Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * normals.cpp 00003 * 00004 * Created on: Oct 30, 2015 00005 * will take an occ model and compute normals at all vertices, using exact geometry info 00006 */ 00007 00008 #include "iGeom.h" 00009 #include "iMesh.h" 00010 #include "iRel.h" 00011 00012 #include <cstdio> 00013 #include <cstdlib> 00014 #include <cstring> 00015 00016 #include "MBiMesh.hpp" 00017 #include "moab/Core.hpp" 00018 00019 #define STRINGIFY_( X ) #X 00020 #define STRINGIFY( X ) STRINGIFY_( X ) 00021 #ifdef MESHDIR 00022 #ifdef HAVE_OCC 00023 #define DEFAULT_GEOM STRINGIFY( MESHDIR / irel / cyl2.stp ) 00024 #define DEFAULT_MESH STRINGIFY( MESHDIR / irel / cyl2.h5m ) 00025 #else 00026 #define DEFAULT_GEOM STRINGIFY( MESHDIR / irel / brick.facet ) 00027 #define DEFAULT_MESH STRINGIFY( MESHDIR / irel / brick.h5m ) 00028 #endif 00029 #endif 00030 00031 #define CHECK_SIZE_C( type, array, allocated_size, size ) \ 00032 if( NULL == *( array ) || *( allocated_size ) == 0 ) \ 00033 { \ 00034 *( array ) = (type*)malloc( sizeof( type ) * ( size ) ); \ 00035 *( allocated_size ) = size; \ 00036 } \ 00037 else if( *( allocated_size ) < ( size ) ) \ 00038 { \ 00039 printf( " Array passed in is non-zero but too short.\n" ); \ 00040 } 00041 00042 typedef void* iRel_EntityHandle; 00043 00044 int print_geom_info( iGeom_Instance geom, iBase_EntityHandle gent ) 00045 { 00046 /* print information about this entity */ 00047 int ent_type; 00048 int result; 00049 const char* type_names[] = { "Vertex", "Edge", "Face", "Region" }; 00050 00051 iGeom_getEntType( geom, gent, &ent_type, &result ); 00052 00053 if( iBase_SUCCESS != result ) 00054 { 00055 printf( "Trouble getting entity adjacencies or types." ); 00056 return 0; 00057 } 00058 00059 printf( "%s 0x%lx\n", type_names[ent_type], (unsigned long)gent ); 00060 00061 return 1; 00062 } 00063 00064 int print_mesh_info( iMesh_Instance mesh, iBase_EntityHandle ment ) 00065 { 00066 /* print information about this entity */ 00067 00068 /* get adjacencies first; assume not more than 50 */ 00069 iBase_EntityHandle adj_ents[500], *adj_ents_ptr = adj_ents; 00070 int ent_types[500], *ent_types_ptr = ent_types; 00071 int adj_ents_alloc = 500, adj_ents_size, ent_types_size, ent_types_allocated = 500; 00072 int result; 00073 00074 iBase_TagHandle* ment_tags = NULL; 00075 int ment_tags_size, ment_tags_alloc; 00076 00077 char** tag_names; 00078 int i; 00079 00080 const char* type_names[] = { "Vertex", "Edge", "Face", "Region" }; 00081 00082 iMesh_getEntAdj( mesh, ment, iBase_ALL_TYPES, &adj_ents_ptr, &adj_ents_alloc, &adj_ents_size, &result ); 00083 00084 if( iBase_SUCCESS != result ) return 0; 00085 00086 /* put this ent on the end, then get types */ 00087 adj_ents[adj_ents_size] = ment; 00088 iMesh_getEntArrType( mesh, adj_ents, adj_ents_size + 1, &ent_types_ptr, &ent_types_allocated, &ent_types_size, 00089 &result ); 00090 if( iBase_SUCCESS != result ) 00091 { 00092 printf( "Trouble getting entity adjacencies or types." ); 00093 return 0; 00094 } 00095 00096 /* get tags on ment */ 00097 iMesh_getAllTags( mesh, ment, &ment_tags, &ment_tags_alloc, &ment_tags_size, &result ); 00098 00099 printf( "Trouble getting tags on an entity or