cgma
CubitFileUtil Member List
This is the complete list of members for CubitFileUtil, including all inherited members.
add_name_to_path(const CubitString &path, const CubitString &name)CubitFileUtil [static]
all_chars_are(char ch, const char *str)CubitFileUtil [private, static]
complete_filename(CubitString &line, int &num_additional_chars, bool &found_quote)CubitFileUtil [static]
contains_char(char ch, const char *str)CubitFileUtil [private, static]
create_directory(const CubitString &wd)CubitFileUtil [static]
CubitFileUtil()CubitFileUtil
file_info(const CubitString &path, off_t &size, time_t &modification_time, int &mode)CubitFileUtil [static]
find_home_path(const CubitString &which_user="")CubitFileUtil [static]
get_current_working_directory(CubitString &wd)CubitFileUtil [static]
get_file_extension(const CubitString &file, bool remove_version=false)CubitFileUtil [static]
get_full_path_str(const CubitString &part, CubitString &full_path)CubitFileUtil [static]
get_next_filenumber(const CubitString &filepattern, int &num_matches, int &first_match)CubitFileUtil [static]
get_nice_filename(const CubitString &path)CubitFileUtil [static]
is_absolute(const CubitString &path)CubitFileUtil [static]
is_directory(const CubitString &path)CubitFileUtil [static]
is_executable(const CubitString &path)CubitFileUtil [static]
is_int_number(const char *str)CubitFileUtil [private, static]
list_matching_files(const char *path, const char *file, std::vector< std::string > suffixes, CubitString &line)CubitFileUtil [static]
make_path_platform_compatible(const CubitString &path)CubitFileUtil [static]
path_exists(const CubitString &path)CubitFileUtil [static]
remove_file(const CubitString &file)CubitFileUtil [static]
rename_file(const CubitString &old_file, const CubitString &new_file)CubitFileUtil [static]
separator()CubitFileUtil [static]
set_current_working_directory(const CubitString &wd)CubitFileUtil [static]
split_path(const CubitString &path, CubitString &dirpart, CubitString &filepart)CubitFileUtil [static]
~CubitFileUtil()CubitFileUtil
