apd_vector_item(CubitOctreeNode *ptr_grid_node) | CubitOctree | [inline, private] |
bboxCenter | CubitOctree | [private] |
bboxDimension | CubitOctree | [private] |
bboxMaxX | CubitOctree | [private] |
bboxMaxY | CubitOctree | [private] |
bboxMaxZ | CubitOctree | [private] |
bboxMinX | CubitOctree | [private] |
bboxMinY | CubitOctree | [private] |
bboxMinZ | CubitOctree | [private] |
blackCellList | CubitOctree | [private] |
boundaryWhiteGridNodeList | CubitOctree | [private] |
build_octree_till_min_depth(CubitOctreeCell *ptr_cell) | CubitOctree | |
calculate_depth_based_on_size(double size) | CubitOctree | [private] |
capsule_distance_to_facet(const CubitVector &point, CubitFacet *lp_facet, CubitVector &int_point, CubitBoolean use_projection_only=CUBIT_FALSE) | CubitOctree | [static] |
circumcenter(CubitVector &a, CubitVector &b, CubitVector &c, CubitVector ¢er, double &radius) | CubitOctree | [private, static] |
color_octreecell(void) | CubitOctree | |
CubitOctree(CubitOctreeGenerator *lattice_gen) | CubitOctree | |
cubitOctreeGenerator | CubitOctree | [private] |
display(const int mode, int opt=0) | CubitOctree | |
epsilonBBox | CubitOctree | [private] |
establish_smooth_transition_of_cells(int max_depth) | CubitOctree | |
find_cell_list_intersecting_line_segment(const CubitVector &p0, const CubitVector &p1, DLIList< CubitOctreeCell * > &cell_list) | CubitOctree | |
find_cells_based_on_surface_angle(DLIList< CubitOctreeCell * > &refine_cell_list, DLIList< CubitFacetEdge * > &crease_edges, DLIList< CubitFacet * > &crease_facets, RefFace *one, RefFace *two, const CubitBoolean draw_facets=CUBIT_FALSE, double dihedral_angle_thresh=CUBIT_PI/2.0) | CubitOctree | |
find_intersection_between_grid_edges_and_facet(CubitOctreeType type, RefFace *ptr_face, CubitFacet *ptr_facet, DLIList< CubitOctreeNode * > &CubitOctree_grid_node_list) | CubitOctree | |
find_max_min_size_grid_node_for_scaling(void) | CubitOctree | [private] |
find_octree_cells_contained_inside_bbox(CubitFacet *ptr_facet, DLIList< CubitOctreeCell * > &CubitOctree_cell_list) | CubitOctree | |
find_octreecell(const CubitVector &pnt) | CubitOctree | |
find_radius_at_boundary_node(void) | CubitOctree | [private] |
gather_initial_grid_nodes_for_smooth_transition(DLIList< CubitOctreeNode * > &queue) | CubitOctree | [private] |
get_bbox_dimension(void) | CubitOctree | [inline, private] |
get_blackcelllist() | CubitOctree | [inline] |
get_greycelllist(void) | CubitOctree | [inline] |
get_gridnodevector(void) | CubitOctree | [inline] |
get_max_depth(void) | CubitOctree | [inline] |
get_max_size_grid_node(void) | CubitOctree | [inline] |
get_min_depth(void) | CubitOctree | [inline] |
get_min_size_grid_node(void) const | CubitOctree | [inline] |
get_root(void) | CubitOctree | [inline] |
get_scaled_from_wrld_size_grid_node(double wrld_size) | CubitOctree | |
get_whitenodelist(void) | CubitOctree | [inline] |
greyCellList | CubitOctree | [private] |
greyGridNodeVector | CubitOctree | [private] |
gridNodeVector | CubitOctree | [private] |
initialize_octree_generation(void) | CubitOctree | |
mark_cells_that_intersect_facet_plane(DLIList< CubitOctreeCell * > &CubitOctree_cell_list) | CubitOctree | [private] |
mark_positive_and_negative_octree_grid_nodes(CubitFacet *ptr_facet, DLIList< CubitOctreeCell * > &CubitOctree_cell_list, DLIList< CubitOctreeNode * > &CubitOctree_grid_node_list) | CubitOctree | |
maxDepth | CubitOctree | [private] |
maxSizeGridNode | CubitOctree | [private] |
minDepth | CubitOctree | [private] |
minSizeGridNode | CubitOctree | [private] |
point_containment(CubitVector tmp_vec, double tolerance) | CubitOctree | |
prepare_for_background_mesh() | CubitOctree | [private] |
refine_cells_to_target_depth(DLIList< CubitOctreeCell * > &refine_cell_list, const int target_depth) | CubitOctree | [private] |
release_memory(void) | CubitOctree | |
reset_internal_node_size(float value, int type) | CubitOctree | [private] |
root | CubitOctree | [private] |
set_max_depth(int max_depth) | CubitOctree | [inline] |
set_min_depth(int min_depth) | CubitOctree | [inline] |
set_status_octree_coloring(CubitBoolean type) | CubitOctree | [inline] |
size_at_a_point(const CubitVector &point, int size_type) | CubitOctree | |
statusCubitOctreeColoring | CubitOctree | [private] |
subdivide_octree_based_on_facet_point(OctreeFacetPointData *ptr_facet_point_data, int max_depth) | CubitOctree | |
subdivide_octree_cell(CubitOctreeCell *ptr_cell, DLIList< CubitOctreeNode * > *ptr_queue, int max_depth) | CubitOctree | |
subdivide_octree_from_leaf_cell(CubitOctreeCell *ptr_cell, OctreeFacetPointData *ptr_facet_point_data, int max_depth) | CubitOctree | [private] |
unmark_octree_cells_not_intersecting_with_facet(CubitFacet *ptr_facet, DLIList< CubitOctreeCell * > &CubitOctree_cell_list) | CubitOctree | [private] |
write_matlab_sizing_info_file(const char *file_name) | CubitOctree | [private] |
write_octree_sizing_info_file(const char *file_name) | CubitOctree | [private] |
write_sizing_info_file(const char *file_name) | CubitOctree | [private] |
~CubitOctree() | CubitOctree | [virtual] |