their names." ); 00100 00101 /* while we're at it, get all the tag names */ 00102 00103 tag_names = (char**)malloc( ment_tags_size * sizeof( char* ) ); 00104 00105 for( i = 0; i < ment_tags_size; i++ ) 00106 { 00107 tag_names[i] = (char*)malloc( 120 * sizeof( char ) ); 00108 iMesh_getTagName( mesh, ment_tags[i], tag_names[i], &result, 120 ); 00109 } 00110 00111 /* now print the information */ 00112 printf( "%s %ld:\n", type_names[ent_types[ent_types_size - 1]], (long)ment ); 00113 printf( "Adjacencies:" ); 00114 for( i = 0; i < adj_ents_size; i++ ) 00115 { 00116 if( i > 0 ) printf( ", " ); 00117 printf( "%s %ld", type_names[ent_types[i]], (long)adj_ents[i] ); 00118 } 00119 printf( "\nTags: \n" ); 00120 for( i = 0; i < ment_tags_size; i++ ) 00121 { 00122 int tag_type; 00123 00124 printf( "%s ", tag_names[i] ); 00125 iMesh_getTagType( mesh, ment_tags[i], &tag_type, &result ); 00126 if( iBase_SUCCESS != result ) 00127 printf( "(trouble getting type...)\n" ); 00128 else 00129 { 00130 char* dum_handle = NULL; 00131 int dum_handle_alloc = 0, dum_handle_size = 0; 00132 int int_data; 00133 double dbl_data; 00134 iBase_EntityHandle eh_data; 00135 00136 switch( tag_type ) 00137 { 00138 case iBase_INTEGER: 00139 iMesh_getIntData( mesh, ment, ment_tags[i], &int_data, &result ); 00140 printf( "(Int value=%d)", int_data ); 00141 break; 00142 case iBase_DOUBLE: 00143 iMesh_getDblData( mesh, ment, ment_tags[i], &dbl_data, &result ); 00144 printf( "(Dbl value=%f)", dbl_data ); 00145 break; 00146 case iBase_ENTITY_HANDLE: 00147 iMesh_getEHData( mesh, ment, ment_tags[i], &eh_data, &result ); 00148 printf( "(EH value=%ld)", (long)eh_data ); 00149 break; 00150 case iBase_BYTES: 00151 iMesh_getData( mesh, ment, ment_tags[i], (void**)&dum_handle, &dum_handle_alloc, &dum_handle_size, 00152 &result ); 00153 if( NULL != dum_handle && dum_handle_size > 0 ) printf( "(Opaque value=%c)", dum_handle[0] ); 00154 break; 00155 } 00156 } 00157 00158 printf( "\n" ); 00159 } 00160 printf( "(end tags)\n\n" ); 00161 free( ment_tags ); 00162 00163 return 1; 00164 } 00165 00166 /*! 00167 @li Load a geom and a mesh file 00168 */ 00169 int load_geom_mesh( const char* geom_filename, const char* mesh_filename, iGeom_Instance geom, iMesh_Instance mesh ) 00170 { 00171 /* load a geom */ 00172 int result; 00173 iGeom_load( geom, geom_filename, 0, &result, strlen( geom_filename ), 0 ); 00174 if( iBase_SUCCESS != result ) 00175 { 00176 printf( "ERROR : can not load a geometry\n" ); 00177 return 0; 00178 } 00179 00180 /* load a mesh */ 00181 iMesh_load( mesh, 0, mesh_filename, 0, &result, strlen( mesh_filename ), 0 ); 00182 if( iBase_SUCCESS != result ) 00183 { 00184 printf( "ERROR : can not load a mesh\n" ); 00185 return 0; 00186 } 00187 00188 return 1; 00189 } 00190 00191 /*! 00192 00193 @li Create relation between geom and mesh 00194 */ 00195 int create_relation( iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle* pair ) 00196 { 00197 int result; 00198 iBase_Instance iface1, iface2; 00199 int type1, type2; 00200 int ent_or_set1, ent_or_set2; 00201 int status1, status2; 00202 00203 iRel_PairHandle tmp_pair; 00204 iRel_PairHandle* pair_ptr = &tmp_pair; 00205 int pairs_alloc = 1, pairs_size; 00206 00207 /* create an relation, entity to set */ 00208 iRel_createPair( assoc, geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE, mesh, iRel_SET, iRel_IMESH_IFACE, 00209 iRel_ACTIVE, pair, &result ); 00210 if( iBase_SUCCESS != result ) 00211 { 00212 printf( "Couldn't create a new relation.