: 04514 mapOptions.strMethod += "mono3;"; 04515 break; 04516 case 2: 04517 mapOptions.strMethod += "mono2;"; 04518 break; 04519 default: 04520 mapOptions.fMonotone = true; 04521 } 04522 } 04523 else 04524 mapOptions.fMonotone = false; 04525 04526 mapOptions.fNoBubble = ( fNoBubble ? *fNoBubble : false ); 04527 mapOptions.fNoConservation = ( fNoConservation ? *fNoConservation > 0 : false ); 04528 mapOptions.fNoCorrectAreas = false; 04529 mapOptions.fNoCheck = !( fValidate ? *fValidate : true ); 04530 if( fVolumetric && *fVolumetric ) mapOptions.strMethod += "volumetric;"; 04531 if( fInverseDistanceMap && *fInverseDistanceMap ) mapOptions.strMethod += "invdist;"; 04532 04533 // Now let us compute the local-global mapping and store it in the context 04534 // We need this mapping when computing matvec products and to do reductions in parallel 04535 // Additionally, the call below will also compute weights with TempestRemap 04536 rval = weightMap->GenerateRemappingWeights( 04537 std::string( disc_method_source ), // const std::string& strInputType 04538 std::string( disc_method_target ), // const std::string& strOutputType 04539 mapOptions, // GenerateOfflineMapAlgorithmOptions& mapOptions 04540 std::string( source_solution_tag_dof_name ), // const std::string& srcDofTagName = "GLOBAL_ID" 04541 std::string( target_solution_tag_dof_name ) // const std::string& tgtDofTagName = "GLOBAL_ID" 04542 );MB_CHK_ERR( rval ); 04543 04544 return moab::MB_SUCCESS; 04545 } 04546 04547 ErrCode iMOAB_ApplyScalarProjectionWeights( 04548 iMOAB_AppID pid_intersection, 04549 const iMOAB_String solution_weights_identifier, /* "scalar", "flux", "custom" */ 04550 const iMOAB_String source_solution_tag_name, 04551 const iMOAB_String target_solution_tag_name ) 04552 { 04553 assert( solution_weights_identifier && strlen( solution_weights_identifier ) ); 04554 assert( source_solution_tag_name && strlen( source_solution_tag_name ) ); 04555 assert( target_solution_tag_name && strlen( target_solution_tag_name ) ); 04556 04557 moab::ErrorCode rval; 04558 04559 // Get the source and target data and pcomm objects 04560 appData& data_intx = context.appDatas[*pid_intersection]; 04561 TempestMapAppData& tdata = data_intx.tempestData; 04562 04563 // Now allocate and initialize the remapper object 04564 moab::TempestRemapper* remapper = tdata.remapper; 04565 moab::TempestOnlineMap* weightMap = tdata.weightMaps[std::string( solution_weights_identifier )]; 04566 04567 // we assume that there are separators ";" between the tag names 04568 std::vector< std::string > srcNames; 04569 std::vector< std::string > tgtNames; 04570 std::vector< Tag > srcTagHandles; 04571 std::vector< Tag > tgtTagHandles; 04572 std::string separator( ":" ); 04573 std::string src_name( source_solution_tag_name ); 04574 std::string tgt_name( target_solution_tag_name ); 04575 split_tag_names( src_name, separator, srcNames ); 04576 split_tag_names( tgt_name, separator, tgtNames ); 04577 if( srcNames.size() != tgtNames.size() ) 04578 { 04579 std::cout << " error in parsing source and target tag names. \n"; 04580 return moab::MB_FAILURE; 04581 } 04582 04583 for( size_t i = 0; i < srcNames.size(); i++ ) 04584 { 04585 Tag tagHandle; 04586 rval = context.MBI->tag_get_handle( srcNames[i].c_str(), tagHandle ); 04587 if( MB_SUCCESS != rval || NULL == tagHandle ) 04588 { 04589 return moab::MB_FAILURE; 04590 } 04591 srcTagHandles.push_back( tagHandle ); 04592 rval = context.MBI->tag_get_handle( tgtNames[i].c_str(), tagHandle ); 04593 if( MB_SUCCESS != rval || NULL == tagHandle ) 04594 { 04595 return moab::MB_FAILURE; 04596 } 04597 tgtTagHandles.push_back( tagHandle ); 04598 } 04599 04600 std::vector< double > solSTagVals; 04601 std::vector< double > solTTagVals; 04602 04603 moab::Range sents, tents; 04604 if( data_intx.point_cloud ) 04605 { 04606 appData& data_src = context.appDatas[*tdata.pid_src]; 04607 appData& data_tgt = context.appDatas[*tdata.pid_dest]; 04608 if( data_src.point_cloud ) 04609 { 04610 moab::Range& covSrcEnts = remapper->GetMeshVertices( moab::Remapper::CoveringMesh ); 04611 solSTagVals.resize( covSrcEnts.size(), -1.0 ); 04612 sents = covSrcEnts; 04613 } 04614 else 04615 { 04616 moab::Range& covSrcEnts = remapper->GetMeshEntities( moab::Remapper::CoveringMesh ); 04617 solSTagVals.resize( covSrcEnts.size() * weightMap->GetSourceNDofsPerElement() * 04618 weightMap->GetSourceNDofsPerElement(), 04619 -1.0 ); 04620 sents = covSrcEnts; 04621 } 04622 if( data_tgt.point_cloud ) 04623 { 04624 moab::Range& tgtEnts = remapper->GetMeshVertices( moab::Remapper::TargetMesh ); 04625 solTTagVals.resize( tgtEnts.size(), -1.0 ); 04626 tents = tgtEnts; 04627 } 04628 else 04629 { 04630 moab::Range& tgtEnts = remapper->GetMeshEntities( moab::Remapper::TargetMesh ); 04631 solTTagVals.resize( tgtEnts.size() * weightMap->GetDestinationNDofsPerElement() * 04632 weightMap->GetDestinationNDofsPerElement(), 04633 -1.0 ); 04634 tents = tgtEnts; 04635 } 04636 } 04637 else 04638 { 04639 moab::Range& covSrcEnts = remapper->GetMeshEntities( moab::Remapper::CoveringMesh ); 04640 moab::Range& tgtEnts = remapper->GetMeshEntities( moab::Remapper::TargetMesh ); 04641 solSTagVals.resize( 04642 covSrcEnts.size() * weightMap->GetSourceNDofsPerElement() * weightMap->GetSourceNDofsPerElement(), -1.0 ); 04643 solTTagVals.resize( tgtEnts.size() * weightMap->GetDestinationNDofsPerElement() * 04644 weightMap->GetDestinationNDofsPerElement(), 04645 -1.0 ); 04646 04647 sents = covSrcEnts; 04648 tents = tgtEnts; 04649 } 04650 04651 for( size_t i = 0; i < srcTagHandles.size(); i++ ) 04652 { 04653 // The tag data is np*np*n_el_src 04654 Tag ssolnTag = srcTagHandles[i]; 04655 Tag tsolnTag = tgtTagHandles[i]; 04656 rval = context.MBI->tag_get_data( ssolnTag, sents, &solSTagVals[0] );MB_CHK_ERR( rval ); 04657 04658 // Compute the application of weights on the suorce solution data and store it in the 04659 // destination solution vector data Optionally, can also perform the transpose application 04660 // of the weight matrix. Set the 3rd argument to true if this is needed 04661 rval = weightMap->ApplyWeights( solSTagVals, solTTagVals, false );MB_CHK_ERR( rval ); 04662 04663 // The tag data is np*np*n_el_dest 04664 rval = context.MBI->tag_set_data( tsolnTag, tents, &solTTagVals[0] );MB_CHK_ERR( rval ); 04665 } 04666 04667 // #define VERBOSE 04668 #ifdef VERBOSE 04669 ParallelComm* pco_intx = context.pcomms[*pid_intersection]; 04670 04671 int ivar = 0; 04672 { 04673 Tag ssolnTag = srcTagHandles[ivar]; 04674 std::stringstream sstr; 04675 sstr << "covsrcTagData_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".txt"; 04676 std::ofstream output_file( sstr.str().c_str() ); 04677 for( unsigned i = 0; i < sents.size(); ++i ) 04678 { 04679 EntityHandle elem = sents[i]; 04680 std::vector< double > locsolSTagVals( 16 ); 04681 rval = context.MBI->tag_get_data( ssolnTag, &elem, 1, &locsolSTagVals[0] );MB_CHK_ERR( rval ); 04682 output_file << "\n" << remapper->GetGlobalID( Remapper::CoveringMesh, i ) << "-- \n\t"; 04683 for( unsigned j = 0; j < 16; ++j ) 04684 output_file << locsolSTagVals[j] << " "; 04685 } 04686 output_file.flush(); // required here 04687 output_file.close(); 04688 } 04689 { 04690 std::stringstream sstr; 04691 sstr << "outputSrcDest_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".h5m"; 04692 EntityHandle sets[2] = {context.appDatas[*tdata.pid_src].file_set, context.appDatas[*tdata.pid_dest].file_set}; 04693 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", sets, 2 );MB_CHK_ERR( rval ); 04694 } 04695 { 04696 std::stringstream sstr; 04697 sstr << "outputCovSrcDest_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".h5m"; 04698 // EntityHandle sets[2] = {data_intx.file_set, data_intx.covering_set}; 04699 EntityHandle covering_set = remapper->GetCoveringSet(); 04700 EntityHandle sets[2] = {covering_set, context.appDatas[*tdata.pid_dest].file_set}; 04701 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", sets, 2 );MB_CHK_ERR( rval ); 04702 } 04703 { 04704 std::stringstream sstr; 04705 sstr << "covMesh_" << *pid_intersection << "_" << pco_intx->rank() << ".vtk"; 04706 // EntityHandle sets[2] = {data_intx.file_set, data_intx.covering_set}; 04707 EntityHandle covering_set = remapper->GetCoveringSet(); 04708 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", &covering_set, 1 );MB_CHK_ERR( rval ); 04709 } 04710 { 04711 std::stringstream sstr; 04712 sstr << "tgtMesh_" << *pid_intersection << "_" << pco_intx->rank() << ".vtk"; 04713 // EntityHandle sets[2] = {data_intx.file_set, data_intx.covering_set}; 04714 EntityHandle target_set = remapper->GetMeshSet( Remapper::TargetMesh ); 04715 rval = context.MBI->write_file( sstr.str().c_str(), NULL, "", &target_set, 1 );MB_CHK_ERR( rval ); 04716 } 04717 { 04718 std::stringstream sstr; 04719 sstr << "colvector_" << *pid_intersection << "_" << ivar << "_" << pco_intx->rank() << ".txt"; 04720 std::ofstream output_file( sstr.str().c_str() ); 04721 for( unsigned i = 0; i < solSTagVals.size(); ++i ) 04722 output_file << i << " " << weightMap->col_dofmap[i] << " " << weightMap->col_gdofmap[i] << " " 04723 << solSTagVals[i] << "\n"; 04724 output_file.flush(); // required here 04725 output_file.close(); 04726 } 04727 #endif 04728 // #undef VERBOSE 04729 04730 return moab::MB_SUCCESS; 04731 } 04732 04733 #endif // MOAB_HAVE_TEMPESTREMAP 04734 04735 #ifdef __cplusplus 04736 } 04737 #endif
