add(CompositeLump *lump) | CompositeBody | |
add(BodySM *body) | CompositeBody | |
append_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeBody | [virtual] |
bodysm() | TopologyBridge | |
BodySM() | BodySM | |
bodysms(DLIList< BodySM * > &bodies, bool unique=true) | TopologyBridge | |
bounding_box() | BodySM | |
bridge_destroyed(TopologyBridge *bridge) | TBOwner | [inline, virtual] |
bridge_manager() const | TopologyBridge | |
bridge_manager(BridgeManager *manager) | TopologyBridge | |
bridge_sense() | TopologyBridge | [inline] |
coedgesms(DLIList< CoEdgeSM * > &coedgesms, bool unique=true) | TopologyBridge | |
combine(CompositeBody *other) | CompositeBody | |
CompositeBody() | CompositeBody | |
contains_bridge(TopologyBridge *bridge) const | CompositeBody | [virtual] |
curves(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
curves_ignore_virtual(DLIList< Curve * > &curves, bool unique=true) | TopologyBridge | |
firstLump | CompositeBody | [private] |
get_body(int index) const | CompositeBody | [inline] |
get_children(DLIList< TopologyBridge * > &children, bool return_hidden_entities=false, int layer=MAX_TB_LAYER) | TopologyBridge | |
get_children_virt(DLIList< TopologyBridge * > &children) | CompositeBody | [virtual] |
get_geometry_query_engine() const | CompositeBody | [virtual] |
get_parents(DLIList< TopologyBridge * > &parents) | TopologyBridge | |
get_parents_virt(DLIList< TopologyBridge * > &parents) | CompositeBody | [virtual] |
get_simple_attribute(DLIList< CubitSimpleAttrib > &attrib_list) | CompositeBody | [virtual] |
get_simple_attribute(const CubitString &name, DLIList< CubitSimpleAttrib > &attrib_list) | CompositeBody | [virtual] |
get_transforms(CubitTransformMatrix &tfm) | CompositeBody | [virtual] |
index_of(BodySM *body) const | CompositeBody | [inline] |
layer() const | CompositeBody | [inline, virtual] |
loopsm() | TopologyBridge | |
loopsms(DLIList< LoopSM * > &loopsms, bool unique=true) | TopologyBridge | |
lump() | TopologyBridge | |
lumps(DLIList< Lump * > &lumps, bool unique=true) | TopologyBridge | |
mass_properties(CubitVector ¢roid, double &volume) | CompositeBody | [virtual] |
MAX_TB_LAYER enum value | TopologyBridge | |
next_lump(CompositeLump *after_this=0) const | CompositeBody | |
notify_copied(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_joined(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_merged(TopologyBridge *dead_bridge, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_reversed(TopologyBridge *bridge) | CompositeBody | [virtual] |
notify_split(TopologyBridge *, TopologyBridge *) | TBOwner | [inline, virtual] |
notify_topology_modified(TopologyBridge *) | TBOwner | [inline, virtual] |
num_bodies() const | CompositeBody | [inline] |
owner() const | TopologyBridge | [inline] |
owner(TBOwner *new_owner) | TopologyBridge | [inline] |
point_containment(const CubitVector &pos, double tolerance=-1.0) | CompositeBody | [virtual] |
points(DLIList< TBPoint * > &points, bool unique=true) | TopologyBridge | |
realBodies | CompositeBody | [private] |
remove(CompositeLump *lump) | CompositeBody | |
remove(BodySM *body) | CompositeBody | |
remove_all_simple_attribute_virt() | CompositeBody | [virtual] |
remove_body(int index) | CompositeBody | |
remove_bridge(TopologyBridge *bridge) | CompositeBody | [virtual] |
remove_simple_attribute_virt(const CubitSimpleAttrib &simple_attrib_ptr) | CompositeBody | [virtual] |
reverse_bridge_sense() | TopologyBridge | [inline] |
shellsms(DLIList< ShellSM * > &shellsms, bool unique=true) | TopologyBridge | |
surfaces(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
surfaces_ignore_virtual(DLIList< Surface * > &surfaces, bool unique=true) | TopologyBridge | |
swap_bridge(TopologyBridge *old_tb, TopologyBridge *new_tb, bool reversed) | CompositeBody | [virtual] |
topology_entity() const | TopologyBridge | |
TopologyBridge() | TopologyBridge | [inline] |
validate(const CubitString &, DLIList< TopologyEntity * > &) | TopologyBridge | [inline, virtual] |
~BodySM() | BodySM | [virtual] |
~CompositeBody() | CompositeBody | |
~TBOwner() | TBOwner | [virtual] |
~TopologyBridge() | TopologyBridge | [virtual] |