\n" ); 00213 return 0; 00214 } 00215 00216 iRel_getPairInfo( assoc, *pair, &iface1, &ent_or_set1, &type1, &status1, &iface2, &ent_or_set2, &type2, &status2, 00217 &result ); 00218 if( iBase_SUCCESS != result ) 00219 { 00220 printf( "Couldn't retrieve relation info.\n" ); 00221 return 0; 00222 } 00223 if( iface1 != geom || ent_or_set1 != iRel_ENTITY || type1 != iRel_IGEOM_IFACE || iface2 != mesh || 00224 ent_or_set2 != iRel_SET || type2 != iRel_IMESH_IFACE ) 00225 { 00226 printf( "Unexpected relation info returned.\n" ); 00227 return 0; 00228 } 00229 00230 iRel_findPairs( assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result ); 00231 if( iBase_SUCCESS != result ) 00232 { 00233 printf( "Couldn't find relation pair when querying geom.\n" ); 00234 return 0; 00235 } 00236 if( pairs_size != 1 || tmp_pair != *pair ) 00237 { 00238 printf( "Unexpected relation pairs returned when querying geom.\n" ); 00239 return 0; 00240 } 00241 00242 iRel_findPairs( assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result ); 00243 if( iBase_SUCCESS != result ) 00244 { 00245 printf( "Couldn't find relation pair when querying mesh.\n" ); 00246 return 0; 00247 } 00248 if( pairs_size != 1 || tmp_pair != *pair ) 00249 { 00250 printf( "Unexpected relation pairs returned when querying mesh.\n" ); 00251 return 0; 00252 } 00253 00254 return 1; 00255 } 00256 00257 /*! 00258 @li Check relation between geom and mesh 00259 */ 00260 int relate_geom_mesh( iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair ) 00261 { 00262 int result; 00263 00264 iBase_EntityHandle* gentities = NULL; 00265 int gentities_size = 0, gentities_alloc = 0; 00266 00267 iBase_EntitySetHandle* mentity_handles = NULL; 00268 int mentity_handles_size = 0, mentity_handles_alloc = 0; 00269 00270 const char* dim_tag_name = "GEOM_DIMENSION"; 00271 iBase_TagHandle dim_tag_mesh; 00272 00273 iBase_EntitySetHandle* mentities_vec; 00274 int mentities_vec_size = 0; 00275 int i; 00276 00277 iBase_EntitySetHandle* out_mentities = NULL; 00278 int out_mentities_size = 0, out_mentities_alloc = 0; 00279 00280 iBase_EntitySetHandle* out_mentities2 = NULL; 00281 int out_mentities2_size = 0, out_mentities2_alloc = 0; 00282 00283 iBase_EntityHandle* out_gentities = NULL; 00284 int out_gentities_size = 0, out_gentities_alloc = 0; 00285 00286 /* relate geometry entities with coresponding mesh entity sets */ 00287 iGeom_getEntities( geom, NULL, iBase_VERTEX, &gentities, &gentities_alloc, &gentities_size, &result ); 00288 if( iBase_SUCCESS != result ) 00289 { 00290 printf( "Failed to get gentities by type in relate_geom_mesh.\n" ); 00291 return 0; 00292 } 00293 00294 iRel_inferEntArrRelations( assoc, pair, gentities, gentities_size, 0, &result ); 00295 if( iBase_SUCCESS != result ) 00296 { 00297 printf( "Failed to relate geom entities in relate_geom_mesh.\n" ); 00298 return 0; 00299 } 00300 00301 /* relate coresponding mesh entity sets for geometry entities */ 00302 /* get 1-dimensional mesh entitysets */ 00303 iMesh_getEntSets( mesh, NULL, 1, &mentity_handles, &mentity_handles_alloc, &mentity_handles_size, &result ); 00304 if( iBase_SUCCESS != result ) 00305 { 00306 printf( "Problem to get all entity sets.\n" ); 00307 return 0; 00308 } 00309 00310 /* get geom dimension tags for mesh entitysets */ 00311 iMesh_createTag( mesh, dim_tag_name, 1, iBase_INTEGER, &dim_tag_mesh, &result, 15 ); 00312 if( iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS ) 00313 { 00314 printf( "Couldn't create geom dim tag for mesh entities.\n" ); 00315 return 0; 00316 } 00317 00318 /* get 1-dimensional mesh entitysets */ 00319 mentities_vec = (iBase_EntitySetHandle*)malloc( mentity_handles_size * sizeof( iBase_EntitySetHandle ) ); 00320 for( i = 0; i < mentity_handles_size; i++ ) 00321 { /* test */ 00322 int dim; 00323 iMesh_getEntSetIntData( mesh, mentity_handles[i], dim_tag_mesh, &dim, &result ); 00324 if( iBase_SUCCESS != result ) continue; 00325 00326 if( dim == 1 ) mentities_vec[mentities_vec_size++] = mentity_handles[i]; 00327 } 00328 00329 iRel_inferSetArrRelations( assoc, pair, mentities_vec, mentities_vec_size, 1, &result ); 00330 if( iBase_SUCCESS != result ) 00331 { 00332 printf( "Failed to relate mesh entities in relate_geom_mesh.\n" ); 00333 return 0; 00334 } 00335 00336 /* relate all geometry and mesh entities */ 00337 iRel_inferAllRelations( assoc, pair, &result ); 00338 if( iBase_SUCCESS != result ) 00339 { 00340 printf( "Failed to relate all geom and mesh entities in relate_geom_mesh.\n" ); 00341 return 0; 00342 } 00343 00344 /* reset geom entities list and get all geom entities (prev 00345 only vertices) */ 00346 free( gentities ); 00347 gentities = NULL; 00348 gentities_alloc = 0; 00349 iGeom_getEntities( geom, NULL, iBase_ALL_TYPES, &gentities, &gentities_alloc, &gentities_size, &result ); 00350 if( iBase_SUCCESS != result ) 00351 { 00352 printf( "Failed to get gentities by type in relate_geom_mesh.\n" ); 00353 return 0; 00354 } 00355 00356 /* get related mesh entity sets for geometry entities */ 00357 iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc, 00358 &out_mentities_size, &result ); 00359 if( iBase_SUCCESS != result ) 00360 { 00361 printf( "Failed to get geom entities in relate_geom_mesh.\n" ); 00362 return 0; 00363 } 00364 00365 if( out_mentities_size != gentities_size ) 00366 { 00367 printf( "Number of input geom entities and output mesh entity sets should be same\n" ); 00368 return 0; 00369 } 00370 00371 /* now try deleting this relation */ 00372 iRel_rmvEntArrRelation( assoc, pair, gentities, gentities_size, 0, &result ); 00373 if( iBase_SUCCESS != result ) 00374 { 00375 printf( "Failed to remove relation in relate_geom_mesh.\n" ); 00376 return 0; 00377 } 00378 00379 iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities2, &out_mentities2_alloc, 00380 &out_mentities2_size, &result ); 00381 if( iBase_SUCCESS == result ) 00382 { 00383 printf( "Shouldn't have gotten mesh sets in relate_geom_mesh.\n" ); 00384 return 0; 00385 } 00386 00387 /* restore the relation, since we need it later */ 00388 iRel_setEntArrSetArrRelation( assoc, pair, gentities, gentities_size, out_mentities, out_mentities_size, &result ); 00389 if( iBase_SUCCESS != result ) 00390 { 00391 printf( "Failed to restore relation in relate_geom_mesh.\n" ); 00392 return 0; 00393 } 00394 00395 /* get related geometry entities for mesh entity sets */ 00396 iRel_getSetArrEntArrRelation( assoc, pair, out_mentities, out_mentities_size, 1, &out_gentities, 00397 &out_gentities_alloc, &out_gentities_size, &result ); 00398 if( iBase_SUCCESS != result ) 00399 { 00400 printf( "Failed to get mesh entities in relate_geom_mesh.\n" ); 00401 return 0; 00402 } 00403 00404 if( out_mentities_size != out_gentities_size ) 00405 { 00406 printf( "Number of input mesh entity sets and output geom entities should be same\n" ); 00407 return 0; 00408 } 00409 free( mentity_handles ); 00410 mentity_handles = NULL; 00411 free( gentities ); 00412 gentities = NULL; 00413 free( mentity_handles ); 00414 mentity_handles = NULL; 00415 free( out_mentities ); 00416 out_mentities = NULL; 00417 free( mentities_vec ); 00418 mentities_vec = NULL; 00419 free( out_gentities ); 00420 out_gentities = NULL; 00421 return 1; 00422 } 00423 00424 /*! 00425 @li compute normals onto the given geometry 00426 */ 00427 int compute_normals( iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair ) 00428 { 00429 int result; 00430 int i; 00431 00432 iBase_EntityHandle* gentities = NULL; 00433 int gentities_size = 0, gentities_alloc = 0; 00434 00435 iBase_EntitySetHandle* out_mentities = NULL; 00436 int out_mentities_size, out_mentities_alloc = 0; 00437 00438 /* get all the face geo entities, and find relation to some mesh entity */ 00439 iGeom_getEntities( geom, NULL, iBase_FACE, &gentities, &gentities_alloc, &gentities_size, &result ); 00440 if( iBase_SUCCESS != result ) 00441 { 00442 printf( "Problem getting all geom entities.\n" ); 00443 return 0; 00444 } 00445 for( i = 0; i < gentities_size; i++ ) 00446 { 00447 print_geom_info( geom, gentities[i] ); 00448 } 00449 00450 iRel_getEntArrSetArrRelation( assoc, pair, gentities, gentities_size, 0, &out_mentities, &out_mentities_alloc, 00451 &out_mentities_size, &result ); 00452 /* might not all be */ 00453 if( iBase_SUCCESS != result ) 00454 { 00455 printf( "Failed to get mesh entities related to geom entities in compute_normals.\n" ); 00456 return 0; 00457 } 00458 00459 /* check that they're all non-null */ 00460 if( out_mentities_size != gentities_size ) 00461 { 00462 printf( "Number of mesh & related geom entities don't match.\n" ); 00463 return 0; 00464 } 00465 00466 /* check to make sure they're mesh sets; how to do that? */ 00467 for( i = 0; i < out_mentities_size; i++ ) 00468 { 00469 int is_list; 00470 iMesh_isList( mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result ); 00471 if( iBase_SUCCESS != result ) 00472 { 00473 printf( "Entity set returned from classification wasn't valid.\n" ); 00474 return 0; 00475 } 00476 } 00477 00478 moab::Interface* mb = reinterpret_cast< MBiMesh* >( mesh )->mbImpl; 00479 if( !mb ) return 0; 00480 moab::ErrorCode rval = MB_SUCCESS; 00481 00482 moab::Tag idtag; 00483 rval = mb->tag_get_handle( "GLOBAL_ID", idtag ); 00484 if( MB_SUCCESS != rval ) return 0; 00485 00486 for( i = 0; i < gentities_size; i++ ) 00487 { 00488 00489 EntityHandle meshSet = (EntityHandle)out_mentities[i]; 00490 Range faces; 00491 rval = mb->get_entities_by_dimension( meshSet, 2, faces ); // MB_CHK_ERR(rval); 00492 00493 Range vertices; 00494 rval = mb->get_connectivity( faces, vertices ); 00495 00496 std::vector< double > coords; 00497 coords.resize( vertices.size() * 3 ); 00498 rval = mb->get_coords( vertices, &coords[0] ); 00499 00500 int id; 00501 rval = mb->tag_get_data( idtag, &meshSet, 1, &id ); 00502 printf( "surface %d has %d faces and %d vertices \n", id, (int)faces.size(), (int)vertices.size() ); 00503 00504 std::vector< double > normals; 00505 normals.resize( 3 * vertices.size() ); 00506 00507 std::vector< double > on_coordinates; 00508 on_coordinates.resize( 3 * vertices.size() ); 00509 00510 for( int j = 0; j < (int)vertices.size(); j++ ) 00511 { 00512 iGeom_getEntNrmlXYZ( geom, gentities[i], coords[3 * j], coords[3 * j + 1], coords[3 * j + 2], 00513 &normals[3 * j], &normals[3 * j + 1], &normals[3 * j + 2], &result ); 00514 if( iBase_SUCCESS != result ) 00515 { 00516 printf( "Problem getting normals.\n" ); 00517 return 0; 00518 } 00519 EntityHandle vertex = vertices[j]; 00520 rval = mb->tag_get_data( idtag, &vertex, 1, &id ); 00521 printf( "v: %4d coor: %12.6f %12.6f %12.6f norm: %12.6f %12.6f %12.6f \n", id, coords[3 * j], 00522 coords[3 * j + 1], coords[3 * j + 2], normals[3 * j], normals[3 * j + 1], normals[3 * j + 2] ); 00523 ; 00524 } 00525 } 00526 00527 free( gentities ); 00528 gentities = NULL; 00529 free( out_mentities ); 00530 out_mentities = NULL; 00531 /* ok, we're done */ 00532 return 1; 00533 } 00534 00535 int main( int argc, char* argv[] ) 00536 { 00537 /* Check command line arg */ 00538 const char* geom_filename = DEFAULT_GEOM; 00539 const char* mesh_filename = DEFAULT_MESH; 00540 00541 int result; 00542 00543 iGeom_Instance geom; 00544 iMesh_Instance mesh; 00545 iRel_Instance assoc; 00546 iRel_PairHandle pair; 00547 00548 printf( "Usage: %s %s\n", geom_filename, mesh_filename ); 00549 00550 if( argc == 2 && !strcmp( argv[1], "-h" ) ) 00551 { 00552 printf( "Usage: %s <geom_filename> <mesh_filename>\n", argv[0] ); 00553 return 1; 00554 } 00555 else if( argc == 2 ) 00556 { 00557 geom_filename = argv[1]; 00558 mesh_filename = argv[1]; 00559 } 00560 else if( argc == 3 ) 00561 { 00562 geom_filename = argv[1]; 00563 mesh_filename = argv[2]; 00564 } 00565 00566 /* initialize the Geometry */ 00567 iGeom_newGeom( 0, &geom, &result, 0 ); 00568 00569 /* initialize the Mesh */ 00570 iMesh_newMesh( 0, &mesh, &result, 0 ); 00571 00572 /* initialize the Associate */ 00573 iRel_create( 0, &assoc, &result, 0 ); 00574 00575 printf( " load_geom_mesh: \n" ); 00576 result = load_geom_mesh( geom_filename, mesh_filename, geom, mesh ); 00577 00578 printf( " create_relation: \n" ); 00579 result = create_relation( assoc, geom, mesh, &pair ); 00580 00581 printf( " relate_geom_mesh: \n" ); 00582 result = relate_geom_mesh( assoc, geom, mesh, pair ); 00583 00584 /* compute normals */ 00585 printf( " compute normals: \n" ); 00586 result = compute_normals( assoc, geom, mesh, pair ); 00587 00588 /* summary */ 00589 00590 iRel_destroy( assoc, &result ); 00591 iMesh_dtor( mesh, &result ); 00592 iGeom_dtor( geom, &result ); 00593 00594 return 0; 00595 }
